171.64.65.54
TomJohnson
Hardware configuration: F@H Info – V8.4.9 – 12 Machines – 123 CPUs - 1,000K+ PPD; 1/5/2025
Mac Pro 14,8, 24 CPUs, 256K PPD;
Mac Pro 5,1, 24 CPUs, 496K PPD;
Mac Studio 13,1, 10 CPUs, 146K PPD;
iMac Pro 1,1, 15 CPUs, 267K PPD;
iMac 18,2, 4 CPUs, 29K PPD;
iMac 14,1, 4 CPUs, 40K PPD;
Mac Book Pro 17,1, 8 CPUs, 166K PPD;
Mac Book Pro 13,3, 8 CPUs, 57K PPD;
Mac Book Air 5,2, 4 CPUs, 23K PPD;
Mac Mini 7,1, 4 CPUs, 9K PPD;
HP Pavilion, 12 CPUs, 105K PPD;
SONY VAIO, 8 CPUs, 44K PPD.
171.64.65.54
Post by TomJohnson »
I have been unable to obtain a new WU from 171.64.65.54 on three Macs for the past 12 hours.
[05:49:44] + Attempting to send results [June 17 05:49:44 UTC]
[05:49:44] - Reading file work/wuresults_04.dat from core
[05:49:44] + Attempting to get work packet
[05:49:44] Passkey found
[05:49:44] (Read 3794292 bytes from disk)
[05:49:44] - Will indicate memory of 16384 MB
[05:49:44] Connecting to http://171.64.65.54:8080/
[05:49:44] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 7, Stepping: 6
[05:49:44] - Connecting to assignment server
[05:49:44] Connecting to http://assign.stanford.edu:8080/
[05:49:45] Posted data.
[05:49:45] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[05:49:45] + Couldn't get work instructions.
[05:49:45] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[05:50:01] + Attempting to get work packet
[05:50:01] Passkey found
[05:50:01] - Will indicate memory of 16384 MB
[05:50:01] - Connecting to assignment server
[05:50:01] Connecting to http://assign.stanford.edu:8080/
[05:50:01] Posted data.
[05:50:01] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[05:50:01] + Couldn't get work instructions.
[05:50:01] - Attempt #2 to get work failed, and no other work to do.
[05:50:18] + Attempting
Mac Pro 14,8, 24 CPUs, 226K PPD;
iMac Pro 1,1. 15 CPUs, 267K PPD;
iMac 18,2, 4 CPUs, 29K PPD; + 7 more CPUs
TomJohnson
Re: 171.64.65.54
Follow up with another server:
[06:00:27] (171.64.65.54:80)
[06:00:27] - Error: Could not transmit unit 04 (completed June 16) to work server.
[06:00:27] - 10 failed uploads of this unit.
[06:00:27] + Attempting to send results [June 17 06:00:27 UTC]
[06:00:27] - Reading file work/wuresults_04.dat from core
[06:00:27] (Read 3794292 bytes from disk)
[06:00:27] Connecting to http://171.67.108.25:8080/
[06:00:27] - Couldn't send HTTP request to server
[06:00:27] + Could not connect to Work Server (results)
[06:00:27] (171.67.108.25:8080)
[06:00:27] + Retrying using alternative port
[06:00:27] Connecting to http://171.67.108.25:80/
[06:00:27] (171.67.108.25:80)
[06:00:27] Could not transmit unit 04 to Collection server; keeping in queue.
[06:00:27] + Sent 0 of 1 completed units to the server
[06:00:27] - Autosend completed
[06:01:20] + Attempting to get work packet
[06:01:20] Passkey found
[06:01:20] - Will indicate memory of 16384 MB
[06:01:20] - Connecting to assignment server
[06:01:20] Connecting to http://assign.stanford.edu:8080/
[06:01:21] Posted data.
[06:01:21] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[06:01:21] + Couldn't get work instructions.
[06:01:21] - Attempt #6 to get work failed, and no other work to do.
Penfold
Unable to connect
Post by Penfold »
Problems at the other end? Haven't seen this before.
The last two entries in the FAHlog.txt file:
[07:25:46] + Couldn't get work instructions.
[07:25:46] - Attempt #12 to get work failed, and no other work to do.
[08:13:49] + Attempting to get work packet
[08:13:49] Passkey found
[08:13:49] - Connecting to assignment server
[08:13:50] + No appropriate work server was available; will try again in a bit.
[08:13:50] + Couldn't get work instructions.
[08:13:50] - Attempt #13 to get work failed, and no other work to do.
[09:02:00] + Attempting to get work packet
[09:02:00] Passkey found
[09:02:00] - Connecting to assignment server
[09:02:02] + No appropriate work server was available; will try again in a bit.
[09:02:02] + Couldn't get work instructions.
[09:02:02] - Attempt #14 to get work failed, and no other work to do.
Edit: Connections to work servers mentioned in the log have been tried:
171.64.65.54:8080
171.64.65.54:80
171.67.108.25:8080
171.67.108.25:80
Entering http://171.64.65.54:8080 in my address bar returns a 'can't connect' message. It is the same for each of the others.
I just found this page containing the following server stats:
171.67.108.25 CS 5 vsp19v pande standby Not Accept
and
171.64.65.54 SMP vspg9b - full DOWN
Both of these servers are mentioned in the FAHlog.txt file
There is mention of "-verbosity 9 flag" on that troubleshooting page. What does that mean? I have no idea.
Is this something that normally has to wait until someone in charge notices it, or can I send a report to a specific address?
Ubuntu 18.04.4
F@H v 7.5.1
compdewd
Hardware configuration: [1] Debian 8 64-bit: EVGA NVIDIA GTX 650 Ti, MSI NVIDIA GTX 460, AMD FX-8120
[2] Windows 7 64-bit: MSI NVIDIA GTX 460, AMD Phenom II X4
Re: Unable to connect
Post by compdewd »
Someone else is having problems with those two servers too:
viewtopic.php?f=18&t=21831&view=unread#unread
compdewd
Re: 171.64.65.54
Post by compdewd »
Someone else is also having problems with those two servers:
viewtopic.php?f=6&t=21832
PS I linked you to each other
RonnyB
171.64.65.54 No WU's since yesterday morning or so ....
Post by RonnyB »
My MBPro was folding fine for past week, then since yesterday it's not having any luck getting jobs. Here is the last part of Terminal window:
1:24] + Attempting to get work packet
[06:21:24] Passkey found
[06:21:24] - Connecting to assignment server
[06:21:25] + No appropriate work server was available; will try again in a bit.
[06:21:25] + Couldn't get work instructions.
[06:21:25] - Attempt #5  to get work failed, and no other work to do.
[06:22:13] - Couldn't send HTTP request to server
[06:22:13] + Could not connect to Work Server (results)
[06:22:13]     (171.64.65.54:80)
[06:22:13] - Error: Could not transmit unit 07 (completed June 16) to work server.
[06:22:13] + Attempting to send results [June 17 06:22:13 UTC]
[06:22:13]     (171.67.108.25:8080)
[06:22:13] + Retrying using alternative port
[06:22:14] - Couldn't send HTTP request to server
[06:22:14] + Could not connect to Work Server (results)
[06:22:14]     (171.67.108.25:80)
[06:22:14]   Could not transmit unit 07 to Collection server; keeping in queue.
[06:22:52] + Attempting to get work packet
[06:22:52] Passkey found
[06:22:52] - Connecting to assignment server
[06:22:55] + No appropriate work server was available; will try again in a bit.
[06:22:55] + Couldn't get work instructions.
[06:22:55] - Attempt #6  to get work failed, and no other work to do.
[06:25:40] + Attempting to get work packet
[06:25:40] Passkey found
[06:25:40] - Connecting to assignment server
[06:25:43] + No appropriate work server was available; will try again in a bit.
[06:25:43] + Couldn't get work instructions.
[06:25:43] - Attempt #7  to get work failed, and no other work to do.
[06:31:13] + Attempting to get work packet
[06:31:13] Passkey found
[06:31:13] - Connecting to assignment server
[06:31:16] + No appropriate work server was available; will try again in a bit.
[06:31:16] + Couldn't get work instructions.
[06:31:16] - Attempt #8  to get work failed, and no other work to do.
[06:46:29] + Attempting to get work packet
[06:46:29] Passkey found
[06:46:29] - Connecting to assignment server
[06:46:32] + No appropriate work server was available; will try again in a bit.
[06:46:32] + Couldn't get work instructions.
[06:46:32] - Attempt #9  to get work failed, and no other work to do.
[07:43:10] + Attempting to get work packet
[07:43:10] Passkey found
[07:43:10] - Connecting to assignment server
[07:43:13] + No appropriate work server was available; will try again in a bit.
[07:43:13] + Couldn't get work instructions.
[07:43:13] - Attempt #10  to get work failed, and no other work to do.
Any suggestions?
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Re: 171.64.65.54 No WU's since yesterday morning or so ....
Post by Jesse_V »
http://fah-web.stanford.edu/pybeta/serverstat.html says that server is "Down" but also says it is in full operation. I'm still learning how to read the server status page, but I suppose you'll just have to wait until the server is fixed.
The Work Server that handles all uploads and downloads of work for Macs running the version 6 client (171.64.65.54) is listed as down on the server status page. All you can do is wait until the server is fixed and back up and then it should take your finished WU. The collection server for that work has been down for a long time and is not expected back until its software is upgraded.
If your MBPro is running 10.6, the beta Version 7 client may be an option for getting other work to do. But it will not handle uploading the WU just completed. That would take running V6 from the command line after the server is up, and disabling it in the meantime.
midnightdavid
Re: 171.64.65.54
Post by midnightdavid »
I've been having the same problem - for 24 hours or so. Can't upload finished work unit, can't get a new work unit either.
edit: neglected to paste this in...
[16:10:13] + Attempting to send results [June 17 16:10:13 UTC]
[16:10:13] - Reading file work/wuresults_00.dat from core
[16:10:13]   (Read 20549104 bytes from disk)
[16:10:13] Connecting to http://171.67.108.25:8080/
[16:10:13] - Couldn't send HTTP request to server
[16:10:13] + Could not connect to Work Server (results)
[16:10:13]     (171.67.108.25:8080)
[16:10:13] + Retrying using alternative port
[16:10:13] Connecting to http://171.67.108.25:80/
[16:10:14] - Couldn't send HTTP request to server
[16:10:14] + Could not connect to Work Server (results)
[16:10:14]     (171.67.108.25:80)
[16:10:14]   Could not transmit unit 00 to Collection server; keeping in queue.
[16:10:14] + Sent 0 of 2 completed units to the server
[16:10:14] - Autosend completed
[16:11:25] + Attempting to get work packet
[16:11:25] Passkey found
[16:11:25] - Will indicate memory of 8192 MB
[16:11:25] - Connecting to assignment server
[16:11:25] Connecting to http://assign.stanford.edu:8080/
[16:11:25] Posted data.
[16:11:25] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[16:11:25] + Couldn't get work instructions.
[16:11:25] - Attempt #7  to get work failed, and no other work to do.
[16:16:49] + Attempting to get work packet
[16:16:49] Passkey found
[16:16:49] - Will indicate memory of 8192 MB
[16:16:49] - Connecting to assignment server
[16:16:49] Connecting to http://assign.stanford.edu:8080/
[16:16:50] Posted data.
[16:16:50] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[16:16:50] + Couldn't get work instructions.
[16:16:50] - Attempt #8  to get work failed, and no other work to do.
Also reported here, viewtopic.php?f=16&t=21833.
Penfold
Re: 171.64.65.54
Post by Penfold »
I'm the other person having trouble with the same server. I should have posted here in your thread, but for some daft reason I started another one as you can see.
Anyway, the server stats page I found seems to explain why we're having problems, as I indicated in my post.
Ubuntu 18.04.4
F@H v 7.5.1
TomJohnson
Re: 171.64.65.54
As with other person experiencing this same problem -- I cannot connect to the IP addresses but I get an OK when connecting to the Assignment Server.
compdewd
Post by compdewd »
The verbosity level basically sets how detailed the log will be. v6 client goes up to 9 I believe and v7 goes up to 5.
I think this is something you should wait for. There are people in charge that get on this forum a lot and especially since multiple people have brought it up, they will figure it out. Maybe they even already know ;)
Penfold
Re: 171.64.65.54
Post by Penfold »
What's the IP address for the Assignment Server?
Ubuntu 18.04.4
F@H v 7.5.1
TomJohnson
Re: 171.64.65.54
See below:
Just double click on the above URL.
