What is this error?
kwk1
What is this error?
Post by kwk1 »
I have this error where it shows the protein information.
03:48:53:ERROR:Exception: Failed to rename 'log.txt' to 'logs/log-20130311-03485
3.txt': The process cannot access the file because it is being used by another p
rocess.
C:\Users\Ken\AppData\Roaming\FAHClient>
I also have this when I open the FAH Client.
The last thing, I used to get 15000-18000 points a day.
Now, I'm barely making 6000 per day.
My version is 7.1.52
I'm not very computer savy, just so you know.
Thanks for any help.
P5-133XL
Machine #2:
Machine 3:
Re: What is this error?
Post by P5-133XL »
When the folding client is restarted it will sometimes rename the log; move it to the log folder; and start a new log. If the old log is being accessed by another application then that process will fail and give that error. Did you perhaps have an editor open that was displaying the log when the client was restarted?
There are several causes of low PPD. You did not supply anywhere close to enough information to be able to diagnose the problem. My first guess would be the video card has dropped to a very low clock rate because p7625 project tends to run hotter than the normal GPU folding project and thus can over-stress a GPU causing a VRM reset that historically hasn't failed. There are other possibilities though.
kwk1
Post by kwk1 »
Hi, I don't know how to move it to the log folder. I quit folding, opened the client and restarted fah control and the client seems okay.
What info do you need to diagnose a problem?
I just know my cpu is at 100% and my dedicated video card is being used.
Thanks
bollix47
Post by bollix47 »
Hi kwk1 and welcome to the folding@home support forum.
Please start by showing us your System Info and Configuration as explained here.
mmonnin
Post by mmonnin »
Perhaps 2 instances of the client are running?
kwk1
Post by kwk1 »
Okay, I copied the log from today, while the program is running. Now what?
EDIT: I'm subscribed to this thread, but am not getting email notifications when new posts are added.
Thanks
*********************** Log Started 2013-03-11T23:40:35Z ***********************
23:40:35:************************* Folding@home Client *************************
23:40:35:      Website: http://folding.stanford.edu/
23:40:35:    Copyright: (c) 2009-2012 Stanford University
23:40:35:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:40:35:         Args: --lifeline 4896 --command-port=36330
23:40:35:       Config: C:/Users/Ken/AppData/Roaming/FAHClient/config.xml
23:40:35:******************************** Build ********************************
23:40:35:      Version: 7.1.52
23:40:35:         Date: Mar 20 2012
23:40:35:         Time: 19:37:42
23:40:35:      SVN Rev: 3515
23:40:35:       Branch: fah/trunk/client
23:40:35:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
23:40:35:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
23:40:35:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
23:40:35:     Platform: win32 XP
23:40:35:         Bits: 32
23:40:35:         Mode: Release
23:40:35:******************************* System ********************************
23:40:35:          CPU: Intel(R) Core(TM) i7-2760QM CPU @ 2.40GHz
23:40:35:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
23:40:35:         CPUs: 8
23:40:35:       Memory: 7.89GiB
23:40:35:  Free Memory: 6.09GiB
23:40:35:      Threads: WINDOWS_THREADS
23:40:35:   On Battery: false
23:40:35:   UTC offset: -5
23:40:35:          PID: 2904
23:40:35:          CWD: C:/Users/Ken/AppData/Roaming/FAHClient
23:40:35:           OS: Windows 7 Professional
23:40:35:      OS Arch: AMD64
23:40:35:         GPUs: 1
23:40:35:        GPU 0: FERMI:1 GF108 [Quadro 1000M]
23:40:35:         CUDA: 2.1
23:40:35:  CUDA Driver: 5000
23:40:35:Win32 Service: false
23:40:35:***********************************************************************
23:40:35:<config>
23:40:35:  <!-- Folding Slot Configuration -->
23:40:35:  <gpu v='true'/>
23:40:35:
23:40:35:  <!-- Network -->
23:40:35:  <proxy v=':8080'/>
23:40:35:
23:40:35:  <!-- User Information -->
23:40:35:  <team v='60'/>
23:40:35:  <user v='kwk1'/>
23:40:35:
23:40:35:  <!-- Folding Slots -->
23:40:35:  <slot id='0' type='GPU'/>
23:40:35:  <slot id='1' type='SMP'/>
23:40:35:</config>
23:40:35:Trying to access database...
23:40:36:Successfully acquired database lock
23:40:36:Enabled folding slot 00: READY gpu:0:"GF108 [Quadro 1000M]"
23:40:36:Enabled folding slot 01: READY smp:8
23:40:36:WU01:FS01:Starting
23:40:37:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Ken/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 701 -lifeline 2904 -checkpoint 15 -np 8
23:40:37:WU01:FS01:Started FahCore on PID 7428
23:40:38:WU01:FS01:Core PID:3356
23:40:38:WU01:FS01:FahCore 0xa4 started
23:40:38:WU00:FS00:Starting
23:40:38:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Ken/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 701 -lifeline 2904 -checkpoint 15 -gpu 0
23:40:38:WU00:FS00:Started FahCore on PID 3632
23:40:39:WU00:FS00:Core PID:7588
23:40:39:WU00:FS00:FahCore 0x15 started
23:40:39:WU01:FS01:0xa4:
23:40:39:WU01:FS01:0xa4:*------------------------------*
23:40:39:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
23:40:39:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
23:40:39:WU01:FS01:0xa4:Preparing to commence simulation
23:40:39:WU01:FS01:0xa4:- Looking at optimizations...
23:40:39:WU01:FS01:0xa4:- Files status OK
23:40:39:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
23:40:39:WU01:FS01:0xa4:- Expanded 701569 -> 5386224 (decompressed 767.7 percent)
23:40:39:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=701569 data_size=5386224, decompressed_data_size=5386224 diff=0
23:40:39:WU01:FS01:0xa4:- Digital signature verified
23:40:40:WU01:FS01:0xa4:
23:40:40:WU01:FS01:0xa4:Project: 7809 (Run 6, Clone 126, Gen 11)
23:40:40:WU01:FS01:0xa4:Assembly optimizations on if available.
23:40:40:WU01:FS01:0xa4:Entering M.D.
23:40:40:WU00:FS00:0x15:
23:40:40:WU00:FS00:0x15:*------------------------------*
23:40:40:WU00:FS00:0x15:Folding@Home GPU Core
23:40:40:WU00:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
23:40:40:WU00:FS00:0x15:Build host             AmoebaRemote
23:40:40:WU00:FS00:0x15:Board Type             NVIDIA/CUDA
23:40:40:WU00:FS00:0x15:Core                   15
23:40:40:WU00:FS00:0x15:Window's signal control handler registered.
23:40:40:WU00:FS00:0x15:Preparing to commence simulation
23:40:40:WU00:FS00:0x15:- Looking at optimizations...
23:40:40:WU00:FS00:0x15:- Files status OK
23:40:40:WU00:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:40:40:WU00:FS00:0x15:- Expanded 125582 -> 502918 (decompressed 400.4 percent)
23:40:40:WU00:FS00:0x15:Called DecompressByteArray: compressed_data_size=125582 data_size=502918, decompressed_data_size=502918 diff=0
23:40:40:WU00:FS00:0x15:- Digital signature verified
23:40:40:WU00:FS00:0x15:Project: 7625 (Run 494, Clone 0, Gen 74)
23:40:40:WU00:FS00:0x15:Assembly optimizations on if available.
23:40:40:WU00:FS00:0x15:Entering M.D.
23:40:43:WU00:FS00:0x15:Will resume from checkpoint file 00/wudata_01.ckp
23:40:43:WU00:FS00:0x15:Tpr hash 00/wudata_01.tpr:  2904012726 2746532782 982349657 3704087211 29538787
23:40:43:WU00:FS00:0x15:GPU device id=0
23:40:44:WU00:FS00:0x15:Working on Protein
23:40:44:WU00:FS00:0x15:Client config unavailable.
23:40:44:WU00:FS00:0x15:Starting GUI Server
23:40:47:WU01:FS01:0xa4:Using Gromacs checkpoints
23:40:47:WU01:FS01:0xa4:Mapping NT from 8 to 8
23:40:54:WU01:FS01:0xa4:Resuming from checkpoint
23:40:54:WU01:FS01:0xa4:Verified 01/wudata_01.log
23:40:55:WU01:FS01:0xa4:Verified 01/wudata_01.trr
23:40:55:WU01:FS01:0xa4:Verified 01/wudata_01.xtc
23:40:55:WU01:FS01:0xa4:Verified 01/wudata_01.edr
23:41:01:WU01:FS01:0xa4:Completed 690050 out of 1500000 steps  (46%)
23:42:04:WU00:FS00:0x15:Resuming from checkpoint
23:42:04:WU00:FS00:0x15:fcCheckPointResume: retreived and current tpr file hash:
23:42:04:WU00:FS00:0x15:   0   2904012726   2904012726
23:42:04:WU00:FS00:0x15:   1   2746532782   2746532782
23:42:04:WU00:FS00:0x15:   2    982349657    982349657
23:42:04:WU00:FS00:0x15:   3   3704087211   3704087211
23:42:04:WU00:FS00:0x15:   4     29538787     29538787
23:42:04:WU00:FS00:0x15:fcCheckPointResume: file hashes same.
23:42:04:WU00:FS00:0x15:fcCheckPointResume: state restored.
23:42:04:WU00:FS00:0x15:fcCheckPointResume: name 00/wudata_01.log Verified 00/wudata_01.log
23:42:04:WU00:FS00:0x15:fcCheckPointResume: name 00/wudata_01.trr Verified 00/wudata_01.trr
23:42:04:WU00:FS00:0x15:fcCheckPointResume: name 00/wudata_01.xtc Verified 00/wudata_01.xtc
23:42:05:WU00:FS00:0x15:fcCheckPointResume: name 00/wudata_01.edr Verified 00/wudata_01.edr
23:42:05:WARNING:WU00:FS00:Detected clock skew, adjusting time estimates
23:42:05:WU00:FS00:0x15:fcCheckPointResume: state restored 2
23:42:05:WU00:FS00:0x15:Resumed from checkpoint
23:42:05:WU00:FS00:0x15:Setting checkpoint frequency: 400000
23:42:05:WU00:FS00:0x15:Completed   5600001 out of 40000000 steps (14%).
00:15:50:WU00:FS00:0x15:Completed   6000000 out of 40000000 steps (15%).
00:49:37:WU00:FS00:0x15:Completed   6400000 out of 40000000 steps (16%).
01:23:23:WU00:FS00:0x15:Completed   6800000 out of 40000000 steps (17%).
Napoleon
Windows 7 Ultimate 64bit
NVidia GT430, core_15 work
Post by Napoleon »
@kwk1,
could you Finish your currently running WUs, uninstall v7.1.52 (also remove FAH data directory) and do a clean install of client v7.3.6? Things have changed a bit and v7.3.6 should be easier on people who are "not very computer savvy", as you phrased it.
Win7 64bit, FAH v7, OC'd
NaCl - Core_15 - display
kwk1
Post by kwk1 »
Hi Napoleon,
So, go to programs and uninstall FAH, I can do that.
I don't know what or where FAH data recovery is though.
Also, will I still be able to save my status and username if I reinstall the newer program?
Or would I be starting from scratch again?
What did anyone find from the data I supplied, just curious?
Thanks
From the time covered in the log it looked like everything was processing okay. It was not long enough to get a sense on how the SMP WU was progressing.
If you delete the data files, you just need to reenter your username, team and passkey. Your status in the stats does not change. If you are already qualified for the QRB, then work turned in after the reinstall will get the bonus. No need to requalify.
Napoleon
Post by Napoleon »
What I said was FAH data directory. In practice that means - once you've Finished your current Work Units - when you uninstall FAH, put a checkmark to "Data" in the uninstaller dialogue:
Checking "Data" will remove everything about FAH from your computer, so you will have to re-enter your username, team, passkey etc again when you install v7.3.6. But just like Joe_H said, it won't affect your FAH standings at all, your Quick Return Bonus eligibility and current points are stored in FAH stats servers. As long as you don't mistype your existing credentials when you do a fresh install, you'll keep accumulating points just as usual.
As for the data you supplied... if the (apparently cosmetic) problem isn't fixed in v7.3.6 already, I'm sure that developers will take an active interest in the matter. Client v7 is getting improved all the time. Pande Group doesn't give any ETAs for fixes/enhancements though, only "soon" or "not soon".
[geek_lingo]But PG "soon" is nothing like Duke Nukem Forever "soon". Think in terms of Steam "soon".[/geek_lingo] :wink:
PinHead
Hardware configuration: Quad Q9550 2.83 contains the GPU 57xx - running SMP and GPU
Post by PinHead »
kwk1, any chance you have the log file open in another dos box / terminal session or notepad screen? That will prevent the client from doing the clean up.
kwk1
Post by kwk1 »
Okay, I guess I just need to wait till I finish the current work unit. Then uninstall the current program, and install the newer program.
Thanks for the help, I'll update this thread when I've installed and fired up V7.3.6.
Pinhead, I don't think I have the file open in another screen.
kwk1
Post by kwk1 »
Okay, finished current WU and uninstalled FAH. Then, installed the latest version.
It took a while, but seems to be working now.
I guess the only question I have now is how to get it to run minimized in the task bar like the older version did.
This new one opens up in a browser window. BTW, I did the express install, not the advanced one.
Thanks
I don't use the web client but you should be able to close it and keep folding. Returning to that website either by browser shortcut, systray icon, or all_programs should reconnect to the active FAH program.
There are some reports of icon problems
viewtopic.php?f=88&t=23880&p=238834#p238834
P5-133XL
Machine #2:
Machine 3:
Post by P5-133XL »
you can run Advanced Control and it will appear in the taskbar and minimizing it works fine...
