some kind of bug ? or my WU is going to the recycle bin
Certificates only 300 WU out of 4000+ WU
technomage
just couple of days ago pay attention that I contribute more 4000 WU and my last certificate is only for 300 WU
MtM
Re: Certificates only 300 WU out of 4000+ WU
Maybe the 300 credited wu's are tied to your passkey and the remainder are not? When I do a search there is a big difference to what's coupled to my username/passkey combination then to my username alone just as you seem to have ( as most of my contributions pre-date the passkey.
technomage
how it can be mate? all my folder stations contribute to the same team 33 and under the same name "technomag"
so how the wu can be coupled to someone else (or be uncoupled to my acc)
sorry for noobish question
MtM
Do you have a passkey? When did you get one, and start using it?
The stats when you search for username/passkey only show the wu's tied to the passkey, not all wu's tied to the username.
Do a search for Marvin_The_Martian as username, note that I folded for quite some time ( though I'm no hardcore folder with a large farm, just what I got at home ). Almost all work units I completed do not have a passkey tied to them, so when I search for Marvin_The_Martian in combination with my passkey I don't find many wu's at all.
technomage
so, now I'am know what is the passkey
thanks
thanks
technomage
again, I update every client with passkey and still after couple of months the certificate freezed at 300 WU ??
what to do ??
what to do ??
Zagen30
I searched for "technomage" and came up with this name contributing to team 33: http://fah-web.stanford.edu/cgi-bin/mai ... TechnoMage
If this is you, you've contributed far more than 300 WUs. Where are you still seeing only 300 WUs?
You didn't accidentally click on the user "technomage" who has folded for MozillaZine (39340) did you? That user has folded 309 work units and would get a certificate for 300 points...
There is also a "technomage" folding for the default - might pay to check that all your clients are folding for team 33.
technomage
Postby Zagen30 » Wed Aug 17, 2011 5:29 pm
Indeed I contribute 300 units to mozillazine team and the rest 4k+ to team 33
I see 300units certificate then I ask for user statistics from F@H core in my pc (the core run to team 33, like all the cores)
Zagen30
Can you post the link to the page that comes up through the client?
technomage
here the links
http://fah-web.stanford.edu/cgi-bin/mai ... technomage
the certificate:
http://fah-web.stanford.edu/awards/cach ... e.5229.jpg
in the first link you can see 5.2k + of units but if you click on the link of certificate (from the page of statistics)
you only see certificate of 300 units
I will follow the donation of the units, just want to see my contribution
the certificate:
Zagen30
It seems like it's something to do with capitalization. It appears the stats are lumping technomage and TechnoMage together. Apparently technomage contributed under teams 0 and 39340, TechnoMage contributed under team 33, and Technomage contributed under team 500. Perhaps the stats server is getting confused.
technomage
thanks, I thought it maybe an issue. So whom I need to ask about the stats?
capitals or not it both mine
does someone from pande group can help me with that issue ?
Stats from different accounts cannot be merged. The only way to sort out which ones are yours and which ones (might) belong to someone else is if you used the same passkey. Have you tried listing the stats with your passkey?
The best we can do is find the certificate for the correct spelling of the user name such as http://fah-web.stanford.edu/awards/cach ... e.5229.jpg
technomage
Hi all, just checked again my contribution score and whoa'lya all WU is there
not that it is very important, but indeed warm a bit my heart.
