multiple NVIDIA cards
Hey, I have 2 x Quado FX1800. how do i get them both working on FAH? and does the viewer need to be open for a WU to be processed?
Re: multiple NVIDIA cards
Are FX1800 on the supported hardware list?
No, nothing needs to be open to fold on V7 client.
I doubt Quadros are enlisted in the whitelist. to have a chance for them being enlisted please have a look at viewforum.php?f=83 section
Actually over a hundred Quadro's are already listed in the GPUs.txt file. The older cards are listed as unsupported, but a number of the more recent cards are whitelisted. That includes the FX1800:muziqaz wrote:I doubt Quadros are enlisted in the whitelist. to have a chance for them being enlisted please have a look at viewforum.php?f=83 section
0x10de:0x0638:2:1:G94 [Quadro FX 1800]
Maybe he has an issue with them working together in one system? Are they in one system?
As I am having hard time getting to fold gtx680 and gt430 in the same system even after I set all the parameters right (or I think they are right)
Since the original post is almost 3 months old and the poster has not come back since, your speculation is just that. There are existing topics for your issues, the problem of dealing with two different cards does not apply here as the poster has two of the same card.
my issue is not the issue yet, as I have other unrelated issues
Happy new year
Happy new year
bambihunter
- Hardware configuration: Fractal Design Define R7 XL USB-C Blackout case
Intel i9-9980xe @ 4.6ghz for 24/7 use (water cooled)
128gb GSkill TridentZ DDR4 3866 RAM
4TB Corsair MP600 PRO XT M.2 NVMe PCIe Gen. 4 x4 SSD
Asus WS x299 Sage motherboard
Asus RTX5090 Astral, RTX4090 TUF, EVGA RTX3090 XTC
Corsair AXi1600i 1600 watt digital power supply
Logitech G910 Spark Keyboard
Logitech G502 Hero Mouse
2 x Dell PowerEdge T630 servers
2 x E5-2699a-v4 (each server)
2 x EVGA RTX 2080ti
128gb (each server) - Location: S.E. Kansas, USA
I realize this is an old thread, but in case someone stumbles across it looking for answers to the same question...
I had a Quadro FX1800 and though it shows it has 64 CUDA's, it simply wouldn't ever run on V7. I couldn't get ANY of the AGP versions to work, but I believe they are even older than the G94 based FX1800. I have quite a few Quadro's from various times and the oldest successful one; the Quadro FX3700 folds, but shows unknown on everything BUT, it does complete units properly. Everything newer like the 2000 (192 shaders) and 4000's (256 shaders) fold great. The 2000 though substantially cheaper than the 4000, gets around 9k ppd whereas the 4000 gets around 10.5k ppd. Because these are single-slot, I run EVGA Precision X and set the fans to ramp up on a higher/faster profile than stock. You can OC them some too if desired. Because of the cost of them, and me wanting them to last until they are obsolete, I left mine stock.
Hope that helps with the quadro questions.
Currently folding on V7
1 x Quadro FX3700 (doesn't show PPD, but works)
2 x Quadro 2000
7 x Quadro 4000
(plus countless ones that no longer fold).
2 x Quadro 2000
7 x Quadro 4000
Member since April 2009. Top 100 folder and proud of it.
P5-133XL
Machine #2:
Machine 3:
The problem with not showing any estimated values is an issue with the server and is a known bug: The server code, the client is pulling the WU from, hasn't been upgraded to supply the information back to the client that it needs to display that data. If it runs and successfully returns WU's everything is working normally.
V7 has a white-list of acceptable video cards. It is quite possible that your video cards are not on the list and therefore won't fold in v7. If you are interested in helping update the list, you may want to start with any that will fold in v6. If it won't fold in v6 with the proper flag then it is very unlikely to fold in v7.
If you don't see it in the GPUs.txt, find the VendorID:DeviceID of your GPU. These can be obtained by running gpu-z and looking six lines down for "device ID" or by running fahclient --lspci (with two dashes) or by looking at the device properties in the Windows device manager. Download the latest copy of GPUs.txt and search for those device codes.
