Hey guys,
I have an Intel i5 z77 computer with 16GB DDR3 memory. I have to pause Folding while I use my computer. The computer lags badly while surfing, playing games or just moving the mouse, when folding is active. If this is GPU related, I have a Nvidia Geforce 550ti. I fold all night and pause during the day
Folding slows fast computer down...
P5-133XL
Machine #2:
Machine 3:
Re: Folding slows fast computer down...
Yes it is GPU related. The video subsystem in Windows has never had any tools for resource competition. Until There is some form of priority system for GPU's there will be lag.
Try pausing just the GPU slot (Rt. click on the GPU slot) during the day while allowing the SMP slot to run continuously and see if that helps.
musicmaker650
Where can I find the GPU slot to right-click on?
Thanks for your help
The slots are listed in the middle of FAHControl. You may need to switch from Novice mode to Advanced mode in the upper left hand corner.
The Development team of the Pande Group is aware of the lag that the GPU can introduce. It's not clear if it's something they can fix, but they're going to try.
musicmaker650
Okay Bruce,
I got it, and pausing the GPU slot helps the lagging...
Thanks again
Thanks again
patonb
- Hardware configuration: WooHoo= SR-2 -- L5639 @ ?? -- Evga 560ti FPB -- 12Gig Corsair XMS3 -- Corsair 1050hx -- Blackhawk Ultra
Also, if you haven't tried... Make sure Areo is enabled as the desktop them.
musicmaker650
Aero is enabled
