#937 F@H not working since moving to university
JorgyBaby
Post by JorgyBaby »
Hey guys, I just started folding again before moving to uni and everything was going smoothly. I got to uni with 2 WU completed and they were trying to send for days but never sent and expired. I've just re installed the client and now it won't even let me download any work units, so I'm pretty sure the problem is being on a new network at uni as it all worked fine before. My internet is working fine (I'm using it to post this right now) so not too sure what the problem is.
Here is the log:
11:30:51:Enabled folding slot 00: READY gpu:0:"GF100 [GeForce GTX 480]"
11:30:51:Enabled folding slot 01: READY smp:4
11:30:51:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
11:30:51:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
11:30:52:WU01:FS01:Connecting to assign3.stanford.edu:8080
11:30:52:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
11:30:52:WU00:FS00:News: Welcome to Folding@Home
11:30:52:WU00:FS00:Assigned to work server 171.67.108.141
11:30:52:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"GF100 [GeForce GTX 480]" from 171.67.108.141
11:30:52:WU00:FS00:Connecting to 171.67.108.141:8080
11:30:54:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
11:31:34:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10002: Received short response, expected 272 bytes, got 0
11:31:34:WU01:FS01:Connecting to assign4.stanford.edu:80
11:31:34:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
11:31:34:WU01:FS01:News: Welcome to Folding@Home
11:31:34:WU01:FS01:Assigned to work server 171.67.108.60
11:31:34:WU01:FS01:Requesting new work unit for slot 01: READY smp:4 from 171.67.108.60
11:31:34:WU01:FS01:Connecting to 171.67.108.60:8080
11:31:34:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
11:31:35:WU00:FS00:News: Welcome to Folding@Home
11:31:35:WU00:FS00:Assigned to work server 171.67.108.141
11:31:35:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"GF100 [GeForce GTX 480]" from 171.67.108.141
11:31:35:WU00:FS00:Connecting to 171.67.108.141:8080
11:32:16:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
11:32:16:WU01:FS01:Connecting to assign3.stanford.edu:8080
11:32:17:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
11:32:35:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
11:32:35:WU00:FS00:News: Welcome to Folding@Home
11:32:35:WU00:FS00:Assigned to work server 171.67.108.141
11:32:35:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"GF100 [GeForce GTX 480]" from 171.67.108.141
11:32:35:WU00:FS00:Connecting to 171.67.108.141:8080
11:32:58:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10002: Received short response, expected 272 bytes, got 0
11:32:58:WU01:FS01:Connecting to assign4.stanford.edu:80
11:33:00:WU01:FS01:News: Welcome to Folding@Home
11:33:00:WU01:FS01:Assigned to work server 171.67.108.60
11:33:00:WU01:FS01:Requesting new work unit for slot 01: READY smp:4 from 171.67.108.60
11:33:00:WU01:FS01:Connecting to 171.67.108.60:8080
11:33:17:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
11:33:42:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
11:33:42:WU01:FS01:Connecting to assign3.stanford.edu:8080
11:34:12:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
11:34:12:WU00:FS00:News: Welcome to Folding@Home
11:34:12:WU00:FS00:Assigned to work server 171.67.108.141
11:34:12:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"GF100 [GeForce GTX 480]" from 171.67.108.141
11:34:12:WU00:FS00:Connecting to 171.67.108.141:8080
11:34:24:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10002: Received short response, expected 272 bytes, got 0
11:34:24:WU01:FS01:Connecting to assign4.stanford.edu:80
11:34:25:WU01:FS01:News: Welcome to Folding@Home
11:34:25:WU01:FS01:Assigned to work server 171.67.108.60
11:34:25:WU01:FS01:Requesting new work unit for slot 01: READY smp:4 from 171.67.108.60
11:34:25:WU01:FS01:Connecting to 171.67.108.60:8080
11:34:54:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
11:35:07:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
11:35:20:WU01:FS01:Connecting to assign3.stanford.edu:8080
Someone has told me the issue appears to be with the ports but I have absolutely no idea how to solve that.
Thanks and any help would be much appreciated :)
Re: F@H not working since moving to university
Talk to your campus IT persons. They may have a firewall or proxy server in place that you will have adjust your network settings to comply with. They may even have a policy that precludes you using F@H, and violating that would also be a violation of the terms of use for F@H. If they do, you can ask them to change that policy, but that you would have to inquire about that first. Otherwise you may be only able to fold when at home.
Welcome to foldingforum.org, JorgyBaby.
A little more on the "ports" issue: From reading the log you provided, it is certain that your U. has some sort of proxy because they're blocking port 8080. FAH is designed to prefer port 8080 but it does not require it. When it is unable to use port 8080, it reverts to port 80 which is the same port used by your browser so it can pass through the proxy as long as they allow internet connections.
Something strange is happening, however when it tries to use port 8080 again. I need to get some more information before I can give you a clear answer.
JorgyBaby
Post by JorgyBaby »
I'll try talking to the IT guys then and see what they say. Thanks for the welcome :) What other information do you need bruce? I'll try my best to provide whatever it is you need :D
Please post the first couple pages of the log, including your system hardware descriptions and the listing of your configuration. Perhaps you've changed a setting that has disrupted the server's logic. If you did not change things, then there's nothing you can fix ... it's a server problem ... but I don't know yet.
I've split the statements in the log you posted initially into two sections, one for Slot 00 and one for Slot 01. I see a few things that I didn't expect. I need more information from Stanford to explain them. If you did make changes to the default configuration, I suggest you reinstall and show what happens if you accept the default config.xml or explain every change that you've made. (That's why I asked to see the part of the log that shows the changes you've made (but with the passkey masked, which is what I expect to see.)
Slot 00
WU00:FS00:Connecting to 171.67.108.141:8080ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
WU00:FS00:Connecting to 171.67.108.141:8080 < At this point, it should be connecting to 171.67.108.141:80
WU00:FS00:Connecting to assign-GPU.stanford.edu:80 < (Good!)
Slot 01
WU01:FS01:Connecting to assign-GPU.stanford.edu:80 < A smp slot has no reason to connect to assign-GPU.
WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10002: Received short response, expected 272 bytes, got 0 < (not particularly important.)
WU01:FS01:News: Welcome to Folding@Home < (Good!)
WU01:FS01:Connecting to 171.67.108.60:8080 < At this point, it should be connecting to 171.67.108.60:80
JorgyBaby
Post by JorgyBaby »
I didn't change any settings since moving to unviersity from home and I already re-installed it once but that didn't work either. I'm doing a clean windows 7 install today (unrelated) so I'll see what happens after that and post the log :) Thanks for the help
Re: #937 F@H not working since moving to university
Glad to see a ticket opened on this for v6 client feature continuity, as it must be set as a minimum requirement feature for V7. V7 should be as good or better in all things, IMO.
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Post by Jesse_V »
As the title of this thread suggests and as 7im said, here's the related ticket: https://fah-web.stanford.edu/projects/F ... ticket/937
k1wi
Post by k1wi »
Jcoffland's note on that ticket RE: #937:
"To me this is a minor issue. A few extra connection attempts on clients who have outgoing connects to port 8080 blocked by a firewall does not seem like a huge problem. Are there negative results other than a slight delay extra network traffic which I'm missing here?"
I suspect that aside from the ticket issue, the main reason for being unable to send results is probably due to the campus firewall/proxy server, particularly if it's the Microsoft server platform. Squid-based firewalls are generally pretty good about it (when properly configured for the oft-large packets).
PinHead
Hardware configuration: Quad Q9550 2.83 contains the GPU 57xx - running SMP and GPU
Post by PinHead »
Couldn't the failed addresses and failed ports ( whether 80 or 8080 ) just be tested in the web browser from campus. When I tested a few, I just get blank pages, no error pages; the :80 gets stripped and just shows the ip but I think it resolved. Just a thought to take the client out of the equation.
From your browser, port 80 is always stripped off. It's the browser's default port so specifying it is redundant.
FAH uses 8080 as it's default. That works almost everywhere, including from home, but not from the university. FAH should revert to 80 only after 8080 fails. The problem is that V7 does not fully revert to port 80 from the university.
Install V6 and I'll bet it works. (Post the log, either way.)
A fundamental question: The log you posted shows V7 attempting to get a WU for 5 minutes. Please post a log showing 20 minutes.
JorgyBaby
Post by JorgyBaby »
Ok guys, I've just finished reinstalling windows so F@H is a fresh install and it is still not working. I'll leave it ~20 minutes and then post the log as you suggested. Update coming soon, thanks for the help, it is appreciated :)
JorgyBaby
Post by JorgyBaby »
Hey guys so this is the 20 minute log. i also emailed the IT guys asking about the issue
*********************** Log Started 2012-10-05T20:50:55Z ***********************
20:50:55:************************* Folding@home Client *************************
20:50:55:      Website: http://folding.stanford.edu/
20:50:55:    Copyright: (c) 2009-2012 Stanford University
20:50:55:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:50:55:         Args: --lifeline 1652 --command-port=36330
20:50:55:       Config: C:/Users/Jordan/AppData/Roaming/FAHClient/config.xml
20:50:55:******************************** Build ********************************
20:50:55:      Version: 7.1.52
20:50:55:         Date: Mar 20 2012
20:50:55:         Time: 19:37:42
20:50:55:      SVN Rev: 3515
20:50:55:       Branch: fah/trunk/client
20:50:55:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
20:50:55:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
20:50:55:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
20:50:55:     Platform: win32 XP
20:50:55:         Bits: 32
20:50:55:         Mode: Release
20:50:55:******************************* System ********************************
20:50:55:          CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
20:50:55:       CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
20:50:55:         CPUs: 4
20:50:55:       Memory: 7.95GiB
20:50:55:  Free Memory: 6.23GiB
20:50:55:      Threads: WINDOWS_THREADS
20:50:55:   On Battery: false
20:50:55:   UTC offset: 1
20:50:55:          PID: 1216
20:50:55:          CWD: C:/Users/Jordan/AppData/Roaming/FAHClient
20:50:55:           OS: Windows 7 Professional
20:50:55:      OS Arch: AMD64
20:50:55:         GPUs: 1
20:50:55:        GPU 0: FERMI:1 GF100 [GeForce GTX 480]
20:50:55:         CUDA: 2.0
20:50:55:  CUDA Driver: 5000
20:50:55:Win32 Service: false
20:50:55:***********************************************************************
20:50:55:<config>
20:50:55:  <!-- Folding Slot Configuration -->
20:50:55:  <gpu v='true'/>
20:50:55:
20:50:55:  <!-- User Information -->
20:50:55:  <passkey v='********************************'/>
20:50:55:  <team v='37726'/>
20:50:55:  <user v='JorgyBaby'/>
20:50:55:
20:50:55:  <!-- Folding Slots -->
20:50:55:</config>
20:50:55:Trying to access database...
20:50:56:Successfully acquired database lock
20:50:56:Enabled folding slot 00: READY gpu:0:"GF100 [GeForce GTX 480]"
20:50:56:Enabled folding slot 01: READY smp:4
20:50:56:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
20:50:56:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
20:50:57:WU01:FS01:Connecting to assign3.stanford.edu:8080
20:50:58:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
20:50:58:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
20:50:58:WU00:FS00:News: Welcome to Folding@Home
20:50:58:WU00:FS00:Assigned to work server 171.67.108.143
20:50:58:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"GF100 [GeForce GTX 480]" from 171.67.108.143
20:50:58:WU00:FS00:Connecting to 171.67.108.143:8080
20:51:39:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10002: Received short response, expected 272 bytes, got 0
20:51:39:WU01:FS01:Connecting to assign4.stanford.edu:80
20:51:40:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
20:51:40:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
20:51:40:WU01:FS01:News: Welcome to Folding@Home
20:51:40:WU01:FS01:Assigned to work server 171.67.108.60
20:51:40:WU01:FS01:Requesting new work unit for slot 01: READY smp:4 from 171.67.108.60
20:51:40:WU01:FS01:Connecting to 171.67.108.60:8080
20:51:41:WU00:FS00:News: Welcome to Folding@Home
20:51:41:WU00:FS00:Assigned to work server 171.67.108.143
20:51:41:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"GF100 [GeForce GTX 480]" from 171.67.108.143
20:51:41:WU00:FS00:Connecting to 171.67.108.143:8080
20:52:22:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
20:52:22:WU01:FS01:Connecting to assign3.stanford.edu:8080
20:52:23:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
20:52:40:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
20:52:41:WU00:FS00:News: Welcome to Folding@Home
20:52:41:WU00:FS00:Assigned to work server 171.67.108.143
20:52:41:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"GF100 [GeForce GTX 480]" from 171.67.108.143
20:52:41:WU00:FS00:Connecting to 171.67.108.143:8080
20:53:04:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10002: Received short response, expected 272 bytes, got 0
20:53:04:WU01:FS01:Connecting to assign4.stanford.edu:80
20:53:05:WU01:FS01:News: Welcome to Folding@Home
20:53:05:WU01:FS01:Assigned to work server 171.67.108.60
20:53:05:WU01:FS01:Requesting new work unit for slot 01: READY smp:4 from 171.67.108.60
20:53:05:WU01:FS01:Connecting to 171.67.108.60:8080
20:53:23:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
20:53:47:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
20:53:47:WU01:FS01:Connecting to assign3.stanford.edu:8080
20:54:17:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
20:54:18:WU00:FS00:News: Welcome to Folding@Home
20:54:18:WU00:FS00:Assigned to work server 171.67.108.143
20:54:18:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"GF100 [GeForce GTX 480]" from 171.67.108.143
20:54:18:WU00:FS00:Connecting to 171.67.108.143:8080
20:54:29:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10002: Received short response, expected 272 bytes, got 0
20:54:29:WU01:FS01:Connecting to assign4.stanford.edu:80
20:54:30:WU01:FS01:News: Welcome to Folding@Home
20:54:30:WU01:FS01:Assigned to work server 171.67.108.60
20:54:30:WU01:FS01:Requesting new work unit for slot 01: READY smp:4 from 171.67.108.60
20:54:30:WU01:FS01:Connecting to 171.67.108.60:8080
20:55:00:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
20:55:12:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
20:55:24:WU01:FS01:Connecting to assign3.stanford.edu:8080
20:56:06:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10002: Received short response, expected 272 bytes, got 0
20:56:06:WU01:FS01:Connecting to assign4.stanford.edu:80
20:56:07:WU01:FS01:News: Welcome to Folding@Home
20:56:07:WU01:FS01:Assigned to work server 171.67.108.60
20:56:07:WU01:FS01:Requesting new work unit for slot 01: READY smp:4 from 171.67.108.60
20:56:07:WU01:FS01:Connecting to 171.67.108.60:8080
20:56:49:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
20:56:54:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
20:56:55:WU00:FS00:News: Welcome to Folding@Home
20:56:55:WU00:FS00:Assigned to work server 171.67.108.143
20:56:55:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"GF100 [GeForce GTX 480]" from 171.67.108.143
20:56:55:WU00:FS00:Connecting to 171.67.108.143:8080
20:57:37:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
20:58:01:WU01:FS01:Connecting to assign3.stanford.edu:8080
20:58:43:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10002: Received short response, expected 272 bytes, got 0
20:58:43:WU01:FS01:Connecting to assign4.stanford.edu:80
20:58:44:WU01:FS01:News: Welcome to Folding@Home
20:58:44:WU01:FS01:Assigned to work server 171.67.108.60
20:58:44:WU01:FS01:Requesting new work unit for slot 01: READY smp:4 from 171.67.108.60
20:58:44:WU01:FS01:Connecting to 171.67.108.60:8080
20:59:26:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
21:01:09:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
21:01:09:WU00:FS00:News: Welcome to Folding@Home
21:01:09:WU00:FS00:Assigned to work server 171.67.108.143
21:01:09:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"GF100 [GeForce GTX 480]" from 171.67.108.143
21:01:09:WU00:FS00:Connecting to 171.67.108.143:8080
21:01:51:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
21:01:51:WU00:FS00:Cleaning up
21:01:52:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
21:01:52:WU02:FS00:News: Welcome to Folding@Home
21:01:52:WU02:FS00:Assigned to work server 171.67.108.143
21:01:52:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"GF100 [GeForce GTX 480]" from 171.67.108.143
21:01:52:WU02:FS00:Connecting to 171.67.108.143:8080
21:02:16:WU01:FS01:Connecting to assign3.stanford.edu:8080
21:02:34:ERROR:WU02:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
21:02:34:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
21:02:35:WU02:FS00:News: Welcome to Folding@Home
21:02:35:WU02:FS00:Assigned to work server 171.67.108.143
21:02:35:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"GF100 [GeForce GTX 480]" from 171.67.108.143
21:02:35:WU02:FS00:Connecting to 171.67.108.143:8080
21:02:58:WARNING:WU01:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10002: Received short response, expected 272 bytes, got 0
21:02:58:WU01:FS01:Connecting to assign4.stanford.edu:80
21:02:58:WU01:FS01:News: Welcome to Folding@Home
21:02:58:WU01:FS01:Assigned to work server 171.67.108.60
21:02:58:WU01:FS01:Requesting new work unit for slot 01: READY smp:4 from 171.67.108.60
21:02:58:WU01:FS01:Connecting to 171.67.108.60:8080
21:03:17:ERROR:WU02:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
21:03:35:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
21:03:35:WU02:FS00:News: Welcome to Folding@Home
21:03:35:WU02:FS00:Assigned to work server 171.67.108.143
21:03:35:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"GF100 [GeForce GTX 480]" from 171.67.108.143
21:03:35:WU02:FS00:Connecting to 171.67.108.143:8080
21:03:40:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
21:03:40:WU01:FS01:Cleaning up
21:03:40:WU00:FS01:Connecting to assign3.stanford.edu:8080
21:04:17:ERROR:WU02:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
21:04:22:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10002: Received short response, expected 272 bytes, got 0
21:04:23:WU00:FS01:Connecting to assign4.stanford.edu:80
21:04:23:WU00:FS01:News: Welcome to Folding@Home
21:04:23:WU00:FS01:Assigned to work server 171.67.108.60
21:04:23:WU00:FS01:Requesting new work unit for slot 01: READY smp:4 from 171.67.108.60
21:04:23:WU00:FS01:Connecting to 171.67.108.60:8080
21:05:05:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
21:05:05:WU00:FS01:Connecting to assign3.stanford.edu:8080
21:05:12:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
21:05:12:WU02:FS00:News: Welcome to Folding@Home
21:05:12:WU02:FS00:Assigned to work server 171.67.108.143
21:05:12:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"GF100 [GeForce GTX 480]" from 171.67.108.143
21:05:12:WU02:FS00:Connecting to 171.67.108.143:8080
21:05:47:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10002: Received short response, expected 272 bytes, got 0
21:05:47:WU00:FS01:Connecting to assign4.stanford.edu:80
21:05:48:WU00:FS01:News: Welcome to Folding@Home
21:05:48:WU00:FS01:Assigned to work server 171.67.108.60
21:05:48:WU00:FS01:Requesting new work unit for slot 01: READY smp:4 from 171.67.108.60
21:05:48:WU00:FS01:Connecting to 171.67.108.60:8080
21:05:54:ERROR:WU02:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
21:06:30:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
21:06:30:WU00:FS01:Connecting to assign3.stanford.edu:8080
21:07:12:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10002: Received short response, expected 272 bytes, got 0
21:07:12:WU00:FS01:Connecting to assign4.stanford.edu:80
21:07:49:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
21:07:49:WU02:FS00:News: Welcome to Folding@Home
21:07:49:WU02:FS00:Assigned to work server 171.67.108.143
21:07:50:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"GF100 [GeForce GTX 480]" from 171.67.108.143
21:07:50:WU02:FS00:Connecting to 171.67.108.143:8080
21:08:15:WU00:FS01:News: Welcome to Folding@Home
21:08:15:WU00:FS01:Assigned to work server 171.67.108.60
21:08:15:WU00:FS01:Requesting new work unit for slot 01: READY smp:4 from 171.67.108.60
21:08:15:WU00:FS01:Connecting to 171.67.108.60:8080
21:08:32:ERROR:WU02:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
21:08:57:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
21:08:57:WU00:FS01:Connecting to assign3.stanford.edu:8080
21:09:39:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': 10002: Received short response, expected 272 bytes, got 0
21:09:39:WU00:FS01:Connecting to assign4.stanford.edu:80
21:09:40:WU00:FS01:News: Welcome to Folding@Home
21:09:40:WU00:FS01:Assigned to work server 171.67.108.60
21:09:52:WU00:FS01:Requesting new work unit for slot 01: READY smp:4 from 171.67.108.60
21:09:52:WU00:FS01:Connecting to 171.67.108.60:8080
21:10:34:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
21:11:34:WU00:FS01:Connecting to assign3.stanford.edu:8080
21:12:03:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
21:12:04:WU02:FS00:News: Welcome to Folding@Home
21:12:04:WU02:FS00:Assigned to work server 171.67.108.143
21:12:04:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"GF100 [GeForce GTX 480]" from 171.67.108.143
21:12:04:WU02:FS00:Connecting to 171.67.108.143:8080
Thanks
That's no small delay. :roll:
JorgyBaby
Post by JorgyBaby »
BUMP - Any ideas guys? I'd like to sort it today as I'm quite busy through the week next week so will have little time to sort it and would be able to leave it folding for quite a while :)
