Folding with Radeon HD 5650 (notebook)
CookieB
Post by CookieB »
hy,
I installed the software on my hp pavilion dv7 4050 ed notebook.
The CPU is an Intel core I5 M 430 and it is folding without any problem (I think)
The GPU, an ATI mobility Radeon HD 5650 is giving me problems.
It is in the slot but after it finaly starts after being constant in "waiting for idle" is states "failed" after a couple of seconds.
It seems like I'm not able to update my driver, if I try it gives a message I have to use the driver provided by HP
http://h10025.www1.hp.com/ewfrf/wc/soft ... 3236#N1425
I have 4GB of Ram, running windows 7 64bit
Is it possible to get it working?
Mod Edit: Removed Code Tags - PantherX
Re: Folding with Radeon HD 5650 (notebook)
Welcome to foldingforum.org, CookieB.
The default configuration for a laptop GPU is to run only when idle -- sort of like a screensaver would run. If you leave your machine unattended, the GPU will start processing but you really won't be able to see that because (also about like trying to see how much CPU time a screensaver is using) the WebControl or FAHControl program won't be visible until you interrupt the idle state which will pause the GPU again.
I've seen reports that repeatedly interrupting the GPU leads to a reported WU failure. I have not confirmed that as a bug but that's not the way it's supposed to operate.
Leave your laptop folding overnight and then post the segment showing what happened. Note that the times in the log are in GMT so you'll have to adjust for whatever timezone you're in.
CookieB
Post by CookieB »
Selected a GPU slot and let it run for while I was at school, here is the log file.
05:57:54:WARNING:WU01:FS01:Detected clock skew (6 hours 56 mins), adjusting time estimates
05:58:39:Removing old file 'configs/config-20130324-151925.xml'
05:58:39:Saving configuration to config.xml
05:58:39:<config>
05:58:39:  <!-- Folding Core -->
05:58:39:  <checkpoint v='10'/>
05:58:39:  <cpu-usage v='90'/>
05:58:39:
05:58:39:  <!-- Folding Slot Configuration -->
05:58:39:  <power v='full'/>
05:58:39:
05:58:39:  <!-- Network -->
05:58:39:  <proxy v=':8080'/>
05:58:39:
05:58:39:  <!-- Slot Control -->
05:58:39:  <pause-on-battery v='false'/>
05:58:39:
05:58:39:  <!-- User Information -->
05:58:39:  <passkey v='********************************'/>
05:58:39:  <team v='223518'/>
05:58:39:  <user v='CookieB'/>
05:58:39:
05:58:39:  <!-- Folding Slots -->
05:58:39:  <slot id='1' type='CPU'/>
05:58:39:</config>
05:58:39:FS01:Shutting core down
05:58:39:WU01:FS01:0xa4:Client no longer detected. Shutting down core
05:58:39:WU01:FS01:0xa4:Folding@home Core Shutdown: CLIENT_DIED
05:58:39:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
05:58:40:WU01:FS01:Starting
05:58:40:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bart/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 703 -lifeline 1404 -checkpoint 10 -cpu 90 -np 4
05:58:40:WU01:FS01:Started FahCore on PID 756
05:58:40:WU01:FS01:Core PID:6380
05:58:40:WU01:FS01:FahCore 0xa4 started
05:58:40:WU01:FS01:0xa4:
05:58:40:WU01:FS01:0xa4:*------------------------------*
05:58:40:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
05:58:40:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
05:58:40:WU01:FS01:0xa4:Preparing to commence simulation
05:58:40:WU01:FS01:0xa4:- Looking at optimizations...
05:58:40:WU01:FS01:0xa4:- Files status OK
05:58:41:WU01:FS01:0xa4:- Expanded 2054063 -> 5365960 (decompressed 261.2 percent)
05:58:41:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2054063 data_size=5365960, decompressed_data_size=5365960 diff=0
05:58:41:WU01:FS01:0xa4:- Digital signature verified
05:58:41:WU01:FS01:0xa4:Project: 7808 (Run 2, Clone 338, Gen 37)
05:58:41:WU01:FS01:0xa4:Assembly optimizations on if available.
05:58:41:WU01:FS01:0xa4:Entering M.D.
05:58:47:WU01:FS01:0xa4:Using Gromacs checkpoints
05:58:47:WU01:FS01:0xa4:Mapping NT from 4 to 4
05:58:48:WU01:FS01:0xa4:Resuming from checkpoint
05:58:48:WU01:FS01:0xa4:Verified 01/wudata_01.log
05:58:49:WU01:FS01:0xa4:Verified 01/wudata_01.trr
05:58:49:WU01:FS01:0xa4:Verified 01/wudata_01.xtc
05:58:49:WU01:FS01:0xa4:Verified 01/wudata_01.edr
05:58:51:WU01:FS01:0xa4:Completed 551350 out of 1500000 steps  (36%)
06:01:29:Removing old file 'configs/config-20130324-161452.xml'
06:01:29:Saving configuration to config.xml
06:01:29:<config>
06:01:29:  <!-- Folding Core -->
06:01:29:  <checkpoint v='10'/>
06:01:29:  <cpu-usage v='85'/>
06:01:29:
06:01:29:  <!-- Folding Slot Configuration -->
06:01:29:  <power v='full'/>
06:01:29:
06:01:29:  <!-- Network -->
06:01:29:  <proxy v=':8080'/>
06:01:29:
06:01:29:  <!-- Slot Control -->
06:01:29:  <pause-on-battery v='false'/>
06:01:29:
06:01:29:  <!-- User Information -->
06:01:29:  <passkey v='********************************'/>
06:01:29:  <team v='223518'/>
06:01:29:  <user v='CookieB'/>
06:01:29:
06:01:29:  <!-- Folding Slots -->
06:01:29:  <slot id='1' type='CPU'/>
06:01:29:</config>
06:01:29:FS01:Shutting core down
06:01:32:WU01:FS01:0xa4:Client no longer detected. Shutting down core
06:01:32:WU01:FS01:0xa4:Folding@home Core Shutdown: CLIENT_DIED
06:01:32:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
06:01:32:WU01:FS01:Starting
06:01:32:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bart/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 703 -lifeline 1404 -checkpoint 10 -cpu 85 -np 4
06:01:33:WU01:FS01:Started FahCore on PID 612
06:01:33:WU01:FS01:Core PID:784
06:01:33:WU01:FS01:FahCore 0xa4 started
06:01:33:WU01:FS01:0xa4:
06:01:33:WU01:FS01:0xa4:*------------------------------*
06:01:33:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
06:01:33:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
06:01:33:WU01:FS01:0xa4:Preparing to commence simulation
06:01:33:WU01:FS01:0xa4:- Looking at optimizations...
06:01:33:WU01:FS01:0xa4:- Files status OK
06:01:33:WU01:FS01:0xa4:- Expanded 2054063 -> 5365960 (decompressed 261.2 percent)
06:01:33:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2054063 data_size=5365960, decompressed_data_size=5365960 diff=0
06:01:33:WU01:FS01:0xa4:- Digital signature verified
06:01:33:WU01:FS01:0xa4:Project: 7808 (Run 2, Clone 338, Gen 37)
06:01:33:WU01:FS01:0xa4:Assembly optimizations on if available.
06:01:33:WU01:FS01:0xa4:Entering M.D.
06:01:40:WU01:FS01:0xa4:Using Gromacs checkpoints
06:01:40:WU01:FS01:0xa4:Mapping NT from 4 to 4
06:01:40:WU01:FS01:0xa4:Resuming from checkpoint
06:01:40:WU01:FS01:0xa4:Verified 01/wudata_01.log
06:01:40:WU01:FS01:0xa4:Verified 01/wudata_01.trr
06:01:40:WU01:FS01:0xa4:Verified 01/wudata_01.xtc
06:01:40:WU01:FS01:0xa4:Verified 01/wudata_01.edr
06:01:41:WU01:FS01:0xa4:Completed 551350 out of 1500000 steps  (36%)
06:09:57:WU01:FS01:0xa4:Completed 555000 out of 1500000 steps  (37%)
06:13:20:Removing old file 'configs/config-20130324-161654.xml'
06:13:20:Saving configuration to config.xml
06:13:20:<config>
06:13:20:  <!-- Folding Core -->
06:13:20:  <checkpoint v='10'/>
06:13:20:  <cpu-usage v='80'/>
06:13:20:
06:13:20:  <!-- Folding Slot Configuration -->
06:13:20:  <power v='full'/>
06:13:20:
06:13:20:  <!-- Network -->
06:13:20:  <proxy v=':8080'/>
06:13:20:
06:13:20:  <!-- Slot Control -->
06:13:20:  <pause-on-battery v='false'/>
06:13:20:
06:13:20:  <!-- User Information -->
06:13:20:  <passkey v='********************************'/>
06:13:20:  <team v='223518'/>
06:13:20:  <user v='CookieB'/>
06:13:20:
06:13:20:  <!-- Folding Slots -->
06:13:20:  <slot id='1' type='CPU'/>
06:13:20:</config>
06:13:20:FS01:Shutting core down
06:13:26:WU01:FS01:0xa4:Client no longer detected. Shutting down core
06:13:26:WU01:FS01:0xa4:Folding@home Core Shutdown: CLIENT_DIED
06:13:26:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
06:13:26:WU01:FS01:Starting
06:13:26:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bart/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 703 -lifeline 1404 -checkpoint 10 -cpu 80 -np 4
06:13:26:WU01:FS01:Started FahCore on PID 4244
06:13:26:WU01:FS01:Core PID:4820
06:13:26:WU01:FS01:FahCore 0xa4 started
06:13:27:WU01:FS01:0xa4:
06:13:27:WU01:FS01:0xa4:*------------------------------*
06:13:27:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
06:13:27:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
06:13:27:WU01:FS01:0xa4:Preparing to commence simulation
06:13:27:WU01:FS01:0xa4:- Looking at optimizations...
06:13:27:WU01:FS01:0xa4:- Files status OK
06:13:27:WU01:FS01:0xa4:- Expanded 2054063 -> 5365960 (decompressed 261.2 percent)
06:13:27:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2054063 data_size=5365960, decompressed_data_size=5365960 diff=0
06:13:27:WU01:FS01:0xa4:- Digital signature verified
06:13:27:WU01:FS01:0xa4:Project: 7808 (Run 2, Clone 338, Gen 37)
06:13:27:WU01:FS01:0xa4:Assembly optimizations on if available.
06:13:27:WU01:FS01:0xa4:Entering M.D.
06:13:33:WU01:FS01:0xa4:Using Gromacs checkpoints
06:13:33:WU01:FS01:0xa4:Mapping NT from 4 to 4
06:13:34:WU01:FS01:0xa4:Resuming from checkpoint
06:13:34:WU01:FS01:0xa4:Verified 01/wudata_01.log
06:13:34:WU01:FS01:0xa4:Verified 01/wudata_01.trr
06:13:34:WU01:FS01:0xa4:Verified 01/wudata_01.xtc
06:13:34:WU01:FS01:0xa4:Verified 01/wudata_01.edr
06:13:34:WU01:FS01:0xa4:Completed 555770 out of 1500000 steps  (37%)
06:14:24:Adding folding slot 00: READY gpu:0:Redwood [Radeon HD 5600 Series]
06:14:24:Removing old file 'configs/config-20130324-162701.xml'
06:14:24:Saving configuration to config.xml
06:14:24:<config>
06:14:24:  <!-- Folding Core -->
06:14:24:  <checkpoint v='10'/>
06:14:24:  <cpu-usage v='80'/>
06:14:24:
06:14:24:  <!-- Folding Slot Configuration -->
06:14:24:  <power v='full'/>
06:14:24:
06:14:24:  <!-- Network -->
06:14:24:  <proxy v=':8080'/>
06:14:24:
06:14:24:  <!-- Slot Control -->
06:14:24:  <pause-on-battery v='false'/>
06:14:24:
06:14:24:  <!-- User Information -->
06:14:24:  <passkey v='********************************'/>
06:14:24:  <team v='223518'/>
06:14:24:  <user v='CookieB'/>
06:14:24:
06:14:24:  <!-- Folding Slots -->
06:14:24:  <slot id='1' type='CPU'/>
06:14:24:  <slot id='0' type='GPU'/>
06:14:24:</config>
06:14:24:FS01:Shutting core down
06:14:24:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
06:14:25:WU00:FS00:News: Welcome to Folding@Home
06:14:25:WU00:FS00:Assigned to work server 171.67.108.44
06:14:25:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Redwood [Radeon HD 5600 Series] from 171.67.108.44
06:14:25:WU00:FS00:Connecting to 171.67.108.44:8080
06:14:27:WU00:FS00:Downloading 44.34KiB
06:14:27:WU00:FS00:Download complete
06:14:27:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11292 run:13 clone:8 gen:17 core:0x16 unit:0x000001336652edbc4caa47ca00000085
06:14:27:WU00:FS00:Starting
06:14:27:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bart/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 703 -lifeline 1404 -checkpoint 10 -gpu 0 -gpu-vendor ati
06:14:27:WU00:FS00:Started FahCore on PID 6852
06:14:27:WU00:FS00:Core PID:4452
06:14:27:WU00:FS00:FahCore 0x16 started
06:14:27:WU00:FS00:0x16:
06:14:27:WU00:FS00:0x16:*------------------------------*
06:14:27:WU00:FS00:0x16:Folding@Home GPU Core
06:14:27:WU00:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
06:14:27:WU00:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
06:14:27:WU00:FS00:0x16:Build host: user-f6d030f24f
06:14:27:WU00:FS00:0x16:Board Type: AMD/OpenCL
06:14:27:WU00:FS00:0x16:Core      : x=16
06:14:27:WU00:FS00:0x16: Window's signal control handler registered.
06:14:27:WU00:FS00:0x16:Preparing to commence simulation
06:14:27:WU00:FS00:0x16:- Looking at optimizations...
06:14:27:WU00:FS00:0x16:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
06:14:27:WU00:FS00:0x16:- Created dyn
06:14:27:WU00:FS00:0x16:- Files status OK
06:14:27:WU00:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
06:14:27:WU00:FS00:0x16:- Expanded 44894 -> 171163 (decompressed 381.2 percent)
06:14:27:WU00:FS00:0x16:Called DecompressByteArray: compressed_data_size=44894 data_size=171163, decompressed_data_size=171163 diff=0
06:14:27:WU00:FS00:0x16:- Digital signature verified
06:14:27:WU00:FS00:0x16:Project: 11292 (Run 13, Clone 8, Gen 17)
06:14:27:WU00:FS00:0x16:Assembly optimizations on if available.
06:14:27:WU00:FS00:0x16:Entering M.D.
06:14:29:WU00:FS00:0x16:Tpr hash 00/wudata_01.tpr:  3216169210 21785347 2264929853 1407427910 1590601260
06:14:29:WU00:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
06:14:29:WU00:FS00:0x16:Client config unavailable.
06:14:30:WU00:FS00:0x16:Starting GUI Server
06:14:30:WU00:FS00:0x16:Run: exception thrown in GuardedRun -- cannot continue further.
06:14:30:WU00:FS00:0x16:Going to send back what have done -- stepsTotalG=0
06:14:30:WU00:FS00:0x16:Work fraction=0.0000 steps=0.
06:14:32:WU01:FS01:0xa4:Client no longer detected. Shutting down core
06:14:32:WU01:FS01:0xa4:Folding@home Core Shutdown: CLIENT_DIED
06:14:32:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
06:14:33:WU01:FS01:Starting
06:14:33:WARNING:WU01:FS01:Changed SMP threads from 4 to 3 this can cause some work units to fail
06:14:33:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bart/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 703 -lifeline 1404 -checkpoint 10 -cpu 80 -np 3
06:14:33:WU01:FS01:Started FahCore on PID 6532
06:14:33:WU01:FS01:Core PID:4936
06:14:33:WU01:FS01:FahCore 0xa4 started
06:14:33:WU01:FS01:0xa4:
06:14:33:WU01:FS01:0xa4:*------------------------------*
06:14:33:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
06:14:33:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
06:14:33:WU01:FS01:0xa4:Preparing to commence simulation
06:14:33:WU01:FS01:0xa4:- Looking at optimizations...
06:14:33:WU01:FS01:0xa4:- Files status OK
06:14:33:WU01:FS01:0xa4:- Expanded 2054063 -> 5365960 (decompressed 261.2 percent)
06:14:33:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2054063 data_size=5365960, decompressed_data_size=5365960 diff=0
06:14:33:WU01:FS01:0xa4:- Digital signature verified
06:14:33:WU01:FS01:0xa4:Project: 7808 (Run 2, Clone 338, Gen 37)
06:14:34:WU01:FS01:0xa4:Assembly optimizations on if available.
06:14:34:WU01:FS01:0xa4:Entering M.D.
06:14:34:WARNING:WU00:FS00:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
06:14:34:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:11292 run:13 clone:8 gen:17 core:0x16 unit:0x000001336652edbc4caa47ca00000085
06:14:34:WU00:FS00:Uploading 633B to 171.67.108.44
06:14:34:WU00:FS00:Connecting to 171.67.108.44:8080
06:14:34:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
06:14:34:WU00:FS00:Upload complete
06:14:34:WU00:FS00:Server responded WORK_ACK (400)
06:14:34:WU00:FS00:Cleaning up
06:14:35:WU02:FS00:News: Welcome to Folding@Home
06:14:35:WU02:FS00:Assigned to work server 171.67.108.44
06:14:35:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:Redwood [Radeon HD 5600 Series] from 171.67.108.44
06:14:35:WU02:FS00:Connecting to 171.67.108.44:8080
06:14:36:WU02:FS00:Downloading 44.61KiB
06:14:36:WU02:FS00:Download complete
06:14:36:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11293 run:11 clone:57 gen:42 core:0x16 unit:0x00000b416652edbc4d9257f6b1fe53b6
06:14:36:WU02:FS00:Starting
06:14:36:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bart/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 703 -lifeline 1404 -checkpoint 10 -gpu 0 -gpu-vendor ati
06:14:36:WU02:FS00:Started FahCore on PID 4636
06:14:36:WU02:FS00:Core PID:1520
06:14:36:WU02:FS00:FahCore 0x16 started
06:14:37:WU02:FS00:0x16:
06:14:37:WU02:FS00:0x16:*------------------------------*
06:14:37:WU02:FS00:0x16:Folding@Home GPU Core
06:14:37:WU02:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
06:14:37:WU02:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
06:14:37:WU02:FS00:0x16:Build host: user-f6d030f24f
06:14:37:WU02:FS00:0x16:Board Type: AMD/OpenCL
06:14:37:WU02:FS00:0x16:Core      : x=16
06:14:37:WU02:FS00:0x16: Window's signal control handler registered.
06:14:37:WU02:FS00:0x16:Preparing to commence simulation
06:14:37:WU02:FS00:0x16:- Looking at optimizations...
06:14:37:WU02:FS00:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
06:14:37:WU02:FS00:0x16:- Created dyn
06:14:37:WU02:FS00:0x16:- Files status OK
06:14:37:WU02:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
06:14:37:WU02:FS00:0x16:- Expanded 45173 -> 171163 (decompressed 378.9 percent)
06:14:37:WU02:FS00:0x16:Called DecompressByteArray: compressed_data_size=45173 data_size=171163, decompressed_data_size=171163 diff=0
06:14:37:WU02:FS00:0x16:- Digital signature verified
06:14:37:WU02:FS00:0x16:Project: 11293 (Run 11, Clone 57, Gen 42)
06:14:37:WU02:FS00:0x16:Assembly optimizations on if available.
06:14:37:WU02:FS00:0x16:Entering M.D.
06:14:38:WU02:FS00:0x16:Tpr hash 02/wudata_01.tpr:  3038873866 1072707407 473333679 1424072527 2790074996
06:14:39:WU02:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
06:14:39:WU02:FS00:0x16:Client config unavailable.
06:14:39:WU02:FS00:0x16:Run: exception thrown in GuardedRun -- cannot continue further.
06:14:39:WU02:FS00:0x16:Going to send back what have done -- stepsTotalG=0
06:14:39:WU02:FS00:0x16:Work fraction=0.0000 steps=0.
06:14:39:WU02:FS00:0x16:Starting GUI Server
06:14:39:WU01:FS01:0xa4:Using Gromacs checkpoints
06:14:40:WU01:FS01:0xa4:Mapping NT from 3 to 3
06:14:40:WU01:FS01:0xa4:Resuming from checkpoint
06:14:40:WU01:FS01:0xa4:Verified 01/wudata_01.log
06:14:40:WU01:FS01:0xa4:Verified 01/wudata_01.trr
06:14:40:WU01:FS01:0xa4:Verified 01/wudata_01.xtc
06:14:40:WU01:FS01:0xa4:Verified 01/wudata_01.edr
06:14:41:WU01:FS01:0xa4:Completed 555770 out of 1500000 steps  (37%)
06:14:43:WU02:FS00:0x16:logfile size=0 infoLength=0 edr=0 trr=23
06:14:43:WU02:FS00:0x16:+ Opened results file
06:14:43:WU02:FS00:0x16:- Writing 633 bytes of core data to disk...
06:14:43:WU02:FS00:0x16:Done: 121 -> 123 (compressed to 101.6 percent)
06:14:43:WU02:FS00:0x16:  ... Done.
06:14:43:WU02:FS00:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
06:14:43:WU02:FS00:0x16:Folding@home Core Shutdown: UNSTABLE_MACHINE
06:14:43:WARNING:WU02:FS00:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
06:14:43:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:11293 run:11 clone:57 gen:42 core:0x16 unit:0x00000b416652edbc4d9257f6b1fe53b6
06:14:43:WU02:FS00:Uploading 635B to 171.67.108.44
06:14:43:WU02:FS00:Connecting to 171.67.108.44:8080
06:14:43:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
06:14:43:WU02:FS00:Upload complete
06:14:43:WU02:FS00:Server responded WORK_ACK (400)
06:14:43:WU02:FS00:Cleaning up
06:14:44:WU00:FS00:News: Welcome to Folding@Home
06:14:44:WU00:FS00:Assigned to work server 171.67.108.44
06:14:44:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Redwood [Radeon HD 5600 Series] from 171.67.108.44
06:14:44:WU00:FS00:Connecting to 171.67.108.44:8080
06:14:45:WU00:FS00:Downloading 44.31KiB
06:14:45:WU00:FS00:Download complete
06:14:46:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11292 run:14 clone:93 gen:17 core:0x16 unit:0x000000b76652edbc4d096dd681346ac8
06:14:46:WU00:FS00:Starting
06:14:46:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bart/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 703 -lifeline 1404 -checkpoint 10 -gpu 0 -gpu-vendor ati
06:14:46:WU00:FS00:Started FahCore on PID 1156
06:14:46:WU00:FS00:Core PID:4128
06:14:46:WU00:FS00:FahCore 0x16 started
06:14:46:WU00:FS00:0x16:
06:14:46:WU00:FS00:0x16:*------------------------------*
06:14:46:WU00:FS00:0x16:Folding@Home GPU Core
06:14:46:WU00:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
06:14:46:WU00:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
06:14:46:WU00:FS00:0x16:Build host: user-f6d030f24f
06:14:46:WU00:FS00:0x16:Board Type: AMD/OpenCL
06:14:46:WU00:FS00:0x16:Core      : x=16
06:14:46:WU00:FS00:0x16: Window's signal control handler registered.
06:14:46:WU00:FS00:0x16:Preparing to commence simulation
06:14:46:WU00:FS00:0x16:- Looking at optimizations...
06:14:46:WU00:FS00:0x16:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
06:14:46:WU00:FS00:0x16:- Created dyn
06:14:46:WU00:FS00:0x16:- Files status OK
06:14:46:WU00:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
06:14:46:WU00:FS00:0x16:- Expanded 44857 -> 171163 (decompressed 381.5 percent)
06:14:46:WU00:FS00:0x16:Called DecompressByteArray: compressed_data_size=44857 data_size=171163, decompressed_data_size=171163 diff=0
06:14:46:WU00:FS00:0x16:- Digital signature verified
06:14:46:WU00:FS00:0x16:Project: 11292 (Run 14, Clone 93, Gen 17)
06:14:46:WU00:FS00:0x16:Assembly optimizations on if available.
06:14:46:WU00:FS00:0x16:Entering M.D.
06:14:48:WU00:FS00:0x16:Tpr hash 00/wudata_01.tpr:  463622311 2438182482 2788540921 761823630 2174357989
06:14:48:WU00:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
06:14:48:WU00:FS00:0x16:Client config unavailable.
06:14:48:WU00:FS00:0x16:Starting GUI Server
06:14:48:WU00:FS00:0x16:Run: exception thrown in GuardedRun -- cannot continue further.
06:14:48:WU00:FS00:0x16:Going to send back what have done -- stepsTotalG=0
06:14:48:WU00:FS00:0x16:Work fraction=0.0000 steps=0.
06:14:53:WU00:FS00:0x16:logfile size=0 infoLength=0 edr=0 trr=23
06:14:53:WU00:FS00:0x16:+ Opened results file
06:14:53:WU00:FS00:0x16:- Writing 633 bytes of core data to disk...
06:14:53:WU00:FS00:0x16:Done: 121 -> 121 (compressed to 100.0 percent)
06:14:53:WU00:FS00:0x16:  ... Done.
06:14:53:WU00:FS00:0x16:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
06:14:53:WU00:FS00:0x16:Folding@home Core Shutdown: UNSTABLE_MACHINE
06:14:53:WARNING:WU00:FS00:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
06:14:53:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:11292 run:14 clone:93 gen:17 core:0x16 unit:0x000000b76652edbc4d096dd681346ac8
06:14:53:WU00:FS00:Uploading 633B to 171.67.108.44
06:14:53:WU00:FS00:Connecting to 171.67.108.44:8080
06:14:53:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
06:14:53:WU00:FS00:Upload complete
06:14:53:WU00:FS00:Server responded WORK_ACK (400)
06:14:53:WU00:FS00:Cleaning up
06:14:54:WU02:FS00:News: Welcome to Folding@Home
06:14:54:WU02:FS00:Assigned to work server 171.67.108.44
06:14:54:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:Redwood [Radeon HD 5600 Series] from 171.67.108.44
06:14:54:WU02:FS00:Connecting to 171.67.108.44:8080
06:14:55:WU02:FS00:Downloading 44.58KiB
06:14:55:WU02:FS00:Download complete
06:14:56:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11293 run:10 clone:83 gen:42 core:0x16 unit:0x0000093d6652edbc4d9257c2b9a10c1c
06:14:56:WU02:FS00:Starting
06:14:56:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bart/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 703 -lifeline 1404 -checkpoint 10 -gpu 0 -gpu-vendor ati
06:14:56:WU02:FS00:Started FahCore on PID 5888
06:14:56:WU02:FS00:Core PID:6160
06:14:56:WU02:FS00:FahCore 0x16 started
06:14:56:WU02:FS00:0x16:
06:14:56:WU02:FS00:0x16:*------------------------------*
06:14:56:WU02:FS00:0x16:Folding@Home GPU Core
06:14:56:WU02:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
06:14:56:WU02:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
06:14:56:WU02:FS00:0x16:Build host: user-f6d030f24f
06:14:56:WU02:FS00:0x16:Board Type: AMD/OpenCL
06:14:56:WU02:FS00:0x16:Core      : x=16
06:14:56:WU02:FS00:0x16: Window's signal control handler registered.
06:14:56:WU02:FS00:0x16:Preparing to commence simulation
06:14:56:WU02:FS00:0x16:- Looking at optimizations...
06:14:56:WU02:FS00:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
06:14:56:WU02:FS00:0x16:- Created dyn
06:14:56:WU02:FS00:0x16:- Files status OK
06:14:56:WU02:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
06:14:56:WU02:FS00:0x16:- Expanded 45133 -> 171163 (decompressed 379.2 percent)
06:14:56:WU02:FS00:0x16:Called DecompressByteArray: compressed_data_size=45133 data_size=171163, decompressed_data_size=171163 diff=0
06:14:56:WU02:FS00:0x16:- Digital signature verified
06:14:56:WU02:FS00:0x16:Project: 11293 (Run 10, Clone 83, Gen 42)
06:14:56:WU02:FS00:0x16:Assembly optimizations on if available.
06:14:56:WU02:FS00:0x16:Entering M.D.
06:14:58:WU02:FS00:0x16:Tpr hash 02/wudata_01.tpr:  1223698356 3201219571 3814432622 2302101008 1805354753
06:14:58:WU02:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
06:14:58:WU02:FS00:0x16:Client config unavailable.
06:14:58:WU02:FS00:0x16:Starting GUI Server
06:14:58:WU02:FS00:0x16:Run: exception thrown in GuardedRun -- cannot continue further.
06:14:58:WU02:FS00:0x16:Going to send back what have done -- stepsTotalG=0
06:14:58:WU02:FS00:0x16:Work fraction=0.0000 steps=0.
06:15:02:WU02:FS00:0x16:logfile size=0 infoLength=0 edr=0 trr=23
06:15:02:WU02:FS00:0x16:+ Opened results file
06:15:02:WU02:FS00:0x16:- Writing 633 bytes of core data to disk...
06:15:02:WU02:FS00:0x16:Done: 121 -> 123 (compressed to 101.6 percent)
06:15:02:WU02:FS00:0x16:  ... Done.
06:15:02:WU02:FS00:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
06:15:02:WU02:FS00:0x16:Folding@home Core Shutdown: UNSTABLE_MACHINE
06:15:02:WARNING:WU02:FS00:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
06:15:02:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:11293 run:10 clone:83 gen:42 core:0x16 unit:0x0000093d6652edbc4d9257c2b9a10c1c
06:15:02:WU02:FS00:Uploading 635B to 171.67.108.44
06:15:02:WU02:FS00:Connecting to 171.67.108.44:8080
06:15:03:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
06:15:03:WU02:FS00:Upload complete
06:15:03:WU02:FS00:Server responded WORK_ACK (400)
06:15:03:WU02:FS00:Cleaning up
06:15:03:WU00:FS00:News: Welcome to Folding@Home
06:15:03:WU00:FS00:Assigned to work server 171.67.108.44
06:15:03:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Redwood [Radeon HD 5600 Series] from 171.67.108.44
06:15:03:WU00:FS00:Connecting to 171.67.108.44:8080
06:15:05:WU00:FS00:Downloading 44.35KiB
06:15:05:WU00:FS00:Download complete
06:15:05:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11292 run:7 clone:91 gen:22 core:0x16 unit:0x000000d86652edbc4d096db670337c7e
06:15:05:WU00:FS00:Starting
06:15:05:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bart/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 703 -lifeline 1404 -checkpoint 10 -gpu 0 -gpu-vendor ati
06:15:05:WU00:FS00:Started FahCore on PID 5160
06:15:05:WU00:FS00:Core PID:1532
06:15:05:WU00:FS00:FahCore 0x16 started
06:15:05:WU00:FS00:0x16:
06:15:05:WU00:FS00:0x16:*------------------------------*
06:15:05:WU00:FS00:0x16:Folding@Home GPU Core
06:15:05:WU00:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
06:15:05:WU00:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
06:15:05:WU00:FS00:0x16:Build host: user-f6d030f24f
06:15:05:WU00:FS00:0x16:Board Type: AMD/OpenCL
06:15:05:WU00:FS00:0x16:Core      : x=16
06:15:05:WU00:FS00:0x16: Window's signal control handler registered.
06:15:05:WU00:FS00:0x16:Preparing to commence simulation
06:15:05:WU00:FS00:0x16:- Looking at optimizations...
06:15:05:WU00:FS00:0x16:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
06:15:05:WU00:FS00:0x16:- Created dyn
06:15:05:WU00:FS00:0x16:- Files status OK
06:15:05:WU00:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
06:15:05:WU00:FS00:0x16:- Expanded 44898 -> 171163 (decompressed 381.2 percent)
06:15:05:WU00:FS00:0x16:Called DecompressByteArray: compressed_data_size=44898 data_size=171163, decompressed_data_size=171163 diff=0
06:15:05:WU00:FS00:0x16:- Digital signature verified
06:15:05:WU00:FS00:0x16:Project: 11292 (Run 7, Clone 91, Gen 22)
06:15:05:WU00:FS00:0x16:Assembly optimizations on if available.
06:15:05:WU00:FS00:0x16:Entering M.D.
06:15:07:WU00:FS00:0x16:Tpr hash 00/wudata_01.tpr:  4117071347 2812714599 2579057301 532499511 761724676
06:15:07:WU00:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
06:15:07:WU00:FS00:0x16:Client config unavailable.
06:15:07:WU00:FS00:0x16:Run: exception thrown in GuardedRun -- cannot continue further.
06:15:07:WU00:FS00:0x16:Going to send back what have done -- stepsTotalG=0
06:15:07:WU00:FS00:0x16:Work fraction=0.0000 steps=0.
06:15:07:WU00:FS00:0x16:Starting GUI Server
06:15:11:WU00:FS00:0x16:logfile size=0 infoLength=0 edr=0 trr=23
06:15:11:WU00:FS00:0x16:+ Opened results file
06:15:11:WU00:FS00:0x16:- Writing 633 bytes of core data to disk...
06:15:11:WU00:FS00:0x16:Done: 121 -> 121 (compressed to 100.0 percent)
06:15:11:WU00:FS00:0x16:  ... Done.
06:15:11:WU00:FS00:0x16:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
06:15:11:WU00:FS00:0x16:Folding@home Core Shutdown: UNSTABLE_MACHINE
06:15:12:WARNING:WU00:FS00:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
06:15:12:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:11292 run:7 clone:91 gen:22 core:0x16 unit:0x000000d86652edbc4d096db670337c7e
06:15:12:WU00:FS00:Uploading 633B to 171.67.108.44
06:15:12:WU00:FS00:Connecting to 171.67.108.44:8080
06:15:12:WU00:FS00:Upload complete
06:15:12:WU00:FS00:Server responded WORK_ACK (400)
06:15:12:WU00:FS00:Cleaning up
06:15:54:Removing old file 'configs/config-20130324-210718.xml'
06:15:54:Saving configuration to config.xml
06:15:54:<config>
06:15:54:  <!-- Folding Core -->
06:15:54:  <checkpoint v='10'/>
06:15:54:  <cpu-usage v='83'/>
06:15:54:
06:15:54:  <!-- Folding Slot Configuration -->
06:15:54:  <power v='full'/>
06:15:54:
06:15:54:  <!-- Network -->
06:15:54:  <proxy v=':8080'/>
06:15:54:
06:15:54:  <!-- Slot Control -->
06:15:54:  <pause-on-battery v='false'/>
06:15:54:
06:15:54:  <!-- User Information -->
06:15:54:  <passkey v='********************************'/>
06:15:54:  <team v='223518'/>
06:15:54:  <user v='CookieB'/>
06:15:54:
06:15:54:  <!-- Folding Slots -->
06:15:54:  <slot id='1' type='CPU'/>
06:15:54:  <slot id='0' type='GPU'/>
06:15:54:</config>
06:15:54:FS01:Shutting core down
06:16:02:WU01:FS01:0xa4:Client no longer detected. Shutting down core
06:16:02:WU01:FS01:0xa4:Folding@home Core Shutdown: CLIENT_DIED
06:16:03:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
06:16:03:WU01:FS01:Starting
06:16:03:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bart/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 703 -lifeline 1404 -checkpoint 10 -cpu 83 -np 3
06:16:03:WU01:FS01:Started FahCore on PID 6356
06:16:03:WU01:FS01:Core PID:4100
06:16:03:WU01:FS01:FahCore 0xa4 started
06:16:03:WU01:FS01:0xa4:
06:16:03:WU01:FS01:0xa4:*------------------------------*
06:16:03:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
06:16:03:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
06:16:03:WU01:FS01:0xa4:Preparing to commence simulation
06:16:03:WU01:FS01:0xa4:- Looking at optimizations...
06:16:03:WU01:FS01:0xa4:- Files status OK
06:16:03:WU01:FS01:0xa4:- Expanded 2054063 -> 5365960 (decompressed 261.2 percent)
06:16:03:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2054063 data_size=5365960, decompressed_data_size=5365960 diff=0
06:16:04:WU01:FS01:0xa4:- Digital signature verified
06:16:04:WU01:FS01:0xa4:Project: 7808 (Run 2, Clone 338, Gen 37)
06:16:04:WU01:FS01:0xa4:Assembly optimizations on if available.
06:16:04:WU01:FS01:0xa4:Entering M.D.
06:16:10:WU01:FS01:0xa4:Using Gromacs checkpoints
06:16:10:WU01:FS01:0xa4:Mapping NT from 3 to 3
06:16:10:WU01:FS01:0xa4:Resuming from checkpoint
06:16:10:WU01:FS01:0xa4:Verified 01/wudata_01.log
06:16:11:WU01:FS01:0xa4:Verified 01/wudata_01.trr
06:16:11:WU01:FS01:0xa4:Verified 01/wudata_01.xtc
06:16:11:WU01:FS01:0xa4:Verified 01/wudata_01.edr
06:16:11:WU01:FS01:0xa4:Completed 555770 out of 1500000 steps  (37%)
06:16:40:Removing old file 'configs/config-20130324-211327.xml'
06:16:40:Saving configuration to config.xml
06:16:40:<config>
06:16:40:  <!-- Folding Core -->
06:16:40:  <checkpoint v='10'/>
06:16:40:  <cpu-usage v='83'/>
06:16:40:
06:16:40:  <!-- Folding Slot Configuration -->
06:16:40:  <power v='full'/>
06:16:40:
06:16:40:  <!-- Network -->
06:16:40:  <proxy v=':8080'/>
06:16:40:
06:16:40:  <!-- Slot Control -->
06:16:40:  <pause-on-battery v='false'/>
06:16:40:
06:16:40:  <!-- User Information -->
06:16:40:  <passkey v='********************************'/>
06:16:40:  <team v='223518'/>
06:16:40:  <user v='CookieB'/>
06:16:40:
06:16:40:  <!-- Folding Slots -->
06:16:40:  <slot id='1' type='CPU'/>
06:16:40:</config>
06:16:40:FS01:Shutting core down
06:16:44:WU01:FS01:0xa4:Client no longer detected. Shutting down core
06:16:44:WU01:FS01:0xa4:Folding@home Core Shutdown: CLIENT_DIED
06:16:44:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
06:17:02:Removing old file 'configs/config-20130325-163945.xml'
06:17:02:Saving configuration to config.xml
06:17:02:<config>
06:17:02:  <!-- Folding Core -->
06:17:02:  <checkpoint v='10'/>
06:17:02:  <cpu-usage v='88'/>
06:17:02:
06:17:02:  <!-- Folding Slot Configuration -->
06:17:02:  <power v='full'/>
06:17:02:
06:17:02:  <!-- Network -->
06:17:02:  <proxy v=':8080'/>
06:17:02:
06:17:02:  <!-- Slot Control -->
06:17:02:  <pause-on-battery v='false'/>
06:17:02:
06:17:02:  <!-- User Information -->
06:17:02:  <passkey v='********************************'/>
06:17:02:  <team v='223518'/>
06:17:02:  <user v='CookieB'/>
06:17:02:
06:17:02:  <!-- Folding Slots -->
06:17:02:  <slot id='1' type='CPU'/>
06:17:02:</config>
06:17:03:WU01:FS01:Starting
06:17:03:WARNING:WU01:FS01:Changed SMP threads from 3 to 4 this can cause some work units to fail
06:17:03:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bart/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 703 -lifeline 1404 -checkpoint 10 -cpu 88 -np 4
06:17:03:WU01:FS01:Started FahCore on PID 6980
06:17:03:WU01:FS01:Core PID:3688
06:17:03:WU01:FS01:FahCore 0xa4 started
06:17:04:WU01:FS01:0xa4:
06:17:04:WU01:FS01:0xa4:*------------------------------*
06:17:04:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
06:17:04:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
06:17:04:WU01:FS01:0xa4:Preparing to commence simulation
06:17:04:WU01:FS01:0xa4:- Looking at optimizations...
06:17:04:WU01:FS01:0xa4:- Files status OK
06:17:04:WU01:FS01:0xa4:- Expanded 2054063 -> 5365960 (decompressed 261.2 percent)
06:17:04:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2054063 data_size=5365960, decompressed_data_size=5365960 diff=0
06:17:04:WU01:FS01:0xa4:- Digital signature verified
06:17:04:WU01:FS01:0xa4:Project: 7808 (Run 2, Clone 338, Gen 37)
06:17:04:WU01:FS01:0xa4:Assembly optimizations on if available.
06:17:04:WU01:FS01:0xa4:Entering M.D.
06:17:10:WU01:FS01:0xa4:Using Gromacs checkpoints
06:17:10:WU01:FS01:0xa4:Mapping NT from 4 to 4
06:17:10:WU01:FS01:0xa4:Resuming from checkpoint
06:17:10:WU01:FS01:0xa4:Verified 01/wudata_01.log
06:17:10:WU01:FS01:0xa4:Verified 01/wudata_01.trr
06:17:10:WU01:FS01:0xa4:Verified 01/wudata_01.xtc
06:17:10:WU01:FS01:0xa4:Verified 01/wudata_01.edr
06:17:11:WU01:FS01:0xa4:Completed 555770 out of 1500000 steps  (37%)
06:17:18:Adding folding slot 00: READY gpu:0:Redwood [Radeon HD 5600 Series]
06:17:18:Removing old file 'configs/config-20130325-172521.xml'
06:17:18:Saving configuration to config.xml
06:17:18:<config>
06:17:18:  <!-- Folding Core -->
06:17:18:  <checkpoint v='10'/>
06:17:18:  <cpu-usage v='88'/>
06:17:18:
06:17:18:  <!-- Folding Slot Configuration -->
06:17:18:  <power v='full'/>
06:17:18:
06:17:18:  <!-- Network -->
06:17:18:  <proxy v=':8080'/>
06:17:18:
06:17:18:  <!-- Slot Control -->
06:17:18:  <pause-on-battery v='false'/>
06:17:18:
06:17:18:  <!-- User Information -->
06:17:18:  <passkey v='********************************'/>
06:17:18:  <team v='223518'/>
06:17:18:  <user v='CookieB'/>
06:17:18:
06:17:18:  <!-- Folding Slots -->
06:17:18:  <slot id='1' type='CPU'/>
06:17:18:  <slot id='0' type='GPU'/>
06:17:18:</config>
06:17:18:FS01:Shutting core down
06:17:18:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
06:17:18:WU00:FS00:News: Welcome to Folding@Home
06:17:18:WU00:FS00:Assigned to work server 171.67.108.44
06:17:18:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Redwood [Radeon HD 5600 Series] from 171.67.108.44
06:17:18:WU00:FS00:Connecting to 171.67.108.44:8080
06:17:20:WU00:FS00:Downloading 44.56KiB
06:17:20:WU00:FS00:Download complete
06:17:20:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11292 run:3 clone:46 gen:16 core:0x16 unit:0x000000e36652edbc4d07b97208643cd9
06:17:20:WU00:FS00:Starting
06:17:20:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bart/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 703 -lifeline 1404 -checkpoint 10 -gpu 0 -gpu-vendor ati
06:17:20:WU00:FS00:Started FahCore on PID 6112
06:17:20:WU00:FS00:Core PID:4552
06:17:20:WU00:FS00:FahCore 0x16 started
06:17:20:WU01:FS01:0xa4:Client no longer detected. Shutting down core
06:17:20:WU01:FS01:0xa4:Folding@home Core Shutdown: CLIENT_DIED
06:17:20:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
06:17:20:WU00:FS00:0x16:
06:17:20:WU00:FS00:0x16:*------------------------------*
06:17:20:WU00:FS00:0x16:Folding@Home GPU Core
06:17:20:WU00:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
06:17:20:WU00:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
06:17:20:WU00:FS00:0x16:Build host: user-f6d030f24f
06:17:20:WU00:FS00:0x16:Board Type: AMD/OpenCL
06:17:20:WU00:FS00:0x16:Core      : x=16
06:17:20:WU00:FS00:0x16: Window's signal control handler registered.
06:17:20:WU00:FS00:0x16:Preparing to commence simulation
06:17:20:WU00:FS00:0x16:- Looking at optimizations...
06:17:20:WU00:FS00:0x16:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
06:17:20:WU00:FS00:0x16:- Created dyn
06:17:20:WU00:FS00:0x16:- Files status OK
06:17:20:WU00:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
06:17:20:WU00:FS00:0x16:- Expanded 45115 -> 171163 (decompressed 379.3 percent)
06:17:20:WU00:FS00:0x16:Called DecompressByteArray: compressed_data_size=45115 data_size=171163, decompressed_data_size=171163 diff=0
06:17:20:WU00:FS00:0x16:- Digital signature verified
06:17:20:WU00:FS00:0x16:Project: 11292 (Run 3, Clone 46, Gen 16)
06:17:20:WU00:FS00:0x16:Assembly optimizations on if available.
06:17:20:WU00:FS00:0x16:Entering M.D.
06:17:22:WU00:FS00:0x16:Tpr hash 00/wudata_01.tpr:  1156051965 1488124657 3834244073 4252119976 1719766795
06:17:22:WU00:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
06:17:22:WU00:FS00:0x16:Client config unavailable.
06:17:22:WU00:FS00:0x16:Run: exception thrown in GuardedRun -- cannot continue further.
06:17:22:WU00:FS00:0x16:Going to send back what have done -- stepsTotalG=0
06:17:22:WU00:FS00:0x16:Work fraction=0.0000 steps=0.
06:17:22:WU00:FS00:0x16:Starting GUI Server
06:17:26:WU00:FS00:0x16:logfile size=0 infoLength=0 edr=0 trr=23
06:17:26:WU00:FS00:0x16:+ Opened results file
06:17:26:WU00:FS00:0x16:- Writing 633 bytes of core data to disk...
06:17:26:WU00:FS00:0x16:Done: 121 -> 121 (compressed to 100.0 percent)
06:17:26:WU00:FS00:0x16:  ... Done.
06:17:26:WU00:FS00:0x16:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
06:17:26:WU00:FS00:0x16:Folding@home Core Shutdown: UNSTABLE_MACHINE
06:17:27:WARNING:WU00:FS00:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
06:17:27:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:11292 run:3 clone:46 gen:16 core:0x16 unit:0x000000e36652edbc4d07b97208643cd9
06:17:27:WU00:FS00:Uploading 633B to 171.67.108.44
06:17:27:WU00:FS00:Connecting to 171.67.108.44:8080
06:17:27:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
06:17:27:WU00:FS00:Upload complete
06:17:27:WU00:FS00:Server responded WORK_ACK (400)
06:17:27:WU00:FS00:Cleaning up
06:17:27:WU02:FS00:News: Welcome to Folding@Home
06:17:27:WU02:FS00:Assigned to work server 171.67.108.44
06:17:27:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:Redwood [Radeon HD 5600 Series] from 171.67.108.44
06:17:27:WU02:FS00:Connecting to 171.67.108.44:8080
06:17:29:WU02:FS00:Downloading 44.62KiB
06:17:29:WU02:FS00:Download complete
06:17:29:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11293 run:31 clone:35 gen:42 core:0x16 unit:0x00000c516652edbc4d94bb43836eb574
06:17:29:WU02:FS00:Starting
06:17:29:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bart/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 703 -lifeline 1404 -checkpoint 10 -gpu 0 -gpu-vendor ati
06:17:29:WU02:FS00:Started FahCore on PID 5072
06:17:29:WU02:FS00:Core PID:4672
06:17:29:WU02:FS00:FahCore 0x16 started
06:17:30:WU02:FS00:0x16:
06:17:30:WU02:FS00:0x16:*------------------------------*
06:17:30:WU02:FS00:0x16:Folding@Home GPU Core
06:17:30:WU02:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
06:17:30:WU02:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
06:17:30:WU02:FS00:0x16:Build host: user-f6d030f24f
06:17:30:WU02:FS00:0x16:Board Type: AMD/OpenCL
06:17:30:WU02:FS00:0x16:Core      : x=16
06:17:30:WU02:FS00:0x16: Window's signal control handler registered.
06:17:30:WU02:FS00:0x16:Preparing to commence simulation
06:17:30:WU02:FS00:0x16:- Looking at optimizations...
06:17:30:WU02:FS00:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
06:17:30:WU02:FS00:0x16:- Created dyn
06:17:30:WU02:FS00:0x16:- Files status OK
06:17:30:WU02:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
06:17:30:WU02:FS00:0x16:- Expanded 45179 -> 171163 (decompressed 378.8 percent)
06:17:30:WU02:FS00:0x16:Called DecompressByteArray: compressed_data_size=45179 data_size=171163, decompressed_data_size=171163 diff=0
06:17:30:WU02:FS00:0x16:- Digital signature verified
06:17:30:WU02:FS00:0x16:Project: 11293 (Run 31, Clone 35, Gen 42)
06:17:30:WU02:FS00:0x16:Assembly optimizations on if available.
06:17:30:WU02:FS00:0x16:Entering M.D.
06:17:31:WU02:FS00:0x16:Tpr hash 02/wudata_01.tpr:  1732039199 560308400 743517982 407224830 3350051227
06:17:32:WU02:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
06:17:32:WU02:FS00:0x16:Client config unavailable.
06:17:32:WU02:FS00:0x16:Run: exception thrown in GuardedRun -- cannot continue further.
06:17:32:WU02:FS00:0x16:Going to send back what have done -- stepsTotalG=0
06:17:32:WU02:FS00:0x16:Work fraction=0.0000 steps=0.
06:17:32:WU02:FS00:0x16:Starting GUI Server
06:17:35:WU02:FS00:0x16:logfile size=0 infoLength=0 edr=0 trr=23
06:17:35:WU02:FS00:0x16:+ Opened results file
06:17:35:WU02:FS00:0x16:- Writing 633 bytes of core data to disk...
06:17:35:WU02:FS00:0x16:Done: 121 -> 123 (compressed to 101.6 percent)
06:17:35:WU02:FS00:0x16:  ... Done.
06:17:35:WU02:FS00:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
06:17:35:WU02:FS00:0x16:Folding@home Core Shutdown: UNSTABLE_MACHINE
06:17:36:WARNING:WU02:FS00:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
06:17:36:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:11293 run:31 clone:35 gen:42 core:0x16 unit:0x00000c516652edbc4d94bb43836eb574
06:17:36:WU02:FS00:Uploading 635B to 171.67.108.44
06:17:36:WU02:FS00:Connecting to 171.67.108.44:8080
06:17:36:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
06:17:36:WU02:FS00:Upload complete
06:17:36:WU02:FS00:Server responded WORK_ACK (400)
06:17:36:WU02:FS00:Cleaning up
06:17:37:WU00:FS00:News: Welcome to Folding@Home
06:17:37:WU00:FS00:Assigned to work server 171.67.108.44
06:17:37:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Redwood [Radeon HD 5600 Series] from 171.67.108.44
06:17:37:WU00:FS00:Connecting to 171.67.108.44:8080
06:17:38:WU00:FS00:Downloading 44.41KiB
06:17:38:WU00:FS00:Download complete
06:17:38:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11292 run:6 clone:97 gen:22 core:0x16 unit:0x000000ea6652edbc4d096db2390d02fc
06:17:38:WU00:FS00:Starting
06:17:38:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bart/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 703 -lifeline 1404 -checkpoint 10 -gpu 0 -gpu-vendor ati
06:17:38:WU00:FS00:Started FahCore on PID 3220
06:17:39:WU00:FS00:Core PID:6656
06:17:39:WU00:FS00:FahCore 0x16 started
06:17:39:WU00:FS00:0x16:
06:17:39:WU00:FS00:0x16:*------------------------------*
06:17:39:WU00:FS00:0x16:Folding@Home GPU Core
06:17:39:WU00:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
06:17:39:WU00:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
06:17:39:WU00:FS00:0x16:Build host: user-f6d030f24f
06:17:39:WU00:FS00:0x16:Board Type: AMD/OpenCL
06:17:39:WU00:FS00:0x16:Core      : x=16
06:17:39:WU00:FS00:0x16: Window's signal control handler registered.
06:17:39:WU00:FS00:0x16:Preparing to commence simulation
06:17:39:WU00:FS00:0x16:- Looking at optimizations...
06:17:39:WU00:FS00:0x16:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
06:17:39:WU00:FS00:0x16:- Created dyn
06:17:39:WU00:FS00:0x16:- Files status OK
06:17:39:WU00:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
06:17:39:WU00:FS00:0x16:- Expanded 44967 -> 171163 (decompressed 380.6 percent)
06:17:39:WU00:FS00:0x16:Called DecompressByteArray: compressed_data_size=44967 data_size=171163, decompressed_data_size=171163 diff=0
06:17:39:WU00:FS00:0x16:- Digital signature verified
06:17:39:WU00:FS00:0x16:Project: 11292 (Run 6, Clone 97, Gen 22)
06:17:39:WU00:FS00:0x16:Assembly optimizations on if available.
06:17:39:WU00:FS00:0x16:Entering M.D.
06:17:41:WU00:FS00:0x16:Tpr hash 00/wudata_01.tpr:  1775584446 698335560 4276414556 383982628 1691360589
06:17:41:WU00:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
06:17:41:WU00:FS00:0x16:Client config unavailable.
06:17:41:WU00:FS00:0x16:Run: exception thrown in GuardedRun -- cannot continue further.
06:17:41:WU00:FS00:0x16:Going to send back what have done -- stepsTotalG=0
06:17:41:WU00:FS00:0x16:Work fraction=0.0000 steps=0.
06:17:41:WU00:FS00:0x16:Starting GUI Server
06:17:45:WU00:FS00:0x16:logfile size=0 infoLength=0 edr=0 trr=23
06:17:45:WU00:FS00:0x16:+ Opened results file
06:17:45:WU00:FS00:0x16:- Writing 633 bytes of core data to disk...
06:17:45:WU00:FS00:0x16:Done: 121 -> 121 (compressed to 100.0 percent)
06:17:45:WU00:FS00:0x16:  ... Done.
06:17:45:WU00:FS00:0x16:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
06:17:45:WU00:FS00:0x16:Folding@home Core Shutdown: UNSTABLE_MACHINE
06:17:45:WARNING:WU00:FS00:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
06:17:45:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:11292 run:6 clone:97 gen:22 core:0x16 unit:0x000000ea6652edbc4d096db2390d02fc
06:17:45:WU00:FS00:Uploading 633B to 171.67.108.44
06:17:45:WU00:FS00:Connecting to 171.67.108.44:8080
06:17:45:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
06:17:46:WU00:FS00:Upload complete
06:17:46:WU00:FS00:Server responded WORK_ACK (400)
06:17:46:WU00:FS00:Cleaning up
06:17:46:WU02:FS00:News: Welcome to Folding@Home
06:17:46:WU02:FS00:Assigned to work server 171.67.108.44
06:17:46:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:Redwood [Radeon HD 5600 Series] from 171.67.108.44
06:17:46:WU02:FS00:Connecting to 171.67.108.44:8080
06:17:47:WU02:FS00:Downloading 44.54KiB
06:17:48:WU02:FS00:Download complete
06:17:48:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11292 run:6 clone:6 gen:15 core:0x16 unit:0x000001376652edbc4caa47c10000003d
06:17:48:WU02:FS00:Starting
06:17:48:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bart/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 703 -lifeline 1404 -checkpoint 10 -gpu 0 -gpu-vendor ati
06:17:48:WU02:FS00:Started FahCore on PID 4272
06:17:48:WU02:FS00:Core PID:2152
06:17:48:WU02:FS00:FahCore 0x16 started
06:17:48:WU02:FS00:0x16:
06:17:48:WU02:FS00:0x16:*------------------------------*
06:17:48:WU02:FS00:0x16:Folding@Home GPU Core
06:17:48:WU02:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
06:17:48:WU02:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
06:17:48:WU02:FS00:0x16:Build host: user-f6d030f24f
06:17:48:WU02:FS00:0x16:Board Type: AMD/OpenCL
06:17:48:WU02:FS00:0x16:Core      : x=16
06:17:48:WU02:FS00:0x16: Window's signal control handler registered.
06:17:48:WU02:FS00:0x16:Preparing to commence simulation
06:17:48:WU02:FS00:0x16:- Looking at optimizations...
06:17:48:WU02:FS00:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
06:17:48:WU02:FS00:0x16:- Created dyn
06:17:48:WU02:FS00:0x16:- Files status OK
06:17:48:WU02:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
06:17:48:WU02:FS00:0x16:- Expanded 45100 -> 171163 (decompressed 379.5 percent)
06:17:48:WU02:FS00:0x16:Called DecompressByteArray: compressed_data_size=45100 data_size=171163, decompressed_data_size=171163 diff=0
06:17:48:WU02:FS00:0x16:- Digital signature verified
06:17:48:WU02:FS00:0x16:Project: 11292 (Run 6, Clone 6, Gen 15)
06:17:48:WU02:FS00:0x16:Assembly optimizations on if available.
06:17:48:WU02:FS00:0x16:Entering M.D.
06:17:50:WU02:FS00:0x16:Tpr hash 02/wudata_01.tpr:  2497209991 2234987838 2623465496 2884680103 4089697708
06:17:50:WU02:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
06:17:50:WU02:FS00:0x16:Client config unavailable.
06:17:50:WU02:FS00:0x16:Run: exception thrown in GuardedRun -- cannot continue further.
06:17:50:WU02:FS00:0x16:Going to send back what have done -- stepsTotalG=0
06:17:50:WU02:FS00:0x16:Work fraction=0.0000 steps=0.
06:17:50:WU02:FS00:0x16:Starting GUI Server
06:17:54:WU02:FS00:0x16:logfile size=0 infoLength=0 edr=0 trr=23
06:17:54:WU02:FS00:0x16:+ Opened results file
06:17:54:WU02:FS00:0x16:- Writing 633 bytes of core data to disk...
06:17:54:WU02:FS00:0x16:Done: 121 -> 123 (compressed to 101.6 percent)
06:17:54:WU02:FS00:0x16:  ... Done.
06:17:54:WU02:FS00:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
06:17:54:WU02:FS00:0x16:Folding@home Core Shutdown: UNSTABLE_MACHINE
06:17:54:WARNING:WU02:FS00:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
06:17:54:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:11292 run:6 clone:6 gen:15 core:0x16 unit:0x000001376652edbc4caa47c10000003d
06:17:54:WU02:FS00:Uploading 635B to 171.67.108.44
06:17:54:WU02:FS00:Connecting to 171.67.108.44:8080
06:17:55:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
06:17:55:WU02:FS00:Upload complete
06:17:55:WU02:FS00:Server responded WORK_ACK (400)
06:17:55:WU02:FS00:Cleaning up
06:17:55:WU00:FS00:News: Welcome to Folding@Home
06:17:55:WU00:FS00:Assigned to work server 171.67.108.44
06:17:55:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Redwood [Radeon HD 5600 Series] from 171.67.108.44
06:17:55:WU00:FS00:Connecting to 171.67.108.44:8080
06:17:57:WU00:FS00:Downloading 44.59KiB
06:17:57:WU00:FS00:Download complete
06:17:57:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11293 run:3 clone:135 gen:42 core:0x16 unit:0x0000074e6652edbc4d9256564260bd65
06:17:57:WU00:FS00:Starting
06:17:57:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bart/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 703 -lifeline 1404 -checkpoint 10 -gpu 0 -gpu-vendor ati
06:17:57:WU00:FS00:Started FahCore on PID 5808
06:17:57:WU00:FS00:Core PID:5564
06:17:57:WU00:FS00:FahCore 0x16 started
06:17:58:WU00:FS00:0x16:
06:17:58:WU00:FS00:0x16:*------------------------------*
06:17:58:WU00:FS00:0x16:Folding@Home GPU Core
06:17:58:WU00:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
06:17:58:WU00:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
06:17:58:WU00:FS00:0x16:Build host: user-f6d030f24f
06:17:58:WU00:FS00:0x16:Board Type: AMD/OpenCL
06:17:58:WU00:FS00:0x16:Core      : x=16
06:17:58:WU00:FS00:0x16: Window's signal control handler registered.
06:17:58:WU00:FS00:0x16:Preparing to commence simulation
06:17:58:WU00:FS00:0x16:- Looking at optimizations...
06:17:58:WU00:FS00:0x16:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
06:17:58:WU00:FS00:0x16:- Created dyn
06:17:58:WU00:FS00:0x16:- Files status OK
06:17:58:WU00:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
06:17:58:WU00:FS00:0x16:- Expanded 45147 -> 171163 (decompressed 379.1 percent)
06:17:58:WU00:FS00:0x16:Called DecompressByteArray: compressed_data_size=45147 data_size=171163, decompressed_data_size=171163 diff=0
06:17:58:WU00:FS00:0x16:- Digital signature verified
06:17:58:WU00:FS00:0x16:Project: 11293 (Run 3, Clone 135, Gen 42)
06:17:58:WU00:FS00:0x16:Assembly optimizations on if available.
06:17:58:WU00:FS00:0x16:Entering M.D.
06:17:59:WU00:FS00:0x16:Tpr hash 00/wudata_01.tpr:  56839161 2646466426 1824319409 1367957297 3858347196
06:17:59:WU00:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
06:17:59:WU00:FS00:0x16:Client config unavailable.
06:17:59:WU00:FS00:0x16:Run: exception thrown in GuardedRun -- cannot continue further.
06:17:59:WU00:FS00:0x16:Going to send back what have done -- stepsTotalG=0
06:17:59:WU00:FS00:0x16:Work fraction=0.0000 steps=0.
06:17:59:WU00:FS00:0x16:Starting GUI Server
06:18:03:WU01:FS01:Starting
06:18:03:WARNING:WU01:FS01:Changed SMP threads from 4 to 3 this can cause some work units to fail
06:18:03:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bart/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 703 -lifeline 1404 -checkpoint 10 -cpu 88 -np 3
06:18:03:WU01:FS01:Started FahCore on PID 2540
06:18:03:WU01:FS01:Core PID:4992
06:18:03:WU01:FS01:FahCore 0xa4 started
06:18:03:WU00:FS00:0x16:logfile size=0 infoLength=0 edr=0 trr=23
06:18:03:WU00:FS00:0x16:+ Opened results file
06:18:03:WU00:FS00:0x16:- Writing 633 bytes of core data to disk...
06:18:03:WU00:FS00:0x16:Done: 121 -> 121 (compressed to 100.0 percent)
06:18:03:WU00:FS00:0x16:  ... Done.
06:18:03:WU00:FS00:0x16:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
06:18:03:WU00:FS00:0x16:Folding@home Core Shutdown: UNSTABLE_MACHINE
06:18:04:WU01:FS01:0xa4:
06:18:04:WU01:FS01:0xa4:*------------------------------*
06:18:04:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
06:18:04:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
06:18:04:WU01:FS01:0xa4:Preparing to commence simulation
06:18:04:WU01:FS01:0xa4:- Looking at optimizations...
06:18:04:WU01:FS01:0xa4:- Files status OK
06:18:04:WARNING:WU00:FS00:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
06:18:04:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:11293 run:3 clone:135 gen:42 core:0x16 unit:0x0000074e6652edbc4d9256564260bd65
06:18:04:WU00:FS00:Uploading 633B to 171.67.108.44
06:18:04:WU00:FS00:Connecting to 171.67.108.44:8080
06:18:04:WU01:FS01:0xa4:- Expanded 2054063 -> 5365960 (decompressed 261.2 percent)
06:18:04:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2054063 data_size=5365960, decompressed_data_size=5365960 diff=0
06:18:04:WU01:FS01:0xa4:- Digital signature verified
06:18:04:WU01:FS01:0xa4:Project: 7808 (Run 2, Clone 338, Gen 37)
06:18:04:WU01:FS01:0xa4:Assembly optimizations on if available.
06:18:04:WU01:FS01:0xa4:Entering M.D.
06:18:04:WU00:FS00:Upload complete
06:18:05:WU00:FS00:Server responded WORK_ACK (400)
06:18:05:WU00:FS00:Cleaning up
06:18:10:WU01:FS01:0xa4:Using Gromacs checkpoints
06:18:10:WU01:FS01:0xa4:Mapping NT from 3 to 3
06:18:11:WU01:FS01:0xa4:Resuming from checkpoint
06:18:11:WU01:FS01:0xa4:Verified 01/wudata_01.log
06:18:11:WU01:FS01:0xa4:Verified 01/wudata_01.trr
06:18:11:WU01:FS01:0xa4:Verified 01/wudata_01.xtc
06:18:11:WU01:FS01:0xa4:Verified 01/wudata_01.edr
06:18:11:WU01:FS01:0xa4:Completed 555770 out of 1500000 steps  (37%)
06:55:14:WU01:FS01:0xa4:Completed 570000 out of 1500000 steps  (38%)
07:34:12:WU01:FS01:0xa4:Completed 585000 out of 1500000 steps  (39%)
08:16:50:WU01:FS01:0xa4:Completed 600000 out of 1500000 steps  (40%)
08:59:27:WU01:FS01:0xa4:Completed 615000 out of 1500000 steps  (41%)
09:42:04:WU01:FS01:0xa4:Completed 630000 out of 1500000 steps  (42%)
10:24:43:WU01:FS01:0xa4:Completed 645000 out of 1500000 steps  (43%)
11:07:19:WU01:FS01:0xa4:Completed 660000 out of 1500000 steps  (44%)
11:49:55:WU01:FS01:0xa4:Completed 675000 out of 1500000 steps  (45%)
******************************* Date: 2013-03-27 *******************************
12:28:50:WU01:FS01:0xa4:Completed 690000 out of 1500000 steps  (46%)
13:11:28:WU01:FS01:0xa4:Completed 705000 out of 1500000 steps  (47%)
13:54:08:WU01:FS01:0xa4:Completed 720000 out of 1500000 steps  (48%)
14:37:06:WU01:FS01:0xa4:Completed 735000 out of 1500000 steps  (49%)
15:19:42:WU01:FS01:0xa4:Completed 750000 out of 1500000 steps  (50%)
16:02:19:WU01:FS01:0xa4:Completed 765000 out of 1500000 steps  (51%)
16:44:02:WU01:FS01:0xa4:Completed 780000 out of 1500000 steps  (52%)
It seems likely that y you have not updated your GPU drivers.
http://support.amd.com/us/gpudownload/Pages/index.aspx
CookieB
Post by CookieB »
Like I've already told in my first post, I get a message of the installer I have to use the drivers provided by my notebook manufacturer.
Is there a newer version of the drivers available from HP? You also need the AMD-ATI SDK installed for OpenCL support. But if the drivers from HP correspond to a version that is too old of the standard ATI driver, you may not be successful in getting your laptop to fold on the GPU.
