Team members.
Team members.
Hello my name is Jamie, administrator of Etobifold(49757). When i first started the team i was unaware that i could run multiple systems under one user name (Jamie) so i created sub names. I was wondering if there was a way i could get team members deleted or the score/WU merged with another member.
TKS
v00d00
- 16GB DDR3,
- Zotac GTX 1050Ti @ Stock.
- Gigabyte GTX 970 @ Stock
Debian 9.
Re: Team members.
Sorry, all scores are final when submitted.
For the minute the only time scores and usernames can be manipulated are when a EULA violation has occurred, or you have forgotten your login details (in which case pm MstrBlstr for help with that).
Re: Team members.
All my scores come from the same ip and the user names all have Jamie in the name, and they have not been active for over a year. Can an exception not be made?
Re: Team members.
Stanford's policy on the issue is firm. See also: FAH WIKI: Altering Published Stats
Re: Team members.
Hello Jamie. I create weekly and/or monthly statistics for a number of teams and, as part of that process, I am able to merge two or more entries (usernames) into a single entry in those stats. Obviously, they will not correspond to those on any other stats site, including Stanford, but if you want to see such statistics, I can create them for you. I can post them to my blog Patermann's Place or some of the sites where I currently post statistics would most likely be happy to allow me to post yours there. I will mock some up later to show you what I mean.
patermann
patermann
Re: Team members.
To give you an idea, I have posted two entries to my blog, both of which are statistics for last week (April 29 to May 5). The first post has all of the users separate - i.e. it is generated directly from Stanford's statistics. (Note that only active users are shown - that is why the stats are so short!
) In the second post, I have combined the results for the three "Jamie" users into one. You will see that the total points and work units for user Jamie are higher than in the first post. Also, the team statistics show 4 members rather than 6.
Given that the statistics will never be combined by Stanford, is this an acceptable substitute? Let me know what you think.
patermann
patermann
