Project: 2671 (Run 29, Clone 72, Gen 145) [fixed]
GTron
Post by GTron »
Project: 2671 (Run 29, Clone 72, Gen 145) appears to be a bad WU as it has 36500004 steps instead of the usual 250000 (146x bigger than usual) and will miss its deadline by months.
I will flush this WU off my folder. Pande Group, please check and remove from the servers. (Log snippet below.)
Thanks,
Greg
[11:27:43] Connecting to http://assign.stanford.edu:8080/
[11:27:43] Posted data.
[11:27:43] Initial: 43AB; - Successful: assigned to (171.67.108.24).
[11:27:43] + News From Folding@Home: Welcome to Folding@Home
[11:27:43] Loaded queue successfully.
[11:27:43] Connecting to http://171.67.108.24:8080/
[11:27:49] Posted data.
[11:27:49] Initial: 0000; - Receiving payload (expected size: 4095719)
[11:27:55] - Downloaded at ~666 kB/s
[11:27:55] - Averaged speed for that direction ~542 kB/s
[11:27:55] + Received work.
[11:27:55] Trying to send all finished work units
[11:27:55] + No unsent completed units remaining.
[11:27:55] + Closed connections
[11:27:55]
[11:27:55] + Processing work unit
[11:27:55] Core required: FahCore_a2.exe
[11:27:55] Core found.
[11:27:55] Working on Unit 00 [December 8 11:27:55]
[11:27:55] + Working ...
[11:27:55] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a2.exe -dir work/ -suffix 00 -checkpoint 20 -verbose -lifeline 6226 -version 602'
[11:27:55]
[11:27:55] *------------------------------*
[11:27:55] Folding@Home Gromacs SMP Core
[11:27:55] Version 2.10 (Sun Aug 30 03:43:28 CEST 2009)
[11:27:55]
[11:27:55] Preparing to commence simulation
[11:27:55] - Ensuring status. Please wait.
[11:27:56] Called DecompressByteArray: compressed_data_size=4095207 data_size=24034317, decompressed_data_size=24034317 diff=0
[11:27:56] - Digital signature verified
[11:27:56]
[11:27:56] Project: 2671 (Run 29, Clone 72, Gen 145)
[11:27:56]
[11:27:56] Assembly optimizations on if available.
[11:27:56] Entering M.D.
[11:28:06] un 29, Clone 72, Gen 145)
[11:28:06]
[11:28:06] Entering M.D.
[14:11:48] - Autosending finished units...
[14:11:48] Trying to send all finished work units
[14:11:48] + No unsent completed units remaining.
[14:11:48] - Autosend completed
[20:11:48] - Autosending finished units...
[20:11:48] Trying to send all finished work units
[20:11:48] + No unsent completed units remaining.
[20:11:48] - Autosend completed
[00:47:30] ompleted 365001 out of 36500004 steps  (1%)
[02:11:48] - Autosending finished units...
[02:11:48] Trying to send all finished work units
[02:11:48] + No unsent completed units remaining.
[02:11:48] - Autosend completed
[08:11:48] - Autosending finished units...
[08:11:48] Trying to send all finished work units
[08:11:48] + No unsent completed units remaining.
[08:11:48] - Autosend completed
[14:09:23] Completed 730001 out of 36500004 steps  (2%)
[03:31:52] Completed 1095001 out of 36500004 steps  (3%)
kasson
Pande Group Member
Re: Project: 2671 (Run 29, Clone 72, Gen 145) [fixed]
Post by kasson »
This work unit has been fixed on the servers. Future assigns should have the correct number of steps.
GTron
Post by GTron »
Thank you Dr. Kasson for your prompt action. As expected, my folder received this WU again after finishing the 2677 it processed after I flushed the earlier version. While I noticed the major reduction in steps to 500000, that still appears to be 2x what 2671 WUs usually are. I will let it run, but you may want to double check this WU. My folder should return it by Fri 13:30 PST. (Log snippet below.)
Thanks,
Greg
[02:10:13] Connecting to http://assign.stanford.edu:8080/
[02:10:14] Posted data.
[02:10:14] Initial: 43AB; - Successful: assigned to (171.67.108.24).
[02:10:14] + News From Folding@Home: Welcome to Folding@Home
[02:10:14] Loaded queue successfully.
[02:10:14] Connecting to http://171.67.108.24:8080/
[02:10:21] Posted data.
[02:10:21] Initial: 0000; - Receiving payload (expected size: 4838873)
[02:10:32] - Downloaded at ~429 kB/s
[02:10:32] - Averaged speed for that direction ~510 kB/s
[02:10:32] + Received work.
[02:10:32] Trying to send all finished work units
[02:10:32] + No unsent completed units remaining.
[02:10:32] + Closed connections
[02:10:32]
[02:10:32] + Processing work unit
[02:10:32] Core required: FahCore_a2.exe
[02:10:32] Core found.
[02:10:32] Working on Unit 02 [December 11 02:10:32]
[02:10:32] + Working ...
[02:10:32] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a2.exe -dir work/ -suffix 02 -checkpoint 20 -verbose -lifeline 6245 -version 602'
[02:10:33]
[02:10:33] *------------------------------*
[02:10:33] Folding@Home Gromacs SMP Core
[02:10:33] Version 2.10 (Sun Aug 30 03:43:28 CEST 2009)
[02:10:33]
[02:10:33] Preparing to commence simulation
[02:10:33] - Ensuring status. Please wait.
[02:10:34] Called DecompressByteArray: compressed_data_size=4838361 data_size=24034317, decompressed_data_size=24034317 diff=0
[02:10:34] - Digital signature verified
[02:10:34]
[02:10:34] Project: 2671 (Run 29, Clone 72, Gen 145)
[02:10:34]
[02:10:34] Assembly optimizations on if available.
[02:10:34] Entering M.D.
[02:10:43] un 29, Clone 72, Gen 145)
[02:10:43]
[02:10:43] Entering M.D.
[02:22:04] pleted 5000 out of 500000 steps  (1%)
[02:33:16] Completed 10000 out of 500000 steps  (2%)
[02:44:26] Completed 15000 out of 500000 steps  (3%)
[02:55:38] Completed 20000 out of 500000 steps  (4%)
orion
Hardware configuration: 4p/4 MC ES @ 3.0GHz/32GB
4p/4x6128 @ 2.47GHz/32GB
2p/2 IL ES @ 2.7GHz/16GB
1p/8150/8GB
1p/1090T/4GB
Post by orion »
I've got the same WU RCG. It too is taking twice as long as the P2671 (59,76,147) it did before.
[11:54:01] Project: 2671 (Run 29, Clone 72, Gen 145)
[11:54:01]
[11:54:01] Assembly optimizations on if available.
[11:54:01] Entering M.D.
[11:54:07] Multi-core optimizations on
[11:54:08] Completed 0 out of 500000 steps  (0%)
[12:02:32] Completed 5000 out of 500000 steps  (1%)
[12:10:55] Completed 10000 out of 500000 steps  (2%)
[12:19:18] Completed 15000 out of 500000 steps  (3%)
[12:27:40] Completed 20000 out of 500000 steps  (4%)
[12:36:02] Completed 25000 out of 500000 steps  (5%)
[12:44:25] Completed 30000 out of 500000 steps  (6%)
[12:52:47] Completed 35000 out of 500000 steps  (7%)
[13:01:11] Completed 40000 out of 500000 steps  (8%)
[13:09:33] Completed 45000 out of 500000 steps  (9%)
[13:17:56] Completed 50000 out of 500000 steps  (10%)
[13:26:19] Completed 55000 out of 500000 steps  (11%)
[13:34:41] Completed 60000 out of 500000 steps  (12%)
[13:43:05] Completed 65000 out of 500000 steps  (13%)
[13:51:28] Completed 70000 out of 500000 steps  (14%)
[13:59:51] Completed 75000 out of 500000 steps  (15%)
[04:26:56] Project: 2671 (Run 59, Clone 76, Gen 147)
[04:26:56]
[04:26:56] Assembly optimizations on if available.
[04:26:56] Entering M.D.
[04:27:02] Multi-core optimizations on
[04:27:03] Completed 0 out of 250000 steps  (0%)
[04:31:18] Completed 2500 out of 250000 steps  (1%)
[04:35:31] Completed 5000 out of 250000 steps  (2%)
[04:39:45] Completed 7500 out of 250000 steps  (3%)
[04:43:59] Completed 10000 out of 250000 steps  (4%)
[04:48:12] Completed 12500 out of 250000 steps  (5%)
[04:52:26] Completed 15000 out of 250000 steps  (6%)
[04:56:40] Completed 17500 out of 250000 steps  (7%)
[05:00:54] Completed 20000 out of 250000 steps  (8%)
[05:05:07] Completed 22500 out of 250000 steps  (9%)
[05:09:21] Completed 25000 out of 250000 steps  (10%)
[05:13:34] Completed 27500 out of 250000 steps  (11%)
[05:17:48] Completed 30000 out of 250000 steps  (12%)
[05:22:01] Completed 32500 out of 250000 steps  (13%)
[05:26:14] Completed 35000 out of 250000 steps  (14%)
[05:30:28] Completed 37500 out of 250000 steps  (15%)
iustus quia...
