Basically question is i am doing some very long work units and i am wondering if there big av units and if i am getting bonus for them?
Computer Specs: Sony VPCEH laptop quad core (on board gpu however)
Core Speed 2693.9 MHz
Multiplier x 27.0
Bus Speed 99.8 MHz
Temperature 84 °C
Core Speed 2693.8 MHz
Multiplier x 27.0
Bus Speed 99.8 MHz
Temperature 78 °C
4 gig ram
Network Connection: no problems here, bb connection however/
Operating System: Windows 7 Home Premium 64-bit SP1
Overclocked?: pfft bios would freak if i asked that!
Stable?: Runs high end cad/cam programs ok- despite on board gpu
Software: was downloaded last week-7.3.6 taken from the about on the advanced screen
WU details: i have no idea... as long as it finishes them in the time and i get points its all good,
currently munching on 7517 with an
eta of 1.07 days,
Est tpf 15 mins 50 secs
base cred 785
est cred 3244
est ppd 2591
I have done a few work units like this one some take up to 1.5 days but she has done them within the time frame and others i have done in 3 hours.
I had to close her down earlier as it took 15 ish mins to start doing anything...seems to be a few threads smiler but once restarted and given some time she woke up
Log file:
*********************** Log Started 2014-01-12T19:48:32Z ***********************
19:48:32:************************* Folding@home Client *************************
19:48:32: Website: http://folding.stanford.edu/
19:48:32: Copyright: (c) 2009-2013 Stanford University
19:48:32: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:48:32: Args: --open-web-control
19:48:32: Config: C:/Users/Angela and ben/AppData/Roaming/FAHClient/config.xml
19:48:32:******************************** Build ********************************
19:48:32: Version: 7.3.6
19:48:32: Date: Feb 18 2013
19:48:32: Time: 15:25:17
19:48:32: SVN Rev: 3923
19:48:32: Branch: fah/trunk/client
19:48:32: Compiler: Intel(R) C++ MSVC 1500 mode 1200
19:48:32: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
19:48:32: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
19:48:32: Platform: win32 XP
19:48:32: Bits: 32
19:48:32: Mode: Release
19:48:32:******************************* System ********************************
19:48:32: CPU: Intel(R) Core(TM) i5-2410M CPU @ 2.30GHz
19:48:32: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
19:48:32: CPUs: 4
19:48:32: Memory: 3.95GiB
19:48:32: Free Memory: 1.71GiB
19:48:32: Threads: WINDOWS_THREADS
19:48:32: Has Battery: true
19:48:32: On Battery: false
19:48:32: UTC offset: 0
19:48:32: PID: 5748
19:48:32: CWD: C:/Users/Angela and ben/AppData/Roaming/FAHClient
19:48:32: OS: Windows 7 Home Premium
19:48:32: OS Arch: AMD64
19:48:32: GPUs: 0
19:48:32: CUDA: Not detected
19:48:32:Win32 Service: false
19:48:32:***********************************************************************
19:48:32:<config>
19:48:32: <service-description v='Folding@home Client'/>
19:48:32: <service-restart v='true'/>
19:48:32: <service-restart-delay v='5000'/>
19:48:32:
19:48:32: <!-- Client Control -->
19:48:32: <client-threads v='4'/>
19:48:32: <cycle-rate v='4'/>
19:48:32: <cycles v='-1'/>
19:48:32: <data-directory v='.'/>
19:48:32: <disable-sleep-when-active v='true'/>
19:48:32: <exec-directory v='C:\Program Files (x86)\FAHClient'/>
19:48:32: <exit-when-done v='false'/>
19:48:32: <fold-anon v='false'/>
19:48:32: <open-web-control v='true'/>
19:48:32:
19:48:32: <!-- Configuration -->
19:48:32: <config-rotate v='true'/>
19:48:32: <config-rotate-dir v='configs'/>
19:48:32: <config-rotate-max v='16'/>
19:48:32:
19:48:32: <!-- Debugging -->
19:48:32: <assignment-servers>
19:48:32: assign3.stanford.edu:8080 assign4.stanford.edu:80
19:48:32: </assignment-servers>
19:48:32: <capture-directory v='capture'/>
19:48:32: <capture-on-error v='false'/>
19:48:32: <capture-packets v='false'/>
19:48:32: <capture-requests v='false'/>
19:48:32: <capture-responses v='false'/>
19:48:32: <capture-sockets v='false'/>
19:48:32: <debug-sockets v='false'/>
19:48:32: <exception-locations v='true'/>
19:48:32: <gpu-assignment-servers>
19:48:32: assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
19:48:32: </gpu-assignment-servers>
19:48:32: <stack-traces v='false'/>
19:48:32:
19:48:32: <!-- Error Handling -->
19:48:32: <max-slot-errors v='5'/>
19:48:32: <max-unit-errors v='5'/>
19:48:32:
19:48:32: <!-- Folding Core -->
19:48:32: <checkpoint v='30'/>
19:48:32: <core-dir v='cores'/>
19:48:32: <core-priority v='low'/>
19:48:32: <cpu-affinity v='false'/>
19:48:32: <cpu-usage v='100'/>
19:48:32: <gpu-usage v='100'/>
19:48:32: <no-assembly v='false'/>
19:48:32:
19:48:32: <!-- Folding Slot Configuration -->
19:48:32: <cause v='ANY'/>
19:48:32: <client-subtype v='STDCLI'/>
19:48:32: <client-type v='normal'/>
19:48:32: <cpu-species v='X86_PENTIUM_II'/>
19:48:32: <cpu-type v='AMD64'/>
19:48:32: <cpus v='-1'/>
19:48:32: <cuda-index v='0'/>
19:48:32: <gpu v='true'/>
19:48:32: <max-packet-size v='normal'/>
19:48:32: <opencl-index v='0'/>
19:48:32: <os-species v='UNKNOWN'/>
19:48:32: <os-type v='WIN32'/>
19:48:32: <power v='full'/>
19:48:32: <project-key v='0'/>
19:48:32: <smp v='true'/>
19:48:32:
19:48:32: <!-- HTTP Server -->
19:48:32: <allow v='127.0.0.1'/>
19:48:32: <connection-timeout v='60'/>
19:48:32: <deny v='0/0'/>
19:48:32: <http-addresses v='0:7396'/>
19:48:32: <https-addresses v=''/>
19:48:32: <max-connect-time v='900'/>
19:48:32: <max-connections v='800'/>
19:48:32: <max-request-length v='52428800'/>
19:48:32: <min-connect-time v='300'/>
19:48:32: <threads v='4'/>
19:48:32:
19:48:32: <!-- Logging -->
19:48:32: <log v='log.txt'/>
19:48:32: <log-color v='false'/>
19:48:32: <log-crlf v='true'/>
19:48:32: <log-date v='false'/>
19:48:32: <log-date-periodically v='21600'/>
19:48:32: <log-debug v='true'/>
19:48:32: <log-domain v='false'/>
19:48:32: <log-header v='true'/>
19:48:32: <log-level v='true'/>
19:48:32: <log-no-info-header v='true'/>
19:48:32: <log-redirect v='false'/>
19:48:32: <log-rotate v='true'/>
19:48:32: <log-rotate-dir v='logs'/>
19:48:32: <log-rotate-max v='16'/>
19:48:32: <log-short-level v='false'/>
19:48:32: <log-simple-domains v='true'/>
19:48:32: <log-thread-id v='false'/>
19:48:32: <log-thread-prefix v='true'/>
19:48:32: <log-time v='true'/>
19:48:32: <log-to-screen v='true'/>
19:48:32: <log-truncate v='false'/>
19:48:32: <verbosity v='5'/>
19:48:32:
19:48:32: <!-- Network -->
19:48:32: <proxy v=':8080'/>
19:48:32: <proxy-enable v='false'/>
19:48:32: <proxy-pass v=''/>
19:48:32: <proxy-user v=''/>
19:48:32:
19:48:32: <!-- Process Control -->
19:48:32: <child v='false'/>
19:48:32: <daemon v='false'/>
19:48:32: <pid v='false'/>
19:48:32: <pid-file v='Folding@home Client.pid'/>
19:48:32: <respawn v='false'/>
19:48:32: <service v='false'/>
19:48:32:
19:48:32: <!-- Remote Command Server -->
19:48:32: <command-address v='0.0.0.0'/>
19:48:32: <command-allow-no-pass v='127.0.0.1'/>
19:48:32: <command-deny-no-pass v='0/0'/>
19:48:32: <command-port v='36330'/>
19:48:32:
19:48:32: <!-- Slot Control -->
19:48:32: <idle v='false'/>
19:48:32: <max-shutdown-wait v='60'/>
19:48:32: <pause-on-battery v='true'/>
19:48:32: <pause-on-start v='false'/>
19:48:32:
19:48:32: <!-- User Information -->
19:48:32: <machine-id v='0'/>
19:48:32: <passkey v='********************************'/>
19:48:32: <team v='44831'/>
19:48:32: <user v='Gooders'/>
19:48:32:
19:48:32: <!-- Web Server -->
19:48:32: <session-timeout v='3600'/>
19:48:32: <web-allow v='127.0.0.1'/>
19:48:32: <web-deny v='0/0'/>
19:48:32:
19:48:32: <!-- Work Unit Control -->
19:48:32: <dump-after-deadline v='true'/>
19:48:32: <max-queue v='16'/>
19:48:32: <max-units v='0'/>
19:48:32: <next-unit-percentage v='99'/>
19:48:32:
19:48:32: <!-- Folding Slots -->
19:48:32: <slot id='1' type='CPU'>
19:48:32: </slot>
19:48:32:</config>
19:48:32:Trying to access database...
19:48:32:Successfully acquired database lock
19:48:32:Enabled folding slot 01: READY cpu:4
19:48:32:Started thread 4 on PID 5748
19:48:32:WU00:FS01:Starting
19:48:32:Started thread 5 on PID 5748
19:48:32:Started thread 6 on PID 5748
19:48:32:Started thread 7 on PID 5748
19:48:32:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Angela and ben/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe" -dir 00 -suffix 01 -version 703 -lifeline 5748 -checkpoint 30 -np 4
19:48:32:WU00:FS01:Started FahCore on PID 11120
19:48:32:Started thread 8 on PID 5748
19:48:32:WU00:FS01:Core PID:9772
19:48:32:WU00:FS01:FahCore 0xa3 started
19:48:32:WU00:FS01:0xa3:
19:48:32:WU00:FS01:0xa3:*------------------------------*
19:48:32:WU00:FS01:0xa3:Folding@Home Gromacs SMP Core
19:48:32:WU00:FS01:0xa3:Version 2.27 (Dec. 15, 2010)
19:48:32:WU00:FS01:0xa3:Preparing to commence simulation
19:48:32:WU00:FS01:0xa3:- Looking at optimizations...
19:48:32:WU00:FS01:0xa3:- Files status OK
19:48:32:WU00:FS01:0xa3:- Expanded 2168485 -> 3131648 (decompressed 144.4 percent)
19:48:32:WU00:FS01:0xa3:Called DecompressByteArray: compressed_data_size=2168485 data_size=3131648, decompressed_data_size=3131648 diff=0
19:48:32:WU00:FS01:0xa3:- Digital signature verified
19:48:32:WU00:FS01:0xa3:Project: 7515 (Run 0, Clone 56, Gen 291)
19:48:32:WU00:FS01:0xa3:Assembly optimizations on if available.
19:48:32:WU00:FS01:0xa3:Entering M.D.
19:48:38:WU00:FS01:0xa3:Mapping NT from 4 to 4
19:48:39:WU00:FS01:0xa3:Completed 0 out of 500000 steps (0%)
19:48:44:Started thread 9 on PID 5748
20:02:54:WU00:FS01:0xa3:Completed 5000 out of 500000 steps (1%)
20:16:57:WU00:FS01:0xa3:Completed 10000 out of 500000 steps (2%)
