171.67.108.11, .25, assign3.stanford.edu
t-fh
Post by t-fh »
Repeatedly getting this error, any help appreciated.
14:03:22:Trying to send results to collection server
14:03:22:Unit 01: Uploading 4.85KiB
14:03:22:Connecting to 171.67.108.25:8080
14:03:23:WARNING: WorkServer connection failed on port 8080 trying 80
14:03:23:Connecting to 171.67.108.25:80
14:03:25:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
14:04:59:Sending unit results: id:01 state:SEND project:10514 run:8 clone:889 gen:480 core:0x11 unit:0x76490b014e21600b01e0037900082912
14:04:59:Unit 01: Uploading 4.85KiB
14:04:59:Connecting to 171.64.65.61:8080
14:04:59:WARNING: Exception: Failed to send results to work server: Failed to read response packet: HTTP_OK
MtM
Hardware configuration: Q6600 - 8gb - p5q deluxe - gtx275 - hd4350 ( not folding ) win7 x64 - smp:4 - gpu slot
T5450 - 4gb - ?? - 8600M GT 512 ( DDR2 ) - win7 x64 - smp:2 - gpu slot
Re: collection server refusing connection
Post by MtM »
Hello t-fh welcome to the forums.
I would not worry about that message, my logs are filled with them. They are still working hard on server upgrades but even currently it shouldn't take that long to upload the results. Eventually you should be able to connect to the work server.
The server status page linked on top of these forums list that server as being online and accepting, just give it some time. ( 171.64.65.61 is the WS, the CS 171.67.108.25 as any other CS servers are on standy eg not accepting any returns and have been for some time )
http://fah-web.stanford.edu/serverstat.html
Please post the log messages immediately before the ones that you posted. The client sends data to the CS only after it has failed to send the data to the primary work server, and it's that work server that we need to know about.
I think you'll find that Project 10514 is trying to upload to 171.64.65.61, as MtM suggests. I'm not aware of any long-term issues with that server but there could have been a temporary issue.
t-fh
Post by t-fh »
Here are a few more lines connecting immediately before log posted earlier.
14:02:12:Unit 01:Run: exception thrown during GuardedRun
14:02:12:Unit 01:Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
14:02:12:Unit 01:Going to send back what have done -- stepsTotalG=15000000
14:02:12:Unit 01:Work fraction=0.1829 steps=15000000.
14:02:16:Unit 01:logfile size=13870 infoLength=13870 edr=0 trr=23
14:02:16:Unit 01:+ Opened results file
14:02:16:Unit 01:- Writing 14406 bytes of core data to disk...
14:02:17:FahCore, running Unit 01, returned: UNSTABLE_MACHINE (122)
14:02:17:Starting Unit 01
14:02:17:Running core: "C:/Program Files/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/G80/Core_11.fah/FahCore_11.exe" -dir 01 -suffix 01 -lifeline 3860 -version 701 -checkpoint 15 -gpu 0
14:02:17:Started core on PID 560
14:02:17:FahCore 0x11 started
14:02:18:FahCore, running Unit 01, returned: MISSING_WORK_FILES (116)
14:02:18:WARNING: Unit 01 Fatal error, dumping
14:02:18:Sending unit results: id:01 state:SEND project:10514 run:8 clone:889 gen:480 core:0x11 unit:0x76490b014e21600b01e0037900082912
14:02:18:Unit 01: Uploading 4.85KiB
14:02:18:Connecting to 171.64.65.61:8080
14:02:18:WARNING: Exception: Failed to send results to work server: Failed to read response packet: HTTP_OK
14:02:18:Trying to send results to collection server
14:02:18:Connecting to 171.67.108.25:8080
14:02:18:Connecting to assign-GPU.stanford.edu:80
14:02:19:News: Welcome to Folding@Home
14:02:19:Assigned to work server 171.67.108.11
14:02:19:Requesting new work unit for slot 01: READY gpu:0:"G84 [GeForce 8600M GT]" from 171.67.108.11
14:02:19:Connecting to 171.67.108.11:8080
14:02:20:WARNING: WorkServer connection failed on port 8080 trying 80
14:02:20:Connecting to 171.67.108.25:80
14:02:20:Slot 01: Downloading 46.13KiB
14:02:21:Slot 01: Download complete
14:02:21:Received Unit: id:02 state:DOWNLOAD project:5765 run:14 clone:287 gen:2528 core:0x11 unit:0x1a922d0b4e21992f09e0011f000e1685
14:02:21:Starting Unit 02
14:02:21:Running core: "C:/Program Files/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/G80/Core_11.fah/FahCore_11.exe" -dir 02 -suffix 01 -lifeline 3860 -version 701 -checkpoint 15 -gpu 0
14:02:21:Started core on PID 3576
14:02:21:FahCore 0x11 started
14:02:21:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
14:02:21:Unit 02:
14:02:21:Unit 02:*------------------------------*
14:02:21:Unit 02:Folding@Home GPU Core
14:02:21:Unit 02:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
14:02:21:Unit 02:
14:02:21:Unit 02:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
14:02:21:Unit 02:Build host: amoeba
14:02:21:Unit 02:Board Type: Nvidia
14:02:21:Unit 02:Core      :
14:02:21:Unit 02:Preparing to commence simulation
14:02:21:Unit 02:- Looking at optimizations...
14:02:21:Unit 02:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
14:02:21:Unit 02:- Created dyn
14:02:21:Unit 02:- Files status OK
14:02:21:Unit 02:- Expanded 46728 -> 252912 (decompressed 541.2 percent)
14:02:21:Unit 02:Called DecompressByteArray: compressed_data_size=46728 data_size=252912, decompressed_data_size=252912 diff=0
14:02:21:Unit 02:- Digital signature verified
14:02:21:Unit 02:
14:02:21:Unit 02:Project: 5765 (Run 14, Clone 287, Gen 2528)
14:02:21:Unit 02:
14:02:21:Unit 02:Assembly optimizations on if available.
14:02:21:Unit 02:Entering M.D.
14:02:21:Sending unit results: id:01 state:SEND project:10514 run:8 clone:889 gen:480 core:0x11 unit:0x76490b014e21600b01e0037900082912
14:02:21:Unit 01: Uploading 4.85KiB
14:02:21:Connecting to 171.64.65.61:8080
14:02:21:WARNING: Exception: Failed to send results to work server: Failed to read response packet: HTTP_OK
14:02:21:Trying to send results to collection server
14:02:21:Connecting to 171.67.108.25:8080
14:02:23:WARNING: WorkServer connection failed on port 8080 trying 80
14:02:23:Connecting to 171.67.108.25:80
14:02:24:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
14:02:27:Unit 02:Tpr hash 02/wudata_01.tpr:  1873707734 1075098262 1404978288 773084095 4171426815
14:02:27:Unit 02:
14:02:27:Unit 02:Calling fah_main args: 14 usage=100
14:02:27:Unit 02:
14:02:27:Unit 02:Working on Protein
14:02:28:Unit 02:Client config unavailable.
14:02:28:Unit 02:Starting GUI Server
14:03:21:Sending unit results: id:01 state:SEND project:10514 run:8 clone:889 gen:480 core:0x11 unit:0x76490b014e21600b01e0037900082912
Mod Edit: Changed Quote Tags To Code Tags - PantherX
These are the lines we're interested in.
t-fh
Post by t-fh »
bruce wrote:These are the lines we're interested in.
Is there something I could do?
t-fh
Post by t-fh »
More errors:
09:55:47:Sending unit results: id:01 state:SEND project:10514 run:8 clone:889 gen:480 core:0x11 unit:0x76490b014e21600b01e0037900082912
09:55:53:Unit 01: Uploading 4.85KiB
09:55:53:Connecting to 171.64.65.61:8080
09:55:54:Server connection id=2 ended
09:55:54:WARNING: WorkServer connection failed on port 8080 trying 80
09:55:54:Connecting to 171.64.65.61:80
09:55:55:WARNING: Exception: Failed to send results to work server: Failed to connect to 171.64.65.61:80: A socket operation was attempted to an unreachable host.
09:55:55:Trying to send results to collection server
09:55:55:Unit 01: Uploading 4.85KiB
09:55:55:Connecting to 171.67.108.25:8080
09:55:55:WARNING: WorkServer connection failed on port 8080 trying 80
09:55:55:ERROR: Exception: Failed to connect to 171.67.108.25:80: A socket operation was attempted to an unreachable host.
09:55:58:Server connection id=3 on 0.0.0.0:36330 from 127.0.0.1
Failed to connect to 171.64.65.61:8080
Can you open http://171.64.65.61 in your browser?
t-fh
Post by t-fh »
Yes, I get a file named "download":
<html><b>OK</b></html>
codysluder
Post by codysluder »
Have you followed the instructions found here? viewtopic.php?f=18&t=17794
t-fh
Post by t-fh »
I have now - ports check out, 171.67.108.25 is listed as "Not accept" with CPU LOAD of 8.81 (but no error 503 displayed anywhere) at the moment, and probably has been for some time. For 171.64.65.61 all values are normal and should work.
Also, I found this:
This feature isn't fully implemented hence you should not report the Collection Server. Instead, you have to report the Work Server which is mentioned before the CS.The following CS should not be reported:
http://171.65.103.100
http://171.67.108.17
http://171.67.108.25
http://171.67.108.26
and
Note 4: Please remember that if the WU was an SMP one, your bonus points will decrease accordingly until the result has been successfully uploaded to the WS.
As currently folding WUs are still on the "Not accept" server, can I change the IP somehow?
Also the WU that couldn't be uploaded has disappeared along with a major portion of the log. Unfortunately it also hasn't been credited.
codysluder
People have been very patient with you but it's getting a little repetitive since they're telling you things that have been clearly explained elsewhere. Apparently you didn't notice the post that's a the top of this forum. It's very thorough and very complete.
Do this first: viewtopic.php?f=18&t=17794
t-fh
Post by t-fh »
I've read that link and replied (and quoted from there) that I have checked through the whole page (and done what is recommended in the first post); aside of that bruce asked for more log lines which I posted and asked to check out an IP in the browser, which I replied to. MtM hinted at the server stat page, which I checked out - I don't see where people had to be especially patient with me. One thing I haven't mentioned but which should be obvious from the logs I posted is that I use -verbosity 9. I've also rechecked the page you posted - can't find anything I haven't tried before. So may I assume from your reply that I'm missing something obvious?
codysluder
Sorry. I guess what I said came off as hostile, especially since I didn't really state clearly what I meant. I shouldn't post things when I'm in a hurry.
t-fh wrote:I have now - ports check out, 171.67.108.25 is listed as "Not accept" with CPU LOAD of 8.81 (but no error 503 displayed anywhere) at the moment, and probably has been for some time. For 171.64.65.61 all values are normal and should work.
Also, I found this:
OK. So we won't be talking about 171.67.108.25 any more. We'll focus on 171.64.65.61 in future discussions.
The last time 171.64.65.61 was "Down" or "Not accept" was 5 days ago, and that was for less than 20 minutes.
No, you cannot change the IP address. Specific projects belong to specific servers and the results have to be returned to the server that assigned the work to you.
You probably restarted the client. A new one is created when the client is restarted. The old logs are kept for a while in a directory called "logs". If that's not what happened, perhaps you need to run chkdisk. Depending on how long it has been since the WU was originally assigned, the WU may have expired. Once a WU expires, it is deleted. I recommend you look through the old logs and figure out what happened.
t-fh
Re: CS: 171.67.108.25 & WS: 171.67.108.11
Post by t-fh »
When I looked for the log (file) last time it wasn't there anymore, unfortunately. For now there are no more unsent WUs left, so I'll wait and see whether the next complete one gets through to those servers.
