I have a problem with my GPU, just installed the client at this PC. (Windows 7)
Here's my log of Slot 00 (=GPU)
*********************** Log Started 2012-11-30T12:01:25Z ***********************
12:01:26:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
12:01:28:WU00:FS00:News: Welcome to Folding@Home
12:01:28:WU00:FS00:Assigned to work server 171.67.108.44
12:01:28:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"BeaverCreek [Radeon HD 6410D]" from 171.67.108.44
12:01:28:WU00:FS00:Connecting to 171.67.108.44:8080
12:01:29:WU00:FS00:Downloading 44.71KiB
12:01:30:WU00:FS00:Download complete
12:01:30:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11293 run:0 clone:6 gen:41 core:0x16 unit:0x0000003d6652edbc4d6438ebee3e987b
12:01:30:WU00:FS00:Starting
12:01:30:WU00:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:/Users/Buero/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 702 -lifeline 3160 -checkpoint 15 -gpu 0
12:01:30:WU00:FS00:Started FahCore on PID 2132
12:01:30:WU00:FS00:Core PID:2264
12:01:30:WU00:FS00:FahCore 0x16 started
12:01:30:WU00:FS00:0x16:
12:01:30:WU00:FS00:0x16:*------------------------------*
12:01:30:WU00:FS00:0x16:Folding@Home GPU Core
12:01:30:WU00:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
12:01:30:WU00:FS00:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
12:01:30:WU00:FS00:0x16:Build host: user-f6d030f24f
12:01:30:WU00:FS00:0x16:Board Type: AMD/OpenCL
12:01:30:WU00:FS00:0x16:Core : x=16
12:01:30:WU00:FS00:0x16: Window's signal control handler registered.
12:01:30:WU00:FS00:0x16:Preparing to commence simulation
12:01:30:WU00:FS00:0x16:- Looking at optimizations...
12:01:30:WU00:FS00:0x16:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
12:01:30:WU00:FS00:0x16:- Created dyn
12:01:30:WU00:FS00:0x16:- Files status OK
12:01:30:WU00:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
12:01:30:WU00:FS00:0x16:- Expanded 45267 -> 171163 (decompressed 378.1 percent)
12:01:30:WU00:FS00:0x16:Called DecompressByteArray: compressed_data_size=45267 data_size=171163, decompressed_data_size=171163 diff=0
12:01:30:WU00:FS00:0x16:- Digital signature verified
12:01:30:WU00:FS00:0x16:Project: 11293 (Run 0, Clone 6, Gen 41)
12:01:30:WU00:FS00:0x16:Assembly optimizations on if available.
12:01:30:WU00:FS00:0x16:Entering M.D.
12:01:32:WU00:FS00:0x16:Tpr hash 00/wudata_01.tpr: 2542687709 2810328026 874916535 1604467891 2213165428
12:01:32:WU00:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
12:01:32:WU00:FS00:0x16:Client config unavailable.
12:01:32:WU00:FS00:0x16:Finished fah_main
12:01:32:WU00:FS00:0x16:Successful run
12:01:32:WU00:FS00:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
12:01:32:WU00:FS00:0x16:Starting GUI Server
12:01:42:WU00:FS00:0x16:Reserved 0 bytes for xtc file; Cosm status=0
12:01:42:WU00:FS00:0x16:Reserved 0 0 786430464 bytes for arc file=<00/wudata_01.trr> Cosm status=0
12:01:42:WU00:FS00:0x16:Allocated 0 bytes for edr file
12:01:42:WU00:FS00:0x16:Error: could not open bedfile, but going on anyway
12:01:42:WU00:FS00:0x16:- Checksum of file (00/wudata_01.edr) read from disk doesn't match
12:01:42:WU00:FS00:0x16:edrfile file hash check failed.
12:01:42:WU00:FS00:0x16:Folding@home Core Shutdown: FILE_IO_ERROR
12:01:43:WARNING:WU00:FS00:FahCore returned: FILE_IO_ERROR (117 = 0x75)
12:01:43:WARNING:WU00:FS00:Fatal error, dumping
12:01:43:WU00:FS00:Sending unit results: id:00 state:SEND error:DUMPED project:11293 run:0 clone:6 gen:41 core:0x16 unit:0x0000003d6652edbc4d6438ebee3e987b
12:01:43:WU00:FS00:Connecting to 171.67.108.44:8080
12:01:43:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
12:01:43:WU00:FS00:Server responded WORK_ACK (400)
12:01:43:WU00:FS00:Cleaning up
12:01:44:WU02:FS00:News: Welcome to Folding@Home
12:01:44:WU02:FS00:Assigned to work server 171.67.108.44
12:01:44:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"BeaverCreek [Radeon HD 6410D]" from 171.67.108.44
12:01:44:WU02:FS00:Connecting to 171.67.108.44:8080
12:01:45:WU02:FS00:Downloading 44.39KiB
12:01:46:WU02:FS00:Download complete
12:01:46:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11293 run:22 clone:7 gen:41 core:0x16 unit:0x0000011d6652edbc4d94b945b59e6ebd
12:01:46:WU02:FS00:Starting
12:01:46:WU02:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:/Users/Buero/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 702 -lifeline 3160 -checkpoint 15 -gpu 0
12:01:46:WU02:FS00:Started FahCore on PID 2872
12:01:46:WU02:FS00:Core PID:2124
12:01:46:WU02:FS00:FahCore 0x16 started
12:01:46:WU02:FS00:0x16:
12:01:46:WU02:FS00:0x16:*------------------------------*
12:01:46:WU02:FS00:0x16:Folding@Home GPU Core
12:01:46:WU02:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
12:01:46:WU02:FS00:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
12:01:46:WU02:FS00:0x16:Build host: user-f6d030f24f
12:01:46:WU02:FS00:0x16:Board Type: AMD/OpenCL
12:01:46:WU02:FS00:0x16:Core : x=16
12:01:46:WU02:FS00:0x16: Window's signal control handler registered.
12:01:46:WU02:FS00:0x16:Preparing to commence simulation
12:01:46:WU02:FS00:0x16:- Looking at optimizations...
12:01:46:WU02:FS00:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
12:01:46:WU02:FS00:0x16:- Created dyn
12:01:46:WU02:FS00:0x16:- Files status OK
12:01:46:WU02:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
12:01:46:WU02:FS00:0x16:- Expanded 44940 -> 171163 (decompressed 380.8 percent)
12:01:46:WU02:FS00:0x16:Called DecompressByteArray: compressed_data_size=44940 data_size=171163, decompressed_data_size=171163 diff=0
12:01:46:WU02:FS00:0x16:- Digital signature verified
12:01:46:WU02:FS00:0x16:Project: 11293 (Run 22, Clone 7, Gen 41)
12:01:46:WU02:FS00:0x16:Assembly optimizations on if available.
12:01:46:WU02:FS00:0x16:Entering M.D.
12:01:48:WU02:FS00:0x16:Tpr hash 02/wudata_01.tpr: 2338517030 1792837351 545898268 1244695940 1458112946
12:01:48:WU02:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
12:01:48:WU02:FS00:0x16:Client config unavailable.
12:01:48:WU02:FS00:0x16:Finished fah_main
12:01:48:WU02:FS00:0x16:Successful run
12:01:48:WU02:FS00:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
12:01:48:WU02:FS00:0x16:Starting GUI Server
12:01:58:WU02:FS00:0x16:Reserved 0 bytes for xtc file; Cosm status=0
12:01:58:WU02:FS00:0x16:Reserved 0 0 786430464 bytes for arc file=<02/wudata_01.trr> Cosm status=0
12:01:58:WU02:FS00:0x16:Allocated 0 bytes for edr file
12:01:58:WU02:FS00:0x16:Error: could not open bedfile, but going on anyway
12:01:58:WU02:FS00:0x16:- Checksum of file (02/wudata_01.edr) read from disk doesn't match
12:01:58:WU02:FS00:0x16:edrfile file hash check failed.
12:01:58:WU02:FS00:0x16:Folding@home Core Shutdown: FILE_IO_ERROR
12:01:58:WARNING:WU02:FS00:FahCore returned: FILE_IO_ERROR (117 = 0x75)
12:01:58:WARNING:WU02:FS00:Fatal error, dumping
12:01:58:WU02:FS00:Sending unit results: id:02 state:SEND error:DUMPED project:11293 run:22 clone:7 gen:41 core:0x16 unit:0x0000011d6652edbc4d94b945b59e6ebd
12:01:58:WU02:FS00:Connecting to 171.67.108.44:8080
12:01:59:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
12:01:59:WU02:FS00:Server responded WORK_ACK (400)
12:01:59:WU02:FS00:Cleaning up
12:01:59:WU00:FS00:News: Welcome to Folding@Home
12:01:59:WU00:FS00:Assigned to work server 171.67.108.44
12:01:59:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"BeaverCreek [Radeon HD 6410D]" from 171.67.108.44
12:01:59:WU00:FS00:Connecting to 171.67.108.44:8080
12:02:00:WU00:FS00:Downloading 44.54KiB
12:02:01:WU00:FS00:Download complete
12:02:01:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11293 run:25 clone:7 gen:41 core:0x16 unit:0x0000003b6652edbc4d94b9eec8d6622c
12:02:01:WU00:FS00:Starting
12:02:01:WU00:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:/Users/Buero/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 702 -lifeline 3160 -checkpoint 15 -gpu 0
12:02:01:WU00:FS00:Started FahCore on PID 2344
12:02:01:WU00:FS00:Core PID:324
12:02:01:WU00:FS00:FahCore 0x16 started
12:02:02:WU00:FS00:0x16:
12:02:02:WU00:FS00:0x16:*------------------------------*
12:02:02:WU00:FS00:0x16:Folding@Home GPU Core
12:02:02:WU00:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
12:02:02:WU00:FS00:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
12:02:02:WU00:FS00:0x16:Build host: user-f6d030f24f
12:02:02:WU00:FS00:0x16:Board Type: AMD/OpenCL
12:02:02:WU00:FS00:0x16:Core : x=16
12:02:02:WU00:FS00:0x16: Window's signal control handler registered.
12:02:02:WU00:FS00:0x16:Preparing to commence simulation
12:02:02:WU00:FS00:0x16:- Looking at optimizations...
12:02:02:WU00:FS00:0x16:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
12:02:02:WU00:FS00:0x16:- Created dyn
12:02:02:WU00:FS00:0x16:- Files status OK
12:02:02:WU00:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
12:02:02:WU00:FS00:0x16:- Expanded 45093 -> 171163 (decompressed 379.5 percent)
12:02:02:WU00:FS00:0x16:Called DecompressByteArray: compressed_data_size=45093 data_size=171163, decompressed_data_size=171163 diff=0
12:02:02:WU00:FS00:0x16:- Digital signature verified
12:02:02:WU00:FS00:0x16:Project: 11293 (Run 25, Clone 7, Gen 41)
12:02:02:WU00:FS00:0x16:Assembly optimizations on if available.
12:02:02:WU00:FS00:0x16:Entering M.D.
12:02:04:WU00:FS00:0x16:Tpr hash 00/wudata_01.tpr: 551476110 2287939378 2917438915 2019512069 2810206525
12:02:04:WU00:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
12:02:04:WU00:FS00:0x16:Client config unavailable.
12:02:04:WU00:FS00:0x16:Finished fah_main
12:02:04:WU00:FS00:0x16:Successful run
12:02:04:WU00:FS00:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
12:02:04:WU00:FS00:0x16:Starting GUI Server
12:02:13:WU00:FS00:0x16:Reserved 0 bytes for xtc file; Cosm status=0
12:02:13:WU00:FS00:0x16:Reserved 0 0 786430464 bytes for arc file=<00/wudata_01.trr> Cosm status=0
12:02:13:WU00:FS00:0x16:Allocated 0 bytes for edr file
12:02:13:WU00:FS00:0x16:Error: could not open bedfile, but going on anyway
12:02:13:WU00:FS00:0x16:- Checksum of file (00/wudata_01.edr) read from disk doesn't match
12:02:13:WU00:FS00:0x16:edrfile file hash check failed.
12:02:13:WU00:FS00:0x16:Folding@home Core Shutdown: FILE_IO_ERROR
12:02:14:WARNING:WU00:FS00:FahCore returned: FILE_IO_ERROR (117 = 0x75)
12:02:14:WARNING:WU00:FS00:Fatal error, dumping
12:02:14:WU00:FS00:Sending unit results: id:00 state:SEND error:DUMPED project:11293 run:25 clone:7 gen:41 core:0x16 unit:0x0000003b6652edbc4d94b9eec8d6622c
12:02:14:WU00:FS00:Connecting to 171.67.108.44:8080
12:02:14:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
12:02:14:WU00:FS00:Server responded WORK_ACK (400)
12:02:15:WU00:FS00:Cleaning up
12:02:15:WU02:FS00:News: Welcome to Folding@Home
12:02:15:WU02:FS00:Assigned to work server 171.67.108.44
12:02:15:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"BeaverCreek [Radeon HD 6410D]" from 171.67.108.44
12:02:15:WU02:FS00:Connecting to 171.67.108.44:8080
12:02:16:WU02:FS00:Downloading 44.60KiB
12:02:17:WU02:FS00:Download complete
12:02:17:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11293 run:2 clone:8 gen:41 core:0x16 unit:0x000000406652edbc4d6438f6fa377dc4
12:02:17:WU02:FS00:Starting
12:02:17:WU02:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:/Users/Buero/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 702 -lifeline 3160 -checkpoint 15 -gpu 0
12:02:17:WU02:FS00:Started FahCore on PID 2112
12:02:17:WU02:FS00:Core PID:3760
12:02:17:WU02:FS00:FahCore 0x16 started
12:02:17:WU02:FS00:0x16:
12:02:17:WU02:FS00:0x16:*------------------------------*
12:02:17:WU02:FS00:0x16:Folding@Home GPU Core
12:02:17:WU02:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
12:02:17:WU02:FS00:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
12:02:17:WU02:FS00:0x16:Build host: user-f6d030f24f
12:02:17:WU02:FS00:0x16:Board Type: AMD/OpenCL
12:02:17:WU02:FS00:0x16:Core : x=16
12:02:17:WU02:FS00:0x16: Window's signal control handler registered.
12:02:17:WU02:FS00:0x16:Preparing to commence simulation
12:02:17:WU02:FS00:0x16:- Looking at optimizations...
12:02:17:WU02:FS00:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
12:02:17:WU02:FS00:0x16:- Created dyn
12:02:17:WU02:FS00:0x16:- Files status OK
12:02:17:WU02:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
12:02:17:WU02:FS00:0x16:- Expanded 45157 -> 171163 (decompressed 379.0 percent)
12:02:17:WU02:FS00:0x16:Called DecompressByteArray: compressed_data_size=45157 data_size=171163, decompressed_data_size=171163 diff=0
12:02:17:WU02:FS00:0x16:- Digital signature verified
12:02:17:WU02:FS00:0x16:Project: 11293 (Run 2, Clone 8, Gen 41)
12:02:17:WU02:FS00:0x16:Assembly optimizations on if available.
12:02:17:WU02:FS00:0x16:Entering M.D.
12:02:19:WU02:FS00:0x16:Tpr hash 02/wudata_01.tpr: 1939959855 4023829952 3922353997 2714099345 1954365506
12:02:19:WU02:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
12:02:19:WU02:FS00:0x16:Client config unavailable.
12:02:19:WU02:FS00:0x16:Finished fah_main
12:02:19:WU02:FS00:0x16:Successful run
12:02:19:WU02:FS00:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
12:02:19:WU02:FS00:0x16:Starting GUI Server
12:02:29:WU02:FS00:0x16:Reserved 0 bytes for xtc file; Cosm status=0
12:02:29:WU02:FS00:0x16:Reserved 0 0 786430464 bytes for arc file=<02/wudata_01.trr> Cosm status=0
12:02:29:WU02:FS00:0x16:Allocated 0 bytes for edr file
12:02:29:WU02:FS00:0x16:Error: could not open bedfile, but going on anyway
12:02:29:WU02:FS00:0x16:- Checksum of file (02/wudata_01.edr) read from disk doesn't match
12:02:29:WU02:FS00:0x16:edrfile file hash check failed.
12:02:29:WU02:FS00:0x16:Folding@home Core Shutdown: FILE_IO_ERROR
12:02:29:WARNING:WU02:FS00:FahCore returned: FILE_IO_ERROR (117 = 0x75)
12:02:29:WARNING:WU02:FS00:Fatal error, dumping
12:02:29:WU02:FS00:Sending unit results: id:02 state:SEND error:DUMPED project:11293 run:2 clone:8 gen:41 core:0x16 unit:0x000000406652edbc4d6438f6fa377dc4
12:02:29:WU02:FS00:Connecting to 171.67.108.44:8080
12:02:30:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
12:02:30:WU02:FS00:Server responded WORK_ACK (400)
12:02:30:WU02:FS00:Cleaning up
12:02:30:WU00:FS00:News: Welcome to Folding@Home
12:02:30:WU00:FS00:Assigned to work server 171.67.108.44
12:02:30:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"BeaverCreek [Radeon HD 6410D]" from 171.67.108.44
12:02:30:WU00:FS00:Connecting to 171.67.108.44:8080
12:02:31:WU00:FS00:Downloading 44.42KiB
12:02:32:WU00:FS00:Download complete
12:02:32:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11293 run:8 clone:8 gen:41 core:0x16 unit:0x0000003a6652edbc4d64391964b57882
12:02:32:WU00:FS00:Starting
12:02:32:WU00:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:/Users/Buero/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 702 -lifeline 3160 -checkpoint 15 -gpu 0
12:02:32:WU00:FS00:Started FahCore on PID 3452
12:02:32:WU00:FS00:Core PID:3680
12:02:32:WU00:FS00:FahCore 0x16 started
12:02:33:WU00:FS00:0x16:
12:02:33:WU00:FS00:0x16:*------------------------------*
12:02:33:WU00:FS00:0x16:Folding@Home GPU Core
12:02:33:WU00:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
12:02:33:WU00:FS00:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
12:02:33:WU00:FS00:0x16:Build host: user-f6d030f24f
12:02:33:WU00:FS00:0x16:Board Type: AMD/OpenCL
12:02:33:WU00:FS00:0x16:Core : x=16
12:02:33:WU00:FS00:0x16: Window's signal control handler registered.
12:02:33:WU00:FS00:0x16:Preparing to commence simulation
12:02:33:WU00:FS00:0x16:- Looking at optimizations...
12:02:33:WU00:FS00:0x16:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
12:02:33:WU00:FS00:0x16:- Created dyn
12:02:33:WU00:FS00:0x16:- Files status OK
12:02:33:WU00:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
12:02:33:WU00:FS00:0x16:- Expanded 44975 -> 171163 (decompressed 380.5 percent)
12:02:33:WU00:FS00:0x16:Called DecompressByteArray: compressed_data_size=44975 data_size=171163, decompressed_data_size=171163 diff=0
12:02:33:WU00:FS00:0x16:- Digital signature verified
12:02:33:WU00:FS00:0x16:Project: 11293 (Run 8, Clone 8, Gen 41)
12:02:33:WU00:FS00:0x16:Assembly optimizations on if available.
12:02:33:WU00:FS00:0x16:Entering M.D.
12:02:34:WU00:FS00:0x16:Tpr hash 00/wudata_01.tpr: 45911232 3775843559 2787945833 2427882407 1278934029
12:02:34:WU00:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
12:02:34:WU00:FS00:0x16:Client config unavailable.
12:02:34:WU00:FS00:0x16:Finished fah_main
12:02:34:WU00:FS00:0x16:Successful run
12:02:34:WU00:FS00:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
12:02:35:WU00:FS00:0x16:Starting GUI Server
12:02:44:WU00:FS00:0x16:Reserved 0 bytes for xtc file; Cosm status=0
12:02:44:WU00:FS00:0x16:Reserved 0 0 786430464 bytes for arc file=<00/wudata_01.trr> Cosm status=0
12:02:44:WU00:FS00:0x16:Allocated 0 bytes for edr file
12:02:44:WU00:FS00:0x16:Error: could not open bedfile, but going on anyway
12:02:44:WU00:FS00:0x16:- Checksum of file (00/wudata_01.edr) read from disk doesn't match
12:02:44:WU00:FS00:0x16:edrfile file hash check failed.
12:02:44:WU00:FS00:0x16:Folding@home Core Shutdown: FILE_IO_ERROR
12:02:45:WARNING:WU00:FS00:FahCore returned: FILE_IO_ERROR (117 = 0x75)
12:02:45:WARNING:WU00:FS00:Fatal error, dumping
12:02:45:WU00:FS00:Sending unit results: id:00 state:SEND error:DUMPED project:11293 run:8 clone:8 gen:41 core:0x16 unit:0x0000003a6652edbc4d64391964b57882
12:02:45:WU00:FS00:Connecting to 171.67.108.44:8080
12:02:45:WU00:FS00:Server responded WORK_ACK (400)
12:02:45:WU00:FS00:Cleaning upFrom the log, I don't understand what's the problem here. Is the file downloaded from the project corrupted? And a 'bedfile' seems to be missing, never heard of such a thing. Anyway, CPU-Folding works fine.
Thanks in advance for any help
