Not getting expected points [No passkey]
Fadamor
Hardware configuration: Windows 11 Pro
Alienware m18 r2 Laptop
Intel Core i9 14900HX CPU
NVIDIA GeForce RTX 4090 GPU (16GB GDDR6)
64GB DDR5 RAM
Post by Fadamor »
100% complete WU's are getting the "bait and switch" treatment. I finished a project 8900 and a project 9000 WU early this morning and as of the 7:00 status update, I have 7670 points for the day from 2 WUs. This does NOT total what the reported credit for the two projects is supposed to deliver.
Reason: Split topic (from a topic on another subject)
P5-133XL
Machine #2:
Machine 3:
Re: Stats backlog
Post by P5-133XL »
Give the project (Run, Gen, Clone) and a moderator will look them up.
Re: Stats backlog
I looked up a report of the most recent WU's that you have completed, you just got base points on the Project 8900 WU turned in. There were also more than one passkey listed as being used by your username, two of them have not been qualified for QRB. That could be from typos entering the passkey, or you applied for a new one and need to qualify that. If the passkey on the machine is supposed to be the same as one you have used before, double check for transposed digits, leading or trailing spaces, and other entry errors.
Fadamor
64GB DDR5 RAM
Re: Stats backlog
Post by Fadamor »
I know nothing about passkeys. I've never set them on my F@H installations. I just have the integrated client installed on ONE computer using default settings and it detects my CPU and GPU and runs one project - each. They are currently working on a Project 8900 WU (605, 1, 59 - due to complete in about 3 1/2 hours), and a Project 7647 WU (141, 1, 168 - due to complete in about 16 1/2 hours). They are supposedly going to get 20321 and 17896 credits, respectively, but I already know that's not what will be awarded by Stanford. And before somebody suggests they time-out for the full points, the 8900 WU times-out in six days and the 7647 Wu times out in 10 days. Rarely will a WU I'm working on take longer than 24 hours to complete. The 8900 run:818 clone:7 gen:7 in the log below (completed at 3:38 this morning in the log below) apparently is one that spanned logs so I don't have the start info.
Here is my current log with all the progress lines stripped out and the entries grouped by WU. A "~~~" indicates a break in time between the two adjacent entries:
19:36:14:WU02:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
19:36:24:WU02:FS01:0xa4:
19:36:24:WU02:FS01:0xa4:Finished Work Unit:
19:36:24:WU02:FS01:0xa4:- Reading up to 811800 from "02/wudata_01.trr": Read 811800
19:36:24:WU02:FS01:0xa4:trr file hash check passed.
19:36:24:WU02:FS01:0xa4:- Reading up to 746188 from "02/wudata_01.xtc": Read 746188
19:36:24:WU02:FS01:0xa4:xtc file hash check passed.
19:36:24:WU02:FS01:0xa4:edr file hash check passed.
19:36:24:WU02:FS01:0xa4:logfile size: 22933
19:36:24:WU02:FS01:0xa4:Leaving Run
19:36:26:WU02:FS01:0xa4:- Writing 1583409 bytes of core data to disk...
19:36:26:WU02:FS01:0xa4:Done: 1582897 -> 1538379 (compressed to 97.1 percent)
19:36:26:WU02:FS01:0xa4:  ... Done.
19:36:26:WU02:FS01:0xa4:- Shutting down core
19:36:26:WU02:FS01:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
19:36:26:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
19:36:27:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:9007 run:0 clone:28 gen:37 core:0xa4 unit:0x00000028664f2de452ba2952dff80b7b
19:36:27:WU02:FS01:Uploading 1.47MiB to 171.64.65.124
19:36:27:WU02:FS01:Connecting to 171.64.65.124:8080
19:36:29:WU02:FS01:Upload complete
19:36:29:WU02:FS01:Server responded WORK_ACK (400)
19:36:29:WU02:FS01:Final credit estimate, 1685.00 points
19:36:29:WU02:FS01:Cleaning up
******************************* Date: 2014-01-20 *******************************
19:33:49:WU00:FS01:Connecting to assign3.stanford.edu:8080
19:33:49:WU00:FS01:News: Welcome to Folding@Home
19:33:49:WU00:FS01:Assigned to work server 171.64.65.124
19:33:49:WU00:FS01:Requesting new work unit for slot 01: RUNNING cpu:12 from 171.64.65.124
19:33:49:WU00:FS01:Connecting to 171.64.65.124:8080
19:33:50:WU00:FS01:Downloading 855.30KiB
19:33:51:WU00:FS01:Download complete
19:33:51:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9006 run:69 clone:23 gen:54 core:0xa4 unit:0x00000038664f2de452b8090f0d91e075
19:36:27:WU00:FS01:Starting
19:36:27:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Larry/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 703 -lifeline 12300 -checkpoint 15 -np 12
19:36:27:WU00:FS01:Started FahCore on PID 3328
19:36:27:WU00:FS01:Core PID:11924
19:36:27:WU00:FS01:FahCore 0xa4 started
19:36:27:WU00:FS01:0xa4:
19:36:27:WU00:FS01:0xa4:*------------------------------*
19:36:27:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
19:36:27:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
19:36:27:WU00:FS01:0xa4:Preparing to commence simulation
19:36:27:WU00:FS01:0xa4:- Looking at optimizations...
19:36:27:WU00:FS01:0xa4:- Created dyn
19:36:27:WU00:FS01:0xa4:- Files status OK
19:36:27:WU00:FS01:0xa4:- Expanded 875319 -> 1434864 (decompressed 163.9 percent)
19:36:27:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=875319 data_size=1434864, decompressed_data_size=1434864 diff=0
19:36:27:WU00:FS01:0xa4:- Digital signature verified
19:36:27:WU00:FS01:0xa4:Project: 9006 (Run 69, Clone 23, Gen 54)
19:36:27:WU00:FS01:0xa4:Assembly optimizations on if available.
19:36:27:WU00:FS01:0xa4:Entering M.D.
19:36:33:WU00:FS01:0xa4:Mapping NT from 12 to 12
21:38:32:WU00:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
21:38:42:WU00:FS01:0xa4:
21:38:42:WU00:FS01:0xa4:Finished Work Unit:
21:38:42:WU00:FS01:0xa4:- Reading up to 870480 from "00/wudata_01.trr": Read 870480
21:38:42:WU00:FS01:0xa4:trr file hash check passed.
21:38:42:WU00:FS01:0xa4:- Reading up to 798700 from "00/wudata_01.xtc": Read 798700
21:38:42:WU00:FS01:0xa4:xtc file hash check passed.
21:38:42:WU00:FS01:0xa4:edr file hash check passed.
21:38:42:WU00:FS01:0xa4:logfile size: 22719
21:38:42:WU00:FS01:0xa4:Leaving Run
21:38:43:WU00:FS01:0xa4:- Writing 1694339 bytes of core data to disk...
21:38:43:WU00:FS01:0xa4:Done: 1693827 -> 1642997 (compressed to 96.9 percent)
21:38:43:WU00:FS01:0xa4:  ... Done.
21:38:43:WU00:FS01:0xa4:- Shutting down core
21:38:43:WU00:FS01:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
21:38:44:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:38:44:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:9006 run:69 clone:23 gen:54 core:0xa4 unit:0x00000038664f2de452b8090f0d91e075
21:38:44:WU00:FS01:Uploading 1.57MiB to 171.64.65.124
21:38:44:WU00:FS01:Connecting to 171.64.65.124:8080
21:38:46:WU00:FS01:Upload complete
21:38:46:WU00:FS01:Server responded WORK_ACK (400)
21:38:46:WU00:FS01:Final credit estimate, 1864.00 points
21:38:46:WU00:FS01:Cleaning up
21:36:05:WU02:FS01:Connecting to assign3.stanford.edu:8080
21:36:05:WU02:FS01:News: Welcome to Folding@Home
21:36:05:WU02:FS01:Assigned to work server 171.64.65.124
21:36:05:WU02:FS01:Requesting new work unit for slot 01: RUNNING cpu:12 from 171.64.65.124
21:36:05:WU02:FS01:Connecting to 171.64.65.124:8080
21:36:06:WU02:FS01:Downloading 855.05KiB
21:36:07:WU02:FS01:Download complete
21:36:07:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9006 run:71 clone:6 gen:62 core:0xa4 unit:0x00000042664f2de452b80925484c5bce21:38:44:WU02:FS01:Starting
21:38:44:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Larry/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 703 -lifeline 12300 -checkpoint 15 -np 12
21:38:44:WU02:FS01:Started FahCore on PID 6884
21:38:44:WU02:FS01:Core PID:5704
21:38:44:WU02:FS01:FahCore 0xa4 started
21:38:44:WU02:FS01:0xa4:
21:38:44:WU02:FS01:0xa4:*------------------------------*
21:38:44:WU02:FS01:0xa4:Folding@Home Gromacs GB Core
21:38:44:WU02:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
21:38:44:WU02:FS01:0xa4:Preparing to commence simulation
21:38:44:WU02:FS01:0xa4:- Looking at optimizations...
21:38:44:WU02:FS01:0xa4:- Created dyn
21:38:44:WU02:FS01:0xa4:- Files status OK
21:38:44:WU02:FS01:0xa4:- Expanded 875059 -> 1434864 (decompressed 163.9 percent)
21:38:44:WU02:FS01:0xa4:Called DecompressByteArray: compressed_data_size=875059 data_size=1434864, decompressed_data_size=1434864 diff=0
21:38:44:WU02:FS01:0xa4:- Digital signature verified
21:38:44:WU02:FS01:0xa4:Project: 9006 (Run 71, Clone 6, Gen 62)
21:38:44:WU02:FS01:0xa4:Assembly optimizations on if available.
21:38:44:WU02:FS01:0xa4:Entering M.D.
21:38:50:WU02:FS01:0xa4:Mapping NT from 12 to 12
23:37:36:WU02:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
23:37:46:WU02:FS01:0xa4:
23:37:46:WU02:FS01:0xa4:Finished Work Unit:
23:37:46:WU02:FS01:0xa4:- Reading up to 870480 from "02/wudata_01.trr": Read 870480
23:37:46:WU02:FS01:0xa4:trr file hash check passed.
23:37:46:WU02:FS01:0xa4:- Reading up to 797948 from "02/wudata_01.xtc": Read 797948
23:37:46:WU02:FS01:0xa4:xtc file hash check passed.
23:37:46:WU02:FS01:0xa4:edr file hash check passed.
23:37:46:WU02:FS01:0xa4:logfile size: 22661
23:37:46:WU02:FS01:0xa4:Leaving Run
23:37:46:WU02:FS01:0xa4:- Writing 1693529 bytes of core data to disk...
23:37:47:WU02:FS01:0xa4:Done: 1693017 -> 1642192 (compressed to 96.9 percent)
23:37:47:WU02:FS01:0xa4:  ... Done.
23:37:47:WU02:FS01:0xa4:- Shutting down core
23:37:47:WU02:FS01:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
23:37:47:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
23:37:47:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:9006 run:71 clone:6 gen:62 core:0xa4 unit:0x00000042664f2de452b80925484c5bce
23:37:47:WU02:FS01:Uploading 1.57MiB to 171.64.65.124
23:37:47:WU02:FS01:Connecting to 171.64.65.124:8080
23:37:49:WU02:FS01:Upload complete
23:37:50:WU02:FS01:Server responded WORK_ACK (400)
23:37:50:WU02:FS01:Final credit estimate, 1888.00 points
23:37:50:WU02:FS01:Cleaning up
23:35:15:WU00:FS01:Connecting to assign3.stanford.edu:8080
23:35:15:WU00:FS01:News: Welcome to Folding@Home
23:35:15:WU00:FS01:Assigned to work server 171.64.65.124
23:35:15:WU00:FS01:Requesting new work unit for slot 01: RUNNING cpu:12 from 171.64.65.124
23:35:15:WU00:FS01:Connecting to 171.64.65.124:8080
23:35:16:WU00:FS01:Downloading 808.54KiB
23:35:18:WU00:FS01:Download complete
23:35:18:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9007 run:38 clone:23 gen:26 core:0xa4 unit:0x0000001e664f2de452ba2b53ee222b18
23:37:47:WU00:FS01:Starting
23:37:47:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Larry/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 703 -lifeline 12300 -checkpoint 15 -np 12
23:37:47:WU00:FS01:Started FahCore on PID 14720
23:37:47:WU00:FS01:Core PID:13148
23:37:47:WU00:FS01:FahCore 0xa4 started
23:37:48:WU00:FS01:0xa4:
23:37:48:WU00:FS01:0xa4:*------------------------------*
23:37:48:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
23:37:48:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
23:37:48:WU00:FS01:0xa4:Preparing to commence simulation
23:37:48:WU00:FS01:0xa4:- Looking at optimizations...
23:37:48:WU00:FS01:0xa4:- Created dyn
23:37:48:WU00:FS01:0xa4:- Files status OK
23:37:48:WU00:FS01:0xa4:- Expanded 827433 -> 1400900 (decompressed 169.3 percent)
23:37:48:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=827433 data_size=1400900, decompressed_data_size=1400900 diff=0
23:37:48:WU00:FS01:0xa4:- Digital signature verified
23:37:48:WU00:FS01:0xa4:Project: 9007 (Run 38, Clone 23, Gen 26)
23:37:48:WU00:FS01:0xa4:Assembly optimizations on if available.
23:37:48:WU00:FS01:0xa4:Entering M.D.
23:37:54:WU00:FS01:0xa4:Mapping NT from 12 to 12
~~~ (now 1/21/2014)
01:36:42:WU00:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
01:36:52:WU00:FS01:0xa4:
01:36:52:WU00:FS01:0xa4:Finished Work Unit:
01:36:52:WU00:FS01:0xa4:- Reading up to 811800 from "00/wudata_01.trr": Read 811800
01:36:52:WU00:FS01:0xa4:trr file hash check passed.
01:36:52:WU00:FS01:0xa4:- Reading up to 746252 from "00/wudata_01.xtc": Read 746252
01:36:52:WU00:FS01:0xa4:xtc file hash check passed.
01:36:52:WU00:FS01:0xa4:edr file hash check passed.
01:36:52:WU00:FS01:0xa4:logfile size: 22929
01:36:52:WU00:FS01:0xa4:Leaving Run
01:36:53:WU00:FS01:0xa4:- Writing 1583469 bytes of core data to disk...
01:36:53:WU00:FS01:0xa4:Done: 1582957 -> 1538072 (compressed to 97.1 percent)
01:36:53:WU00:FS01:0xa4:  ... Done.
01:36:53:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:36:53:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:9007 run:38 clone:23 gen:26 core:0xa4 unit:0x0000001e664f2de452ba2b53ee222b18
01:36:54:WU00:FS01:Uploading 1.47MiB to 171.64.65.124
01:36:54:WU00:FS01:Connecting to 171.64.65.124:8080
01:36:56:WU00:FS01:Upload complete
01:36:57:WU00:FS01:Server responded WORK_ACK (400)
01:36:57:WU00:FS01:Final credit estimate, 1778.00 points
01:36:57:WU00:FS01:Cleaning up
******************************* Date: 2014-01-21 *******************************
03:21:29:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
03:21:29:WU00:FS00:News: Welcome to Folding@Home
03:21:29:WU00:FS00:Assigned to work server 171.64.65.69
03:21:29:WU00:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:GK104 [GeForce GTX 770] from 171.64.65.69
03:21:29:WU00:FS00:Connecting to 171.64.65.69:8080
03:21:30:WU00:FS00:Downloading 4.18MiB
03:21:32:WU00:FS00:Download complete
03:21:32:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8900 run:605 clone:1 gen:59 core:0x17 unit:0x00000065028c126651a6ad35054124c2
03:37:56:WU00:FS00:Starting
03:37:56:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Larry/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 703 -lifeline 12300 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
03:37:56:WU00:FS00:Started FahCore on PID 12836
03:37:56:WU00:FS00:Core PID:13296
03:37:56:WU00:FS00:FahCore 0x17 started
03:37:57:WU00:FS00:0x17:*********************** Log Started 2014-01-21T03:37:56Z ***********************
03:37:57:WU00:FS00:0x17:Project: 8900 (Run 605, Clone 1, Gen 59)
03:37:57:WU00:FS00:0x17:Unit: 0x00000065028c126651a6ad35054124c2
03:37:57:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
03:37:57:WU00:FS00:0x17:Machine: 0
03:37:57:WU00:FS00:0x17:Reading tar file state.xml
03:37:57:WU00:FS00:0x17:Reading tar file system.xml
03:37:58:WU00:FS00:0x17:Reading tar file integrator.xml
03:37:58:WU00:FS00:0x17:Reading tar file core.xml
03:37:58:WU00:FS00:0x17:Digital signatures verified
03:37:58:WU00:FS00:0x17:Folding@home GPU core17
03:37:58:WU00:FS00:0x17:Version 0.0.52
03:37:56:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:37:56:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8900 run:818 clone:7 gen:7 core:0x17 unit:0x0000001b028c126651a6dcbd04f8dd49
03:37:56:WU01:FS00:Uploading 12.97MiB to 171.64.65.69
03:37:56:WU01:FS00:Connecting to 171.64.65.69:8080
03:38:02:WU01:FS00:Upload 29.89%
03:38:08:WU01:FS00:Upload 64.11%
03:38:14:WU01:FS00:Upload 93.52%
03:38:24:WU01:FS00:Upload complete
03:38:24:WU01:FS00:Server responded WORK_ACK (400)
03:38:24:WU01:FS00:Final credit estimate, 18334.00 points
03:38:24:WU01:FS00:Cleaning up
01:34:20:WU02:FS01:Connecting to assign3.stanford.edu:8080
01:34:20:WU02:FS01:News: Welcome to Folding@Home
01:34:20:WU02:FS01:Assigned to work server 171.64.65.124
01:34:20:WU02:FS01:Requesting new work unit for slot 01: RUNNING cpu:12 from 171.64.65.124
01:34:20:WU02:FS01:Connecting to 171.64.65.124:8080
01:34:21:WU02:FS01:Downloading 862.47KiB
01:34:22:WU02:FS01:Download complete
01:34:22:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9005 run:26 clone:29 gen:33 core:0xa4 unit:0x00000023664f2de452b8018c75be4623
01:36:54:WU02:FS01:Starting
01:36:54:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Larry/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 703 -lifeline 12300 -checkpoint 15 -np 12
01:36:54:WU02:FS01:Started FahCore on PID 17008
01:36:54:WU02:FS01:Core PID:5420
01:36:54:WU02:FS01:FahCore 0xa4 started
01:36:54:WU02:FS01:0xa4:
01:36:54:WU02:FS01:0xa4:*------------------------------*
01:36:54:WU02:FS01:0xa4:Folding@Home Gromacs GB Core
01:36:54:WU02:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
01:36:54:WU02:FS01:0xa4:Preparing to commence simulation
01:36:54:WU02:FS01:0xa4:- Looking at optimizations...
01:36:54:WU02:FS01:0xa4:- Created dyn
01:36:54:WU02:FS01:0xa4:- Files status OK
01:36:54:WU02:FS01:0xa4:- Expanded 882656 -> 1469104 (decompressed 166.4 percent)
01:36:54:WU02:FS01:0xa4:Called DecompressByteArray: compressed_data_size=882656 data_size=1469104, decompressed_data_size=1469104 diff=0
01:36:54:WU02:FS01:0xa4:- Digital signature verified
01:36:54:WU02:FS01:0xa4:Project: 9005 (Run 26, Clone 29, Gen 33)
01:36:54:WU02:FS01:0xa4:Assembly optimizations on if available.
01:36:54:WU02:FS01:0xa4:Entering M.D.
01:37:00:WU02:FS01:0xa4:Mapping NT from 12 to 12
01:37:00:WU02:FS01:0xa4:Completed 0 out of 250000 steps  (0%)
03:37:53:WU02:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
03:38:06:WU02:FS01:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
03:38:07:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:38:07:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:9005 run:26 clone:29 gen:33 core:0xa4 unit:0x00000023664f2de452b8018c75be4623
03:38:07:WU02:FS01:Uploading 1.57MiB to 171.64.65.124
03:38:07:WU02:FS01:Connecting to 171.64.65.124:8080
03:38:09:WU02:FS01:Upload complete
03:38:09:WU02:FS01:Server responded WORK_ACK (400)
03:38:09:WU02:FS01:Final credit estimate, 1837.00 points
03:38:09:WU02:FS01:Cleaning up
03:35:27:WU03:FS01:Connecting to assign3.stanford.edu:8080
03:35:27:WU03:FS01:News: Welcome to Folding@Home
03:35:27:WU03:FS01:Assigned to work server 171.64.65.101
03:35:27:WU03:FS01:Requesting new work unit for slot 01: RUNNING cpu:12 from 171.64.65.101
03:35:27:WU03:FS01:Connecting to 171.64.65.101:8080
03:35:28:WU03:FS01:Downloading 534.97KiB
03:35:29:WU03:FS01:Download complete
03:35:29:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:7647 run:141 clone:1 gen:168 core:0xa4 unit:0x0000012d664f2dcd4fa7fe80cbaac609
03:38:07:WU03:FS01:Starting
03:38:07:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Larry/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 03 -suffix 01 -version 703 -lifeline 12300 -checkpoint 15 -np 12
03:38:07:WU03:FS01:Started FahCore on PID 14420
03:38:07:WU03:FS01:Core PID:10104
03:38:07:WU03:FS01:FahCore 0xa4 started
03:38:07:WU03:FS01:0xa4:
03:38:07:WU03:FS01:0xa4:*------------------------------*
03:38:07:WU03:FS01:0xa4:Folding@Home Gromacs GB Core
03:38:07:WU03:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
03:38:07:WU03:FS01:0xa4:Preparing to commence simulation
03:38:07:WU03:FS01:0xa4:- Looking at optimizations...
03:38:07:WU03:FS01:0xa4:- Created dyn
03:38:07:WU03:FS01:0xa4:- Files status OK
03:38:07:WU03:FS01:0xa4:- Expanded 547300 -> 846804 (decompressed 154.7 percent)
03:38:07:WU03:FS01:0xa4:Called DecompressByteArray: compressed_data_size=547300 data_size=846804, decompressed_data_size=846804 diff=0
03:38:07:WU03:FS01:0xa4:- Digital signature verified
03:38:07:WU03:FS01:0xa4:Project: 7647 (Run 141, Clone 1, Gen 168)
03:38:07:WU03:FS01:0xa4:Assembly optimizations on if available.
03:38:07:WU03:FS01:0xa4:Entering M.D.
Re: Stats backlog
Please note that the WU Database confirms that you are only getting base points:
Hi Fadamor (team 315),
Your WU (P8900 R818 C7 G7) was added to the stats database on 2014-01-20 20:03:09 for 6000 points of credit.
The reason is that you aren't using the passkey so I would suggest that you get it if you want to get bonus points (once you qualify for it) and for security reasons (http://folding.stanford.edu/home/faq/faq-passkey/).
Fadamor
64GB DDR5 RAM
Re: Not getting expected points [No passkey]
Post by Fadamor »
And MY suggestion would be for Stanford to stop reporting totals including "bonus points" in the log's estimated credits entry when their own website states that passkeys (required for those "bonus points") are not mandatory. If they want to add a line in the log indicating the estimated credit with bonus points and LABEL IT AS SUCH, that would be fine. But as long as they're maintaining that passkeys are optional, it is misleading to only report totals that require a passkey in their log.
Correct, passkeys are not mandatory. Neither are bonus points. You are welcomed to keep folding without either one.
Fixed in next version. Points estimates will show bonus if passkey installed. Points will show base credit (no bonus) if no passkey installed.
Fadamor
64GB DDR5 RAM
Post by Fadamor »
Thank you.
Which doesn't really matter because everyone should be using a Passkey. Every V7 client installer prompts for a passkey.
Fadamor
64GB DDR5 RAM
Post by Fadamor »
7im wrote:Which doesn't really matter because everyone should be using a Passkey. Every V7 client installer prompts for a passkey.
What you're claiming doesn't make sense. Either a passkey is mandatory or it isn't. The Stanford position is that it isn't, so a claim that "everybody should be using a passkey" is disingenuous, at best. Sure, you legally get away with the statement because you used "should" instead of "must", but the tone of your statement makes the passkey mandatory. The fact that the installer prompts for the passkey is mitigated by the fact that the installer ALSO notes that the passkey is optional. The actual text is "For added security, you can request a passkey and enter it here." Note it does not say "you must request a passkey and enter it here". It doesn't even go as far as you did and say "you should request a passkey and enter it here".
There must be a reason why Stanford insisted on not making the passkey mandatory, so please stop with the insistence that "everyone should be using a Passkey". You obviously don't speak for Stanford in this regard.
This is a FAH community support forum. The only people who speak for Stanford are listed as "Pande Group Member" and they use the Stanford crest for their avatar. (See this post) 7im is not one of them and neither am I; we're volunteers, like yourself.
It may not make sense to you, but here's a little history plus my take on the question.
The early versions of FAH did not have passkeys; they're a comparatively "recent" development. Some people still run older clients which don't have passkeys, so the official position is that they're not required. Paying attention to points and bonuses is not required, either. Some donors ignore the points and concentrate only on doing scientific work for purely altruistic reasons.
If you're interested in bonus points, you must have a passkey. My personal opinion (and apparently that of 7im) is that everybody should use a passkey. Consider that as friendly advice. That still leaves the decision entirely in your hands, rather than being covered by Stanford's official requirements.
Fadamor
64GB DDR5 RAM
Re: Stats backlog
Post by Fadamor »
Then getting back to my original post, how can I see what PantherX found regarding my submissions? Going to the F@H website and selecting my username just puts up a summary page with no details about the most recent submissions I've sent.
The Pande Group has chosen to limit access to information like that. Only forum Moderators or Pande Group Members have access to that database. Post the PRCG numbers and I'll gladly look them up for you, particularly if you suspect there was a crediting problem.
You can look at 3rd party stats sites and see individual work units, several are linked from the toolbar at the top of the forum.
The specific info the Mods have is a Mods only search tool. No public access.
Fadamor
64GB DDR5 RAM
Post by Fadamor »
OK, one of the most recent was 8900 (Run 298, Clone 4, Gen 79) and should include bonus points because I added a passkey and restarted the client yesterday at around 18:00Z (shortly after my post here at 12:42pm EST). The WU should have been received this morning at 06:59Z. Based on the entries at http://folding.extremeoverclocking.com/ ... s=&u=55975, two WUs were recorded in that three-hour block yet neither one looks like it includes passkey points. (Extremeoverclocking uses CST and so is six hours behind Zulu time. A 06:59Z submission would be included in Extremeoverclocking's 03:00 CST entry because 06:59Z is 00:59 CST.)
