Project 10720 run 0 clone7543 gen 12 running extremely slow
Ed_B
Post by Ed_B »
Hello All:
For some reason project 10720 run 0 clone 7543 gen 12 is running extremely slow, taking 25 minutes to fold each percent. Is this normal or is it a bad WU? I have a fast computer that usually runs WU's 10 times faster than this one.
Thanks Ed
bollix47
Re: Project 10720 run 0 clone7543 gen 12 running extreamly s
Post by bollix47 »
Some projects have considerably longer TPFs than other projects. P10720 appears to be one of those projects. I looked up a previous generation of this project and the donor took 11 days to finish it successfully. Without knowing their machine specs and their folding habits it's difficult to say if that was 'normal' but having long time frames does not necessarily suggest it is a bad WU. If other work units in the same project were experiencing significantly shorter time frames then it might suggest it's bad but that doesn't appear to be the situation in this case.
Re: Project 10720 run 0 clone7543 gen 12 running extremely s
As a rough estimate of TPF when comparing two different projects, look both of them up on the Projet Summary and compare the "credit." Project 10720 is worth 984.00 baseline points. Look up whatever projects you're mentally comparing it to and I'll bet they earn significantly fewer points for a single WU.
Ed_B
Post by Ed_B »
OK Guys thanks for the info my folding rig has a six core exreme intel CPU running at over 4 Ghz and I'm not used to seeing slow WU's. Whats even more troubling is that core Temp shows no more than 51% on any one core and some of the cores show 0%, of course the numbers jump around constantly, but it seems that all six cores would only add up to 100% load at any time that I'm watching it. And that is really weird, usually all six cores are running between 75 and 100%, so it desn't seem right to me.
Ed
bollix47
Post by bollix47 »
That additional piece of the puzzle concerning CPU usage is interesting.
Please supply the log including all three sections.
For the actual working part of the log please copy and paste from the download of the WU up to and including the first 10 percentages of work.
Ed_B
Post by Ed_B »
OK here's part of my log, the WU I'm working on now and the previous WU.
Ed
                       Folding@Home Client Version 6.34
                          http://folding.stanford.edu
Launch directory: C:\FAHsmp
Executable: C:\FAHsmp\FAH6.34-win32-SMP.exe
[03:06:19] - Ask before connecting: No
[03:06:19] - User name: Ed_B (Team 40051)
[03:06:19] - User ID: 402936B97A0FA35C
[03:06:19] - Machine ID: 1
[03:06:19]
[03:06:20] Loaded queue successfully.
[03:06:20]
[03:06:20] + Processing work unit
[03:06:20] Core required: FahCore_a4.exe
[03:06:20] Core found.
[03:06:20] Working on queue slot 02 [December 19 03:06:20 UTC]
[03:06:20] + Working ...
[03:06:20]
[03:06:20] *------------------------------*
[03:06:20] Folding@Home Gromacs GB Core
[03:06:20] Version 2.27 (Dec. 15, 2010)
[03:06:20]
[03:06:20] Preparing to commence simulation
[03:06:20] - Looking at optimizations...
[03:06:20] - Files status OK
[03:06:21] - Expanded 528700 -> 1216376 (decompressed 230.0 percent)
[03:06:21] Called DecompressByteArray: compressed_data_size=528700 data_size=1216376, decompressed_data_size=1216376 diff=0
[03:06:21] - Digital signature verified
[03:06:21]
[03:06:21] Project: 8027 (Run 2189, Clone 3, Gen 23)
[03:06:21]
[03:06:21] Assembly optimizations on if available.
[03:06:21] Entering M.D.
[03:06:27] Using Gromacs checkpoints
[03:06:27] Mapping NT from 1 to 1
[03:06:27] Resuming from checkpoint
[03:06:27] Verified work/wudata_02.log
[03:06:27] Verified work/wudata_02.trr
[03:06:27] Verified work/wudata_02.xtc
[03:06:27] Verified work/wudata_02.edr
[03:06:27] Completed 213600 out of 500000 steps  (42%)
[03:08:09] Completed 215000 out of 500000 steps  (43%)
[03:14:12] Completed 220000 out of 500000 steps  (44%)
[03:20:16] Completed 225000 out of 500000 steps  (45%)
[03:26:19] Completed 230000 out of 500000 steps  (46%)
[03:32:22] Completed 235000 out of 500000 steps  (47%)
[03:38:25] Completed 240000 out of 500000 steps  (48%)
[03:44:30] Completed 245000 out of 500000 steps  (49%)
[03:50:35] Completed 250000 out of 500000 steps  (50%)
[03:56:39] Completed 255000 out of 500000 steps  (51%)
[04:02:44] Completed 260000 out of 500000 steps  (52%)
[04:08:48] Completed 265000 out of 500000 steps  (53%)
[04:14:51] Completed 270000 out of 500000 steps  (54%)
[04:20:55] Completed 275000 out of 500000 steps  (55%)
[04:26:59] Completed 280000 out of 500000 steps  (56%)
[04:33:05] Completed 285000 out of 500000 steps  (57%)
[04:39:09] Completed 290000 out of 500000 steps  (58%)
[04:45:13] Completed 295000 out of 500000 steps  (59%)
[04:51:18] Completed 300000 out of 500000 steps  (60%)
[04:57:22] Completed 305000 out of 500000 steps  (61%)
[05:03:25] Completed 310000 out of 500000 steps  (62%)
[05:09:30] Completed 315000 out of 500000 steps  (63%)
[05:15:33] Completed 320000 out of 500000 steps  (64%)
[05:21:37] Completed 325000 out of 500000 steps  (65%)
[05:27:39] Completed 330000 out of 500000 steps  (66%)
[05:33:43] Completed 335000 out of 500000 steps  (67%)
[05:39:46] Completed 340000 out of 500000 steps  (68%)
[05:45:48] Completed 345000 out of 500000 steps  (69%)
[05:51:51] Completed 350000 out of 500000 steps  (70%)
[05:57:55] Completed 355000 out of 500000 steps  (71%)
[06:03:59] Completed 360000 out of 500000 steps  (72%)
[06:10:02] Completed 365000 out of 500000 steps  (73%)
[06:16:06] Completed 370000 out of 500000 steps  (74%)
[06:22:11] Completed 375000 out of 500000 steps  (75%)
[06:28:13] Completed 380000 out of 500000 steps  (76%)
[06:34:16] Completed 385000 out of 500000 steps  (77%)
[06:40:18] Completed 390000 out of 500000 steps  (78%)
[06:46:23] Completed 395000 out of 500000 steps  (79%)
[06:52:27] Completed 400000 out of 500000 steps  (80%)
[06:58:32] Completed 405000 out of 500000 steps  (81%)
[07:04:36] Completed 410000 out of 500000 steps  (82%)
[07:10:41] Completed 415000 out of 500000 steps  (83%)
[07:16:44] Completed 420000 out of 500000 steps  (84%)
[07:22:49] Completed 425000 out of 500000 steps  (85%)
[07:28:53] Completed 430000 out of 500000 steps  (86%)
[07:34:57] Completed 435000 out of 500000 steps  (87%)
[07:41:02] Completed 440000 out of 500000 steps  (88%)
[07:47:07] Completed 445000 out of 500000 steps  (89%)
[07:53:12] Completed 450000 out of 500000 steps  (90%)
[07:59:18] Completed 455000 out of 500000 steps  (91%)
[08:05:23] Completed 460000 out of 500000 steps  (92%)
[08:11:28] Completed 465000 out of 500000 steps  (93%)
[08:17:32] Completed 470000 out of 500000 steps  (94%)
[08:23:37] Completed 475000 out of 500000 steps  (95%)
[08:29:41] Completed 480000 out of 500000 steps  (96%)
[08:35:45] Completed 485000 out of 500000 steps  (97%)
[08:41:49] Completed 490000 out of 500000 steps  (98%)
[08:47:53] Completed 495000 out of 500000 steps  (99%)
[08:53:57] Completed 500000 out of 500000 steps  (100%)
[08:53:57] DynamicWrapper: Finished Work Unit: sleep=10000
[08:54:07]
[08:54:07] Finished Work Unit:
[08:54:07] - Reading up to 771072 from "work/wudata_02.trr": Read 771072
[08:54:07] trr file hash check passed.
[08:54:07] - Reading up to 836636 from "work/wudata_02.xtc": Read 836636
[08:54:07] xtc file hash check passed.
[08:54:07] edr file hash check passed.
[08:54:07] logfile size: 26763
[08:54:07] Leaving Run
[08:54:10] - Writing 1643295 bytes of core data to disk...
[08:54:10] Done: 1642783 -> 1579771 (compressed to 96.1 percent)
[08:54:10]   ... Done.
[08:54:11] - Shutting down core
[08:54:11]
[08:54:11] Folding@home Core Shutdown: FINISHED_UNIT
[08:54:13] CoreStatus = 64 (100)
[08:54:13] Sending work to server
[08:54:13] Project: 8027 (Run 2189, Clone 3, Gen 23)
[08:54:13] - Read packet limit of 540015616... Set to 524286976.
[08:54:13] + Attempting to send results [December 19 08:54:13 UTC]
[08:54:34] - Couldn't send HTTP request to server
[08:54:34] + Could not connect to Work Server (results)
[08:54:34]     (171.67.108.34:8080)
[08:54:34] + Retrying using alternative port
[08:54:55] - Couldn't send HTTP request to server
[08:54:55] + Could not connect to Work Server (results)
[08:54:55]     (171.67.108.34:80)
[08:54:55] - Error: Could not transmit unit 02 (completed December 19) to work server.
[08:54:55]   Keeping unit 02 in queue.
[08:54:55] Project: 8027 (Run 2189, Clone 3, Gen 23)
[08:54:55] - Read packet limit of 540015616... Set to 524286976.
[08:54:55] + Attempting to send results [December 19 08:54:55 UTC]
[08:55:16] - Couldn't send HTTP request to server
[08:55:16] + Could not connect to Work Server (results)
[08:55:16]     (171.67.108.34:8080)
[08:55:16] + Retrying using alternative port
[08:55:37] - Couldn't send HTTP request to server
[08:55:37] + Could not connect to Work Server (results)
[08:55:37]     (171.67.108.34:80)
[08:55:37] - Error: Could not transmit unit 02 (completed December 19) to work server.
[08:55:37] - Read packet limit of 540015616... Set to 524286976.
[08:55:37] + Attempting to send results [December 19 08:55:37 UTC]
[08:56:58] + Results successfully sent
[08:56:58] Thank you for your contribution to Folding@Home.
[08:56:58] + Number of Units Completed: 2
[08:57:00]   Successfully sent unit 02 to Collection server.
[08:57:00] - Preparing to get new work unit...
[08:57:00] Cleaning up work directory
[08:57:00] + Attempting to get work packet
[08:57:00] Passkey found
[08:57:00] - Connecting to assignment server
[08:57:00] - Successful: assigned to (171.67.108.42).
[08:57:00] + News From Folding@Home: Welcome to Folding@Home
[08:57:00] Loaded queue successfully.
[08:57:02] + Closed connections
[08:57:02]
[08:57:02] + Processing work unit
[08:57:02] Core required: FahCore_a4.exe
[08:57:02] Core found.
[08:57:02] Working on queue slot 03 [December 19 08:57:02 UTC]
[08:57:02] + Working ...
[08:57:02]
[08:57:02] *------------------------------*
[08:57:02] Folding@Home Gromacs GB Core
[08:57:02] Version 2.27 (Dec. 15, 2010)
[08:57:02]
[08:57:02] Preparing to commence simulation
[08:57:02] - Looking at optimizations...
[08:57:02] - Created dyn
[08:57:02] - Files status OK
[08:57:02] - Expanded 128594 -> 179848 (decompressed 139.8 percent)
[08:57:02] Called DecompressByteArray: compressed_data_size=128594 data_size=179848, decompressed_data_size=179848 diff=0
[08:57:02] - Digital signature verified
[08:57:02]
[08:57:02] Project: 10720 (Run 0, Clone 7543, Gen 12)
[08:57:02]
[08:57:02] Assembly optimizations on if available.
[08:57:02] Entering M.D.
[08:57:08] Mapping NT from 1 to 1
[08:57:09] Completed 0 out of 7000000 steps  (0%)
[09:22:38] Completed 70000 out of 7000000 steps  (1%)
[09:48:07] Completed 140000 out of 7000000 steps  (2%)
[10:12:29] Completed 210000 out of 7000000 steps  (3%)
[10:37:56] Completed 280000 out of 7000000 steps  (4%)
Folding@Home Client Shutdown.
--- Opening Log file [December 20 05:49:51 UTC]
[05:49:51] - Ask before connecting: No
[05:49:51] - User name: Ed_B (Team 40051)
[05:49:51] - User ID: 402936B97A0FA35C
[05:49:51] - Machine ID: 1
[05:49:51]
[05:49:51] Loaded queue successfully.
[05:49:51]
[05:49:51] + Processing work unit
[05:49:51] Core required: FahCore_a4.exe
[05:49:51] Core found.
[05:49:51] Working on queue slot 03 [December 20 05:49:51 UTC]
[05:49:51] + Working ...
[05:49:51]
[05:49:51] *------------------------------*
[05:49:51] Folding@Home Gromacs GB Core
[05:49:51] Version 2.27 (Dec. 15, 2010)
[05:49:51]
[05:49:51] Preparing to commence simulation
[05:49:51] - Looking at optimizations...
[05:49:51] - Files status OK
[05:49:52] - Expanded 128594 -> 179848 (decompressed 139.8 percent)
[05:49:52] Called DecompressByteArray: compressed_data_size=128594 data_size=179848, decompressed_data_size=179848 diff=0
[05:49:52] - Digital signature verified
[05:49:52]
[05:49:52] Project: 10720 (Run 0, Clone 7543, Gen 12)
[05:49:52]
[05:49:52] Assembly optimizations on if available.
[05:49:52] Entering M.D.
[05:49:58] Using Gromacs checkpoints
[05:49:58] Mapping NT from 1 to 1
[05:49:58] Resuming from checkpoint
[05:49:58] Verified work/wudata_03.log
[05:49:58] Verified work/wudata_03.trr
[05:49:58] Verified work/wudata_03.xtc
[05:49:58] Verified work/wudata_03.edr
[05:49:58] Completed 312622 out of 7000000 steps  (4%)
[06:03:34] Completed 350000 out of 7000000 steps  (5%)
[06:29:00] Completed 420000 out of 7000000 steps  (6%)
[06:54:28] Completed 490000 out of 7000000 steps  (7%)
[07:20:00] Completed 560000 out of 7000000 steps  (8%)
[07:45:29] Completed 630000 out of 7000000 steps  (9%)
[08:10:59] Completed 700000 out of 7000000 steps  (10%)
[08:36:27] Completed 770000 out of 7000000 steps  (11%)
[09:01:55] Completed 840000 out of 7000000 steps  (12%)
[09:26:33] Completed 910000 out of 7000000 steps  (13%)
[09:52:02] Completed 980000 out of 7000000 steps  (14%)
[10:17:34] Completed 1050000 out of 7000000 steps  (15%)
[10:43:09] Completed 1120000 out of 7000000 steps  (16%)
--- Opening Log file [December 20 11:05:43 UTC]
[11:05:43] - Ask before connecting: No
[11:05:43] - User name: Ed_B (Team 40051)
[11:05:43] - User ID: 402936B97A0FA35C
[11:05:43] - Machine ID: 1
[11:05:43]
[11:05:43] Loaded queue successfully.
[11:05:43]
[11:05:43] + Processing work unit
[11:05:43] Core required: FahCore_a4.exe
[11:05:43] Core found.
[11:05:43] Working on queue slot 03 [December 20 11:05:43 UTC]
[11:05:43] + Working ...
[11:05:43]
[11:05:43] *------------------------------*
[11:05:43] Folding@Home Gromacs GB Core
[11:05:43] Version 2.27 (Dec. 15, 2010)
[11:05:43]
[11:05:43] Preparing to commence simulation
[11:05:43] - Looking at optimizations...
[11:05:43] - Files status OK
[11:05:43] - Expanded 128594 -> 179848 (decompressed 139.8 percent)
[11:05:43] Called DecompressByteArray: compressed_data_size=128594 data_size=179848, decompressed_data_size=179848 diff=0
[11:05:43] - Digital signature verified
[11:05:43]
[11:05:43] Project: 10720 (Run 0, Clone 7543, Gen 12)
[11:05:43]
[11:05:43] Assembly optimizations on if available.
[11:05:43] Entering M.D.
[11:05:49] Using Gromacs checkpoints
[11:05:49] Mapping NT from 1 to 1
[11:05:49] Resuming from checkpoint
[11:05:49] Verified work/wudata_03.log
[11:05:49] Verified work/wudata_03.trr
[11:05:49] Verified work/wudata_03.xtc
[11:05:49] Verified work/wudata_03.edr
[11:05:50] Completed 1177062 out of 7000000 steps  (16%)
--- Opening Log file [December 21 03:12:17 UTC]
[03:12:17] - Ask before connecting: No
[03:12:17] - User name: Ed_B (Team 40051)
[03:12:17] - User ID: 402936B97A0FA35C
[03:12:17] - Machine ID: 1
[03:12:17]
[03:12:17] Loaded queue successfully.
[03:12:17]
[03:12:17] + Processing work unit
[03:12:17] Core required: FahCore_a4.exe
[03:12:17] Core found.
[03:12:17] Working on queue slot 03 [December 21 03:12:17 UTC]
[03:12:17] + Working ...
[03:12:17]
[03:12:17] *------------------------------*
[03:12:17] Folding@Home Gromacs GB Core
[03:12:17] Version 2.27 (Dec. 15, 2010)
[03:12:17]
[03:12:17] Preparing to commence simulation
[03:12:17] - Looking at optimizations...
[03:12:17] - Files status OK
[03:12:17] - Expanded 128594 -> 179848 (decompressed 139.8 percent)
[03:12:17] Called DecompressByteArray: compressed_data_size=128594 data_size=179848, decompressed_data_size=179848 diff=0
[03:12:17] - Digital signature verified
[03:12:17]
[03:12:17] Project: 10720 (Run 0, Clone 7543, Gen 12)
[03:12:17]
[03:12:17] Assembly optimizations on if available.
[03:12:17] Entering M.D.
[03:12:23] Using Gromacs checkpoints
[03:12:23] Mapping NT from 1 to 1
[03:12:23] Resuming from checkpoint
[03:12:23] Verified work/wudata_03.log
[03:12:23] Verified work/wudata_03.trr
[03:12:23] Verified work/wudata_03.xtc
[03:12:23] Verified work/wudata_03.edr
[03:12:24] Completed 1181592 out of 7000000 steps  (16%)
[03:15:28] Completed 1190000 out of 7000000 steps  (17%)
[03:40:59] Completed 1260000 out of 7000000 steps  (18%)
[04:06:30] Completed 1330000 out of 7000000 steps  (19%)
[04:32:03] Completed 1400000 out of 7000000 steps  (20%)
[04:57:32] Completed 1470000 out of 7000000 steps  (21%)
[05:23:00] Completed 1540000 out of 7000000 steps  (22%)
[05:48:34] Completed 1610000 out of 7000000 steps  (23%)
[06:14:02] Completed 1680000 out of 7000000 steps  (24%)
[06:39:28] Completed 1750000 out of 7000000 steps  (25%)
[07:04:55] Completed 1820000 out of 7000000 steps  (26%)
[07:30:23] Completed 1890000 out of 7000000 steps  (27%)
[07:55:50] Completed 1960000 out of 7000000 steps  (28%)
[08:21:19] Completed 2030000 out of 7000000 steps  (29%)
[08:46:48] Completed 2100000 out of 7000000 steps  (30%)
[09:12:18] Completed 2170000 out of 7000000 steps  (31%)
bollix47
Post by bollix47 »
Okay, didn't realize you were using v6. Sorry for the misleading instructions.
You're running it in uniprocessor mode rather than SMP. You need to stop the current run and add -smp to your startup line.
bollix47
Post by bollix47 »
Ed,
Were you able to add the -smp option to your commandline? Please let us know if you got the desired results.
Also, you may want to consider switching to v7.2.9 after finishing the current WU(s) on v6 using the -oneunit option or the Finish when done option if you're not using the console version. There are many features of v7 that are an improvement over v6 including a separate SMP check box that automatically defaults to using all your computer's cores but does give you the opportunity to use less if you need to set aside a core or two for other functions. I find v7's ability to monitor and modify both my local computer and the other computers on my network especially handy and even if you're only using one computer with a couple of slots (e.g. SMP and GPU) it's so much easier to cleanly pause one because you need the resources for some other task or both for those software updates that require a reboot. Switching is of course not mandatory but I could not go back to v6 now that I've used v7 for a few months and v7 does appear to be the future for folding.
Ed_B
Post by Ed_B »
Hello Bollix47:
Yes I did add the line and everything is perking right alon at less than 3 ninutes per percent. I only Fold during the winter because it's just too hot here in Lake Havasu City, Arizona in the summer, 110-120 June trough September, I can't afford the a/c. I downloaded a new FAH Client and I don't know if it's the best one for me? My old one didn't want to run, so I nuked it and found this one, the website has changed since last spring and I had trouble finding the download page. Thank you for the help, I was pretty sure that something wasn't right, when it was going so slow.
Thanks again Ed
