Sapphire 7850
Pik0
Sapphire 7850
Post by Pik0 »
Hey guys,
I have 7770 OC working but my 7850 on a separate computer isnt working, It shows that its finding the right GPU (updated the GPUS.txt file).
Here is the log:
*********************** Log Started 2012-08-21T12:39:27Z ***********************
12:39:27:WU01:FS00:Starting
12:39:27:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/PCPC/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 701 -lifeline 4692 -checkpoint 15 -gpu 0
12:39:28:WU01:FS00:Started FahCore on PID 2932
12:39:28:WU01:FS00:Core PID:4420
12:39:28:WU01:FS00:FahCore 0x16 started
12:39:28:WU01:FS00:0x16:
12:39:28:WU01:FS00:0x16:*------------------------------*
12:39:28:WU01:FS00:0x16:Folding@Home GPU Core
12:39:28:WU01:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
12:39:28:WU01:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
12:39:28:WU01:FS00:0x16:Build host: user-f6d030f24f
12:39:28:WU01:FS00:0x16:Board Type: AMD/OpenCL
12:39:28:WU01:FS00:0x16:Core      : x=16
12:39:28:WU01:FS00:0x16: Window's signal control handler registered.
12:39:28:WU01:FS00:0x16:Preparing to commence simulation
12:39:28:WU01:FS00:0x16:- Ensuring status. Please wait.
12:39:37:WU01:FS00:0x16:- Looking at optimizations...
12:39:37:WU01:FS00:0x16:- Working with standard loops on this execution.
12:39:37:WU01:FS00:0x16:- Previous termination of core was improper.
12:39:37:WU01:FS00:0x16:- Files status OK
12:39:37:WU01:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
12:39:37:WU01:FS00:0x16:- Expanded 45102 -> 171163 (decompressed 379.5 percent)
12:39:37:WU01:FS00:0x16:Called DecompressByteArray: compressed_data_size=45102 data_size=171163, decompressed_data_size=171163 diff=0
12:39:37:WU01:FS00:0x16:- Digital signature verified
12:39:37:WU01:FS00:0x16:Project: 11293 (Run 7, Clone 424, Gen 24)
12:39:37:WU01:FS00:0x16:Entering M.D.
12:39:39:WU01:FS00:0x16:Tpr hash 01/wudata_01.tpr:  2400204013 1587196043 3721427428 531395749 635968155
12:39:39:WU01:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
12:39:39:WU01:FS00:0x16:Client config unavailable.
12:39:40:WU01:FS00:0x16:Starting GUI Server
12:42:03:FS00:Paused
12:42:03:FS00:Shutting core down
12:42:06:FS00:Unpaused
12:42:07:WU01:FS00:0x16:Client no longer detected. Shutting down core
12:42:07:WU01:FS00:0x16:Folding@home Core Shutdown: CLIENT_DIED
12:42:08:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
12:42:08:WU01:FS00:Starting
12:42:08:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/PCPC/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 701 -lifeline 4692 -checkpoint 15 -gpu 0
12:42:08:WU01:FS00:Started FahCore on PID 3096
12:42:08:WU01:FS00:Core PID:3140
12:42:08:WU01:FS00:FahCore 0x16 started
12:42:08:WU01:FS00:0x16:
12:42:08:WU01:FS00:0x16:*------------------------------*
12:42:08:WU01:FS00:0x16:Folding@Home GPU Core
12:42:08:WU01:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
12:42:08:WU01:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
12:42:08:WU01:FS00:0x16:Build host: user-f6d030f24f
12:42:08:WU01:FS00:0x16:Board Type: AMD/OpenCL
12:42:08:WU01:FS00:0x16:Core      : x=16
12:42:08:WU01:FS00:0x16: Window's signal control handler registered.
12:42:08:WU01:FS00:0x16:Preparing to commence simulation
12:42:08:WU01:FS00:0x16:- Looking at optimizations...
12:42:08:WU01:FS00:0x16:- Files status OK
12:42:08:WU01:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
12:42:08:WU01:FS00:0x16:- Expanded 45102 -> 171163 (decompressed 379.5 percent)
12:42:08:WU01:FS00:0x16:Called DecompressByteArray: compressed_data_size=45102 data_size=171163, decompressed_data_size=171163 diff=0
12:42:08:WU01:FS00:0x16:- Digital signature verified
12:42:08:WU01:FS00:0x16:Project: 11293 (Run 7, Clone 424, Gen 24)
12:42:08:WU01:FS00:0x16:Assembly optimizations on if available.
12:42:08:WU01:FS00:0x16:Entering M.D.
12:42:10:WU01:FS00:0x16:Tpr hash 01/wudata_01.tpr:  2400204013 1587196043 3721427428 531395749 635968155
12:42:10:WU01:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
12:42:10:WU01:FS00:0x16:Client config unavailable.
12:42:10:WU01:FS00:0x16:Starting GUI Server
Pik0
Re: Sapphire 7850
Post by Pik0 »
Sorry, didnt really explain it well. It sits there saying its running (green box) but CCC says that it isnt being used at all.
Re: Sapphire 7850
Which version of the Catalyst drivers are you using on each machine? There have been reports of problems using the latest revisions of the drivers, pre-12.4 appear to work and install OpenCL properly. Not sure which is the earliest version that supports a 7850.
Pik0
Re: Sapphire 7850
Post by Pik0 »
Both running the latest drivers 12.8
Pik0
Re: Sapphire 7850
Post by Pik0 »
Please post your *** System *** section of the log file, and a section of the log file showing the GPU client trying to start up and failing. Thanks.
Here is the Log
12:39:27:******************************* System ********************************
12:39:27:          CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
12:39:27:       CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
12:39:27:         CPUs: 4
12:39:27:       Memory: 7.90GiB
12:39:27:  Free Memory: 6.60GiB
12:39:27:      Threads: WINDOWS_THREADS
12:39:27:   On Battery: false
12:39:27:   UTC offset: 10
12:39:27:          PID: 4692
12:39:27:          CWD: C:/Users/PCPC/AppData/Roaming/FAHClient
12:39:27:           OS: Windows 7 Professional
12:39:27:      OS Arch: AMD64
12:39:27:         GPUs: 1
12:39:27:        GPU 0: ATI:4 PITCAIRN PRO [Radeon HD 7800 Series]
12:39:27:         CUDA: Not detected
12:39:27:Win32 Service: false
12:39:27:***********************************************************************
12:39:27:<config>
12:39:27:  <!-- Folding Slot Configuration -->
12:39:27:  <gpu v='true'/>
12:39:27:
12:39:27:  <!-- Network -->
12:39:27:  <proxy v=':8080'/>
12:39:27:
12:39:27:  <!-- User Information -->
12:39:27:  <passkey v='********************************'/>
12:39:27:  <team v='24'/>
12:39:27:  <user v='Pik0'/>
12:39:27:
12:39:27:  <!-- Folding Slots -->
12:39:27:  <slot id='0' type='GPU'/>
12:39:27:  <slot id='1' type='SMP'/>
12:39:27:</config>
12:39:27:Trying to access database...
12:39:27:Successfully acquired database lock
12:39:27:Enabled folding slot 00: READY gpu:0:"PITCAIRN PRO [Radeon HD 7800 Series]"
12:39:27:Enabled folding slot 01: READY smp:4
12:39:28:WU00:FS01:Starting
12:39:28:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/PCPC/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 701 -lifeline 4692 -checkpoint 15 -np 4
12:39:28:WU00:FS01:Started FahCore on PID 4336
12:39:28:WU00:FS01:Core PID:4628
12:39:28:WU00:FS01:FahCore 0xa4 started
12:39:28:WU00:FS01:0xa4:
12:39:28:WU00:FS01:0xa4:*------------------------------*
12:39:28:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
12:39:28:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
12:39:28:WU00:FS01:0xa4:Preparing to commence simulation
12:39:28:WU00:FS01:0xa4:- Ensuring status. Please wait.
12:39:31:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
12:39:38:WU00:FS01:0xa4:- Looking at optimizations...
12:39:38:WU00:FS01:0xa4:- Working with standard loops on this execution.
12:39:38:WU00:FS01:0xa4:- Previous termination of core was improper.
12:39:38:WU00:FS01:0xa4:- Files status OK
12:39:38:WU00:FS01:0xa4:- Expanded 966721 -> 2210540 (decompressed 228.6 percent)
12:39:38:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=966721 data_size=2210540, decompressed_data_size=2210540 diff=0
12:39:38:WU00:FS01:0xa4:- Digital signature verified
12:39:38:WU00:FS01:0xa4:Project: 8049 (Run 468, Clone 10, Gen 30)
12:39:38:WU00:FS01:0xa4:Entering M.D.
12:39:44:WU00:FS01:0xa4:Using Gromacs checkpoints
12:39:44:WU00:FS01:0xa4:Mapping NT from 4 to 4
12:39:44:WU00:FS01:0xa4:Resuming from checkpoint
12:39:44:WU00:FS01:0xa4:Verified 00/wudata_01.log
12:39:44:WU00:FS01:0xa4:Verified 00/wudata_01.trr
12:39:44:WU00:FS01:0xa4:Verified 00/wudata_01.xtc
12:39:44:WU00:FS01:0xa4:Verified 00/wudata_01.edr
12:39:44:WU00:FS01:0xa4:Completed 235570 out of 250000 steps  (94%)
You can see where it wasnt working so I stopped and started it again but still the same thing is happening. Any help would be appreciated.
Re: Sapphire 7850
It has been a while since I installed ATI drivers and I don't remember whether OpenCL is packaged with every install or you have to download it separately. That may also depend on whether the drivers are the default version from Microsoft or whether they're downloaded directly from AMD/ATI. Be sure you have OpenCL.
Evil Penguin
Re: Sapphire 7850
Post by Evil Penguin »
It's included by default.
Re: Sapphire 7850
In standard versions yes, but not in beta versions.
It probably wouldn't hurt to verify the version of opencl packed with each version of cat driver.
Pik0
Re: Sapphire 7850
Post by Pik0 »
Does it matter if its a 32 bit system or a 64 bit system? Or is there a place I should be putting the file?
Evil Penguin
Re: Sapphire 7850
7im wrote:In standard versions yes, but not in beta versions.
I've tested quite a few betas (released to public and some that weren't) and they all have included the APP SDK Runtime.
12.8 was released as WHQL certified and the only beta version of it was 12.7 which did include the APP SDK Runtime.
