Use Two Machines on my home network?
abrogard
Post by abrogard »
I have installed F@H on two machines on my home winxp network. Without making any network-specific provisions. Is this okay?
Zagen30
Re: Use Two Machines on my home network?
Post by Zagen30 »
Yes. Each machine gets its own unique machine ID to differentiate it to the F@h servers.
Be sure to request and enter a passkey so you get all the optional bonus points.
abrogard
Post by abrogard »
Yes, I did that on the second install - I don't remember it raising the issue on the first one. It's okay then, thankyou, I'll just let them get on with it. Got one more half way decent machine and I'll install on it, too.
GreyWhiskers
--i7 2600K@4.2 GHz
--ASUS P8P67 DeluxeB3
--4GB ADATA 1600 RAM
--750W Corsair PS
--MSI GTX560Ti @900MHz
Post by GreyWhiskers »
abrogard wrote:Yes, I did that on the second install - I don't remember it raising the issue on the first one. It's okay then, thankyou, I'll just let them get on with it. Got one more half way decent machine and I'll install on it, too.
You actually need to explicitly enter the passkey on both machines - it won't automatically generate quick return bonuses on the first machine unless the passkey is added. And, of course, you need to have successfully completed 10 bonus-eligible work units with the passkey present at work unit download with a success rate of 80% or better. Then you will start receiving bonuses on subsequent work units.
abrogard
Post by abrogard »
Oh, okay. I didn't know that. I've just done it.
Thanks.
