SMP or GPU2?
impossiblerubix
SMP or GPU2?
Which client should I use? GPU2 or SMP Client? See system specs below.
System Specs-
GeForce 8400GS 512mb
AMD Athlon X2 2.71 GHz
2 GB 1066 Ram
System Specs-
2 GB 1066 Ram
v00d00
- 16GB DDR3,
- Zotac GTX 1050Ti @ Stock.
- Gigabyte GTX 970 @ Stock
Debian 9.
jrweiss
Re: SMP or GPU2?
Both.
Zagen30
Re: SMP or GPU2?
Neither.
J/k. Both. GPU2 on an Nvidia card barely uses the CPU. An 8400 GS won't get great PPD, but every piece of hardware helps the project.
impossiblerubix
Re: SMP or GPU2?
Alright, since everyone says both. I will use both. =D Console versions!
Re: SMP or GPU2?
Be careful, you'll probably have to fold 24/7 to be able to make the deadlines ...
If you can't (or don't want to), stick to two uniprocessor clients.
Re: SMP or GPU2?
v00d00 wrote:SMP.
jrweiss wrote:Both.
Zagen30 wrote:Neither.
toTOW wrote:Be careful, you'll probably have to fold 24/7 to be able to make the deadlines ...
Ok, so the real answer is: It depends . . . .
314159
Re: SMP or GPU2?
A sense of humor from a Site Admin?
I have never experienced that other than in private correspondences with the above.
IMHO, there should be some sort of (at least general) guidelines in a thread in this (now huge and barely manageable) forum that contains some sort of "optimization" information (and is updated as needed).
I guess that it simply depends........
John (from the central part of the Commonwealth of Virginia, U.S.A.)
A friendly visitor to what hopefully will remain a friendly Forum.
With thanks to all of the dedicated volunteers on the staff here!!
v00d00
- 16GB DDR3,
Debian 9.
Re: SMP or GPU2?
With SMP he should make the deadlines on a dual core at 2.7, but yes would have to fold near enough 24/7 to do it.
A GF 8400 probably isnt worth running, but if you can afford to run it then do so, i personally wouldnt.
ashdaw84
- Hardware configuration: E8400 Core Duo
EP45 DS3R M/B
PC8500 x 4GB ram,
9600GT NVidia
3x500gb sata,
750w PSU
Samsung 22" Monitor - Location: Canberra Australia
Re: SMP or GPU2?
I will add to this question here. I have an E8400 with 4GB ram and a 9600GT Nvidia. I am currently using the GPU systray client and have been wondering lately if I could run more than one client (like GPU and SMP)
The computer doesn't get used for gaming or anything like it and is mostly left on 24/7.
I have Server 2008 64bit and also a Win 7 install plus Ubuntu. So, would it be useful for ME to run the SMP AND the Gpu client?
Still new at this
jrweiss
Re: SMP or GPU2?
Yes. The Linux SMP client will run faster (it uses a different core than the Win SMP client), so you can try that route.
extrasalty
Re: SMP or GPU2?
Get the virtual appliance @ http://reilly.homeip.net/folding/ and run it under VMware Player. Make sure you put your name and team.
MSI Eclipse i7@3.45GHz
2x GTX260@702/1053/1512 Win 7+VMware+linuxfah VM+bigadv
