GPU client not getting WU's
sgt_bombulous
Post by sgt_bombulous »
Has anyone else has this issue? For the past 3 or 4 days my GTX-680 has been sitting idle. I'm using the V7 Client, and the work server is reported as 0.0.0.0
And on a side note, any word on an optimized Kepler core? :oops:
bollix47
Re: GPU client not getting WU's
Post by bollix47 »
Both problems might be resolved it you download the latest GPUs.txt file:
viewtopic.php?f=83&t=21205&
Folding on 680s only seems to work using the beta setting, which is discussed in the beta section of the forum.
Any news about Kepler optimizations would get posted in the FAH Blog (News) linked at the top of this forum page.
sgt_bombulous
I did use the new GPU's file, I've been folding on this same card since April. Now all of a sudden it stops working. I don't think it's the card, since it works fine on games.
sswilson
Hardware configuration: ASUS Crosshair IV Formula / AMD 1090T / 4X2 Gig GSkill Pi PC3-12800 / Corsair TX750W PSU / Sparkle GTX275 Plus / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Enzotech Luna WB / Dell Ultrasharp 2209WA
Gigabyte P35-DQ6 / Q6600 / 2X 1G 1066 Firestix / "Baked" XFX GTX 280 (RIP again :( ) / MSI GTS 450 Cyclone OC /PC P&C 750W Silencer / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Highspeed PC Tech Station / Samsung 931BF / BenQ Q9T4
Post by sswilson »
There is apparently an update to the gpu.txt file that you need to dl to replace the old one with. I ran into the same issue and replacing the gpu.txt file got me up and running again.
The previous GPUs.txt file had a bug were it would show 2 available GPU slots, a 670 and a 680. It would allow you to fold on either "GPU"
But now that bug has been fixed in both the GPUs.txt and on the Assignment server. The problem is that you may have been folding on the 1 of the 2 GPU IDs that was fixed (disabled).
Removing and re-adding the GPU slot may resolve that issue.
sgt_bombulous
Ok. I tried removing and then re-adding the GPU client/slot. I also replaced the GPUs.txt with the one you guys provided. It did nothing, it just gives up immediately on downloading a project and reverts to "unknown". This is getting frustrating...
k1wi
Post by k1wi »
I presume you are using standard/non-beta settings? Otherwise there isn't anything that anyone can say in this section of the forums - as per 7ims first post.
We will need to see the *** System *** of the log.
sgt_bombulous
This is what I have (If I'm looking in the right place):
*********************** Log Started 2012-07-05T12:32:00Z ***********************
12:32:00:************************* Folding@home Client *************************
12:32:00:      Website: http://folding.stanford.edu/
12:32:00:    Copyright: (c) 2009-2012 Stanford University
12:32:00:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:32:00:         Args: --lifeline 4268 --command-port=36330
12:32:00:       Config: D:/Folding/config.xml
12:32:00:******************************** Build ********************************
12:32:00:      Version: 7.1.52
12:32:00:         Date: Mar 20 2012
12:32:00:         Time: 19:37:42
12:32:00:      SVN Rev: 3515
12:32:00:       Branch: fah/trunk/client
12:32:00:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
12:32:00:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
12:32:00:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
12:32:00:     Platform: win32 XP
12:32:00:         Bits: 32
12:32:00:         Mode: Release
12:32:00:******************************* System ********************************
12:32:00:          CPU: Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz
12:32:00:       CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
12:32:00:         CPUs: 4
12:32:00:       Memory: 7.99GiB
12:32:00:  Free Memory: 5.76GiB
12:32:00:      Threads: WINDOWS_THREADS
12:32:00:   On Battery: false
12:32:00:   UTC offset: -5
12:32:00:          PID: 6048
12:32:00:          CWD: D:/Folding
12:32:00:           OS: Windows 7 Professional
12:32:00:      OS Arch: AMD64
12:32:00:         GPUs: 2
12:32:00:        GPU 0: FERMI:1 GK104 [Geforce GTX680]
12:32:00:        GPU 1: FERMI:1 GF114 [GeForce GTX 680]
12:32:00:         CUDA: 3.0
12:32:00:  CUDA Driver: 4020
12:32:00:Win32 Service: false
12:32:00:***********************************************************************
12:32:00:<config>
12:32:00:  <!-- Folding Slot Configuration -->
12:32:00:  <gpu v='true'/>
12:32:00:
12:32:00:  <!-- Network -->
12:32:00:  <proxy v=':8080'/>
12:32:00:
12:32:00:  <!-- User Information -->
12:32:00:  <passkey v='********************************'/>
12:32:00:  <team v='111065'/>
12:32:00:  <user v='sgt_bombulous'/>
12:32:00:
12:32:00:  <!-- Folding Slots -->
12:32:00:  <slot id='2' type='SMP'>
12:32:00:    <cpus v='4'/>
12:32:00:  </slot>
12:32:00:  <slot id='0' type='GPU'>
12:32:00:    <client-type v='beta'/>
12:32:00:  </slot>
12:32:00:</config>
12:32:00:Trying to access database...
12:32:00:Successfully acquired database lock
12:32:00:Enabled folding slot 02: READY smp:4
12:32:00:Enabled folding slot 00: READY gpu:0:"GK104 [Geforce GTX680] "
12:32:00:WU01:FS02:Starting
12:32:00:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:/Folding/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 701 -lifeline 6048 -checkpoint 15 -np 4
12:32:00:WU01:FS02:Started FahCore on PID 3788
12:32:00:WU01:FS02:Core PID:3356
12:32:00:WU01:FS02:FahCore 0xa4 started
12:32:00:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
12:32:00:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
12:32:00:WU00:FS00:News: Welcome to Folding@Home
12:32:00:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
12:32:00:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
12:32:00:WU01:FS02:0xa4:
12:32:00:WU01:FS02:0xa4:*------------------------------*
12:32:00:WU01:FS02:0xa4:Folding@Home Gromacs GB Core
12:32:00:WU01:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
12:32:00:WU01:FS02:0xa4:Preparing to commence simulation
12:32:00:WU01:FS02:0xa4:- Looking at optimizations...
12:32:00:WU01:FS02:0xa4:- Files status OK
12:32:00:WU01:FS02:0xa4:- Expanded 479112 -> 1077356 (decompressed 224.8 percent)
12:32:00:WU01:FS02:0xa4:Called DecompressByteArray: compressed_data_size=479112 data_size=1077356, decompressed_data_size=1077356 diff=0
12:32:00:WU01:FS02:0xa4:- Digital signature verified
12:32:00:WU01:FS02:0xa4:Project: 8046 (Run 0, Clone 36, Gen 43)
12:32:00:WU01:FS02:0xa4:Assembly optimizations on if available.
12:32:00:WU01:FS02:0xa4:Entering M.D.
12:32:01:WU00:FS00:News: Welcome to Folding@Home
12:32:01:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
12:32:01:ERROR:WU00:FS00:Exception: Could not get an assignment
12:32:01:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
12:32:01:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
12:32:01:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
12:32:06:WU01:FS02:0xa4:Using Gromacs checkpoints
12:32:06:WU01:FS02:0xa4:Mapping NT from 4 to 4
12:33:01:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
12:33:01:WU00:FS00:News: Welcome to Folding@Home
12:33:01:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
12:33:01:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
12:33:01:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
12:33:01:ERROR:WU00:FS00:Exception: Could not get an assignment
12:34:13:WU01:FS02:0xa4:Resuming from checkpoint
12:34:13:WU01:FS02:0xa4:Verified 01/wudata_01.log
12:34:13:WU01:FS02:0xa4:Verified 01/wudata_01.trr
12:34:13:WU01:FS02:0xa4:Verified 01/wudata_01.xtc
12:34:13:WU01:FS02:0xa4:Verified 01/wudata_01.edr
12:34:14:WU01:FS02:0xa4:Completed 51880 out of 250000 steps  (20%)
12:34:14:WARNING:WU01:FS02:Detected clock skew, adjusting time estimates
12:34:38:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
12:34:38:WU00:FS00:News: Welcome to Folding@Home
12:34:38:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
12:34:38:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
12:34:39:WU00:FS00:News: Welcome to Folding@Home
12:34:39:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
12:34:39:ERROR:WU00:FS00:Exception: Could not get an assignment
sgt_bombulous
Anyone?
Remove the setting <client-type v='beta'/>
sgt_bombulous
Nothin' :(. I don't get it, it gives up instantly on a download. It doesn't even seem to be trying.
