Failed to connect to 171.67.108.11
mele
Post by mele »
Server 171.67.108.25 refusing wu.
10:45:45:WU00:FS01:0x11:
10:45:45:WU00:FS01:0x11:Assembly optimizations on if available.
10:45:45:WU00:FS01:0x11:Entering M.D.
10:45:45:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
10:45:45:WU02:FS01:Connecting to 171.67.108.11:80
10:45:46:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: No connection could be made because the target machine actively refused it.
10:45:46:WU02:FS01:Trying to send results to collection server
10:45:46:WU02:FS01:Uploading 93.82KiB to 171.67.108.25
10:45:46:WU02:FS01:Connecting to 171.67.108.25:8080
10:45:47:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
10:45:47:WU02:FS01:Connecting to 171.67.108.25:80
10:45:49:ERROR:WU02:FS01:Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
10:45:49:WU02:FS01:Sending unit results: id:02 state:SEND error:OK project:5767 run:5 clone:153 gen:4101 core:0x11 unit:0x05472c894fb375ca1005009900051687
10:45:49:WU02:FS01:Uploading 93.82KiB to 171.67.108.11
10:45:49:WU02:FS01:Connecting to 171.67.108.11:8080
10:45:50:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
10:45:50:WU02:FS01:Connecting to 171.67.108.11:80
10:45:50:WU00:FS01:0x11:Tpr hash 00/wudata_01.tpr:  1261844969 3417157528 954851288 2947144747 3781956822
10:45:50:WU00:FS01:0x11:Calling fah_main args: 14 usage=100
10:45:51:WU00:FS01:0x11:Working on Protein
10:45:51:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: No connection could be made because the target machine actively refused it.
10:45:51:WU02:FS01:Trying to send results to collection server
10:45:51:WU02:FS01:Uploading 93.82KiB to 171.67.108.25
10:45:51:WU02:FS01:Connecting to 171.67.108.25:8080
10:45:51:WU00:FS01:0x11:Client config unavailable.
10:45:52:WU00:FS01:0x11:Starting GUI Server
10:45:52:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
10:45:52:WU02:FS01:Connecting to 171.67.108.25:80
10:45:54:ERROR:WU02:FS01:Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
10:46:49:WU02:FS01:Sending unit results: id:02 state:SEND error:OK project:5767 run:5 clone:153 gen:4101 core:0x11 unit:0x05472c894fb375ca1005009900051687
10:46:49:WU02:FS01:Uploading 93.82KiB to 171.67.108.11
10:46:49:WU02:FS01:Connecting to 171.67.108.11:8080
10:46:50:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
10:46:50:WU02:FS01:Connecting to 171.67.108.11:80
10:46:51:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: No connection could be made because the target machine actively refused it.
10:46:51:WU02:FS01:Trying to send results to collection server
10:46:52:WU02:FS01:Uploading 93.82KiB to 171.67.108.25
10:46:52:WU02:FS01:Connecting to 171.67.108.25:8080
10:46:53:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
10:46:53:WU02:FS01:Connecting to 171.67.108.25:80
10:46:54:ERROR:WU02:FS01:Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
10:46:57:WU00:FS01:0x11:Completed 1%
10:48:04:WU00:FS01:0x11:Completed 2%
10:48:26:WU02:FS01:Sending unit results: id:02 state:SEND error:OK project:5767 run:5 clone:153 gen:4101 core:0x11 unit:0x05472c894fb375ca1005009900051687
10:48:26:WU02:FS01:Uploading 93.82KiB to 171.67.108.11
10:48:26:WU02:FS01:Connecting to 171.67.108.11:8080
10:48:33:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
10:48:33:WU02:FS01:Connecting to 171.67.108.11:80
10:48:34:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: No connection could be made because the target machine actively refused it.
10:48:34:WU02:FS01:Trying to send results to collection server
10:48:34:WU02:FS01:Uploading 93.82KiB to 171.67.108.25
10:48:34:WU02:FS01:Connecting to 171.67.108.25:8080
10:48:35:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
10:48:35:WU02:FS01:Connecting to 171.67.108.25:80
10:48:42:ERROR:WU02:FS01:Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
10:49:10:WU00:FS01:0x11:Completed 3%
10:49:26:WU01:FS00:0xa4:Completed 162500 out of 250000 steps  (65%)
10:50:16:WU00:FS01:0x11:Completed 4%
10:51:04:WU02:FS01:Sending unit results: id:02 state:SEND error:OK project:5767 run:5 clone:153 gen:4101 core:0x11 unit:0x05472c894fb375ca1005009900051687
10:51:04:WU02:FS01:Uploading 93.82KiB to 171.67.108.11
10:51:04:WU02:FS01:Connecting to 171.67.108.11:8080
10:51:05:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
10:51:05:WU02:FS01:Connecting to 171.67.108.11:80
10:51:06:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: No connection could be made because the target machine actively refused it.
10:51:06:WU02:FS01:Trying to send results to collection server
10:51:06:WU02:FS01:Uploading 93.82KiB to 171.67.108.25
10:51:06:WU02:FS01:Connecting to 171.67.108.25:8080
10:51:07:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
10:51:07:WU02:FS01:Connecting to 171.67.108.25:80
10:51:08:ERROR:WU02:FS01:Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
10:51:23:WU00:FS01:0x11:Completed 5%
10:52:29:WU00:FS01:0x11:Completed 6%
10:53:36:WU00:FS01:0x11:Completed 7%
10:54:38:WU01:FS00:0xa4:Completed 165000 out of 250000 steps  (66%)
10:54:42:WU00:FS01:0x11:Completed 8%
10:55:18:WU02:FS01:Sending unit results: id:02 state:SEND error:OK project:5767 run:5 clone:153 gen:4101 core:0x11 unit:0x05472c894fb375ca1005009900051687
10:55:18:WU02:FS01:Uploading 93.82KiB to 171.67.108.11
10:55:18:WU02:FS01:Connecting to 171.67.108.11:8080
10:55:19:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
10:55:19:WU02:FS01:Connecting to 171.67.108.11:80
10:55:20:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: No connection could be made because the target machine actively refused it.
10:55:20:WU02:FS01:Trying to send results to collection server
10:55:20:WU02:FS01:Uploading 93.82KiB to 171.67.108.25
10:55:20:WU02:FS01:Connecting to 171.67.108.25:8080
10:55:21:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
10:55:21:WU02:FS01:Connecting to 171.67.108.25:80
10:55:22:ERROR:WU02:FS01:Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
10:55:49:WU00:FS01:0x11:Completed 9%
10:56:55:WU00:FS01:0x11:Completed 10%
10:58:02:WU00:FS01:0x11:Completed 11%
10:59:08:WU00:FS01:0x11:Completed 12%
10:59:49:WU01:FS00:0xa4:Completed 167500 out of 250000 steps  (67%)
11:00:15:WU00:FS01:0x11:Completed 13%
11:01:21:WU00:FS01:0x11:Completed 14%
11:02:09:WU02:FS01:Sending unit results: id:02 state:SEND error:OK project:5767 run:5 clone:153 gen:4101 core:0x11 unit:0x05472c894fb375ca1005009900051687
11:02:09:WU02:FS01:Uploading 93.82KiB to 171.67.108.11
11:02:09:WU02:FS01:Connecting to 171.67.108.11:8080
11:02:10:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
11:02:10:WU02:FS01:Connecting to 171.67.108.11:80
11:02:11:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: No connection could be made because the target machine actively refused it.
11:02:11:WU02:FS01:Trying to send results to collection server
11:02:11:WU02:FS01:Uploading 93.82KiB to 171.67.108.25
11:02:11:WU02:FS01:Connecting to 171.67.108.25:8080
11:02:13:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
11:02:13:WU02:FS01:Connecting to 171.67.108.25:80
11:02:14:ERROR:WU02:FS01:Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
11:02:28:WU00:FS01:0x11:Completed 15%
11:03:34:WU00:FS01:0x11:Completed 16%
11:04:41:WU00:FS01:0x11:Completed 17%
11:05:03:WU01:FS00:0xa4:Completed 170000 out of 250000 steps  (68%)
11:05:47:WU00:FS01:0x11:Completed 18%
11:06:54:WU00:FS01:0x11:Completed 19%
11:08:00:WU00:FS01:0x11:Completed 20%
11:09:07:WU00:FS01:0x11:Completed 21%
11:10:13:WU01:FS00:0xa4:Completed 172500 out of 250000 steps  (69%)
11:10:13:WU00:FS01:0x11:Completed 22%
11:11:20:WU00:FS01:0x11:Completed 23%
11:12:26:WU00:FS01:0x11:Completed 24%
11:13:15:WU02:FS01:Sending unit results: id:02 state:SEND error:OK project:5767 run:5 clone:153 gen:4101 core:0x11 unit:0x05472c894fb375ca1005009900051687
11:13:15:WU02:FS01:Uploading 93.82KiB to 171.67.108.11
11:13:15:WU02:FS01:Connecting to 171.67.108.11:8080
11:13:16:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
11:13:16:WU02:FS01:Connecting to 171.67.108.11:80
11:13:17:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: No connection could be made because the target machine actively refused it.
11:13:17:WU02:FS01:Trying to send results to collection server
11:13:17:WU02:FS01:Uploading 93.82KiB to 171.67.108.25
11:13:17:WU02:FS01:Connecting to 171.67.108.25:8080
11:13:18:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
11:13:18:WU02:FS01:Connecting to 171.67.108.25:80
11:13:19:ERROR:WU02:FS01:Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
Reason: Added [code] tags and changed title.
Re: Failed to connect to 171.67.108.25:80:
Welcome to foldingforum.org, mele.
I'm changing the title of this topic. Server 171.67.108.11 is the Work Server that we need to focus on, not the Collection Server 171.67.108.25. In fact, if either is working, that should be enough, and several of the Collection Servers are permanently off-line. You'll find that information in the topic "Do this first" at the top of this forum.
What happens when you open http://171.67.108.11 from your browser? I am able to open it from here. If it's accessible through your browser but not through FAH, it's a problem with your security software blocking the FAH client from making outgoing connections.
mele
Re: Failed to connect to 171.67.108.11
Post by mele »
Well....... may be a problem with my passkey setup on that paticular system? I forgot to input my passkey in the config of that system.
That is the only thing I've changed on my systems yesterday.
Passkey would not keep your system from connecting and uploading a WU. Lack of a passkey or adding it would only effect points awarded for the Quick Return Bonus or meeting the established requisites to get the QRB points.
bollix47
Post by bollix47 »
The log for server 171.67.108.11 shows that it had a Reject status around the time you were trying to upload which would explain the client's attempt to use the collection server. I doubt there's anything wrong at your end and the collection server is a known issue. Not much you can do when it happens but wait for the work server problem to be resolved. Reporting the problem is always a good idea in case nobody at Stanford realizes there's something going on with their server. IIRC there is an automatic script that runs on the server to reset some reject conditions but it takes an hour or so before that solution 'kicks in'.
As Joe mentioned the passkey has nothing to do with communication problems and since this is a GPU server it doesn't even matter if a passkey is used or not because GPU WUs do not receive a bonus ... yet. :wink:
mele
Post by mele »
Thanks for the response.
I was just wondering about the passkey because I was not sure how it worked.
However, I asked because as soon and I entered it into this system the WU went through...
Just coincidence I guess....
Mel
