GPU process fails hash check
niio
Post by niio »
I just installed FAH. Two slots were set up, one CPU and one GPU. The CPU slot runs fine. The GPU slot waited until I moved the utilization slider to full then tried to start but failed with an I/O error on the hash check. What next? Here is my config and the log failure:
04:09:54:******************************** Build ********************************
04:09:54:      Version: 7.3.6
04:09:54:         Date: Feb 18 2013
04:09:54:         Time: 15:25:17
04:09:54:      SVN Rev: 3923
04:09:54:       Branch: fah/trunk/client
04:09:54:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
04:09:54:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
04:09:54:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
04:09:54:     Platform: win32 XP
04:09:54:         Bits: 32
04:09:54:         Mode: Release
04:09:54:******************************* System ********************************
04:09:54:          CPU: Intel(R) Pentium(R) D CPU 2.80GHz
04:09:54:       CPU ID: GenuineIntel Family 15 Model 4 Stepping 7
04:09:54:         CPUs: 2
04:09:54:       Memory: 3.00GiB
04:09:54:  Free Memory: 1.29GiB
04:09:54:      Threads: WINDOWS_THREADS
04:09:54:  Has Battery: false
04:09:54:   On Battery: false
04:09:54:   UTC offset: -8
04:09:54:          PID: 2468
04:09:54:          CWD: C:/Documents and Settings/p f/Application Data/FAHClient
04:09:54:           OS: Microsoft Windows XP Service Pack 2
04:09:54:      OS Arch: X86
04:09:54:         GPUs: 1
04:09:54:        GPU 0: ATI:4 Radeon HD 5870 (Cypress)
04:09:54:         CUDA: Not detected
04:09:54:Win32 Service: false
Failure
06:08:21:WU01:FS00:Started FahCore on PID 1792
06:08:21:WU01:FS00:Core PID:1184
06:08:21:WU01:FS00:FahCore 0x16 started
06:08:21:WU01:FS00:0x16:
06:08:21:WU01:FS00:0x16:*------------------------------*
06:08:21:WU01:FS00:0x16:Folding@Home GPU Core
06:08:21:WU01:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
06:08:21:WU01:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
06:08:21:WU01:FS00:0x16:Build host: user-f6d030f24f
06:08:21:WU01:FS00:0x16:Board Type: AMD/OpenCL
06:08:21:WU01:FS00:0x16:Core      : x=16
06:08:21:WU01:FS00:0x16: Window's signal control handler registered.
06:08:21:WU01:FS00:0x16:Preparing to commence simulation
06:08:21:WU01:FS00:0x16:- Looking at optimizations...
06:08:21:WU01:FS00:0x16:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
06:08:21:WU01:FS00:0x16:- Created dyn
06:08:21:WU01:FS00:0x16:- Files status OK
06:08:21:WU01:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
06:08:21:WU01:FS00:0x16:- Expanded 44941 -> 171163 (decompressed 380.8 percent)
06:08:21:WU01:FS00:0x16:Called DecompressByteArray: compressed_data_size=44941 data_size=171163, decompressed_data_size=171163 diff=0
06:08:21:WU01:FS00:0x16:- Digital signature verified
06:08:21:WU01:FS00:0x16:Project: 11293 (Run 30, Clone 459, Gen 42)
06:08:21:WU01:FS00:0x16:Assembly optimizations on if available.
06:08:21:WU01:FS00:0x16:Entering M.D.
06:08:23:WU01:FS00:0x16:Tpr hash 01/wudata_01.tpr:  2187573953 1350520304 19743429 766295036 4122020970
06:08:23:WU01:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
06:08:23:WU01:FS00:0x16:Client config unavailable.
06:08:23:WU01:FS00:0x16:Finished fah_main
06:08:23:WU01:FS00:0x16:Successful run
06:08:23:WU01:FS00:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
06:08:23:WU01:FS00:0x16:Starting GUI Server
06:08:23:WU02:FS00:Server responded WORK_ACK (400)
06:08:23:WU02:FS00:Cleaning up
06:08:26:Saving configuration to config.xml
06:08:26:<config>
06:08:26:  <!-- Folding Slot Configuration -->
06:08:26:  <power v='full'/>
06:08:26:
06:08:26:  <!-- User Information -->
06:08:26:  <user v='Niio'/>
06:08:26:
06:08:26:  <!-- Folding Slots -->
06:08:26:  <slot id='0' type='GPU'/>
06:08:26:  <slot id='1' type='CPU'/>
06:08:26:</config>
06:08:33:WU01:FS00:0x16:Reserved 0 bytes for xtc file; Cosm status=0
06:08:33:WU01:FS00:0x16:Reserved 0 0 786430464 bytes for arc file=<01/wudata_01.trr> Cosm status=0
06:08:33:WU01:FS00:0x16:Allocated 544 bytes for edr file
06:08:33:WU01:FS00:0x16:Read bedfile
06:08:33:WU01:FS00:0x16:- Checksum of file (01/wudata_01.edr) read from disk doesn't match
06:08:33:WU01:FS00:0x16:edrfile file hash check failed.
06:08:33:WU01:FS00:0x16:Folding@home Core Shutdown: FILE_IO_ERROR
06:08:33:WARNING:WU01:FS00:FahCore returned: FILE_IO_ERROR (117 = 0x75)
06:08:33:WARNING:WU01:FS00:Fatal error, dumping
06:08:33:WU01:FS00:Sending unit results: id:01 state:SEND error:DUMPED project:11293 run:30 clone:459 gen:42 core:0x16 unit:0x000000f36652edbc4d94bb3bb747cae4
06:08:33:WU01:FS00:Connecting to 171.67.108.44:8080
06:08:33:WU01:FS00:Server responded WORK_ACK (400)
06:08:33:WU01:FS00:Cleaning up
folding_hoomer
Hardware configuration: Sys 1: I7 2700K@4,4GHz with NH-C14
8GB G.Skill Sniper DDR3 1866MHz CL 9-10-9-28
MSI Z68A-GD65 (G3), various operating systems (WinXP, Ubuntu: 10.4.3 LTS, 12.04.2 LTS)
Optional: GTX560TI 448@stock/OC´d
Sys 2: I7 3930K@4,4GHz with Corsair H110
16GB G.Skill Ripjaws X DDR3 1866MHz CL 9-10-9-28
ASUS Ranpage IV Formula, Ubuntu 10.10
Sys 3 i7 875K@3,826 GHz with Scythe Mine2
MSI P55-GD80, Win7 64Bit Pro
Sapphire Radeon HD5870@1,163V 900/1250MHz
Sapphire Radeon HD7870@1,218V 1200/1300MHz
Sys 4 i7 2600K@4,4GHz with Scythe Mine2
Optional:
ASUS P5Q Pro with Q9550
ASUS P5Q Pro with Q6300
Re: GPU process fails hash check
Post by folding_hoomer »
Welcome to the folding@home support forum niio.
1. Which version of Catalyst do you use to fold?
Catalyst 12.8 ist the latest driver known working well with Core16 and HD5870.
2. Do you OC´d your GPU? - If so, please use standart clocks.
3. Why don´t you update your WinXP SP2 to SP3 within the latest corrections?
Maybe this one reason for failing to fold using your HD 5870 - so please update your WinXP-Installation.
AMD-ATI dropped support for OpenCL on Windows XP over a year ago. I forget the number of the release of the drivers that had the last supported OpenCL package, but it was around 12.1 or earlier. So if you have a newer version you will need to completely remove it and revert to an older Catalyst version with OpenCL support from the SDK. Also check through the requirements listed here in the Windows Install Guide.
The 11.12 AMD device driver is the last version to support OpenCL on Windows XP.
niio
Post by niio »
Thanks for all the replies. It was the device driver. I had gone to 12.8 from 13.4, but now rolled back to 11.12 it works.
