Ok, so i have my Athlon 620 @ 3.1 ghz and an hd 4650 disregard my sig, If i am just running the smp i get about the same ppd as running both smp and vga so power is not an issue so.
Which configuration helps folding @ home more scientifically getting the smp back sooner or having both an smp and gpu2 cores running
Most productive for fah
- Hardware configuration: AMD Phenom II 955 @ 3.8 +ATi HD 5870
AMD Athlon II 610e @ 2.5 + 2x Nvidia 560Ti @ 1ghz
AMD Athlon II 605e @ 2.4 +Nvidia 550Ti + Nvidia GT 240
AMD Athlon II 620 @ 3.3ghz
Things yet to materialize.
- Hardware configuration: WooHoo= SR-2 -- L5639 @ ?? -- Evga 560ti FPB -- 12Gig Corsair XMS3 -- Corsair 1050hx -- Blackhawk Ultra
Re: Most productive for fah
Faster return, means new work can be sent out. The science runs by you finishing 1 part, then the next person continuing on with where you left off.
If the PPD together is the same as the cpu alone, then you need another computer to house the gpu. One computer is clearly not enough.
But seriously folks, if the gpu isn't adding additional points, you're wasting power to use both. Just use the cpu.
single 1070
