long 1-4 interactions and Project 1487
GTron
Post by GTron »
I just completed 4 project 1487 WUs on a new folder and noticed on each the long 1-4 interactions warning in the FAHlog.txt even before the 0 steps message (see example below). The WUs eventually completed, and I was glad not to see the CoreStatus and client-core communication error messages that seem to usually follow, but thought it strange none-the-less. Is this a characteristic of this project or just a coincidence?
The 4 WUs:
Project: 1487 (Run 0, Clone 284, Gen 21)
Project: 1487 (Run 0, Clone 327, Gen 24)
Project: 1487 (Run 0, Clone 812, Gen 22)
Project: 1487 (Run 0, Clone 654, Gen 19)
[22:13:53] *------------------------------*
[22:13:53] Folding@Home Gromacs 3.3 Core
[22:13:53] Version 1.92 (April 17. 2007)
[22:13:53]
[22:13:53] Preparing to commence simulation
[22:13:53] - Looking at optimizations...
[22:13:53] - Created dyn
[22:13:53] - Files status OK
[22:13:53] - Expanded 3627520 -> 16858811 (decompressed 464.7 percent)
[22:13:53] - Starting from initial work packet
[22:13:53]
[22:13:53] Project: 1487 (Run 0, Clone 284, Gen 21)
[22:13:53]
[22:13:54] Assembly optimizations on if available.
[22:13:54] Entering M.D.
[22:14:00] Protein: p1487_DPPC_DOPC_CHOL
[22:14:00] Writing local files
[22:14:01] Extra 3DNow boost OK.
[22:14:01] Extra SSE boost OK.
[22:14:01] Warning:  long 1-4 interactions
[22:14:01] Writing local files
[22:14:02] Completed 0 out of 1000000 steps  (0 percent)
Greg
Re: long 1-4 interactions and Project 1487
This is "normal" for this project and won't cause the end of the WU (like it does usually) ... :)
GTron
Post by GTron »
Thanks toTOW!
It seemed a little too weird to be normal, but to have all 4 be a coincidence seemed even weirder, hence the question. I'm glad it's only weird...I mean "normal"! :wink:
Greg
Post by muziqaz »
I got few of them just now:
[15:10:56] Project: 1487 (Run 0, Clone 857, Gen 15)
[15:10:56] Assembly optimizations on if available.
[15:10:56] Entering M.D.
[15:11:03] Protein: p1487_DPPC_DOPC_CHOL
[15:11:03] Gromacs cannot continue further.
[15:11:03] Going to send back what have done.
[15:11:03] logfile size: 1562
[15:11:03] - Writing 2098 bytes of core data to disk...
[15:11:03]   ... Done.
[b][15:11:03] - Failed to delete work/wudata_05.sas
[15:11:03] - Failed to delete work/wudata_05.goe[/b]
[15:11:03]
[15:11:03] Folding@home Core Shutdown: EARLY_UNIT_END
[15:11:06] CoreStatus = 72 (114)
[15:11:06] Sending work to server
[15:11:06] - Read packet limit of 540015616... Set to 524286976.
[15:11:06] + Attempting to send results
[15:11:06] - Reading file work/wuresults_05.dat from core
[15:11:06]   (Read 2098 bytes from disk)
[15:11:06] Connecting to http://171.65.103.68:8080/
[15:11:07] Posted data.
[15:11:07] Initial: 0000; - Uploaded at ~3 kB/s
[15:11:07] - Averaged speed for that direction ~4 kB/s
[15:11:07] + Results successfully sent
[15:11:07] Thank you for your contribution to Folding@Home.
[15:11:11] Trying to send all finished work units
[15:11:11] + No unsent completed units remaining.
[15:11:11] - Preparing to get new work unit...
[15:11:11] + Attempting to get work packet
[15:11:11] - Will indicate memory of 1000 MB
[15:11:11] - Connecting to assignment server
[15:11:11] Connecting to http://assign.stanford.edu:8080/
[15:11:12] Posted data.
[15:11:12] Initial: 41AB; - Successful: assigned to (171.65.103.68).
[15:11:12] + News From Folding@Home: Welcome to Folding@Home
[15:11:13] Loaded queue successfully.
[15:11:13] Connecting to http://171.65.103.68:8080/
[15:11:15] Posted data.
[15:11:15] Initial: 0000; - Receiving payload (expected size: 879414)
[15:11:32] - Downloaded at ~50 kB/s
[15:11:32] - Averaged speed for that direction ~46 kB/s
[15:11:32] + Received work.
[15:11:32] Trying to send all finished work units
[15:11:32] + No unsent completed units remaining.
[15:11:32] + Closed connections
[15:11:37]
[15:11:37] + Processing work unit
[15:11:37] Core required: FahCore_a0.exe
[15:11:37] Core found.
[15:11:37] Working on Unit 06 [May 5 15:11:37]
[15:11:37] + Working ...
[15:11:37] - Calling 'FahCore_a0.exe -dir work/ -suffix 06 -priority 96 -checkpoint 3 -forceasm -verbose -lifeline 896 -version 601'
[15:11:37] *------------------------------*
[15:11:37] Folding@Home Gromacs 3.3 Core
[15:11:37] Version 1.92 (April 17, 2007)
[15:11:37]
[15:11:37] Preparing to commence simulation
[15:11:37] - Assembly optimizations manually forced on.
[15:11:37] - Not checking prior termination.
[15:11:39] - Expanded 878902 -> 8670083 (decompressed 986.4 percent)
[15:11:39] - Starting from initial work packet
[15:11:39]
[15:11:39] Project: 1487 (Run 0, Clone 665, Gen 14)
[15:11:39]
[15:11:39] Assembly optimizations on if available.
[15:11:39] Entering M.D.
[15:11:46] Protein: p1487_DPPC_DOPC_CHOL
[b][15:11:46] Gromacs cannot continue further.[/b]
[15:11:46] Going to send back what have done.
[15:11:46] logfile size: 0
[b][15:11:46] Warning: Core could not open logfile.[/b]
[15:11:46] - Writing 536 bytes of core data to disk...
[15:11:46]   ... Done.
[b][15:11:46] - Failed to delete work/wudata_06.sas
[15:11:46] - Failed to delete work/wudata_06.goe[/b]
[15:11:46]
[15:11:46] Folding@home Core Shutdown: EARLY_UNIT_END
[15:11:49] CoreStatus = 72 (114)
[15:11:49] Sending work to server
[15:11:49] - Read packet limit of 540015616... Set to 524286976.
[15:11:49] + Attempting to send results
[15:11:49] - Reading file work/wuresults_06.dat from core
[15:11:49]   (Read 536 bytes from disk)
[15:11:49] Connecting to http://171.65.103.68:8080/
[15:11:50] Posted data.
[15:11:55] Initial: 41AB; - Successful: assigned to (171.65.103.68).
[15:11:55] + News From Folding@Home: Welcome to Folding@Home
[15:11:55] Loaded queue successfully.
[15:11:55] Connecting to http://171.65.103.68:8080/
[15:12:01] Posted data.
[15:12:01] Initial: 0000; - Receiving payload (expected size: 3619754)
[15:13:27] - Downloaded at ~41 kB/s
[15:13:27] - Averaged speed for that direction ~45 kB/s
[15:13:27] + Received work.
[15:13:27] Trying to send all finished work units
[15:13:27] + No unsent completed units remaining.
[15:13:27] + Closed connections
[15:13:32]
[15:13:32] + Processing work unit
[15:13:32] Core required: FahCore_a0.exe
[15:13:32] Core found.
[15:13:40] Project: 1487 (Run 0, Clone 716, Gen 26)
[15:13:40]
[15:13:41] Assembly optimizations on if available.
[15:13:41] Entering M.D.
[15:13:48] Protein: p1487_DPPC_DOPC_CHOL
[15:13:48] Writing local files
[15:13:55] Extra SSE boost OK.
[b][15:13:56] Warning:  long 1-4 interactions[/b]
[15:13:56] Writing local files
[15:13:56] Completed 0 out of 1000000 steps  (0 percent)
[15:16:57] Timered checkpoint triggered.
[15:19:58] Timered checkpoint triggered.
[15:23:00] Timered checkpoint triggered.
notice 15:11:46 mark.
and as you can see from last lines of the logfile, now it looks like it is folding alright.
PC: Sempron 2800+ 2ghz, 1.5ghz ram, Win XP. not overclock, 100% stable.
FAH Omega tester
[BrainBug]
Post by [BrainBug] »
What exactly is project 1487? It's rather large and taking quite a long time to move 1%. I'm hoping the point value is worth it. :)
The project lookup page says it's a new project and stay tuned :\
Project Number	Server IP	Work Unit Name	Number of Atoms	Preferred (days)	Final deadline (days) 	Credit	Frames	Code	Description	Contact
1487	 171.65.103.68 	p1487_DPPC_DOPC_CHOL	87920	 47.00	 150.00	 1741.00	100	GROMACS33	Description	kasson
[BrainBug]
Nice! I have 2 or 3 or those chugging along. Anyone know what this project deals with though? Rough description or anything?
