Is this GPU too weak to bother with?
willfolder
Post by willfolder »
I have an Nvidia 8400 GS, it's quite old and I am wondering if it can do any useful work?
Re: Is this GPU too weak to bother with?
Since it is a Pre-Fermi GPU, it can still fold FahCore_11 WUs. However, do note that FahCore_11 WUs have gone End Of Life (EOL) so it may be stopped sometime in the future (https://folding.stanford.edu/home/remin ... -core78-2/).
willfolder
In the Folding slots section of FAH control
the gpu is listed but status reads: Paused:no gpu access
Does this mean it is essentially idle and won't be called on to do any work?
DOes it need any specific configuration? or should I just give up and remove it from the slot?
I haven't come across that message before. Can you please post the log file including the initial section so we can see the system configuration and F@H settings? Also, what drivers are you using on your system?
willfolder
The graphics driver is NVIDIA
driver date 10/15/2011
driver version 8.17.12.8562
*********************** Log Started 2014-06-05T13:39:40Z ***********************
13:39:40:************************* Folding@home Client *************************
13:39:40:      Website: http://folding.stanford.edu/
13:39:40:    Copyright: (c) 2009-2014 Stanford University
13:39:40:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:39:40:         Args:
13:39:40:       Config: C:/ProgramData/FAHClient/config.xml
13:39:40:******************************** Build ********************************
13:39:40:      Version: 7.4.4
13:39:40:         Date: Mar 4 2014
13:39:40:         Time: 20:26:54
13:39:40:      SVN Rev: 4130
13:39:40:       Branch: fah/trunk/client
13:39:40:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
13:39:40:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
13:39:40:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
13:39:40:     Platform: win32 XP
13:39:40:         Bits: 32
13:39:40:         Mode: Release
13:39:40:******************************* System ********************************
13:39:40:          CPU: Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz
13:39:40:       CPU ID: GenuineIntel Family 6 Model 26 Stepping 5
13:39:40:         CPUs: 8
13:39:40:       Memory: 5.99GiB
13:39:40:  Free Memory: 5.04GiB
13:39:40:      Threads: WINDOWS_THREADS
13:39:40:   OS Version: 6.1
13:39:40:  Has Battery: false
13:39:40:   On Battery: false
13:39:40:   UTC Offset: 2
13:39:40:          PID: 1520
13:39:40:          CWD: C:/Windows/system32
13:39:40:           OS: Windows 7 Ultimate
13:39:40:      OS Arch: AMD64
13:39:40:         GPUs: 1
13:39:40:        GPU 0: NVIDIA:1 G98 [GeForce 8400 GS]
13:39:40:         CUDA: Not detected
13:39:40:Win32 Service: true
13:39:40:***********************************************************************
13:39:40:<config>
13:39:40:  <service-description v='Folding@home Client'/>
13:39:40:  <service-restart v='true'/>
13:39:40:  <service-restart-delay v='5000'/>
13:39:40:
13:39:40:  <!-- Client Control -->
13:39:40:  <client-threads v='6'/>
13:39:40:  <cycle-rate v='4'/>
13:39:40:  <cycles v='-1'/>
13:39:40:  <data-directory v='.'/>
13:39:40:  <disable-sleep-when-active v='true'/>
13:39:40:  <exec-directory v='C:\Program Files (x86)\FAHClient'/>
13:39:40:  <exit-when-done v='false'/>
13:39:40:  <fold-anon v='false'/>
13:39:40:  <open-web-control v='false'/>
13:39:40:
13:39:40:  <!-- Configuration -->
13:39:40:  <config-rotate v='true'/>
13:39:40:  <config-rotate-dir v='configs'/>
13:39:40:  <config-rotate-max v='16'/>
13:39:40:
13:39:40:  <!-- Debugging -->
13:39:40:  <assignment-servers>
13:39:40:    assign3.stanford.edu:8080 assign4.stanford.edu:80
13:39:40:  </assignment-servers>
13:39:40:  <auth-as v='true'/>
13:39:40:  <capture-directory v='capture'/>
13:39:40:  <capture-on-error v='false'/>
13:39:40:  <capture-packets v='false'/>
13:39:40:  <capture-requests v='false'/>
13:39:40:  <capture-responses v='false'/>
13:39:40:  <capture-sockets v='false'/>
13:39:40:  <core-exec v='FahCore_$type'/>
13:39:40:  <core-wrapper-exec v='FAHCoreWrapper'/>
13:39:40:  <debug-sockets v='false'/>
13:39:40:  <exception-locations v='true'/>
13:39:40:  <gpu-assignment-servers>
13:39:40:    assign-GPU.stanford.edu:80 assign-GPU2.stanford.edu:80
13:39:40:  </gpu-assignment-servers>
13:39:40:  <stack-traces v='false'/>
13:39:40:
13:39:40:  <!-- Error Handling -->
13:39:40:  <max-slot-errors v='10'/>
13:39:40:  <max-unit-errors v='5'/>
13:39:40:
13:39:40:  <!-- Folding Core -->
13:39:40:  <checkpoint v='21'/>
13:39:40:  <core-dir v='cores'/>
13:39:40:  <core-priority v='idle'/>
13:39:40:  <cpu-affinity v='false'/>
13:39:40:  <cpu-usage v='100'/>
13:39:40:  <gpu-usage v='100'/>
13:39:40:  <no-assembly v='false'/>
13:39:40:
13:39:40:  <!-- Folding Slot Configuration -->
13:39:40:  <cause v='ANY'/>
13:39:40:  <client-subtype v='STDCLI'/>
13:39:40:  <client-type v='normal'/>
13:39:40:  <cpu-species v='X86_PENTIUM_II'/>
13:39:40:  <cpu-type v='AMD64'/>
13:39:40:  <cpus v='-1'/>
13:39:40:  <gpu v='true'/>
13:39:40:  <max-packet-size v='normal'/>
13:39:40:  <os-species v='UNKNOWN'/>
13:39:40:  <os-type v='WIN32'/>
13:39:40:  <project-key v='0'/>
13:39:40:  <smp v='true'/>
13:39:40:
13:39:40:  <!-- GUI -->
13:39:40:  <gui-enabled v='true'/>
13:39:40:
13:39:40:  <!-- HTTP Server -->
13:39:40:  <allow v='127.0.0.1'/>
13:39:40:  <connection-timeout v='60'/>
13:39:40:  <deny v='0/0'/>
13:39:40:  <http-addresses v='0:7396'/>
13:39:40:  <https-addresses v=''/>
13:39:40:  <max-connect-time v='900'/>
13:39:40:  <max-connections v='800'/>
13:39:40:  <max-request-length v='52428800'/>
13:39:40:  <min-connect-time v='300'/>
13:39:40:  <threads v='8'/>
13:39:40:
13:39:40:  <!-- Logging -->
13:39:40:  <log v='log.txt'/>
13:39:40:  <log-color v='false'/>
13:39:40:  <log-crlf v='true'/>
13:39:40:  <log-date v='false'/>
13:39:40:  <log-date-periodically v='21600'/>
13:39:40:  <log-debug v='true'/>
13:39:40:  <log-domain v='false'/>
13:39:40:  <log-header v='true'/>
13:39:40:  <log-level v='true'/>
13:39:40:  <log-no-info-header v='true'/>
13:39:40:  <log-redirect v='false'/>
13:39:40:  <log-rotate v='true'/>
13:39:40:  <log-rotate-dir v='logs'/>
13:39:40:  <log-rotate-max v='16'/>
13:39:40:  <log-short-level v='false'/>
13:39:40:  <log-simple-domains v='true'/>
13:39:40:  <log-thread-id v='false'/>
13:39:40:  <log-thread-prefix v='true'/>
13:39:40:  <log-time v='true'/>
13:39:40:  <log-to-screen v='true'/>
13:39:40:  <log-truncate v='false'/>
13:39:40:  <verbosity v='5'/>
13:39:40:
13:39:40:  <!-- Network -->
13:39:40:  <proxy v=':8080'/>
13:39:40:  <proxy-enable v='false'/>
13:39:40:  <proxy-pass v=''/>
13:39:40:  <proxy-user v=''/>
13:39:40:
13:39:40:  <!-- Process Control -->
13:39:40:  <child v='false'/>
13:39:40:  <daemon v='false'/>
13:39:40:  <pid v='false'/>
13:39:40:  <pid-file v='Folding@home Client.pid'/>
13:39:40:  <respawn v='false'/>
13:39:40:  <service v='true'/>
13:39:40:
13:39:40:  <!-- Remote Command Server -->
13:39:40:  <command-address v='0.0.0.0'/>
13:39:40:  <command-allow-no-pass v='127.0.0.1'/>
13:39:40:  <command-deny-no-pass v='0/0'/>
13:39:40:  <command-enable v='true'/>
13:39:40:  <command-port v='36330'/>
13:39:40:
13:39:40:  <!-- Slot Control -->
13:39:40:  <idle v='false'/>
13:39:40:  <max-shutdown-wait v='60'/>
13:39:40:  <pause-on-battery v='true'/>
13:39:40:  <pause-on-start v='false'/>
13:39:40:  <paused v='false'/>
13:39:40:  <power v='full'/>
13:39:40:
13:39:40:  <!-- User Information -->
13:39:40:  <machine-id v='0'/>
13:39:40:  <passkey v='********************************'/>
13:39:40:  <team v='0'/>
13:39:40:  <user v='willfolder'/>
13:39:40:
13:39:40:  <!-- Web Server -->
13:39:40:  <web-allow v='127.0.0.1'/>
13:39:40:  <web-deny v='0/0'/>
13:39:40:  <web-enable v='true'/>
13:39:40:
13:39:40:  <!-- Web Server Sessions -->
13:39:40:  <session-cookie v='sid'/>
13:39:40:  <session-lifetime v='86400'/>
13:39:40:  <session-timeout v='3600'/>
13:39:40:
13:39:40:  <!-- Work Unit Control -->
13:39:40:  <dump-after-deadline v='true'/>
13:39:40:  <max-queue v='16'/>
13:39:40:  <max-units v='0'/>
13:39:40:  <next-unit-percentage v='99'/>
13:39:40:  <stall-detection-enabled v='false'/>
13:39:40:  <stall-percent v='5'/>
13:39:40:  <stall-timeout v='1800'/>
13:39:40:
13:39:40:  <!-- Folding Slots -->
13:39:40:  <slot id='0' type='CPU'>
13:39:40:    <paused v='true'/>
13:39:40:  </slot>
13:39:40:</config>
13:39:40:Trying to access database...
13:39:40:Successfully acquired database lock
13:39:40:Enabled folding slot 00: PAUSED cpu:8 (by user)
13:39:42:Started thread 7 on PID 1520
13:39:42:Started thread 5 on PID 1520
13:39:42:Started thread 9 on PID 1520
13:39:42:Started thread 6 on PID 1520
13:39:42:Started thread 8 on PID 1520
13:39:42:Started thread 4 on PID 1520
13:41:10:Started thread 10 on PID 1520
13:41:13:FS00:Unpaused
13:41:13:WU01:FS00:Starting
13:41:13:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 1520 -checkpoint 21 -np 8 -service
13:41:14:WU01:FS00:Started FahCore on PID 2700
13:41:14:Started thread 11 on PID 1520
13:41:14:WU01:FS00:Core PID:2444
13:41:14:WU01:FS00:FahCore 0xa4 started
13:41:14:WU01:FS00:0xa4:
13:41:14:WU01:FS00:0xa4:*------------------------------*
13:41:14:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
13:41:14:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
13:41:14:WU01:FS00:0xa4:Preparing to commence simulation
13:41:14:WU01:FS00:0xa4:- Ensuring status. Please wait.
13:41:23:WU01:FS00:0xa4:- Looking at optimizations...
13:41:23:WU01:FS00:0xa4:- Working with standard loops on this execution.
13:41:23:WU01:FS00:0xa4:- Previous termination of core was improper.
13:41:23:WU01:FS00:0xa4:- Going to use standard loops.
13:41:23:WU01:FS00:0xa4:- Files status OK
13:41:24:WU01:FS00:0xa4:- Expanded 117264 -> 264000 (decompressed 225.1 percent)
13:41:24:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=117264 data_size=264000, decompressed_data_size=264000 diff=0
13:41:24:WU01:FS00:0xa4:- Digital signature verified
13:41:24:WU01:FS00:0xa4:Project: 6370 (Run 43, Clone 71, Gen 6)
13:41:24:WU01:FS00:0xa4:Entering M.D.
13:41:30:WU01:FS00:0xa4:Using Gromacs checkpoints
13:41:30:WU01:FS00:0xa4:Mapping NT from 8 to 8
13:41:30:WU01:FS00:0xa4:Resuming from checkpoint
13:41:30:WU01:FS00:0xa4:Verified 01/wudata_01.log
13:41:30:WU01:FS00:0xa4:Verified 01/wudata_01.trr
13:41:30:WU01:FS00:0xa4:Verified 01/wudata_01.xtc
13:41:30:WU01:FS00:0xa4:Verified 01/wudata_01.edr
13:41:30:WU01:FS00:0xa4:Completed 3992310 out of 5000000 steps  (79%)
13:41:42:Removing old file 'configs/config-20140531-093344.xml'
13:41:42:Saving configuration to config.xml
13:41:42:<config>
13:41:42:  <!-- Folding Core -->
13:41:42:  <checkpoint v='21'/>
13:41:42:
13:41:42:  <!-- Logging -->
13:41:42:  <verbosity v='5'/>
13:41:42:
13:41:42:  <!-- Network -->
13:41:42:  <proxy v=':8080'/>
13:41:42:
13:41:42:  <!-- Slot Control -->
13:41:42:  <power v='full'/>
13:41:42:
13:41:42:  <!-- User Information -->
13:41:42:  <passkey v='********************************'/>
13:41:42:  <user v='willfolder'/>
13:41:42:
13:41:42:  <!-- Folding Slots -->
13:41:42:  <slot id='0' type='CPU'/>
13:41:42:</config>
13:41:51:WU01:FS00:0xa4:Completed 4000000 out of 5000000 steps  (80%)
14:25:01:WU01:FS00:0xa4:Completed 4950000 out of 5000000 steps  (99%)
14:25:02:WU00:FS00:Connecting to 171.67.108.200:8080
14:25:04:WU00:FS00:Assigned to work server 171.67.108.60
14:25:04:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:8 from 171.67.108.60
14:25:04:WU00:FS00:Connecting to 171.67.108.60:8080
14:25:05:WU00:FS00:Downloading 532.56KiB
14:25:10:WU00:FS00:Download complete
14:25:10:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9500 run:2094 clone:1 gen:111 core:0xa4 unit:0x000000786652edcc53642ed1845c5ce0
14:27:10:WU01:FS00:0xa4:Completed 5000000 out of 5000000 steps  (100%)
14:27:10:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
14:27:20:WU01:FS00:0xa4:
14:27:20:WU01:FS00:0xa4:Finished Work Unit:
14:27:20:WU01:FS00:0xa4:- Reading up to 1249776 from "01/wudata_01.trr": Read 1249776
14:27:20:WU01:FS00:0xa4:trr file hash check passed.
14:27:20:WU01:FS00:0xa4:- Reading up to 102972 from "01/wudata_01.xtc": Read 102972
14:27:20:WU01:FS00:0xa4:xtc file hash check passed.
14:27:20:WU01:FS00:0xa4:edr file hash check passed.
14:27:20:WU01:FS00:0xa4:logfile size: 89620
14:27:20:WU01:FS00:0xa4:Leaving Run
14:27:24:WU01:FS00:0xa4:- Writing 1514268 bytes of core data to disk...
14:27:24:WU01:FS00:0xa4:Done: 1513756 -> 1278794 (compressed to 84.4 percent)
14:27:24:WU01:FS00:0xa4:  ... Done.
14:27:25:WU01:FS00:0xa4:- Shutting down core
14:27:25:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
14:27:25:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:27:25:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:6370 run:43 clone:71 gen:6 core:0xa4 unit:0x000000060002894b533434baf993d488
14:27:25:WU01:FS00:Uploading 1.22MiB to 155.247.166.219
14:27:25:WU00:FS00:Starting
14:27:25:WU01:FS00:Connecting to 155.247.166.219:8080
14:27:25:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 1520 -checkpoint 21 -np 8 -service
14:27:25:WU00:FS00:Started FahCore on PID 2236
14:27:25:Started thread 12 on PID 1520
14:27:26:WU00:FS00:Core PID:2948
14:27:26:WU00:FS00:FahCore 0xa4 started
14:27:26:WU00:FS00:0xa4:
14:27:26:WU00:FS00:0xa4:*------------------------------*
14:27:26:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
14:27:26:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
14:27:26:WU00:FS00:0xa4:Preparing to commence simulation
14:27:26:WU00:FS00:0xa4:- Looking at optimizations...
14:27:26:WU00:FS00:0xa4:- Created dyn
14:27:26:WU00:FS00:0xa4:- Files status OK
14:27:26:WU00:FS00:0xa4:- Expanded 544834 -> 1305980 (decompressed 239.7 percent)
14:27:26:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=544834 data_size=1305980, decompressed_data_size=1305980 diff=0
14:27:26:WU00:FS00:0xa4:- Digital signature verified
14:27:26:WU00:FS00:0xa4:Project: 9500 (Run 2094, Clone 1, Gen 111)
14:27:26:WU00:FS00:0xa4:Assembly optimizations on if available.
14:27:26:WU00:FS00:0xa4:Entering M.D.
14:27:31:WU01:FS00:Upload 20.49%
14:27:32:WU00:FS00:0xa4:Mapping NT from 8 to 8
14:27:32:WU00:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
14:27:37:WU01:FS00:Upload 46.10%
14:27:43:WU01:FS00:Upload 71.72%
14:27:49:WU01:FS00:Upload 97.33%
14:27:50:WU01:FS00:Upload complete
14:27:50:WU01:FS00:Server responded WORK_ACK (400)
14:27:50:WU01:FS00:Final credit estimate, 1739.00 points
14:27:50:WU01:FS00:Cleaning up
14:28:20:WU00:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
15:49:45:WU00:FS00:0xa4:Completed 247500 out of 250000 steps  (99%)
15:49:47:WU01:FS00:Connecting to 171.67.108.200:8080
15:49:48:WU01:FS00:Assigned to work server 171.67.108.60
15:49:48:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:8 from 171.67.108.60
15:49:48:WU01:FS00:Connecting to 171.67.108.60:8080
15:49:50:WU01:FS00:Downloading 532.34KiB
15:49:55:WU01:FS00:Download complete
15:49:55:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9500 run:3387 clone:0 gen:101 core:0xa4 unit:0x0000006d6652edcc5364312f6c734685
15:50:45:WU00:FS00:0xa4:Completed 250000 out of 250000 steps  (100%)
15:50:45:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
15:50:55:WU00:FS00:0xa4:
15:50:55:WU00:FS00:0xa4:Finished Work Unit:
15:50:55:WU00:FS00:0xa4:- Reading up to 513504 from "00/wudata_01.trr": Read 513504
15:50:55:WU00:FS00:0xa4:trr file hash check passed.
15:50:55:WU00:FS00:0xa4:- Reading up to 456792 from "00/wudata_01.xtc": Read 456792
15:50:55:WU00:FS00:0xa4:xtc file hash check passed.
15:50:55:WU00:FS00:0xa4:edr file hash check passed.
15:50:55:WU00:FS00:0xa4:logfile size: 22637
15:50:55:WU00:FS00:0xa4:Leaving Run
15:51:00:WU00:FS00:0xa4:- Writing 998337 bytes of core data to disk...
15:51:00:WU00:FS00:0xa4:Done: 997825 -> 959711 (compressed to 96.1 percent)
15:51:00:WU00:FS00:0xa4:  ... Done.
15:51:01:WU00:FS00:0xa4:- Shutting down core
15:51:01:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
15:51:02:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:51:02:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9500 run:2094 clone:1 gen:111 core:0xa4 unit:0x000000786652edcc53642ed1845c5ce0
15:51:02:WU00:FS00:Uploading 937.72KiB to 171.67.108.60
15:51:02:WU01:FS00:Starting
15:51:02:WU00:FS00:Connecting to 171.67.108.60:8080
15:51:02:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 1520 -checkpoint 21 -np 8 -service
15:51:02:WU01:FS00:Started FahCore on PID 4884
15:51:02:Started thread 13 on PID 1520
15:51:02:WU01:FS00:Core PID:4988
15:51:02:WU01:FS00:FahCore 0xa4 started
15:51:02:WU01:FS00:0xa4:
15:51:02:WU01:FS00:0xa4:*------------------------------*
15:51:02:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
15:51:02:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
15:51:02:WU01:FS00:0xa4:Preparing to commence simulation
15:51:02:WU01:FS00:0xa4:- Looking at optimizations...
15:51:02:WU01:FS00:0xa4:- Created dyn
15:51:02:WU01:FS00:0xa4:- Files status OK
15:51:02:WU01:FS00:0xa4:- Expanded 544606 -> 1305548 (decompressed 239.7 percent)
15:51:02:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=544606 data_size=1305548, decompressed_data_size=1305548 diff=0
15:51:02:WU01:FS00:0xa4:- Digital signature verified
15:51:02:WU01:FS00:0xa4:Project: 9500 (Run 3387, Clone 0, Gen 101)
15:51:02:WU01:FS00:0xa4:Assembly optimizations on if available.
15:51:02:WU01:FS00:0xa4:Entering M.D.
15:51:08:WU01:FS00:0xa4:Mapping NT from 8 to 8
15:51:09:WU01:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
15:51:10:WU00:FS00:Upload 20.48%
15:51:18:WU00:FS00:Upload 40.95%
15:51:24:WU00:FS00:Upload 61.43%
15:51:31:WU00:FS00:Upload 81.90%
15:51:37:WU00:FS00:Upload 100.00%
15:51:38:WU00:FS00:Upload complete
15:51:38:WU00:FS00:Server responded WORK_ACK (400)
15:51:38:WU00:FS00:Final credit estimate, 710.00 points
15:51:38:WU00:FS00:Cleaning up
15:52:12:WU01:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
17:16:43:WU01:FS00:0xa4:Completed 247500 out of 250000 steps  (99%)
17:16:45:WU00:FS00:Connecting to 171.67.108.200:8080
17:16:47:WU00:FS00:Assigned to work server 171.67.108.60
17:16:47:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:8 from 171.67.108.60
17:16:47:WU00:FS00:Connecting to 171.67.108.60:8080
17:16:48:WU00:FS00:Downloading 532.10KiB
17:16:54:WU00:FS00:Download 12.03%
17:17:01:WU00:FS00:Download 36.08%
17:17:08:WU00:FS00:Download 84.19%
17:17:10:WU00:FS00:Download complete
17:17:10:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9500 run:1194 clone:0 gen:135 core:0xa4 unit:0x000000936652edcc53642d26fc40ffaf
17:17:34:WU01:FS00:0xa4:Completed 250000 out of 250000 steps  (100%)
17:17:35:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
17:17:45:WU01:FS00:0xa4:
17:17:45:WU01:FS00:0xa4:Finished Work Unit:
17:17:45:WU01:FS00:0xa4:- Reading up to 513288 from "01/wudata_01.trr": Read 513288
17:17:45:WU01:FS00:0xa4:trr file hash check passed.
17:17:45:WU01:FS00:0xa4:- Reading up to 456384 from "01/wudata_01.xtc": Read 456384
17:17:45:WU01:FS00:0xa4:xtc file hash check passed.
17:17:45:WU01:FS00:0xa4:edr file hash check passed.
17:17:45:WU01:FS00:0xa4:logfile size: 22699
17:17:45:WU01:FS00:0xa4:Leaving Run
17:17:46:WU01:FS00:0xa4:- Writing 997775 bytes of core data to disk...
17:17:47:WU01:FS00:0xa4:Done: 997263 -> 959149 (compressed to 96.1 percent)
17:17:47:WU01:FS00:0xa4:  ... Done.
17:17:48:WU01:FS00:0xa4:- Shutting down core
17:17:48:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
17:17:48:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
17:17:48:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:9500 run:3387 clone:0 gen:101 core:0xa4 unit:0x0000006d6652edcc5364312f6c734685
17:17:48:WU01:FS00:Uploading 937.17KiB to 171.67.108.60
17:17:48:WU00:FS00:Starting
17:17:48:WU01:FS00:Connecting to 171.67.108.60:8080
17:17:48:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 1520 -checkpoint 21 -np 8 -service
17:17:48:WU00:FS00:Started FahCore on PID 2240
17:17:48:Started thread 14 on PID 1520
17:17:48:WU00:FS00:Core PID:6044
17:17:48:WU00:FS00:FahCore 0xa4 started
17:17:49:WU00:FS00:0xa4:
17:17:49:WU00:FS00:0xa4:*------------------------------*
17:17:49:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
17:17:49:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
17:17:49:WU00:FS00:0xa4:Preparing to commence simulation
17:17:49:WU00:FS00:0xa4:- Looking at optimizations...
17:17:49:WU00:FS00:0xa4:- Created dyn
17:17:49:WU00:FS00:0xa4:- Files status OK
17:17:49:WU00:FS00:0xa4:- Expanded 544361 -> 1304828 (decompressed 239.6 percent)
17:17:49:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=544361 data_size=1304828, decompressed_data_size=1304828 diff=0
17:17:49:WU00:FS00:0xa4:- Digital signature verified
17:17:49:WU00:FS00:0xa4:Project: 9500 (Run 1194, Clone 0, Gen 135)
17:17:49:WU00:FS00:0xa4:Assembly optimizations on if available.
17:17:49:WU00:FS00:0xa4:Entering M.D.
17:17:55:WU00:FS00:0xa4:Mapping NT from 8 to 8
17:17:55:WU00:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
17:17:57:WU01:FS00:Upload 6.83%
17:18:05:WU01:FS00:Upload 20.49%
17:18:12:WU01:FS00:Upload 34.15%
17:18:21:WU01:FS00:Upload 47.80%
17:18:27:WU01:FS00:Upload 61.46%
17:18:34:WU01:FS00:Upload 75.12%
17:18:40:WU01:FS00:Upload 88.78%
17:18:46:WU01:FS00:Upload 95.61%
17:18:47:WU00:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
17:18:49:WU01:FS00:Upload complete
17:18:49:WU01:FS00:Server responded WORK_ACK (400)
17:18:49:WU01:FS00:Final credit estimate, 701.00 points
17:18:49:WU01:FS00:Cleaning up
17:19:38:WU00:FS00:0xa4:Completed 5000 out of 250000 steps  (2%)
18:39:54:WU00:FS00:0xa4:Completed 247500 out of 250000 steps  (99%)
18:39:56:WU01:FS00:Connecting to 171.67.108.200:8080
18:39:57:WU01:FS00:Assigned to work server 155.247.166.219
18:39:57:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:8 from 155.247.166.219
18:39:57:WU01:FS00:Connecting to 155.247.166.219:8080
18:39:59:WU01:FS00:Downloading 115.01KiB
18:40:01:WU01:FS00:Download complete
18:40:01:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:6370 run:8 clone:68 gen:6 core:0xa4 unit:0x000000090002894b53343324b0135f89
18:40:43:WU00:FS00:0xa4:Completed 250000 out of 250000 steps  (100%)
18:40:43:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
18:40:53:WU00:FS00:0xa4:
18:40:53:WU00:FS00:0xa4:Finished Work Unit:
18:40:53:WU00:FS00:0xa4:- Reading up to 512928 from "00/wudata_01.trr": Read 512928
18:40:53:WU00:FS00:0xa4:trr file hash check passed.
18:40:53:WU00:FS00:0xa4:- Reading up to 456016 from "00/wudata_01.xtc": Read 456016
18:40:53:WU00:FS00:0xa4:xtc file hash check passed.
18:40:53:WU00:FS00:0xa4:edr file hash check passed.
18:40:53:WU00:FS00:0xa4:logfile size: 22638
18:40:53:WU00:FS00:0xa4:Leaving Run
18:40:58:WU00:FS00:0xa4:- Writing 996986 bytes of core data to disk...
18:40:58:WU00:FS00:0xa4:Done: 996474 -> 958389 (compressed to 96.1 percent)
18:40:58:WU00:FS00:0xa4:  ... Done.
18:40:59:WU00:FS00:0xa4:- Shutting down core
18:40:59:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
18:40:59:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:41:00:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9500 run:1194 clone:0 gen:135 core:0xa4 unit:0x000000936652edcc53642d26fc40ffaf
18:41:00:WU00:FS00:Uploading 936.43KiB to 171.67.108.60
18:41:00:WU01:FS00:Starting
18:41:00:WU00:FS00:Connecting to 171.67.108.60:8080
18:41:00:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 1520 -checkpoint 21 -np 8 -service
18:41:00:WU01:FS00:Started FahCore on PID 4136
18:41:00:Started thread 15 on PID 1520
18:41:00:WU01:FS00:Core PID:716
18:41:00:WU01:FS00:FahCore 0xa4 started
18:41:00:WU01:FS00:0xa4:
18:41:00:WU01:FS00:0xa4:*------------------------------*
18:41:00:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
18:41:00:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
18:41:00:WU01:FS00:0xa4:Preparing to commence simulation
18:41:00:WU01:FS00:0xa4:- Looking at optimizations...
18:41:00:WU01:FS00:0xa4:- Created dyn
18:41:00:WU01:FS00:0xa4:- Files status OK
18:41:00:WU01:FS00:0xa4:- Expanded 117256 -> 264000 (decompressed 225.1 percent)
18:41:00:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=117256 data_size=264000, decompressed_data_size=264000 diff=0
18:41:00:WU01:FS00:0xa4:- Digital signature verified
18:41:00:WU01:FS00:0xa4:Project: 6370 (Run 8, Clone 68, Gen 6)
18:41:00:WU01:FS00:0xa4:Assembly optimizations on if available.
18:41:00:WU01:FS00:0xa4:Entering M.D.
18:41:06:WU01:FS00:0xa4:Mapping NT from 8 to 8
18:41:06:WU01:FS00:0xa4:Completed 0 out of 5000000 steps  (0%)
18:41:08:WU00:FS00:Upload 6.83%
18:41:16:WU00:FS00:Upload 20.50%
18:41:24:WU00:FS00:Upload 34.17%
18:41:30:WU00:FS00:Upload 47.84%
18:41:36:WU00:FS00:Upload 61.51%
18:41:43:WU00:FS00:Upload 75.18%
18:41:52:WU00:FS00:Upload 88.85%
18:42:01:WU00:FS00:Upload 100.00%
18:42:02:WU00:FS00:Upload complete
18:42:02:WU00:FS00:Server responded WORK_ACK (400)
18:42:02:WU00:FS00:Final credit estimate, 716.00 points
18:42:02:WU00:FS00:Cleaning up
18:43:20:WU01:FS00:0xa4:Completed 50000 out of 5000000 steps  (1%)
21:37:08:WU01:FS00:0xa4:Completed 3950000 out of 5000000 steps  (79%)
21:40:14:WARNING:WU01:FS00:Detected clock skew (1 mins 07 secs), adjusting time estimates
21:40:14:Started thread 16 on PID 1520
21:40:27:WU01:FS00:0xa4:Completed 4000000 out of 5000000 steps  (80%)
22:22:14:WU01:FS00:0xa4:Completed 4950000 out of 5000000 steps  (99%)
22:22:16:WU00:FS00:Connecting to 171.67.108.200:8080
22:22:18:WU00:FS00:Assigned to work server 128.143.231.202
22:22:18:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:8 from 128.143.231.202
22:22:18:WU00:FS00:Connecting to 128.143.231.202:8080
22:22:20:WU00:FS00:Downloading 3.67MiB
22:22:26:WU00:FS00:Download 32.35%
22:22:32:WU00:FS00:Download 66.40%
22:22:38:WU00:FS00:Download 100.00%
22:22:38:WU00:FS00:Download complete
22:22:38:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8567 run:1 clone:4 gen:433 core:0xa3 unit:0x000018e70a3b1e5952278a08572d5ce5
22:24:26:WU01:FS00:0xa4:Completed 5000000 out of 5000000 steps  (100%)
22:24:27:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
22:24:37:WU01:FS00:0xa4:
22:24:37:WU01:FS00:0xa4:Finished Work Unit:
22:24:37:WU01:FS00:0xa4:- Reading up to 1249776 from "01/wudata_01.trr": Read 1249776
22:24:37:WU01:FS00:0xa4:trr file hash check passed.
22:24:37:WU01:FS00:0xa4:- Reading up to 103336 from "01/wudata_01.xtc": Read 103336
22:24:37:WU01:FS00:0xa4:xtc file hash check passed.
22:24:37:WU01:FS00:0xa4:edr file hash check passed.
22:24:37:WU01:FS00:0xa4:logfile size: 86995
22:24:37:WU01:FS00:0xa4:Leaving Run
22:24:39:WU01:FS00:0xa4:- Writing 1512007 bytes of core data to disk...
22:24:39:WU01:FS00:0xa4:Done: 1511495 -> 1278433 (compressed to 84.5 percent)
22:24:39:WU01:FS00:0xa4:  ... Done.
22:24:40:WU01:FS00:0xa4:- Shutting down core
22:24:40:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
22:24:40:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:24:40:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:6370 run:8 clone:68 gen:6 core:0xa4 unit:0x000000090002894b53343324b0135f89
22:24:40:WU01:FS00:Uploading 1.22MiB to 155.247.166.219
22:24:40:WU00:FS00:Starting
22:24:40:WU01:FS00:Connecting to 155.247.166.219:8080
22:24:40:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 704 -lifeline 1520 -checkpoint 21 -np 8 -service
22:24:40:WU00:FS00:Started FahCore on PID 5000
22:24:40:Started thread 17 on PID 1520
22:24:41:WU00:FS00:Core PID:5164
22:24:41:WU00:FS00:FahCore 0xa3 started
22:24:41:WU00:FS00:0xa3:
22:24:41:WU00:FS00:0xa3:*------------------------------*
22:24:41:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
22:24:41:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
22:24:41:WU00:FS00:0xa3:Preparing to commence simulation
22:24:41:WU00:FS00:0xa3:- Looking at optimizations...
22:24:41:WU00:FS00:0xa3:- Created dyn
22:24:41:WU00:FS00:0xa3:- Files status OK
22:24:41:WU00:FS00:0xa3:- Expanded 3848522 -> 4383072 (decompressed 113.8 percent)
22:24:41:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3848522 data_size=4383072, decompressed_data_size=4383072 diff=0
22:24:41:WU00:FS00:0xa3:- Digital signature verified
22:24:41:WU00:FS00:0xa3:Project: 8567 (Run 1, Clone 4, Gen 433)
22:24:41:WU00:FS00:0xa3:Assembly optimizations on if available.
22:24:41:WU00:FS00:0xa3:Entering M.D.
22:24:46:WU01:FS00:Upload 20.50%
22:24:47:WU00:FS00:0xa3:Mapping NT from 8 to 8
22:24:48:WU00:FS00:0xa3:Completed 0 out of 500000 steps  (0%)
22:24:52:WU01:FS00:Upload 46.12%
22:24:58:WU01:FS00:Upload 71.74%
22:25:04:WU01:FS00:Upload 97.36%
22:25:05:WU01:FS00:Upload complete
22:25:05:WU01:FS00:Server responded WORK_ACK (400)
22:25:05:WU01:FS00:Final credit estimate, 2035.00 points
22:25:05:WU01:FS00:Cleaning up
22:36:23:WU00:FS00:0xa3:Completed 5000 out of 500000 steps  (1%)
00:14:38:WU00:FS00:0xa3:Completed 45000 out of 500000 steps  (9%)
00:23:52:FS00:Paused
00:23:52:FS00:Shutting core down
00:23:52:WARNING:FS00:FahCore not accepting gentle shutdown, killing
00:23:52:WARNING:FS00:Killing WU00
00:23:52:WU00:FS00:FahCore terminated
00:23:55:Removing old file 'configs/config-20140604-212930.xml'
00:23:55:Saving configuration to config.xml
00:23:55:<config>
00:23:55:  <!-- Folding Core -->
00:23:55:  <checkpoint v='21'/>
00:23:55:
00:23:55:  <!-- Logging -->
00:23:55:  <verbosity v='5'/>
00:23:55:
00:23:55:  <!-- Network -->
00:23:55:  <proxy v=':8080'/>
00:23:55:
00:23:55:  <!-- Slot Control -->
00:23:55:  <power v='full'/>
00:23:55:
00:23:55:  <!-- User Information -->
00:23:55:  <passkey v='********************************'/>
00:23:55:  <user v='willfolder'/>
00:23:55:
00:23:55:  <!-- Folding Slots -->
00:23:55:  <slot id='0' type='CPU'>
00:23:55:    <paused v='true'/>
00:23:55:  </slot>
00:23:55:</config>
00:24:56:FS00:Unpaused
00:24:56:WU00:FS00:Starting
00:24:56:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 704 -lifeline 1520 -checkpoint 21 -np 8 -service
00:24:56:WU00:FS00:Started FahCore on PID 5480
00:24:56:Started thread 18 on PID 1520
00:24:56:WU00:FS00:Core PID:3612
00:24:56:WU00:FS00:FahCore 0xa3 started
00:24:57:WU00:FS00:0xa3:
00:24:57:WU00:FS00:0xa3:*------------------------------*
00:24:57:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
00:24:57:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
00:24:57:WU00:FS00:0xa3:Preparing to commence simulation
00:24:57:WU00:FS00:0xa3:- Ensuring status. Please wait.
00:25:06:WU00:FS00:0xa3:- Looking at optimizations...
00:25:06:WU00:FS00:0xa3:- Working with standard loops on this execution.
00:25:06:WU00:FS00:0xa3:- Previous termination of core was improper.
00:25:06:WU00:FS00:0xa3:- Files status OK
00:25:06:WU00:FS00:0xa3:- Expanded 3848522 -> 4383072 (decompressed 113.8 percent)
00:25:06:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3848522 data_size=4383072, decompressed_data_size=4383072 diff=0
00:25:06:WU00:FS00:0xa3:- Digital signature verified
00:25:06:WU00:FS00:0xa3:Project: 8567 (Run 1, Clone 4, Gen 433)
00:25:06:WU00:FS00:0xa3:Entering M.D.
00:25:12:WU00:FS00:0xa3:Using Gromacs checkpoints
00:25:13:WU00:FS00:0xa3:Mapping NT from 8 to 8
00:25:13:WU00:FS00:0xa3:Resuming from checkpoint
00:25:13:WU00:FS00:0xa3:Verified 00/wudata_01.log
00:25:13:WU00:FS00:0xa3:Verified 00/wudata_01.trr
00:25:13:WU00:FS00:0xa3:Verified 00/wudata_01.edr
00:25:14:WU00:FS00:0xa3:Completed 42930 out of 500000 steps  (8%)
00:25:57:Removing old file 'configs/config-20140604-213132.xml'
00:25:57:Saving configuration to config.xml
00:25:57:<config>
00:25:57:  <!-- Folding Core -->
00:25:57:  <checkpoint v='21'/>
00:25:57:
00:25:57:  <!-- Logging -->
00:25:57:  <verbosity v='5'/>
00:25:57:
00:25:57:  <!-- Network -->
00:25:57:  <proxy v=':8080'/>
00:25:57:
00:25:57:  <!-- Slot Control -->
00:25:57:  <power v='full'/>
00:25:57:
00:25:57:  <!-- User Information -->
00:25:57:  <passkey v='********************************'/>
00:25:57:  <user v='willfolder'/>
00:25:57:
00:25:57:  <!-- Folding Slots -->
00:25:57:  <slot id='0' type='CPU'/>
00:25:57:</config>
00:30:09:WU00:FS00:0xa3:Completed 45000 out of 500000 steps  (9%)
01:38:54:WU00:FS00:0xa3:Completed 75000 out of 500000 steps  (15%)
******************************* Date: 2014-06-06 *******************************
01:50:57:WU00:FS00:0xa3:Completed 80000 out of 500000 steps  (16%)
07:34:25:WU00:FS00:0xa3:Completed 235000 out of 500000 steps  (47%)
07:41:16:Started thread 19 on PID 1520
07:41:16:WARNING:WU00:FS00:Detected clock skew (1 mins 02 secs), adjusting time estimates
07:46:28:WU00:FS00:0xa3:Completed 240000 out of 500000 steps  (48%)
07:57:24:WU00:FS00:0xa3:Completed 245000 out of 500000 steps  (49%)
08:52:24:WU00:FS00:0xa3:Completed 270000 out of 500000 steps  (54%)
09:
03:26:WU00:FS00:0xa3:Completed 275000 out of 500000 steps  (55%)
09:14:28:WU00:FS00:0xa3:Completed 280000 out of 500000 steps  (56%)
13:50:24:WU00:FS00:0xa3:Completed 405000 out of 500000 steps  (81%)
14:01:58:WU00:FS00:0xa3:Completed 410000 out of 500000 steps  (82%)
17:10:49:WU00:FS00:0xa3:Completed 495000 out of 500000 steps  (99%)
17:10:51:WU01:FS00:Connecting to 171.67.108.200:8080
17:10:53:WU01:FS00:Assigned to work server 171.64.65.100
17:10:53:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:8 from 171.64.65.100
17:10:53:WU01:FS00:Connecting to 171.64.65.100:8080
17:10:54:WU01:FS00:Downloading 614.89KiB
17:11:00:WU01:FS00:Download 62.45%
17:11:02:WU01:FS00:Download complete
17:11:02:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:7812 run:2361 clone:0 gen:92 core:0xa4 unit:0x000000a2664f2dcc528fcae763e79e1a
17:21:54:WU00:FS00:0xa3:Completed 500000 out of 500000 steps  (100%)
17:21:57:WU00:FS00:0xa3:DynamicWrapper: Finished Work Unit: sleep=10000
17:22:06:WU00:FS00:0xa3:
17:22:06:WU00:FS00:0xa3:Finished Work Unit:
17:22:06:WU00:FS00:0xa3:- Reading up to 8056320 from "00/wudata_01.trr": Read 8056320
17:22:06:WU00:FS00:0xa3:trr file hash check passed.
17:22:06:WU00:FS00:0xa3:edr file hash check passed.
17:22:06:WU00:FS00:0xa3:logfile size: 59706
17:22:06:WU00:FS00:0xa3:Leaving Run
17:22:08:WU00:FS00:0xa3:- Writing 8152858 bytes of core data to disk...
17:22:10:WU00:FS00:0xa3:Done: 8152346 -> 7529577 (compressed to 92.3 percent)
17:22:10:WU00:FS00:0xa3:  ... Done.
17:22:14:WU00:FS00:0xa3:- Shutting down core
17:22:14:WU00:FS00:0xa3:Folding@home Core Shutdown: FINISHED_UNIT
17:22:14:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
17:22:15:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:8567 run:1 clone:4 gen:433 core:0xa3 unit:0x000018e70a3b1e5952278a08572d5ce5
17:22:15:WU00:FS00:Uploading 7.18MiB to 128.143.231.202
17:22:15:WU01:FS00:Starting
17:22:15:WU00:FS00:Connecting to 128.143.231.202:8080
17:22:15:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 1520 -checkpoint 21 -np 8 -service
17:22:15:WU01:FS00:Started FahCore on PID 5072
17:22:15:Started thread 20 on PID 1520
17:22:15:WU01:FS00:Core PID:4872
17:22:15:WU01:FS00:FahCore 0xa4 started
17:22:15:WU01:FS00:0xa4:
17:22:15:WU01:FS00:0xa4:*------------------------------*
17:22:15:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
17:22:15:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
17:22:15:WU01:FS00:0xa4:Preparing to commence simulation
17:22:15:WU01:FS00:0xa4:- Looking at optimizations...
17:22:15:WU01:FS00:0xa4:- Created dyn
17:22:15:WU01:FS00:0xa4:- Files status OK
17:22:15:WU01:FS00:0xa4:- Expanded 629137 -> 868440 (decompressed 138.0 percent)
17:22:15:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=629137 data_size=868440, decompressed_data_size=868440 diff=0
17:22:15:WU01:FS00:0xa4:- Digital signature verified
17:22:15:WU01:FS00:0xa4:Project: 7812 (Run 2361, Clone 0, Gen 92)
17:22:15:WU01:FS00:0xa4:Assembly optimizations on if available.
17:22:15:WU01:FS00:0xa4:Entering M.D.
17:22:21:WU01:FS00:0xa4:Mapping NT from 8 to 8
17:22:21:WU01:FS00:0xa4:Completed 0 out of 500000 steps  (0%)
17:22:21:WU00:FS00:Upload 4.35%
17:22:28:WU00:FS00:Upload 8.70%
17:22:35:WU00:FS00:Upload 13.05%
17:22:41:WU00:FS00:Upload 16.54%
17:22:48:WU00:FS00:Upload 20.02%
17:22:55:WU00:FS00:Upload 23.50%
17:23:02:WU00:FS00:Upload 26.98%
17:23:08:WU00:FS00:Upload 30.46%
17:23:14:WU00:FS00:Upload 33.07%
17:23:20:WU00:FS00:Upload 36.55%
17:23:27:WU00:FS00:Upload 40.03%
17:23:34:WU00:FS00:Upload 43.52%
17:23:40:WU00:FS00:Upload 47.00%
17:23:47:WU00:FS00:Upload 50.48%
17:23:54:WU00:FS00:Upload 53.96%
17:24:00:WU01:FS00:0xa4:Completed 5000 out of 500000 steps  (1%)
17:24:01:WU00:FS00:Upload 57.44%
17:24:07:WU00:FS00:Upload 60.92%
17:24:14:WU00:FS00:Upload 63.53%
17:24:22:WU00:FS00:Upload 64.40%
17:24:28:WU00:FS00:Upload 65.27%
17:24:35:WU00:FS00:Upload 67.89%
17:24:42:WU00:FS00:Upload 71.37%
17:24:49:WU00:FS00:Upload 74.85%
17:24:56:WU00:FS00:Upload 78.33%
17:25:02:WU00:FS00:Upload 81.81%
17:25:08:WU00:FS00:Upload 84.42%
17:25:15:WU00:FS00:Upload 87.90%
17:25:21:WU00:FS00:Upload 91.38%
17:25:28:WU00:FS00:Upload 94.87%
17:25:35:WU00:FS00:Upload 98.35%
17:25:40:WU00:FS00:Upload complete
17:25:40:WU00:FS00:Server responded WORK_ACK (400)
17:25:40:WU00:FS00:Final credit estimate, 11836.00 points
17:25:40:WU00:FS00:Cleaning up
17:25:46:WU01:FS00:0xa4:Completed 10000 out of 500000 steps  (2%)
18:40:49:WU01:FS00:0xa4:Completed 230000 out of 500000 steps  (46%)
18:42:17:Started thread 21 on PID 1520
18:42:17:WARNING:WU01:FS00:Detected clock skew (1 mins 01 secs), adjusting time estimates
18:43:38:WU01:FS00:0xa4:Completed 235000 out of 500000 steps  (47%)
20:00:23:WU01:FS00:0xa4:Completed 460000 out of 500000 steps  (92%)
20:02:04:WU01:FS00:0xa4:Completed 465000 out of 500000 steps  (93%)
20:12:11:WU01:FS00:0xa4:Completed 495000 out of 500000 steps  (99%)
20:12:12:WU00:FS00:Connecting to 171.67.108.200:8080
20:12:14:WU00:FS00:Assigned to work server 128.143.231.202
20:12:14:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:8 from 128.143.231.202
20:12:14:WU00:FS00:Connecting to 128.143.231.202:8080
20:12:16:WU00:FS00:Downloading 3.67MiB
20:12:22:WU00:FS00:Download 25.53%
20:12:28:WU00:FS00:Download 56.16%
20:12:34:WU00:FS00:Download 81.69%
20:12:38:WU00:FS00:Download complete
20:12:38:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8573 run:1 clone:6 gen:441 core:0xa3 unit:0x00001a380a3b1e5952288596ca900477
20:13:51:WU01:FS00:0xa4:Completed 500000 out of 500000 steps  (100%)
20:13:52:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
20:14:02:WU01:FS00:0xa4:
20:14:02:WU01:FS00:0xa4:Finished Work Unit:
20:14:02:WU01:FS00:0xa4:- Reading up to 877596 from "01/wudata_01.trr": Read 877596
20:14:02:WU01:FS00:0xa4:trr file hash check passed.
20:14:02:WU01:FS00:0xa4:- Reading up to 960036 from "01/wudata_01.xtc": Read 960036
20:14:02:WU01:FS00:0xa4:xtc file hash check passed.
20:14:02:WU01:FS00:0xa4:edr file hash check passed.
20:14:02:WU01:FS00:0xa4:logfile size: 26966
20:14:02:WU01:FS00:0xa4:Leaving Run
20:14:04:WU01:FS00:0xa4:- Writing 1873570 bytes of core data to disk...
20:14:04:WU01:FS00:0xa4:Done: 1873058 -> 1804790 (compressed to 96.3 percent)
20:14:04:WU01:FS00:0xa4:  ... Done.
20:14:05:WU01:FS00:0xa4:- Shutting down core
20:14:05:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
20:14:06:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:14:06:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:7812 run:2361 clone:0 gen:92 core:0xa4 unit:0x000000a2664f2dcc528fcae763e79e1a
20:14:06:WU01:FS00:Uploading 1.72MiB to 171.64.65.100
20:14:06:WU00:FS00:Starting
20:14:06:WU01:FS00:Connecting to 171.64.65.100:8080
20:14:06:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 704 -lifeline 1520 -checkpoint 21 -np 8 -service
20:14:06:WU00:FS00:Started FahCore on PID 1080
20:14:06:Started thread 22 on PID 1520
20:14:06:WU00:FS00:Core PID:3152
20:14:06:WU00:FS00:FahCore 0xa3 started
20:14:06:WU00:FS00:0xa3:
20:14:06:WU00:FS00:0xa3:*------------------------------*
20:14:06:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
20:14:06:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
20:14:06:WU00:FS00:0xa3:Preparing to commence simulation
20:14:06:WU00:FS00:0xa3:- Looking at optimizations...
20:14:06:WU00:FS00:0xa3:- Created dyn
20:14:06:WU00:FS00:0xa3:- Files status OK
20:14:06:WU00:FS00:0xa3:- Expanded 3850320 -> 4393460 (decompressed 114.1 percent)
20:14:06:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3850320 data_size=4393460, decompressed_data_size=4393460 diff=0
20:14:06:WU00:FS00:0xa3:- Digital signature verified
20:14:06:WU00:FS00:0xa3:Project: 8573 (Run 1, Clone 6, Gen 441)
20:14:06:WU00:FS00:0xa3:Assembly optimizations on if available.
20:14:06:WU00:FS00:0xa3:Entering M.D.
20:14:12:WU00:FS00:0xa3:Mapping NT from 8 to 8
20:14:13:WU00:FS00:0xa3:Completed 0 out of 500000 steps  (0%)
20:14:13:WU01:FS00:Upload 14.52%
20:14:19:WU01:FS00:Upload 25.41%
20:14:25:WU01:FS00:Upload 36.30%
20:14:32:WU01:FS00:Upload 47.19%
20:14:38:WU01:FS00:Upload 58.08%
20:14:44:WU01:FS00:Upload 68.97%
20:14:50:WU01:FS00:Upload 79.86%
20:14:56:WU01:FS00:Upload 90.75%
20:15:02:WU01:FS00:Upload complete
20:15:02:WU01:FS00:Server responded WORK_ACK (400)
20:15:02:WU01:FS00:Final credit estimate, 1467.00 points
20:15:02:WU01:FS00:Cleaning up
20:25:35:WU00:FS00:0xa3:Completed 5000 out of 500000 steps  (1%)
20:36:58:WU00:FS00:0xa3:Completed 10000 out of 500000 steps  (2%)
20:48:24:WU00:FS00:0xa3:Completed 15000 out of 500000 steps  (3%)
20:55:55:Adding folding slot 01: PAUSED gpu:0:G98 [GeForce 8400 GS] (no gpu access)
20:55:55:FS00:Shutting core down
20:55:55:WARNING:FS00:FahCore not accepting gentle shutdown, killing
20:55:55:WARNING:FS00:Killing WU00
20:55:55:WU00:FS00:FahCore terminated
20:55:55:WU00:FS00:Starting
20:55:55:WARNING:WU00:FS00:Changed SMP threads from 8 to 7 this can cause some work units to fail
20:55:55:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 704 -lifeline 1520 -checkpoint 21 -np 7 -service
20:55:55:WU00:FS00:Started FahCore on PID 932
20:55:55:Started thread 23 on PID 1520
20:55:55:WU00:FS00:Core PID:5288
20:55:55:WU00:FS00:FahCore 0xa3 started
20:55:56:WU00:FS00:0xa3:
20:55:56:WU00:FS00:0xa3:*------------------------------*
20:55:56:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
20:55:56:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
20:55:56:WU00:FS00:0xa3:Preparing to commence simulation
20:55:56:WU00:FS00:0xa3:- Ensuring status. Please wait.
20:55:56:Removing old file 'configs/config-20140605-052831.xml'
20:55:56:Saving configuration to config.xml
20:55:56:<config>
20:55:56:  <!-- Folding Core -->
20:55:56:  <checkpoint v='21'/>
20:55:56:
20:55:56:  <!-- Logging -->
20:55:56:  <verbosity v='5'/>
20:55:56:
20:55:56:  <!-- Network -->
20:55:56:  <proxy v=':8080'/>
20:55:56:
20:55:56:  <!-- Slot Control -->
20:55:56:  <power v='full'/>
20:55:56:
20:55:56:  <!-- User Information -->
20:55:56:  <passkey v='********************************'/>
20:55:56:  <user v='willfolder'/>
20:55:56:
20:55:56:  <!-- Folding Slots -->
20:55:56:  <slot id='0' type='CPU'/>
20:55:56:  <slot id='1' type='GPU'/>
20:55:56:</config>
20:56:05:WU00:FS00:0xa3:- Looking at optimizations...
20:56:05:WU00:FS00:0xa3:- Working with standard loops on this execution.
20:56:05:WU00:FS00:0xa3:- Previous termination of core was improper.
20:56:05:WU00:FS00:0xa3:- Files status OK
20:56:05:WU00:FS00:0xa3:- Expanded 3850320 -> 4393460 (decompressed 114.1 percent)
20:56:05:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3850320 data_size=4393460, decompressed_data_size=4393460 diff=0
20:56:05:WU00:FS00:0xa3:- Digital signature verified
20:56:05:WU00:FS00:0xa3:Project: 8573 (Run 1, Clone 6, Gen 441)
20:56:05:WU00:FS00:0xa3:Entering M.D.
20:56:11:WU00:FS00:0xa3:Using Gromacs checkpoints
20:56:12:WU00:FS00:0xa3:Mapping NT from 7 to 7
20:56:12:WU00:FS00:0xa3:Resuming from checkpoint
20:56:12:WU00:FS00:0xa3:Verified 00/wudata_01.log
20:56:12:WU00:FS00:0xa3:Verified 00/wudata_01.trr
20:56:12:WU00:FS00:0xa3:Verified 00/wudata_01.edr
20:56:13:WU00:FS00:0xa3:Completed 9250 out of 500000 steps  (1%)
20:56:29:Removing old file 'configs/config-20140605-052932.xml'
20:56:29:Saving configuration to config.xml
20:56:29:<config>
20:56:29:  <!-- Folding Core -->
20:56:29:  <checkpoint v='21'/>
20:56:29:
20:56:29:  <!-- Logging -->
20:56:29:  <verbosity v='5'/>
20:56:29:
20:56:29:  <!-- Network -->
20:56:29:  <proxy v=':8080'/>
20:56:29:
20:56:29:  <!-- Slot Control -->
20:56:29:  <power v='full'/>
20:56:29:
20:56:29:  <!-- User Information -->
20:56:29:  <passkey v='********************************'/>
20:56:29:  <user v='willfolder'/>
20:56:29:
20:56:29:  <!-- Folding Slots -->
20:56:29:  <slot id='0' type='CPU'/>
20:56:29:  <slot id='1' type='GPU'/>
20:56:29:</config>
20:58:01:WU00:FS00:0xa3:Completed 10000 out of 500000 steps  (2%)
21:10:12:WU00:FS00:0xa3:Completed 15000 out of 500000 steps  (3%)
21:12:07:Started thread 24 on PID 1520
21:22:22:WU00:FS00:0xa3:Completed 20000 out of 500000 steps  (4%)
21:34:28:WU00:FS00:0xa3:Completed 25000 out of 500000 steps  (5%)
21:37:55:FS01:Paused
21:38:01:FS01:Unpaused
21:46:34:WU00:FS00:0xa3:Completed 30000 out of 500000 steps  (6%)
01:49:28:WU00:FS00:0xa3:Completed 120000 out of 500000 steps  (24%)
******************************* Date: 2014-06-07 *******************************
02:04:56:WU00:FS00:0xa3:Completed 125000 out of 500000 steps  (25%)
05:40:38:WU00:FS00:0xa3:Completed 215000 out of 500000 steps  (43%)
05:43:18:Started thread 25 on PID 1520
05:43:18:WARNING:WU00:FS00:Detected clock skew (1 mins 01 secs), adjusting time estimates
05:44:03:FS00:Paused
05:44:03:FS01:Paused
05:44:03:FS00:Shutting core down
05:44:03:WARNING:FS00:FahCore not accepting gentle shutdown, killing
05:44:03:WARNING:FS00:Killing WU00
05:44:03:WU00:FS00:FahCore terminated
05:44:19:Removing old file 'configs/config-20140605-110058.xml'
05:44:19:Saving configuration to config.xml
05:44:19:<config>
05:44:19:  <!-- Folding Core -->
05:44:19:  <checkpoint v='21'/>
05:44:19:
05:44:19:  <!-- Logging -->
05:44:19:  <verbosity v='5'/>
05:44:19:
05:44:19:  <!-- Network -->
05:44:19:  <proxy v=':8080'/>
05:44:19:
05:44:19:  <!-- Slot Control -->
05:44:19:  <power v='full'/>
05:44:19:
05:44:19:  <!-- User Information -->
05:44:19:  <passkey v='********************************'/>
05:44:19:  <user v='willfolder'/>
05:44:19:
05:44:19:  <!-- Folding Slots -->
05:44:19:  <slot id='0' type='CPU'>
05:44:19:    <paused v='true'/>
05:44:19:  </slot>
05:44:19:  <slot id='1' type='GPU'>
05:44:19:  </slot>
05:44:19:</config>
05:47:06:FS00:Unpaused
05:47:06:FS01:Unpaused
05:47:06:WU00:FS00:Starting
05:47:06:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 704 -lifeline 1520 -checkpoint 21 -np 7 -service
05:47:06:WU00:FS00:Started FahCore on PID 4656
05:47:06:Started thread 26 on PID 1520
05:47:06:WU00:FS00:Core PID:152
05:47:06:WU00:FS00:FahCore 0xa3 started
05:47:07:WU00:FS00:0xa3:
05:47:07:WU00:FS00:0xa3:*------------------------------*
05:47:07:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
05:47:07:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
05:47:07:WU00:FS00:0xa3:Preparing to commence simulation
05:47:07:WU00:FS00:0xa3:- Ensuring status. Please wait.
05:47:16:WU00:FS00:0xa3:- Looking at optimizations...
05:47:16:WU00:FS00:0xa3:- Working with standard loops on this execution.
05:47:16:WU00:FS00:0xa3:- Previous termination of core was improper.
05:47:16:WU00:FS00:0xa3:- Going to use standard loops.
05:47:16:WU00:FS00:0xa3:- Files status OK
05:47:16:WU00:FS00:0xa3:- Expanded 3850320 -> 4393460 (decompressed 114.1 percent)
05:47:16:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3850320 data_size=4393460, decompressed_data_size=4393460 diff=0
05:47:16:WU00:FS00:0xa3:- Digital signature verified
05:47:16:WU00:FS00:0xa3:Project: 8573 (Run 1, Clone 6, Gen 441)
05:47:16:WU00:FS00:0xa3:Entering M.D.
05:47:22:Removing old file 'configs/config-20140605-110300.xml'
05:47:22:Saving configuration to config.xml
05:47:22:<config>
05:47:22:  <!-- Folding Core -->
05:47:22:  <checkpoint v='21'/>
05:47:22:
05:47:22:  <!-- Logging -->
05:47:22:  <verbosity v='5'/>
05:47:22:
05:47:22:  <!-- Network -->
05:47:22:  <proxy v=':8080'/>
05:47:22:
05:47:22:  <!-- Slot Control -->
05:47:22:  <power v='full'/>
05:47:22:
05:47:22:  <!-- User Information -->
05:47:22:  <passkey v='********************************'/>
05:47:22:  <user v='willfolder'/>
05:47:22:
05:47:22:  <!-- Folding Slots -->
05:47:22:  <slot id='0' type='CPU'/>
05:47:22:  <slot id='1' type='GPU'/>
05:47:22:</config>
05:47:22:WU00:FS00:0xa3:Using Gromacs checkpoints
05:47:22:WU00:FS00:0xa3:Mapping NT from 7 to 7
05:47:23:WU00:FS00:0xa3:Resuming from checkpoint
05:47:23:WU00:FS00:0xa3:Verified 00/wudata_01.log
05:47:24:WU00:FS00:0xa3:Verified 00/wudata_01.trr
05:47:24:WU00:FS00:0xa3:Verified 00/wudata_01.edr
05:47:24:WU00:FS00:0xa3:Completed 215235 out of 500000 steps  (43%)
willfolder
I am downloading the newest nvidia drivers and will see if this makes a difference.
P5-133XL
Machine #2:
Machine 3:
Post by P5-133XL »
You can not GPU fold if running as a service in Win7. Microsoft, in its infinite wisdom, decided that access to the video subsystem by any service is a security breach and stops it cold.
Please put the log verbosity back to the default value of 3. At 3, only changes to the default values are shown and that makes it much simpler to detect when something that should not be changed has been.
willfolder
Is this the problem then - it is running gpu as a service? I assume I will have to reinstall the client if this is the case
How do I determine if the client is running as a service and not as a normal program?
I have just downloaded the very latest Nvidia drivers.
P5-133XL
Machine #2:
Machine 3:
Post by P5-133XL »
Your system info says you are: 13:39:40:Win32 Service: true
and yes, the easiest way (not the only way) to solve this is to re-install the client from scratch.
willfolder
I will wait for the current WU to complete and then install the client not as a service.
Will then give the GPU a go.
PantherX wrote:Since it is a Pre-Fermi GPU, it can still fold FahCore_11 WUs. However, do note that FahCore_11 WUs have gone End Of Life (EOL) so it may be stopped sometime in the future (https://folding.stanford.edu/home/remin ... -core78-2/).
Is this GPU on the supported list in the install guide?
7im wrote:...Is this GPU on the supported list in the install guide?
The installation guide links to this site (https://developer.nvidia.com/cuda-gpus) and GeForce 8400 GS is mentioned on it.
willfolder
Have re-einstalled the client as a non service. And so far results look bad. The GPU is running but my points per day are down to about 8000 as apposed to
about 17000 which was when I was running just the CPU.
Also the time allotment to complete the GPU task is about 3 days which will never be met even if running 24/7.
Also when both the CPU and GPU are running the computer becomes too sluggish to use normally - just running the CPU means I can at least use the computer
for other work with no hinderence.
Had this same problem on another computer with a better GPU and in that case resolved to just fold with a CPU.
*********************** Log Started 2014-06-07T16:50:44Z ***********************
16:50:44:************************* Folding@home Client *************************
16:50:44:      Website: http://folding.stanford.edu/
16:50:44:    Copyright: (c) 2009-2014 Stanford University
16:50:44:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:50:44:         Args: --open-web-control
16:50:44:       Config: <none>
16:50:44:******************************** Build ********************************
16:50:44:      Version: 7.4.4
16:50:44:         Date: Mar 4 2014
16:50:44:         Time: 20:26:54
16:50:44:      SVN Rev: 4130
16:50:44:       Branch: fah/trunk/client
16:50:44:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
16:50:44:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
16:50:44:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
16:50:44:     Platform: win32 XP
16:50:44:         Bits: 32
16:50:44:         Mode: Release
16:50:44:******************************* System ********************************
16:50:44:          CPU: Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz
16:50:44:       CPU ID: GenuineIntel Family 6 Model 26 Stepping 5
16:50:44:         CPUs: 8
16:50:44:       Memory: 5.99GiB
16:50:44:  Free Memory: 3.57GiB
16:50:44:      Threads: WINDOWS_THREADS
16:50:44:   OS Version: 6.1
16:50:44:  Has Battery: false
16:50:44:   On Battery: false
16:50:44:   UTC Offset: 2
16:50:44:          PID: 2516
16:50:44:          CWD: C:/ProgramData/FAHClient
16:50:44:           OS: Windows 7 Ultimate
16:50:44:      OS Arch: AMD64
16:50:44:         GPUs: 1
16:50:44:        GPU 0: NVIDIA:1 G98 [GeForce 8400 GS]
16:50:44:         CUDA: 1.1
16:50:44:  CUDA Driver: 6000
16:50:44:Win32 Service: false
16:50:44:***********************************************************************
16:50:44:<config>
16:50:44:  <!-- Folding Slots -->
16:50:44:</config>
16:50:44:Connecting to assign-GPU.stanford.edu:80
16:50:51:Updated GPUs.txt
16:50:51:Read GPUs.txt
16:50:51:Trying to access database...
16:50:51:Successfully acquired database lock
16:50:51:Enabled folding slot 00: PAUSED cpu:6 (not configured)
16:50:51:Enabled folding slot 01: PAUSED gpu:0:G98 [GeForce 8400 GS] (not configured)
16:51:44:13:127.0.0.1:New Web connection
16:51:52:Saving configuration to config.xml
16:51:52:<config>
16:51:52:  <!-- Folding Slots -->
16:51:52:  <slot id='0' type='CPU'/>
16:51:52:  <slot id='1' type='GPU'/>
16:51:52:</config>
16:51:52:Set client configured
16:51:53:WU00:FS00:Connecting to 171.67.108.200:8080
16:51:53:WU01:FS01:Connecting to 171.67.108.200:8080
16:51:55:WU01:FS01:Connecting to 171.67.108.201:80
16:51:58:WU00:FS00:Connecting to 171.67.108.200:8080
16:51:59:WU01:FS01:Assigned to work server 171.67.108.11
16:51:59:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:G98 [GeForce 8400 GS] from 171.67.108.11
16:51:59:WU01:FS01:Connecting to 171.67.108.11:8080
16:52:02:WU01:FS01:Downloading 46.10KiB
16:52:06:WU00:FS00:Assigned to work server 155.247.166.219
16:52:06:WU00:FS00:Requesting new work unit for slot 00: READY cpu:6 from 155.247.166.219
16:52:06:WU00:FS00:Connecting to 155.247.166.219:8080
16:52:08:WU01:FS01:Download 100.00%
16:52:08:WU01:FS01:Download complete
16:52:08:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:5765 run:1 clone:430 gen:8766 core:0x11 unit:0x65dc80005393435b223e01ae00011685
16:52:08:WU01:FS01:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah
16:52:08:WU01:FS01:Connecting to web.stanford.edu:80
16:52:10:WU01:FS01:FahCore 11: Downloading 648.82KiB
16:52:16:WU01:FS01:FahCore 11: 19.73%
16:52:18:Saving configuration to config.xml
16:52:18:<config>
16:52:18:  <!-- Network -->
16:52:18:  <proxy v=':8080'/>
16:52:18:
16:52:18:  <!-- User Information -->
16:52:18:  <passkey v='********************************'/>
16:52:18:  <user v='willfolder'/>
16:52:18:
16:52:18:  <!-- Folding Slots -->
16:52:18:  <slot id='0' type='CPU'/>
16:52:18:  <slot id='1' type='GPU'/>
16:52:18:</config>
16:52:19:WU00:FS00:Downloading 115.60KiB
16:52:31:WU01:FS01:FahCore 11: 29.59%
16:52:40:WU01:FS01:FahCore 11: 39.46%
16:52:45:WU00:FS00:Download 55.36%
16:52:53:Saving configuration to config.xml
16:52:53:<config>
16:52:53:  <!-- Network -->
16:52:53:  <proxy v=':8080'/>
16:52:53:
16:52:53:  <!-- User Information -->
16:52:53:  <passkey v='********************************'/>
16:52:53:  <user v='willfolder'/>
16:52:53:
16:52:53:  <!-- Folding Slots -->
16:52:53:  <slot id='0' type='CPU'/>
16:52:53:  <slot id='1' type='GPU'/>
16:52:53:</config>
16:52:58:WU01:FS01:FahCore 11: 49.32%
16:53:01:WU00:FS00:Download 100.00%
16:53:01:WU00:FS00:Download complete
16:53:01:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:6368 run:59 clone:11 gen:20 core:0xa4 unit:0x0000001b0002894b532765819ab15252
16:53:02:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
16:53:02:WU00:FS00:Connecting to web.stanford.edu:80
16:53:03:WU00:FS00:FahCore a4: Downloading 2.89MiB
16:53:11:WU01:FS01:FahCore 11: 59.18%
16:53:17:WU00:FS00:FahCore a4: 2.16%
16:53:21:WU01:FS01:FahCore 11: 69.05%
16:53:29:WU00:FS00:FahCore a4: 4.33%
16:53:36:WU00:FS00:FahCore a4: 6.49%
16:53:36:WU01:FS01:FahCore 11: 78.91%
16:53:47:WU00:FS00:FahCore a4: 8.66%
16:53:56:WU01:FS01:FahCore 11: 88.78%
16:54:05:WU00:FS00:FahCore a4: 10.82%
16:54:15:WU01:FS01:FahCore 11: 98.64%
16:54:16:WU01:FS01:FahCore 11: Download complete
16:54:16:WU01:FS01:Valid core signature
16:54:16:WU01:FS01:Unpacked 1.82MiB to cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe
16:54:16:WU01:FS01:Starting
16:54:16:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 01 -suffix 01 -version 704 -lifeline 2516 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
16:54:16:WU01:FS01:Started FahCore on PID 5272
16:54:17:WU01:FS01:Core PID:5732
16:54:17:WU01:FS01:FahCore 0x11 started
16:54:17:WU01:FS01:0x11:
16:54:17:WU01:FS01:0x11:*------------------------------*
16:54:17:WU01:FS01:0x11:Folding@Home GPU Core
16:54:17:WU01:FS01:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
16:54:17:WU01:FS01:0x11:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
16:54:17:WU01:FS01:0x11:Build host: amoeba
16:54:17:WU01:FS01:0x11:Board Type: Nvidia
16:54:17:WU01:FS01:0x11:Core      :
16:54:17:WU01:FS01:0x11:Preparing to commence simulation
16:54:17:WU01:FS01:0x11:- Looking at optimizations...
16:54:17:WU01:FS01:0x11:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
16:54:17:WU01:FS01:0x11:- Created dyn
16:54:17:WU01:FS01:0x11:- Files status OK
16:54:17:WU01:FS01:0x11:- Expanded 46698 -> 252912 (decompressed 541.5 percent)
16:54:17:WU01:FS01:0x11:Called DecompressByteArray: compressed_data_size=46698 data_size=252912, decompressed_data_size=252912 diff=0
16:54:17:WU01:FS01:0x11:- Digital signature verified
16:54:17:WU01:FS01:0x11:Project: 5765 (Run 1, Clone 430, Gen 8766)
16:54:17:WU01:FS01:0x11:Assembly optimizations on if available.
16:54:17:WU01:FS01:0x11:Entering M.D.
16:54:23:WU01:FS01:0x11:Tpr hash 01/wudata_01.tpr:  693223909 2900608833 2551797036 1570997524 1159703630
16:54:23:WU01:FS01:0x11:Calling fah_main args: 14 usage=100
16:54:24:WU01:FS01:0x11:Working on Protein
16:54:29:WU00:FS00:FahCore a4: 12.99%
16:54:45:WU00:FS00:FahCore a4: 15.15%
16:54:55:Saving configuration to config.xml
16:54:55:<config>
16:54:55:  <!-- Network -->
16:54:55:  <proxy v=':8080'/>
16:54:55:
16:54:55:  <!-- Slot Control -->
16:54:55:  <power v='full'/>
16:54:55:
16:54:55:  <!-- User Information -->
16:54:55:  <passkey v='********************************'/>
16:54:55:  <user v='willfolder'/>
16:54:55:
16:54:55:  <!-- Folding Slots -->
16:54:55:  <slot id='0' type='CPU'/>
16:54:55:  <slot id='1' type='GPU'/>
16:54:55:</config>
16:54:56:WU00:FS00:FahCore a4: 17.31%
16:55:00:WU01:FS01:0x11:Client config unavailable.
16:55:00:WU01:FS01:0x11:Starting GUI Server
16:55:09:WU00:FS00:FahCore a4: 19.48%
16:55:23:WU00:FS00:FahCore a4: 21.64%
16:55:35:WU00:FS00:FahCore a4: 23.81%
16:55:44:WU00:FS00:FahCore a4: 25.97%
16:55:53:WU00:FS00:FahCore a4: 28.13%
16:56:15:WU00:FS00:FahCore a4: 32.46%
16:56:28:WU00:FS00:FahCore a4: 34.63%
16:56:37:WU00:FS00:FahCore a4: 36.79%
16:56:45:WU00:FS00:FahCore a4: 38.96%
16:56:58:WU00:FS00:FahCore a4: 41.12%
16:57:09:WU00:FS00:FahCore a4: 43.28%
16:57:21:WU00:FS00:FahCore a4: 47.61%
16:57:34:WU00:FS00:FahCore a4: 49.78%
16:57:47:WU00:FS00:FahCore a4: 51.94%
16:57:56:WU00:FS00:FahCore a4: 54.10%
16:58:08:WU00:FS00:FahCore a4: 56.27%
16:58:34:WU00:FS00:FahCore a4: 58.43%
16:58:55:WU00:FS00:FahCore a4: 60.60%
16:59:18:WU00:FS00:FahCore a4: 62.76%
16:59:32:WU00:FS00:FahCore a4: 64.93%
16:59:54:WU00:FS00:FahCore a4: 67.09%
17:00:00:Saving configuration to config.xml
17:00:00:<config>
17:00:00:  <!-- Network -->
17:00:00:  <proxy v=':8080'/>
17:00:00:
17:00:00:  <!-- User Information -->
17:00:00:  <passkey v='********************************'/>
17:00:00:  <user v='willfolder'/>
17:00:00:
17:00:00:  <!-- Folding Slots -->
17:00:00:  <slot id='0' type='CPU'/>
17:00:00:  <slot id='1' type='GPU'/>
17:00:00:</config>
17:00:04:WU00:FS00:FahCore a4: 69.25%
17:00:23:WU00:FS00:FahCore a4: 71.42%
17:00:34:WU00:FS00:FahCore a4: 73.58%
17:00:46:WU00:FS00:FahCore a4: 75.75%
17:01:02:WU00:FS00:FahCore a4: 77.91%
17:01:27:WU00:FS00:FahCore a4: 80.07%
17:01:50:WU00:FS00:FahCore a4: 82.24%
17:02:00:WU00:FS00:FahCore a4: 84.40%
17:02:06:WU00:FS00:FahCore a4: 97.39%
17:02:07:WU00:FS00:FahCore a4: Download complete
17:02:07:WU00:FS00:Valid core signature
17:02:07:WU00:FS00:Unpacked 9.59MiB to cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe
17:02:07:WU00:FS00:Starting
17:02:07:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 2516 -checkpoint 15 -np 6
17:02:07:WU00:FS00:Started FahCore on PID 4940
17:02:08:WU00:FS00:Core PID:5984
17:02:08:WU00:FS00:FahCore 0xa4 started
17:02:09:WU00:FS00:0xa4:
17:02:09:WU00:FS00:0xa4:*------------------------------*
17:02:09:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
17:02:09:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
17:02:09:WU00:FS00:0xa4:Preparing to commence simulation
17:02:09:WU00:FS00:0xa4:- Looking at optimizations...
17:02:09:WU00:FS00:0xa4:- Created dyn
17:02:09:WU00:FS00:0xa4:- Files status OK
17:02:09:WU00:FS00:0xa4:- Expanded 117861 -> 266400 (decompressed 226.0 percent)
17:02:09:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=117861 data_size=266400, decompressed_data_size=266400 diff=0
17:02:09:WU00:FS00:0xa4:- Digital signature verified
17:02:09:WU00:FS00:0xa4:Project: 6368 (Run 59, Clone 11, Gen 20)
17:02:09:WU00:FS00:0xa4:Assembly optimizations on if available.
17:02:09:WU00:FS00:0xa4:Entering M.D.
17:02:14:WU00:FS00:0xa4:Mapping NT from 6 to 6
17:02:14:WU00:FS00:0xa4:Completed 0 out of 5000000 steps  (0%)
17:04:33:WU00:FS00:0xa4:Completed 50000 out of 5000000 steps  (1%)
17:05:20:FS00:Shutting core down
17:05:28:WU00:FS00:0xa4:Client no longer detected. Shutting down core
17:05:28:WU00:FS00:0xa4:Folding@home Core Shutdown: CLIENT_DIED
17:05:29:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
17:05:29:WU00:FS00:Starting
17:05:29:WARNING:WU00:FS00:Changed SMP threads from 6 to 7 this can cause some work units to fail
17:05:29:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 2516 -checkpoint 15 -np 7
17:05:29:WU00:FS00:Started FahCore on PID 4028
17:05:29:WU00:FS00:Core PID:5392
17:05:29:WU00:FS00:FahCore 0xa4 started
17:05:29:WU00:FS00:0xa4:
17:05:29:WU00:FS00:0xa4:*------------------------------*
17:05:29:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
17:05:29:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
17:05:29:WU00:FS00:0xa4:Preparing to commence simulation
17:05:29:WU00:FS00:0xa4:- Looking at optimizations...
17:05:29:WU00:FS00:0xa4:- Files status OK
17:05:29:WU00:FS00:0xa4:- Expanded 117861 -> 266400 (decompressed 226.0 percent)
17:05:29:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=117861 data_size=266400, decompressed_data_size=266400 diff=0
17:05:29:WU00:FS00:0xa4:- Digital signature verified
17:05:29:WU00:FS00:0xa4:Project: 6368 (Run 59, Clone 11, Gen 20)
17:05:29:WU00:FS00:0xa4:Assembly optimizations on if available.
17:05:29:WU00:FS00:0xa4:Entering M.D.
17:05:35:WU00:FS00:0xa4:Mapping NT from 7 to 7
17:05:35:WU00:FS00:0xa4:mdrun returned 255
17:05:35:WU00:FS00:0xa4:Going to send back what have done -- stepsTotalG=5000000
17:05:35:WU00:FS00:0xa4:Work fraction=0.0000 steps=5000000.
17:05:39:WU00:FS00:0xa4:logfile size=0 infoLength=0 edr=0 trr=25
17:05:39:WU00:FS00:0xa4:logfile size: 0 info=0 bed=0 hdr=25
17:05:39:WU00:FS00:0xa4:- Writing 641 bytes of core data to disk...
17:05:39:WU00:FS00:0xa4:Done: 129 -> 144 (compressed to 111.6 percent)
17:05:39:WU00:FS00:0xa4:  ... Done.
17:05:39:WU00:FS00:0xa4:Folding@home Core Shutdown: EARLY_UNIT_END
17:05:40:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
17:05:40:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:6368 run:59 clone:11 gen:20 core:0xa4 unit:0x0000001b0002894b532765819ab15252
17:05:40:WU00:FS00:Uploading 656B to 155.247.166.219
17:05:40:WU00:FS00:Connecting to 155.247.166.219:8080
17:05:41:WU00:FS00:Upload complete
17:05:41:WU02:FS00:Connecting to 171.67.108.200:8080
17:05:41:WU00:FS00:Server responded WORK_ACK (400)
17:05:42:WU00:FS00:Cleaning up
17:05:43:WU02:FS00:Assigned to work server 128.143.231.202
17:05:43:WU02:FS00:Requesting new work unit for slot 00: READY cpu:7 from 128.143.231.202
17:05:43:WU02:FS00:Connecting to 128.143.231.202:8080
17:05:45:WU02:FS00:Downloading 3.67MiB
17:05:51:WU02:FS00:Download 28.94%
17:05:57:WU02:FS00:Download 62.99%
17:06:03:WU02:FS00:Download 97.05%
17:06:03:WU02:FS00:Download complete
17:06:03:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:8568 run:1 clone:6 gen:424 core:0xa3 unit:0x000019ec0a3b1e59522881a4e98d8db6
17:06:04:WU02:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah
17:06:04:WU02:FS00:Connecting to web.stanford.edu:80
17:06:05:WU02:FS00:FahCore a3: Downloading 2.89MiB
17:06:06:Saving configuration to config.xml
17:06:06:<config>
17:06:06:  <!-- Network -->
17:06:06:  <proxy v=':8080'/>
17:06:06:
17:06:06:  <!-- Slot Control -->
17:06:06:  <power v='full'/>
17:06:06:
17:06:06:  <!-- User Information -->
17:06:06:  <passkey v='********************************'/>
17:06:06:  <user v='willfolder'/>
17:06:06:
17:06:06:  <!-- Folding Slots -->
17:06:06:  <slot id='0' type='CPU'/>
17:06:06:  <slot id='1' type='GPU'/>
17:06:06:</config>
17:06:11:WU02:FS00:FahCore a3: 19.48%
17:06:17:WU02:FS00:FahCore a3: 38.96%
17:06:23:WU02:FS00:FahCore a3: 58.43%
17:06:30:WU02:FS00:FahCore a3: 71.42%
17:06:36:WU02:FS00:FahCore a3: 84.41%
17:06:40:WU02:FS00:FahCore a3: Download complete
17:06:40:WU02:FS00:Valid core signature
17:06:40:WU02:FS00:Unpacked 9.59MiB to cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe
17:06:40:WU02:FS00:Starting
17:06:40:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 02 -suffix 01 -version 704 -lifeline 2516 -checkpoint 15 -np 7
17:06:40:WU02:FS00:Started FahCore on PID 3708
17:06:41:WU02:FS00:Core PID:1672
17:06:41:WU02:FS00:FahCore 0xa3 started
17:06:41:WU02:FS00:0xa3:
17:06:41:WU02:FS00:0xa3:*------------------------------*
17:06:41:WU02:FS00:0xa3:Folding@Home Gromacs SMP Core
17:06:41:WU02:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
17:06:41:WU02:FS00:0xa3:Preparing to commence simulation
17:06:41:WU02:FS00:0xa3:- Looking at optimizations...
17:06:41:WU02:FS00:0xa3:- Created dyn
17:06:41:WU02:FS00:0xa3:- Files status OK
17:06:41:WU02:FS00:0xa3:- Expanded 3848775 -> 4382860 (decompressed 113.8 percent)
17:06:41:WU02:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3848775 data_size=4382860, decompressed_data_size=4382860 diff=0
17:06:41:WU02:FS00:0xa3:- Digital signature verified
17:06:41:WU02:FS00:0xa3:Project: 8568 (Run 1, Clone 6, Gen 424)
17:06:41:WU02:FS00:0xa3:Assembly optimizations on if available.
17:06:41:WU02:FS00:0xa3:Entering M.D.
17:06:47:WU02:FS00:0xa3:Mapping NT from 7 to 7
17:06:48:WU02:FS00:0xa3:Completed 0 out of 500000 steps  (0%)
17:12:22:FS00:Paused
17:12:22:FS01:Paused
17:12:22:FS00:Shutting core down
17:12:22:FS01:Shutting core down
17:12:27:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
17:12:32:WU02:FS00:0xa3:Client no longer detected. Shutting down core
17:12:32:WU02:FS00:0xa3:Folding@home Core Shutdown: CLIENT_DIED
17:12:32:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
17:13:13:Saving configuration to config.xml
17:13:13:<config>
17:13:13:  <!-- Network -->
17:13:13:  <proxy v=':8080'/>
17:13:13:
17:13:13:  <!-- Slot Control -->
17:13:13:  <power v='full'/>
17:13:13:
17:13:13:  <!-- User Information -->
17:13:13:  <passkey v='********************************'/>
17:13:13:  <user v='willfolder'/>
17:13:13:
17:13:13:  <!-- Folding Slots -->
17:13:13:  <slot id='0' type='CPU'>
17:13:13:    <paused v='true'/>
17:13:13:  </slot>
17:13:13:  <slot id='1' type='GPU'>
17:13:13:  </slot>
17:13:13:</config>
17:13:53:FS00:Unpaused
17:13:53:FS01:Unpaused
17:13:53:WU01:FS01:Starting
17:13:53:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 01 -suffix 01 -version 704 -lifeline 2516 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
17:13:53:WU01:FS01:Started FahCore on PID 4152
17:13:53:WU01:FS01:Core PID:2280
17:13:53:WU01:FS01:FahCore 0x11 started
17:13:53:WU02:FS00:Starting
17:13:53:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 02 -suffix 01 -version 704 -lifeline 2516 -checkpoint 15 -np 7
17:13:53:WU02:FS00:Started FahCore on PID 5912
17:13:53:WU02:FS00:Core PID:2736
17:13:53:WU02:FS00:FahCore 0xa3 started
17:13:53:WU01:FS01:0x11:
17:13:53:WU01:FS01:0x11:*------------------------------*
17:13:53:WU01:FS01:0x11:Folding@Home GPU Core
17:13:53:WU01:FS01:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
17:13:53:WU01:FS01:0x11:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
17:13:53:WU01:FS01:0x11:Build host: amoeba
17:13:53:WU01:FS01:0x11:Board Type: Nvidia
17:13:53:WU01:FS01:0x11:Core      :
17:13:53:WU01:FS01:0x11:Preparing to commence simulation
17:13:53:WU01:FS01:0x11:- Looking at optimizations...
17:13:53:WU01:FS01:0x11:- Files status OK
17:13:53:WU01:FS01:0x11:- Expanded 46698 -> 252912 (decompressed 541.5 percent)
17:13:53:WU01:FS01:0x11:Called DecompressByteArray: compressed_data_size=46698 data_size=252912, decompressed_data_size=252912 diff=0
17:13:53:WU01:FS01:0x11:- Digital signature verified
17:13:53:WU01:FS01:0x11:Project: 5765 (Run 1, Clone 430, Gen 8766)
17:13:53:WU01:FS01:0x11:Assembly optimizations on if available.
17:13:53:WU01:FS01:0x11:Entering M.D.
17:13:53:WU02:FS00:0xa3:
17:13:53:WU02:FS00:0xa3:*------------------------------*
17:13:53:WU02:FS00:0xa3:Folding@Home Gromacs SMP Core
17:13:53:WU02:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
17:13:53:WU02:FS00:0xa3:Preparing to commence simulation
17:13:53:WU02:FS00:0xa3:- Looking at optimizations...
17:13:53:WU02:FS00:0xa3:- Files status OK
17:13:53:WU02:FS00:0xa3:- Expanded 3848775 -> 4382860 (decompressed 113.8 percent)
17:13:53:WU02:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3848775 data_size=4382860, decompressed_data_size=4382860 diff=0
17:13:53:WU02:FS00:0xa3:- Digital signature verified
17:13:53:WU02:FS00:0xa3:Project: 8568 (Run 1, Clone 6, Gen 424)
17:13:53:WU02:FS00:0xa3:Assembly optimizations on if available.
17:13:53:WU02:FS00:0xa3:Entering M.D.
17:13:59:WU01:FS01:0x11:Will resume from checkpoint file
17:13:59:WU01:FS01:0x11:Tpr hash 01/wudata_01.tpr:  693223909 2900608833 2551797036 1570997524 1159703630
17:13:59:WU01:FS01:0x11:Calling fah_main args: 14 usage=100
17:13:59:WU02:FS00:0xa3:Mapping NT from 7 to 7
17:14:00:WU01:FS01:0x11:Working on Protein
17:14:00:WU02:FS00:0xa3:Completed 0 out of 500000 steps  (0%)
17:14:14:Saving configuration to config.xml
17:14:14:<config>
17:14:14:  <!-- Network -->
17:14:14:  <proxy v=':8080'/>
17:14:14:
17:14:14:  <!-- Slot Control -->
17:14:14:  <power v='full'/>
17:14:14:
17:14:14:  <!-- User Information -->
17:14:14:  <passkey v='********************************'/>
17:14:14:  <user v='willfolder'/>
17:14:14:
17:14:14:  <!-- Folding Slots -->
17:14:14:  <slot id='0' type='CPU'/>
17:14:14:  <slot id='1' type='GPU'/>
17:14:14:</config>
17:14:19:WU01:FS01:0x11:Client config unavailable.
17:14:19:WU01:FS01:0x11:Starting GUI Server
17:14:20:WU01:FS01:0x11:Resuming from checkpoint
17:14:20:WU01:FS01:0x11:fcCheckPointResume: retreived and current tpr file hash:
17:14:20:WU01:FS01:0x11:   0    693223909    693223909
17:14:20:WU01:FS01:0x11:   1   2900608833   2900608833
17:14:20:WU01:FS01:0x11:   2   2551797036   2551797036
17:14:20:WU01:FS01:0x11:   3   1570997524   1570997524
17:14:20:WU01:FS01:0x11:   4   1159703630   1159703630
17:14:20:WU01:FS01:0x11:fcCheckPointResume: file hashes same.
17:14:20:WU01:FS01:0x11:fcCheckPointResume: state restored.
17:14:20:WU01:FS01:0x11:Verified 01/wudata_01.log
17:14:20:WU01:FS01:0x11:Verified 01/wudata_01.edr
17:14:20:WU01:FS01:0x11:Verified 01/wudata_01.xtc
17:17:17:FS01:Paused
17:17:17:FS01:Shutting core down
17:17:23:WU01:FS01:0x11:Client no longer detected. Shutting down core
17:17:23:WU01:FS01:0x11:Folding@home Core Shutdown: CLIENT_DIED
17:17:23:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
17:18:18:Saving configuration to config.xml
17:18:18:<config>
17:18:18:  <!-- Network -->
17:18:18:  <proxy v=':8080'/>
17:18:18:
17:18:18:  <!-- Slot Control -->
17:18:18:  <power v='full'/>
17:18:18:
17:18:18:  <!-- User Information -->
17:18:18:  <passkey v='********************************'/>
17:18:18:  <user v='willfolder'/>
17:18:18:
17:18:18:  <!-- Folding Slots -->
17:18:18:  <slot id='0' type='CPU'/>
17:18:18:  <slot id='1' type='GPU'>
17:18:18:    <paused v='true'/>
17:18:18:  </slot>
17:18:18:</config>
17:24:09:FS01:Unpaused
17:24:09:WU01:FS01:Starting
17:24:09:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 01 -suffix 01 -version 704 -lifeline 2516 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
17:24:09:WU01:FS01:Started FahCore on PID 692
17:24:09:WU01:FS01:Core PID:2484
17:24:09:WU01:FS01:FahCore 0x11 started
17:24:09:WU01:FS01:0x11:
17:24:09:WU01:FS01:0x11:*------------------------------*
17:24:09:WU01:FS01:0x11:Folding@Home GPU Core
17:24:09:WU01:FS01:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
17:24:09:WU01:FS01:0x11:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
17:24:09:WU01:FS01:0x11:Build host: amoeba
17:24:09:WU01:FS01:0x11:Board Type: Nvidia
17:24:09:WU01:FS01:0x11:Core      :
17:24:09:WU01:FS01:0x11:Preparing to commence simulation
17:24:09:WU01:FS01:0x11:- Looking at optimizations...
17:24:09:WU01:FS01:0x11:- Files status OK
17:24:09:WU01:FS01:0x11:- Expanded 46698 -> 252912 (decompressed 541.5 percent)
17:24:09:WU01:FS01:0x11:Called DecompressByteArray: compressed_data_size=46698 data_size=252912, decompressed_data_size=252912 diff=0
17:24:09:WU01:FS01:0x11:- Digital signature verified
17:24:09:WU01:FS01:0x11:Project: 5765 (Run 1, Clone 430, Gen 8766)
17:24:09:WU01:FS01:0x11:Assembly optimizations on if available.
17:24:09:WU01:FS01:0x11:Entering M.D.
17:24:15:WU01:FS01:0x11:Will resume from checkpoint file
17:24:15:WU01:FS01:0x11:Tpr hash 01/wudata_01.tpr:  693223909 2900608833 2551797036 1570997524 1159703630
17:24:15:WU01:FS01:0x11:Calling fah_main args: 14 usage=100
17:24:16:WU01:FS01:0x11:Working on Protein
17:24:20:WU01:FS01:0x11:Client config unavailable.
17:24:20:WU01:FS01:0x11:Starting GUI Server
17:24:20:WU01:FS01:0x11:Resuming from checkpoint
17:24:20:WU01:FS01:0x11:fcCheckPointResume: retreived and current tpr file hash:
17:24:20:WU01:FS01:0x11:   0    693223909    693223909
17:24:20:WU01:FS01:0x11:   1   2900608833   2900608833
17:24:20:WU01:FS01:0x11:   2   2551797036   2551797036
17:24:20:WU01:FS01:0x11:   3   1570997524   1570997524
17:24:20:WU01:FS01:0x11:   4   1159703630   1159703630
17:24:20:WU01:FS01:0x11:fcCheckPointResume: file hashes same.
17:24:20:WU01:FS01:0x11:fcCheckPointResume: state restored.
17:24:20:WU01:FS01:0x11:Verified 01/wudata_01.log
17:24:20:WU01:FS01:0x11:Verified 01/wudata_01.edr
17:24:20:WU01:FS01:0x11:Verified 01/wudata_01.xtc
17:24:24:Saving configuration to config.xml
17:24:24:<config>
17:24:24:  <!-- Network -->
17:24:24:  <proxy v=':8080'/>
17:24:24:
17:24:24:  <!-- Slot Control -->
17:24:24:  <power v='full'/>
17:24:24:
17:24:24:  <!-- User Information -->
17:24:24:  <passkey v='********************************'/>
17:24:24:  <user v='willfolder'/>
17:24:24:
17:24:24:  <!-- Folding Slots -->
17:24:24:  <slot id='0' type='CPU'/>
17:24:24:  <slot id='1' type='GPU'/>
17:24:24:</config>
17:24:56:WU02:FS00:0xa3:Completed 5000 out of 500000 steps  (1%)
17:32:41:FS00:Paused
17:32:41:FS01:Paused
17:32:41:FS00:Shutting core down
17:32:41:FS01:Shutting core down
17:32:44:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
17:32:49:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
17:33:33:Saving configuration to config.xml
17:33:33:<config>
17:33:33:  <!-- Network -->
17:33:33:  <proxy v=':8080'/>
17:33:33:
17:33:33:  <!-- Slot Control -->
17:33:33:  <power v='full'/>
17:33:33:
17:33:33:  <!-- User Information -->
17:33:33:  <passkey v='********************************'/>
17:33:33:  <user v='willfolder'/>
17:33:33:
17:33:33:  <!-- Folding Slots -->
17:33:33:  <slot id='0' type='CPU'>
17:33:33:    <paused v='true'/>
17:33:33:  </slot>
17:33:33:  <slot id='1' type='GPU'>
17:33:33:  </slot>
17:33:33:</config>
Mod Edit: added code tags
Re: Is this GPU too weak to bother with?
Regarding the drop in points, it will take time to reflect the actual production once ~5% of the WU is completed since it is a fresh installation. In short, let is fold for a few hours and then you can get a good estimate. The same applies for the deadline. Best option is to leave it overnight and see what happens.
Screen lag is something that the hardware vendors and OS manufacturers will have to sort out, nothing that PG can do for now. You can either stop folding on your GPU or configure it to fold only when your system is idle and it can meet the deadline of the assigned WU.
Assuming your system is not constrained by either power or heat limitations, you'll need to choose between to configurations.
1) Folding with a GPU slot plus folding with 6 CPU threads
2) Folding with 8 CPU threads.
To compare the two, you'll have to run "a long time" before the PPD estimates stabilize or you'll have to calculate the PPD from the TPF values once they stabilize. Adding two more CPU threads will provide a slight increase in CPU throughput but by much less than 8:6 ... (a 33% increase) since the CPU is HyperThreaded. If your system seems sluggish when folding with the GPU, it could be what's commonly called "screen lag" and that may induce you to limit GPU folding to when you're not using the system. (There's a setting for pause when active.)
