I am not sure this is the right forum for this post, but, I could not see another that fit my needs.
I regret that I have to give up folding at home, but the way that statistics are kept and records of
WU's are kept just make it impossible for me to keep folding at this time.
I will check in again later to see, But my WU's(unearned) vs WU's(earned) seem
to make my machine unusable in this project. VERY SORRY!
Goodbye
John.
I've had enough!
Re: I've had enough!
jrnull,
I am very sorry for you. You are missing the major point of this Project in exchange for your "missed points".
Hope that you never need the results that this Project will bring to the rest of us.
Best Regards, Fernando.
Always remember Dick Howell.
- Hardware configuration: WooHoo= SR-2 -- L5639 @ ?? -- Evga 560ti FPB -- 12Gig Corsair XMS3 -- Corsair 1050hx -- Blackhawk Ultra
Other than just posting your unhappyness, why not post your problem, with more info, and get help.
Odds are its a mis-config of the clients.
I am pretty green, but with pretty much plain systray installations and putting in the right team number, my stats for 15 machines set up this past month appear fine. I do now pretty much use kakaostats.com to get the team summary. I agree about the ask for help part. Folks helped me get my CPU usage down from 50% default to 10% by tuning the environment variables.
David
David
thank you!! it can help me..
Hello jrnull,
some answers above are right. You can stop F@H, it's your choise. But test the helpfullness in this forum first.
I just did so. And they told me, V. Pande's team is installing new server. (24GB Ram, ... ^^ )
Once I had had problems with my config-file. It was changed by itself. Not very funny. But at last, I was able to fix the problem by myself.
Have courage and write about your problems.
Stopping F@H means, your CPUs are boring. GPU?
- Hardware configuration: 2 x X5550 Xeons - SuperMicro MBD-X8DAi-O
Server 2008 R2 x64 - 12GB Crucial DDR3 ECC Ram
PCP&C 910 Silencer - 1 x HIS 4850 ICEQ Turbo Edition
6 x E5530 Xeons (3 Systems) - SUPERMICRO MBD-X8DTL-i-O
Server 2008 RS x64 - 8GB DDR3 GSkill Non-ECC Ram
Seasonic 80+ Bronze 380w PSU
2 x E5504 - SUPERMICRO MBD-X8DTL-i-O
Server 2008 R2 x64 - 6GB DDR3 GSkill Non-ECC Ram
2.3 TB Raid 5 Array - Corsair 520 Power Supply
E5504 - EVGA X58 ATX Motherboard
Windows 7 x64 - 6GB DDR3 GSkill Non-ECC Ram
Seasonic 300 Power Supply
Intel X5550 CPU - EVGA X58 Micro ATX Motherboard
Windows 7 x64 - 3GB Corsair DDR3-1600
Corsair 550 Power Supply - ATI 4350
Dell Vostro 1500 Laptop - Intel T9300 C2D CPU
Windows 7 x64 - 4 GB DDR2-6400 - nVidia 8400m GS
Xeon 3075 C2D - Intel P35 Motherboard - 4GB DDR2 Non-ECC Ram
Server 2008 R2 x64- Seasonic 300 Power Supply - Location: Columbia, Tennessee
Not much use trying to ask this user questions.Only one post and have not signed in since this post started.
