I lost all my points!
Xamonas Chegwé
Post by Xamonas Chegwé »
Hi there. Sorry to start off my posting here with a moan! But I just joined a team - by adding the team number to my preferences - and now my stats have been completely zeroed!! I was ranked at about 80,000 with something like 160 WUs to my name and now I have nothing - in my personal stats as well as in my team stats!
What's going on here? Is this just a temporary thing? Or have I lost all that credit? :eo
Re: I lost all my points!
A returned WU is associated to a Username/Teamnumber combination once and for all. If you change something in the combination, you'll start from scratch (but previous WU are still registered under your old combination).
Xamonas Chegwé
toTOW wrote:A returned WU is associated to a Username/Teamnumber combination once and for all. If you change something in the combination, you'll start from scratch (but previous WU are still registered under your old combination).
Thanks. I think I get it. So if I changed my team back to default, I would see all the points / WUs that I have already done?
susato
Post by susato »
If you go to Stanford's donor stats page and type in your donor name you will see a separate entry for each team you have belonged to.
Xamonas Chegwé
Thanks a lot - although the stats page seems to be down for an update. i will look later. :D
Xamonas Chegwé
I see it now. Thanks susato
