GPU Core Crashes (Or at least it doesn't work)
tlapaso
Post by tlapaso »
Hello,
The basic problem is that the GPU core is not working (although SMP seems fine). The same exact problem occurs on two very different computers.
I did a fresh install of the v7.1.52 client and accepted all the default options. On both computers, the GPU is recognized by the FaH client as “Cedar PRO [Radeon HD 5450]”. Additionally, GPU-Z recognizes it as the a "Radeon HD5450".
A few minutes after installation, the GPU slot displays a big red "FAILED" message. Below is a partial listing of the log. You'll see there are a lot of errors related to the GPU core.
Does anyone have a solution to this? It seems unlikely that both the FaH client and GPU-Z mis-identify the GPU.
*********************** Log Started 2012-04-13T16:17:10Z ***********************
16:17:10:************************* Folding@home Client *************************
16:17:10:      Website: http://folding.stanford.edu/
16:17:10:    Copyright: (c) 2009-2012 Stanford University
16:17:10:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:17:10:         Args:
16:17:10:       Config: C:/ProgramData/FAHClient/config.xml
16:17:10:******************************** Build ********************************
16:17:10:      Version: 7.1.52
16:17:10:         Date: Mar 20 2012
16:17:10:         Time: 19:37:42
16:17:10:      SVN Rev: 3515
16:17:10:       Branch: fah/trunk/client
16:17:10:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
16:17:10:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
16:17:10:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
16:17:10:     Platform: win32 XP
16:17:10:         Bits: 32
16:17:10:         Mode: Release
16:17:10:******************************* System ********************************
16:17:10:          CPU: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
16:17:10:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
16:17:10:         CPUs: 8
16:17:10:       Memory: 9.98GiB
16:17:10:  Free Memory: 8.81GiB
16:17:10:      Threads: WINDOWS_THREADS
16:17:10:   On Battery: false
16:17:10:   UTC offset: -5
16:17:10:          PID: 2544
16:17:10:          CWD: C:/Windows/system32
16:17:10:           OS: Windows 7 Professional
16:17:10:      OS Arch: AMD64
16:17:10:         GPUs: 1
16:17:10:        GPU 0: ATI:4 Cedar PRO [Radeon HD 5450]
16:17:10:         CUDA: Not detected
16:17:10:Win32 Service: true
16:17:10:***********************************************************************
16:17:10:<config>
16:17:10:  <!-- FahCore Control -->
16:17:10:  <checkpoint v='5'/>
16:17:10:
16:17:10:  <!-- Folding Slot Configuration -->
16:17:10:  <gpu v='true'/>
16:17:10:
16:17:10:  <!-- Network -->
16:17:10:  <proxy v=':8080'/>
16:17:10:
16:17:10:  <!-- Folding Slots -->
16:17:10:  <slot id='1' type='SMP'/>
16:17:10:  <slot id='0' type='GPU'/>
16:17:10:</config>
16:17:10:Trying to access database...
16:17:11:Successfully acquired database lock
16:17:11:Enabled folding slot 01: READY smp:8
16:17:11:Enabled folding slot 00: READY gpu:0:"Cedar PRO [Radeon HD 5450]"
16:17:11:WU01:FS01:Starting
16:17:11:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -np 8 -service
16:17:12:WU01:FS01:Started FahCore on PID 2764
16:17:15:WU01:FS01:Core PID:2900
16:17:15:WU01:FS01:FahCore 0xa4 started
16:17:16:WU01:FS01:0xa4:
16:17:16:WU01:FS01:0xa4:*------------------------------*
16:17:16:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
16:17:16:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
16:17:16:WU01:FS01:0xa4:Preparing to commence simulation
16:17:16:WU01:FS01:0xa4:- Looking at optimizations...
16:17:16:WU01:FS01:0xa4:- Files status OK
16:17:16:WU01:FS01:0xa4:- Expanded 652339 -> 1008860 (decompressed 154.6 percent)
16:17:16:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=652339 data_size=1008860, decompressed_data_size=1008860 diff=0
16:17:16:WU01:FS01:0xa4:- Digital signature verified
16:17:16:WU01:FS01:0xa4:Project: 7903 (Run 171, Clone 5, Gen 23)
16:17:16:WU01:FS01:0xa4:Assembly optimizations on if available.
16:17:16:WU01:FS01:0xa4:Entering M.D.
16:17:16:WU02:FS00:Starting
16:17:16:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -gpu 0 -service
16:17:16:WU02:FS00:Started FahCore on PID 2924
16:17:17:WU02:FS00:Core PID:2956
16:17:17:WU02:FS00:FahCore 0x16 started
16:17:17:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
16:17:17:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:17:17:WU02:FS00:Starting
16:17:17:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -gpu 0 -service
16:17:17:WU02:FS00:Started FahCore on PID 2964
16:17:17:WU02:FS00:Core PID:2992
16:17:18:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
16:17:18:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:17:22:WU01:FS01:0xa4:Using Gromacs checkpoints
16:17:22:WU01:FS01:0xa4:Mapping NT from 8 to 8
16:17:22:WU01:FS01:0xa4:Resuming from checkpoint
16:17:22:WU01:FS01:0xa4:Verified 01/wudata_01.log
16:17:28:WU01:FS01:0xa4:Verified 01/wudata_01.trr
16:17:28:WU01:FS01:0xa4:Verified 01/wudata_01.edr
16:17:28:WU01:FS01:0xa4:Completed 757860 out of 2500000 steps  (30%)
16:17:44:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
16:18:17:WU02:FS00:Starting
16:18:17:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -gpu 0 -service
16:18:17:WU02:FS00:Started FahCore on PID 3948
16:18:18:WU02:FS00:Core PID:4008
16:18:18:WU02:FS00:FahCore 0x16 started
16:18:18:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
16:18:18:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:18:18:WARNING:WU02:FS00:Too many errors, failing
16:18:18:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:11293 run:14 clone:493 gen:6 core:0x16 unit:0x0000008d6652edbc4d9258b53c61de68
16:18:19:WU02:FS00:Connecting to 171.67.108.44:8080
16:18:19:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
16:18:19:WU00:FS00:News: Welcome to Folding@Home
16:18:19:WU00:FS00:Assigned to work server 171.67.108.44
16:18:19:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"Cedar PRO [Radeon HD 5450]" from 171.67.108.44
16:18:19:WU00:FS00:Connecting to 171.67.108.44:8080
16:18:19:WU02:FS00:Server responded WORK_QUIT (404)
16:18:19:WARNING:WU02:FS00:Server did not like results, dumping
16:18:20:WU02:FS00:Cleaning up
16:18:21:WU00:FS00:Downloading 44.27KiB
16:18:21:WU00:FS00:Download complete
16:18:21:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:OK project:11293 run:3 clone:288 gen:6 core:0x16 unit:0x000000e96652edbc4d9256659b4e09c0
16:18:21:WU00:FS00:Starting
16:18:21:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -gpu 0 -service
16:18:21:WU00:FS00:Started FahCore on PID 1076
16:18:21:WU00:FS00:Core PID:2552
16:18:21:WU00:FS00:FahCore 0x16 started
16:18:21:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
16:18:21:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:18:22:WU00:FS00:Starting
16:18:22:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -gpu 0 -service
16:18:22:WU00:FS00:Started FahCore on PID 2332
16:18:22:WU00:FS00:Core PID:3800
16:18:22:WU00:FS00:FahCore 0x16 started
16:18:22:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
16:18:22:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:19:22:WU00:FS00:Starting
16:19:22:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -gpu 0 -service
16:19:22:WU00:FS00:Started FahCore on PID 4296
16:19:22:WU00:FS00:Core PID:4324
16:19:22:WU00:FS00:FahCore 0x16 started
16:19:22:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
16:19:22:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:20:59:WU00:FS00:Starting
16:20:59:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -gpu 0 -service
16:20:59:WU00:FS00:Started FahCore on PID 1364
16:20:59:WU00:FS00:Core PID:4392
16:20:59:WU00:FS00:FahCore 0x16 started
16:21:00:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
16:21:00:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:21:51:WU01:FS01:0xa4:Completed 775000 out of 2500000 steps  (31%)
16:23:36:WU00:FS00:Starting
16:23:36:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -gpu 0 -service
16:23:36:WU00:FS00:Started FahCore on PID 6512
16:23:36:WU00:FS00:Core PID:3652
16:23:36:WU00:FS00:FahCore 0x16 started
16:23:37:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
16:23:37:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:23:37:WARNING:WU00:FS00:Too many errors, failing
16:23:37:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:11293 run:3 clone:288 gen:6 core:0x16 unit:0x000000e96652edbc4d9256659b4e09c0
16:23:37:WU00:FS00:Connecting to 171.67.108.44:8080
16:23:37:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
16:23:37:WU02:FS00:News: Welcome to Folding@Home
16:23:37:WU02:FS00:Assigned to work server 171.67.108.44
16:23:37:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"Cedar PRO [Radeon HD 5450]" from 171.67.108.44
16:23:37:WU02:FS00:Connecting to 171.67.108.44:8080
16:23:38:ERROR:WU02:FS00:Exception: 10001: Server responded: HTTP_INTERNAL_SERVER_ERROR
16:23:38:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
16:23:38:WU02:FS00:News: Welcome to Folding@Home
16:23:38:WU02:FS00:Assigned to work server 171.67.108.44
16:23:38:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"Cedar PRO [Radeon HD 5450]" from 171.67.108.44
16:23:38:WU02:FS00:Connecting to 171.67.108.44:8080
16:23:41:WU00:FS00:Server responded WORK_QUIT (404)
16:23:41:WARNING:WU00:FS00:Server did not like results, dumping
16:23:41:WU00:FS00:Cleaning up
16:24:38:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
16:24:38:WU02:FS00:News: Welcome to Folding@Home
16:24:38:WU02:FS00:Assigned to work server 171.67.108.44
16:24:38:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"Cedar PRO [Radeon HD 5450]" from 171.67.108.44
16:24:38:WU02:FS00:Connecting to 171.67.108.44:8080
16:24:39:WU02:FS00:Downloading 44.24KiB
16:24:39:WU02:FS00:Download complete
16:24:39:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:OK project:11293 run:22 clone:242 gen:5 core:0x16 unit:0x000000b86652edbc4d94b95d92b5eee9
16:24:39:WU02:FS00:Starting
16:24:39:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -gpu 0 -service
16:24:39:WU02:FS00:Started FahCore on PID 6876
16:24:39:WU02:FS00:Core PID:4792
16:24:39:WU02:FS00:FahCore 0x16 started
16:24:39:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
16:24:39:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:24:40:WU02:FS00:Starting
16:24:40:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -gpu 0 -service
16:24:40:WU02:FS00:Started FahCore on PID 4852
16:24:40:WU02:FS00:Core PID:7144
16:24:40:WU02:FS00:FahCore 0x16 started
16:24:40:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
16:24:40:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:25:40:WU02:FS00:Starting
16:25:40:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -gpu 0 -service
16:25:40:WU02:FS00:Started FahCore on PID 2596
16:25:40:WU02:FS00:Core PID:4404
16:25:40:WU02:FS00:FahCore 0x16 started
16:25:40:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
16:25:40:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:27:17:WU02:FS00:Starting
16:27:17:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -gpu 0 -service
16:27:17:WU02:FS00:Started FahCore on PID 2944
16:27:17:WU02:FS00:Core PID:3636
16:27:17:WU02:FS00:FahCore 0x16 started
16:27:17:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
16:27:17:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:29:05:WU01:FS01:0xa4:Completed 800000 out of 2500000 steps  (32%)
16:29:54:WU02:FS00:Starting
16:29:54:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -gpu 0 -service
16:29:54:WU02:FS00:Started FahCore on PID 6228
16:29:54:WU02:FS00:Core PID:5152
16:29:54:WU02:FS00:FahCore 0x16 started
16:29:55:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
16:29:55:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:29:55:WARNING:WU02:FS00:Too many errors, failing
16:29:55:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:11293 run:22 clone:242 gen:5 core:0x16 unit:0x000000b86652edbc4d94b95d92b5eee9
16:29:55:WU02:FS00:Connecting to 171.67.108.44:8080
16:29:55:WU02:FS00:Server responded WORK_QUIT (404)
16:29:55:WARNING:WU02:FS00:Server did not like results, dumping
16:29:55:WU02:FS00:Cleaning up
16:29:55:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
16:29:55:WU00:FS00:News: Welcome to Folding@Home
16:29:55:WU00:FS00:Assigned to work server 171.67.108.44
16:29:55:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"Cedar PRO [Radeon HD 5450]" from 171.67.108.44
16:29:55:WU00:FS00:Connecting to 171.67.108.44:8080
16:29:56:WU00:FS00:Downloading 44.26KiB
16:29:56:WU00:FS00:Download complete
16:29:56:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:OK project:11293 run:26 clone:313 gen:6 core:0x16 unit:0x000000ae6652edbc4d94ba50fb21f006
16:29:56:WU00:FS00:Starting
16:29:56:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -gpu 0 -service
16:29:56:WU00:FS00:Started FahCore on PID 5612
16:29:56:WU00:FS00:Core PID:5008
16:29:56:WU00:FS00:FahCore 0x16 started
16:29:57:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
16:29:57:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:29:57:WU00:FS00:Starting
16:29:57:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -gpu 0 -service
16:29:57:WU00:FS00:Started FahCore on PID 6384
16:29:57:WU00:FS00:Core PID:724
16:29:57:WU00:FS00:FahCore 0x16 started
16:29:58:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
16:29:58:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:30:57:WU00:FS00:Starting
16:30:57:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -gpu 0 -service
16:30:57:WU00:FS00:Started FahCore on PID 376
16:30:57:WU00:FS00:Core PID:388
16:30:57:WU00:FS00:FahCore 0x16 started
16:30:58:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
16:30:58:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:32:34:WU00:FS00:Starting
16:32:34:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -gpu 0 -service
16:32:34:WU00:FS00:Started FahCore on PID 4960
16:32:34:WU00:FS00:Core PID:4972
16:32:34:WU00:FS00:FahCore 0x16 started
16:32:35:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
16:32:35:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:35:12:WU00:FS00:Starting
16:35:12:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -gpu 0 -service
16:35:12:WU00:FS00:Started FahCore on PID 3540
16:35:12:WU00:FS00:Core PID:4228
16:35:12:WU00:FS00:FahCore 0x16 started
16:35:12:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
16:35:12:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:35:12:WARNING:WU00:FS00:Too many errors, failing
16:35:12:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:11293 run:26 clone:313 gen:6 core:0x16 unit:0x000000ae6652edbc4d94ba50fb21f006
16:35:12:WU00:FS00:Connecting to 171.67.108.44:8080
16:35:13:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
16:35:13:WU00:FS00:Server responded WORK_QUIT (404)
16:35:13:WARNING:WU00:FS00:Server did not like results, dumping
16:35:13:WU01:FS01:0xa4:Completed 825000 out of 2500000 steps  (33%)
16:35:13:WU00:FS00:Cleaning up
16:35:13:WU02:FS00:News: Welcome to Folding@Home
16:35:13:WU02:FS00:Assigned to work server 171.67.108.44
16:35:13:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"Cedar PRO [Radeon HD 5450]" from 171.67.108.44
16:35:13:WU02:FS00:Connecting to 171.67.108.44:8080
16:35:14:WU02:FS00:Downloading 44.40KiB
16:35:14:WU02:FS00:Download complete
16:35:14:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:OK project:11293 run:13 clone:491 gen:6 core:0x16 unit:0x000000516652edbc4d9258886214ed17
16:35:14:WU02:FS00:Starting
16:35:14:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -gpu 0 -service
16:35:14:WU02:FS00:Started FahCore on PID 376
16:35:14:WU02:FS00:Core PID:4824
16:35:14:WU02:FS00:FahCore 0x16 started
16:35:15:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
16:35:15:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:35:15:WU02:FS00:Starting
16:35:15:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -gpu 0 -service
16:35:15:WU02:FS00:Started FahCore on PID 6712
16:35:15:WU02:FS00:Core PID:2388
16:35:15:WU02:FS00:FahCore 0x16 started
16:36:15:WU02:FS00:Starting
16:36:15:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -gpu 0 -service
16:36:15:WU02:FS00:Started FahCore on PID 1932
16:36:15:WU02:FS00:Core PID:3612
16:36:15:WU02:FS00:FahCore 0x16 started
16:36:15:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
16:36:15:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:37:52:WU02:FS00:Starting
16:37:52:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -gpu 0 -service
16:37:52:WU02:FS00:Started FahCore on PID 6600
16:37:52:WU02:FS00:Core PID:1208
16:37:52:WU02:FS00:FahCore 0x16 started
16:37:53:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
16:37:53:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:40:29:WU02:FS00:Starting
16:40:29:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -gpu 0 -service
16:40:29:WU02:FS00:Started FahCore on PID 4636
16:40:29:WU02:FS00:Core PID:4792
16:40:29:WU02:FS00:FahCore 0x16 started
16:40:30:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741515 = 0xc0000135)
16:40:30:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:40:30:WARNING:WU02:FS00:Too many errors, failing
16:40:30:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:11293 run:13 clone:491 gen:6 core:0x16 unit:0x000000516652edbc4d9258886214ed17
16:40:30:WU02:FS00:Connecting to 171.67.108.44:8080
16:40:30:WU02:FS00:Server responded WORK_QUIT (404)
16:40:30:WARNING:WU02:FS00:Server did not like results, dumping
16:40:30:WU02:FS00:Cleaning up
16:41:17:WU01:FS01:0xa4:Completed 850000 out of 2500000 steps  (34%)
16:48:06:WU01:FS01:0xa4:Completed 875000 out of 2500000 steps  (35%)
16:53:46:WU01:FS01:0xa4:Completed 900000 out of 2500000 steps  (36%)
16:59:22:WU01:FS01:0xa4:Completed 925000 out of 2500000 steps  (37%)
17:04:53:WU01:FS01:0xa4:Completed 950000 out of 2500000 steps  (38%)
17:14:50:WU01:FS01:0xa4:Completed 975000 out of 2500000 steps  (39%)
17:20:41:WU01:FS01:0xa4:Completed 1000000 out of 2500000 steps  (40%)
17:26:01:WU01:FS01:0xa4:Completed 1025000 out of 2500000 steps  (41%)
17:31:30:WU01:FS01:0xa4:Completed 1050000 out of 2500000 steps  (42%)
17:36:54:WU01:FS01:0xa4:Completed 1075000 out of 2500000 steps  (43%)
17:42:24:WU01:FS01:0xa4:Completed 1100000 out of 2500000 steps  (44%)
17:47:56:WU01:FS01:0xa4:Completed 1125000 out of 2500000 steps  (45%)
17:53:21:WU01:FS01:0xa4:Completed 1150000 out of 2500000 steps  (46%)
17:58:59:WU01:FS01:0xa4:Completed 1175000 out of 2500000 steps  (47%)
18:04:32:WU01:FS01:0xa4:Completed 1200000 out of 2500000 steps  (48%)
18:09:57:WU01:FS01:0xa4:Completed 1225000 out of 2500000 steps  (49%)
18:15:24:WU01:FS01:0xa4:Completed 1250000 out of 2500000 steps  (50%)
18:21:07:WU01:FS01:0xa4:Completed 1275000 out of 2500000 steps  (51%)
18:26:32:WU01:FS01:0xa4:Completed 1300000 out of 2500000 steps  (52%)
18:32:22:WU01:FS01:0xa4:Completed 1325000 out of 2500000 steps  (53%)
18:38:08:WU01:FS01:0xa4:Completed 1350000 out of 2500000 steps  (54%)
18:43:53:WU01:FS01:0xa4:Completed 1375000 out of 2500000 steps  (55%)
18:49:26:WU01:FS01:0xa4:Completed 1400000 out of 2500000 steps  (56%)
18:54:59:WU01:FS01:0xa4:Completed 1425000 out of 2500000 steps  (57%)
19:00:37:WU01:FS01:0xa4:Completed 1450000 out of 2500000 steps  (58%)
19:06:16:WU01:FS01:0xa4:Completed 1475000 out of 2500000 steps  (59%)
19:11:49:WU01:FS01:0xa4:Completed 1500000 out of 2500000 steps  (60%)
19:17:30:WU01:FS01:0xa4:Completed 1525000 out of 2500000 steps  (61%)
19:23:03:WU01:FS01:0xa4:Completed 1550000 out of 2500000 steps  (62%)
19:28:52:WU01:FS01:0xa4:Completed 1575000 out of 2500000 steps  (63%)
19:36:34:WU01:FS01:0xa4:Completed 1600000 out of 2500000 steps  (64%)
19:45:19:WU01:FS01:0xa4:Completed 1625000 out of 2500000 steps  (65%)
19:52:00:WU01:FS01:0xa4:Completed 1650000 out of 2500000 steps  (66%)
19:58:02:WU01:FS01:0xa4:Completed 1675000 out of 2500000 steps  (67%)
20:03:52:WU01:FS01:0xa4:Completed 1700000 out of 2500000 steps  (68%)
20:10:04:WU01:FS01:0xa4:Completed 1725000 out of 2500000 steps  (69%)
20:15:57:WU01:FS01:0xa4:Completed 1750000 out of 2500000 steps  (70%)
20:22:03:WU01:FS01:0xa4:Completed 1775000 out of 2500000 steps  (71%)
20:29:35:WU01:FS01:0xa4:Completed 1800000 out of 2500000 steps  (72%)
20:35:56:WU01:FS01:0xa4:Completed 1825000 out of 2500000 steps  (73%)
20:42:15:WU01:FS01:0xa4:Completed 1850000 out of 2500000 steps  (74%)
20:48:22:WU01:FS01:0xa4:Completed 1875000 out of 2500000 steps  (75%)
20:54:28:WU01:FS01:0xa4:Completed 1900000 out of 2500000 steps  (76%)
21:00:30:WU01:FS01:0xa4:Completed 1925000 out of 2500000 steps  (77%)
21:06:33:WU01:FS01:0xa4:Completed 1950000 out of 2500000 steps  (78%)
21:19:04:WU01:FS01:0xa4:Completed 1975000 out of 2500000 steps  (79%)
21:33:53:WU01:FS01:0xa4:Completed 2000000 out of 2500000 steps  (80%)
21:40:39:WU01:FS01:0xa4:Completed 2025000 out of 2500000 steps  (81%)
21:46:34:WU01:FS01:0xa4:Completed 2050000 out of 2500000 steps  (82%)
21:52:20:WU01:FS01:0xa4:Completed 2075000 out of 2500000 steps  (83%)
21:58:05:WU01:FS01:0xa4:Completed 2100000 out of 2500000 steps  (84%)
22:04:04:WU01:FS01:0xa4:Completed 2125000 out of 2500000 steps  (85%)
22:09:54:WU01:FS01:0xa4:Completed 2150000 out of 2500000 steps  (86%)
22:15:41:WU01:FS01:0xa4:Completed 2175000 out of 2500000 steps  (87%)
******************************** Date: 13/04/12 ********************************
22:21:27:WU01:FS01:0xa4:Completed 2200000 out of 2500000 steps  (88%)
22:27:12:WU01:FS01:0xa4:Completed 2225000 out of 2500000 steps  (89%)
22:33:09:WU01:FS01:0xa4:Completed 2250000 out of 2500000 steps  (90%)
22:38:58:WU01:FS01:0xa4:Completed 2275000 out of 2500000 steps  (91%)
22:44:41:WU01:FS01:0xa4:Completed 2300000 out of 2500000 steps  (92%)
22:50:26:WU01:FS01:0xa4:Completed 2325000 out of 2500000 steps  (93%)
22:56:11:WU01:FS01:0xa4:Completed 2350000 out of 2500000 steps  (94%)
23:02:04:WU01:FS01:0xa4:Completed 2375000 out of 2500000 steps  (95%)
23:07:53:WU01:FS01:0xa4:Completed 2400000 out of 2500000 steps  (96%)
23:13:39:WU01:FS01:0xa4:Completed 2425000 out of 2500000 steps  (97%)
23:19:22:WU01:FS01:0xa4:Completed 2450000 out of 2500000 steps  (98%)
23:25:08:WU01:FS01:0xa4:Completed 2475000 out of 2500000 steps  (99%)
23:25:09:WU00:FS01:Connecting to assign3.stanford.edu:8080
23:25:10:WU00:FS01:News: Welcome to Folding@Home
23:25:10:WU00:FS01:Assigned to work server 128.113.12.161
23:25:10:WU00:FS01:Requesting new work unit for slot 01: RUNNING smp:8 from 128.113.12.161
23:25:10:WU00:FS01:Connecting to 128.113.12.161:8080
23:25:10:WU00:FS01:Downloading 646.31KiB
23:25:11:WU00:FS01:Download complete
23:25:11:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:OK project:7903 run:211 clone:0 gen:16 core:0xa4 unit:0x0000001300ac9c214e4d2c7c204793f4
23:31:04:WU01:FS01:0xa4:Completed 2500000 out of 2500000 steps  (100%)
23:31:04:WU01:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
23:31:14:WU01:FS01:0xa4:
23:31:14:WU01:FS01:0xa4:Finished Work Unit:
23:31:15:WU01:FS01:0xa4:- Reading up to 35910936 from "01/wudata_01.trr": Read 35910936
23:31:15:WU01:FS01:0xa4:trr file hash check passed.
23:31:15:WU01:FS01:0xa4:edr file hash check passed.
23:31:15:WU01:FS01:0xa4:logfile size: 62697
23:31:15:WU01:FS01:0xa4:Leaving Run
23:31:16:WU01:FS01:0xa4:- Writing 36003549 bytes of core data to disk...
23:31:23:WU01:FS01:0xa4:Done: 36003037 -> 30214443 (compressed to 83.9 percent)
23:31:23:WU01:FS01:0xa4:  ... Done.
23:31:26:WU01:FS01:0xa4:- Shutting down core
23:31:26:WU01:FS01:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
23:31:26:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
23:31:27:WU01:FS01:Sending unit results: id:01 state:SEND error:OK project:7903 run:171 clone:5 gen:23 core:0xa4 unit:0x0000001a00ac9c214eca689ba183ab78
23:31:27:WU01:FS01:Uploading 28.82MiB to 128.113.12.161
23:31:27:WU00:FS01:Starting
23:31:27:WU01:FS01:Connecting to 128.113.12.161:8080
23:31:27:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -np 8 -service
23:31:27:WU00:FS01:Started FahCore on PID 7428
23:31:27:WU00:FS01:Core PID:5904
23:31:27:WU00:FS01:FahCore 0xa4 started
23:31:28:WU00:FS01:0xa4:
23:31:28:WU00:FS01:0xa4:*------------------------------*
23:31:28:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
23:31:28:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
23:31:28:WU00:FS01:0xa4:Preparing to commence simulation
23:31:28:WU00:FS01:0xa4:- Looking at optimizations...
23:31:28:WU00:FS01:0xa4:- Created dyn
23:31:28:WU00:FS01:0xa4:- Files status OK
23:31:28:WU00:FS01:0xa4:- Expanded 661307 -> 1008860 (decompressed 152.5 percent)
23:31:28:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=661307 data_size=1008860, decompressed_data_size=1008860 diff=0
23:31:28:WU00:FS01:0xa4:- Digital signature verified
23:31:28:WU00:FS01:0xa4:Project: 7903 (Run 211, Clone 0, Gen 16)
23:31:28:WU00:FS01:0xa4:Assembly optimizations on if available.
23:31:28:WU00:FS01:0xa4:Entering M.D.
23:31:33:WU01:FS01:Upload 5.42%
23:31:33:WU00:FS01:0xa4:Mapping NT from 8 to 8
23:31:33:WU00:FS01:0xa4:Completed 0 out of 2500000 steps  (0%)
23:31:39:WU01:FS01:Upload 10.84%
23:31:45:WU01:FS01:Upload 16.70%
23:31:51:WU01:FS01:Upload 22.34%
23:31:57:WU01:FS01:Upload 27.98%
23:32:03:WU01:FS01:Upload 33.62%
23:32:09:WU01:FS01:Upload 39.26%
23:32:15:WU01:FS01:Upload 44.90%
23:32:21:WU01:FS01:Upload 50.54%
23:32:27:WU01:FS01:Upload 56.18%
23:32:33:WU01:FS01:Upload 61.82%
23:32:39:WU01:FS01:Upload 67.46%
23:32:45:WU01:FS01:Upload 73.10%
23:32:51:WU01:FS01:Upload 78.73%
23:32:57:WU01:FS01:Upload 84.37%
23:33:03:WU01:FS01:Upload 90.01%
23:33:09:WU01:FS01:Upload 95.65%
23:33:18:WU01:FS01:Upload complete
23:33:18:WU01:FS01:Server responded WORK_ACK (400)
23:33:18:WU01:FS01:Final credit estimate, 4873.00 points
23:33:18:WU01:FS01:Cleaning up
23:37:29:WU00:FS01:0xa4:Completed 25000 out of 2500000 steps  (1%)
23:43:14:WU00:FS01:0xa4:Completed 50000 out of 2500000 steps  (2%)
23:48:57:WU00:FS01:0xa4:Completed 75000 out of 2500000 steps  (3%)
23:54:42:WU00:FS01:0xa4:Completed 100000 out of 2500000 steps  (4%)
00:00:26:WU00:FS01:0xa4:Completed 125000 out of 2500000 steps  (5%)
00:06:10:WU00:FS01:0xa4:Completed 150000 out of 2500000 steps  (6%)
00:11:56:WU00:FS01:0xa4:Completed 175000 out of 2500000 steps  (7%)
00:17:50:WU00:FS01:0xa4:Completed 200000 out of 2500000 steps  (8%)
00:23:42:WU00:FS01:0xa4:Completed 225000 out of 2500000 steps  (9%)
00:29:26:WU00:FS01:0xa4:Completed 250000 out of 2500000 steps  (10%)
00:35:10:WU00:FS01:0xa4:Completed 275000 out of 2500000 steps  (11%)
00:40:59:WU00:FS01:0xa4:Completed 300000 out of 2500000 steps  (12%)
00:46:55:WU00:FS01:0xa4:Completed 325000 out of 2500000 steps  (13%)
00:52:45:WU00:FS01:0xa4:Completed 350000 out of 2500000 steps  (14%)
00:58:32:WU00:FS01:0xa4:Completed 375000 out of 2500000 steps  (15%)
01:04:21:WU00:FS01:0xa4:Completed 400000 out of 2500000 steps  (16%)
01:10:08:WU00:FS01:0xa4:Completed 425000 out of 2500000 steps  (17%)
01:16:02:WU00:FS01:0xa4:Completed 450000 out of 2500000 steps  (18%)
01:21:50:WU00:FS01:0xa4:Completed 475000 out of 2500000 steps  (19%)
01:27:36:WU00:FS01:0xa4:Completed 500000 out of 2500000 steps  (20%)
01:33:24:WU00:FS01:0xa4:Completed 525000 out of 2500000 steps  (21%)
01:39:12:WU00:FS01:0xa4:Completed 550000 out of 2500000 steps  (22%)
01:45:06:WU00:FS01:0xa4:Completed 575000 out of 2500000 steps  (23%)
01:50:55:WU00:FS01:0xa4:Completed 600000 out of 2500000 steps  (24%)
01:56:42:WU00:FS01:0xa4:Completed 625000 out of 2500000 steps  (25%)
02:02:28:WU00:FS01:0xa4:Completed 650000 out of 2500000 steps  (26%)
02:08:15:WU00:FS01:0xa4:Completed 675000 out of 2500000 steps  (27%)
02:14:09:WU00:FS01:0xa4:Completed 700000 out of 2500000 steps  (28%)
02:19:59:WU00:FS01:0xa4:Completed 725000 out of 2500000 steps  (29%)
02:25:47:WU00:FS01:0xa4:Completed 750000 out of 2500000 steps  (30%)
02:31:35:WU00:FS01:0xa4:Completed 775000 out of 2500000 steps  (31%)
02:37:24:WU00:FS01:0xa4:Completed 800000 out of 2500000 steps  (32%)
02:43:13:WU00:FS01:0xa4:Completed 825000 out of 2500000 steps  (33%)
02:49:11:WU00:FS01:0xa4:Completed 850000 out of 2500000 steps  (34%)
02:55:01:WU00:FS01:0xa4:Completed 875000 out of 2500000 steps  (35%)
03:00:52:WU00:FS01:0xa4:Completed 900000 out of 2500000 steps  (36%)
03:06:42:WU00:FS01:0xa4:Completed 925000 out of 2500000 steps  (37%)
03:12:30:WU00:FS01:0xa4:Completed 950000 out of 2500000 steps  (38%)
03:18:27:WU00:FS01:0xa4:Completed 975000 out of 2500000 steps  (39%)
03:24:17:WU00:FS01:0xa4:Completed 1000000 out of 2500000 steps  (40%)
03:30:06:WU00:FS01:0xa4:Completed 1025000 out of 2500000 steps  (41%)
03:35:56:WU00:FS01:0xa4:Completed 1050000 out of 2500000 steps  (42%)
03:41:47:WU00:FS01:0xa4:Completed 1075000 out of 2500000 steps  (43%)
03:47:46:WU00:FS01:0xa4:Completed 1100000 out of 2500000 steps  (44%)
03:53:38:WU00:FS01:0xa4:Completed 1125000 out of 2500000 steps  (45%)
03:59:27:WU00:FS01:0xa4:Completed 1150000 out of 2500000 steps  (46%)
04:05:17:WU00:FS01:0xa4:Completed 1175000 out of 2500000 steps  (47%)
04:11:09:WU00:FS01:0xa4:Completed 1200000 out of 2500000 steps  (48%)
04:17:08:WU00:FS01:0xa4:Completed 1225000 out of 2500000 steps  (49%)
******************************** Date: 14/04/12 ********************************
04:23:01:WU00:FS01:0xa4:Completed 1250000 out of 2500000 steps  (50%)
04:28:49:WU00:FS01:0xa4:Completed 1275000 out of 2500000 steps  (51%)
04:34:39:WU00:FS01:0xa4:Completed 1300000 out of 2500000 steps  (52%)
04:40:29:WU00:FS01:0xa4:Completed 1325000 out of 2500000 steps  (53%)
04:46:28:WU00:FS01:0xa4:Completed 1350000 out of 2500000 steps  (54%)
04:51:30:Server connection id=1 ended
04:52:19:WU00:FS01:0xa4:Completed 1375000 out of 2500000 steps  (55%)
04:58:06:WU00:FS01:0xa4:Completed 1400000 out of 2500000 steps  (56%)
05:03:55:WU00:FS01:0xa4:Completed 1425000 out of 2500000 steps  (57%)
05:09:44:WU00:FS01:0xa4:Completed 1450000 out of 2500000 steps  (58%)
05:15:44:WU00:FS01:0xa4:Completed 1475000 out of 2500000 steps  (59%)
05:21:36:WU00:FS01:0xa4:Completed 1500000 out of 2500000 steps  (60%)
05:27:26:WU00:FS01:0xa4:Completed 1525000 out of 2500000 steps  (61%)
05:34:54:WU00:FS01:0xa4:Completed 1550000 out of 2500000 steps  (62%)
05:40:47:WU00:FS01:0xa4:Completed 1575000 out of 2500000 steps  (63%)
05:46:47:WU00:FS01:0xa4:Completed 1600000 out of 2500000 steps  (64%)
05:52:40:WU00:FS01:0xa4:Completed 1625000 out of 2500000 steps  (65%)
05:58:28:WU00:FS01:0xa4:Completed 1650000 out of 2500000 steps  (66%)
06:04:18:WU00:FS01:0xa4:Completed 1675000 out of 2500000 steps  (67%)
06:10:10:WU00:FS01:0xa4:Completed 1700000 out of 2500000 steps  (68%)
06:16:03:WU00:FS01:0xa4:Completed 1725000 out of 2500000 steps  (69%)
06:21:54:WU00:FS01:0xa4:Completed 1750000 out of 2500000 steps  (70%)
06:27:44:WU00:FS01:0xa4:Completed 1775000 out of 2500000 steps  (71%)
06:33:47:WU00:FS01:0xa4:Completed 1800000 out of 2500000 steps  (72%)
06:39:41:WU00:FS01:0xa4:Completed 1825000 out of 2500000 steps  (73%)
06:45:32:WU00:FS01:0xa4:Completed 1850000 out of 2500000 steps  (74%)
06:51:22:WU00:FS01:0xa4:Completed 1875000 out of 2500000 steps  (75%)
06:57:14:WU00:FS01:0xa4:Completed 1900000 out of 2500000 steps  (76%)
07:03:17:WU00:FS01:0xa4:Completed 1925000 out of 2500000 steps  (77%)
07:09:12:WU00:FS01:0xa4:Completed 1950000 out of 2500000 steps  (78%)
07:15:04:WU00:FS01:0xa4:Completed 1975000 out of 2500000 steps  (79%)
07:20:57:WU00:FS01:0xa4:Completed 2000000 out of 2500000 steps  (80%)
07:26:51:WU00:FS01:0xa4:Completed 2025000 out of 2500000 steps  (81%)
07:32:55:WU00:FS01:0xa4:Completed 2050000 out of 2500000 steps  (82%)
07:38:50:WU00:FS01:0xa4:Completed 2075000 out of 2500000 steps  (83%)
07:44:42:WU00:FS01:0xa4:Completed 2100000 out of 2500000 steps  (84%)
07:50:33:WU00:FS01:0xa4:Completed 2125000 out of 2500000 steps  (85%)
07:56:27:WU00:FS01:0xa4:Completed 2150000 out of 2500000 steps  (86%)
08:02:31:WU00:FS01:0xa4:Completed 2175000 out of 2500000 steps  (87%)
08:10:51:WU00:FS01:0xa4:Completed 2200000 out of 2500000 steps  (88%)
08:16:47:WU00:FS01:0xa4:Completed 2225000 out of 2500000 steps  (89%)
08:22:43:WU00:FS01:0xa4:Completed 2250000 out of 2500000 steps  (90%)
08:28:46:WU00:FS01:0xa4:Completed 2275000 out of 2500000 steps  (91%)
08:34:44:WU00:FS01:0xa4:Completed 2300000 out of 2500000 steps  (92%)
08:40:40:WU00:FS01:0xa4:Completed 2325000 out of 2500000 steps  (93%)
08:46:35:WU00:FS01:0xa4:Completed 2350000 out of 2500000 steps  (94%)
08:52:29:WU00:FS01:0xa4:Completed 2375000 out of 2500000 steps  (95%)
08:58:23:WU00:FS01:0xa4:Completed 2400000 out of 2500000 steps  (96%)
09:05:23:WU00:FS01:0xa4:Completed 2425000 out of 2500000 steps  (97%)
09:11:45:WU00:FS01:0xa4:Completed 2450000 out of 2500000 steps  (98%)
09:17:42:WU00:FS01:0xa4:Completed 2475000 out of 2500000 steps  (99%)
09:17:43:WU01:FS01:Connecting to assign3.stanford.edu:8080
09:17:43:WU01:FS01:News: Welcome to Folding@Home
09:17:43:WU01:FS01:Assigned to work server 128.113.12.161
09:17:43:WU01:FS01:Requesting new work unit for slot 01: RUNNING smp:8 from 128.113.12.161
09:17:43:WU01:FS01:Connecting to 128.113.12.161:8080
09:17:44:WU01:FS01:Downloading 637.66KiB
09:17:45:WU01:FS01:Download complete
09:17:45:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:OK project:7903 run:176 clone:6 gen:10 core:0xa4 unit:0x0000000e00ac9c214eca68a3460ab091
09:23:43:WU00:FS01:0xa4:Completed 2500000 out of 2500000 steps  (100%)
09:23:43:WU00:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
09:23:53:WU00:FS01:0xa4:
09:23:53:WU00:FS01:0xa4:Finished Work Unit:
09:23:56:WU00:FS01:0xa4:- Reading up to 35910936 from "00/wudata_01.trr": Read 35910936
09:23:56:WU00:FS01:0xa4:trr file hash check passed.
09:23:56:WU00:FS01:0xa4:edr file hash check passed.
09:23:56:WU00:FS01:0xa4:logfile size: 62699
09:23:56:WU00:FS01:0xa4:Leaving Run
09:23:56:WU00:FS01:0xa4:- Writing 36003551 bytes of core data to disk...
09:24:04:WU00:FS01:0xa4:Done: 36003039 -> 30224894 (compressed to 83.9 percent)
09:24:04:WU00:FS01:0xa4:  ... Done.
09:24:07:WU00:FS01:0xa4:- Shutting down core
09:24:07:WU00:FS01:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
09:24:08:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:24:08:WU00:FS01:Sending unit results: id:00 state:SEND error:OK project:7903 run:211 clone:0 gen:16 core:0xa4 unit:0x0000001300ac9c214e4d2c7c204793f4
09:24:08:WU00:FS01:Uploading 28.83MiB to 128.113.12.161
09:24:08:WU01:FS01:Starting
09:24:08:WU00:FS01:Connecting to 128.113.12.161:8080
09:24:08:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -np 8 -service
09:24:08:WU01:FS01:Started FahCore on PID 11488
09:24:08:WU01:FS01:Core PID:8416
09:24:08:WU01:FS01:FahCore 0xa4 started
09:24:09:WU01:FS01:0xa4:
09:24:09:WU01:FS01:0xa4:*------------------------------*
09:24:09:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
09:24:09:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
09:24:09:WU01:FS01:0xa4:Preparing to commence simulation
09:24:09:WU01:FS01:0xa4:- Looking at optimizations...
09:24:09:WU01:FS01:0xa4:- Created dyn
09:24:09:WU01:FS01:0xa4:- Files status OK
09:24:09:WU01:FS01:0xa4:- Expanded 652448 -> 1008860 (decompressed 154.6 percent)
09:24:09:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=652448 data_size=1008860, decompressed_data_size=1008860 diff=0
09:24:09:WU01:FS01:0xa4:- Digital signature verified
09:24:09:WU01:FS01:0xa4:Project: 7903 (Run 176, Clone 6, Gen 10)
09:24:09:WU01:FS01:0xa4:Assembly optimizations on if available.
09:24:09:WU01:FS01:0xa4:Entering M.D.
09:24:14:WU00:FS01:Upload 5.20%
09:24:15:WU01:FS01:0xa4:Mapping NT from 8 to 8
09:24:15:WU01:FS01:0xa4:Completed 0 out of 2500000 steps  (0%)
09:24:20:WU00:FS01:Upload 10.62%
09:24:26:WU00:FS01:Upload 16.04%
09:24:32:WU00:FS01:Upload 21.68%
09:24:38:WU00:FS01:Upload 27.32%
09:24:44:WU00:FS01:Upload 33.17%
09:24:50:WU00:FS01:Upload 39.03%
09:24:56:WU00:FS01:Upload 44.67%
09:25:02:WU00:FS01:Upload 49.87%
09:25:08:WU00:FS01:Upload 55.72%
09:25:14:WU00:FS01:Upload 61.36%
09:25:20:WU00:FS01:Upload 67.00%
09:25:26:WU00:FS01:Upload 72.64%
09:25:32:WU00:FS01:Upload 78.49%
09:25:38:WU00:FS01:Upload 84.13%
09:25:44:WU00:FS01:Upload 89.98%
09:25:50:WU00:FS01:Upload 95.62%
09:25:59:WU00:FS01:Upload complete
09:25:59:WU00:FS01:Server responded WORK_ACK (400)
09:25:59:WU00:FS01:Final credit estimate, 4946.00 points
09:25:59:WU00:FS01:Cleaning up
09:30:23:WU01:FS01:0xa4:Completed 25000 out of 2500000 steps  (1%)
09:36:27:WU01:FS01:0xa4:Completed 50000 out of 2500000 steps  (2%)
09:42:28:WU01:FS01:0xa4:Completed 75000 out of 2500000 steps  (3%)
09:48:25:WU01:FS01:0xa4:Completed 100000 out of 2500000 steps  (4%)
09:54:26:WU01:FS01:0xa4:Completed 125000 out of 2500000 steps  (5%)
10:00:33:WU01:FS01:0xa4:Completed 150000 out of 2500000 steps  (6%)
10:06:37:WU01:FS01:0xa4:Completed 175000 out of 2500000 steps  (7%)
10:12:37:WU01:FS01:0xa4:Completed 200000 out of 2500000 steps  (8%)
10:18:35:WU01:FS01:0xa4:Completed 225000 out of 2500000 steps  (9%)
10:24:35:WU01:FS01:0xa4:Completed 250000 out of 2500000 steps  (10%)
10:30:44:WU01:FS01:0xa4:Completed 275000 out of 2500000 steps  (11%)
10:36:51:WU01:FS01:0xa4:Completed 300000 out of 2500000 steps  (12%)
10:42:51:WU01:FS01:0xa4:Completed 325000 out of 2500000 steps  (13%)
10:48:51:WU01:FS01:0xa4:Completed 350000 out of 2500000 steps  (14%)
10:54:52:WU01:FS01:0xa4:Completed 375000 out of 2500000 steps  (15%)
11:01:01:WU01:FS01:0xa4:Completed 400000 out of 2500000 steps  (16%)
11:07:06:WU01:FS01:0xa4:Completed 425000 out of 2500000 steps  (17%)
11:13:09:WU01:FS01:0xa4:Completed 450000 out of 2500000 steps  (18%)
11:19:09:WU01:FS01:0xa4:Completed 475000 out of 2500000 steps  (19%)
11:25:12:WU01:FS01:0xa4:Completed 500000 out of 2500000 steps  (20%)
11:31:23:WU01:FS01:0xa4:Completed 525000 out of 2500000 steps  (21%)
11:37:28:WU01:FS01:0xa4:Completed 550000 out of 2500000 steps  (22%)
11:43:30:WU01:FS01:0xa4:Completed 575000 out of 2500000 steps  (23%)
11:49:30:WU01:FS01:0xa4:Completed 600000 out of 2500000 steps  (24%)
11:55:33:WU01:FS01:0xa4:Completed 625000 out of 2500000 steps  (25%)
12:01:45:WU01:FS01:0xa4:Completed 650000 out of 2500000 steps  (26%)
12:07:53:WU01:FS01:0xa4:Completed 675000 out of 2500000 steps  (27%)
12:13:58:WU01:FS01:0xa4:Completed 700000 out of 2500000 steps  (28%)
12:20:02:WU01:FS01:0xa4:Completed 725000 out of 2500000 steps  (29%)
12:26:12:WU01:FS01:0xa4:Completed 750000 out of 2500000 steps  (30%)
12:32:26:WU01:FS01:0xa4:Completed 775000 out of 2500000 steps  (31%)
12:38:33:WU01:FS01:0xa4:Completed 800000 out of 2500000 steps  (32%)
12:44:38:WU01:FS01:0xa4:Completed 825000 out of 2500000 steps  (33%)
12:50:41:WU01:FS01:0xa4:Completed 850000 out of 2500000 steps  (34%)
12:56:45:WU01:FS01:0xa4:Completed 875000 out of 2500000 steps  (35%)
13:03:00:WU01:FS01:0xa4:Completed 900000 out of 2500000 steps  (36%)
13:09:07:WU01:FS01:0xa4:Completed 925000 out of 2500000 steps  (37%)
13:15:11:WU01:FS01:0xa4:Completed 950000 out of 2500000 steps  (38%)
13:21:15:WU01:FS01:0xa4:Completed 975000 out of 2500000 steps  (39%)
13:27:22:WU01:FS01:0xa4:Completed 1000000 out of 2500000 steps  (40%)
13:33:41:WU01:FS01:0xa4:Completed 1025000 out of 2500000 steps  (41%)
13:39:50:WU01:FS01:0xa4:Completed 1050000 out of 2500000 steps  (42%)
13:45:56:WU01:FS01:0xa4:Completed 1075000 out of 2500000 steps  (43%)
13:52:02:WU01:FS01:0xa4:Completed 1100000 out of 2500000 steps  (44%)
13:58:10:WU01:FS01:0xa4:Completed 1125000 out of 2500000 steps  (45%)
14:04:29:WU01:FS01:0xa4:Completed 1150000 out of 2500000 steps  (46%)
14:10:38:WU01:FS01:0xa4:Completed 1175000 out of 2500000 steps  (47%)
14:16:45:WU01:FS01:0xa4:Completed 1200000 out of 2500000 steps  (48%)
14:22:52:WU01:FS01:0xa4:Completed 1225000 out of 2500000 steps  (49%)
14:29:08:WU01:FS01:0xa4:Completed 1250000 out of 2500000 steps  (50%)
14:35:19:WU01:FS01:0xa4:Completed 1275000 out of 2500000 steps  (51%)
14:41:31:WU01:FS01:0xa4:Completed 1300000 out of 2500000 steps  (52%)
14:47:39:WU01:FS01:0xa4:Completed 1325000 out of 2500000 steps  (53%)
14:53:48:WU01:FS01:0xa4:Completed 1350000 out of 2500000 steps  (54%)
15:00:03:WU01:FS01:0xa4:Completed 1375000 out of 2500000 steps  (55%)
15:06:16:WU01:FS01:0xa4:Completed 1400000 out of 2500000 steps  (56%)
15:12:27:WU01:FS01:0xa4:Completed 1425000 out of 2500000 steps  (57%)
15:18:38:WU01:FS01:0xa4:Completed 1450000 out of 2500000 steps  (58%)
15:24:49:WU01:FS01:0xa4:Completed 1475000 out of 2500000 steps  (59%)
15:31:08:WU01:FS01:0xa4:Completed 1500000 out of 2500000 steps  (60%)
15:37:20:WU01:FS01:0xa4:Completed 1525000 out of 2500000 steps  (61%)
15:43:33:WU01:FS01:0xa4:Completed 1550000 out of 2500000 steps  (62%)
15:49:42:WU01:FS01:0xa4:Completed 1575000 out of 2500000 steps  (63%)
15:55:53:WU01:FS01:0xa4:Completed 1600000 out of 2500000 steps  (64%)
16:02:13:WU01:FS01:0xa4:Completed 1625000 out of 2500000 steps  (65%)
16:08:31:WU01:FS01:0xa4:Completed 1650000 out of 2500000 steps  (66%)
16:14:43:WU01:FS01:0xa4:Completed 1675000 out of 2500000 steps  (67%)
16:20:54:WU01:FS01:0xa4:Completed 1700000 out of 2500000 steps  (68%)
16:27:09:WU01:FS01:0xa4:Completed 1725000 out of 2500000 steps  (69%)
16:33:34:WU01:FS01:0xa4:Completed 1750000 out of 2500000 steps  (70%)
16:39:49:WU01:FS01:0xa4:Completed 1775000 out of 2500000 steps  (71%)
16:46:01:WU01:FS01:0xa4:Completed 1800000 out of 2500000 steps  (72%)
16:52:13:WU01:FS01:0xa4:Completed 1825000 out of 2500000 steps  (73%)
16:58:26:WU01:FS01:0xa4:Completed 1850000 out of 2500000 steps  (74%)
17:04:51:WU01:FS01:0xa4:Completed 1875000 out of 2500000 steps  (75%)
17:11:08:WU01:FS01:0xa4:Completed 1900000 out of 2500000 steps  (76%)
17:17:23:WU01:FS01:0xa4:Completed 1925000 out of 2500000 steps  (77%)
17:23:39:WU01:FS01:0xa4:Completed 1950000 out of 2500000 steps  (78%)
17:30:02:WU01:FS01:0xa4:Completed 1975000 out of 2500000 steps  (79%)
17:36:20:WU01:FS01:0xa4:Completed 2000000 out of 2500000 steps  (80%)
17:42:38:WU01:FS01:0xa4:Completed 2025000 out of 2500000 steps  (81%)
17:48:52:WU01:FS01:0xa4:Completed 2050000 out of 2500000 steps  (82%)
17:55:07:WU01:FS01:0xa4:Completed 2075000 out of 2500000 steps  (83%)
18:01:32:WU01:FS01:0xa4:Completed 2100000 out of 2500000 steps  (84%)
18:07:50:WU01:FS01:0xa4:Completed 2125000 out of 2500000 steps  (85%)
18:14:08:WU01:FS01:0xa4:Completed 2150000 out of 2500000 steps  (86%)
18:20:22:WU01:FS01:0xa4:Completed 2175000 out of 2500000 steps  (87%)
18:26:39:WU01:FS01:0xa4:Completed 2200000 out of 2500000 steps  (88%)
18:33:07:WU01:FS01:0xa4:Completed 2225000 out of 2500000 steps  (89%)
18:39:28:WU01:FS01:0xa4:Completed 2250000 out of 2500000 steps  (90%)
18:45:45:WU01:FS01:0xa4:Completed 2275000 out of 2500000 steps  (91%)
18:52:01:WU01:FS01:0xa4:Completed 2300000 out of 2500000 steps  (92%)
18:58:19:WU01:FS01:0xa4:Completed 2325000 out of 2500000 steps  (93%)
19:04:48:WU01:FS01:0xa4:Completed 2350000 out of 2500000 steps  (94%)
19:11:09:WU01:FS01:0xa4:Completed 2375000 out of 2500000 steps  (95%)
19:17:28:WU01:FS01:0xa4:Completed 2400000 out of 2500000 steps  (96%)
19:23:48:WU01:FS01:0xa4:Completed 2425000 out of 2500000 steps  (97%)
19:30:16:WU01:FS01:0xa4:Completed 2450000 out of 2500000 steps  (98%)
19:36:41:WU01:FS01:0xa4:Completed 2475000 out of 2500000 steps  (99%)
19:36:42:WU00:FS01:Connecting to assign3.stanford.edu:8080
19:36:42:WU00:FS01:News: Welcome to Folding@Home
19:36:42:WU00:FS01:Assigned to work server 171.67.108.58
19:36:42:WU00:FS01:Requesting new work unit for slot 01: RUNNING smp:8 from 171.67.108.58
19:36:42:WU00:FS01:Connecting to 171.67.108.58:8080
19:36:43:WU00:FS01:Downloading 530.55KiB
19:36:44:WU00:FS01:Download complete
19:36:44:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:OK project:8001 run:94 clone:54 gen:102 core:0xa4 unit:0x000000986652edca4ededfbc4787dc2c
19:36:44:WU00:FS01:Downloading project 8001 description
19:36:44:WU00:FS01:Connecting to fah-web.stanford.edu:80
19:36:45:WU00:FS01:Project 8001 description downloaded successfully
19:43:00:WU01:FS01:0xa4:Completed 2500000 out of 2500000 steps  (100%)
19:43:01:WU01:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
19:43:11:WU01:FS01:0xa4:
19:43:11:WU01:FS01:0xa4:Finished Work Unit:
19:43:11:WU01:FS01:0xa4:- Reading up to 35910936 from "01/wudata_01.trr": Read 35910936
19:43:11:WU01:FS01:0xa4:trr file hash check passed.
19:43:11:WU01:FS01:0xa4:edr file hash check passed.
19:43:11:WU01:FS01:0xa4:logfile size: 63144
19:43:11:WU01:FS01:0xa4:Leaving Run
19:43:15:WU01:FS01:0xa4:- Writing 36003996 bytes of core data to disk...
19:43:22:WU01:FS01:0xa4:Done: 36003484 -> 30222729 (compressed to 83.9 percent)
19:43:22:WU01:FS01:0xa4:  ... Done.
19:43:26:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
19:43:27:WU01:FS01:Sending unit results: id:01 state:SEND error:OK project:7903 run:176 clone:6 gen:10 core:0xa4 unit:0x0000000e00ac9c214eca68a3460ab091
19:43:27:WU01:FS01:Uploading 28.82MiB to 128.113.12.161
19:43:27:WU00:FS01:Starting
19:43:27:WU01:FS01:Connecting to 128.113.12.161:8080
19:43:27:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 701 -lifeline 2544 -checkpoint 5 -np 8 -service
19:43:27:WU00:FS01:Started FahCore on PID 2768
19:43:27:WU00:FS01:Core PID:11944
19:43:27:WU00:FS01:FahCore 0xa4 started
19:43:28:WU00:FS01:0xa4:
19:43:28:WU00:FS01:0xa4:*------------------------------*
19:43:28:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
19:43:28:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
19:43:28:WU00:FS01:0xa4:Preparing to commence simulation
19:43:28:WU00:FS01:0xa4:- Looking at optimizations...
19:43:28:WU00:FS01:0xa4:- Created dyn
19:43:28:WU00:FS01:0xa4:- Files status OK
19:43:28:WU00:FS01:0xa4:- Expanded 542775 -> 1302000 (decompressed 239.8 percent)
19:43:28:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=542775 data_size=1302000, decompressed_data_size=1302000 diff=0
19:43:28:WU00:FS01:0xa4:- Digital signature verified
19:43:28:WU00:FS01:0xa4:Project: 8001 (Run 94, Clone 54, Gen 102)
19:43:28:WU00:FS01:0xa4:Assembly optimizations on if available.
19:43:28:WU00:FS01:0xa4:Entering M.D.
19:43:34:WU00:FS01:0xa4:Mapping NT from 8 to 8
19:43:34:WU00:FS01:0xa4:Completed 0 out of 250000 steps  (0%)
19:43:48:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
19:43:48:WU01:FS01:Connecting to 128.113.12.161:80
19:44:09:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 128.113.12.161:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
19:44:09:WU01:FS01:Trying to send results to collection server
19:44:09:WU01:FS01:Uploading 28.82MiB to 129.74.85.16
19:44:09:WU01:FS01:Connecting to 129.74.85.16:8080
19:44:15:WU01:FS01:Upload 10.63%
19:44:19:WU00:FS01:0xa4:Completed 2500 out of 250000 steps  (1%)
19:44:21:WU01:FS01:Upload 21.68%
19:44:27:WU01:FS01:Upload 31.88%
19:44:33:WU01:FS01:Upload 41.20%
19:44:39:WU01:FS01:Upload 51.17%
19:44:45:WU01:FS01:Upload 60.72%
19:44:51:WU01:FS01:Upload 70.04%
19:44:57:WU01:FS01:Upload 78.71%
19:45:03:WU01:FS01:Upload 88.04%
19:45:03:WU00:FS01:0xa4:Completed 5000 out of 250000 steps  (2%)
19:45:09:WU01:FS01:Upload 97.14%
19:45:11:WU01:FS01:Upload complete
19:45:11:WU01:FS01:Server responded WORK_QUIT (404)
19:45:11:WARNING:WU01:FS01:Server did not like results, dumping
19:45:11:WU01:FS01:Cleaning up
19:45:47:WU00:FS01:0xa4:Completed 7500 out of 250000 steps  (3%)
19:46:32:WU00:FS01:0xa4:Completed 10000 out of 250000 steps  (4%)
19:47:16:WU00:FS01:0xa4:Completed 12500 out of 250000 steps  (5%)
19:48:00:WU00:FS01:0xa4:Completed 15000 out of 250000 steps  (6%)
19:48:44:WU00:FS01:0xa4:Completed 17500 out of 250000 steps  (7%)
19:49:29:WU00:FS01:0xa4:Completed 20000 out of 250000 steps  (8%)
Re: GPU Core Crashes (Or at least it doesn't work)
Hello tlapaso, welcome to the forum.
What driver version are you using? And if not an HD5450, then what is it supposed to show? What clock speeds, default and OC?
tlapaso
Post by tlapaso »
7im wrote:Hello tlapaso, welcome to the forum.
Hi 7im,
I don't know the answer to any of your questions. The reason I think it's an HD5450 is because that's what both GPU-Z and the FaH client report.
How can I get the answers to your questions? What's "OC"? If it's over-clocked, then, no, nothing is over-clocked.
devpao
Post by devpao »
You may want to uninstall your current drivers and install the last known usable for windows XP (11-12_xp32_dd_ccc_ocl.exe)
Ikester
Post by Ikester »
Dunno if this is proper but I searched and could only find this thread re: Radeon 5450. I too am running a Radeon HD 5450. I just installed it today and noted that the client fails after a few minutes.
Here's the log I get after clearing the initial attempt and getting the GPU to request another project:
08:52:48:FS00:Paused
08:52:52:FS00:Unpaused
08:52:52:FS00:Finishing
08:53:03:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
08:53:04:WU01:FS00:News: Welcome to Folding@Home
08:53:04:WU01:FS00:Assigned to work server 171.67.108.44
08:53:04:WU01:FS00:Requesting new work unit for slot 00: READY gpu:2:"Cedar PRO [Radeon HD 5450]" from 171.67.108.44
08:53:04:WU01:FS00:Connecting to 171.67.108.44:8080
08:53:04:WU01:FS00:Downloading 44.55KiB
08:53:05:WU01:FS00:Download complete
08:53:05:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11293 run:24 clone:270 gen:37 core:0x16 unit:0x0000002f6652edbc4d94b9d49524aace
08:53:05:WU01:FS00:Starting
08:53:05:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 702 -lifeline 4532 -checkpoint 3 -gpu 2
08:53:05:WU01:FS00:Started FahCore on PID 5612
08:53:05:WU01:FS00:Core PID:5572
08:53:05:WU01:FS00:FahCore 0x16 started
08:53:05:WU01:FS00:0x16:
08:53:05:WU01:FS00:0x16:*------------------------------*
08:53:05:WU01:FS00:0x16:Folding@Home GPU Core
08:53:05:WU01:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
08:53:05:WU01:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
08:53:05:WU01:FS00:0x16:Build host: user-f6d030f24f
08:53:05:WU01:FS00:0x16:Board Type: AMD/OpenCL
08:53:05:WU01:FS00:0x16:Core      : x=16
08:53:05:WU01:FS00:0x16: Window's signal control handler registered.
08:53:05:WU01:FS00:0x16:Preparing to commence simulation
08:53:05:WU01:FS00:0x16:- Looking at optimizations...
08:53:05:WU01:FS00:0x16:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
08:53:05:WU01:FS00:0x16:- Created dyn
08:53:05:WU01:FS00:0x16:- Files status OK
08:53:05:WU01:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
08:53:05:WU01:FS00:0x16:- Expanded 45104 -> 171163 (decompressed 379.4 percent)
08:53:05:WU01:FS00:0x16:Called DecompressByteArray: compressed_data_size=45104 data_size=171163, decompressed_data_size=171163 diff=0
08:53:05:WU01:FS00:0x16:- Digital signature verified
08:53:05:WU01:FS00:0x16:Project: 11293 (Run 24, Clone 270, Gen 37)
08:53:05:WU01:FS00:0x16:Assembly optimizations on if available.
08:53:05:WU01:FS00:0x16:Entering M.D.
08:53:07:WU01:FS00:0x16:Tpr hash 01/wudata_01.tpr:  3372296074 2385231307 231529931 3980341505 2835079913
08:53:07:WU01:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
08:53:07:WU01:FS00:0x16:Client config unavailable.
08:53:07:WU01:FS00:0x16:Starting GUI Server
08:53:16:WU01:FS00:0x16:Setting checkpoint frequency: 500000
08:53:16:WU01:FS00:0x16:Completed         3 out of 50000000 steps (0%).
08:53:18:WU01:FS00:0x16:Run: exception thrown in GuardedRun -- cannot continue further.
08:53:18:WU01:FS00:0x16:Going to send back what have done -- stepsTotalG=50000000
08:53:18:WU01:FS00:0x16:Work fraction=0.0004 steps=50000000.
08:53:22:WU01:FS00:0x16:logfile size=7221 infoLength=7221 edr=0 trr=23
08:53:22:WU01:FS00:0x16:+ Opened results file
08:53:22:WU01:FS00:0x16:- Writing 7757 bytes of core data to disk...
08:53:22:WU01:FS00:0x16:Decompress: Memory problem 2
08:53:22:WU01:FS00:0x16:  ... Done.
08:53:22:WU01:FS00:0x16:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
08:53:22:WU01:FS00:0x16:Folding@home Core Shutdown: UNSTABLE_MACHINE
08:53:22:WARNING:WU01:FS00:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
08:53:23:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:11293 run:24 clone:270 gen:37 core:0x16 unit:0x0000002f6652edbc4d94b9d49524aace
08:53:23:WU01:FS00:Uploading 1.09KiB to 171.67.108.44
08:53:23:WU01:FS00:Connecting to 171.67.108.44:8080
08:53:23:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
08:53:23:WU01:FS00:Upload complete
08:53:23:WU01:FS00:Server responded WORK_QUIT (404)
08:53:23:WARNING:WU01:FS00:Server did not like results, dumping
08:53:23:WU01:FS00:Cleaning up
08:53:23:WU02:FS00:News: Welcome to Folding@Home
08:53:23:WU02:FS00:Assigned to work server 171.67.108.44
08:53:23:WU02:FS00:Requesting new work unit for slot 00: READY gpu:2:"Cedar PRO [Radeon HD 5450]" from 171.67.108.44
08:53:23:WU02:FS00:Connecting to 171.67.108.44:8080
08:53:24:WU02:FS00:Downloading 44.34KiB
08:53:24:WU02:FS00:Download complete
08:53:24:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11293 run:25 clone:270 gen:37 core:0x16 unit:0x0000003e6652edbc4d94ba0f2299ac9d
08:53:24:WU02:FS00:Starting
08:53:24:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 702 -lifeline 4532 -checkpoint 3 -gpu 2
08:53:24:WU02:FS00:Started FahCore on PID 4404
08:53:24:WU02:FS00:Core PID:6108
08:53:24:WU02:FS00:FahCore 0x16 started
08:53:25:WU02:FS00:0x16:
08:53:25:WU02:FS00:0x16:*------------------------------*
08:53:25:WU02:FS00:0x16:Folding@Home GPU Core
08:53:25:WU02:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
08:53:25:WU02:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
08:53:25:WU02:FS00:0x16:Build host: user-f6d030f24f
08:53:25:WU02:FS00:0x16:Board Type: AMD/OpenCL
08:53:25:WU02:FS00:0x16:Core      : x=16
08:53:25:WU02:FS00:0x16: Window's signal control handler registered.
08:53:25:WU02:FS00:0x16:Preparing to commence simulation
08:53:25:WU02:FS00:0x16:- Looking at optimizations...
08:53:25:WU02:FS00:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
08:53:25:WU02:FS00:0x16:- Created dyn
08:53:25:WU02:FS00:0x16:- Files status OK
08:53:25:WU02:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
08:53:25:WU02:FS00:0x16:- Expanded 44893 -> 171163 (decompressed 381.2 percent)
08:53:25:WU02:FS00:0x16:Called DecompressByteArray: compressed_data_size=44893 data_size=171163, decompressed_data_size=171163 diff=0
08:53:25:WU02:FS00:0x16:- Digital signature verified
08:53:25:WU02:FS00:0x16:Project: 11293 (Run 25, Clone 270, Gen 37)
08:53:25:WU02:FS00:0x16:Assembly optimizations on if available.
08:53:25:WU02:FS00:0x16:Entering M.D.
08:53:26:WU02:FS00:0x16:Tpr hash 02/wudata_01.tpr:  2548079201 3992002177 1452060020 2579284441 4085578076
08:53:26:WU02:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
08:53:26:WU02:FS00:0x16:Client config unavailable.
08:53:27:WU02:FS00:0x16:Starting GUI Server
08:53:34:WU02:FS00:0x16:Setting checkpoint frequency: 500000
08:53:34:WU02:FS00:0x16:Completed         3 out of 50000000 steps (0%).
08:53:36:WU02:FS00:0x16:Run: exception thrown in GuardedRun -- cannot continue further.
08:53:36:WU02:FS00:0x16:Going to send back what have done -- stepsTotalG=50000000
08:53:36:WU02:FS00:0x16:Work fraction=0.0004 steps=50000000.
08:53:40:WU02:FS00:0x16:logfile size=7221 infoLength=7221 edr=0 trr=23
08:53:40:WU02:FS00:0x16:+ Opened results file
08:53:40:WU02:FS00:0x16:- Writing 7757 bytes of core data to disk...
08:53:40:WU02:FS00:0x16:Decompress: Memory problem 2
08:53:40:WU02:FS00:0x16:  ... Done.
08:53:40:WU02:FS00:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
08:53:40:WU02:FS00:0x16:Folding@home Core Shutdown: UNSTABLE_MACHINE
08:53:40:WARNING:WU02:FS00:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
08:53:40:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:11293 run:25 clone:270 gen:37 core:0x16 unit:0x0000003e6652edbc4d94ba0f2299ac9d
08:53:40:WU02:FS00:Uploading 1.09KiB to 171.67.108.44
08:53:40:WU02:FS00:Connecting to 171.67.108.44:8080
08:53:41:WU02:FS00:Upload complete
08:53:41:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
08:53:41:WU02:FS00:Server responded WORK_QUIT (404)
08:53:41:WARNING:WU02:FS00:Server did not like results, dumping
08:53:41:WU02:FS00:Cleaning up
08:53:41:WU01:FS00:News: Welcome to Folding@Home
08:53:41:WU01:FS00:Assigned to work server 171.67.108.44
08:53:41:WU01:FS00:Requesting new work unit for slot 00: READY gpu:2:"Cedar PRO [Radeon HD 5450]" from 171.67.108.44
08:53:41:WU01:FS00:Connecting to 171.67.108.44:8080
08:53:42:WU01:FS00:Downloading 44.50KiB
08:53:42:WU01:FS00:Download complete
08:53:42:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11293 run:26 clone:270 gen:37 core:0x16 unit:0x0000003d6652edbc4d94ba4cbe4ecb97
08:53:42:WU01:FS00:Starting
08:53:42:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 702 -lifeline 4532 -checkpoint 3 -gpu 2
08:53:42:WU01:FS00:Started FahCore on PID 6136
08:53:42:WU01:FS00:Core PID:1476
08:53:42:WU01:FS00:FahCore 0x16 started
08:53:43:WU01:FS00:0x16:
08:53:43:WU01:FS00:0x16:*------------------------------*
08:53:43:WU01:FS00:0x16:Folding@Home GPU Core
08:53:43:WU01:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
08:53:43:WU01:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
08:53:43:WU01:FS00:0x16:Build host: user-f6d030f24f
08:53:43:WU01:FS00:0x16:Board Type: AMD/OpenCL
08:53:43:WU01:FS00:0x16:Core      : x=16
08:53:43:WU01:FS00:0x16: Window's signal control handler registered.
08:53:43:WU01:FS00:0x16:Preparing to commence simulation
08:53:43:WU01:FS00:0x16:- Looking at optimizations...
08:53:43:WU01:FS00:0x16:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
08:53:43:WU01:FS00:0x16:- Created dyn
08:53:43:WU01:FS00:0x16:- Files status OK
08:53:43:WU01:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
08:53:43:WU01:FS00:0x16:- Expanded 45060 -> 171163 (decompressed 379.8 percent)
08:53:43:WU01:FS00:0x16:Called DecompressByteArray: compressed_data_size=45060 data_size=171163, decompressed_data_size=171163 diff=0
08:53:43:WU01:FS00:0x16:- Digital signature verified
08:53:43:WU01:FS00:0x16:Project: 11293 (Run 26, Clone 270, Gen 37)
08:53:43:WU01:FS00:0x16:Assembly optimizations on if available.
08:53:43:WU01:FS00:0x16:Entering M.D.
08:53:44:WU01:FS00:0x16:Tpr hash 01/wudata_01.tpr:  3317668929 4261108119 317792484 16922458 185387434
08:53:45:WU01:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
08:53:45:WU01:FS00:0x16:Client config unavailable.
08:53:45:WU01:FS00:0x16:Starting GUI Server
08:53:54:WU01:FS00:0x16:Setting checkpoint frequency: 500000
08:53:54:WU01:FS00:0x16:Completed         3 out of 50000000 steps (0%).
08:53:56:WU01:FS00:0x16:Run: exception thrown in GuardedRun -- cannot continue further.
08:53:56:WU01:FS00:0x16:Going to send back what have done -- stepsTotalG=50000000
08:53:56:WU01:FS00:0x16:Work fraction=0.0004 steps=50000000.
08:54:00:WU01:FS00:0x16:logfile size=7221 infoLength=7221 edr=0 trr=23
08:54:00:WU01:FS00:0x16:+ Opened results file
08:54:00:WU01:FS00:0x16:- Writing 7757 bytes of core data to disk...
08:54:00:WU01:FS00:0x16:Decompress: Memory problem 2
08:54:00:WU01:FS00:0x16:  ... Done.
08:54:00:WU01:FS00:0x16:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
08:54:00:WU01:FS00:0x16:Folding@home Core Shutdown: EARLY_UNIT_END
08:54:01:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
08:54:01:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:11293 run:26 clone:270 gen:37 core:0x16 unit:0x0000003d6652edbc4d94ba4cbe4ecb97
08:54:01:WU01:FS00:Uploading 1.09KiB to 171.67.108.44
08:54:01:WU01:FS00:Connecting to 171.67.108.44:8080
08:54:01:WU01:FS00:Upload complete
08:54:01:WU01:FS00:Server responded WORK_QUIT (404)
08:54:01:WARNING:WU01:FS00:Server did not like results, dumping
08:54:01:WU01:FS00:Cleaning up
08:54:01:ERROR:WU01:FS00:Exception: Failed to remove directory './work/01': boost::filesystem::remove: The process cannot access the file because it is being used by another process: ".\work\01\wudata_01.edr"
08:54:01:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
08:54:01:WU02:FS00:News: Welcome to Folding@Home
08:54:01:WU02:FS00:Assigned to work server 171.67.108.44
08:54:01:WU02:FS00:Requesting new work unit for slot 00: READY gpu:2:"Cedar PRO [Radeon HD 5450]" from 171.67.108.44
08:54:01:WU02:FS00:Connecting to 171.67.108.44:8080
08:54:02:WU02:FS00:Downloading 44.40KiB
08:54:02:WU02:FS00:Download complete
08:54:02:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11293 run:27 clone:270 gen:37 core:0x16 unit:0x000000466652edbc4d94ba7c4d295a34
08:54:03:WU02:FS00:Starting
08:54:03:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 702 -lifeline 4532 -checkpoint 3 -gpu 2
08:54:03:WU02:FS00:Started FahCore on PID 3696
08:54:03:WU02:FS00:Core PID:3340
08:54:03:WU02:FS00:FahCore 0x16 started
08:54:03:WU02:FS00:0x16:
08:54:03:WU02:FS00:0x16:*------------------------------*
08:54:03:WU02:FS00:0x16:Folding@Home GPU Core
08:54:03:WU02:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
08:54:03:WU02:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
08:54:03:WU02:FS00:0x16:Build host: user-f6d030f24f
08:54:03:WU02:FS00:0x16:Board Type: AMD/OpenCL
08:54:03:WU02:FS00:0x16:Core      : x=16
08:54:03:WU02:FS00:0x16: Window's signal control handler registered.
08:54:03:WU02:FS00:0x16:Preparing to commence simulation
08:54:03:WU02:FS00:0x16:- Looking at optimizations...
08:54:03:WU02:FS00:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
08:54:03:WU02:FS00:0x16:- Created dyn
08:54:03:WU02:FS00:0x16:- Files status OK
08:54:03:WU02:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
08:54:03:WU02:FS00:0x16:- Expanded 44949 -> 171163 (decompressed 380.7 percent)
08:54:03:WU02:FS00:0x16:Called DecompressByteArray: compressed_data_size=44949 data_size=171163, decompressed_data_size=171163 diff=0
08:54:03:WU02:FS00:0x16:- Digital signature verified
08:54:03:WU02:FS00:0x16:Project: 11293 (Run 27, Clone 270, Gen 37)
08:54:03:WU02:FS00:0x16:Assembly optimizations on if available.
08:54:03:WU02:FS00:0x16:Entering M.D.
08:54:05:WU02:FS00:0x16:Tpr hash 02/wudata_01.tpr:  3393977762 2863883618 3070752013 2279527809 4176746313
08:54:05:WU02:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
08:54:05:WU02:FS00:0x16:Client config unavailable.
08:54:05:WU02:FS00:0x16:Starting GUI Server
08:54:14:WU02:FS00:0x16:Setting checkpoint frequency: 500000
08:54:14:WU02:FS00:0x16:Completed         3 out of 50000000 steps (0%).
08:54:16:WU02:FS00:0x16:Run: exception thrown in GuardedRun -- cannot continue further.
08:54:16:WU02:FS00:0x16:Going to send back what have done -- stepsTotalG=50000000
08:54:17:WU02:FS00:0x16:Work fraction=0.0004 steps=50000000.
08:54:20:WU02:FS00:0x16:logfile size=7221 infoLength=7221 edr=0 trr=23
08:54:20:WU02:FS00:0x16:+ Opened results file
08:54:20:WU02:FS00:0x16:- Writing 7757 bytes of core data to disk...
08:54:20:WU02:FS00:0x16:Decompress: Memory problem 2
08:54:20:WU02:FS00:0x16:  ... Done.
08:54:20:WU02:FS00:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
08:54:21:WU02:FS00:0x16:
08:54:21:WU02:FS00:0x16:Folding@home Core Shutdown: EARLY_UNIT_END
08:54:21:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
08:54:21:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:11293 run:27 clone:270 gen:37 core:0x16 unit:0x000000466652edbc4d94ba7c4d295a34
08:54:21:WU02:FS00:Uploading 1.09KiB to 171.67.108.44
08:54:21:WU02:FS00:Connecting to 171.67.108.44:8080
08:54:21:WU02:FS00:Upload complete
08:54:21:WU02:FS00:Server responded WORK_QUIT (404)
08:54:21:WARNING:WU02:FS00:Server did not like results, dumping
08:54:21:WU02:FS00:Cleaning up
08:54:21:ERROR:WU02:FS00:Exception: Failed to remove directory './work/02': boost::filesystem::remove: The process cannot access the file because it is being used by another process: ".\work\02\wudata_01.edr"
08:54:21:WU03:FS00:Connecting to assign-GPU.stanford.edu:80
08:54:22:WU03:FS00:News: Welcome to Folding@Home
08:54:22:WU03:FS00:Assigned to work server 171.67.108.44
08:54:22:WU03:FS00:Requesting new work unit for slot 00: READY gpu:2:"Cedar PRO [Radeon HD 5450]" from 171.67.108.44
08:54:22:WU03:FS00:Connecting to 171.67.108.44:8080
08:54:22:WU03:FS00:Downloading 44.34KiB
08:54:23:WU03:FS00:Download complete
08:54:23:WU03:FS00:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:11293 run:28 clone:270 gen:37 core:0x16 unit:0x000000456652edbc4d94baaf3436799c
08:54:23:WU03:FS00:Starting
08:54:23:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 03 -suffix 01 -version 702 -lifeline 4532 -checkpoint 3 -gpu 2
08:54:23:WU03:FS00:Started FahCore on PID 5260
08:54:23:WU03:FS00:Core PID:2900
08:54:23:WU03:FS00:FahCore 0x16 started
08:54:23:WU03:FS00:0x16:
08:54:23:WU03:FS00:0x16:*------------------------------*
08:54:23:WU03:FS00:0x16:Folding@Home GPU Core
08:54:23:WU03:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
08:54:23:WU03:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
08:54:23:WU03:FS00:0x16:Build host: user-f6d030f24f
08:54:23:WU03:FS00:0x16:Board Type: AMD/OpenCL
08:54:23:WU03:FS00:0x16:Core      : x=16
08:54:23:WU03:FS00:0x16: Window's signal control handler registered.
08:54:23:WU03:FS00:0x16:Preparing to commence simulation
08:54:23:WU03:FS00:0x16:- Looking at optimizations...
08:54:23:WU03:FS00:0x16:DeleteFrameFiles: successfully deleted file=03/wudata_01.ckp
08:54:23:WU03:FS00:0x16:- Created dyn
08:54:23:WU03:FS00:0x16:- Files status OK
08:54:23:WU03:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
08:54:23:WU03:FS00:0x16:- Expanded 44896 -> 171163 (decompressed 381.2 percent)
08:54:23:WU03:FS00:0x16:Called DecompressByteArray: compressed_data_size=44896 data_size=171163, decompressed_data_size=171163 diff=0
08:54:23:WU03:FS00:0x16:- Digital signature verified
08:54:23:WU03:FS00:0x16:Project: 11293 (Run 28, Clone 270, Gen 37)
08:54:23:WU03:FS00:0x16:Assembly optimizations on if available.
08:54:23:WU03:FS00:0x16:Entering M.D.
08:54:25:WU03:FS00:0x16:Tpr hash 03/wudata_01.tpr:  461830019 1265577424 4213818578 491970602 4132869790
08:54:25:WU03:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
08:54:25:WU03:FS00:0x16:Client config unavailable.
08:54:25:WU03:FS00:0x16:Starting GUI Server
08:54:31:WU03:FS00:0x16:Setting checkpoint frequency: 500000
08:54:31:WU03:FS00:0x16:Completed         3 out of 50000000 steps (0%).
08:54:33:WU03:FS00:0x16:Run: exception thrown in GuardedRun -- cannot continue further.
08:54:33:WU03:FS00:0x16:Going to send back what have done -- stepsTotalG=50000000
08:54:33:WU03:FS00:0x16:Work fraction=0.0004 steps=50000000.
08:54:37:WU03:FS00:0x16:logfile size=7221 infoLength=7221 edr=0 trr=23
08:54:37:WU03:FS00:0x16:+ Opened results file
08:54:37:WU03:FS00:0x16:- Writing 7757 bytes of core data to disk...
08:54:37:WU03:FS00:0x16:Decompress: Memory problem 2
08:54:37:WU03:FS00:0x16:  ... Done.
08:54:37:WU03:FS00:0x16:DeleteFrameFiles: successfully deleted file=03/wudata_01.ckp
08:54:37:WU03:FS00:0x16:Folding@home Core Shutdown: UNSTABLE_MACHINE
08:54:38:WARNING:WU03:FS00:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
08:54:38:WU03:FS00:Sending unit results: id:03 state:SEND error:FAULTY project:11293 run:28 clone:270 gen:37 core:0x16 unit:0x000000456652edbc4d94baaf3436799c
08:54:38:WU03:FS00:Uploading 1.09KiB to 171.67.108.44
08:54:38:WU03:FS00:Connecting to 171.67.108.44:8080
08:54:38:WU03:FS00:Upload complete
08:54:38:WU03:FS00:Server responded WORK_QUIT (404)
08:54:38:WARNING:WU03:FS00:Server did not like results, dumping
08:54:38:WU03:FS00:Cleaning up
08:55:01:WU01:FS00:Cleaning up
I'm running Windows 7 X64 with the latest Radeon 5450 drivers: AMD Version 9.2.0.0, dated 27/09/2012 installed using 12-10_vista_win7_win8_64_dd_ccc_whql_net4.exe No problems are reported via Device Manager and the adapter displays graphics just fine. Anything else that could be of use to ID the problem?
Rolo
Hardware configuration: Zaphod: i5-2500K@4.2GHz, 8GB DDR3-2133, GTX580@882/1765/2037
Trillian: i5-2500K@4.2GHz, 8GB DDR3-2133, GTX580@795/1590/2004
Beeblebrox: Conroe E6700@3.0GHz, 4x1GB Corsair Dominator PC8500 DDR2@900, Gigabyte GA-965P-DQ6v3.3, MSI N260GTX-T2D896-OC@621/1296/1080/1.125v (65nm-192core)
Hotblack: Wolfdale E7500@3.66, 2x2GB Crucial Ballistix PC8500 DDR2@1000, Gigabyte GA-965P-DQ6v3.3, MSI N260GTX-T2D896-OC@621/1296/1080/1.125v (65nm-192core)
Post by Rolo »
I infer that means video RAM problem; you may want to run VMT (Video Memory Test). (and memtest86+ first to be certain main RAM is fine)
If that passes, try Unigene Heaven (unless someone can suggest a video RAM tester that puts the GPU at 3D clocks whilst testing).
A number of persons have reported problems doing F@H using the 12.10 drivers. 12.8 is known to work. One user has reported a workaround has been posted at overclock.net for using the 12.10 drivers, forum post, but that may have its own issues. I would recommend 12.8 over using parts of two different installs.
The OpenMM folks at Stanford did a study on GPU memory and created memtestCL. Like the original memtest86, it's a bit clunky (runs from the "DOS box") but it seems to work through the OpenCL interface.
Rolo
Post by Rolo »
bruce wrote:The OpenMM folks at Stanford did a study on GPU memory and created memtestCL. Like the original memtest86, it's a bit clunky (runs from the "DOS box") but it seems to work through the OpenCL interface.
Sidebar: Would it be possible to make memtestG80/CL run at 3D performance clocks? Currently memtestG80 only tests my video RAM at 2D/desktop speeds (300MHz vs. 1080 and 324 vs. 2037)
Possible? Yes. Likely? No.
Nobody at Stanford is going to update memtestCL. They MIGHT accept an open-source submitted version or you can just publish it yourself as a 3rd party tool (after removing the part about submitting your results, since they've finished their study).
jrweiss
Post by jrweiss »
IMO, it's a waste of time to try to get a low-end AMD GPU Folding. IF you get it to run, the slowdown of your SMP WU will likely offset any points you get.
I tried on my 7750, but gave up. I previously Folded on several low-end ATI GPUs, including a 3850 and 4670. I don't want the endless trial & error of Catalyst releases and other conflicts any more...
jrweiss wrote:IMO, it's a waste of time to try to get a low-end AMD GPU Folding. IF you get it to run, the slowdown of your SMP WU will likely offset any points you get.
Support for the 3000 and 4000 series was withdrawn by ATI some time back and Stanford can't be expected to support them if ATI doesn't. OpenCL supported devices require V7.
You're very likely right for the 5000 series and perhaps the 6000 series, and it looks like AMD current drivers have a problem with the 7000 series. See Joe_H's post above for some work-arounds.
jrweiss
Post by jrweiss »
I understand about the 3000 and 4000 series. I abandoned them before Pande Group did, for the stated reasons.
IIRC, I started on an X1950, and bought that card specifically to try Folding on it...
Rolo
Post by Rolo »
heh...I have four X1950XTXs in the basement parts bin
Rolo
Post by Rolo »
You can run GPU-Z's render test to put the card in 3D mode and run memtestG80/CL concurrently. Test about 200MB less than what your GPU has total.
