Blocked database (Locked database?)
fordyce0593
I recently have converted my PC to Windows8 64 bits.
I have re-installed Folding@home (I am folding since years under the Name [PCA]_FORDYCE Team 51).
The software works now on my graphic card (GEForce) and on one core of my Pentium processor.
Since then I am experiencing some problems :
-- First a WU has stayed working for more than fifteen days, has been sent to Stanford, without any points credit.
-- Secondly ; since four days the client stopped to send finished WU, see log :
15:13:25:WARNING:WU05:FS00:Exception: Failed to advance statement result: The database file is locked
15:13:25:WARNING:WU09:FS00:Detected clock skew (1 mins 01 secs), adjusting time estimates
15:13:55:WARNING:WU03:FS00:Exception: Failed to send results to work server: Failed to advance statement result: The database file is locked
15:14:25:ERROR:WU03:FS00:Exception: Failed to advance statement result: The database file is locked
15:14:42:ERROR:WU08:FS00:Exception: Failed to advance statement result: The database file is locked
15:20:02:ERROR:WU09:FS00:Exception: Failed to advance statement result: The database file is locked
15:20:33:WARNING:WU05:FS00:Exception: Failed to advance statement result: The database file is locked
15:20:33:WARNING:WU09:FS00:Detected clock skew (1 mins 01 secs), adjusting time estimates
15:21:50:ERROR:WU08:FS00:Exception: Failed to advance statement result: The database file is locked
15:26:51:WARNING:WU04:FS00:Exception: Failed to send results to work server: Failed to advance statement result: The database file is locked
15:27:22:ERROR:WU04:FS00:Exception: Failed to advance statement result: The database file is locked
15:27:22:WARNING:WU09:FS00:Detected clock skew (1 mins 02 secs), adjusting time estimates
15:27:52:ERROR:WU09:FS00:Exception: Failed to advance statement result: The database file is locked
15:28:22:WARNING:WU05:FS00:Exception: Failed to advance statement result: The database file is locked
15:29:10:ERROR:WU08:FS00:Exception: Failed to advance statement result: The database file is locked
15:34:45:WARNING:WU05:FS00:Exception: Failed to send results to work server: Failed to advance statement result: The database file is locked
15:35:16:ERROR:WU05:FS00:Exception: Failed to advance statement result: The database file is locked
15:35:16:WARNING:WU09:FS00:Detected clock skew (1 mins 01 secs), adjusting time estimates
15:35:46:ERROR:WU09:FS00:Exception: Failed to advance statement result: The database file is locked
15:36:16:WARNING:WU05:FS00:Exception: Failed to advance statement result: The database file is locked
15:36:53:ERROR:WU08:FS00:Exception: Failed to advance statement result: The database file is locked
15:42:55:ERROR:WU09:FS00:Exception: Failed to advance statement result: The database file is locked
15:43:25:WARNING:WU05:FS00:Exception: Failed to advance statement result: The database file is locked
15:44:34:ERROR:WU08:FS00:Exception: Failed to advance statement result: The database file is locked
15:46:39:WARNING:WU07:FS00:Exception: Failed to send results to work server: Failed to advance statement result: The database file is locked
15:47:10:ERROR:WU07:FS00:Exception: Failed to advance statement result: The database file is locked
15:47:10:WARNING:WU09:FS00:Detected clock skew (1 mins 01 secs), adjusting time estimates
Therefore the WU are piling up, and, obviously, nothing is sent out.
Does somebody has an idea to unlock this database ?
List of the work queue :
0 7809(0,328,43) 73% Run
1 5768(1,215,4806)100% Send
2 10503(101,6,3)0%Send
3 5768(4,137,2340)0%Send
4 5769(12,384,8986)100%Send
5 5765(10,205,1807)0%Send
6 5772(5,27,5173)0%Send
7 5765(10,314,3999)100%Send
8 5772(11,321,2035)0%Send
9 5765(1,93,2561)72%Run
I am waiting for any good advice.
Thanks.
Fordyce
Thanks.
Fordyce
Re: Blocked database
Welcome to the F@H Forum fordyce0593,
Can you please tell us which version of FAH is installed on your system? Moreover, could you post the initial section of the log (using the Code Tags found in the Full Editor) which will have the details like this:
*********************** Log Started 2013-01-10T18:58:50Z ***********************
18:58:50:************************* Folding@home Client *************************
18:58:50: Website: http://folding.stanford.edu/
18:58:50: Copyright: (c) 2009-2012 Stanford University
18:58:50: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:58:50: Args: --lifeline 5252 --command-port=36330
18:58:50: Config: C:/Users/PantherX/AppData/Roaming/FAHClient/config.xml
18:58:50:******************************** Build ********************************
18:58:50: Version: 7.2.9
18:58:50: Date: Oct 3 2012
18:58:50: Time: 18:05:48
18:58:50: SVN Rev: 3578
18:58:50: Branch: fah/trunk/client
18:58:50: Compiler: Intel(R) C++ MSVC 1500 mode 1200
18:58:50: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
18:58:50: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
18:58:50: Platform: win32 XP
18:58:50: Bits: 32
18:58:50: Mode: Release
18:58:50:******************************* System ********************************
18:58:50: CPU: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
18:58:50: CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
18:58:50: CPUs: 8
18:58:50: Memory: 10.99GiB
18:58:50: Free Memory: 9.38GiB
18:58:50: Threads: WINDOWS_THREADS
18:58:50: On Battery: false
18:58:50: UTC offset: 3
18:58:50: PID: 5740
18:58:50: CWD: C:/Users/PantherX/AppData/Roaming/FAHClient
18:58:50: OS: Windows 8 Pro
18:58:50: OS Arch: AMD64
18:58:50: GPUs: 1
18:58:50: GPU 0: NVIDIA:1 GT200 [GeForce GTX 260]
18:58:50: CUDA: 1.3
18:58:50: CUDA Driver: 5000
18:58:50:Win32 Service: false
18:58:50:***********************************************************************
18:58:50:<config>
18:58:50: <!-- Folding Slot Configuration -->
18:58:50: <gpu v='true'/>
18:58:50: <smp v='false'/>
18:58:50:
18:58:50: <!-- Network -->
18:58:50: <proxy v=':8080'/>
18:58:50:
18:58:50: <!-- User Information -->
18:58:50: <passkey v='********************************'/>
18:58:50: <team v='69411'/>
18:58:50: <user v='PantherX'/>
18:58:50:
18:58:50: <!-- Folding Slots -->
18:58:50: <slot id='0' type='GPU'>
18:58:50: <max-packet-size v='big'/>
18:58:50: <next-unit-percentage v='100'/>
18:58:50: <pause-on-start v='true'/>
18:58:50: </slot>
18:58:50: <slot id='1' type='SMP'>
18:58:50: <cpus v='6'/>
18:58:50: </slot>
18:58:50:</config>ETA:
art_l_j_PlanetAMD64
I have not used Windows 8, but in FAH v7.2.9 and using Windows 7, here is how to find and post the log file information. You can find the log file(s) by going here:
Start -> All Programs -> FAHClient -> Data Directory
The log in v7 is called log.txt and is located in the Data Directory. In that same directory you will see a sub-directory called 'logs'. There you will find a number of previous logs depending on how long you've been folding and which options have been set.
As PantherX said, you should include the information at the top of the log file (System Info and Configuration) as described here, as well as the part of the log file starting just before where the problem appeared.
When you are posting a log file extract, please enclose the log file extract in a 'code' window. You can do that by clicking on the 'Code' button above the editing window when you are typing a message. It makes the message much easier to read and analyze. Thanks!
art_l_j_PlanetAMD64
Over 1.04 Billion Total Points
Over 185,000 Work Units
Over 3,800,000 PPD
Overall rank (if points are combined) 20 of 1721690
In memory of my Mother May 12th 1923 - February 10th 2012
Over 3,800,000 PPD
codysluder
The only time I've ever seen"database locked" was when two copies of fah got started Please check if it was started automatically and you also started it manually.
art_l_j_PlanetAMD64
This is a very good point, you can check on the FAH processes by running Task Manager and looking at the processes that are running:codysluder wrote:The only time I've ever seen"database locked" was when two copies of fah got started Please check if it was started automatically and you also started it manually.
1) Right-click on an empty area of the taskbar, and left-click on 'Start Task Manager'.
2) Select the 'Processes' tab.
3) Click on the 'Image Name' title to sort them alphabetically.
You should see one (and only one) FAHClient.exe process.
When FAHClient is folding an SMP Work Unit (WU), you should see these 3 processes:
1) FAHClient.exe
2) FAHCoreWrapper.exe
3) FahCore_xx.exe (where 'xx' will be something like 'a3' or 'a4')
When a GPU WU is being folded, you will also see this:
1) another FAHCoreWrapper.exe
2) FahCore_xx.exe (where 'xx' will be something like '11' or '15' or '16')
The FAH processes will have '*32' associated with them, showing that they are 32-bit Windows processes.
art_l_j_PlanetAMD64
Over 3,800,000 PPD
Over 3,800,000 PPD
fordyce0593
Thanks for a so prompt reply.
I am using Client Control version 7.2.9
Unfortunately I cannot get any copy of the stucked WU.
This is the beginning of the running log Slot 1 Queue 0 :
The other running slot 0 queue 9 :
I got this log directly on the disk, not through the software : See the beginning :
and the end :
The problem is coming with the Slot 0 working on the graphic card.
I am afraid I have to drop faulty WU's. Since I am not very aware of Folding@home procedure, I prefer to get advice before.
I would also get advice about the use of the graphic card. It is nice to process two WU's at a time, however this is productive if it works.
I have modified this message after receiving a new advice from Planet AMD64.
Thanks to everybody, I feel no more alone !
Fordyce
Mod Edit: Adjusted Code Tags & Post- PantherX
*********************** Log Started 2013-01-17T18:50:16Z ***********************
18:50:16:WU00:FS01:Starting
18:50:16:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Michel/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 702 -lifeline 1936 -checkpoint 15 -np 2
18:50:16:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Michel/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 702 -lifeline 52 -checkpoint 15 -np 2
18:50:16:WU00:FS01:Started FahCore on PID 341618:50:16:WU00:FS01:Started FahCore on PID 2988
18:50:16:WU00:FS01:Core PID:3552
18:50:16:WU00:FS01:Core PID:4560
18:50:16:WU00:FS01:FahCore 0xa4 started
18:50:17:WU00:FS01:0xa4:
18:50:17:WU00:FS01:0xa4:*------------------------------*
18:50:17:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
18:50:17:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
18:50:17:WU00:FS01:0xa4:Preparing to commence simulation
18:50:17:WU00:FS01:0xa4:- Looking at optimizations...
18:50:17:WU00:FS01:0xa4:- Files status OK
18:50:17:WU00:FS01:0xa4:- Expanded 2079116 -> 5386224 (decompressed 259.0 percent)
18:50:17:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2079116 data_size=5386224, decompressed_data_size=5386224 diff=0
18:50:17:WU00:FS01:0xa4:- Digital signature verified
18:50:17:WU00:FS01:0xa4:18:50:17:WU00:FS01:0xa4:Project: 7809 (Run 0, Clone 328, Gen 43)
18:50:17:WU00:FS01:0xa4:Assembly optimizations on if available.
18:50:17:WU00:FS01:0xa4:Entering M.D.
18:50:23:WU00:FS01:0xa4:Using Gromacs checkpoints
18:50:24:WU00:FS01:0xa4:Mapping NT from 2 to 2
18:50:24:WU00:FS01:0xa4:Resuming from checkpoint
18:50:24:WU00:FS01:0xa4:Verified 00/wudata_01.log
18:50:24:WU00:FS01:0xa4:Verified 00/wudata_01.trr18:50:24:WU00:FS01:0xa4:Verified 00/wudata_01.trr
18:50:24:WU00:FS01:0xa4:Verified 00/wudata_01.xtc18:50:24:WU00:FS01:0xa4:Verified 00/wudata_01.xtc
18:50:24:WU00:FS01:0xa4:Verified 00/wudata_01.edr
18:50:25:WU00:FS01:0xa4:Completed 818910 out of 1500000 steps (54%)
18:50:47:ERROR:WU00:FS01:Exception: Failed to advance statement result: The database file is locked18:50:47:ERROR:WU00:FS01:Exception: Failed to advance statement result: The database file is locked
18:51:48:ERROR:WU00:FS01:Exception: Failed to advance statement result: The database file is locked
18:52:52:WARNING:WU00:FS01:Exception: Failed to advance statement result: The database file is locked
18:52:52:WARNING:WU00:FS01:Detected clock skew (1 mins 35 secs), adjusting time estimates
18:50:16:WU00:FS01:FahCore 0xa4 startedCode: Select all
16:55:24:ERROR:WU09:FS00:Exception: Failed to advance statement result: The database file is locked
16:57:00:WU09:FS00:Sending unit results: id:09 state:SEND error:FAILED project:5772 run:13 clone:141 gen:3537 core:0x11 unit:0x28d57b9350fac9e90dd1008d000d168c
16:57:30:WARNING:WU09:FS00:Exception: Failed to send results to work server: Failed to advance statement result: The database file is locked
16:57:30:WU09:FS00:Trying to send results to collection server
16:58:00:ERROR:WU09:FS00:Exception: Failed to advance statement result: The database file is lockedCode: Select all
*********************** Log Started 2013-01-10T11:45:47Z ***********************
11:45:47:************************* Folding@home Client *************************
11:45:47: Website: http://folding.stanford.edu/
11:45:47: Copyright: (c) 2009-2012 Stanford University
11:45:47: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:45:47: Args: --lifeline 2764 --command-port=36330
11:45:47: Config: C:/Users/Michel/AppData/Roaming/FAHClient/config.xml
11:45:47:******************************** Build ********************************
11:45:47: Version: 7.2.9
11:45:47: Date: Oct 3 2012
11:45:47: Time: 18:05:48
11:45:47: SVN Rev: 3578
11:45:47: Branch: fah/trunk/client
11:45:47: Compiler: Intel(R) C++ MSVC 1500 mode 1200
11:45:47: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
11:45:47: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
11:45:47: Platform: win32 XP
11:45:47: Bits: 32
11:45:47: Mode: Release
11:45:47:******************************* System ********************************
11:45:47: CPU: Pentium(R) Dual-Core CPU E5300 @ 2.60GHz
11:45:47: CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
11:45:47: CPUs: 2
11:45:47: Memory: 8.00GiB
11:45:47: Free Memory: 6.82GiB
11:45:47: Threads: WINDOWS_THREADS
11:45:47: On Battery: false
11:45:47: UTC offset: 1
11:45:47: PID: 2356
11:45:47: CWD: C:/Users/Michel/AppData/Roaming/FAHClient
11:45:47: OS: Windows 8 Pro
11:45:47: OS Arch: AMD64
11:45:47: GPUs: 1
11:45:47: GPU 0: NVIDIA:1 G96 [GeForce 9500 GT]
11:45:47: CUDA: 1.1
11:45:47: CUDA Driver: 5000
11:45:47:Win32 Service: false
11:45:47:***********************************************************************
11:45:47:<config>
11:45:47: <!-- Folding Slot Configuration -->
11:45:47: <gpu v='true'/>
11:45:47:
11:45:47: <!-- Network -->
11:45:47: <proxy v=':8080'/>
11:45:47:
11:45:47: <!-- User Information -->
11:45:47: <team v='51'/>
11:45:47: <user v='[PCA]_FORDYCE'/>
11:45:47:
11:45:47: <!-- Folding Slots -->
11:45:47: <slot id='0' type='GPU'/>
11:45:47: <slot id='1' type='SMP'/>
11:45:47:</config>
11:45:47:Trying to access database...
11:45:47:Successfully acquired database lock
11:45:47:Enabled folding slot 00: READY gpu:0:"G96 [GeForce 9500 GT]"
11:45:47:Enabled folding slot 01: READY smp:2
11:45:47:WU02:FS00:Starting
11:45:47:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Michel/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 02 -suffix 01 -version 702 -lifeline 2356 -checkpoint 15 -gpu 0
11:45:47:WU02:FS00:Started FahCore on PID 2560
11:45:48:WU02:FS00:Core PID:4140
11:45:48:WU02:FS00:FahCore 0x11 started
11:45:48:WU01:FS01:Starting
11:45:48:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Michel/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 01 -suffix 01 -version 702 -lifeline 2356 -checkpoint 15 -np 2
11:45:48:WU01:FS01:Started FahCore on PID 2760
11:45:49:WU01:FS01:Core PID:4720
11:45:49:WU01:FS01:FahCore 0xa3 started
11:45:49:WU02:FS00:0x11:
11:45:49:WU02:FS00:0x11:*------------------------------*
11:45:49:WU02:FS00:0x11:Folding@Home GPU Core
11:45:49:WU02:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
11:45:49:WU02:FS00:0x11:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
11:45:49:WU02:FS00:0x11:Build host: amoeba
11:45:49:WU02:FS00:0x11:Board Type: Nvidia
11:45:49:WU02:FS00:0x11:Core :
11:45:49:WU02:FS00:0x11:Preparing to commence simulation
11:45:49:WU02:FS00:0x11:- Ensuring status. Please wait.
11:45:49:WU01:FS01:0xa3:
11:45:49:WU01:FS01:0xa3:*------------------------------*
11:45:49:WU01:FS01:0xa3:Folding@Home Gromacs SMP Core
11:45:49:WU01:FS01:0xa3:Version 2.27 (Dec. 15, 2010)
11:45:49:WU01:FS01:0xa3:Preparing to commence simulation
11:45:49:WU01:FS01:0xa3:- Ensuring status. Please wait.
11:45:50:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
11:45:58:WU02:FS00:0x11:- Looking at optimizations...
11:45:58:WU02:FS00:0x11:- Working with standard loops on this execution.
11:45:58:WU02:FS00:0x11:Examination of work files indicates 8 consecutive improper terminations of core.
11:45:58:WU01:FS01:0xa3:- Looking at optimizations...
11:45:58:WU02:FS00:0x11:- Expanded 46740 -> 252912 (decompressed 541.1 percent)
11:45:58:WU01:FS01:0xa3:- Working with standard loops on this execution.
11:45:58:WU02:FS00:0x11:Called DecompressByteArray: compressed_data_size=46740 data_size=252912, decompressed_data_size=252912 diff=0
11:45:58:WU01:FS01:0xa3:Examination of work files indicates 8 consecutive improper terminations of core.
11:45:58:WU02:FS00:0x11:- Digital signature verified
11:45:58:WU02:FS00:0x11:Project: 5766 (Run 5, Clone 463, Gen 2695)
11:45:58:WU02:FS00:0x11:Entering M.D.
11:45:59:WU01:FS01:0xa3:- Expanded 2034758 -> 3061060 (decompressed 150.4 percent)
11:45:59:WU01:FS01:0xa3:Called DecompressByteArray: compressed_data_size=2034758 data_size=3061060, decompressed_data_size=3061060 diff=0
11:45:59:WU01:FS01:0xa3:- Digital signature verified
11:45:59:WU01:FS01:0xa3:Project: 10127 (Run 48, Clone 1, Gen 105)
11:45:59:WU01:FS01:0xa3:Entering M.D.
11:46:04:WU02:FS00:0x11:Will resume from checkpoint file
11:46:04:WU02:FS00:0x11:Tpr hash 02/wudata_01.tpr: 3496738666 4176459736 2570014027 593871929 1687173880
11:46:04:WU02:FS00:0x11:Calling fah_main args: 14 usage=100
11:46:05:WU02:FS00:0x11:Working on Protein
11:46:05:WU01:FS01:0xa3:Using Gromacs checkpoints
11:46:05:WU01:FS01:0xa3:Mapping NT from 2 to 2
11:46:05:WU02:FS00:0x11:Client config unavailable.
11:46:05:WU02:FS00:0x11:Starting GUI Server
11:46:05:WU02:FS00:0x11:Resuming from checkpoint
11:46:05:WU02:FS00:0x11:fcCheckPointResume: retreived and current tpr file hash:
11:46:05:WU02:FS00:0x11: 0 3496738666 3496738666
11:46:05:WU02:FS00:0x11: 1 4176459736 4176459736
11:46:05:WU02:FS00:0x11: 2 2570014027 2570014027
11:46:05:WU02:FS00:0x11: 3 593871929 593871929
11:46:05:WU02:FS00:0x11: 4 1687173880 1687173880
11:46:05:WU02:FS00:0x11:fcCheckPointResume: file hashes same.
11:46:05:WU02:FS00:0x11:fcCheckPointResume: state restored.
11:46:05:WU02:FS00:0x11:Verified 02/wudata_01.log
11:46Code: Select all
19:53:21:WU02:FS00:0x11:Completed 7%
19:56:49:WU02:FS00:0x11:Completed 8%
20:00:16:WU02:FS00:0x11:Completed 9%
20:03:44:WU02:FS00:0x11:Completed 10%
20:07:13:WU02:FS00:0x11:Completed 11%
20:10:42:WU02:FS00:0x11:Completed 12%
20:14:12:WU02:FS00:0x11:Completed 13%
20:17:44:WU02:FS00:0x11:Completed 14%
20:21:16:WU02:FS00:0x11:Completed 15%
20:21:30:Lost lifeline PID 2764, exiting
20:21:30:Server connection id=3 ended
20:21:31:FS00:Shutting core down
20:21:31:FS01:Shutting core down
20:21:33:WU02:FS00:0x11:Client no longer detected. Shutting down core
20:21:33:WU02:FS00:0x11:Folding@home Core Shutdown: CLIENT_DIED
20:21:40:WU00:FS01:0xa4:Client no longer detected. Shutting down core
20:21:40:WU00:FS01:0xa4:Folding@home Core Shutdown: CLIENT_DIED
20:21:40:Clean exitI am afraid I have to drop faulty WU's. Since I am not very aware of Folding@home procedure, I prefer to get advice before.
Fordyce
codysluder
Are you running fah as a service or switching users?
fordyce0593
I checked the task manager. I have :
2 instances of Fah control.
2 instances of Fah client.
8 instances of Fah core.
Unfortunately I don't know how to send a screen copy.
I'm afraid this is a little bit messy.
Fordyce
Fordyce
fordyce0593
I am not sure however I think I am not using Fah as a service since it is not included in this list.
Haha could you put the code tags around the fah log portion of your post instead of your comments. That'll add the scroll bar and reduce the overall length of your post.
I see some duplicate lines in the log file. Can you check processes listed in task manager as art mentioned prior to your last posts. My first guess is that you have 2 clients starting up. Maybe one as a service and one in FAHControl?
Edit: And I see you posted some of that as I was reading/posting...
art_l_j_PlanetAMD64
You're welcome, but you put the 'code' and '/code' tags around your text by mistake, instead of around the log file extracts.fordyce0593 wrote:I have modified this message after receiving a new advice from Planet AMD64.
OK, please give us the hardware information about your computer, like the CPU, GPU (graphics card), power supply, motherboard, RAM, and anything else you have. Also please provide the software information (you already said you have Windows 8) like the graphics card driver version. Thanks!fordyce0593 wrote:I would also get advice about the use of the graphic card. It is nice to process two WU's at a time, however this is productive if it works.
EDIT:
I see that you have the GeForce 9500 GT graphics card.
art_l_j_PlanetAMD64
Over 3,800,000 PPD
Over 3,800,000 PPD
From the log, I noticed that you have a GPU and SMP slot configured which is fine and that you are not running it as a service. Moreover, I noticed that you are missing a passkey. If you purposely edited it out and its fine. However, if you don't have one, you may want to consider getting one (http://folding.stanford.edu/English/FAQ-passkey)
What you described in the Task Manager would suggest that you have two instances of FAHClient running and that is what is causing the issues.
BTW, after the installation, did you do something "special" or tweaked the system as I would like to know how you got two instances of FAH running on the same system.
A quick fix would be to do a full uninstall and make sure that the folder "FAHClient" in C:/Users/Michel/AppData/Roaming/ doesn't exist after the uninstall. You can then reinstall it and it should work fine.
A longer fix would be to determine how to stop the two copies from working simultaneously and then you can stop one copy while the other copy finishes and once it finishes, delete it and you will be left with a single copy.
art_l_j_PlanetAMD64
OK, when you are in Task Manager, stop the processes in this order by clicking on the name (to highlight the process) and then clicking on the 'End Process' button at the bottom right:fordyce0593 wrote:I checked the task manager. I have :
Fordyce
- each FAHControl process
- each FAHClient process
- each FahCore process
EDIT:
You should do what PantherX said above, he was posting that message as I was typing this message.
art_l_j_PlanetAMD64
Over 3,800,000 PPD
Over 3,800,000 PPD
art_l_j_PlanetAMD64
Yes, this sounds similar to what was described here. There appears to be something that a user is doing that causes two instances of FAHClient to be started.PantherX wrote:What you described in the Task Manager would suggest that you have two instances of FAHClient running and that is what is causing the issues.
art_l_j_PlanetAMD64
Over 3,800,000 PPD
Over 3,800,000 PPD
fordyce0593
I have opted for the harsh method. I killed in the task manager the task who seemed to me stucked.
Then I made a reboot, this cleaned everything, I have now only two processes only running.
1 Fah control
1 Fah client
1 Fahcore_11
1 Fahcore_a3
2 Fahcore wrapper
I think this is correct. Everything is running smoothly since two hours.
Thanks to you all, you are really efficient.
1 Fah control
1 Fah client
1 Fahcore_11
1 Fahcore_a3
2 Fahcore wrapper
