Project: 5741 (Run 1, Clone 16, Gen 502)
SparkyJJO
Post by SparkyJJO »
Instant EUE, my 4870 is stable with all the other projects. Had to delete the unitinfo.dat and work folder to get it to download a different unit.
====================Folding since 2006====================
valleton
Hardware configuration: Intel E8600
Club3D Radeon HD4870 1GB
Re: Project: 5741 (Run 1, Clone 16, Gen 502)
Post by valleton »
This one wasted my PC's production now.
Leinad112
Post by Leinad112 »
I am having problems with this WU:
[07:21:04] Completed 93%
[07:24:24] Completed 94%
[07:27:45] Completed 95%
[07:31:05] Completed 96%
[07:34:24] Completed 97%
[07:37:45] Completed 98%
[07:41:05] Completed 99%
[07:44:26] Completed 100%
[07:44:26] Successful run
[07:44:26] DynamicWrapper: Finished Work Unit: sleep=10000
[07:44:35] Reserved 220356 bytes for xtc file; Cosm status=0
[07:44:35] Allocated 220356 bytes for xtc file
[07:44:35] - Reading up to 220356 from "work/wudata_02.xtc": Read 220356
[07:44:35] Read 220356 bytes from xtc file; available packet space=786210108
[07:44:35] xtc file hash check passed.
[07:44:35] Reserved 33528 33528 786210108 bytes for arc file=<work/wudata_02.trr> Cosm status=0
[07:44:35] Allocated 33528 bytes for arc file
[07:44:35] - Reading up to 33528 from "work/wudata_02.trr": Read 33528
[07:44:35] Read 33528 bytes from arc file; available packet space=786176580
[07:44:35] trr file hash check passed.
[07:44:35] Allocated 560 bytes for edr file
[07:44:35] Read bedfile
[07:44:35] edr file hash check passed.
[07:44:35] Allocated 0 bytes for logfile
[07:44:35] Could not open/read logfile=<work/wudata_02.log>; Cosm status=-1
[07:44:35] GuardedRun: success in DynamicWrapper
[07:44:35] GuardedRun: done
[07:44:35] Run: GuardedRun completed.
[07:44:37] - Writing 254956 bytes of core data to disk...
[07:44:37] Done: 254444 -> 253404 (compressed to 99.5 percent)
[07:44:37]   ... Done.
[07:44:37] - Shutting down core
[07:44:37]
[07:44:37] Folding@home Core Shutdown: FINISHED_UNIT
[07:44:40] CoreStatus = 64 (100)
[07:44:40] Sending work to server
[07:44:40] Project: 5735 (Run 4, Clone 7, Gen 380)
[07:44:40] - Read packet limit of 540015616... Set to 524286976.
[07:44:40] + Attempting to send results [September 23 07:44:40 UTC]
[07:44:44] + Results successfully sent
[07:44:44] Thank you for your contribution to Folding@Home.
[07:44:44] + Number of Units Completed: 59
[07:44:48] - Preparing to get new work unit...
[07:44:48] + Attempting to get work packet
[07:44:48] - Connecting to assignment server
[07:44:49] - Successful: assigned to (171.64.65.102).
[07:44:49] + News From Folding@Home: Welcome to Folding@Home
[07:44:49] Loaded queue successfully.
[07:44:51] + Closed connections
[07:44:51]
[07:44:51] + Processing work unit
[07:44:51] Core required: FahCore_11.exe
[07:44:51] Core found.
[07:44:51] Working on queue slot 03 [September 23 07:44:51 UTC]
[07:44:51] + Working ...
[07:44:51]
[07:44:51] *------------------------------*
[07:44:51] Folding@Home GPU Core - Beta
[07:44:51] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[07:44:51]
[07:44:51] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[07:44:51] Build host: amoeba
[07:44:51] Board Type: AMD
[07:44:51] Core      :
[07:44:51] Preparing to commence simulation
[07:44:51] - Looking at optimizations...
[07:44:51] - Created dyn
[07:44:51] - Files status OK
[07:44:51] - Expanded 70234 -> 360060 (decompressed 512.6 percent)
[07:44:51] Called DecompressByteArray: compressed_data_size=70234 data_size=360060, decompressed_data_size=360060 diff=0
[07:44:51] - Digital signature verified
[07:44:51]
[07:44:51] Project: 5741 (Run 1, Clone 16, Gen 502)
[07:44:51]
[07:44:51] Assembly optimizations on if available.
[07:44:51] Entering M.D.
[07:44:57] Tpr hash work/wudata_03.tpr:  859612253 4235038467 437682866 3888534315 1747312355
[07:44:57] Working on Protein
[07:44:58] Client config found, loading data.
[07:44:58] Starting GUI Server
[07:45:01] mdrun_gpu returned
[07:45:01] SHAKE violations on GPU
[07:45:01]
[07:45:01] Folding@home Core Shutdown: UNSTABLE_MACHINE
[07:45:04] CoreStatus = 7A (122)
[07:45:04] Sending work to server
[07:45:04] Project: 5741 (Run 1, Clone 16, Gen 502)
[07:45:04] - Read packet limit of 540015616... Set to 524286976.
[07:45:04] - Error: Could not get length of results file work/wuresults_03.dat
[07:45:04] - Error: Could not read unit 03 file. Removing from queue.
[07:45:04] - Preparing to get new work unit...
[07:45:04] + Attempting to get work packet
[07:45:04] - Connecting to assignment server
[07:45:05] - Successful: assigned to (171.64.65.102).
[07:45:05] + News From Folding@Home: Welcome to Folding@Home
[07:45:05] Loaded queue successfully.
[07:45:07] + Closed connections
[07:45:12]
[07:45:12] + Processing work unit
[07:45:12] Core required: FahCore_11.exe
[07:45:12] Core found.
[07:45:12] Working on queue slot 04 [September 23 07:45:12 UTC]
[07:45:12] + Working ...
[07:45:12]
[07:45:12] *------------------------------*
[07:45:12] Folding@Home GPU Core - Beta
[07:45:12] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[07:45:12]
[07:45:12] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[07:45:12] Build host: amoeba
[07:45:12] Board Type: AMD
[07:45:12] Core      :
[07:45:12] Preparing to commence simulation
[07:45:12] - Looking at optimizations...
[07:45:12] - Created dyn
[07:45:12] - Files status OK
[07:45:12] - Expanded 70234 -> 360060 (decompressed 512.6 percent)
[07:45:12] Called DecompressByteArray: compressed_data_size=70234 data_size=360060, decompressed_data_size=360060 diff=0
[07:45:12] - Digital signature verified
[07:45:12]
[07:45:12] Project: 5741 (Run 1, Clone 16, Gen 502)
[07:45:12]
[07:45:12] Assembly optimizations on if available.
[07:45:12] Entering M.D.
[07:45:18] Tpr hash work/wudata_04.tpr:  859612253 4235038467 437682866 3888534315 1747312355
[07:45:18] Working on Protein
[07:45:19] Client config found, loading data.
[07:45:19] Starting GUI Server
[07:45:21] mdrun_gpu returned
[07:45:21] SHAKE violations on GPU
[07:45:21]
[07:45:21] Folding@home Core Shutdown: UNSTABLE_MACHINE
[07:45:24] CoreStatus = 7A (122)
[07:45:24] Sending work to server
[07:45:24] Project: 5741 (Run 1, Clone 16, Gen 502)
[07:45:24] - Read packet limit of 540015616... Set to 524286976.
[07:45:24] - Error: Could not get length of results file work/wuresults_04.dat
[07:45:24] - Error: Could not read unit 04 file. Removing from queue.
[07:45:24] - Preparing to get new work unit...
[07:45:24] + Attempting to get work packet
[07:45:24] - Connecting to assignment server
[07:45:25] - Successful: assigned to (171.64.65.102).
[07:45:25] + News From Folding@Home: Welcome to Folding@Home
[07:45:25] Loaded queue successfully.
[07:45:27] + Closed connections
[07:45:32]
[07:45:32] + Processing work unit
[07:45:32] Core required: FahCore_11.exe
[07:45:32] Core found.
[07:45:32] Working on queue slot 05 [September 23 07:45:32 UTC]
[07:45:32] + Working ...
[07:45:32]
[07:45:32] *------------------------------*
[07:45:32] Folding@Home GPU Core - Beta
[07:45:32] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[07:45:32]
[07:45:32] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[07:45:32] Build host: amoeba
[07:45:32] Board Type: AMD
[07:45:32] Core      :
[07:45:32] Preparing to commence simulation
[07:45:32] - Looking at optimizations...
[07:45:32] - Created dyn
[07:45:32] - Files status OK
[07:45:32] - Expanded 70234 -> 360060 (decompressed 512.6 percent)
[07:45:32] Called DecompressByteArray: compressed_data_size=70234 data_size=360060, decompressed_data_size=360060 diff=0
[07:45:32] - Digital signature verified
[07:45:32]
[07:45:32] Project: 5741 (Run 1, Clone 16, Gen 502)
[07:45:32]
[07:45:32] Assembly optimizations on if available.
[07:45:32] Entering M.D.
[07:45:38] Tpr hash work/wudata_05.tpr:  859612253 4235038467 437682866 3888534315 1747312355
[07:45:38] Working on Protein
[07:45:39] Client config found, loading data.
[07:45:39] Starting GUI Server
[07:45:42] mdrun_gpu returned
[07:45:42] SHAKE violations on GPU
[07:45:42]
[07:45:42] Folding@home Core Shutdown: UNSTABLE_MACHINE
[07:45:45] CoreStatus = 7A (122)
[07:45:45] Sending work to server
[07:45:45] Project: 5741 (Run 1, Clone 16, Gen 502)
[07:45:45] - Read packet limit of 540015616... Set to 524286976.
[07:45:45] + Attempting to send results [September 23 07:45:45 UTC]
[07:45:45] + Results successfully sent
[07:45:45] Thank you for your contribution to Folding@Home.
[07:45:49] - Preparing to get new work unit...
[07:45:49] + Attempting to get work packet
[07:45:49] - Connecting to assignment server
[07:45:50] - Successful: assigned to (171.64.65.102).
[07:45:50] + News From Folding@Home: Welcome to Folding@Home
[07:45:50] Loaded queue successfully.
[07:45:52] + Closed connections
[07:45:57]
[07:45:57] + Processing work unit
[07:45:57] Core required: FahCore_11.exe
[07:45:57] Core found.
[07:45:57] Working on queue slot 06 [September 23 07:45:57 UTC]
[07:45:57] + Working ...
[07:45:57]
[07:45:57] *------------------------------*
[07:45:57] Folding@Home GPU Core - Beta
[07:45:57] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[07:45:57]
[07:45:57] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[07:45:57] Build host: amoeba
[07:45:57] Board Type: AMD
[07:45:57] Core      :
[07:45:57] Preparing to commence simulation
[07:45:57] - Looking at optimizations...
[07:45:57] - Created dyn
[07:45:57] - Files status OK
[07:45:57] - Expanded 70234 -> 360060 (decompressed 512.6 percent)
[07:45:57] Called DecompressByteArray: compressed_data_size=70234 data_size=360060, decompressed_data_size=360060 diff=0
[07:45:57] - Digital signature verified
[07:45:57]
[07:45:57] Project: 5741 (Run 1, Clone 16, Gen 502)
[07:45:57]
[07:45:57] Assembly optimizations on if available.
[07:45:57] Entering M.D.
[07:46:04] Tpr hash work/wudata_06.tpr:  859612253 4235038467 437682866 3888534315 1747312355
[07:46:04] Working on Protein
[07:46:05] Client config found, loading data.
[07:46:05] Starting GUI Server
[07:46:07] mdrun_gpu returned
[07:46:07] SHAKE violations on GPU
[07:46:07]
[07:46:07] Folding@home Core Shutdown: UNSTABLE_MACHINE
[07:46:10] CoreStatus = 7A (122)
[07:46:10] Sending work to server
[07:46:10] Project: 5741 (Run 1, Clone 16, Gen 502)
[07:46:10] - Read packet limit of 540015616... Set to 524286976.
[07:46:10] - Error: Could not get length of results file work/wuresults_06.dat
[07:46:10] - Error: Could not read unit 06 file. Removing from queue.
[07:46:10] - Preparing to get new work unit...
[07:46:10] + Attempting to get work packet
[07:46:10] - Connecting to assignment server
[07:46:11] - Successful: assigned to (171.64.65.102).
[07:46:11] + News From Folding@Home: Welcome to Folding@Home
[07:46:11] Loaded queue successfully.
[07:46:13] + Closed connections
[07:46:18]
[07:46:18] + Processing work unit
[07:46:18] Core required: FahCore_11.exe
[07:46:18] Core found.
[07:46:18] Working on queue slot 07 [September 23 07:46:18 UTC]
[07:46:18] + Working ...
[07:46:18]
[07:46:18] *------------------------------*
[07:46:18] Folding@Home GPU Core - Beta
[07:46:18] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[07:46:18]
[07:46:18] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[07:46:18] Build host: amoeba
[07:46:18] Board Type: AMD
[07:46:18] Core      :
[07:46:18] Preparing to commence simulation
[07:46:18] - Looking at optimizations...
[07:46:18] - Created dyn
[07:46:18] - Files status OK
[07:46:18] - Expanded 70234 -> 360060 (decompressed 512.6 percent)
[07:46:18] Called DecompressByteArray: compressed_data_size=70234 data_size=360060, decompressed_data_size=360060 diff=0
[07:46:18] - Digital signature verified
[07:46:18]
[07:46:18] Project: 5741 (Run 1, Clone 16, Gen 502)
[07:46:18]
[07:46:18] Assembly optimizations on if available.
[07:46:18] Entering M.D.
[07:46:24] Tpr hash work/wudata_07.tpr:  859612253 4235038467 437682866 3888534315 1747312355
[07:46:24] Working on Protein
[07:46:25] Client config found, loading data.
[07:46:25] Starting GUI Server
[07:46:28] mdrun_gpu returned
[07:46:28] SHAKE violations on GPU
[07:46:28]
[07:46:28] Folding@home Core Shutdown: UNSTABLE_MACHINE
[07:46:30] CoreStatus = 7A (122)
[07:46:30] Sending work to server
[07:46:30] Project: 5741 (Run 1, Clone 16, Gen 502)
[07:46:30] - Read packet limit of 540015616... Set to 524286976.
[07:46:30] - Error: Could not get length of results file work/wuresults_07.dat
[07:46:30] - Error: Could not read unit 07 file. Removing from queue.
[07:46:30] EUE limit exceeded. Pausing 24 hours.
valleton
Post by valleton »
I got this WU again. Too many failing WUs lately, very annoying, but not giving up yet.
Leinad112
Post by Leinad112 »
I got this WU again...
Can Panda remove this WU please, is just causing problems.... :?
Tynat
Post by Tynat »
Add me to the list.
All clients stopped due to Stanford's upcoming September 2011 decision
DrSpalding
Hardware configuration: Dell Studio 425 MTS-Core i7-920 c0 stock
evga SLI 3x o/c Core i7-920 d0 @ 3.9GHz + nVidia GTX275
Dell 5150 + nVidia 9800GT
Post by DrSpalding »
Ditto.
[22:21:24] *------------------------------*
[22:21:24] Folding@Home GPU Core - Beta
[22:21:24] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[22:21:24]
[22:21:24] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[22:21:24] Build host: amoeba
[22:21:24] Board Type: AMD
[22:21:24] Core      :
[22:21:24] Preparing to commence simulation
[22:21:24] - Looking at optimizations...
[22:21:24] - Created dyn
[22:21:24] - Files status OK
[22:21:24] - Expanded 70234 -> 360060 (decompressed 512.6 percent)
[22:21:24] Called DecompressByteArray: compressed_data_size=70234 data_size=360060, decompressed_data_size=360060 diff=0
[22:21:24] - Digital signature verified
[22:21:24]
[22:21:24] Project: 5741 (Run 1, Clone 16, Gen 502)
[22:21:24]
[22:21:24] Assembly optimizations on if available.
[22:21:24] Entering M.D.
[22:21:30] Tpr hash work/wudata_09.tpr:  859612253 4235038467 437682866 3888534315 1747312355
[22:21:30] Working on Protein
[22:21:31] Client config found, loading data.
[22:21:31] Starting GUI Server
[22:21:47] mdrun_gpu returned
[22:21:47] NANs detected on GPU
[22:21:47]
[22:21:47] Folding@home Core Shutdown: UNSTABLE_MACHINE
[22:21:51] CoreStatus = 7A (122)
[22:21:51] Sending work to server
[22:21:51] Project: 5741 (Run 1, Clone 16, Gen 502)
I ended up deleting the work directory files to get it to move on.
Not a real doctor, I just play one on the 'net!
mathwhiz
Post by mathwhiz »
This one popped up just now for me as well.
susato
Post by susato »
PM sent to the researcher. Thanks, everyone, for your reports.
FaaR
Post by FaaR »
Project bugs out immediately; computer is otherwise completely stable and all other projects run fine (except one other project that behaved the exact same way, which may or may not have been this one; it was weeks ago since it happened).
System:
Intel Core i7 920
AMD Radeon HD 4890
Windows Vista 64bit
Catalyst 9.9
                          http://folding.stanford.edu
Launch directory: C:\Users\Xxxxx\AppData\Roaming\Folding@home-gpu 2
Arguments: -gpu 1
[12:17:31] - Ask before connecting: No
[12:17:31] - User name: Kapten_Stofil (Team 37451)
[12:17:31] - User ID: 515773BF3A42AE54
[12:17:31] - Machine ID: 15
[12:17:31]
[12:17:31] Loaded queue successfully.
[12:17:31] Initialization complete
[12:17:31] - Preparing to get new work unit...
[12:17:31] + Attempting to get work packet
[12:17:31] - Connecting to assignment server
[12:17:32] - Successful: assigned to (171.64.65.102).
[12:17:32] + News From Folding@Home: Welcome to Folding@Home
[12:17:32] Loaded queue successfully.
[12:17:34] + Closed connections
[12:17:34]
[12:17:34] + Processing work unit
[12:17:34] Core required: FahCore_11.exe
[12:17:34] Core found.
[12:17:34] Working on queue slot 04 [October 26 12:17:34 UTC]
[12:17:34] + Working ...
[12:17:34]
[12:17:34] *------------------------------*
[12:17:34] Folding@Home GPU Core - Beta
[12:17:34] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[12:17:34]
[12:17:34] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:17:34] Build host: amoeba
[12:17:34] Board Type: AMD
[12:17:34] Core      :
[12:17:34] Preparing to commence simulation
[12:17:34] - Looking at optimizations...
[12:17:34] - Created dyn
[12:17:34] - Files status OK
[12:17:34] - Expanded 70234 -> 360060 (decompressed 512.6 percent)
[12:17:34] Called DecompressByteArray: compressed_data_size=70234 data_size=360060, decompressed_data_size=360060 diff=0
[12:17:34] - Digital signature verified
[12:17:34]
[12:17:34] Project: 5741 (Run 1, Clone 16, Gen 502)
[12:17:34]
[12:17:34] Assembly optimizations on if available.
[12:17:34] Entering M.D.
[12:17:40] Tpr hash work/wudata_04.tpr:  859612253 4235038467 437682866 3888534315 1747312355
[12:17:40] Working on Protein
[12:17:40] Client config found, loading data.
[12:17:40] Starting GUI Server
[12:17:53] mdrun_gpu returned
[12:17:53] NANs detected on GPU
[12:17:53]
[12:17:53] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:17:58] CoreStatus = 7A (122)
[12:17:58] Sending work to server
[12:17:58] Project: 5741 (Run 1, Clone 16, Gen 502)
[12:17:58] - Error: Could not get length of results file work/wuresults_04.dat
[12:17:58] - Error: Could not read unit 04 file. Removing from queue.
[12:17:58] - Preparing to get new work unit...
[12:17:58] + Attempting to get work packet
[12:17:58] - Connecting to assignment server
[12:17:59] - Successful: assigned to (171.64.65.102).
[12:17:59] + News From Folding@Home: Welcome to Folding@Home
[12:17:59] Loaded queue successfully.
[12:18:01] + Closed connections
[12:18:06]
[12:18:06] + Processing work unit
[12:18:06] Core required: FahCore_11.exe
[12:18:06] Core found.
[12:18:06] Working on queue slot 05 [October 26 12:18:06 UTC]
[12:18:06] + Working ...
[12:18:06]
[12:18:06] *------------------------------*
[12:18:06] Folding@Home GPU Core - Beta
[12:18:06] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[12:18:06]
[12:18:06] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:18:06] Build host: amoeba
[12:18:06] Board Type: AMD
[12:18:06] Core      :
[12:18:06] Preparing to commence simulation
[12:18:06] - Looking at optimizations...
[12:18:06] - Created dyn
[12:18:06] - Files status OK
[12:18:06] - Expanded 70234 -> 360060 (decompressed 512.6 percent)
[12:18:06] Called DecompressByteArray: compressed_data_size=70234 data_size=360060, decompressed_data_size=360060 diff=0
[12:18:06] - Digital signature verified
[12:18:06]
[12:18:06] Project: 5741 (Run 1, Clone 16, Gen 502)
[12:18:06]
[12:18:06] Assembly optimizations on if available.
[12:18:06] Entering M.D.
[12:18:12] Tpr hash work/wudata_05.tpr:  859612253 4235038467 437682866 3888534315 1747312355
[12:18:12] Working on Protein
[12:18:12] Client config found, loading data.
[12:18:12] Starting GUI Server
[12:18:25] mdrun_gpu returned
[12:18:25] NANs detected on GPU
[12:18:25]
[12:18:25] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:18:30] CoreStatus = 7A (122)
[12:18:30] Sending work to server
[12:18:30] Project: 5741 (Run 1, Clone 16, Gen 502)
[12:18:30] - Error: Could not get length of results file work/wuresults_05.dat
[12:18:30] - Error: Could not read unit 05 file. Removing from queue.
[12:18:30] - Preparing to get new work unit...
[12:18:30] + Attempting to get work packet
[12:18:30] - Connecting to assignment server
[12:18:31] - Successful: assigned to (171.64.65.102).
[12:18:31] + News From Folding@Home: Welcome to Folding@Home
[12:18:31] Loaded queue successfully.
[12:18:33] + Closed connections
[12:18:38]
[12:18:38] + Processing work unit
[12:18:38] Core required: FahCore_11.exe
[12:18:38] Core found.
[12:18:38] Working on queue slot 06 [October 26 12:18:38 UTC]
[12:18:38] + Working ...
[12:18:38]
[12:18:38] *------------------------------*
[12:18:38] Folding@Home GPU Core - Beta
[12:18:38] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[12:18:38]
[12:18:38] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:18:38] Build host: amoeba
[12:18:38] Board Type: AMD
[12:18:38] Core      :
[12:18:38] Preparing to commence simulation
[12:18:38] - Looking at optimizations...
[12:18:38] - Created dyn
[12:18:38] - Files status OK
[12:18:38] - Expanded 70234 -> 360060 (decompressed 512.6 percent)
[12:18:38] Called DecompressByteArray: compressed_data_size=70234 data_size=360060, decompressed_data_size=360060 diff=0
[12:18:38] - Digital signature verified
[12:18:38]
[12:18:38] Project: 5741 (Run 1, Clone 16, Gen 502)
[12:18:38]
[12:18:38] Assembly optimizations on if available.
[12:18:38] Entering M.D.
[12:18:44] Tpr hash work/wudata_06.tpr:  859612253 4235038467 437682866 3888534315 1747312355
[12:18:44] Working on Protein
[12:18:44] Client config found, loading data.
[12:18:44] Starting GUI Server
[12:18:57] mdrun_gpu returned
[12:18:57] NANs detected on GPU
[12:18:57]
[12:18:57] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:19:04] CoreStatus = 7A (122)
[12:19:04] Sending work to server
[12:19:04] Project: 5741 (Run 1, Clone 16, Gen 502)
[12:19:04] - Error: Could not get length of results file work/wuresults_06.dat
[12:19:04] - Error: Could not read unit 06 file. Removing from queue.
[12:19:04] - Preparing to get new work unit...
[12:19:04] + Attempting to get work packet
[12:19:04] - Connecting to assignment server
[12:19:04] - Successful: assigned to (171.64.65.102).
[12:19:04] + News From Folding@Home: Welcome to Folding@Home
[12:19:05] Loaded queue successfully.
[12:19:07] + Closed connections
[12:19:12]
[12:19:12] + Processing work unit
[12:19:12] Core required: FahCore_11.exe
[12:19:12] Core found.
[12:19:12] Working on queue slot 07 [October 26 12:19:12 UTC]
[12:19:12] + Working ...
[12:19:12]
[12:19:12] *------------------------------*
[12:19:12] Folding@Home GPU Core - Beta
[12:19:12] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[12:19:12]
[12:19:12] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:19:12] Build host: amoeba
[12:19:12] Board Type: AMD
[12:19:12] Core      :
[12:19:12] Preparing to commence simulation
[12:19:12] - Looking at optimizations...
[12:19:12] - Created dyn
[12:19:12] - Files status OK
[12:19:12] - Expanded 70234 -> 360060 (decompressed 512.6 percent)
[12:19:12] Called DecompressByteArray: compressed_data_size=70234 data_size=360060, decompressed_data_size=360060 diff=0
[12:19:12] - Digital signature verified
[12:19:12]
[12:19:12] Project: 5741 (Run 1, Clone 16, Gen 502)
[12:19:12]
[12:19:12] Assembly optimizations on if available.
[12:19:12] Entering M.D.
[12:19:18] Tpr hash work/wudata_07.tpr:  859612253 4235038467 437682866 3888534315 1747312355
[12:19:18] Working on Protein
[12:19:18] Client config found, loading data.
[12:19:18] Starting GUI Server
[12:19:32] mdrun_gpu returned
[12:19:32] NANs detected on GPU
[12:19:32]
[12:19:32] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:19:36] CoreStatus = 7A (122)
[12:19:36] Sending work to server
[12:19:36] Project: 5741 (Run 1, Clone 16, Gen 502)
[12:19:36] - Error: Could not get length of results file work/wuresults_07.dat
[12:19:36] - Error: Could not read unit 07 file. Removing from queue.
[12:19:36] - Preparing to get new work unit...
[12:19:36] + Attempting to get work packet
[12:19:36] - Connecting to assignment server
[12:19:37] - Successful: assigned to (171.64.65.102).
[12:19:37] + News From Folding@Home: Welcome to Folding@Home
[12:19:37] Loaded queue successfully.
[12:19:39] + Closed connections
[12:19:44]
[12:19:44] + Processing work unit
[12:19:44] Core required: FahCore_11.exe
[12:19:44] Core found.
[12:19:44] Working on queue slot 08 [October 26 12:19:44 UTC]
[12:19:44] + Working ...
[12:19:44]
[12:19:44] *------------------------------*
[12:19:44] Folding@Home GPU Core - Beta
[12:19:44] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[12:19:44]
[12:19:44] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:19:44] Build host: amoeba
[12:19:44] Board Type: AMD
[12:19:44] Core      :
[12:19:44] Preparing to commence simulation
[12:19:44] - Looking at optimizations...
[12:19:44] - Created dyn
[12:19:44] - Files status OK
[12:19:44] - Expanded 70234 -> 360060 (decompressed 512.6 percent)
[12:19:44] Called DecompressByteArray: compressed_data_size=70234 data_size=360060, decompressed_data_size=360060 diff=0
[12:19:44] - Digital signature verified
[12:19:44]
[12:19:44] Project: 5741 (Run 1, Clone 16, Gen 502)
[12:19:44]
[12:19:44] Assembly optimizations on if available.
[12:19:44] Entering M.D.
[12:19:50] Tpr hash work/wudata_08.tpr:  859612253 4235038467 437682866 3888534315 1747312355
[12:19:50] Working on Protein
[12:19:50] Client config found, loading data.
[12:19:50] Starting GUI Server
[12:20:04] mdrun_gpu returned
[12:20:04] NANs detected on GPU
[12:20:04]
[12:20:04] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:20:08] CoreStatus = 7A (122)
[12:20:08] Sending work to server
[12:20:08] Project: 5741 (Run 1, Clone 16, Gen 502)
[12:20:08] - Error: Could not get length of results file work/wuresults_08.dat
[12:20:08] - Error: Could not read unit 08 file. Removing from queue.
[12:20:08] EUE limit exceeded. Pausing 24 hours.
Leoslocks
Hardware configuration: Q6600 | P35-DQ6 | Crucial 2 x 1 GB ram | VisionTek 3870
GPU2 Version 6.20| CPU three 6.20 Clients
Post by Leoslocks »
Restarting the client may get you a different WU after multiple EUEs.
bollix47
Post by bollix47 »
It's a known bad WU:
viewtopic.php?f=19&t=11462
EDIT by Mod: Threads merged.
FaaR
Post by FaaR »
Yeah, I noticed the other thread after I had already made this one.
Question arises though, if it's already known to be bad since quite a while, why is it still being sent out again and again?
FaaR wrote:Yeah, I noticed the other thread after I had already made this one.
There's a server feature that is supposed to eliminates a WU after a certain number of errors but it doesn't always act as fast as most of us would like it to. It has to retry a WU a certain number of times to allow for that fact that it can't tell whether your hardware was unstable or the WU itself was unstable.
Sometimes when the automatic feature doesn't kick in, the WUs get removed manually by the project owner. I'll notify him.
vvoelz
Pande Group Member
Post by vvoelz »
I've killed this project from further assignments. (WUs still out in the world will be accepted, though).
--Vince
