*********************** Log Started 2012-06-09T06:51:10Z ***********************
06:51:10:************************* Folding@home Client *************************
06:51:10: Website: http://folding.stanford.edu/
06:51:10: Copyright: (c) 2009-2012 Stanford University
06:51:10: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:51:10: Args: --lifeline 1716 --command-port=36330
06:51:10: Config: C:/Documents and Settings/Patrick/Application
06:51:10: Data/FAHClient/config.xml
06:51:10:******************************** Build ********************************
06:51:10: Version: 7.1.52
06:51:10: Date: Mar 20 2012
06:51:10: Time: 19:37:42
06:51:10: SVN Rev: 3515
06:51:10: Branch: fah/trunk/client
06:51:10: Compiler: Intel(R) C++ MSVC 1500 mode 1200
06:51:10: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
06:51:10: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
06:51:10: Platform: win32 XP
06:51:10: Bits: 32
06:51:10: Mode: Release
06:51:10:******************************* System ********************************
06:51:10: CPU: AMD Sempron(tm) Processor 3100+
06:51:10: CPU ID: AuthenticAMD Family 15 Model 44 Stepping 2
06:51:10: CPUs: 1
06:51:10: Memory: 478.43MiB
06:51:10: Free Memory: 141.68MiB
06:51:10: Threads: WINDOWS_THREADS
06:51:10: On Battery: false
06:51:10: UTC offset: -4
06:51:10: PID: 3328
06:51:10: CWD: C:/Documents and Settings/Patrick/Application Data/FAHClient
06:51:10: OS: Microsoft Windows XP Service Pack 3
06:51:10: OS Arch: X86
06:51:10: GPUs: 1
06:51:10: GPU 0: UNSUPPORTED: C51G [GeForce 6100]
06:51:10: CUDA: Not detected
06:51:10:Win32 Service: false
06:51:10:***********************************************************************
06:51:10:<config>
06:51:10: <service-description v='Folding@home Client'/>
06:51:10: <service-restart v='true'/>
06:51:10: <service-restart-delay v='5000'/>
06:51:10:
06:51:10: <!-- Client Control -->
06:51:10: <cycle-rate v='4'/>
06:51:10: <cycles v='-1'/>
06:51:10: <data-directory v='.'/>
06:51:10: <disable-project-lookup v='false'/>
06:51:10: <exec-directory v='C:\Program Files\FAHClient'/>
06:51:10: <exit-when-done v='false'/>
06:51:10: <threads v='4'/>
06:51:10:
06:51:10: <!-- Configuration -->
06:51:10: <config-rotate v='true'/>
06:51:10: <config-rotate-dir v='configs'/>
06:51:10: <config-rotate-max v='16'/>
06:51:10:
06:51:10: <!-- Debugging -->
06:51:10: <assignment-servers>
06:51:10: assign3.stanford.edu:8080 assign4.stanford.edu:80
06:51:10: </assignment-servers>
06:51:10: <capture-directory v='capture'/>
06:51:10: <capture-sockets v='false'/>
06:51:10: <debug-sockets v='false'/>
06:51:10: <exception-locations v='true'/>
06:51:10: <gpu-assignment-servers>
06:51:10: assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
06:51:10: </gpu-assignment-servers>
06:51:10: <stack-traces v='false'/>
06:51:10:
06:51:10: <!-- Error Handling -->
06:51:10: <max-slot-errors v='5'/>
06:51:10: <max-unit-errors v='5'/>
06:51:10:
06:51:10: <!-- FahCore Control -->
06:51:10: <checkpoint v='10'/>
06:51:10: <core-dir v='cores'/>
06:51:10: <core-priority v='idle'/>
06:51:10: <cpu-affinity v='false'/>
06:51:10: <cpu-usage v='100'/>
06:51:10: <no-assembly v='false'/>
06:51:10:
06:51:10: <!-- Folding Slot Configuration -->
06:51:10: <client-subtype v='STDCLI'/>
06:51:10: <client-type v='normal'/>
06:51:10: <cpu-species v='X86_AMD'/>
06:51:10: <cpu-type v='X86'/>
06:51:10: <cpus v='-1'/>
06:51:10: <cuda-index v='0'/>
06:51:10: <gpu v='false'/>
06:51:10: <gpu-usage v='100'/>
06:51:10: <max-packet-size v='normal'/>
06:51:10: <opencl-index v='0'/>
06:51:10: <os-species v='WIN_XP'/>
06:51:10: <os-type v='WIN32'/>
06:51:10: <project-key v='0'/>
06:51:10: <smp v='false'/>
06:51:10:
06:51:10: <!-- Logging -->
06:51:10: <log v='log.txt'/>
06:51:10: <log-color v='false'/>
06:51:10: <log-crlf v='true'/>
06:51:10: <log-date v='false'/>
06:51:10: <log-date-periodically v='21600'/>
06:51:10: <log-debug v='true'/>
06:51:10: <log-domain v='false'/>
06:51:10: <log-header v='true'/>
06:51:10: <log-level v='true'/>
06:51:10: <log-no-info-header v='true'/>
06:51:10: <log-redirect v='false'/>
06:51:10: <log-rotate v='true'/>
06:51:10: <log-rotate-dir v='logs'/>
06:51:10: <log-rotate-max v='16'/>
06:51:10: <log-short-level v='false'/>
06:51:10: <log-simple-domains v='true'/>
06:51:10: <log-thread-id v='false'/>
06:51:10: <log-thread-prefix v='true'/>
06:51:10: <log-time v='true'/>
06:51:10: <log-to-screen v='true'/>
06:51:10: <log-truncate v='false'/>
06:51:10: <verbosity v='5'/>
06:51:10:
06:51:10: <!-- Network -->
06:51:10: <proxy v=':8080'/>
06:51:10: <proxy-enable v='false'/>
06:51:10: <proxy-pass v=''/>
06:51:10: <proxy-user v=''/>
06:51:10:
06:51:10: <!-- Process Control -->
06:51:10: <child v='false'/>
06:51:10: <daemon v='false'/>
06:51:10: <pid v='false'/>
06:51:10: <pid-file v='Folding@home Client.pid'/>
06:51:10: <respawn v='false'/>
06:51:10: <service v='false'/>
06:51:10:
06:51:10: <!-- Remote Command Server -->
06:51:10: <command-address v='0.0.0.0'/>
06:51:10: <command-allow v='127.0.0.1'/>
06:51:10: <command-allow-no-pass v='127.0.0.1'/>
06:51:10: <command-deny v='0.0.0.0/0'/>
06:51:10: <command-deny-no-pass v='0.0.0.0/0'/>
06:51:10: <command-port v='36330'/>
06:51:10:
06:51:10: <!-- Slot Control -->
06:51:10: <max-shutdown-wait v='60'/>
06:51:10: <pause-on-battery v='false'/>
06:51:10: <pause-on-start v='false'/>
06:51:10:
06:51:10: <!-- User Information -->
06:51:10: <machine-id v='0'/>
06:51:10: <passkey v='********************************'/>
06:51:10: <team v='0'/>
06:51:10: <user v='compdewd'/>
06:51:10:
06:51:10: <!-- Work Unit Control -->
06:51:10: <dump-after-deadline v='true'/>
06:51:10: <max-queue v='16'/>
06:51:10: <max-units v='0'/>
06:51:10: <next-unit-percentage v='99'/>
06:51:10:
06:51:10: <!-- Folding Slots -->
06:51:10: <slot id='0' type='UNIPROCESSOR'/>
06:51:10:</config>
06:51:10:Trying to access database...
06:51:11:Successfully acquired database lock
06:51:11:Enabled folding slot 00: READY uniprocessor
06:51:12:Started thread 1 on PID 3328
06:51:12:Started thread 3 on PID 3328
06:51:12:Started thread 4 on PID 3328
06:51:12:Started thread 5 on PID 3328
06:51:12:Started thread 6 on PID 3328
06:51:12:WU00:FS00:Starting
06:51:12:WU00:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/Patrick/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 00 -suffix 01 -version 701 -lifeline 3328 -checkpoint 10
06:51:14:WU00:FS00:Started FahCore on PID 3908
06:51:14:Started thread 7 on PID 3328
06:51:22:WU00:FS00:Core PID:1228
06:51:22:WU00:FS00:FahCore 0xa4 started
06:51:23:WU00:FS00:0xa4:
06:51:23:WU00:FS00:0xa4:*------------------------------*
06:51:23:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
06:51:23:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
06:51:23:WU00:FS00:0xa4:Preparing to commence simulation
06:51:23:WU00:FS00:0xa4:- Looking at optimizations...
06:51:23:WU00:FS00:0xa4:- Files status OK
06:51:23:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
06:51:23:Started thread 8 on PID 3328
06:51:24:WU00:FS00:0xa4:- Expanded 885857 -> 2026188 (decompressed 228.7 percent)
06:51:24:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=885857 data_size=2026188, decompressed_data_size=2026188 diff=0
06:51:24:WU00:FS00:0xa4:- Digital signature verified
06:51:24:WU00:FS00:0xa4:Project: 8013 (Run 230, Clone 39, Gen 14)
06:51:24:WU00:FS00:0xa4:Assembly optimizations on if available.
06:51:24:WU00:FS00:0xa4:Entering M.D.
06:51:31:WU00:FS00:0xa4:Using Gromacs checkpoints
06:51:31:WU00:FS00:0xa4:Mapping NT from 1 to 1
06:51:33:WU00:FS00:0xa4:Resuming from checkpoint
06:51:33:WU00:FS00:0xa4:Verified 00/wudata_01.log
06:51:33:WU00:FS00:0xa4:Verified 00/wudata_01.trr
06:51:33:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
06:51:33:WU00:FS00:0xa4:Verified 00/wudata_01.edr
06:51:35:WU00:FS00:0xa4:Completed 91210 out of 250000 steps (36%)
06:51:48:Saving configuration to config.xml
06:51:48:<config>
06:51:48: <!-- FahCore Control -->
06:51:48: <checkpoint v='10'/>
06:51:48:
06:51:48: <!-- Folding Slot Configuration -->
06:51:48: <smp v='false'/>
06:51:48:
06:51:48: <!-- Logging -->
06:51:48: <verbosity v='5'/>
06:51:48:
06:51:48: <!-- Network -->
06:51:48: <proxy v=':8080'/>
06:51:48:
06:51:48: <!-- User Information -->
06:51:48: <passkey v='********************************'/>
06:51:48: <user v='compdewd'/>
06:51:48:
06:51:48: <!-- Folding Slots -->
06:51:48: <slot id='0' type='UNIPROCESSOR'/>
06:51:48:</config>
06:52:06:Adding folding slot 01: READY gpu:0:"C51G [GeForce 6100]"
06:52:07:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
06:52:07:Saving configuration to config.xml
06:52:07:<config>
06:52:07: <!-- FahCore Control -->
06:52:07: <checkpoint v='10'/>
06:52:07:
06:52:07: <!-- Folding Slot Configuration -->
06:52:07: <smp v='false'/>
06:52:07:
06:52:07: <!-- Logging -->
06:52:07: <verbosity v='5'/>
06:52:07:
06:52:07: <!-- Network -->
06:52:07: <proxy v=':8080'/>
06:52:07:
06:52:07: <!-- User Information -->
06:52:07: <passkey v='********************************'/>
06:52:07: <user v='compdewd'/>
06:52:07:
06:52:07: <!-- Folding Slots -->
06:52:07: <slot id='0' type='UNIPROCESSOR'/>
06:52:07: <slot id='1' type='GPU'>
06:52:07: <gpu-index v='0'/>
06:52:07: </slot>
06:52:07:</config>
06:52:07:WU01:FS01:News: Welcome to Folding@Home
06:52:07:WARNING:WU01:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
06:52:07:WU01:FS01:Connecting to assign-GPU.stanford.edu:8080
06:52:08:WU01:FS01:News: Welcome to Folding@Home
06:52:08:WARNING:WU01:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
06:52:08:ERROR:WU01:FS01:Exception: Could not get an assignment
06:52:08:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
06:52:08:WARNING:WU01:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
06:52:08:WU01:FS01:Connecting to assign-GPU.stanford.edu:8080
06:53:08:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
06:53:08:WU01:FS01:News: Welcome to Folding@Home
06:53:08:WARNING:WU01:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
06:53:08:WU01:FS01:Connecting to assign-GPU.stanford.edu:8080
06:53:08:WARNING:WU01:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
06:53:08:ERROR:WU01:FS01:Exception: Could not get an assignment
06:54:45:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
06:54:45:WU01:FS01:News: Welcome to Folding@Home
06:54:45:WARNING:WU01:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
06:54:45:WU01:FS01:Connecting to assign-GPU.stanford.edu:8080
06:54:46:WU01:FS01:News: Welcome to Folding@Home
06:54:46:WARNING:WU01:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
06:54:46:ERROR:WU01:FS01:Exception: Could not get an assignment
06:57:22:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
06:57:22:WU01:FS01:News: Welcome to Folding@Home
06:57:23:WARNING:WU01:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
06:57:23:WU01:FS01:Connecting to assign-GPU.stanford.edu:8080
06:57:23:WU01:FS01:News: Welcome to Folding@Home
06:57:23:WARNING:WU01:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
06:57:23:ERROR:WU01:FS01:Exception: Could not get an assignment
07:01:37:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
07:01:37:WU01:FS01:News: Welcome to Folding@Home
07:01:37:WARNING:WU01:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
07:01:37:WU01:FS01:Connecting to assign-GPU.stanford.edu:8080
07:01:37:WARNING:WU01:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
07:01:37:ERROR:WU01:FS01:Exception: Could not get an assignment
07:05:20:WU00:FS00:0xa4:Completed 92500 out of 250000 steps (37%)
07:08:28:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
07:08:28:WU01:FS01:News: Welcome to Folding@Home
07:08:28:WARNING:WU01:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
07:08:28:WU01:FS01:Connecting to assign-GPU.stanford.edu:8080
07:08:28:WARNING:WU01:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
07:08:28:ERROR:WU01:FS01:Exception: Could not get an assignment
