Empty work server assignment for HD4000 series GPU
AYColumbia
Post by AYColumbia »
Hi,
My GPU has been stuck at "Ready" for almost 2 days now and I decided it's time to peruse the forum. Sounds like I have this issue? The status is currently and has been "Download" with Unknown. I can shut down the FAH client and bring it back up, but it just goes back to the same status. The CPU is folding just fine and this is only on the GPU. While looking for a possible solution here, here's what my log is filling up with:
20:35:39:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
20:35:39:WU00:FS00:News: Welcome to Folding@Home
20:35:39:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
20:35:39:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
20:35:39:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
20:35:39:ERROR:WU00:FS00:Exception: Could not get an assignment
I've tried rebooting, restarting the client, specifically pausing/resuming/finishing specifically on the GPU slot without success. Any suggestions on getting the GPU folding again shy of uninstalling everything and reinstalling? Thanks much.
Re: #911:v7 don`t retry when disconnect while downloading
Different issue. You have no problem exiting and restarting.
What model GPU?
AYColumbia
7im wrote:Different issue. You have no problem exiting and restarting.
What model GPU?
Sapphire Radeon HD 4870. I copied the detailed info from CCC. BTW, I never had this issue with the old v6 and this is the first it happened since I updated to v7. I think I started using v7 about 3 weeks ago so it hasn't been long. Also, I don't want to hijaak this thread. Should a new thread be created for this issue? Thank you.
Graphics Card Manufacturer	Powered by AMD
Graphics Chipset	ATI Radeon HD 4800 Series
Device ID	944C
Vendor	1002
Subsystem ID	E810
Subsystem Vendor ID	174B
Graphics Bus Capability	PCI Express 2.0
Maximum Bus Setting	PCI Express 2.0 x16
BIOS Version	011.013.000.000
BIOS Part Number	11X-B50102-X19
BIOS Date	2008/09/26
Memory Size	512 MB
Memory Type	GDDR3
Core Clock in MHz	575 MHz
Memory Clock in MHz	900 MHz
Total Memory Bandwidth in GByte/s	57.6 GByte/s
AYColumbia wrote:Sapphire Radeon HD 4870.
The Pande Group announced over a year ago that they were removing support and projects that run on ATI Cards prior to the 5000 series. They thought the earliest they would run out of work for the ATI cards from the 4000 series and earlier would be last Fall, the supply started becoming scarce this Spring. As of a month ago they are almost gone, the occasional WU appears to get assigned and returned to the server. So you may not see another one for your 4870.
codysluder
Post by codysluder »
. . . and as far as anybody knows, it is identical for V6 and for V7. Pure chance, and a slimmer chance as every week passes.
AYColumbia
Huh, I wonder why they did that. I'll have to search for the announcement to find out the reasons. I can't believe the irony in getting this reponse for me. Just a few hours ago, I decided to upgrade my HTPC from an HD 5670 to an HD 7750. So I'll be replacing my 4870 with the 5670 soon. Although it stinks because I have another computer that could have used the 4870 to fold in addition to its CPU which is a shame as it's still a pretty good video card.
ATI dropped support for CAL/Brook and transitioned to OpenCL so Stanford had to do the same. The HD5000 supports a more advanced version of OpenCL than the HD4000 and it's the minimum required for FAH.
All three of them are pretty good video cards, but just two of them will fold.
Since this is a different issue, I'm moving it to it's own thread.
AYColumbia
Re: Empty work server assignment for HD4000 series GPU
I appreciate you moving it to its own thread.
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Post by Jesse_V »
http://folding.typepad.com/news/2011/03 ... -gpus.html
May be the post you're looking for.
AYColumbia
Jesse_V wrote:http://folding.typepad.com/news/2011/03 ... -gpus.html
Thank you. Very helpful and clarifies things.
