No Appropriate Work Server Available
joe53
Post by joe53 »
I've not been able to download any WUs for the last half day, after my SMP Client v. 6.34 has been working well continuously for almost 2 years. All attempts to get work fail. Passkey is found and 8 cores are detected. My last WU was successfully sent yesterday. Closing program and a system re-boot does not help.
What to do to fix this? Is this a server problem at F@H?
Napoleon
Windows 7 Ultimate 64bit
NVidia GT430, core_15 work
Re: No Appropriate Work Server Available
Post by Napoleon »
Seeing some logs would be useful in order to determine which server(s) you're having problems with, if any. According to http://fah-web.stanford.edu/pybeta/serverstat.html, most SMP servers seem to be up and running.
Win7 64bit, FAH v7, OC'd
NaCl - Core_15 - display
artoar_11
Hardware configuration: AMD R7 3700X @ 4.0 GHz; ASUS ROG STRIX X470-F GAMING; DDR4 2x8GB @ 3.0 GHz; GByte RTX 3060 Ti @ 1890 MHz; Fortron-550W 80+ bronze; Win10 Pro/64
Post by artoar_11 »
It happened to me several times. Only with client v6.34. Stop the client, remove - unitinfo.txt ; queue.dat ; MyFolding.html and folder work. Launch v6.34 .exe, should be OK :)
PS: viewtopic.php?f=18&t=23520#p235311
viewtopic.php?f=18&t=23520&start=15#p236757
joe53
Post by joe53 »
artoar_11:
Thanks so much! That fixed it. I see all those files were re-created on opening the client.
I am most grateful for your simple solution. :D
k1wi
Post by k1wi »
I just had this problem on one of my computers.
The real solution to the problem is to upgrade to V7.
