Beginners question
pddawg8806
Beginners question
Post by pddawg8806 »
I'm using two 8800gts on windows 7 with the 6.23 client. I think I have set it up correct, but when when I click on each of the processes in the taskbar and select "Display" I get the same image (same percent completion etc.) Are both working on the same thing? I tried to download new projects using FahMon but nothing changed. Any help?
http://yfrog.com/fvcapturebbj
Zagen30
Re: Beginners question
Post by Zagen30 »
Welcome to the forums, pddawg.
It looks like you're running the same WU on each client, which should not be the case. It looks like your second card (GPU 2) hasn't made as much progress on it. Shut that client down, then go to its folder and delete the work folder and queue.dat, then restart the client. It should pick up a different WU.
pddawg8806
thanks that worked. also, in FahMon, I clicked Web > My Stats ... I'm guessing nothing will show up until I complete one job correct? I have put in the passkey in for both, so will the stats be combined for both GPUs?
kiore
Post by kiore »
pddawg8806 wrote:thanks that worked. also, in FahMon, I clicked Web > My Stats ... I'm guessing nothing will show up until I complete one job correct? I have put in the passkey in for both, so will the stats be combined for both GPUs?
They will both be under your folding name if you set it up like that, the machine ID thing doesn't make a difference for that, the key is to have the same folding name and team number etc.
Regarding the usage of Passkey, all SMP2 WUs are registered under it. Some GPU WUs too are registered under it. Everything is registered under your Username.
