GT 220 (GT216) and constant "Empty work server assignment"
undelete88
Post by undelete88 »
Hello, up until 3 months ago I could fold using my gpu GT 220 (GT216) just fine, then one day it stopped getting WU. I waited for it, uninstalled, reinstalled, changed drivers, looked around in the net for solutions, nothing worked. all I get is "Empty work server assignment". The cpu folds just fine.
I'm on Win8.1 x64 running the latest client.
it tries servers 171.67.108.201:80 and 171.64.65.160:80 but nada. Firewalls etc disabled and still nothing (I can connect to the servers via browser)
I need some help on what to try.
(Here's the log, I edited out the team and pc username)
*********************** Log Started 2014-08-19T22:58:10Z ***********************
22:58:10:************************* Folding@home Client *************************
22:58:10:      Website: http://folding.stanford.edu/
22:58:10:    Copyright: (c) 2009-2014 Stanford University
22:58:10:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:58:10:         Args: --open-web-control
22:58:10:       Config: C:/Users/xxx/AppData/Roaming/FAHClient/config.xml
22:58:10:******************************** Build ********************************
22:58:10:      Version: 7.4.4
22:58:10:         Date: Mar 4 2014
22:58:10:         Time: 20:26:54
22:58:10:      SVN Rev: 4130
22:58:10:       Branch: fah/trunk/client
22:58:10:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
22:58:10:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
22:58:10:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
22:58:10:     Platform: win32 XP
22:58:10:         Bits: 32
22:58:10:         Mode: Release
22:58:10:******************************* System ********************************
22:58:10:          CPU: Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz
22:58:10:       CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
22:58:10:         CPUs: 2
22:58:10:       Memory: 12.00GiB
22:58:10:  Free Memory: 10.24GiB
22:58:10:      Threads: WINDOWS_THREADS
22:58:10:   OS Version: 6.2
22:58:10:  Has Battery: false
22:58:10:   On Battery: false
22:58:10:   UTC Offset: 3
22:58:10:          PID: 3304
22:58:10:          CWD: C:/Users/xxx/AppData/Roaming/FAHClient
22:58:10:           OS: Windows 8.1 Pro
22:58:10:      OS Arch: AMD64
22:58:10:         GPUs: 1
22:58:10:        GPU 0: NVIDIA:1 GT216 [GeForce GT 220]
22:58:10:         CUDA: 1.2
22:58:10:  CUDA Driver: 6050
22:58:10:Win32 Service: false
22:58:10:***********************************************************************
22:58:10:<config>
22:58:10:  <!-- Network -->
22:58:10:  <proxy v=':8080'/>
22:58:10:
22:58:10:  <!-- Slot Control -->
22:58:10:  <power v='full'/>
22:58:10:
22:58:10:  <!-- User Information -->
22:58:10:  <passkey v='********************************'/>
22:58:10:  <team v='xxxx'/>
22:58:10:  <user v='undelete88'/>
22:58:10:
22:58:10:  <!-- Folding Slots -->
22:58:10:  <slot id='0' type='CPU'>
22:58:10:    <idle v='true'/>
22:58:10:  </slot>
22:58:10:  <slot id='1' type='GPU'>
22:58:10:  </slot>
22:58:10:</config>
22:58:10:Trying to access database...
22:58:10:Successfully acquired database lock
22:58:10:Enabled folding slot 00: PAUSED cpu:1 (waiting for idle)
22:58:10:Enabled folding slot 01: PAUSED gpu:0:GT216 [GeForce GT 220] (waiting for idle)
22:58:20:13:127.0.0.1:New Web connection
22:58:37:WU01:FS01:Connecting to 171.67.108.201:80
22:58:38:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': Empty work server assignment
22:58:38:WU01:FS01:Connecting to 171.64.65.160:80
22:58:39:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.160:80': Empty work server assignment
22:58:39:ERROR:WU01:FS01:Exception: Could not get an assignment
22:58:46:WU00:FS00:Starting
22:58:46:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/xxx/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 3304 -checkpoint 15
22:58:47:WU00:FS00:Started FahCore on PID 5412
22:58:47:WU00:FS00:Core PID:3592
22:58:47:WU00:FS00:FahCore 0xa4 started
22:58:47:WU01:FS01:Connecting to 171.67.108.201:80
22:58:47:WU00:FS00:0xa4:
22:58:47:WU00:FS00:0xa4:*------------------------------*
22:58:47:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
22:58:47:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
22:58:47:WU00:FS00:0xa4:Preparing to commence simulation
22:58:47:WU00:FS00:0xa4:- Looking at optimizations...
22:58:47:WU00:FS00:0xa4:- Files status OK
22:58:47:WU00:FS00:0xa4:- Expanded 923344 -> 1534204 (decompressed 166.1 percent)
22:58:47:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=923344 data_size=1534204, decompressed_data_size=1534204 diff=0
22:58:47:WU00:FS00:0xa4:- Digital signature verified
22:58:47:WU00:FS00:0xa4:Project: 9014 (Run 65, Clone 0, Gen 2)
22:58:47:WU00:FS00:0xa4:Assembly optimizations on if available.
22:58:47:WU00:FS00:0xa4:Entering M.D.
22:58:48:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': Empty work server assignment
22:58:48:WU01:FS01:Connecting to 171.64.65.160:80
22:58:48:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.160:80': Empty work server assignment
22:58:48:ERROR:WU01:FS01:Exception: Could not get an assignment
22:58:53:WU00:FS00:0xa4:Mapping NT from 1 to 1
22:58:54:WU00:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
22:59:11:Saving configuration to config.xml
22:59:11:<config>
22:59:11:  <!-- Network -->
22:59:11:  <proxy v=':8080'/>
22:59:11:
22:59:11:  <!-- Slot Control -->
22:59:11:  <power v='full'/>
22:59:11:
22:59:11:  <!-- User Information -->
22:59:11:  <passkey v='********************************'/>
22:59:11:  <team v='xxxxx'/>
22:59:11:  <user v='undelete88'/>
22:59:11:
22:59:11:  <!-- Folding Slots -->
22:59:11:  <slot id='0' type='CPU'/>
22:59:11:  <slot id='1' type='GPU'/>
22:59:11:</config>
22:59:48:FS00:Finishing
23:00:24:WU01:FS01:Connecting to 171.67.108.201:80
23:00:25:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': Empty work server assignment
23:00:25:WU01:FS01:Connecting to 171.64.65.160:80
23:00:26:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.160:80': Empty work server assignment
23:00:26:ERROR:WU01:FS01:Exception: Could not get an assignment
23:03:01:WU01:FS01:Connecting to 171.67.108.201:80
23:03:02:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': Empty work server assignment
23:03:02:WU01:FS01:Connecting to 171.64.65.160:80
23:03:03:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.160:80': Empty work server assignment
23:03:03:ERROR:WU01:FS01:Exception: Could not get an assignment
23:07:16:WU01:FS01:Connecting to 171.67.108.201:80
23:07:16:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': Empty work server assignment
23:07:16:WU01:FS01:Connecting to 171.64.65.160:80
23:07:17:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.160:80': Empty work server assignment
23:07:17:ERROR:WU01:FS01:Exception: Could not get an assignment
23:08:34:WU00:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
23:14:07:WU01:FS01:Connecting to 171.67.108.201:80
23:14:08:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': Empty work server assignment
23:14:08:WU01:FS01:Connecting to 171.64.65.160:80
23:14:08:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.160:80': Empty work server assignment
23:14:08:ERROR:WU01:FS01:Exception: Could not get an assignment
23:18:02:WU00:FS00:0xa4:Completed 5000 out of 250000 steps  (2%)
Any help is much appreciated.
Thank you for your time.
Re: GT 220 (GT216) and constant "Empty work server assignmen
The servers with Core_11 WU's for the older pre-Fermi GPU's had intermittent failures over the last few months. There is a longish topic discussing those outages here - viewtopic.php?f=18&t=26481. The last failure a few weeks ago appears to be final, you can read about that on pages 4 & 5 of the linked topic. Core_11 work was also announced to be end of life about a year ago.
There is apparently some recent testing of projects using Core_15 on pre-Fermi cards that you can read about in the Beta forum. A previous trial release of Core_15 WU's to pre-Fermi cards such as your Tesla based GPU had problems on some cards, so this current testing may be to see which cards are suitable for assignments. No official announcements have been made yet as to full availability of work to these older GPU's.
undelete88
Thank you very much for the information, I guess it's time for a hardware upgrade :)
Yes, time for an upgrade. Sorry.
No further developments will be made for core_11 or core_15.
