Suddenly my Radeon HD 6870 failed to fold. The AMD Vision Engine Control Center was updated to , Ver. 2012.1219.1521.27485 and Catalyst Ver. 13.1, Driver Packaging Ver. 9.012-121219a-151592C-ATI. The original was a beta version. and I was told to change that because the folding took 10-17 hours on the GPU and 3-5 days on the CPU, before that it was 2-4 hours and 12-15 hours.
Now the GPU fail to run.
I uninstall all of the Catalyst and all drivers, restarted the computers and then installed the 12.8 still the same problem. uninstalled that and installed the 13.1 and the CPU time is now 4 hours for the CPU and total fail on the GPU.
PLEASE, PLEASE Help me.
Thanks in advanced
PS if you need more info please ask me and I will try to answer you. BTW see my signature for my computer info.
XFX Radeon HD 6870 Problems suddenly
RealBigSwede
- Hardware configuration: Intel(R) Core(TM) i5-9600KF CPU @ 3.70GHz 3.70 GHz
Nvidia GeForce XFX 970
Vvidia GeForce XFX 1070
16 GB DDR4
OZS 120 SSD + Intel 128 SSD + Intel 250 SSD + 2TB Seagate Barracuda
48" RCA @ 4k - Location: Infront of my 'puter
Re: XFX Radeon HD 6870 Problems suddenly
Can you please post the initial section of the fahlog so we can see your system specification, client configuration and errors?
RealBigSwede
16 GB DDR4
what I did was a total reformat and re-installed win8 and now all is working perfect. Most have been a corrupt file somewhere..
Evil Penguin
It was the drivers more than likely.
I was messing with them recently and I ran into the errors that you did when we were on IRC.
Atiman uninstaller did the trick and I installed Catalyst 13.2 beta 6.
I think Cat. 13.1 would work better for you, though.
RealBigSwede
16 GB DDR4
that is what I running now... and the core 17 beta is working like a charm make a wu in 5.5-6 hours
