171.64.65.65 not crediting units
daveb
Post by daveb »
The last 5 units I have returned to 171.64.65.65 over the past few days do not appear to have been credited.
Project: 2611, Run 1, Clone 907, Gen 162 Returned Feb 17 @ 6:03 UTC
Project: 2613, Run 12, Clone 3, Gen 151 Feb 18 @ 6:32 UTC
Project: 2613, Run 88, Clone 2, Gen 158 Feb 18 @ 5:40 UTC
Project: 2613, Run 76, Clone 2, Gen 159 Feb 18 @ 6:28 UTC
Project: 2611, Run 0, Clone 759, Gen 158 Feb 18 @ 5:54 UTC
At least several of these machines have successfully uploaded units to this server in the past. All appeared to upload successfully in the FAHlog files.
For example:
[05:40:18] - User name: daveb@carlsbad.***********.com (Team 1971)
[05:40:18] - User ID: 321B9123401B2087
[05:40:18] - Machine ID: 7
[05:40:18]
[05:40:18] Loaded queue successfully.
[05:40:18] Attempting to return result(s) to server...
[05:40:18] Trying to send all finished work units
[05:40:18] Project: 2613 (Run 88, Clone 2, Gen 158)
[05:40:18] + Attempting to send results [February 18 05:40:18 UTC]
[05:40:18] - Reading file work/wuresults_03.dat from core
[05:40:19]   (Read 17466149 bytes from disk)
[05:40:21] Connecting to http://171.64.65.65:8080/
[05:44:34] Posted data.
[05:44:34] Initial: 0000; - Uploaded at ~67 kB/s
[05:44:34] - Averaged speed for that direction ~88 kB/s
[05:44:34] + Results successfully sent
[05:44:34] Thank you for your contribution to Folding@Home.
[05:44:34] + Number of Units Completed: 156
[05:45:03] + Sent 1 of 1 completed units to the server
Can someone please let me know if there is a problem on my end?
Thanks,
Dave
_r2w_ben
Re: 171.64.65.65 not crediting units
Post by _r2w_ben »
The server log indicates it went down after Tue Feb 16 08:55:10 PST 2010.
It came back to life around Tue Feb 16 18:05:10 PST 2010.
Since then the WUs RCV count continues to increase. Normally this figure decreases hourly as the stats update and you receive credit.
To me it looks like it's a server problem and not something wrong with your machines.
On a side note, % Ass % Ass 80 columns are empty since the server came back to life so it appears that it's not assigning new work either.
Someone (but not you) completed Project: 2613 (Run 88, Clone 2, Gen 158) successfully on 2010-02-15 21:11:55 ...
I'm checking deeper into your problem and don't have a real answer yet, but I do see one possibility.
daveb wrote:[05:40:18] - User name: daveb@carlsbad.***********.com (Team 1971)
At one time or another, you have spelled carlsbad.***********.com two different ways.
daveb
Post by daveb »
I want to thank all of you for the information you provided.
r2w_ben, I only noticed that the server status showed full and accepting after it came back up, I didn't think to check the received column and note that the units were piling up.
Bruce, I have made more than a few mistakes typing in my ridiculously long username over the past years. I did go back and check that the name for all of the units posted here was correct.
I just noticed that one of my machines has pulled down a new unit from 171.64.65.65, and I received credit for 5 units and ~3.600 pts, so I assume that everything has been fixed.
Dave
