Complete v6.41 Fermi client for download?
I ran into this before with a newly built system with Fermi video card.
I went to the page at Stanford with all the clients, and download the Fermi console client v6.41 ... and it won't run. It's missing something ... "cudart32_30_14.dll is missing".
Searching online seems to indicate that 6.41 is designed to be used in an "upgrade" situation ... where certain files from older clients are still on the system. This is not true for a newly built system.
What gives? Where does Stanford hide the full Fermi console client?
I mess around googling for the missing files and wind up downloading a "rar" of the missing dll's from a dubious source .... last time I did this, I was lucky ... but now with my new PC build, my client almost but never quite "runs" (or actually fully satrt) correctly. I want to delete it and start fresh ... but with an official "Full" copy of the 6.41 client.
Thanks,
Thanks,
MtM
Re: Complete v6.41 Fermi client for download?
You downloaded the drop in executable, scroll up and look for the version for your operating system, that will install all dependencies, after that drop in the executable overwriting the existing one.
Or, try the v7 beta -> viewforum.php?f=67
OK, so If I want to go with the established console GPU clients for now, I would download the non-Fermi v6.23 for Vista/Win7 ... install it ... then replace the executable with the v6.41 (Fermi) one that I downloaded earlier ?
I just tried what I said just above, and I am still getting message "cudart32_30_14.dll is missing" ...also that "cufft32_30_14.dll " was missing. I added them from my files in my previous attempt's folder ... but I am still getting "Error Starting Folding @Home Core".
This loops and it downloads a new WU ... to no avail ... the loop continues as before with the "Error" starting a new attempt
Here is my Fahlog.txt
--- Opening Log file [April 21 15:41:26 UTC]
Folding@Home Client Version 6.41r2
http://folding.stanford.edu
Launch directory: F:\Folding\GPU1
Executable: F:\Folding\GPU1\FAH641.exe
[15:41:26] Gpu type=3 species=21.
[15:41:26] Configuring Folding@Home...
[15:44:44] - Ask before connecting: No
[15:44:44] - User name: Ron_S (Team 37412)
[15:44:44] - User ID:
[15:44:44] - Machine ID: 4
[15:44:44]
[15:44:44] Work directory not found. Creating...
[15:44:44] Could not open work queue, generating new queue...
[15:44:44] - Preparing to get new work unit...
[15:44:44] Cleaning up work directory
[15:44:44] - Autosending finished units... [April 21 15:44:44 UTC]
[15:44:44] + Attempting to get work packet
[15:44:44] Trying to send all finished work units
[15:44:44] Passkey found
[15:44:44] + No unsent completed units remaining.
[15:44:44] - Will indicate memory of 6000 MB
[15:44:44] - Autosend completed
[15:44:44] Gpu type=3 species=21.
[15:44:44] - Detect CPU. Vendor: AuthenticAMD, Family: 15, Model: 10, Stepping: 0
[15:44:44] - Connecting to assignment server
[15:44:44] Connecting to http://assign-GPU.stanford.edu:8080/
[15:44:45] Posted data.
[15:44:45] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[15:44:45] + News From Folding@Home: Welcome to Folding@Home
[15:44:45] Loaded queue successfully.
[15:44:45] Gpu type=3 species=21.
[15:44:45] Sent data
[15:44:45] Connecting to http://171.64.65.64:8080/
[15:44:45] Initial: 0000; - Receiving payload (expected size: 42077)
[15:44:46] - Downloaded at ~41 kB/s
[15:44:46] - Averaged speed for that direction ~41 kB/s
[15:44:46] + Received work.
[15:44:46] + Closed connections
[15:44:46]
[15:44:46] + Processing work unit
[15:44:46] Core required: FahCore_15.exe
[15:44:46] Core not found.
[15:44:46] - Core is not present or corrupted.
[15:44:46] - Attempting to download new core...
[15:44:46] + Downloading new core: FahCore_15.exe
[15:44:46] Downloading core (/~pande/Win32/x86/NVIDIA/Fermi/Core_15.fah from www.stanford.edu)
[15:44:46] Initial: AFDE; + 10240 bytes downloaded
[15:44:47] Initial: 4A9F; + 20480 bytes downloaded
[15:44:47] Initial: 02DB; + 30720 bytes downloaded
[15:44:47] Initial: 32D2; + 40960 bytes downloaded
[15:44:47] Initial: 0664; + 51200 bytes downloaded
[15:44:47] Initial: 0400; + 61440 bytes downloaded
[15:44:47] Initial: 3AB8; + 71680 bytes downloaded
[15:44:47] Initial: F8D2; + 81920 bytes downloaded
[15:44:47] Initial: F4EE; + 92160 bytes downloaded
[15:44:47] Initial: ECE1; + 102400 bytes downloaded
[15:44:47] Initial: 9A21; + 112640 bytes downloaded
[15:44:47] Initial: 4572; + 122880 bytes downloaded
[15:44:47] Initial: A5AF; + 133120 bytes downloaded
[15:44:47] Initial: AE73; + 143360 bytes downloaded
[15:44:47] Initial: 324F; + 153600 bytes downloaded
[15:44:47] Initial: 6A97; + 163840 bytes downloaded
[15:44:47] Initial: E123; + 174080 bytes downloaded
[15:44:47] Initial: 5426; + 184320 bytes downloaded
[15:44:47] Initial: 9D76; + 194560 bytes downloaded
[15:44:47] Initial: 2226; + 204800 bytes downloaded
[15:44:48] Initial: FE64; + 215040 bytes downloaded
[15:44:48] Initial: F9F2; + 225280 bytes downloaded
[15:44:48] Initial: 4F35; + 235520 bytes downloaded
[15:44:48] Initial: D07D; + 245760 bytes downloaded
[15:44:48] Initial: 9E40; + 256000 bytes downloaded
[15:44:48] Initial: 38A2; + 266240 bytes downloaded
[15:44:48] Initial: BD94; + 276480 bytes downloaded
[15:44:48] Initial: 4BAC; + 286720 bytes downloaded
[15:44:48] Initial: D740; + 296960 bytes downloaded
[15:44:48] Initial: B43A; + 307200 bytes downloaded
[15:44:48] Initial: 4B3F; + 317440 bytes downloaded
[15:44:48] Initial: BDD0; + 327680 bytes downloaded
[15:44:48] Initial: 18EB; + 337920 bytes downloaded
[15:44:48] Initial: E612; + 348160 bytes downloaded
[15:44:48] Initial: BD4D; + 358400 bytes downloaded
[15:44:48] Initial: D804; + 368640 bytes downloaded
[15:44:48] Initial: B7D0; + 378880 bytes downloaded
[15:44:48] Initial: 6492; + 389120 bytes downloaded
[15:44:48] Initial: B390; + 399360 bytes downloaded
[15:44:48] Initial: 2ADA; + 409600 bytes downloaded
[15:44:48] Initial: BAB5; + 419840 bytes downloaded
[15:44:48] Initial: BC78; + 430080 bytes downloaded
[15:44:48] Initial: 1119; + 440320 bytes downloaded
[15:44:48] Initial: 27B1; + 450560 bytes downloaded
[15:44:49] Initial: 8A2A; + 460800 bytes downloaded
[15:44:49] Initial: 6F27; + 471040 bytes downloaded
[15:44:49] Initial: FFFF; + 481280 bytes downloaded
[15:44:49] Initial: D0B6; + 491520 bytes downloaded
[15:44:49] Initial: 0702; + 501760 bytes downloaded
[15:44:49] Initial: 08C1; + 512000 bytes downloaded
[15:44:49] Initial: E64B; + 522240 bytes downloaded
[15:44:49] Initial: F5F0; + 532480 bytes downloaded
[15:44:49] Initial: 98CB; + 542720 bytes downloaded
[15:44:49] Initial: 2477; + 552960 bytes downloaded
[15:44:49] Initial: 494C; + 563200 bytes downloaded
[15:44:49] Initial: 4D49; + 573440 bytes downloaded
[15:44:49] Initial: C6C8; + 583680 bytes downloaded
[15:44:49] Initial: 2D13; + 593920 bytes downloaded
[15:44:49] Initial: 03F9; + 604160 bytes downloaded
[15:44:49] Initial: 1315; + 614400 bytes downloaded
[15:44:49] Initial: 0887; + 624640 bytes downloaded
[15:44:49] Initial: 5BA1; + 634880 bytes downloaded
[15:44:49] Initial: E140; + 645120 bytes downloaded
[15:44:49] Initial: 1E9D; + 655360 bytes downloaded
[15:44:49] Initial: 6C1A; + 665600 bytes downloaded
[15:44:49] Initial: 8A4A; + 675840 bytes downloaded
[15:44:49] Initial: 57FD; + 686080 bytes downloaded
[15:44:50] Initial: F8E0; + 696320 bytes downloaded
[15:44:50] Initial: 0CD1; + 706560 bytes downloaded
[15:44:50] Initial: D1E2; + 716800 bytes downloaded
[15:44:50] Initial: 9CA8; + 727040 bytes downloaded
[15:44:50] Initial: 7F13; + 737280 bytes downloaded
[15:44:50] Initial: 3231; + 747520 bytes downloaded
[15:44:50] Initial: 5F16; + 757760 bytes downloaded
[15:44:50] Initial: BF95; + 768000 bytes downloaded
[15:44:50] Initial: 70A4; + 778240 bytes downloaded
[15:44:50] Initial: 6D26; + 788480 bytes downloaded
[15:44:50] Initial: 13C7; + 798720 bytes downloaded
[15:44:50] Initial: 9F26; + 808960 bytes downloaded
[15:44:50] Initial: C7B5; + 819200 bytes downloaded
[15:44:50] Initial: D5A9; + 829440 bytes downloaded
[15:44:50] Initial: F796; + 839680 bytes downloaded
[15:44:50] Initial: A004; + 849920 bytes downloaded
[15:44:50] Initial: 1011; + 860160 bytes downloaded
[15:44:50] Initial: 3F6F; + 870400 bytes downloaded
[15:44:50] Initial: B01C; + 880640 bytes downloaded
[15:44:50] Initial: E903; + 890880 bytes downloaded
[15:44:50] Initial: 29D0; + 901120 bytes downloaded
[15:44:50] Initial: 3DD6; + 911360 bytes downloaded
[15:44:50] Initial: D5BF; + 921600 bytes downloaded
[15:44:50] Initial: EC69; + 931840 bytes downloaded
[15:44:50] Initial: 1A1D; + 942080 bytes downloaded
[15:44:51] Initial: 7BC0; + 952320 bytes downloaded
[15:44:51] Initial: 9C4E; + 962560 bytes downloaded
[15:44:51] Initial: 9C59; + 972800 bytes downloaded
[15:44:51] Initial: 7BBD; + 983040 bytes downloaded
[15:44:51] Initial: D395; + 993280 bytes downloaded
[15:44:51] Initial: 5239; + 1003520 bytes downloaded
[15:44:51] Initial: BE83; + 1013760 bytes downloaded
[15:44:51] Initial: 428D; + 1024000 bytes downloaded
[15:44:51] Initial: E2EE; + 1034240 bytes downloaded
[15:44:51] Initial: 64BB; + 1044480 bytes downloaded
[15:44:51] Initial: 7200; + 1054720 bytes downloaded
[15:44:51] Initial: 71BB; + 1064960 bytes downloaded
[15:44:51] Initial: 9A20; + 1075200 bytes downloaded
[15:44:51] Initial: 1D08; + 1085440 bytes downloaded
[15:44:51] Initial: B1BD; + 1095680 bytes downloaded
[15:44:51] Initial: 4946; + 1105920 bytes downloaded
[15:44:51] Initial: 5297; + 1116160 bytes downloaded
[15:44:51] Initial: 201F; + 1126400 bytes downloaded
[15:44:51] Initial: A318; + 1136640 bytes downloaded
[15:44:51] Initial: 3ED5; + 1146880 bytes downloaded
[15:44:51] Initial: 8473; + 1157120 bytes downloaded
[15:44:51] Initial: D9B9; + 1167360 bytes downloaded
[15:44:51] Initial: 2D15; + 1177600 bytes downloaded
[15:44:51] Initial: F6A1; + 1187840 bytes downloaded
[15:44:52] Initial: 1850; + 1198080 bytes downloaded
[15:44:52] Initial: 3D3E; + 1208320 bytes downloaded
[15:44:52] Initial: 2ADB; + 1218560 bytes downloaded
[15:44:52] Initial: FF21; + 1228800 bytes downloaded
[15:44:52] Initial: 1708; + 1239040 bytes downloaded
[15:44:52] Initial: ADA8; + 1249280 bytes downloaded
[15:44:52] Initial: 8E4E; + 1259520 bytes downloaded
[15:44:52] Initial: 63C7; + 1269760 bytes downloaded
[15:44:52] Initial: 7316; + 1280000 bytes downloaded
[15:44:52] Initial: B3D8; + 1290240 bytes downloaded
[15:44:52] Initial: 2693; + 1300480 bytes downloaded
[15:44:52] Initial: 1B77; + 1310720 bytes downloaded
[15:44:52] Initial: F16F; + 1320960 bytes downloaded
[15:44:52] Initial: 45F0; + 1331200 bytes downloaded
[15:44:52] Initial: 289C; + 1341440 bytes downloaded
[15:44:52] Initial: 83F2; + 1351680 bytes downloaded
[15:44:52] Initial: 1459; + 1361920 bytes downloaded
[15:44:52] Initial: 1A62; + 1372160 bytes downloaded
[15:44:52] Initial: C408; + 1382400 bytes downloaded
[15:44:52] Initial: C561; + 1392640 bytes downloaded
[15:44:52] Initial: 8827; + 1402880 bytes downloaded
[15:44:52] Initial: 3F18; + 1413120 bytes downloaded
[15:44:52] Initial: 212C; + 1422551 bytes downloaded
[15:44:53] Verifying core Core_15.fah...
[15:44:53] Signature is VALID
[15:44:53]
[15:44:53] Trying to unzip core FahCore_15.exe
[15:44:53] Decompressed FahCore_15.exe (3903488 bytes) successfully
[15:44:58] + Core successfully engaged
[15:45:03]
[15:45:03] + Processing work unit
[15:45:03] Core required: FahCore_15.exe
[15:45:03] Core found.
[15:45:03] Working on queue slot 01 [April 21 15:45:03 UTC]
[15:45:03] + Working ...
[15:45:03] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -nocpulock -checkpoint 3 -verbose -lifeline 4532 -version 641'
[15:46:48] CoreStatus = C0000135 (-1073741515)
[15:46:48] Client-core communications error: ERROR 0xc0000135
[15:46:48] This is a sign of more serious problems, shutting down.
[15:46:59] ***** Got a SIGTERM signal (2)
[15:46:59] Killing all core threads
Folding@Home Client Shutdown.
--- Opening Log file [April 21 15:47:40 UTC]
Arguments: -gpu 0 -verbosity 9 -local
[15:47:40] - Ask before connecting: No
[15:47:40] - User name: Ron_S (Team 37412)
[15:47:40] - User ID:
[15:47:40] - Machine ID: 4
[15:47:40]
[15:47:40] Gpu type=3 species=21.
[15:47:40] Loaded queue successfully.
[15:47:40]
[15:47:40] - Autosending finished units... [April 21 15:47:40 UTC]
[15:47:40] + Processing work unit
[15:47:40] Core required: FahCore_15.exe
[15:47:40] Core found.
[15:47:40] Working on queue slot 01 [April 21 15:47:40 UTC]
[15:47:40] + Working ...
[15:47:40] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -nocpulock -checkpoint 3 -verbose -lifeline 2992 -version 641'
[15:47:40] Trying to send all finished work units
[15:47:40] + No unsent completed units remaining.
[15:47:40] - Autosend completed
[15:47:46] CoreStatus = C0000135 (-1073741515)
[15:47:46] Client-core communications error: ERROR 0xc0000135
[15:47:46] This is a sign of more serious problems, shutting down.
--- Opening Log file [April 21 15:48:13 UTC]
[15:48:13] - Ask before connecting: No
[15:48:13] - User name: Ron_S (Team 37412)
[15:48:13] - User ID
[15:48:13] - Machine ID: 4
[15:48:13]
[15:48:13] Gpu type=3 species=21.
[15:48:13] Loaded queue successfully.
[15:48:13]
[15:48:13] + Processing work unit
[15:48:13] - Autosending finished units... [April 21 15:48:13 UTC]
[15:48:13] Core required: FahCore_15.exe
[15:48:13] Core found.
[15:48:13] Working on queue slot 01 [April 21 15:48:13 UTC]
[15:48:13] + Working ...
[15:48:13] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -nocpulock -checkpoint 3 -verbose -lifeline 916 -version 641'
[15:48:13] Trying to send all finished work units
[15:48:13] + No unsent completed units remaining.
[15:48:13] - Autosend completed
[15:48:14]
[15:48:14] *------------------------------*
[15:48:14] Folding@Home GPU Core
[15:48:14] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[15:48:14]
[15:48:14] Build host: SimbiosNvdWin7
[15:48:14] Board Type: NVIDIA/CUDA
[15:48:14] Core : x=15
[15:48:14] Window's signal control handler registered.
[15:48:14] Preparing to commence simulation
[15:48:14] - Looking at optimizations...
[15:48:14] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[15:48:14] - Created dyn
[15:48:14] - Files status OK
[15:48:14] sizeof(CORE_PACKET_HDR) = 512 file=<>
[15:48:14] - Expanded 41565 -> 162639 (decompressed 391.2 percent)
[15:48:14] Called DecompressByteArray: compressed_data_size=41565 data_size=162639, decompressed_data_size=162639 diff=0
[15:48:14] - Digital signature verified
[15:48:14]
[15:48:14] Project: 6805 (Run 8635, Clone 2, Gen 11)
[15:48:14]
[15:48:14] Assembly optimizations on if available.
[15:48:14] Entering M.D.
[15:48:16] Tpr hash work/wudata_01.tpr: 1727262770 1673432331 2831433277 1952541477 3366849156
[15:48:16] Working on ALZHEIMER'S DISEASE AMYLOID
[15:48:16] Client config found, loading data.
[15:48:20] CoreStatus = 63 (99)
[15:48:20] + Error starting Folding@home core.
[15:48:25]
[15:48:25] + Processing work unit
[15:48:25] Core required: FahCore_15.exe
[15:48:25] Core found.
[15:48:25] Working on queue slot 01 [April 21 15:48:25 UTC]
[15:48:25] + Working ...
[15:48:25] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -nocpulock -checkpoint 3 -verbose -lifeline 916 -version 641'
[15:48:25]
[15:48:25] *------------------------------*
[15:48:25] Folding@Home GPU Core
[15:48:25] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[15:48:25]
[15:48:25] Build host: SimbiosNvdWin7
[15:48:25] Board Type: NVIDIA/CUDA
[15:48:25] Core : x=15
[15:48:25] Window's signal control handler registered.
[15:48:25] Preparing to commence simulation
[15:48:25] - Ensuring status. Please wait.
[15:48:34] - Looking at optimizations...
[15:48:34] - Working with standard loops on this execution.
[15:48:34] - Previous termination of core was improper.
[15:48:34] - Files status OK
[15:48:34] sizeof(CORE_PACKET_HDR) = 512 file=<>
[15:48:34] - Expanded 41565 -> 162639 (decompressed 391.2 percent)
[15:48:34] Called DecompressByteArray: compressed_data_size=41565 data_size=162639, decompressed_data_size=162639 diff=0
[15:48:34] - Digital signature verified
[15:48:34]
[15:48:34] Project: 6805 (Run 8635, Clone 2, Gen 11)
[15:48:34]
[15:48:34] Entering M.D.
[15:48:36] Tpr hash work/wudata_01.tpr: 1727262770 1673432331 2831433277 1952541477 3366849156
[15:48:36] Working on ALZHEIMER'S DISEASE AMYLOID
[15:48:36] Client config found, loading data.
[15:48:39] CoreStatus = 63 (99)
[15:48:39] + Error starting Folding@home core.
[15:48:44]
[15:48:44] + Processing work unit
[15:48:44] Core required: FahCore_15.exe
[15:48:44] Core found.
[15:48:44] Working on queue slot 01 [April 21 15:48:44 UTC]
[15:48:44] + Working ...
[15:48:44] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -nocpulock -checkpoint 3 -verbose -lifeline 916 -version 641'
[15:48:44]
[15:48:44] *------------------------------*
[15:48:44] Folding@Home GPU Core
[15:48:44] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[15:48:44]
[15:48:44] Build host: SimbiosNvdWin7
[15:48:44] Board Type: NVIDIA/CUDA
[15:48:44] Core : x=15
[15:48:44] Window's signal control handler registered.
[15:48:44] Preparing to commence simulation
[15:48:44] - Ensuring status. Please wait.
[15:48:54] - Looking at optimizations...
[15:48:54] - Working with standard loops on this execution.
[15:48:54] - Previous termination of core was improper.
[15:48:54] - Going to use standard loops.
[15:48:54] - Files status OK
[15:48:54] sizeof(CORE_PACKET_HDR) = 512 file=<>
[15:48:54] - Expanded 41565 -> 162639 (decompressed 391.2 percent)
[15:48:54] Called DecompressByteArray: compressed_data_size=41565 data_size=162639, decompressed_data_size=162639 diff=0
[15:48:54] - Digital signature verified
[15:48:54]
[15:48:54] Project: 6805 (Run 8635, Clone 2, Gen 11)
[15:48:54]
[15:48:54] Entering M.D.
[15:48:56] Tpr hash work/wudata_01.tpr: 1727262770 1673432331 2831433277 1952541477 3366849156
[15:48:56] Working on ALZHEIMER'S DISEASE AMYLOID
[15:48:56] Client config found, loading data.
[15:48:58] CoreStatus = 63 (99)
[15:48:58] + Error starting Folding@home core.
[15:48:58] - Attempting to download new core...
[15:48:58] + Downloading new core: FahCore_15.exe
[15:48:58] Downloading core (/~pande/Win32/x86/NVIDIA/Fermi/Core_15.fah from www.stanford.edu)
[15:48:58] Initial: AFDE; + 10240 bytes downloaded
[15:48:59] Initial: 4A9F; + 20480 bytes downloaded
[15:48:59] Initial: 02DB; + 30720 bytes downloaded
[15:48:59] Initial: 32D2; + 40960 bytes downloaded
[15:48:59] Initial: 0664; + 51200 bytes downloaded
[15:48:59] Initial: 0400; + 61440 bytes downloaded
[15:48:59] Initial: 3AB8; + 71680 bytes downloaded
[15:48:59] Initial: F8D2; + 81920 bytes downloaded
[15:48:59] Initial: F4EE; + 92160 bytes downloaded
[15:48:59] Initial: ECE1; + 102400 bytes downloaded
[15:48:59] Initial: 9A21; + 112640 bytes downloaded
[15:48:59] Initial: 4572; + 122880 bytes downloaded
[15:48:59] Initial: A5AF; + 133120 bytes downloaded
[15:48:59] Initial: AE73; + 143360 bytes downloaded
[15:48:59] Initial: 324F; + 153600 bytes downloaded
[15:48:59] Initial: 6A97; + 163840 bytes downloaded
[15:48:59] Initial: E123; + 174080 bytes downloaded
[15:49:00] Initial: 5426; + 184320 bytes downloaded
[15:49:00] Initial: 9D76; + 194560 bytes downloaded
[15:49:00] Initial: 2226; + 204800 bytes downloaded
[15:49:00] Initial: FE64; + 215040 bytes downloaded
[15:49:00] Initial: F9F2; + 225280 bytes downloaded
[15:49:00] Initial: 4F35; + 235520 bytes downloaded
[15:49:00] Initial: D07D; + 245760 bytes downloaded
[15:49:00] Initial: 9E40; + 256000 bytes downloaded
[15:49:00] Initial: 38A2; + 266240 bytes downloaded
[15:49:00] Initial: BD94; + 276480 bytes downloaded
[15:49:00] Initial: 4BAC; + 286720 bytes downloaded
[15:49:00] Initial: D740; + 296960 bytes downloaded
[15:49:00] Initial: B43A; + 307200 bytes downloaded
[15:49:00] Initial: 4B3F; + 317440 bytes downloaded
[15:49:00] Initial: BDD0; + 327680 bytes downloaded
[15:49:00] Initial: 18EB; + 337920 bytes downloaded
[15:49:00] Initial: E612; + 348160 bytes downloaded
[15:49:00] Initial: BD4D; + 358400 bytes downloaded
[15:49:00] Initial: D804; + 368640 bytes downloaded
[15:49:00] Initial: B7D0; + 378880 bytes downloaded
[15:49:00] Initial: 6492; + 389120 bytes downloaded
[15:49:00] Initial: B390; + 399360 bytes downloaded
[15:49:00] Initial: 2ADA; + 409600 bytes downloaded
[15:49:00] Initial: BAB5; + 419840 bytes downloaded
[15:49:00] Initial: BC78; + 430080 bytes downloaded
[15:49:01] Initial: 1119; + 440320 bytes downloaded
[15:49:01] Initial: 27B1; + 450560 bytes downloaded
[15:49:01] Initial: 8A2A; + 460800 bytes downloaded
[15:49:01] Initial: 6F27; + 471040 bytes downloaded
[15:49:01] Initial: FFFF; + 481280 bytes downloaded
[15:49:01] Initial: D0B6; + 491520 bytes downloaded
[15:49:01] Initial: 0702; + 501760 bytes downloaded
[15:49:01] Initial: 08C1; + 512000 bytes downloaded
[15:49:01] Initial: E64B; + 522240 bytes downloaded
[15:49:01] Initial: F5F0; + 532480 bytes downloaded
[15:49:01] Initial: 98CB; + 542720 bytes downloaded
[15:49:01] Initial: 2477; + 552960 bytes downloaded
[15:49:01] Initial: 494C; + 563200 bytes downloaded
[15:49:01] Initial: 4D49; + 573440 bytes downloaded
[15:49:01] Initial: C6C8; + 583680 bytes downloaded
[15:49:01] Initial: 2D13; + 593920 bytes downloaded
[15:49:01] Initial: 03F9; + 604160 bytes downloaded
[15:49:01] Initial: 1315; + 614400 bytes downloaded
[15:49:01] Initial: 0887; + 624640 bytes downloaded
[15:49:01] Initial: 5BA1; + 634880 bytes downloaded
[15:49:01] Initial: E140; + 645120 bytes downloaded
[15:49:01] Initial: 1E9D; + 655360 bytes downloaded
[15:49:01] Initial: 6C1A; + 665600 bytes downloaded
[15:49:01] Initial: 8A4A; + 675840 bytes downloaded
[15:49:02] Initial: 57FD; + 686080 bytes downloaded
[15:49:02] Initial: F8E0; + 696320 bytes downloaded
[15:49:02] Initial: 0CD1; + 706560 bytes downloaded
[15:49:02] Initial: D1E2; + 716800 bytes downloaded
[15:49:02] Initial: 9CA8; + 727040 bytes downloaded
[15:49:02] Initial: 7F13; + 737280 bytes downloaded
[15:49:02] Initial: 3231; + 747520 bytes downloaded
[15:49:02] Initial: 5F16; + 757760 bytes downloaded
[15:49:02] Initial: BF95; + 768000 bytes downloaded
[15:49:02] Initial: 70A4; + 778240 bytes downloaded
[15:49:02] Initial: 6D26; + 788480 bytes downloaded
[15:49:02] Initial: 13C7; + 798720 bytes downloaded
[15:49:02] Initial: 9F26; + 808960 bytes downloaded
[15:49:02] Initial: C7B5; + 819200 bytes downloaded
[15:49:02] Initial: D5A9; + 829440 bytes downloaded
[15:49:02] Initial: F796; + 839680 bytes downloaded
[15:49:02] Initial: A004; + 849920 bytes downloaded
[15:49:02] Initial: 1011; + 860160 bytes downloaded
[15:49:02] Initial: 3F6F; + 870400 bytes downloaded
[15:49:02] Initial: B01C; + 880640 bytes downloaded
[15:49:02] Initial: E903; + 890880 bytes downloaded
[15:49:02] Initial: 29D0; + 901120 bytes downloaded
[15:49:02] Initial: 3DD6; + 911360 bytes downloaded
[15:49:03] Initial: D5BF; + 921600 bytes downloaded
[15:49:03] Initial: EC69; + 931840 bytes downloaded
[15:49:03] Initial: 1A1D; + 942080 bytes downloaded
[15:49:03] Initial: 7BC0; + 952320 bytes downloaded
[15:49:03] Initial: 9C4E; + 962560 bytes downloaded
[15:49:03] Initial: 9C59; + 972800 bytes downloaded
[15:49:03] Initial: 7BBD; + 983040 bytes downloaded
[15:49:03] Initial: D395; + 993280 bytes downloaded
[15:49:03] Initial: 5239; + 1003520 bytes downloaded
[15:49:03] Initial: BE83; + 1013760 bytes downloaded
[15:49:03] Initial: 428D; + 1024000 bytes downloaded
[15:49:03] Initial: E2EE; + 1034240 bytes downloaded
[15:49:03] Initial: 64BB; + 1044480 bytes downloaded
[15:49:03] Initial: 7200; + 1054720 bytes downloaded
[15:49:03] Initial: 71BB; + 1064960 bytes downloaded
[15:49:03] Initial: 9A20; + 1075200 bytes downloaded
[15:49:03] Initial: 1D08; + 1085440 bytes downloaded
[15:49:03] Initial: B1BD; + 1095680 bytes downloaded
[15:49:03] Initial: 4946; + 1105920 bytes downloaded
[15:49:03] Initial: 5297; + 1116160 bytes downloaded
[15:49:03] Initial: 201F; + 1126400 bytes downloaded
[15:49:03] Initial: A318; + 1136640 bytes downloaded
[15:49:03] Initial: 3ED5; + 1146880 bytes downloaded
[15:49:03] Initial: 8473; + 1157120 bytes downloaded
[15:49:03] Initial: D9B9; + 1167360 bytes downloaded
[15:49:04] Initial: 2D15; + 1177600 bytes downloaded
[15:49:04] Initial: F6A1; + 1187840 bytes downloaded
[15:49:04] Initial: 1850; + 1198080 bytes downloaded
[15:49:04] Initial: 3D3E; + 1208320 bytes downloaded
[15:49:04] Initial: 2ADB; + 1218560 bytes downloaded
[15:49:04] Initial: FF21; + 1228800 bytes downloaded
[15:49:04] Initial: 1708; + 1239040 bytes downloaded
[15:49:04] Initial: ADA8; + 1249280 bytes downloaded
[15:49:04] Initial: 8E4E; + 1259520 bytes downloaded
[15:49:04] Initial: 63C7; + 1269760 bytes downloaded
[15:49:04] Initial: 7316; + 1280000 bytes downloaded
[15:49:04] Initial: B3D8; + 1290240 bytes downloaded
[15:49:04] Initial: 2693; + 1300480 bytes downloaded
[15:49:04] Initial: 1B77; + 1310720 bytes downloaded
[15:49:04] Initial: F16F; + 1320960 bytes downloaded
[15:49:04] Initial: 45F0; + 1331200 bytes downloaded
[15:49:04] Initial: 289C; + 1341440 bytes downloaded
[15:49:04] Initial: 83F2; + 1351680 bytes downloaded
[15:49:04] Initial: 1459; + 1361920 bytes downloaded
[15:49:04] Initial: 1A62; + 1372160 bytes downloaded
[15:49:04] Initial: C408; + 1382400 bytes downloaded
[15:49:04] Initial: C561; + 1392640 bytes downloaded
[15:49:04] Initial: 8827; + 1402880 bytes downloaded
[15:49:04] Initial: 3F18; + 1413120 bytes downloaded
[15:49:05] Initial: 212C; + 1422551 bytes downloaded
[15:49:05] Verifying core Core_15.fah...
[15:49:05] Signature is VALID
[15:49:05]
[15:49:05] Trying to unzip core FahCore_15.exe
[15:49:05] Decompressed FahCore_15.exe (3903488 bytes) successfully
[15:49:10] + Core successfully engaged
[15:49:15]
[15:49:15] + Processing work unit
[15:49:15] Core required: FahCore_15.exe
[15:49:15] Core found.
[15:49:15] Working on queue slot 01 [April 21 15:49:15 UTC]
[15:49:15] + Working ...
[15:49:15] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -nocpulock -checkpoint 3 -verbose -lifeline 916 -version 641'
[15:49:15]
[15:49:15] *------------------------------*
[15:49:15] Folding@Home GPU Core
[15:49:15] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[15:49:15]
[15:49:15] Build host: SimbiosNvdWin7
[15:49:15] Board Type: NVIDIA/CUDA
[15:49:15] Core : x=15
[15:49:15] Window's signal control handler registered.
[15:49:15] Preparing to commence simulation
[15:49:15] - Ensuring status. Please wait.
[15:49:25] - Looking at optimizations...
[15:49:25] - Working with standard loops on this execution.
[15:49:25] - Previous termination of core was improper.
[15:49:25] - Going to use standard loops.
[15:49:25] - Files status OK
[15:49:25] sizeof(CORE_PACKET_HDR) = 512 file=<>
[15:49:25] - Expanded 41565 -> 162639 (decompressed 391.2 percent)
[15:49:25] Called DecompressByteArray: compressed_data_size=41565 data_size=162639, decompressed_data_size=162639 diff=0
[15:49:25] - Digital signature verified
[15:49:25]
[15:49:25] Project: 6805 (Run 8635, Clone 2, Gen 11)
[15:49:25]
[15:49:25] Entering M.D.
[15:49:27] Tpr hash work/wudata_01.tpr: 1727262770 1673432331 2831433277 1952541477 3366849156
[15:49:27] Working on ALZHEIMER'S DISEASE AMYLOID
[15:49:27] Client config found, loading data.
[15:49:30] CoreStatus = 63 (99)
[15:49:30] + Error starting Folding@home core.
[15:49:35]
[15:49:35] + Processing work unit
[15:49:35] Core required: FahCore_15.exe
[15:49:35] Core found.
[15:49:35] Working on queue slot 01 [April 21 15:49:35 UTC]
[15:49:35] + Working ...
[15:49:35] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -nocpulock -checkpoint 3 -verbose -lifeline 916 -version 641'
[15:49:35]
[15:49:35] *------------------------------*
[15:49:35] Folding@Home GPU Core
[15:49:35] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[15:49:35]
[15:49:35] Build host: SimbiosNvdWin7
[15:49:35] Board Type: NVIDIA/CUDA
[15:49:35] Core : x=15
[15:49:35] Window's signal control handler registered.
[15:49:35] Preparing to commence simulation
[15:49:35] - Ensuring status. Please wait.
[15:49:44] - Looking at optimizations...
[15:49:44] - Working with standard loops on this execution.
[15:49:44] - Previous termination of core was improper.
[15:49:44] - Going to use standard loops.
[15:49:44] - Files status OK
[15:49:44] sizeof(CORE_PACKET_HDR) = 512 file=<>
[15:49:44] - Expanded 41565 -> 162639 (decompressed 391.2 percent)
[15:49:44] Called DecompressByteArray: compressed_data_size=41565 data_size=162639, decompressed_data_size=162639 diff=0
[15:49:44] - Digital signature verified
[15:49:44]
[15:49:44] Project: 6805 (Run 8635, Clone 2, Gen 11)
[15:49:44]
[15:49:44] Entering M.D.
[15:49:46] Tpr hash work/wudata_01.tpr: 1727262770 1673432331 2831433277 1952541477 3366849156
[15:49:46] Working on ALZHEIMER'S DISEASE AMYLOID
[15:49:46] Client config found, loading data.
[15:49:49] CoreStatus = 63 (99)
[15:49:49] + Error starting Folding@home core.
[15:49:54]
[15:49:54] + Processing work unit
[15:49:54] Core required: FahCore_15.exe
[15:49:54] Core found.
[15:49:54] Working on queue slot 01 [April 21 15:49:54 UTC]
[15:49:54] + Working ...
[15:49:54] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -nocpulock -checkpoint 3 -verbose -lifeline 916 -version 641'
[15:49:54]
[15:49:54] *------------------------------*
[15:49:54] Folding@Home GPU Core
[15:49:54] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[15:49:54]
[15:49:54] Build host: SimbiosNvdWin7
[15:49:54] Board Type: NVIDIA/CUDA
[15:49:54] Core : x=15
[15:49:54] Window's signal control handler registered.
[15:49:54] Preparing to commence simulation
[15:49:54] - Ensuring status. Please wait.
[15:50:03] - Looking at optimizations...
[15:50:03] - Working with standard loops on this execution.
[15:50:03] - Previous termination of core was improper.
[15:50:03] - Going to use standard loops.
[15:50:03] - Files status OK
[15:50:03] sizeof(CORE_PACKET_HDR) = 512 file=<>
[15:50:03] - Expanded 41565 -> 162639 (decompressed 391.2 percent)
[15:50:03] Called DecompressByteArray: compressed_data_size=41565 data_size=162639, decompressed_data_size=162639 diff=0
[15:50:03] - Digital signature verified
[15:50:03]
[15:50:03] Project: 6805 (Run 8635, Clone 2, Gen 11)
[15:50:03]
[15:50:03] Entering M.D.
[15:50:05] Tpr hash work/wudata_01.tpr: 1727262770 1673432331 2831433277 1952541477 3366849156
[15:50:05] Working on ALZHEIMER'S DISEASE AMYLOID
[15:50:05] Client config found, loading data.
[15:50:08] CoreStatus = 63 (99)
[15:50:08] + Error starting Folding@home core.
[15:50:08] - Attempting to download new core...
[15:50:08] + Downloading new core: FahCore_15.exe
[15:50:08] Downloading core (/~pande/Win32/x86/NVIDIA/Fermi/Core_15.fah from www.stanford.edu)
[15:50:08] Initial: AFDE; + 10240 bytes downloaded
[15:50:08] Initial: 4A9F; + 20480 bytes downloaded
[15:50:08] Initial: 02DB; + 30720 bytes downloaded
[15:50:08] Initial: 32D2; + 40960 bytes downloaded
[15:50:09] Initial: 0664; + 51200 bytes downloaded
[15:50:09] Initial: 0400; + 61440 bytes downloaded
[15:50:09] Initial: 3AB8; + 71680 bytes downloaded
[15:50:09] Initial: F8D2; + 81920 bytes downloaded
[15:50:09] Initial: F4EE; + 92160 bytes downloaded
[15:50:09] Initial: ECE1; + 102400 bytes downloaded
[15:50:09] Initial: 9A21; + 112640 bytes downloaded
[15:50:09] Initial: 4572; + 122880 bytes downloaded
[15:50:09] Initial: A5AF; + 133120 bytes downloaded
[15:50:09] Initial: AE73; + 143360 bytes downloaded
[15:50:09] Initial: 324F; + 153600 bytes downloaded
[15:50:09] Initial: 6A97; + 163840 bytes downloaded
[15:50:09] Initial: E123; + 174080 bytes downloaded
[15:50:09] Initial: 5426; + 184320 bytes downloaded
[15:50:09] Initial: 9D76; + 194560 bytes downloaded
[15:50:09] Initial: 2226; + 204800 bytes downloaded
[15:50:09] Initial: FE64; + 215040 bytes downloaded
[15:50:09] Initial: F9F2; + 225280 bytes downloaded
[15:50:09] Initial: 4F35; + 235520 bytes downloaded
[15:50:09] Initial: D07D; + 245760 bytes downloaded
[15:50:09] Initial: 9E40; + 256000 bytes downloaded
[15:50:09] Initial: 38A2; + 266240 bytes downloaded
[15:50:09] Initial: BD94; + 276480 bytes downloaded
[15:50:09] Initial: 4BAC; + 286720 bytes downloaded
[15:50:09] Initial: D740; + 296960 bytes downloaded
[15:50:10] Initial: B43A; + 307200 bytes downloaded
[15:50:10] Initial: 4B3F; + 317440 bytes downloaded
[15:50:10] Initial: BDD0; + 327680 bytes downloaded
[15:50:10] Initial: 18EB; + 337920 bytes downloaded
[15:50:10] Initial: E612; + 348160 bytes downloaded
[15:50:10] Initial: BD4D; + 358400 bytes downloaded
[15:50:10] Initial: D804; + 368640 bytes downloaded
[15:50:10] Initial: B7D0; + 378880 bytes downloaded
[15:50:10] Initial: 6492; + 389120 bytes downloaded
[15:50:10] Initial: B390; + 399360 bytes downloaded
[15:50:10] Initial: 2ADA; + 409600 bytes downloaded
[15:50:10] Initial: BAB5; + 419840 bytes downloaded
[15:50:10] Initial: BC78; + 430080 bytes downloaded
[15:50:10] Initial: 1119; + 440320 bytes downloaded
[15:50:10] Initial: 27B1; + 450560 bytes downloaded
[15:50:10] Initial: 8A2A; + 460800 bytes downloaded
[15:50:10] Initial: 6F27; + 471040 bytes downloaded
[15:50:10] Initial: FFFF; + 481280 bytes downloaded
[15:50:10] Initial: D0B6; + 491520 bytes downloaded
[15:50:10] Initial: 0702; + 501760 bytes downloaded
[15:50:10] Initial: 08C1; + 512000 bytes downloaded
[15:50:10] Initial: E64B; + 522240 bytes downloaded
[15:50:11] Initial: F5F0; + 532480 bytes downloaded
[15:50:11] Initial: 98CB; + 542720 bytes downloaded
[15:50:11] Initial: 2477; + 552960 bytes downloaded
[15:50:11] Initial: 494C; + 563200 bytes downloaded
[15:50:11] Initial: 4D49; + 573440 bytes downloaded
[15:50:11] Initial: C6C8; + 583680 bytes downloaded
[15:50:11] Initial: 2D13; + 593920 bytes downloaded
[15:50:11] Initial: 03F9; + 604160 bytes downloaded
[15:50:11] Initial: 1315; + 614400 bytes downloaded
[15:50:11] Initial: 0887; + 624640 bytes downloaded
[15:50:11] Initial: 5BA1; + 634880 bytes downloaded
[15:50:11] Initial: E140; + 645120 bytes downloaded
[15:50:11] Initial: 1E9D; + 655360 bytes downloaded
[15:50:11] Initial: 6C1A; + 665600 bytes downloaded
[15:50:11] Initial: 8A4A; + 675840 bytes downloaded
[15:50:11] Initial: 57FD; + 686080 bytes downloaded
[15:50:11] Initial: F8E0; + 696320 bytes downloaded
[15:50:11] Initial: 0CD1; + 706560 bytes downloaded
[15:50:11] Initial: D1E2; + 716800 bytes downloaded
[15:50:11] Initial: 9CA8; + 727040 bytes downloaded
[15:50:11] Initial: 7F13; + 737280 bytes downloaded
[15:50:11] Initial: 3231; + 747520 bytes downloaded
[15:50:11] Initial: 5F16; + 757760 bytes downloaded
[15:50:11] Initial: BF95; + 768000 bytes downloaded
[15:50:12] Initial: 70A4; + 778240 bytes downloaded
[15:50:12] Initial: 6D26; + 788480 bytes downloaded
[15:50:12] Initial: 13C7; + 798720 bytes downloaded
[15:50:12] Initial: 9F26; + 808960 bytes downloaded
[15:50:12] Initial: C7B5; + 819200 bytes downloaded
[15:50:12] Initial: D5A9; + 829440 bytes downloaded
[15:50:12] Initial: F796; + 839680 bytes downloaded
[15:50:12] Initial: A004; + 849920 bytes downloaded
[15:50:12] Initial: 1011; + 860160 bytes downloaded
[15:50:12] Initial: 3F6F; + 870400 bytes downloaded
[15:50:12] Initial: B01C; + 880640 bytes downloaded
[15:50:12] Initial: E903; + 890880 bytes downloaded
[15:50:12] Initial: 29D0; + 901120 bytes downloaded
[15:50:12] Initial: 3DD6; + 911360 bytes downloaded
[15:50:12] Initial: D5BF; + 921600 bytes downloaded
[15:50:12] Initial: EC69; + 931840 bytes downloaded
[15:50:12] Initial: 1A1D; + 942080 bytes downloaded
[15:50:12] Initial: 7BC0; + 952320 bytes downloaded
[15:50:12] Initial: 9C4E; + 962560 bytes downloaded
[15:50:12] Initial: 9C59; + 972800 bytes downloaded
[15:50:12] Initial: 7BBD; + 983040 bytes downloaded
[15:50:12] Initial: D395; + 993280 bytes downloaded
[15:50:12] Initial: 5239; + 1003520 bytes downloaded
[15:50:12] Initial: BE83; + 1013760 bytes downloaded
[15:50:12] Initial: 428D; + 1024000 bytes downloaded
[15:50:13] Initial: E2EE; + 1034240 bytes downloaded
[15:50:13] Initial: 64BB; + 1044480 bytes downloaded
[15:50:13] Initial: 7200; + 1054720 bytes downloaded
[15:50:13] Initial: 71BB; + 1064960 bytes downloaded
[15:50:13] Initial: 9A20; + 1075200 bytes downloaded
[15:50:13] Initial: 1D08; + 1085440 bytes downloaded
[15:50:13] Initial: B1BD; + 1095680 bytes downloaded
[15:50:13] Initial: 4946; + 1105920 bytes downloaded
[15:50:13] Initial: 5297; + 1116160 bytes downloaded
[15:50:13] Initial: 201F; + 1126400 bytes downloaded
[15:50:13] Initial: A318; + 1136640 bytes downloaded
[15:50:13] Initial: 3ED5; + 1146880 bytes downloaded
[15:50:13] Initial: 8473; + 1157120 bytes downloaded
[15:50:13] Initial: D9B9; + 1167360 bytes downloaded
[15:50:13] Initial: 2D15; + 1177600 bytes downloaded
[15:50:13] Initial: F6A1; + 1187840 bytes downloaded
[15:50:13] Initial: 1850; + 1198080 bytes downloaded
[15:50:13] Initial: 3D3E; + 1208320 bytes downloaded
[15:50:13] Initial: 2ADB; + 1218560 bytes downloaded
[15:50:13] Initial: FF21; + 1228800 bytes downloaded
[15:50:13] Initial: 1708; + 1239040 bytes downloaded
[15:50:13] Initial: ADA8; + 1249280 bytes downloaded
[15:50:13] Initial: 8E4E; + 1259520 bytes downloaded
[15:50:14] Initial: 63C7; + 1269760 bytes downloaded
[15:50:14] Initial: 7316; + 1280000 bytes downloaded
[15:50:14] Initial: B3D8; + 1290240 bytes downloaded
[15:50:14] Initial: 2693; + 1300480 bytes downloaded
[15:50:14] Initial: 1B77; + 1310720 bytes downloaded
[15:50:14] Initial: F16F; + 1320960 bytes downloaded
[15:50:14] Initial: 45F0; + 1331200 bytes downloaded
[15:50:14] Initial: 289C; + 1341440 bytes downloaded
[15:50:14] Initial: 83F2; + 1351680 bytes downloaded
[15:50:14] Initial: 1459; + 1361920 bytes downloaded
[15:50:14] Initial: 1A62; + 1372160 bytes downloaded
[15:50:14] Initial: C408; + 1382400 bytes downloaded
[15:50:14] Initial: C561; + 1392640 bytes downloaded
[15:50:14] Initial: 8827; + 1402880 bytes downloaded
[15:50:14] Initial: 3F18; + 1413120 bytes downloaded
[15:50:14] Initial: 212C; + 1422551 bytes downloaded
[15:50:15] Verifying core Core_15.fah...
[15:50:15] Signature is VALID
[15:50:15]
[15:50:15] Trying to unzip core FahCore_15.exe
[15:50:15] Decompressed FahCore_15.exe (3903488 bytes) successfully
[15:50:20] + Core successfully engaged
[15:50:25]
[15:50:25] + Processing work unit
[15:50:25] Core required: FahCore_15.exe
[15:50:25] Core found.
[15:50:25] Working on queue slot 01 [April 21 15:50:25 UTC]
[15:50:25] + Working ...
[15:50:25] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -nocpulock -checkpoint 3 -verbose -lifeline 916 -version 641'
[15:50:25]
[15:50:25] *------------------------------*
[15:50:25] Folding@Home GPU Core
[15:50:25] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[15:50:25]
[15:50:25] Build host: SimbiosNvdWin7
[15:50:25] Board Type: NVIDIA/CUDA
[15:50:25] Core : x=15
[15:50:25] Window's signal control handler registered.
[15:50:25] Preparing to commence simulation
[15:50:25] - Ensuring status. Please wait.
[15:50:35] - Looking at optimizations...
[15:50:35] - Working with standard loops on this execution.
[15:50:35] - Previous termination of core was improper.
[15:50:35] - Going to use standard loops.
[15:50:35] - Files status OK
[15:50:35] sizeof(CORE_PACKET_HDR) = 512 file=<>
[15:50:35] - Expanded 41565 -> 162639 (decompressed 391.2 percent)
[15:50:35] Called DecompressByteArray: compressed_data_size=41565 data_size=162639, decompressed_data_size=162639 diff=0
[15:50:35] - Digital signature verified
[15:50:35]
[15:50:35] Project: 6805 (Run 8635, Clone 2, Gen 11)
[15:50:35]
[15:50:35] Entering M.D.
[15:50:37] Tpr hash work/wudata_01.tpr: 1727262770 1673432331 2831433277 1952541477 3366849156
[15:50:37] Working on ALZHEIMER'S DISEASE AMYLOID
[15:50:37] Client config found, loading data.
[15:50:39] CoreStatus = 63 (99)
[15:50:39] + Error starting Folding@home core.
[15:50:44]
[15:50:44] + Processing work unit
[15:50:44] Core required: FahCore_15.exe
[15:50:44] Core found.
[15:50:44] Working on queue slot 01 [April 21 15:50:44 UTC]
[15:50:44] + Working ...
[15:50:44] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -nocpulock -checkpoint 3 -verbose -lifeline 916 -version 641'
[15:50:44]
[15:50:44] *------------------------------*
[15:50:44] Folding@Home GPU Core
[15:50:44] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[15:50:44]
[15:50:44] Build host: SimbiosNvdWin7
[15:50:44] Board Type: NVIDIA/CUDA
[15:50:44] Core : x=15
[15:50:44] Window's signal control handler registered.
[15:50:44] Preparing to commence simulation
[15:50:44] - Ensuring status. Please wait.
[15:50:54] - Looking at optimizations...
[15:50:54] - Working with standard loops on this execution.
[15:50:54] - Previous termination of core was improper.
[15:50:54] - Going to use standard loops.
[15:50:54] - Files status OK
[15:50:54] sizeof(CORE_PACKET_HDR) = 512 file=<>
[15:50:54] - Expanded 41565 -> 162639 (decompressed 391.2 percent)
[15:50:54] Called DecompressByteArray: compressed_data_size=41565 data_size=162639, decompressed_data_size=162639 diff=0
[15:50:54] - Digital signature verified
[15:50:54]
[15:50:54] Project: 6805 (Run 8635, Clone 2, Gen 11)
[15:50:54]
[15:50:54] Entering M.D.
[15:50:56] Tpr hash work/wudata_01.tpr: 1727262770 1673432331 2831433277 1952541477 3366849156
[15:50:56] Working on ALZHEIMER'S DISEASE AMYLOID
[15:50:56] Client config found, loading data.
[15:50:58] CoreStatus = 63 (99)
[15:50:58] + Error starting Folding@home core.
[15:51:03]
[15:51:03] + Processing work unit
[15:51:03] Core required: FahCore_15.exe
[15:51:03] Core found.
[15:51:03] Working on queue slot 01 [April 21 15:51:03 UTC]
[15:51:03] + Working ...
[15:51:03] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -nocpulock -checkpoint 3 -verbose -lifeline 916 -version 641'
[15:51:04]
[15:51:04] *------------------------------*
[15:51:04] Folding@Home GPU Core
[15:51:04] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[15:51:04]
[15:51:04] Build host: SimbiosNvdWin7
[15:51:04] Board Type: NVIDIA/CUDA
[15:51:04] Core : x=15
[15:51:04] Window's signal control handler registered.
[15:51:04] Preparing to commence simulation
[15:51:04] - Ensuring status. Please wait.
[15:51:13] - Looking at optimizations...
[15:51:13] - Working with standard loops on this execution.
[15:51:13] Examination of work files indicates 8 consecutive improper terminations of core.
[15:51:13] sizeof(CORE_PACKET_HDR) = 512 file=<>
[15:51:13] - Expanded 41565 -> 162639 (decompressed 391.2 percent)
[15:51:13] Called DecompressByteArray: compressed_data_size=41565 data_size=162639, decompressed_data_size=162639 diff=0
[15:51:13] - Digital signature verified
[15:51:13]
[15:51:13] Project: 6805 (Run 8635, Clone 2, Gen 11)
[15:51:13]
[15:51:13] Entering M.D.
[15:51:15] Tpr hash work/wudata_01.tpr: 1727262770 1673432331 2831433277 1952541477 3366849156
[15:51:15] Working on ALZHEIMER'S DISEASE AMYLOID
[15:51:15] Client config found, loading data.
[15:51:18] CoreStatus = 63 (99)
[15:51:18] + Error starting Folding@home core.
[15:51:18] - Attempting to download new core...
[15:51:18] + Downloading new core: FahCore_15.exe
[15:51:18] Downloading core (/~pande/Win32/x86/NVIDIA/Fermi/Core_15.fah from www.stanford.edu)
gwildperson
Did you try the installation guide? It recommends the systray version which is a complete package. Once you've got it running, you can update it easily to the console version if you really like looking at the text window.
http://folding.stanford.edu/English/WinGPUGuide
But the console install for Fermi has worked for me before ... on other machines. I may have had to add a missing cudart32_30_14.dll ... or so ... but it all worked before
MtM
Direct download links for the .dll files...
http://www.stanford.edu/~friedrim/cudart32_31_9.dll
http://www.stanford.edu/~friedrim/cufft32_31_9.dll
But that's only 2 of the 4, but might be enough for you to make it work.
Another trick is to download the v6.41 .msi installer for the Systray client as mentioned above. However, instead of installing that client, and then converting it to run as a console, simply install, but don't run it. Then copy the .DLL files out of the AppData folder, and in to your console client folder.
I did this. The list of .DLL files it extracted is...
amdcalcl.dll
amdcalrt.dll
cudart32_30_14.dll
cudart.dll
cufft32_30_14.dll
cuftt.dll
amdcalcl.dll
amdcalrt.dll
cudart32_30_14.dll
cudart.dll
cufft32_30_14.dll
cuftt.dll
I tried the systray installer and found that it had installed in All Programs ... however not a single .dll is to be found amongst all the files that the installer created .... ???
Neverminde ... found them by clicking "expert mode"
Copied the .dll's ...
BUT ... I am still getting "Error Starting Folding @Home core"
I am going away for the Easter weekend ... and in a last ditch attempt to have my new machine folding while I was away, I decided to try to install the Fermi Systray client.
However once again I am having problems. Here is the Fahlog.txt from the systray client:
Any help is appreciated
--- Opening Log file [April 22 02:25:12 UTC]
# Windows GPU Systray Edition #################################################
Launch directory: C:\Users\Ron\AppData\Roaming\Folding@home-gpu
[02:25:12] - Ask before connecting: No
[02:25:12] - User name: Anonymous (Team 0)
[02:25:12] - User ID: 45999D7C6A09CBFA
[02:25:12] - Machine ID: 2
[02:25:12]
[02:25:12] Gpu type=3 species=21.
[02:25:12] Loaded queue successfully.
[02:25:12] Initialization complete
[02:25:12]
[02:25:12] + Processing work unit
[02:25:12] Core required: FahCore_15.exe
[02:25:12] Core found.
[02:25:12] Working on queue slot 01 [April 22 02:25:12 UTC]
[02:25:12] + Working ...
[02:25:12]
[02:25:12] *------------------------------*
[02:25:12] Folding@Home GPU Core
[02:25:12] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[02:25:12]
[02:25:12] Build host: SimbiosNvdWin7
[02:25:12] Board Type: NVIDIA/CUDA
[02:25:12] Core : x=15
[02:25:12] Window's signal control handler registered.
[02:25:12] Preparing to commence simulation
[02:25:12] - Ensuring status. Please wait.
[02:25:22] - Looking at optimizations...
[02:25:22] - Working with standard loops on this execution.
[02:25:22] Examination of work files indicates 8 consecutive improper terminations of core.
[02:25:22] sizeof(CORE_PACKET_HDR) = 512 file=<>
[02:25:22] - Expanded 43882 -> 172159 (decompressed 392.3 percent)
[02:25:22] Called DecompressByteArray: compressed_data_size=43882 data_size=172159, decompressed_data_size=172159 diff=0
[02:25:22] - Digital signature verified
[02:25:22]
[02:25:22] Project: 6806 (Run 8000, Clone 2, Gen 15)
[02:25:22]
[02:25:22] Entering M.D.
[02:25:24] Tpr hash work/wudata_01.tpr: 3975951696 614214245 3243939412 2893478340 1682207625
[02:25:24] Working on 2 PEPTIDE (1-42)
[02:25:24] Client config found, loading data.
[02:25:26] CoreStatus = 63 (99)
[02:25:26] + Error starting Folding@home core.
[02:25:31]
[02:25:31] + Processing work unit
[02:25:31] Core required: FahCore_15.exe
[02:25:31] Core found.
[02:25:31] Working on queue slot 01 [April 22 02:25:31 UTC]
[02:25:31] + Working ...
[02:25:31]
[02:25:31] *------------------------------*
[02:25:31] Folding@Home GPU Core
[02:25:31] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[02:25:31]
[02:25:31] Build host: SimbiosNvdWin7
[02:25:31] Board Type: NVIDIA/CUDA
[02:25:31] Core : x=15
[02:25:31] Window's signal control handler registered.
[02:25:31] Preparing to commence simulation
[02:25:31] - Ensuring status. Please wait.
[02:25:41] - Looking at optimizations...
[02:25:41] - Working with standard loops on this execution.
[02:25:41] Examination of work files indicates 8 consecutive improper terminations of core.
[02:25:41] sizeof(CORE_PACKET_HDR) = 512 file=<>
[02:25:41] - Expanded 43882 -> 172159 (decompressed 392.3 percent)
[02:25:41] Called DecompressByteArray: compressed_data_size=43882 data_size=172159, decompressed_data_size=172159 diff=0
[02:25:41] - Digital signature verified
[02:25:41]
[02:25:41] Project: 6806 (Run 8000, Clone 2, Gen 15)
[02:25:41]
[02:25:41] Entering M.D.
[02:25:43] Tpr hash work/wudata_01.tpr: 3975951696 614214245 3243939412 2893478340 1682207625
[02:25:43] Working on 2 PEPTIDE (1-42)
[02:25:43] Client config found, loading data.
[02:25:45] CoreStatus = 63 (99)
[02:25:45] + Error starting Folding@home core.
[02:25:50]
[02:25:50] + Processing work unit
[02:25:50] Core required: FahCore_15.exe
[02:25:50] Core found.
[02:25:50] Working on queue slot 01 [April 22 02:25:50 UTC]
[02:25:50] + Working ...
[02:25:51]
[02:25:51] *------------------------------*
[02:25:51] Folding@Home GPU Core
[02:25:51] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[02:25:51]
[02:25:51] Build host: SimbiosNvdWin7
[02:25:51] Board Type: NVIDIA/CUDA
[02:25:51] Core : x=15
[02:25:51] Window's signal control handler registered.
[02:25:51] Preparing to commence simulation
[02:25:51] - Ensuring status. Please wait.
[02:26:00] - Looking at optimizations...
[02:26:00] - Working with standard loops on this execution.
[02:26:00] Examination of work files indicates 8 consecutive improper terminations of core.
[02:26:00] sizeof(CORE_PACKET_HDR) = 512 file=<>
[02:26:00] - Expanded 43882 -> 172159 (decompressed 392.3 percent)
[02:26:00] Called DecompressByteArray: compressed_data_size=43882 data_size=172159, decompressed_data_size=172159 diff=0
[02:26:00] - Digital signature verified
[02:26:00]
[02:26:00] Project: 6806 (Run 8000, Clone 2, Gen 15)
[02:26:00]
[02:26:00] Entering M.D.
[02:26:02] Tpr hash work/wudata_01.tpr: 3975951696 614214245 3243939412 2893478340 1682207625
[02:26:03] Working on 2 PEPTIDE (1-42)
[02:26:03] Client config found, loading data.
[02:26:05] CoreStatus = 63 (99)
[02:26:05] + Error starting Folding@home core.
[02:26:05] - Attempting to download new core...
[02:26:05] + Downloading new core: FahCore_15.exe
[02:26:05] + 10240 bytes downloaded
[02:26:05] + 20480 bytes downloaded
[02:26:05] + 30720 bytes downloaded
[02:26:05] + 40960 bytes downloaded
[02:26:05] + 51200 bytes downloaded
[02:26:05] + 61440 bytes downloaded
[02:26:05] + 71680 bytes downloaded
[02:26:05] + 81920 bytes downloaded
[02:26:05] + 92160 bytes downloaded
[02:26:05] + 102400 bytes downloaded
[02:26:05] + 112640 bytes downloaded
[02:26:05] + 122880 bytes downloaded
[02:26:05] + 133120 bytes downloaded
[02:26:05] + 143360 bytes downloaded
[02:26:06] + 153600 bytes downloaded
[02:26:06] + 163840 bytes downloaded
[02:26:06] + 174080 bytes downloaded
[02:26:06] + 184320 bytes downloaded
[02:26:06] + 194560 bytes downloaded
[02:26:06] + 204800 bytes downloaded
[02:26:06] + 215040 bytes downloaded
[02:26:06] + 225280 bytes downloaded
[02:26:06] + 235520 bytes downloaded
[02:26:06] + 245760 bytes downloaded
[02:26:06] + 256000 bytes downloaded
[02:26:06] + 266240 bytes downloaded
[02:26:06] + 276480 bytes downloaded
[02:26:06] + 286720 bytes downloaded
[02:26:06] + 296960 bytes downloaded
[02:26:06] + 307200 bytes downloaded
[02:26:06] + 317440 bytes downloaded
[02:26:06] + 327680 bytes downloaded
[02:26:06] + 337920 bytes downloaded
[02:26:06] + 348160 bytes downloaded
[02:26:06] + 358400 bytes downloaded
[02:26:06] + 368640 bytes downloaded
[02:26:06] + 378880 bytes downloaded
[02:26:07] + 389120 bytes downloaded
[02:26:07] + 399360 bytes downloaded
[02:26:07] + 409600 bytes downloaded
[02:26:07] + 419840 bytes downloaded
[02:26:07] + 430080 bytes downloaded
[02:26:07] + 440320 bytes downloaded
[02:26:07] + 450560 bytes downloaded
[02:26:07] + 460800 bytes downloaded
[02:26:07] + 471040 bytes downloaded
[02:26:07] + 481280 bytes downloaded
[02:26:07] + 491520 bytes downloaded
[02:26:07] + 501760 bytes downloaded
[02:26:07] + 512000 bytes downloaded
[02:26:07] + 522240 bytes downloaded
[02:26:07] + 532480 bytes downloaded
[02:26:07] + 542720 bytes downloaded
[02:26:07] + 552960 bytes downloaded
[02:26:07] + 563200 bytes downloaded
[02:26:07] + 573440 bytes downloaded
[02:26:07] + 583680 bytes downloaded
[02:26:07] + 593920 bytes downloaded
[02:26:07] + 604160 bytes downloaded
[02:26:07] + 614400 bytes downloaded
[02:26:07] + 624640 bytes downloaded
[02:26:07] + 634880 bytes downloaded
[02:26:08] + 645120 bytes downloaded
[02:26:08] + 655360 bytes downloaded
[02:26:08] + 665600 bytes downloaded
[02:26:08] + 675840 bytes downloaded
[02:26:08] + 686080 bytes downloaded
[02:26:08] + 696320 bytes downloaded
[02:26:08] + 706560 bytes downloaded
[02:26:08] + 716800 bytes downloaded
[02:26:08] + 727040 bytes downloaded
[02:26:08] + 737280 bytes downloaded
[02:26:08] + 747520 bytes downloaded
[02:26:08] + 757760 bytes downloaded
[02:26:08] + 768000 bytes downloaded
[02:26:08] + 778240 bytes downloaded
[02:26:08] + 788480 bytes downloaded
[02:26:08] + 798720 bytes downloaded
[02:26:08] + 808960 bytes downloaded
[02:26:08] + 819200 bytes downloaded
[02:26:08] + 829440 bytes downloaded
[02:26:08] + 839680 bytes downloaded
[02:26:08] + 849920 bytes downloaded
[02:26:08] + 860160 bytes downloaded
[02:26:08] + 870400 bytes downloaded
[02:26:08] + 880640 bytes downloaded
[02:26:08] + 890880 bytes downloaded
[02:26:09] + 901120 bytes downloaded
[02:26:09] + 911360 bytes downloaded
[02:26:09] + 921600 bytes downloaded
[02:26:09] + 931840 bytes downloaded
[02:26:09] + 942080 bytes downloaded
[02:26:09] + 952320 bytes downloaded
[02:26:09] + 962560 bytes downloaded
[02:26:09] + 972800 bytes downloaded
[02:26:09] + 983040 bytes downloaded
[02:26:09] + 993280 bytes downloaded
[02:26:09] + 1003520 bytes downloaded
[02:26:09] + 1013760 bytes downloaded
[02:26:09] + 1024000 bytes downloaded
[02:26:09] + 1034240 bytes downloaded
[02:26:09] + 1044480 bytes downloaded
[02:26:09] + 1054720 bytes downloaded
[02:26:09] + 1064960 bytes downloaded
[02:26:09] + 1075200 bytes downloaded
[02:26:09] + 1085440 bytes downloaded
[02:26:09] + 1095680 bytes downloaded
[02:26:09] + 1105920 bytes downloaded
[02:26:09] + 1116160 bytes downloaded
[02:26:10] + 1126400 bytes downloaded
[02:26:10] + 1136640 bytes downloaded
[02:26:10] + 1146880 bytes downloaded
[02:26:10] + 1157120 bytes downloaded
[02:26:10] + 1167360 bytes downloaded
[02:26:10] + 1177600 bytes downloaded
[02:26:10] + 1187840 bytes downloaded
[02:26:10] + 1198080 bytes downloaded
[02:26:10] + 1208320 bytes downloaded
[02:26:10] + 1218560 bytes downloaded
[02:26:10] + 1228800 bytes downloaded
[02:26:10] + 1239040 bytes downloaded
[02:26:10] + 1249280 bytes downloaded
[02:26:10] + 1259520 bytes downloaded
[02:26:10] + 1269760 bytes downloaded
[02:26:10] + 1280000 bytes downloaded
[02:26:10] + 1290240 bytes downloaded
[02:26:10] + 1300480 bytes downloaded
[02:26:10] + 1310720 bytes downloaded
[02:26:10] + 1320960 bytes downloaded
[02:26:10] + 1331200 bytes downloaded
[02:26:10] + 1341440 bytes downloaded
[02:26:10] + 1351680 bytes downloaded
[02:26:10] + 1361920 bytes downloaded
[02:26:10] + 1372160 bytes downloaded
[02:26:11] + 1382400 bytes downloaded
[02:26:11] + 1392640 bytes downloaded
[02:26:11] + 1402880 bytes downloaded
[02:26:11] + 1413120 bytes downloaded
[02:26:11] + 1422551 bytes downloaded
[02:26:11] Verifying core Core_15.fah...
[02:26:11] Signature is VALID
[02:26:11]
[02:26:11] Trying to unzip core FahCore_15.exe
[02:26:11] Decompressed FahCore_15.exe (3903488 bytes) successfully
[02:26:16] + Core successfully engaged
[02:26:21]
[02:26:21] + Processing work unit
[02:26:21] Core required: FahCore_15.exe
[02:26:21] Core found.
[02:26:21] Working on queue slot 01 [April 22 02:26:21 UTC]
[02:26:21] + Working ...
[02:26:21]
[02:26:21] *------------------------------*
[02:26:21] Folding@Home GPU Core
[02:26:21] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[02:26:21]
[02:26:21] Build host: SimbiosNvdWin7
[02:26:21] Board Type: NVIDIA/CUDA
[02:26:21] Core : x=15
[02:26:21] Window's signal control handler registered.
[02:26:21] Preparing to commence simulation
[02:26:21] - Ensuring status. Please wait.
[02:26:31] - Looking at optimizations...
[02:26:31] - Working with standard loops on this execution.
[02:26:31] Examination of work files indicates 8 consecutive improper terminations of core.
[02:26:31] sizeof(CORE_PACKET_HDR) = 512 file=<>
[02:26:31] - Expanded 43882 -> 172159 (decompressed 392.3 percent)
[02:26:31] Called DecompressByteArray: compressed_data_size=43882 data_size=172159, decompressed_data_size=172159 diff=0
[02:26:31] - Digital signature verified
[02:26:31]
[02:26:31] Project: 6806 (Run 8000, Clone 2, Gen 15)
[02:26:31]
[02:26:31] Entering M.D.
[02:26:33] Tpr hash work/wudata_01.tpr: 3975951696 614214245 3243939412 2893478340 1682207625
[02:26:33] Working on 2 PEPTIDE (1-42)
[02:26:33] Client config found, loading data.
[02:26:36] CoreStatus = 63 (99)
[02:26:36] + Error starting Folding@home core.
[02:26:41]
[02:26:41] + Processing work unit
[02:26:41] Core required: FahCore_15.exe
[02:26:41] Core found.
[02:26:41] Working on queue slot 01 [April 22 02:26:41 UTC]
[02:26:41] + Working ...
[02:26:49] CoreStatus = C0000135 (-1073741515)
[02:26:49] Client-core communications error: ERROR 0xc0000135
[02:26:49] This is a sign of more serious problems, shutting down.
--- Opening Log file [April 22 02:33:37 UTC]
[02:33:37] - Ask before connecting: No
[02:33:37] - User name: Anonymous (Team 0)
[02:33:37] - User ID: 45999D7C6A09CBFA
[02:33:37] - Machine ID: 2
[02:33:37]
[02:33:37] Gpu type=3 species=21.
[02:33:37] Loaded queue successfully.
[02:33:37] Initialization complete
[02:33:37]
[02:33:37] + Processing work unit
[02:33:37] Core required: FahCore_15.exe
[02:33:37] Core found.
[02:33:37] Working on queue slot 01 [April 22 02:33:37 UTC]
[02:33:37] + Working ...
[02:33:37]
[02:33:37] *------------------------------*
[02:33:37] Folding@Home GPU Core
[02:33:37] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[02:33:37]
[02:33:37] Build host: SimbiosNvdWin7
[02:33:37] Board Type: NVIDIA/CUDA
[02:33:37] Core : x=15
[02:33:37] Window's signal control handler registered.
[02:33:37] Preparing to commence simulation
[02:33:37] - Ensuring status. Please wait.
[02:33:46] - Looking at optimizations...
[02:33:46] - Working with standard loops on this execution.
[02:33:46] Examination of work files indicates 8 consecutive improper terminations of core.
[02:33:46] sizeof(CORE_PACKET_HDR) = 512 file=<>
[02:33:46] - Expanded 43882 -> 172159 (decompressed 392.3 percent)
[02:33:46] Called DecompressByteArray: compressed_data_size=43882 data_size=172159, decompressed_data_size=172159 diff=0
[02:33:46] - Digital signature verified
[02:33:46]
[02:33:46] Project: 6806 (Run 8000, Clone 2, Gen 15)
[02:33:46]
[02:33:46] Entering M.D.
[02:33:48] Tpr hash work/wudata_01.tpr: 3975951696 614214245 3243939412 2893478340 1682207625
[02:33:49] Working on 2 PEPTIDE (1-42)
[02:33:49] Client config found, loading data.
[02:33:51] CoreStatus = 63 (99)
[02:33:51] + Error starting Folding@home core.
[02:33:56]
[02:33:56] + Processing work unit
[02:33:56] Core required: FahCore_15.exe
[02:33:56] Core found.
[02:33:56] Working on queue slot 01 [April 22 02:33:56 UTC]
[02:33:56] + Working ...
[02:33:56]
[02:33:56] *------------------------------*
[02:33:56] Folding@Home GPU Core
[02:33:56] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[02:33:56]
[02:33:56] Build host: SimbiosNvdWin7
[02:33:56] Board Type: NVIDIA/CUDA
[02:33:56] Core : x=15
[02:33:56] Window's signal control handler registered.
[02:33:56] Preparing to commence simulation
[02:33:56] - Ensuring status. Please wait.
[02:34:06] - Looking at optimizations...
[02:34:06] - Working with standard loops on this execution.
[02:34:06] Examination of work files indicates 8 consecutive improper terminations of core.
[02:34:06] sizeof(CORE_PACKET_HDR) = 512 file=<>
[02:34:06] - Expanded 43882 -> 172159 (decompressed 392.3 percent)
[02:34:06] Called DecompressByteArray: compressed_data_size=43882 data_size=172159, decompressed_data_size=172159 diff=0
[02:34:06] - Digital signature verified
[02:34:06]
[02:34:06] Project: 6806 (Run 8000, Clone 2, Gen 15)
[02:34:06]
[02:34:06] Entering M.D.
[02:34:08] Tpr hash work/wudata_01.tpr: 3975951696 614214245 3243939412 2893478340 1682207625
[02:34:08] Working on 2 PEPTIDE (1-42)
[02:34:08] Client config found, loading data.
[02:34:10] CoreStatus = 63 (99)
[02:34:10] + Error starting Folding@home core.
[02:34:15]
[02:34:15] + Processing work unit
[02:34:15] Core required: FahCore_15.exe
[02:34:15] Core found.
[02:34:15] Working on queue slot 01 [April 22 02:34:15 UTC]
[02:34:15] + Working ...
[02:34:15]
[02:34:15] *------------------------------*
[02:34:15] Folding@Home GPU Core
[02:34:15] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[02:34:15]
[02:34:15] Build host: SimbiosNvdWin7
[02:34:15] Board Type: NVIDIA/CUDA
[02:34:15] Core : x=15
[02:34:15] Window's signal control handler registered.
[02:34:15] Preparing to commence simulation
[02:34:15] - Ensuring status. Please wait.
[02:34:25] - Looking at optimizations...
[02:34:25] - Working with standard loops on this execution.
[02:34:25] Examination of work files indicates 8 consecutive improper terminations of core.
[02:34:25] sizeof(CORE_PACKET_HDR) = 512 file=<>
[02:34:25] - Expanded 43882 -> 172159 (decompressed 392.3 percent)
[02:34:25] Called DecompressByteArray: compressed_data_size=43882 data_size=172159, decompressed_data_size=172159 diff=0
[02:34:25] - Digital signature verified
[02:34:25]
[02:34:25] Project: 6806 (Run 8000, Clone 2, Gen 15)
[02:34:25]
[02:34:25] Entering M.D.
[02:34:27] Tpr hash work/wudata_01.tpr: 3975951696 614214245 3243939412 2893478340 1682207625
[02:34:27] Working on 2 PEPTIDE (1-42)
[02:34:27] Client config found, loading data.
[02:34:30] CoreStatus = 63 (99)
[02:34:30] + Error starting Folding@home core.
[02:34:30] - Attempting to download new core...
[02:34:30] + Downloading new core: FahCore_15.exe
[02:34:30] + 10240 bytes downloaded
[02:34:30] + 20480 bytes downloaded
[02:34:30] + 30720 bytes downloaded
[02:34:30] + 40960 bytes downloaded
[02:34:30] + 51200 bytes downloaded
[02:34:30] + 61440 bytes downloaded
[02:34:30] + 71680 bytes downloaded
[02:34:31] + 81920 bytes downloaded
[02:34:31] + 92160 bytes downloaded
[02:34:31] + 102400 bytes downloaded
[02:34:31] + 112640 bytes downloaded
[02:34:31] + 122880 bytes downloaded
[02:34:31] + 133120 bytes downloaded
[02:34:31] + 143360 bytes downloaded
[02:34:31] + 153600 bytes downloaded
[02:34:31] + 163840 bytes downloaded
[02:34:31] + 174080 bytes downloaded
[02:34:31] + 184320 bytes downloaded
[02:34:31] + 194560 bytes downloaded
[02:34:31] + 204800 bytes downloaded
[02:34:31] + 215040 bytes downloaded
[02:34:31] + 225280 bytes downloaded
[02:34:31] + 235520 bytes downloaded
[02:34:31] + 245760 bytes downloaded
[02:34:31] + 256000 bytes downloaded
[02:34:31] + 266240 bytes downloaded
[02:34:31] + 276480 bytes downloaded
[02:34:31] + 286720 bytes downloaded
[02:34:31] + 296960 bytes downloaded
[02:34:31] + 307200 bytes downloaded
[02:34:31] + 317440 bytes downloaded
[02:34:31] + 327680 bytes downloaded
[02:34:32] + 337920 bytes downloaded
[02:34:32] + 348160 bytes downloaded
[02:34:32] + 358400 bytes downloaded
[02:34:32] + 368640 bytes downloaded
[02:34:32] + 378880 bytes downloaded
[02:34:32] + 389120 bytes downloaded
[02:34:32] + 399360 bytes downloaded
[02:34:32] + 409600 bytes downloaded
[02:34:32] + 419840 bytes downloaded
[02:34:32] + 430080 bytes downloaded
[02:34:32] + 440320 bytes downloaded
[02:34:32] + 450560 bytes downloaded
[02:34:32] + 460800 bytes downloaded
[02:34:32] + 471040 bytes downloaded
[02:34:32] + 481280 bytes downloaded
[02:34:32] + 491520 bytes downloaded
[02:34:32] + 501760 bytes downloaded
[02:34:32] + 512000 bytes downloaded
[02:34:32] + 522240 bytes downloaded
[02:34:32] + 532480 bytes downloaded
[02:34:32] + 542720 bytes downloaded
[02:34:32] + 552960 bytes downloaded
[02:34:32] + 563200 bytes downloaded
[02:34:33] + 573440 bytes downloaded
[02:34:33] + 583680 bytes downloaded
[02:34:33] + 593920 bytes downloaded
[02:34:33] + 604160 bytes downloaded
[02:34:33] + 614400 bytes downloaded
[02:34:33] + 624640 bytes downloaded
[02:34:33] + 634880 bytes downloaded
[02:34:33] + 645120 bytes downloaded
[02:34:33] + 655360 bytes downloaded
[02:34:33] + 665600 bytes downloaded
[02:34:33] + 675840 bytes downloaded
[02:34:33] + 686080 bytes downloaded
[02:34:33] + 696320 bytes downloaded
[02:34:33] + 706560 bytes downloaded
[02:34:33] + 716800 bytes downloaded
[02:34:33] + 727040 bytes downloaded
[02:34:33] + 737280 bytes downloaded
[02:34:33] + 747520 bytes downloaded
[02:34:33] + 757760 bytes downloaded
[02:34:33] + 768000 bytes downloaded
[02:34:33] + 778240 bytes downloaded
[02:34:33] + 788480 bytes downloaded
[02:34:33] + 798720 bytes downloaded
[02:34:33] + 808960 bytes downloaded
[02:34:34] + 819200 bytes downloaded
[02:34:34] + 829440 bytes downloaded
[02:34:34] + 839680 bytes downloaded
[02:34:34] + 849920 bytes downloaded
[02:34:34] + 860160 bytes downloaded
[02:34:34] + 870400 bytes downloaded
[02:34:34] + 880640 bytes downloaded
[02:34:34] + 890880 bytes downloaded
[02:34:34] + 901120 bytes downloaded
[02:34:34] + 911360 bytes downloaded
[02:34:34] + 921600 bytes downloaded
[02:34:34] + 931840 bytes downloaded
[02:34:34] + 942080 bytes downloaded
[02:34:34] + 952320 bytes downloaded
[02:34:34] + 962560 bytes downloaded
[02:34:34] + 972800 bytes downloaded
[02:34:34] + 983040 bytes downloaded
[02:34:34] + 993280 bytes downloaded
[02:34:34] + 1003520 bytes downloaded
[02:34:34] + 1013760 bytes downloaded
[02:34:34] + 1024000 bytes downloaded
[02:34:34] + 1034240 bytes downloaded
[02:34:34] + 1044480 bytes downloaded
[02:34:34] + 1054720 bytes downloaded
[02:34:34] + 1064960 bytes downloaded
[02:34:35] + 1075200 bytes downloaded
[02:34:35] + 1085440 bytes downloaded
[02:34:35] + 1095680 bytes downloaded
[02:34:35] + 1105920 bytes downloaded
[02:34:35] + 1116160 bytes downloaded
[02:34:35] + 1126400 bytes downloaded
[02:34:35] + 1136640 bytes downloaded
[02:34:35] + 1146880 bytes downloaded
[02:34:35] + 1157120 bytes downloaded
[02:34:35] + 1167360 bytes downloaded
[02:34:35] + 1177600 bytes downloaded
[02:34:35] + 1187840 bytes downloaded
[02:34:35] + 1198080 bytes downloaded
[02:34:35] + 1208320 bytes downloaded
[02:34:35] + 1218560 bytes downloaded
[02:34:35] + 1228800 bytes downloaded
[02:34:35] + 1239040 bytes downloaded
[02:34:35] + 1249280 bytes downloaded
[02:34:35] + 1259520 bytes downloaded
[02:34:35] + 1269760 bytes downloaded
[02:34:35] + 1280000 bytes downloaded
[02:34:35] + 1290240 bytes downloaded
[02:34:35] + 1300480 bytes downloaded
[02:34:36] + 1310720 bytes downloaded
[02:34:36] + 1320960 bytes downloaded
[02:34:36] + 1331200 bytes downloaded
[02:34:36] + 1341440 bytes downloaded
[02:34:36] + 1351680 bytes downloaded
[02:34:36] + 1361920 bytes downloaded
[02:34:36] + 1372160 bytes downloaded
[02:34:36] + 1382400 bytes downloaded
[02:34:36] + 1392640 bytes downloaded
[02:34:36] + 1402880 bytes downloaded
[02:34:36] + 1413120 bytes downloaded
[02:34:36] + 1422551 bytes downloaded
[02:34:36] Verifying core Core_15.fah...
[02:34:36] Signature is VALID
[02:34:36]
[02:34:36] Trying to unzip core FahCore_15.exe
[02:34:36] Decompressed FahCore_15.exe (3903488 bytes) successfully
[02:34:41] + Core successfully engaged
[02:34:46]
[02:34:46] + Processing work unit
[02:34:46] Core required: FahCore_15.exe
[02:34:46] Core found.
[02:34:46] Working on queue slot 01 [April 22 02:34:46 UTC]
[02:34:46] + Working ...
[02:34:47]
[02:34:47] *------------------------------*
[02:34:47] Folding@Home GPU Core
[02:34:47] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[02:34:47]
[02:34:47] Build host: SimbiosNvdWin7
[02:34:47] Board Type: NVIDIA/CUDA
[02:34:47] Core : x=15
[02:34:47] Window's signal control handler registered.
[02:34:47] Preparing to commence simulation
[02:34:47] - Ensuring status. Please wait.
[02:34:56] - Looking at optimizations...
[02:34:56] - Working with standard loops on this execution.
[02:34:56] Examination of work files indicates 8 consecutive improper terminations of core.
[02:34:56] sizeof(CORE_PACKET_HDR) = 512 file=<>
[02:34:56] - Expanded 43882 -> 172159 (decompressed 392.3 percent)
[02:34:56] Called DecompressByteArray: compressed_data_size=43882 data_size=172159, decompressed_data_size=172159 diff=0
[02:34:56] - Digital signature verified
[02:34:56]
[02:34:56] Project: 6806 (Run 8000, Clone 2, Gen 15)
[02:34:56]
[02:34:56] Entering M.D.
[02:34:58] Tpr hash work/wudata_01.tpr: 3975951696 614214245 3243939412 2893478340 1682207625
[02:34:59] Working on 2 PEPTIDE (1-42)
[02:34:59] Client config found, loading data.
[02:34:59] Starting GUI Server
[02:35:01] CoreStatus = 63 (99)
[02:35:01] + Error starting Folding@home core.
[02:35:06]
[02:35:06] + Processing work unit
[02:35:06] Core required: FahCore_15.exe
[02:35:06] Core found.
[02:35:06] Working on queue slot 01 [April 22 02:35:06 UTC]
[02:35:06] + Working ...
[02:35:06]
[02:35:06] *------------------------------*
[02:35:06] Folding@Home GPU Core
[02:35:06] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[02:35:06]
[02:35:06] Build host: SimbiosNvdWin7
[02:35:06] Board Type: NVIDIA/CUDA
[02:35:06] Core : x=15
[02:35:06] Window's signal control handler registered.
[02:35:06] Preparing to commence simulation
[02:35:06] - Ensuring status. Please wait.
gwildperson
Re: Complete v6.41 Fermi client for download?
Is there some reason you can't run the systray client that you just installed? It may not be your preferred client for the long term but work that out after you get back.
It's possible that Project: 6806 (Run 8000, Clone 2, Gen 15) might be bad WU. Since it won't fold, you could try deleting everything in AppData\Roaming\Folding@home-gpu except client.cfg and the .dll files. Then restart the client.
If you get the exact same WU again and it still doesn't fold, change the machine ID of the client before shutting it down. Then delete the same files again before restarting.
If you do get a different WU and the problem persists, let us know.
No data in the WU Database yet for Project: 6806 (Run 8000, Clone 2, Gen 15) so I have marked it for a follow-up.
If you want the Console Client v6.41, then please do this:
Step 1: Download the [Full] Console 6.31 from here (viewtopic.php?p=158851#p158851).
Step 2: Unzip it in the desired folder.
Step 3: Download the [Drop-in] Console 6.41 from here (viewtopic.php?p=158851#p158851).
Step 4: Replace the 6.31 contents with 6.41
Step 5: Start the GPU Client and it should work fine.
It would seem prudent to have the v6.41 Fermi Console client available as a complete download. How many potential folders are lost when the first thing they download hasn't got a chance of working? A few come here and get help, some go to a team forum to get help, many more just give up.
