171.64.65.93
davidcoton
171.64.65.93
Post by davidcoton »
Uploads are timing out after 15min. This is not adequate for 13+MB files on typical UK ADSL connections, which only get to 25-40% in that time.
Projects 7642 and 7644 currently trying to upload -sample filtered log below. (1 of 25 attempts between 2 WUs)
13:49:40:WU02:FS01:Sending unit results: id:02 state:SEND error:OK project:7642 run:21 clone:0 gen:3 core:0x15 unit:0x000000040a3b1e814f42a780e3d06148
13:49:40:WU02:FS01:Uploading 13.96MiB to 171.64.65.93
13:49:40:WU02:FS01:Connecting to 171.64.65.93:8080
13:49:51:WU02:FS01:Upload 4.03%
13:50:04:WU02:FS01:Upload 4.48%
13:50:15:WU02:FS01:Upload 4.93%
13:50:26:WU02:FS01:Upload 5.37%
13:50:40:WU02:FS01:Upload 5.82%
13:50:53:WU02:FS01:Upload 6.27%
13:51:07:WU02:FS01:Upload 6.72%
13:51:16:WU02:FS01:Upload 7.17%
13:51:27:WU02:FS01:Upload 7.61%
13:51:41:WU02:FS01:Upload 8.06%
13:51:54:WU02:FS01:Upload 8.51%
13:52:08:WU02:FS01:Upload 8.96%
13:52:21:WU02:FS01:Upload 9.40%
13:52:35:WU02:FS01:Upload 9.85%
13:52:48:WU02:FS01:Upload 10.30%
13:53:02:WU02:FS01:Upload 10.75%
13:53:15:WU02:FS01:Upload 11.20%
13:53:27:WU02:FS01:Upload 11.64%
13:53:34:WU02:FS01:Upload 12.09%
13:53:41:WU02:FS01:Upload 12.54%
13:53:48:WU02:FS01:Upload 12.99%
13:54:01:WU02:FS01:Upload 13.44%
13:54:15:WU02:FS01:Upload 13.88%
13:54:28:WU02:FS01:Upload 14.33%
13:54:41:WU02:FS01:Upload 14.78%
13:54:55:WU02:FS01:Upload 15.23%
13:55:08:WU02:FS01:Upload 15.67%
13:55:22:WU02:FS01:Upload 16.12%
13:55:35:WU02:FS01:Upload 16.57%
13:55:49:WU02:FS01:Upload 17.02%
13:56:03:WU02:FS01:Upload 17.47%
13:56:17:WU02:FS01:Upload 17.91%
13:56:30:WU02:FS01:Upload 18.36%
13:56:44:WU02:FS01:Upload 18.81%
13:56:57:WU02:FS01:Upload 19.26%
13:57:11:WU02:FS01:Upload 19.71%
13:57:24:WU02:FS01:Upload 20.15%
13:57:38:WU02:FS01:Upload 20.60%
13:57:52:WU02:FS01:Upload 21.05%
13:57:59:WU02:FS01:Upload 21.50%
13:58:06:WU02:FS01:Upload 21.94%
13:58:13:WU02:FS01:Upload 22.39%
13:58:20:WU02:FS01:Upload 22.84%
13:58:27:WU02:FS01:Upload 23.29%
13:58:34:WU02:FS01:Upload 23.74%
13:58:41:WU02:FS01:Upload 24.18%
13:58:48:WU02:FS01:Upload 24.63%
13:58:58:WU02:FS01:Upload 25.08%
13:59:12:WU02:FS01:Upload 25.53%
13:59:25:WU02:FS01:Upload 25.98%
13:59:39:WU02:FS01:Upload 26.42%
13:59:52:WU02:FS01:Upload 26.87%
14:00:06:WU02:FS01:Upload 27.32%
14:00:19:WU02:FS01:Upload 27.77%
14:00:32:WU02:FS01:Upload 28.21%
14:00:46:WU02:FS01:Upload 28.66%
14:00:59:WU02:FS01:Upload 29.11%
14:01:13:WU02:FS01:Upload 29.56%
14:01:26:WU02:FS01:Upload 30.01%
14:01:40:WU02:FS01:Upload 30.45%
14:01:53:WU02:FS01:Upload 30.90%
14:02:07:WU02:FS01:Upload 31.35%
14:02:20:WU02:FS01:Upload 31.80%
14:02:34:WU02:FS01:Upload 32.25%
14:02:47:WU02:FS01:Upload 32.69%
14:03:01:WU02:FS01:Upload 33.14%
14:03:14:WU02:FS01:Upload 33.59%
14:03:28:WU02:FS01:Upload 34.04%
14:03:41:WU02:FS01:Upload 34.48%
14:03:55:WU02:FS01:Upload 34.93%
14:04:09:WU02:FS01:Upload 35.38%
14:04:22:WU02:FS01:Upload 35.83%
14:04:36:WU02:FS01:Upload 36.28%
14:04:42:WU02:FS01:Upload 49.71%
14:04:44:WARNING:WU02:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
Regards,
David
tjlane
Pande Group Member
Re: 171.64.65.93
Post by tjlane »
David,
Thanks for bringing this to our attention. I'll increase the upload time immediately. Let us know if you continue to experience issues.
Thanks,
TJ
davidcoton
Re: 171.64.65.93
TJ,
Thanks for sorting that. Both WUs now uploaded, taking 49 and 26 min. The slower time was with another concurrent upload.
David
Re: 171.64.65.93
Just what speed is your aDSL provider giving you? I used to transfer compressed files over a 33.6kbps dial-up modem at the rate of 11 MB an hour. The slowest DSL uplink rate around here is 256 kbps, 768 kbps is more common. 256 kbps would transfer your 13 MB upload in 9-10 minutes. :eo
davidcoton
Re: 171.64.65.93
Joe_H wrote:Just what speed is your aDSL provider giving you?
Nominally, I'm getting a 1Mbps upload (good for UK ADSL, though things are improving). But on top of that there is contention with other users on the local loop, and I suspect some congestion further up. As you say, the raw sums do not indicate a problem, but in practice I have seen this sort of behaviour before -- there is a clear pattern of uploads aborting after a consistent period, which turns out to be the server timeout. There may be some other problem with an IP packet setting somewhere along the route, but there have been no suggestions which have made a difference so far. It may be significant that (AFAICT, and the evidence is elusive since the experiment is not repeatable) when the ADSL upload speed was doubled last year, upload times were nowhere near halved.
Regards,
David
