I want to make sure that at all time no CPU slot sneak in; stealing resources from GPU support. I saw in the past that when I don't configure a disabled CPU slot the client might recreate and activate a CPU slot.
20:59:10:************************* Folding@home Client *************************
20:59:10: Website: http://folding.stanford.edu/
20:59:10: Copyright: (c) 2009-2013 Stanford University
20:59:10: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:59:10: Args: --child --lifeline 5136 /etc/fahclient/config.xml --run-as
20:59:10: fahclient --pid-file=/var/run/fahclient.pid --daemon
20:59:10: Config: /etc/fahclient/config.xml
20:59:10:******************************** Build ********************************
20:59:10: Version: 7.3.6
20:59:10: Date: Feb 18 2013
20:59:10: Time: 07:24:08
20:59:10: SVN Rev: 3923
20:59:10: Branch: fah/trunk/client
20:59:10: Compiler: GNU 4.4.7
20:59:10: Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
20:59:10: -fno-unsafe-math-optimizations -msse2
20:59:10: Platform: linux2 3.2.0-1-amd64
20:59:10: Bits: 64
20:59:10: Mode: Release
20:59:10:******************************* System ********************************
20:59:10: CPU: Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz
20:59:10: CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
20:59:10: CPUs: 4
20:59:10: Memory: 7.80GiB
20:59:10:Free Memory: 6.79GiB
20:59:10: Threads: POSIX_THREADS
20:59:10:Has Battery: false
20:59:10: On Battery: false
20:59:10: UTC offset: 9
20:59:10: PID: 5143
20:59:10: CWD: /var/lib/fahclient
20:59:10: OS: Linux 3.8.0-19-generic x86_64
20:59:10: OS Arch: AMD64
20:59:10: GPUs: 2
20:59:10: GPU 0: NVIDIA:3 GK110 [GeForce GTX 780]
20:59:10: GPU 1: NVIDIA:3 GK104 [GeForce GTX 660 Ti]
20:59:10: CUDA: 3.5
20:59:10:CUDA Driver: 5050
20:59:10:***********************************************************************
20:59:10:<config>
20:59:10: <!-- Client Control -->
20:59:10: <fold-anon v='true'/>
20:59:10:
20:59:10: <!-- Folding Slot Configuration -->
20:59:10: <gpu v='true'/>
20:59:10: <power v='full'/>
20:59:10:
20:59:10: <!-- Logging -->
20:59:10: <log-rotate-max v='1024'/>
20:59:10:
20:59:10: <!-- Folding Slots -->
20:59:10: <slot id='0' type='GPU'>
20:59:10: <pause-on-start v='true'/>
20:59:10: </slot>
20:59:10: <slot id='1' type='GPU'>
20:59:10: </slot>
20:59:10: <slot id='2' type='CPU'>
20:59:10: <cpus v='2'/>
20:59:10: </slot>
20:59:10:</config>I tried the FAQs but couldn't find any hint how to achieve a CPU-slot prevention.
On a side question: what is the parameter fold-anon ? I assume folding anonymous ... Can I remove that line ? I have my donor ID, group and passkey configured (removed from them config above)
Thanks in advance
