ATI RADEON HD6870 PROBLEM
darkcrystal33
Post by darkcrystal33 »
Folding@home don't work with my graphic card.
My card is in whitelist as: 0x1002:0x6738:1:4:Barts XT [ATI Radeon HD 6800 Series]
Errors look like this:
*********************** Log Started 2012-09-15T15:05:16Z ***********************
15:05:35:WARNING:WU00:FS00:Fatal error, dumping
15:05:55:WARNING:WU01:FS00:Fatal error, dumping
15:06:14:WARNING:WU00:FS00:Fatal error, dumping
15:06:32:WARNING:WU01:FS00:Fatal error, dumping
15:06:51:WARNING:WU00:FS00:Fatal error, dumping
I put the end of the logfile below:
15:06:35:WU00:FS00:0x16:*------------------------------*
15:06:35:WU00:FS00:0x16:Folding@Home GPU Core
15:06:35:WU00:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
15:06:35:WU00:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
15:06:35:WU00:FS00:0x16:Build host: user-f6d030f24f
15:06:35:WU00:FS00:0x16:Board Type: AMD/OpenCL
15:06:35:WU00:FS00:0x16:Core      : x=16
15:06:35:WU00:FS00:0x16: Window's signal control handler registered.
15:06:35:WU00:FS00:0x16:Preparing to commence simulation
15:06:35:WU00:FS00:0x16:- Looking at optimizations...
15:06:35:WU00:FS00:0x16:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
15:06:35:WU00:FS00:0x16:- Created dyn
15:06:35:WU00:FS00:0x16:- Files status OK
15:06:35:WU00:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
15:06:35:WU00:FS00:0x16:- Expanded 45018 -> 171163 (decompressed 380.2 percent)
15:06:35:WU00:FS00:0x16:Called DecompressByteArray: compressed_data_size=45018 data_size=171163, decompressed_data_size=171163 diff=0
15:06:35:WU00:FS00:0x16:- Digital signature verified
15:06:35:WU00:FS00:0x16:Project: 11293 (Run 31, Clone 133, Gen 28)
15:06:35:WU00:FS00:0x16:Assembly optimizations on if available.
15:06:35:WU00:FS00:0x16:Entering M.D.
15:06:37:WU00:FS00:0x16:Tpr hash 00/wudata_01.tpr:  2404340039 523224237 118479365 46716196 2774660357
15:06:37:WU00:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
15:06:37:WU00:FS00:0x16:Client config unavailable.
15:06:37:WU00:FS00:0x16:Starting GUI Server
15:06:40:WU00:FS00:0x16:Finished fah_main
15:06:40:WU00:FS00:0x16:Successful run
15:06:40:WU00:FS00:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
15:06:50:WU00:FS00:0x16:Reserved 0 bytes for xtc file; Cosm status=0
15:06:50:WU00:FS00:0x16:Reserved 0 0 786430464 bytes for arc file=<00/wudata_01.trr> Cosm status=0
15:06:50:WU00:FS00:0x16:Allocated 0 bytes for edr file
15:06:50:WU00:FS00:0x16:Error: could not open bedfile, but going on anyway
15:06:50:WU00:FS00:0x16:- Checksum of file (00/wudata_01.edr) read from disk doesn't match
15:06:50:WU00:FS00:0x16:edrfile file hash check failed.
15:06:50:WU00:FS00:0x16:Folding@home Core Shutdown: FILE_IO_ERROR
15:06:51:WU00:FS00:FahCore returned: FILE_IO_ERROR (117 = 0x75)
15:06:51:WU00:FS00:Sending unit results: id:00 state:SEND error:DUMPED project:11293 run:31 clone:133 gen:28 core:0x16 unit:0x000000296652edbc4d94bb4efba585e4
15:06:51:WU00:FS00:Connecting to 171.67.108.44:8080
15:06:52:WU00:FS00:Server responded WORK_ACK (400)
15:06:52:WU00:FS00:Cleaning up
bollix47
Re: ATI RADEON HD6870 PROBLEM
Post by bollix47 »
Welcome to the folding support forum darkcrystal33!
If you could copy/paste the top part of the v7 log it may be helpful. Click on the refresh button above the log, then scroll up to the top and copy the system info and config. Paste that between code tags (available in Full Editor) in a post here.
darkcrystal33
Hi thx
*********************** Log Started 2012-09-15T15:48:57Z ***********************
15:48:57:************************* Folding@home Client *************************
15:48:57:      Website: http://folding.stanford.edu/
15:48:57:    Copyright: (c) 2009-2012 Stanford University
15:48:57:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:48:57:         Args: --lifeline 3396 --command-port=36330
15:48:57:       Config: C:/Users/TEMPETE/AppData/Roaming/FAHClient/config.xml
15:48:57:******************************** Build ********************************
15:48:57:      Version: 7.1.52
15:48:57:         Date: Mar 20 2012
15:48:57:         Time: 19:37:42
15:48:57:      SVN Rev: 3515
15:48:57:       Branch: fah/trunk/client
15:48:57:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
15:48:57:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
15:48:57:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
15:48:57:     Platform: win32 XP
15:48:57:         Bits: 32
15:48:57:         Mode: Release
15:48:57:******************************* System ********************************
15:48:57:          CPU: Intel(R) Core(TM)2 Duo CPU E7300 @ 2.66GHz
15:48:57:       CPU ID: GenuineIntel Family 6 Model 23 Stepping 6
15:48:57:         CPUs: 2
15:48:57:       Memory: 4.00GiB
15:48:57:  Free Memory: 2.92GiB
15:48:57:      Threads: WINDOWS_THREADS
15:48:57:   On Battery: false
15:48:57:   UTC offset: 2
15:48:57:          PID: 4768
15:48:57:          CWD: C:/Users/TEMPETE/AppData/Roaming/FAHClient
15:48:57:           OS: Windows 7 Home Premium
15:48:57:      OS Arch: AMD64
15:48:57:         GPUs: 1
15:48:57:        GPU 0: ATI:4 Barts XT [ATI Radeon HD 6800 Series]
15:48:57:         CUDA: Not detected
15:48:57:Win32 Service: false
15:48:57:***********************************************************************
15:48:57:<config>
15:48:57:  <!-- Folding Slot Configuration -->
15:48:57:  <gpu v='true'/>
15:48:57:  <smp v='false'/>
15:48:57:
15:48:57:  <!-- User Information -->
15:48:57:  <team v='221870'/>
15:48:57:  <user v='darkcrystal33'/>
15:48:57:
15:48:57:  <!-- Folding Slots -->
15:48:57:</config>
15:48:57:Trying to access database...
15:48:57:Successfully acquired database lock
15:48:57:Enabled folding slot 00: READY gpu:0:"Barts XT [ATI Radeon HD 6800 Series]"
15:48:57:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
15:48:58:WU00:FS00:News: Welcome to Folding@Home
15:48:58:WU00:FS00:Assigned to work server 171.67.108.44
15:48:58:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts XT [ATI Radeon HD 6800 Series]" from 171.67.108.44
15:48:58:WU00:FS00:Connecting to 171.67.108.44:8080
15:48:59:WU00:FS00:Downloading 44.64KiB
15:48:59:WU00:FS00:Download complete
15:48:59:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:OK project:11293 run:30 clone:136 gen:28 core:0x16 unit:0x0000006a6652edbc4d94bb182259fb0d
15:48:59:WU00:FS00:Starting
15:48:59:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/TEMPETE/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 701 -lifeline 4768 -checkpoint 15 -gpu 0
15:48:59:WU00:FS00:Started FahCore on PID 4540
15:49:00:WU00:FS00:Core PID:4388
15:49:00:WU00:FS00:FahCore 0x16 started
15:49:00:WU00:FS00:0x16:
15:49:00:WU00:FS00:0x16:*------------------------------*
15:49:00:WU00:FS00:0x16:Folding@Home GPU Core
15:49:00:WU00:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
15:49:00:WU00:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
15:49:00:WU00:FS00:0x16:Build host: user-f6d030f24f
15:49:00:WU00:FS00:0x16:Board Type: AMD/OpenCL
15:49:00:WU00:FS00:0x16:Core      : x=16
15:49:00:WU00:FS00:0x16: Window's signal control handler registered.
15:49:00:WU00:FS00:0x16:Preparing to commence simulation
15:49:00:WU00:FS00:0x16:- Looking at optimizations...
15:49:00:WU00:FS00:0x16:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
15:49:00:WU00:FS00:0x16:- Created dyn
15:49:00:WU00:FS00:0x16:- Files status OK
15:49:00:WU00:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
15:49:00:WU00:FS00:0x16:- Expanded 45201 -> 171163 (decompressed 378.6 percent)
15:49:00:WU00:FS00:0x16:Called DecompressByteArray: compressed_data_size=45201 data_size=171163, decompressed_data_size=171163 diff=0
15:49:00:WU00:FS00:0x16:- Digital signature verified
15:49:00:WU00:FS00:0x16:Project: 11293 (Run 30, Clone 136, Gen 28)
15:49:00:WU00:FS00:0x16:Assembly optimizations on if available.
15:49:00:WU00:FS00:0x16:Entering M.D.
15:49:00:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
15:49:02:WU00:FS00:0x16:Tpr hash 00/wudata_01.tpr:  1756419624 2148224596 3318521375 2035353308 1335549938
15:49:02:WU00:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
15:49:02:WU00:FS00:0x16:Client config unavailable.
15:49:02:WU00:FS00:0x16:Starting GUI Server
15:49:05:WU00:FS00:0x16:Finished fah_main
15:49:05:WU00:FS00:0x16:Successful run
15:49:05:WU00:FS00:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
15:49:15:WU00:FS00:0x16:Reserved 0 bytes for xtc file; Cosm status=0
15:49:15:WU00:FS00:0x16:Reserved 0 0 786430464 bytes for arc file=<00/wudata_01.trr> Cosm status=0
15:49:15:WU00:FS00:0x16:Allocated 0 bytes for edr file
15:49:15:WU00:FS00:0x16:Error: could not open bedfile, but going on anyway
15:49:15:WU00:FS00:0x16:- Checksum of file (00/wudata_01.edr) read from disk doesn't match
15:49:15:WU00:FS00:0x16:edrfile file hash check failed.
15:49:15:WU00:FS00:0x16:Folding@home Core Shutdown: FILE_IO_ERROR
15:49:16:WU00:FS00:FahCore returned: FILE_IO_ERROR (117 = 0x75)
15:49:16:WARNING:WU00:FS00:Fatal error, dumping
15:49:16:WU00:FS00:Sending unit results: id:00 state:SEND error:DUMPED project:11293 run:30 clone:136 gen:28 core:0x16 unit:0x0000006a6652edbc4d94bb182259fb0d
15:49:16:WU00:FS00:Connecting to 171.67.108.44:8080
15:49:16:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
15:49:16:WU00:FS00:Server responded WORK_ACK (400)
15:49:16:WU00:FS00:Cleaning up
15:49:16:WU01:FS00:News: Welcome to Folding@Home
15:49:16:WU01:FS00:Assigned to work server 171.67.108.44
15:49:16:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts XT [ATI Radeon HD 6800 Series]" from 171.67.108.44
15:49:16:WU01:FS00:Connecting to 171.67.108.44:8080
15:49:17:WU01:FS00:Downloading 44.58KiB
15:49:18:WU01:FS00:Download complete
15:49:18:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:OK project:11293 run:31 clone:136 gen:28 core:0x16 unit:0x000000256652edbc4d94bb4e83bb3131
15:49:18:WU01:FS00:Starting
15:49:18:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/TEMPETE/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 701 -lifeline 4768 -checkpoint 15 -gpu 0
15:49:18:WU01:FS00:Started FahCore on PID 2708
15:49:18:WU01:FS00:Core PID:5028
15:49:18:WU01:FS00:FahCore 0x16 started
15:49:19:WU01:FS00:0x16:
15:49:19:WU01:FS00:0x16:*------------------------------*
15:49:19:WU01:FS00:0x16:Folding@Home GPU Core
15:49:19:WU01:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
15:49:19:WU01:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
15:49:19:WU01:FS00:0x16:Build host: user-f6d030f24f
15:49:19:WU01:FS00:0x16:Board Type: AMD/OpenCL
15:49:19:WU01:FS00:0x16:Core      : x=16
15:49:19:WU01:FS00:0x16: Window's signal control handler registered.
15:49:19:WU01:FS00:0x16:Preparing to commence simulation
15:49:19:WU01:FS00:0x16:- Looking at optimizations...
15:49:19:WU01:FS00:0x16:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
15:49:19:WU01:FS00:0x16:- Created dyn
15:49:19:WU01:FS00:0x16:- Files status OK
15:49:19:WU01:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
15:49:19:WU01:FS00:0x16:- Expanded 45137 -> 171163 (decompressed 379.2 percent)
15:49:19:WU01:FS00:0x16:Called DecompressByteArray: compressed_data_size=45137 data_size=171163, decompressed_data_size=171163 diff=0
15:49:19:WU01:FS00:0x16:- Digital signature verified
15:49:19:WU01:FS00:0x16:Project: 11293 (Run 31, Clone 136, Gen 28)
15:49:19:WU01:FS00:0x16:Assembly optimizations on if available.
15:49:19:WU01:FS00:0x16:Entering M.D.
15:49:20:WU01:FS00:0x16:Tpr hash 01/wudata_01.tpr:  284253834 2901794583 2548346308 1009478266 3319970702
15:49:20:WU01:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
15:49:20:WU01:FS00:0x16:Client config unavailable.
15:49:20:WU01:FS00:0x16:Starting GUI Server
15:49:24:WU01:FS00:0x16:Finished fah_main
15:49:24:WU01:FS00:0x16:Successful run
15:49:24:WU01:FS00:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
15:49:34:WU01:FS00:0x16:Reserved 0 bytes for xtc file; Cosm status=0
15:49:34:WU01:FS00:0x16:Reserved 0 0 786430464 bytes for arc file=<01/wudata_01.trr> Cosm status=0
15:49:34:WU01:FS00:0x16:Allocated 0 bytes for edr file
15:49:34:WU01:FS00:0x16:Error: could not open bedfile, but going on anyway
15:49:34:WU01:FS00:0x16:- Checksum of file (01/wudata_01.edr) read from disk doesn't match
15:49:34:WU01:FS00:0x16:edrfile file hash check failed.
15:49:34:WU01:FS00:0x16:Folding@home Core Shutdown: FILE_IO_ERROR
15:49:34:WU01:FS00:FahCore returned: FILE_IO_ERROR (117 = 0x75)
15:49:34:WARNING:WU01:FS00:Fatal error, dumping
15:49:34:WU01:FS00:Sending unit results: id:01 state:SEND error:DUMPED project:11293 run:31 clone:136 gen:28 core:0x16 unit:0x000000256652edbc4d94bb4e83bb3131
15:49:34:WU01:FS00:Connecting to 171.67.108.44:8080
15:49:34:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
15:49:35:WU01:FS00:Server responded WORK_ACK (400)
15:49:35:WU01:FS00:Cleaning up
15:49:35:WU00:FS00:News: Welcome to Folding@Home
15:49:35:WU00:FS00:Assigned to work server 171.67.108.44
15:49:35:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts XT [ATI Radeon HD 6800 Series]" from 171.67.108.44
15:49:35:WU00:FS00:Connecting to 171.67.108.44:8080
15:49:36:WU00:FS00:Downloading 44.33KiB
15:49:37:WU00:FS00:Download complete
15:49:37:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:OK project:11293 run:1 clone:137 gen:28 core:0x16 unit:0x000000266652edbc4d9255f413352819
15:49:37:WU00:FS00:Starting
15:49:37:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/TEMPETE/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 701 -lifeline 4768 -checkpoint 15 -gpu 0
15:49:37:WU00:FS00:Started FahCore on PID 4716
15:49:37:WU00:FS00:Core PID:816
15:49:37:WU00:FS00:FahCore 0x16 started
15:49:37:WU00:FS00:0x16:
15:49:37:WU00:FS00:0x16:*------------------------------*
15:49:37:WU00:FS00:0x16:Folding@Home GPU Core
15:49:37:WU00:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
15:49:37:WU00:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
15:49:37:WU00:FS00:0x16:Build host: user-f6d030f24f
15:49:37:WU00:FS00:0x16:Board Type: AMD/OpenCL
15:49:37:WU00:FS00:0x16:Core      : x=16
15:49:37:WU00:FS00:0x16: Window's signal control handler registered.
15:49:37:WU00:FS00:0x16:Preparing to commence simulation
15:49:37:WU00:FS00:0x16:- Looking at optimizations...
15:49:37:WU00:FS00:0x16:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
15:49:37:WU00:FS00:0x16:- Created dyn
15:49:37:WU00:FS00:0x16:- Files status OK
15:49:37:WU00:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
15:49:37:WU00:FS00:0x16:- Expanded 44883 -> 171163 (decompressed 381.3 percent)
15:49:37:WU00:FS00:0x16:Called DecompressByteArray: compressed_data_size=44883 data_size=171163, decompressed_data_size=171163 diff=0
15:49:37:WU00:FS00:0x16:- Digital signature verified
15:49:37:WU00:FS00:0x16:Project: 11293 (Run 1, Clone 137, Gen 28)
15:49:37:WU00:FS00:0x16:Assembly optimizations on if available.
15:49:37:WU00:FS00:0x16:Entering M.D.
15:49:39:WU00:FS00:0x16:Tpr hash 00/wudata_01.tpr:  1114949122 3972880429 3215526591 3959404932 2533102745
15:49:39:WU00:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
15:49:39:WU00:FS00:0x16:Client config unavailable.
15:49:39:WU00:FS00:0x16:Starting GUI Server
15:49:42:WU00:FS00:0x16:Finished fah_main
15:49:42:WU00:FS00:0x16:Successful run
15:49:42:WU00:FS00:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
15:49:52:WU00:FS00:0x16:Reserved 0 bytes for xtc file; Cosm status=0
15:49:52:WU00:FS00:0x16:Reserved 0 0 786430464 bytes for arc file=<00/wudata_01.trr> Cosm status=0
15:49:52:WU00:FS00:0x16:Allocated 0 bytes for edr file
15:49:52:WU00:FS00:0x16:Error: could not open bedfile, but going on anyway
15:49:52:WU00:FS00:0x16:- Checksum of file (00/wudata_01.edr) read from disk doesn't match
15:49:52:WU00:FS00:0x16:edrfile file hash check failed.
15:49:52:WU00:FS00:0x16:Folding@home Core Shutdown: FILE_IO_ERROR
15:49:53:WU00:FS00:FahCore returned: FILE_IO_ERROR (117 = 0x75)
15:49:53:WARNING:WU00:FS00:Fatal error, dumping
15:49:53:WU00:FS00:Sending unit results: id:00 state:SEND error:DUMPED project:11293 run:1 clone:137 gen:28 core:0x16 unit:0x000000266652edbc4d9255f413352819
15:49:53:WU00:FS00:Connecting to 171.67.108.44:8080
15:49:53:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
15:49:53:WU00:FS00:Server responded WORK_ACK (400)
15:49:53:WU00:FS00:Cleaning up
15:49:54:WU01:FS00:News: Welcome to Folding@Home
15:49:54:WU01:FS00:Assigned to work server 171.67.108.44
15:49:54:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts XT [ATI Radeon HD 6800 Series]" from 171.67.108.44
15:49:54:WU01:FS00:Connecting to 171.67.108.44:8080
15:49:54:WU01:FS00:Downloading 44.42KiB
15:49:55:WU01:FS00:Download complete
15:49:55:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:OK project:11293 run:2 clone:137 gen:28 core:0x16 unit:0x0000002a6652edbc4d925628d9ad1abc
15:49:55:WU01:FS00:Starting
15:49:55:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/TEMPETE/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 701 -lifeline 4768 -checkpoint 15 -gpu 0
15:49:55:WU01:FS00:Started FahCore on PID 4528
15:49:55:WU01:FS00:Core PID:5092
15:49:55:WU01:FS00:FahCore 0x16 started
15:49:56:WU01:FS00:0x16:
15:49:56:WU01:FS00:0x16:*------------------------------*
15:49:56:WU01:FS00:0x16:Folding@Home GPU Core
15:49:56:WU01:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
15:49:56:WU01:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
15:49:56:WU01:FS00:0x16:Build host: user-f6d030f24f
15:49:56:WU01:FS00:0x16:Board Type: AMD/OpenCL
15:49:56:WU01:FS00:0x16:Core      : x=16
15:49:56:WU01:FS00:0x16: Window's signal control handler registered.
15:49:56:WU01:FS00:0x16:Preparing to commence simulation
15:49:56:WU01:FS00:0x16:- Looking at optimizations...
15:49:56:WU01:FS00:0x16:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
15:49:56:WU01:FS00:0x16:- Created dyn
15:49:56:WU01:FS00:0x16:- Files status OK
15:49:56:WU01:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
15:49:56:WU01:FS00:0x16:- Expanded 44975 -> 171163 (decompressed 380.5 percent)
15:49:56:WU01:FS00:0x16:Called DecompressByteArray: compressed_data_size=44975 data_size=171163, decompressed_data_size=171163 diff=0
15:49:56:WU01:FS00:0x16:- Digital signature verified
15:49:56:WU01:FS00:0x16:Project: 11293 (Run 2, Clone 137, Gen 28)
15:49:56:WU01:FS00:0x16:Assembly optimizations on if available.
15:49:56:WU01:FS00:0x16:Entering M.D.
15:49:58:WU01:FS00:0x16:Tpr hash 01/wudata_01.tpr:  1798359995 1294984964 3223165523 3382757836 2040630454
15:49:58:WU01:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
15:49:58:WU01:FS00:0x16:Client config unavailable.
15:49:58:WU01:FS00:0x16:Starting GUI Server
15:50:02:WU01:FS00:0x16:Finished fah_main
15:50:02:WU01:FS00:0x16:Successful run
15:50:02:WU01:FS00:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
15:50:12:WU01:FS00:FahCore returned: FILE_IO_ERROR (117 = 0x75)
15:50:12:WARNING:WU01:FS00:Fatal error, dumping
15:50:12:WU01:FS00:Sending unit results: id:01 state:SEND error:DUMPED project:11293 run:2 clone:137 gen:28 core:0x16 unit:0x0000002a6652edbc4d925628d9ad1abc
15:50:12:WU01:FS00:Connecting to 171.67.108.44:8080
15:50:12:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
15:50:12:WU01:FS00:Server responded WORK_ACK (400)
15:50:12:WU01:FS00:Cleaning up
15:50:13:WU00:FS00:News: Welcome to Folding@Home
15:50:13:WU00:FS00:Assigned to work server 171.67.108.44
15:50:13:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"Barts XT [ATI Radeon HD 6800 Series]" from 171.67.108.44
15:50:13:WU00:FS00:Connecting to 171.67.108.44:8080
15:50:14:WU00:FS00:Downloading 44.29KiB
15:50:15:WU00:FS00:Download complete
15:50:15:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:OK project:11293 run:4 clone:137 gen:28 core:0x16 unit:0x0000002b6652edbc4d9256864eb77687
15:50:15:WU00:FS00:Starting
15:50:15:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/TEMPETE/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 701 -lifeline 4768 -checkpoint 15 -gpu 0
15:50:15:WU00:FS00:Started FahCore on PID 4452
15:50:15:WU00:FS00:Core PID:2588
15:50:15:WU00:FS00:FahCore 0x16 started
15:50:15:WU00:FS00:0x16:
15:50:15:WU00:FS00:0x16:*------------------------------*
15:50:15:WU00:FS00:0x16:Folding@Home GPU Core
15:50:15:WU00:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
15:50:15:WU00:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
15:50:15:WU00:FS00:0x16:Build host: user-f6d030f24f
15:50:15:WU00:FS00:0x16:Board Type: AMD/OpenCL
15:50:15:WU00:FS00:0x16:Core      : x=16
15:50:15:WU00:FS00:0x16: Window's signal control handler registered.
15:50:15:WU00:FS00:0x16:Preparing to commence simulation
15:50:15:WU00:FS00:0x16:- Looking at optimizations...
15:50:15:WU00:FS00:0x16:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
15:50:15:WU00:FS00:0x16:- Created dyn
15:50:15:WU00:FS00:0x16:- Files status OK
15:50:15:WU00:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
15:50:15:WU00:FS00:0x16:- Expanded 44843 -> 171163 (decompressed 381.6 percent)
15:50:15:WU00:FS00:0x16:Called DecompressByteArray: compressed_data_size=44843 data_size=171163, decompressed_data_size=171163 diff=0
15:50:15:WU00:FS00:0x16:- Digital signature verified
15:50:15:WU00:FS00:0x16:Project: 11293 (Run 4, Clone 137, Gen 28)
15:50:15:WU00:FS00:0x16:Assembly optimizations on if available.
15:50:15:WU00:FS00:0x16:Entering M.D.
15:50:17:WU00:FS00:0x16:Tpr hash 00/wudata_01.tpr:  3611229420 2380536386 2702682569 2065734902 2656499946
15:50:17:WU00:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
15:50:17:WU00:FS00:0x16:Client config unavailable.
15:50:17:WU00:FS00:0x16:Starting GUI Server
15:50:20:WU00:FS00:0x16:Finished fah_main
15:50:20:WU00:FS00:0x16:Successful run
15:50:20:WU00:FS00:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
15:50:30:WU00:FS00:0x16:Reserved 0 bytes for xtc file; Cosm status=0
15:50:30:WU00:FS00:0x16:Reserved 0 0 786430464 bytes for arc file=<00/wudata_01.trr> Cosm status=0
15:50:30:WU00:FS00:0x16:Allocated 0 bytes for edr file
15:50:30:WU00:FS00:0x16:Error: could not open bedfile, but going on anyway
15:50:30:WU00:FS00:0x16:- Checksum of file (00/wudata_01.edr) read from disk doesn't match
15:50:30:WU00:FS00:0x16:edrfile file hash check failed.
15:50:30:WU00:FS00:0x16:Folding@home Core Shutdown: FILE_IO_ERROR
15:50:31:WU00:FS00:FahCore returned: FILE_IO_ERROR (117 = 0x75)
15:50:31:WARNING:WU00:FS00:Fatal error, dumping
15:50:31:WU00:FS00:Sending unit results: id:00 state:SEND error:DUMPED project:11293 run:4 clone:137 gen:28 core:0x16 unit:0x0000002b6652edbc4d9256864eb77687
15:50:31:WU00:FS00:Connecting to 171.67.108.44:8080
15:50:31:WU00:FS00:Server responded WORK_ACK (400)
15:50:31:WU00:FS00:Cleaning up
Also, what version of the Catalyst drivers do you have installed? Not all versions are known to be stable for folding.
darkcrystal33
It's the last one: Catalyst 12.8
But have same problem with the Catalyst 12.6
Problems have been reported with the drivers starting with 12.4, though there is a report of 12.6 working with a different ATI card. Make certain OpenCL support is installed by the driver package. If you can, try a driver earlier than 12.4. The last time I had a system set up with GPU folding earlier this year, the 11.10 driver worked fine with a ATI 5870.
darkcrystal33
I have installed intel_sdk_for_ocl_applications_2012_x64_setup.exe from here: http://software.intel.com/en-us/vcsourc ... opencl-sdk
and it's look like working fine with Catalyst 12.8
thx for help
bollix47
Post by bollix47 »
Interesting find ... thanks for sharing!
bollix47
Post by bollix47 »
After using the intel-sdk for a week can you confirm that the GPU is actually doing the work? i.e. is the GPU showing a high percentage(90-99%) of usage or is the CPU somehow being used to process the work units?
Was there something else you did around the same time that you installed the intel-sdk?
We are trying to determine how and why installing the intel-sdk got things working for you.
Thanks for any help.
