lost WU
midnytwarrior
Hardware configuration: MB: ASUS Rampage V Edition 10
CPU: i7 6850k
RAM: Corsair DDR4-3000 4x4GB
VGA: GTX 1080 x 2
HDD: 2 x 2TB WD Caviar Black, 1TB WD Caviar Black
PSU: EVGA 1600G2
OS: Windows 10 Pro 64-Bit
lost WU
Post by midnytwarrior »
Hi! is there a possibility that 2 finished WU uploaded together at the same time be considered as 1? The first WU finished at slot#4 while the 2nd WU finished at slot #5 was uploaded leaving slot #4 on queue. After WU on slot # 6 finished, and uploaded, the info on slot # 4 said that it was also uploaded (empty/deleted) knowing that the WU in slot #4 was uploaded along with the WU at slot #6 but when I checked my stats, a WU was missing. Is there any way to get a "score" or "point" on this one, or shall we put "a hard days work unit" out of the counting?
--- Opening Log file [July 8 18:44:25 UTC]
                          http://folding.stanford.edu
Launch directory: C:\Users\b0cHn01\AppData\Roaming\Folding@home-gpu
[18:44:25] - Ask before connecting: Yes
[18:44:25] - User name: midnytwarrior (Team 2291)
[18:44:25] - User ID: 31AE61B12B279073
[18:44:25] - Machine ID: 1
[18:44:25]
[18:44:25] Loaded queue successfully.
[18:44:25] Deleting incompletely fetched item (4) from queue position #6
[18:44:25] Initialization complete
[18:44:25] - Preparing to get new work unit...
[18:44:25] - Presenting message box asking to network.
[18:44:25] Project: 5735 (Run 2, Clone 75, Gen 222)
[18:44:25] - Read packet limit of 540015616... Set to 524286976.
[18:44:25] + Attempting to send results [July 8 18:44:25 UTC]
[18:45:29] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=2291...
[18:45:57] - Couldn't send HTTP request to server
[18:45:57] + Could not connect to Work Server (results)
[18:45:57]     (171.64.65.102:8080)
[18:45:57] + Retrying using alternative port
[18:45:57]     (171.64.65.102:80)
[18:45:57] - Error: Could not transmit unit 04 (completed July 7) to work server.
[18:45:57] - Read packet limit of 540015616... Set to 524286976.
[18:45:57] + Attempting to send results [July 8 18:45:57 UTC]
[18:45:57]     (171.67.108.17:8080)
[18:45:57]     (171.67.108.17:80)
[18:45:57]   Could not transmit unit 04 to Collection server; keeping in queue.
[18:46:15] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=2291...
[18:47:41] + Attempting to get work packet
[18:47:41] - Connecting to assignment server
[18:47:44] - Successful: assigned to (171.64.65.102).
[18:47:44] + News From Folding@Home: Welcome to Folding@Home
[18:47:44] Loaded queue successfully.
[18:47:48] + Connections closed: You may now disconnect
[18:47:48]
[18:47:48] + Processing work unit
[18:47:48] Core required: FahCore_11.exe
[18:47:48] Core found.
[18:47:48] Working on queue slot 06 [July 8 18:47:48 UTC]
[18:47:48] + Working ...
[18:47:48]
[18:47:48] *------------------------------*
[18:47:48] Folding@Home GPU Core - Beta
[18:47:48] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[18:47:48]
[18:47:48] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[18:47:48] Build host: amoeba
[18:47:48] Board Type: AMD
[18:47:48] Core      :
[18:47:48] Preparing to commence simulation
[18:47:48] - Looking at optimizations...
[18:47:48] - Created dyn
[18:47:48] - Files status OK
[18:47:48] - Expanded 70042 -> 360060 (decompressed 514.0 percent)
[18:47:48] Called DecompressByteArray: compressed_data_size=70042 data_size=360060, decompressed_data_size=360060 diff=0
[18:47:48] - Digital signature verified
[18:47:48]
[18:47:48] Project: 5741 (Run 4, Clone 77, Gen 280)
[18:47:48]
[18:47:48] Assembly optimizations on if available.
[18:47:48] Entering M.D.
[18:47:54] Tpr hash work/wudata_06.tpr:  1157468733 2443797951 3461051252 162867767 4042067788
[18:47:54] Working on Protein
[18:47:54] Client config found, loading data.
[18:47:54] Starting GUI Server
[18:49:08] Printing Queue Information
Current Queue:
Slot 07  Empty/Deleted
Project: 5745 (Run 2, Clone 32, Gen 309), Core: 11
Work server: 171.64.65.102:8080
Collection server: 171.67.108.17
Download date: June 30 05:16:06
Finished date: June 30 22:24:43
Slot 08  Empty/Deleted
Project: 5740 (Run 1, Clone 6, Gen 341), Core: 11
Download date: June 30 22:28:30
Finished date: July 1 03:03:49
Slot 09  Empty/Deleted
Project: 5739 (Run 2, Clone 70, Gen 184), Core: 11
Download date: July 1 05:11:24
Finished date: July 2 02:00:12
Slot 00  Empty/Deleted
Project: 5733 (Run 1, Clone 47, Gen 197), Core: 11
Download date: July 2 04:17:14
Finished date: July 3 05:39:35
Slot 01  Empty/Deleted
Project: 5744 (Run 1, Clone 20, Gen 342), Core: 11
Download date: July 3 06:07:04
Finished date: July 3 17:53:42
Failed uploads: 3
Slot 02  Empty/Deleted
Project: 5734 (Run 1, Clone 4, Gen 253), Core: 11
Download date: July 4 04:08:37
Finished date: July 5 03:38:29
Slot 03  Empty/Deleted
Project: 5743 (Run 1, Clone 28, Gen 315), Core: 11
Download date: July 5 06:16:13
Finished date: July 6 01:19:03
Slot 04  Done
Project: 5735 (Run 2, Clone 75, Gen 222), Core: 11
Download date: July 6 05:00:13
Finished date: July 7 05:28:21
Failed uploads: 7
Slot 05  Empty/Deleted
Project: 5743 (Run 1, Clone 24, Gen 256), Core: 11
Download date: July 7 05:42:47
Finished date: July 8 02:44:42
Failed uploads: 3
Slot 06 *Active
Project: 5741 (Run 4, Clone 77, Gen 280), Core: 11
Download date: July 8 18:47:48
Deadline date: July 11 18:47:48
PF: 0.730033 based on last 4 slot(s)
[18:50:43] Completed 1%
[18:53:30] Completed 2%
[18:56:16] Completed 3%
[18:58:22] + Paused
--- Opening Log file [July 8 22:24:04 UTC]
[22:24:04] - Ask before connecting: Yes
[22:24:04] - User name: midnytwarrior (Team 2291)
[22:24:04] - User ID: 31AE61B12B279073
[22:24:04] - Machine ID: 1
[22:24:04]
[22:24:04] Loaded queue successfully.
[22:24:04] Initialization complete
[22:24:04]
[22:24:04] + Processing work unit
[22:24:04] Project: 5735 (Run 2, Clone 75, Gen 222)
[22:24:04] - Read packet limit of 540015616... Set to 524286976.
[22:24:04] + Attempting to send results [July 8 22:24:04 UTC]
[22:24:04] Core required: FahCore_11.exe
[22:24:04] Core found.
[22:24:04] - Presenting message box asking to network.
[22:24:04] Working on queue slot 06 [July 8 22:24:04 UTC]
[22:24:04] + Working ...
[22:24:04]
[22:24:04] *------------------------------*
[22:24:04] Folding@Home GPU Core - Beta
[22:24:04] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[22:24:04]
[22:24:04] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[22:24:04] Build host: amoeba
[22:24:04] Board Type: AMD
[22:24:04] Core      :
[22:24:04] Preparing to commence simulation
[22:24:04] - Ensuring status. Please wait.
[22:24:14] - Looking at optimizations...
[22:24:14] - Working with standard loops on this execution.
[22:24:14] - Previous termination of core was improper.
[22:24:14] - Files status OK
[22:24:14] - Expanded 70042 -> 360060 (decompressed 514.0 percent)
[22:24:14] Called DecompressByteArray: compressed_data_size=70042 data_size=360060, decompressed_data_size=360060 diff=0
[22:24:14] - Digital signature verified
[22:24:14]
[22:24:14] Project: 5741 (Run 4, Clone 77, Gen 280)
[22:24:14]
[22:24:14] Entering M.D.
[22:24:20] Will resume from checkpoint file
[22:24:20] Tpr hash work/wudata_06.tpr:  1157468733 2443797951 3461051252 162867767 4042067788
[22:24:21] Working on Protein
[22:24:21] Client config found, loading data.
[22:24:21] Starting GUI Server
[22:24:23] Resuming from checkpoint
[22:24:23] fcCheckPointResume: retreived and current tpr file hash:
[22:24:23]    0   1157468733   1157468733
[22:24:23]    1   2443797951   2443797951
[22:24:23]    2   3461051252   3461051252
[22:24:23]    3    162867767    162867767
[22:24:23]    4   4042067788   4042067788
[22:24:23] Verified work/wudata_06.log
[22:24:23] Verified work/wudata_06.edr
[22:24:23] Verified work/wudata_06.xtc
[22:24:23] Completed 3%
[22:25:28] - Couldn't send HTTP request to server
[22:25:28] + Could not connect to Work Server (results)
[22:25:28]     (171.64.65.102:8080)
[22:25:28] + Retrying using alternative port
[22:26:06] Printing Queue Information
Current Queue:
Failed uploads: 3
Slot 04  Done
Failed uploads: 7
Failed uploads: 3
Slot 06 *Active
[22:26:22] Opening http://foldingforum.org/...
[22:26:39] - Couldn't send HTTP request to server
[22:26:39] + Could not connect to Work Server (results)
[22:26:39]     (171.64.65.102:80)
[22:26:39] - Error: Could not transmit unit 04 (completed July 7) to work server.
[22:26:39] - Read packet limit of 540015616... Set to 524286976.
[22:26:39] + Attempting to send results [July 8 22:26:39 UTC]
[22:27:00] - Couldn't send HTTP request to server
[22:27:00] + Could not connect to Work Server (results)
[22:27:00]     (171.67.108.17:8080)
[22:27:00] + Retrying using alternative port
[22:27:09] Completed 4%
[22:27:49] - Couldn't send HTTP request to server
[22:27:49] + Could not connect to Work Server (results)
[22:27:49]     (171.67.108.17:80)
[22:27:49]   Could not transmit unit 04 to Collection server; keeping in queue.
[22:29:56] Completed 5%
[22:32:42] Completed 6%
[22:35:27] Completed 7%
[22:38:12] Completed 8%
[22:40:57] Completed 9%
[22:43:41] Completed 10%
[22:46:24] Completed 11%
[22:49:08] Completed 12%
[22:51:51] Completed 13%
[22:54:35] Completed 14%
[22:57:18] Completed 15%
[23:00:01] Completed 16%
[23:02:45] Completed 17%
[23:05:28] Completed 18%
[23:08:11] Completed 19%
[23:10:55] Completed 20%
[23:13:39] Completed 21%
[23:16:22] Completed 22%
[23:19:05] Completed 23%
[23:21:49] Completed 24%
[23:24:32] Completed 25%
[23:27:16] Completed 26%
[23:29:59] Completed 27%
[23:32:43] Completed 28%
[23:35:25] Completed 29%
[23:38:09] Completed 30%
[23:40:53] Completed 31%
[23:43:36] Completed 32%
[23:46:20] Completed 33%
[23:49:03] Completed 34%
[23:51:46] Completed 35%
[23:54:30] Completed 36%
[23:57:13] Completed 37%
[23:59:57] Completed 38%
[00:02:42] Completed 39%
[00:05:26] Completed 40%
[00:08:09] Completed 41%
[00:10:53] Completed 42%
[00:13:38] Completed 43%
[00:16:24] Completed 44%
[00:19:08] Completed 45%
[00:21:52] Completed 46%
[00:24:35] Completed 47%
[00:27:18] Completed 48%
[00:30:01] Completed 49%
[00:32:45] Completed 50%
[00:35:28] Completed 51%
[00:38:11] Completed 52%
[00:40:55] Completed 53%
[00:43:37] Completed 54%
[00:46:20] Completed 55%
[00:49:04] Completed 56%
[00:51:47] Completed 57%
[00:54:30] Completed 58%
[00:57:14] Completed 59%
[00:59:56] Completed 60%
[01:02:40] Completed 61%
[01:05:23] Completed 62%
[01:08:06] Completed 63%
[01:10:50] Completed 64%
[01:13:33] Completed 65%
[01:16:16] Completed 66%
[01:18:59] Completed 67%
[01:21:42] Completed 68%
[01:24:25] Completed 69%
[01:27:09] Completed 70%
[01:29:52] Completed 71%
[01:32:35] Completed 72%
[01:35:18] Completed 73%
[01:38:01] Completed 74%
[01:40:44] Completed 75%
[01:43:27] Completed 76%
[01:46:11] Completed 77%
[01:48:54] Completed 78%
[01:51:37] Completed 79%
[01:54:20] Completed 80%
[01:57:03] Completed 81%
[01:59:47] Completed 82%
[02:02:30] Completed 83%
[02:05:13] Completed 84%
[02:07:56] Completed 85%
[02:10:39] Completed 86%
[02:13:23] Completed 87%
[02:16:06] Completed 88%
[02:18:49] Completed 89%
[02:21:33] Completed 90%
[02:24:15] Completed 91%
[02:26:59] Completed 92%
[02:29:42] Completed 93%
[02:32:25] Completed 94%
[02:35:08] Completed 95%
[02:37:52] Completed 96%
[02:40:34] Completed 97%
[02:43:18] Completed 98%
[02:46:01] Completed 99%
[02:48:44] Completed 100%
[02:48:44] Successful run
[02:48:44] DynamicWrapper: Finished Work Unit: sleep=10000
[02:48:54] Reserved 154080 bytes for xtc file; Cosm status=0
[02:48:54] Allocated 154080 bytes for xtc file
[02:48:54] - Reading up to 154080 from "work/wudata_06.xtc": Read 154080
[02:48:54] Read 154080 bytes from xtc file; available packet space=786276384
[02:48:54] xtc file hash check passed.
[02:48:54] Reserved 23472 23472 786276384 bytes for arc file=<work/wudata_06.trr> Cosm status=0
[02:48:54] Allocated 23472 bytes for arc file
[02:48:54] - Reading up to 23472 from "work/wudata_06.trr": Read 23472
[02:48:54] Read 23472 bytes from arc file; available packet space=786252912
[02:48:54] trr file hash check passed.
[02:48:54] Allocated 560 bytes for edr file
[02:48:54] Read bedfile
[02:48:54] edr file hash check passed.
[02:48:54] Allocated 24310 bytes for logfile
[02:48:54] Read logfile
[02:48:54] GuardedRun: success in DynamicWrapper
[02:48:54] GuardedRun: done
[02:48:54] Run: GuardedRun completed.
[02:48:58] - Writing 202934 bytes of core data to disk...
[02:48:58] Done: 202422 -> 185117 (compressed to 91.4 percent)
[02:48:58]   ... Done.
[02:48:58] - Shutting down core
[02:48:58]
[02:48:58] Folding@home Core Shutdown: FINISHED_UNIT
[02:49:01] CoreStatus = 64 (100)
[02:49:01] Sending work to server
[02:49:01] Project: 5741 (Run 4, Clone 77, Gen 280)
[02:49:01] - Read packet limit of 540015616... Set to 524286976.
[02:49:01] + Attempting to send results [July 9 02:49:01 UTC]
[02:49:01] - Couldn't send HTTP request to server
[02:49:01] + Could not connect to Work Server (results)
[02:49:01]     (171.64.65.102:8080)
[02:49:01] + Retrying using alternative port
[02:49:01]     (171.64.65.102:80)
[02:49:01] - Error: Could not transmit unit 06 (completed July 9) to work server.
[02:49:01]   Keeping unit 06 in queue.
[02:49:01] Project: 5735 (Run 2, Clone 75, Gen 222)
[02:49:01] - Error: Could not transmit unit 04 (completed July 7) to work server.
[02:49:01]     (171.67.108.17:8080)
[02:49:01]     (171.67.108.17:80)
[02:49:01]   Could not transmit unit 04 to Collection server; keeping in queue.
[02:49:01]   Could not transmit unit 06 to Collection server; keeping in queue.
[02:49:01] + Connections closed: You may now disconnect
[02:49:01] + Paused after finishing unit
[05:58:51] - Preparing to get new work unit...
[05:58:51] - Presenting message box asking to network.
[05:58:52] + Attempting to get work packet
[05:58:52] - Connecting to assignment server
[05:59:24] - Successful: assigned to (171.64.65.102).
[05:59:24] + News From Folding@Home: Welcome to Folding@Home
[05:59:24] Loaded queue successfully.
[05:59:48] Printing Queue Information
Current Queue:
Slot 07  Fetching
Failed uploads: 3
Slot 04  Done
Failed uploads: 9
Failed uploads: 3
Slot 06 *Done
Finished date: July 9 02:49:01
Failed uploads: 2
PF: 0.761748 based on last 4 slot(s)
[05:59:52] Project: 5735 (Run 2, Clone 75, Gen 222)
[05:59:52] - Read packet limit of 540015616... Set to 524286976.
[05:59:52] + Attempting to send results [July 9 05:59:52 UTC]
[06:03:14] - Couldn't send HTTP request to server
[06:03:14] + Could not connect to Work Server (results)
[06:03:14]     (171.64.65.102:8080)
[06:03:14] + Retrying using alternative port
[06:03:14]     (171.64.65.102:80)
[06:03:14] - Error: Could not transmit unit 04 (completed July 7) to work server.
[06:03:14] - Read packet limit of 540015616... Set to 524286976.
[06:03:14] + Attempting to send results [July 9 06:03:14 UTC]
[06:03:14]     (171.67.108.17:8080)
[06:03:14]     (171.67.108.17:80)
[06:03:14]   Could not transmit unit 04 to Collection server; keeping in queue.
[06:03:14] Project: 5741 (Run 4, Clone 77, Gen 280)
[06:03:14] - Error: Could not transmit unit 06 (completed July 9) to work server.
[06:03:14]   Could not transmit unit 06 to Collection server; keeping in queue.
[06:03:14] + Connections closed: You may now disconnect
[06:03:14]
[06:03:14] + Processing work unit
[06:03:14] Core required: FahCore_11.exe
[06:03:14] Core found.
[06:03:14] Working on queue slot 07 [July 9 06:03:14 UTC]
[06:03:14] + Working ...
[06:03:14]
[06:03:14] *------------------------------*
[06:03:14] Folding@Home GPU Core - Beta
[06:03:14] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[06:03:14]
[06:03:14] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[06:03:14] Build host: amoeba
[06:03:14] Board Type: AMD
[06:03:14] Core      :
[06:03:14] Preparing to commence simulation
[06:03:14] - Looking at optimizations...
[06:03:14] - Created dyn
[06:03:14] - Files status OK
[06:03:14] - Expanded 98672 -> 492188 (decompressed 498.8 percent)
[06:03:14] Called DecompressByteArray: compressed_data_size=98672 data_size=492188, decompressed_data_size=492188 diff=0
[06:03:14] - Digital signature verified
[06:03:14]
[06:03:14] Project: 5735 (Run 1, Clone 49, Gen 217)
[06:03:14]
[06:03:14] Assembly optimizations on if available.
[06:03:14] Entering M.D.
[06:03:20] Tpr hash work/wudata_07.tpr:  676152276 3073962154 3957176105 3697332915 449708859
[06:03:20] Working on Protein
[06:03:20] Client config found, loading data.
[06:03:20] Starting GUI Server
--- Opening Log file [July 9 06:15:27 UTC]
[06:15:27] - Ask before connecting: Yes
[06:15:27] - User name: midnytwarrior (Team 2291)
[06:15:27] - User ID: 31AE61B12B279073
[06:15:27] - Machine ID: 1
[06:15:27]
[06:15:27] Loaded queue successfully.
[06:15:27] Initialization complete
[06:15:27] Unit 4's deadline (July 9 05:00) has passed.
[06:15:39]
[06:15:39] + Processing work unit
[06:15:39] Project: 5741 (Run 4, Clone 77, Gen 280)
[06:15:39] - Read packet limit of 540015616... Set to 524286976.
[06:15:39] + Attempting to send results [July 9 06:15:39 UTC]
[06:15:39] Core required: FahCore_11.exe
[06:15:39] Core found.
[06:15:39] Working on queue slot 07 [July 9 06:15:39 UTC]
[06:15:39] + Working ...
[06:15:39] - Presenting message box asking to network.
[06:15:39]
[06:15:39] *------------------------------*
[06:15:39] Folding@Home GPU Core - Beta
[06:15:39] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[06:15:39]
[06:15:39] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[06:15:39] Build host: amoeba
[06:15:39] Board Type: AMD
[06:15:39] Core      :
[06:15:39] Preparing to commence simulation
[06:15:39] - Looking at optimizations...
[06:15:39] - Previous termination of core was improper.
[06:15:39] - Files status OK
[06:15:39] - Expanded 98672 -> 492188 (decompressed 498.8 percent)
[06:15:39] Called DecompressByteArray: compressed_data_size=98672 data_size=492188, decompressed_data_size=492188 diff=0
[06:15:39] - Digital signature verified
[06:15:39]
[06:15:39] Project: 5735 (Run 1, Clone 49, Gen 217)
[06:15:39]
[06:15:39] Entering M.D.
[06:15:45] Will resume from checkpoint file
[06:15:45] Tpr hash work/wudata_07.tpr:  676152276 3073962154 3957176105 3697332915 449708859
[06:15:45] Working on Protein
[06:15:46] Client config found, loading data.
[06:15:46] Starting GUI Server
[06:15:48] Resuming from checkpoint
[06:15:48] fcCheckPointResume: retreived and current tpr file hash:
[06:15:48]    0    676152276    676152276
[06:15:48]    1   3073962154   3073962154
[06:15:48]    2   3957176105   3957176105
[06:15:48]    3   3697332915   3697332915
[06:15:48]    4    449708859    449708859
[06:15:48] Verified work/wudata_07.log
[06:15:48] Verified work/wudata_07.edr
[06:15:48] Verified work/wudata_07.xtc
[06:16:02] - Couldn't send HTTP request to server
[06:16:02] + Could not connect to Work Server (results)
[06:16:02]     (171.64.65.102:8080)
[06:16:02] + Retrying using alternative port
[06:16:53] + Results successfully sent
[06:16:53] Thank you for your contribution to Folding@Home.
[06:16:53] + Number of Units Completed: 100
[06:19:36] Printing Queue Information
Current Queue:
Failed uploads: 3
Slot 04  Empty/Deleted
Failed uploads: 3
Slot 06  Empty/Deleted
Failed uploads: 3
Slot 07 *Ready
Project: 5735 (Run 1, Clone 49, Gen 217), Core: 11
Download date: July 9 05:59:52
Deadline date: July 12 05:59:52
[06:19:48] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=2291...
[06:20:03] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=midnytwarrior...
susato
Re: lost WU
Post by susato »
Hello midnytwarrior,
I checked in the CPU database which shows the last WU returned from each of a donor's machines. It only shows PS3 units for you. Your GPU units don't seem to be getting through at all.
Your log has a lot of statements of the type
and
I suggest that you try posting this issue in the GPU folding subforum for NVidia or ATI issues depending on what card you are using. That's where the experts are. Since the problem seems to happen repeatedly, it's probably not a question of bad work units, but a software setting or networking problem.
midnytwarrior
CPU: i7 6850k
VGA: GTX 1080 x 2
PSU: EVGA 1600G2
Re: lost WU
Sir, did you mean by PS3 as in Play Station 3? I'm sorry but I don't have any PS3 consoles here. Nor I'm planning to use one.
For now, I'm using 2 machines, 1st is a Q9650 coupled with an ATI 3870X2, and the other one is a Q6600 and an ATI 4670.
As i was not having problems with my GPU, or my network but the way the WU just disappeared entirely.
If it was about bad units, maybe a WU error could have been reported, OS or software settings are the same which I had been using day after day, WU after WU for both of my machines. Network is also very much the same the way I had been using the net and sending and downloading WU every time.
So now we are talking about a lost WU. If so,please kindly advise me to open this topic in another subforum where you may find it suitable.
Thank you
susato
Re: lost WU
Post by susato »
Sorry for the misunderstanding. The "User's Last WU" database characterized your equipment as PS3 rather than GPU, which is why I responded as I did. Thanks for clarifying.
Here's the portion of your FAHlog which describes the fate of your missing WU.
[06:15:39]
Unfortunately, by the time that work unit was sent back to Stanford, it had passed its final deadline and was no longer eligible for points. The problem was probably associated with server downtime: if you look in the server log of the 171.64.65.102 server assigning p5735 WU's, it was in reject mode for part of July 7 and the collection server was very busy during that time, accounting for the multiple upload failures.
I"m sorry that you'll have to write off that WU at least in terms of the points. It can still be valuable to the science if it failed to complete, or went over deadline, on its subsequent assignment.
midnytwarrior
CPU: i7 6850k
VGA: GTX 1080 x 2
PSU: EVGA 1600G2
Re: lost WU
what's the purpose of this http://fah-web.stanford.edu/serverstat.html anyway? if in your "server log" says that it wasn't accepting and the server stats say they are?
sorry? -that's it?
well at least you could have counted in the WU even without the points. since they'll still be of some use for the "science".
or maybe you could bring in more "science" to keep your servers up
Re: lost WU
The purpost of the Server Status page is to help Contributors to the project help themselves. If I have a work unit that isn't uploading to 171.65.103.158, then I can go check that page, and see that server is currently down.
But please note, that server status page is not live data. It's a snap shot of the data taken every 15 minutes, and a lot can change in that amount of time.
midnytwarrior
CPU: i7 6850k
VGA: GTX 1080 x 2
PSU: EVGA 1600G2
Re: lost WU
7im wrote: But please note, that server status page is not live data. It's a snap shot of the data taken every 15 minutes, and a lot can change in that amount of time.
I viewed the page not only once or twice when trying to upload the WU. Plus, the WU on slot # 5 was collected by the same server as the WU on slot #4 and just entirely left WU on #4
while accepting WU in #5
Re: lost WU
Please note susato's comment above. WU in slot #4 expired before it could be uploaded. Once expired, there is no benefit to uploading.
midnytwarrior
CPU: i7 6850k
VGA: GTX 1080 x 2
PSU: EVGA 1600G2
Re: lost WU
Is there something we could do or could be done to avoid this things? Honestly, it's kind of frustrating to see one's hard work or "hard earned" work becomes non beneficial?
Re: lost WU
midnytwarrior wrote:Is there something we could do or could be done to avoid this things? Honestly, it's kind of frustrating to see one's hard work or "hard earned" work becomes non beneficial?
I understand your frustration.
This isn't something that comes up very often. The portions of the process that are under your control are things that happen from the moment that a WU is downloaded until processing is complete and how that compares to the deadlines for the projects that you process. The portions of the process that are not under your control are those issues associated with server down-time.
If you have slow hardware or you only fold a limited number of hours per day, you can decide whether there's something that needs to be changed. If the server is down, the Pande Group will attempt to get the server back on-line as soon as possible. There is redundancy built into the process since generally speaking any WU can be uploaded to either the Work Server or the Collection Server and (presuming that nothing is blocking the upload on your system) that both attempts are made at least every 6 hours.
Running an advanced client (GPU or SMP) rather than the CPU client does expose you to added risks including short deadlines. That's one reason those clients earn higher points. The CPU client has much, much longer deadlines and I believe I can guarantee that those people who choose to run the CPU client a reasonable number of hours per week on any relatively modern computer will never miss a deadline. Only you can choose which client(s) best fit your style.
midnytwarrior
CPU: i7 6850k
VGA: GTX 1080 x 2
PSU: EVGA 1600G2
Re: lost WU
fits my lifestyle? Or fits the server's lifestyle?
Re: lost WU
With some people, there is no difference. ;) With some, they are very intertwined, as the server runs in the bedroom, and is too loud for a person to sleep, the contributor and computer must sleep at the same time. With some, it's a very loose interaction. Might be the cost of running the server 24/7 is too expensive to maintain your current lifestyle.
Any way you cut it, the server needs to run enough hours per day to complete a work unit before the deadline. If that is not possible for a client with short deadlines (GPU or SMP) then a client like the CPU client, which has more relaxed deadlines would better fit yours or your computing style. ;)
midnytwarrior
CPU: i7 6850k
VGA: GTX 1080 x 2
PSU: EVGA 1600G2
Re: lost WU
as I see it, whether I get relaxed or long deadline, if the WU is not collected after deadline date then it's just as you would call it - junk
Re: lost WU
The relaxed deadlines of the CPU client are in the order of months, not minutes as with the GPU client, and folding part time. If the servers are down for a few days with GPU, you could easily miss a deadline. If the same thing happens with CPU client, you still have several weeks to spare. That's a big difference.
midnytwarrior
CPU: i7 6850k
VGA: GTX 1080 x 2
PSU: EVGA 1600G2
Re: lost WU
whether GPU or CPU client, if it ain't be collected on time, there is no difference
