fourteen (14) failures in a row, cannot progress further
model name : Intel(R) Core(TM)2 Duo CPU E8500 @ 3.16GHz
cpu MHz : 3166.650
cache size : 6144 KB
Memory: 1.01 GB physical, 1.94 GB virtual
Client Version 6.02
Core: FahCore_78.exe
Core Version 1.90 (March 8, 2006)
[16:14:04] - Will indicate memory of 500 MB
Typical error
[16:13:12] Completed 105000 out of 250000 steps (42%)
[16:13:47] CoreStatus = 0 (0)
[16:13:47] Client-core communications error: ERROR 0x0
Project: 6513 (Run 14, Clone 207, Gen 55) - 0x0 @ 42%
Re: Project: 6513 (Run 14, Clone 207, Gen 55) - 0x0 @ 42%
Thank you for the feedback.
I just checked the trajectory of project 6513 (Run 14, Clone 207, Gen 54) and it seems ok. Also I checked the tpr file of (Run 14, Clone 207, Gen 55) and it looks fine. So far I am not sure what happened. I will think more later.
Best,
Lan
Best,
Lan
