Cannot upload to 171.64.65.62
amuro.ID
Post by amuro.ID »
My client already trying to upload to this server for about 2 days.
06:55:34] Loaded queue successfully.
[06:55:34] Attempting to return result(s) to server...
[06:55:34] Project: 6501 (Run 9, Clone 741, Gen 2)
[06:55:34] + Attempting to send results [May 1 06:55:34 UTC]
[06:55:35] - Couldn't send HTTP request to server
[06:55:35]   (Got status 504)
[06:55:35] + Could not connect to Work Server (results)
[06:55:35]     (171.64.65.62:8080)
[06:55:35] + Retrying using alternative port
[06:55:36] - Couldn't send HTTP request to server
[06:55:36]   (Got status 504)
[06:55:36] + Could not connect to Work Server (results)
[06:55:36]     (171.64.65.62:80)
[06:55:36] - Error: Could not transmit unit 04 (completed April 30) to work server.
[06:55:36] + Attempting to send results [May 1 06:55:36 UTC]
[06:56:35] - Server does not have record of this unit. Will try again later.
[06:56:35]   Could not transmit unit 04 to Collection server; keeping in queue.
[06:56:35] - Failed to send unit 04 to server
Folding@Home Client Shutdown.
Char_Ell
Hardware configuration: Mainboard: MSI P4N Diamond
CPU: Pentium 4 660 @ 3.6 GHz
GPU: NVIDIA GeForce 9800 GTX+
RAM: 2 GB
OS: Windows XP SP2
Re: Cannot upload to 171.64.65.62
Post by Char_Ell »
Looks like I'm experiencing the same issue.
Accessing http://171.64.65.62 using my web browser returns "unable to connect" message. Same response when attempting to access port 8080.
The server status page shows 171.64.65.62 with status=Full and connect=Reject
The log page for 171.64.65.62 shows this server has been Full/Reject since Sun May 9 10:35:10 PDT 2010
My CPU client will of course keep attempting to resend but posting this just in case someone, like maybe vvoelz, isn't aware... :)
[10:25:47] + Attempting to send results [May 11 10:25:47 UTC]
[10:25:48] - Couldn't send HTTP request to server
[10:25:48] + Could not connect to Work Server (results)
[10:25:48]     (171.64.65.62:8080)
[10:25:48] + Retrying using alternative port
[10:25:49] - Couldn't send HTTP request to server
[10:25:49] + Could not connect to Work Server (results)
[10:25:49]     (171.64.65.62:80)
[10:25:49] - Error: Could not transmit unit 05 (completed May 9) to work server.
[10:25:49] - Read packet limit of 540015616... Set to 524286976.
[10:25:49] + Attempting to send results [May 11 10:25:49 UTC]
[10:25:51] - Server does not have record of this unit. Will try again later.
[10:25:51]   Could not transmit unit 05 to Collection server; keeping in queue.
DrBB1
Post by DrBB1 »
Cannot upload to this server. There does not appear to be an alternate collection server assigned. Note message, "Server does not have a record of this unit." So far, upload has failed 15 times. I do not see anything wrong when I check server status. Can anyone provide an explanation of what the problem may be?
[14:52:58] Project: 6503 (Run 14, Clone 581, Gen 22)
[14:52:58] - Read packet limit of 540015616... Set to 524286976.
[14:52:58] + Attempting to send results [May 11 14:52:58 UTC]
[14:52:59] - Couldn't send HTTP request to server
[14:52:59] + Could not connect to Work Server (results)
[14:52:59]     (171.64.65.62:8080)
[14:52:59] + Retrying using alternative port
[14:53:01] - Couldn't send HTTP request to server
[14:53:01] + Could not connect to Work Server (results)
[14:53:01]     (171.64.65.62:80)
[14:53:01] - Error: Could not transmit unit 09 (completed May 9) to work server.
[14:53:01] - Read packet limit of 540015616... Set to 524286976.
[14:53:01] + Attempting to send results [May 11 14:53:01 UTC]
[14:53:02] - Server does not have record of this unit. Will try again later.
[14:53:02]   Could not transmit unit 09 to Collection server; keeping in queue.
[14:53:02] + Working...
DrBB1
Sometimes the message "Server does not have record of this unit" is due to an interruption in communications between the Work Server and the Collection Server. Other times, it means that the WU has already been uploaded. In this case, you did get (partial) credit for it and uploading it again isn't going to be accepted. I suggest you delete the WU so your client will stop repeatedly trying to upload it.
Hi DrBB1 (team 39340),
Your WU (P6503 R14 C581 G22) was added to the stats database on 2010-05-11 14:03:07 for 59.45 points of credit.
The message " Read packet limit of 540015616... Set to 524286976." has never been adequately explained, but it does seem to be related to some kind of upload problems.
The Reject status of 171.64.65.62 was corrected about 14 hours ago and it has been busy dealing with the backlog. It seems to be getting back to normal now.
Char_Ell
RAM: 2 GB
OS: Windows XP SP2
Post by Char_Ell »
Thanks Bruce. I can confirm my CPU client successfully uploaded my WU for Project: 6501 (Run 17, Clone 840, Gen 8) completed May 9 about 7 hours ago.
DrBB1
Post by DrBB1 »
Bruce,
Thanks for the explanation. With respect to the following,
is there a way for me to access this information about the status of one of my own uploads, or is this something only administrators have access to?
Thanks for the help.
DrBB1
bruce wrote:The message " Read packet limit of 540015616... Set to 524286976." has never been adequately explained, but it does seem to be related to some kind of upload problems.
When I asked about it, the response was it wasn't an error but a notification. Here is some more info (http://foldingforum.org/viewtopic.php?f=47&t=13747)
DrBB1 wrote:Bruce,
Sorry, but it's for forum Moderators only.
DrBB1
Post by DrBB1 »
That's what I figured, but since the message started "Hi DrBB1...," I thought it might be for users, too. No harm in asking... :ewink:
Thanks again, Bruce.
DrBB1
codysluder
Post by codysluder »
Bruce was telling you what the database says for (P6503 R14 C581 G22). It knows who you are and what team you're on and that's apparently automatically part of the reports that the mods post when they're helping anybody.
