on line going crazy
harry48
on line going crazy
Post by harry48 »
hi this is my first post here , when i joined everything went great the setting was 0/500 then i went into task manager saw a strange prog; and took it out , it was folding at home
downloaded again the setting this time was 0/1500 , got my first wu , working away up to 1355/1500 , until to-night i had to shut down the pc quickly , restarted and i lost all that had built up , i'm now back to 15/1500 starting again
why did this happen , harry
AZBrandon
Re: on line going crazy
Post by AZBrandon »
Look in the install directory for the software for a file called fahlog.txt. That will tell you what happened and you can cut and paste the relevant section here for analysis.
"i had to shut down the pc quickly"
A forced shutdown can corrupt the work unit data, even though the client saves a checkpoint. Try to avoid doing that in the future, and the client will be fine.
As AZBrandon, the fahlog can also help us figure out what happened.
harry48
Post by harry48 »
i think this happened about the 21/22 june , thank you , harry
[20:15:25] Timer requesting checkpoint
[20:19:45] Completed 90000 out of 1500000 steps  (6%)
[20:34:51] Timer requesting checkpoint
[20:49:52] Timer requesting checkpoint
[21:05:09] Timer requesting checkpoint
[21:20:26] Timer requesting checkpoint
[21:35:27] Timer requesting checkpoint
[21:50:27] Timer requesting checkpoint
[21:56:30] Completed 105000 out of 1500000 steps  (7%)
[22:11:40] Timer requesting checkpoint
[22:26:45] Timer requesting checkpoint
[22:41:58] Timer requesting checkpoint
[22:57:01] Timer requesting checkpoint
[23:12:06] Timer requesting checkpoint
[18:34:04] - Ask before connecting: No
[18:34:04] - User name: 48harry48 (Team 67290)
[18:34:04] - User ID: 1F4F9C933BE845BC
[18:34:04] - Machine ID: 3
[18:34:04]
[18:34:04] Loaded queue successfully.
[18:34:05] Initialization complete
[18:34:14]
[18:34:14] + Processing work unit
[18:34:17] Core required: FahCore_7c.exe
[18:34:17] Core found.
[18:34:22] Working on queue slot 04 [June 15 18:34:22 UTC]
[18:34:22] + Working ...
[18:34:39]
[18:34:39] *------------------------------*
[18:34:39] Folding@Home Double Gromacs Core C
[18:34:39] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[18:34:39]
[18:34:39] Preparing to commence simulation
[18:34:39] - Files status OK
[18:34:49] - Expanded 230912 -> 635624 (decompressed 275.2 percent)
[18:34:54]
[18:34:54] Project: 3863 (Run 599, Clone 3, Gen 7)
[18:34:54]
[18:35:06] Assembly optimizations on if available.
[18:35:06] Entering M.D.
[18:35:12] Will resume from checkpoint file
[18:35:13] Working on p3863_fkbprelative_ligand
[18:35:13] Completed 0 out of 1500000 steps  (0%)
[18:35:14] Extra SSE2 boost OK
[18:35:14] Resuming from checkpoint
[18:35:14] Verified work/wudata_04.log
[18:35:14] Verified work/wudata_04.edr
[18:35:15] Verified work/wudata_04.xvg
[18:35:15] Verified work/wudata_04.trr
[18:35:15] Verified work/wudata_04.xtc
[18:35:15] Completed 819451 out of 1500000 steps  (54%)
[18:50:16] Timer requesting checkpoint
[19:05:16] Timer requesting checkpoint
[19:20:17] Timer requesting checkpoint
[19:20:39] Completed 825000 out of 1500000 steps  (55%)
[19:35:43] Timer requesting checkpoint
[19:50:44] Timer requesting checkpoint
[20:05:45] Timer requesting checkpoint
[20:08:19] Completed 840000 out of 1500000 steps  (56%)
[20:23:20] Timer requesting checkpoint
[20:38:42] Timer requesting checkpoint
[20:54:02] Timer requesting checkpoint
[21:09:02] Timer requesting checkpoint
[21:21:28] Completed 855000 out of 1500000 steps  (57%)
[21:36:29] Timer requesting checkpoint
[21:51:29] Timer requesting checkpoint
[21:58:59] Completed 870000 out of 1500000 steps  (58%)
[22:14:05] Timer requesting checkpoint
[22:29:30] Timer requesting checkpoint
[22:44:36] Timer requesting checkpoint
[22:59:46] Timer requesting checkpoint
[23:14:56] Timer requesting checkpoint
--- Opening Log file [June 16 14:19:06 UTC]
# Windows CPU Systray Edition #################################################
                          http://folding.stanford.edu
Launch directory: C:\Documents and Settings\harold mullan\Application Data\Folding@home-x86
[14:19:06] - Ask before connecting: No
[14:19:06] - User name: 48harry48 (Team 67290)
[14:19:06] - User ID: 1F4F9C933BE845BC
[14:19:06] - Machine ID: 3
[14:19:06]
[14:19:06] Loaded queue successfully.
[14:19:06] Initialization complete
[14:19:09]
[14:19:09] + Processing work unit
[14:19:09] Core required: FahCore_7c.exe
[14:19:09] Core found.
[14:19:15] Working on queue slot 04 [June 16 14:19:15 UTC]
[14:19:15] + Working ...
[14:19:15]
[14:19:15] *------------------------------*
[14:19:15] Folding@Home Double Gromacs Core C
[14:19:15] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[14:19:15]
[14:19:15] Preparing to commence simulation
[14:19:15] - Files status OK
[14:19:15] - Expanded 230912 -> 635624 (decompressed 275.2 percent)
[14:19:15]
[14:19:15] Project: 3863 (Run 599, Clone 3, Gen 7)
[14:19:15]
[14:19:16] Assembly optimizations on if available.
[14:19:16] Entering M.D.
[14:19:24] Will resume from checkpoint file
[14:19:24] Working on p3863_fkbprelative_ligand
[14:19:24] Completed 0 out of 1500000 steps  (0%)
[14:19:24] Extra SSE2 boost OK
[14:19:25] Resuming from checkpoint
[14:19:25] Verified work/wudata_04.log
[14:19:25] Verified work/wudata_04.edr
[14:19:25] Verified work/wudata_04.xvg
[14:19:25] Verified work/wudata_04.trr
[14:19:25] Verified work/wudata_04.xtc
[14:19:25] Completed 872851 out of 1500000 steps  (58%)
--- Opening Log file [June 16 18:43:02 UTC]
[18:43:02] - Ask before connecting: No
[18:43:02] - User name: 48harry48 (Team 67290)
[18:43:02] - User ID: 1F4F9C933BE845BC
[18:43:02] - Machine ID: 3
[18:43:02]
--- Opening Log file [June 16 19:43:22 UTC]
[19:43:22] - Ask before connecting: No
[19:43:22] - User name: 48harry48 (Team 67290)
[19:43:22] - User ID: 1F4F9C933BE845BC
[19:43:22] - Machine ID: 3
[19:43:22]
[19:43:22] Loaded queue successfully.
[19:43:22] Initialization complete
[19:43:22]
[19:43:22] + Processing work unit
[19:43:22] Core required: FahCore_7c.exe
[19:43:22] Core found.
[19:43:22] Working on queue slot 04 [June 16 19:43:22 UTC]
[19:43:22] + Working ...
[19:43:23]
[19:43:23] *------------------------------*
[19:43:23] Folding@Home Double Gromacs Core C
[19:43:23] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[19:43:23]
[19:43:23] Preparing to commence simulation
[19:43:23] - Files status OK
[19:43:24] - Expanded 230912 -> 635624 (decompressed 275.2 percent)
[19:43:24]
[19:43:24] Project: 3863 (Run 599, Clone 3, Gen 7)
[19:43:24]
[19:43:24] Assembly optimizations on if available.
[19:43:24] Entering M.D.
[19:43:30] Will resume from checkpoint file
[19:43:30] Working on p3863_fkbprelative_ligand
[19:43:30] Completed 0 out of 1500000 steps  (0%)
[19:43:30] Extra SSE2 boost OK
[19:43:32] Resuming from checkpoint
[19:43:32] Verified work/wudata_04.log
[19:43:32] Verified work/wudata_04.edr
[19:43:32] Verified work/wudata_04.xvg
[19:43:32] Verified work/wudata_04.trr
[19:43:32] Verified work/wudata_04.xtc
[19:43:32] Completed 872852 out of 1500000 steps  (58%)
[19:58:32] Timer requesting checkpoint
[20:13:32] Timer requesting checkpoint
[20:28:32] Timer requesting checkpoint
[20:33:13] Completed 885000 out of 1500000 steps  (59%)
[20:48:14] Timer requesting checkpoint
[21:03:15] Timer requesting checkpoint
[21:14:23] Completed 900000 out of 1500000 steps  (60%)
[21:29:24] Timer requesting checkpoint
[21:44:24] Timer requesting checkpoint
[21:50:04] Completed 915000 out of 1500000 steps  (61%)
[22:03:10] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=48harry48...
[22:03:29] Opening C:\Documents and Settings\harold mullan\Application Data\Folding@home-x86\MyFolding.html...
[22:03:57] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=67290...
[22:05:05] Timer requesting checkpoint
[22:20:05] Timer requesting checkpoint
[22:35:06] Timer requesting checkpoint
[22:50:21] Timer requesting checkpoint
[23:05:29] Timer requesting checkpoint
[23:20:40] Timer requesting checkpoint
[23:35:50] Timer requesting checkpoint
[23:38:44] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=67290...
--- Opening Log file [June 17 18:23:07 UTC]
[18:23:07] - Ask before connecting: No
[18:23:07] - User name: 48harry48 (Team 67290)
[18:23:07] - User ID: 1F4F9C933BE845BC
[18:23:07] - Machine ID: 3
[18:23:07]
[18:23:07] Loaded queue successfully.
[18:23:07] Initialization complete
[18:23:07]
[18:23:07] + Processing work unit
[18:23:10] Core required: FahCore_7c.exe
[18:23:12] Core found.
[18:23:12] Working on queue slot 04 [June 17 18:23:12 UTC]
[18:23:12] + Working ...
[18:23:12]
[18:23:12] *------------------------------*
[18:23:12] Folding@Home Double Gromacs Core C
[18:23:12] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[18:23:12]
[18:23:12] Preparing to commence simulation
[18:23:12] - Files status OK
[18:23:18] - Expanded 230912 -> 635624 (decompressed 275.2 percent)
[18:23:18]
[18:23:18] Project: 3863 (Run 599, Clone 3, Gen 7)
[18:23:18]
[18:23:21] Assembly optimizations on if available.
[18:23:21] Entering M.D.
[18:23:27] Will resume from checkpoint file
[18:24:12] Working on p3863_fkbprelative_ligand
[18:24:12] Completed 0 out of 1500000 steps  (0%)
[18:24:14] Extra SSE2 boost OK
[18:24:17] Resuming from checkpoint
[18:24:17] Verified work/wudata_04.log
[18:24:17] Verified work/wudata_04.edr
[18:24:19] Verified work/wudata_04.xvg
[18:24:19] Verified work/wudata_04.trr
[18:24:19] Verified work/wudata_04.xtc
[18:24:19] Completed 926385 out of 1500000 steps  (61%)
[18:39:20] Timer requesting checkpoint
[18:54:37] Timer requesting checkpoint
[18:57:08] Completed 930000 out of 1500000 steps  (62%)
[19:12:13] Timer requesting checkpoint
[19:27:13] Timer requesting checkpoint
[19:42:14] Timer requesting checkpoint
[19:51:21] Completed 945000 out of 1500000 steps  (63%)
[20:06:23] Timer requesting checkpoint
[20:21:28] Timer requesting checkpoint
[20:36:47] Timer requesting checkpoint
[20:51:56] Timer requesting checkpoint
[20:53:37] Completed 960000 out of 1500000 steps  (64%)
[21:08:39] Timer requesting checkpoint
[21:23:39] Timer requesting checkpoint
[21:28:43] Completed 975000 out of 1500000 steps  (65%)
[21:43:44] Timer requesting checkpoint
[21:58:44] Timer requesting checkpoint
[22:03:45] Completed 990000 out of 1500000 steps  (66%)
[22:18:47] Timer requesting checkpoint
[22:33:48] Timer requesting checkpoint
[22:48:48] Timer requesting checkpoint
[22:54:23] Completed 1005000 out of 1500000 steps  (67%)
[23:09:23] Timer requesting checkpoint
[23:24:25] Timer requesting checkpoint
[23:39:28] Timer requesting checkpoint
[23:55:58] Timer requesting checkpoint
[00:11:15] Timer requesting checkpoint
--- Opening Log file [June 18 18:49:11 UTC]
[18:49:11] - Ask before connecting: No
[18:49:11] - User name: 48harry48 (Team 67290)
[18:49:11] - User ID: 1F4F9C933BE845BC
[18:49:11] - Machine ID: 3
[18:49:11]
[18:49:11] Loaded queue successfully.
[18:49:11] Initialization complete
[18:49:11]
[18:49:11] + Processing work unit
[18:49:21] Core required: FahCore_7c.exe
[18:49:21] Core found.
[18:49:37] Working on queue slot 04 [June 18 18:49:37 UTC]
[18:49:37] + Working ...
[18:49:42]
[18:49:42] *------------------------------*
[18:49:42] Folding@Home Double Gromacs Core C
[18:49:42] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[18:49:42]
[18:49:42] Preparing to commence simulation
[18:49:42] - Files status OK
[18:49:45] - Expanded 230912 -> 635624 (decompressed 275.2 percent)
[18:49:45]
[18:49:45] Project: 3863 (Run 599, Clone 3, Gen 7)
[18:49:45]
[18:49:53] Assembly optimizations on if available.
[18:49:53] Entering M.D.
[18:49:56] Will resume from checkpoint file
[18:50:12] Working on p3863_fkbprelative_ligand
[18:50:12] Completed 0 out of 1500000 steps  (0%)
[18:50:13] Extra SSE2 boost OK
[18:50:15] Resuming from checkpoint
[18:50:15] Verified work/wudata_04.log
[18:50:15] Verified work/wudata_04.edr
[18:50:16] Verified work/wudata_04.xvg
[18:50:16] Verified work/wudata_04.trr
[18:50:17] Verified work/wudata_04.xtc
[18:50:17] Completed 1017487 out of 1500000 steps  (67%)
[19:01:42] Completed 1020000 out of 1500000 steps  (68%)
[19:16:45] Timer requesting checkpoint
[19:31:45] Timer requesting checkpoint
[19:46:21] Completed 1035000 out of 1500000 steps  (69%)
[20:01:23] Timer requesting checkpoint
[20:16:27] Timer requesting checkpoint
[20:31:32] Timer requesting checkpoint
[20:46:41] Timer requesting checkpoint
[21:01:40] Timer requesting checkpoint
[21:16:02] Completed 1050000 out of 1500000 steps  (70%)
[21:31:04] Timer requesting checkpoint
[21:46:03] Timer requesting checkpoint
[22:01:04] Timer requesting checkpoint
[22:03:32] Completed 1065000 out of 1500000 steps  (71%)
[22:18:37] Timer requesting checkpoint
--- Opening Log file [June 18 22:30:48 UTC]
[22:30:48] - Ask before connecting: No
[22:30:48] - User name: 48harry48 (Team 67290)
[22:30:48] - User ID: 1F4F9C933BE845BC
[22:30:48] - Machine ID: 3
[22:30:48]
[22:30:49] Loaded queue successfully.
[22:30:49] Initialization complete
[22:30:59]
[22:30:59] + Processing work unit
[22:30:59] Core required: FahCore_7c.exe
[22:30:59] Core found.
[22:31:04] Working on queue slot 04 [June 18 22:31:04 UTC]
[22:31:04] + Working ...
[22:31:11]
[22:31:11] *------------------------------*
[22:31:11] Folding@Home Double Gromacs Core C
[22:31:11] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[22:31:11]
[22:31:11] Preparing to commence simulation
[22:31:11] - Files status OK
[22:31:17] - Expanded 230912 -> 635624 (decompressed 275.2 percent)
[22:31:17]
[22:31:17] Project: 3863 (Run 599, Clone 3, Gen 7)
[22:31:17]
[22:31:22] Assembly optimizations on if available.
[22:31:22] Entering M.D.
[22:31:33] Will resume from checkpoint file
[22:31:47] Working on p3863_fkbprelative_ligand
[22:31:47] Completed 0 out of 1500000 steps  (0%)
[22:31:48] Extra SSE2 boost OK
[22:31:50] Resuming from checkpoint
[22:31:50] Verified work/wudata_04.log
[22:31:51] Verified work/wudata_04.edr
[22:31:51] Verified work/wudata_04.xvg
[22:31:51] Verified work/wudata_04.trr
[22:31:51] Verified work/wudata_04.xtc
[22:31:51] Completed 1069302 out of 1500000 steps  (71%)
[22:46:57] Timer requesting checkpoint
--- Opening Log file [June 19 18:35:11 UTC]
[18:35:11] - Ask before connecting: No
[18:35:11] - User name: 48harry48 (Team 67290)
[18:35:11] - User ID: 1F4F9C933BE845BC
[18:35:11] - Machine ID: 3
[18:35:11]
[18:35:11] Loaded queue successfully.
[18:35:11] Initialization complete
[18:35:13]
[18:35:13] + Processing work unit
[18:35:13] Core required: FahCore_7c.exe
[18:35:13] Core found.
[18:35:13] Working on queue slot 04 [June 19 18:35:13 UTC]
[18:35:13] + Working ...
[18:35:13]
[18:35:13] *------------------------------*
[18:35:13] Folding@Home Double Gromacs Core C
[18:35:13] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[18:35:13]
[18:35:13] Preparing to commence simulation
[18:35:13] - Files status OK
[18:35:21] - Expanded 230912 -> 635624 (decompressed 275.2 percent)
[18:35:31]
[18:35:31] Project: 3863 (Run 599, Clone 3, Gen 7)
[18:35:31]
[18:35:52] Assembly optimizations on if available.
[18:35:52] Entering M.D.
[18:36:02] Will resume from checkpoint file
[18:36:11] Working on p3863_fkbprelative_ligand
[18:36:11] Completed 0 out of 1500000 steps  (0%)
[18:36:11] Extra SSE2 boost OK
[18:36:12] Resuming from checkpoint
[18:36:13] Verified work/wudata_04.log
[18:36:13] Verified work/wudata_04.edr
[18:36:14] Verified work/wudata_04.xvg
[18:36:14] Verified work/wudata_04.trr
[18:36:14] Verified work/wudata_04.xtc
[18:36:14] Completed 1069858 out of 1500000 steps  (71%)
[18:51:14] Timer requesting checkpoint
[19:06:14] Timer requesting checkpoint
[19:15:01] Completed 1080000 out of 1500000 steps  (72%)
[19:30:02] Timer requesting checkpoint
[19:45:02] Timer requesting checkpoint
[20:00:07] Timer requesting checkpoint
[20:15:15] Timer requesting checkpoint
[20:16:39] Completed 1095000 out of 1500000 steps  (73%)
[20:31:40] Timer requesting checkpoint
[20:46:40] Timer requesting checkpoint
[20:51:14] Completed 1110000 out of 1500000 steps  (74%)
[21:06:16] Timer requesting checkpoint
[21:21:16] Timer requesting checkpoint
[21:25:38] Completed 1125000 out of 1500000 steps  (75%)
[21:40:40] Timer requesting checkpoint
[21:55:43] Timer requesting checkpoint
[22:10:55] Timer requesting checkpoint
[22:27:31] Timer requesting checkpoint
--- Opening Log file [June 20 17:01:27 UTC]
[17:01:27] - Ask before connecting: No
[17:01:27] - User name: 48harry48 (Team 67290)
[17:01:27] - User ID: 1F4F9C933BE845BC
[17:01:27] - Machine ID: 3
[17:01:27]
[17:01:27] Loaded queue successfully.
[17:01:27] Initialization complete
[17:01:31]
[17:01:31] + Processing work unit
[17:01:40] Core required: FahCore_7c.exe
[17:01:40] Core found.
[17:01:50] Working on queue slot 04 [June 20 17:01:50 UTC]
[17:01:50] + Working ...
[17:01:51]
[17:01:51] *------------------------------*
[17:01:51] Folding@Home Double Gromacs Core C
[17:01:51] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[17:01:51]
[17:01:51] Preparing to commence simulation
[17:01:51] - Files status OK
[17:01:51] - Expanded 230912 -> 635624 (decompressed 275.2 percent)
[17:01:51]
[17:01:51] Project: 3863 (Run 599, Clone 3, Gen 7)
[17:01:51]
[17:01:52] Assembly optimizations on if available.
[17:01:52] Entering M.D.
[17:02:02] Will resume from checkpoint file
[17:02:30] Working on p3863_fkbprelative_ligand
[17:02:30] Completed 0 out of 1500000 steps  (0%)
[17:02:30] Extra SSE2 boost OK
[17:02:32] Resuming from checkpoint
[17:02:32] Verified work/wudata_04.log
[17:02:32] Verified work/wudata_04.edr
[17:02:33] Verified work/wudata_04.xvg
[17:02:33] Verified work/wudata_04.trr
[17:02:33] Verified work/wudata_04.xtc
[17:02:33] Completed 1135301 out of 1500000 steps  (75%)
[17:17:34] Timer requesting checkpoint
--- Opening Log file [June 20 18:36:31 UTC]
[18:36:31] - Ask before connecting: No
[18:36:31] - User name: 48harry48 (Team 67290)
[18:36:31] - User ID: 1F4F9C933BE845BC
[18:36:31] - Machine ID: 3
[18:36:31]
[18:36:31] Loaded queue successfully.
[18:36:31] Initialization complete
[18:36:37]
[18:36:37] + Processing work unit
[18:36:42] Core required: FahCore_7c.exe
[18:36:42] Core found.
[18:36:49] Working on queue slot 04 [June 20 18:36:49 UTC]
[18:36:49] + Working ...
[18:36:55]
[18:36:55] *------------------------------*
[18:36:55] Folding@Home Double Gromacs Core C
[18:36:55] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[18:36:55]
[18:36:55] Preparing to commence simulation
[18:36:55] - Files status OK
[18:36:56] - Expanded 230912 -> 635624 (decompressed 275.2 percent)
[18:36:56]
[18:36:56] Project: 3863 (Run 599, Clone 3, Gen 7)
[18:36:56]
[18:37:01] Assembly optimizations on if available.
[18:37:01] Entering M.D.
[18:37:03] Will resume from checkpoint file
[18:37:32] Working on p3863_fkbprelative_ligand
[18:37:32] Completed 0 out of 1500000 steps  (0%)
[18:37:32] Extra SSE2 boost OK
[18:37:34] Resuming from checkpoint
[18:37:34] Verified work/wudata_04.log
[18:37:34] Verified work/wudata_04.edr
[18:37:35] Verified work/wudata_04.xvg
[18:37:36] Verified work/wudata_04.trr
[18:37:36] Verified work/wudata_04.xtc
[18:37:36] Completed 1138422 out of 1500000 steps  (75%)
[18:47:02] Completed 1140000 out of 1500000 steps  (76%)
[19:02:08] Timer requesting checkpoint
[19:17:10] Timer requesting checkpoint
[19:32:15] Timer requesting checkpoint
[19:47:24] Timer requesting checkpoint
[20:02:37] Timer requesting checkpoint
[20:17:45] Timer requesting checkpoint
[20:32:45] Timer requesting checkpoint
[20:47:44] Timer requesting checkpoint
[21:02:45] Timer requesting checkpoint
[21:04:02] Completed 1155000 out of 1500000 steps  (77%)
[21:19:03] Timer requesting checkpoint
[21:34:03] Timer requesting checkpoint
[21:42:47] Completed 1170000 out of 1500000 steps  (78%)
[21:57:49] Timer requesting checkpoint
[22:12:48] Timer requesting checkpoint
[22:21:40] Completed 1185000 out of 1500000 steps  (79%)
[22:36:41] Timer requesting checkpoint
[22:51:42] Timer requesting checkpoint
[22:59:21] Completed 1200000 out of 1500000 steps  (80%)
[23:14:23] Timer requesting checkpoint
[23:29:23] Timer requesting checkpoint
[23:44:27] Timer requesting checkpoint
[23:59:37] Timer requesting checkpoint
--- Opening Log file [June 21 18:14:43 UTC]
[18:14:43] - Ask before connecting: No
[18:14:43] - User name: 48harry48 (Team 67290)
[18:14:43] - User ID: 1F4F9C933BE845BC
[18:14:43] - Machine ID: 3
[18:14:43]
[18:14:43] Loaded queue successfully.
[18:14:43] Initialization complete
[18:14:43]
[18:14:43] + Processing work unit
[18:14:44] Core required: FahCore_7c.exe
[18:14:44] Core found.
[18:14:44] Working on queue slot 04 [June 21 18:14:44 UTC]
[18:14:44] + Working ...
[18:14:44]
[18:14:44] *------------------------------*
[18:14:44] Folding@Home Double Gromacs Core C
[18:14:44] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[18:14:44]
[18:14:44] Preparing to commence simulation
[18:14:44] - Files status OK
[18:14:44] - Expanded 230912 -> 635624 (decompressed 275.2 percent)
[18:14:44]
[18:14:44] Project: 3863 (Run 599, Clone 3, Gen 7)
[18:14:44]
[18:14:44] Assembly optimizations on if available.
[18:14:44] Entering M.D.
[18:14:55] Will resume from checkpoint file
[18:15:22] Working on p3863_fkbprelative_ligand
[18:15:22] Completed 0 out of 1500000 steps  (0%)
[18:15:23] Extra SSE2 boost OK
[18:15:23] Resuming from checkpoint
[18:15:24] Verified work/wudata_04.log
[18:15:24] Verified work/wudata_04.edr
[18:15:25] Verified work/wudata_04.xvg
[18:15:25] Verified work/wudata_04.trr
[18:15:25] Verified work/wudata_04.xtc
[18:15:25] Completed 1209501 out of 1500000 steps  (80%)
[18:30:25] Timer requesting checkpoint
[18:45:29] Timer requesting checkpoint
[18:51:02] Completed 1215000 out of 1500000 steps  (81%)
[19:06:04] Timer requesting checkpoint
[19:21:05] Timer requesting checkpoint
[19:36:05] Timer requesting checkpoint
[19:51:05] Timer requesting checkpoint
[20:05:26] Completed 1230000 out of 1500000 steps  (82%)
[20:20:27] Timer requesting checkpoint
--- Opening Log file [June 21 20:34:47 UTC]
[20:34:47] - Ask before connecting: No
[20:34:47] - User name: 48harry48 (Team 67290)
[20:34:47] - User ID: 1F4F9C933BE845BC
[20:34:47] - Machine ID: 3
[20:34:47]
[20:34:47] Loaded queue successfully.
[20:34:47] Initialization complete
[20:34:57]
[20:34:57] + Processing work unit
[20:34:57] Core required: FahCore_7c.exe
[20:34:57] Core found.
[20:35:02] Working on queue slot 04 [June 21 20:35:02 UTC]
[20:35:02] + Working ...
[20:35:15]
[20:35:15] *------------------------------*
[20:35:15] Folding@Home Double Gromacs Core C
[20:35:15] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[20:35:15]
[20:35:15] Preparing to commence simulation
[20:35:15] - Files status OK
[20:35:15] - Expanded 230912 -> 635624 (decompressed 275.2 percent)
[20:35:15]
[20:35:15] Project: 3863 (Run 599, Clone 3, Gen 7)
[20:35:15]
[20:35:15] Assembly optimizations on if available.
[20:35:15] Entering M.D.
[20:35:21] Will resume from checkpoint file
[20:35:22] Working on p3863_fkbprelative_ligand
[20:35:22] Completed 0 out of 1500000 steps  (0%)
[20:35:22] Extra SSE2 boost OK
[20:35:23] Resuming from checkpoint
[20:35:23] Verified work/wudata_04.log
[20:35:23] Verified work/wudata_04.edr
[20:35:23] Verified work/wudata_04.xvg
[20:35:23] Verified work/wudata_04.trr
[20:35:23] Verified work/wudata_04.xtc
[20:35:23] Completed 1234355 out of 1500000 steps  (82%)
[20:50:23] Timer requesting checkpoint
[21:05:23] Timer requesting checkpoint
[21:20:23] Timer requesting checkpoint
[21:35:23] Timer requesting checkpoint
[21:39:16] Completed 1245000 out of 1500000 steps  (83%)
--- Opening Log file [June 21 21:47:54 UTC]
[21:47:54] - Ask before connecting: No
[21:47:54] - User name: 48harry48 (Team 67290)
[21:47:54] - User ID: 1F4F9C933BE845BC
[21:47:54] - Machine ID: 3
[21:47:54]
[21:47:54] Loaded queue successfully.
[21:47:54] Initialization complete
[21:48:04]
[21:48:04] + Processing work unit
[21:48:08] Core required: FahCore_7c.exe
[21:48:08] Core found.
[21:48:09] Working on queue slot 04 [June 21 21:48:09 UTC]
[21:48:09] + Working ...
[21:48:19]
[21:48:19] *------------------------------*
[21:48:19] Folding@Home Double Gromacs Core C
[21:48:19] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[21:48:19]
[21:48:19] Preparing to commence simulation
[21:48:19] - Files status OK
[21:48:19] - Expanded 230912 -> 635624 (decompressed 275.2 percent)
[21:48:20]
[21:48:20] Project: 3863 (Run 599, Clone 3, Gen 7)
[21:48:20]
[21:48:20] Assembly optimizations on if available.
[21:48:20] Entering M.D.
[21:48:27] Will resume from checkpoint file
[21:48:31] Working on p3863_fkbprelative_ligand
[21:48:31] Completed 0 out of 1500000 steps  (0%)
[21:48:33] Extra SSE2 boost OK
[21:49:02] Resuming from checkpoint
[21:49:02] Verified work/wudata_04.log
[21:49:03] Verified work/wudata_04.edr
[21:49:04] Verified work/wudata_04.xvg
[21:49:04] Verified work/wudata_04.trr
[21:49:04] Verified work/wudata_04.xtc
[21:49:04] Completed 1245001 out of 1500000 steps  (83%)
[22:04:05] Timer requesting checkpoint
[22:19:06] Timer requesting checkpoint
[22:34:07] Timer requesting checkpoint
[22:43:49] Completed 1260000 out of 1500000 steps  (84%)
[22:58:51] Timer requesting checkpoint
[23:14:04] Timer requesting checkpoint
[23:29:20] Timer requesting checkpoint
--- Opening Log file [June 22 17:51:57 UTC]
[17:51:57] - Ask before connecting: No
[17:51:57] - User name: 48harry48 (Team 67290)
[17:51:57] - User ID: 1F4F9C933BE845BC
[17:51:57] - Machine ID: 3
[17:51:57]
[17:51:57] Loaded queue successfully.
[17:51:57] Initialization complete
[17:51:58]
[17:51:58] + Processing work unit
[17:51:58] Core required: FahCore_7c.exe
[17:51:58] Core found.
[17:51:58] Working on queue slot 04 [June 22 17:51:58 UTC]
[17:51:58] + Working ...
[17:51:58]
[17:51:58] *------------------------------*
[17:51:58] Folding@Home Double Gromacs Core C
[17:51:58] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[17:51:58]
[17:51:58] Preparing to commence simulation
[17:51:58] - Files status OK
[17:51:58] - Expanded 230912 -> 635624 (decompressed 275.2 percent)
[17:51:58]
[17:51:58] Project: 3863 (Run 599, Clone 3, Gen 7)
[17:51:58]
[17:51:58] Assembly optimizations on if available.
[17:51:58] Entering M.D.
[17:52:10] Will resume from checkpoint file
[17:52:30] Working on p3863_fkbprelative_ligand
[17:52:30] Completed 0 out of 1500000 steps  (0%)
[17:52:30] Extra SSE2 boost OK
[17:52:33] Resuming from checkpoint
[17:52:34] Verified work/wudata_04.log
[17:52:34] Verified work/wudata_04.edr
[17:52:35] Verified work/wudata_04.xvg
[17:52:35] Verified work/wudata_04.trr
[17:52:35] Verified work/wudata_04.xtc
[17:52:35] Completed 1260694 out of 1500000 steps  (84%)
[18:07:35] Timer requesting checkpoint
[18:22:36] Timer requesting checkpoint
[18:37:37] Timer requesting checkpoint
[18:38:45] Completed 1275000 out of 1500000 steps  (85%)
[18:53:47] Timer requesting checkpoint
[19:08:47] Timer requesting checkpoint
[19:23:56] Timer requesting checkpoint
[19:39:08] Timer requesting checkpoint
[19:48:57] Completed 1290000 out of 1500000 steps  (86%)
[20:03:57] Timer requesting checkpoint
[20:18:58] Timer requesting checkpoint
[20:28:28] Completed 1305000 out of 1500000 steps  (87%)
[20:43:29] Timer requesting checkpoint
[20:58:29] Timer requesting checkpoint
[21:13:07] Completed 1320000 out of 1500000 steps  (88%)
[21:28:09] Timer requesting checkpoint
[21:43:10] Timer requesting checkpoint
[21:58:10] Timer requesting checkpoint
[22:13:15] Timer requesting checkpoint
[22:29:06] Timer requesting checkpoint
[22:44:08] Timer requesting checkpoint
[22:59:56] Timer requesting checkpoint
[23:15:10] Timer requesting checkpoint
--- Opening Log file [June 23 19:02:10 UTC]
[19:02:10] - Ask before connecting: No
[19:02:10] - User name: 48harry48 (Team 67290)
[19:02:10] - User ID: 1F4F9C933BE845BC
[19:02:10] - Machine ID: 3
[19:02:10]
[19:02:10] Loaded queue successfully.
[19:02:11] Initialization complete
[19:02:15]
[19:02:15] + Processing work unit
[19:02:15] Core required: FahCore_7c.exe
[19:02:20] Core found.
[19:02:25] Working on queue slot 04 [June 23 19:02:25 UTC]
[19:02:25] + Working ...
[19:02:26]
[19:02:26] *------------------------------*
[19:02:26] Folding@Home Double Gromacs Core C
[19:02:26] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[19:02:26]
[19:02:26] Preparing to commence simulation
[19:02:26] - Files status OK
[19:02:36] - Expanded 230912 -> 635624 (decompressed 275.2 percent)
[19:02:37]
[19:02:37] Project: 3863 (Run 599, Clone 3, Gen 7)
[19:02:37]
[19:02:39] Assembly optimizations on if available.
[19:02:39] Entering M.D.
[19:02:45] Will resume from checkpoint file
[19:02:46] Working on p3863_fkbprelative_ligand
[19:02:46] Completed 0 out of 1500000 steps  (0%)
[19:02:46] Extra SSE2 boost OK
[19:02:48] Resuming from checkpoint
[19:02:49] Verified work/wudata_04.log
[19:02:49] Verified work/wudata_04.edr
[19:03:10] Verified work/wudata_04.xvg
[19:03:16] Verified work/wudata_04.trr
[19:03:16] Verified work/wudata_04.xtc
[19:03:16] Completed 1332490 out of 1500000 steps  (88%)
[19:12:56] Completed 1335000 out of 1500000 steps  (89%)
[19:15:07]  to open work/wudata_04.trr
[19:15:07] Verified work/wudata_04.trr
[19:15:07] truncate: unable to open work/wudata_04.xtc
[19:15:07] Verified work/wudata_04.xtc
[19:15:07] Completed 1335001 out of 1500000 steps  (89%)
[19:30:07] Timer requesting checkpoint
[19:45:07] Timer requesting checkpoint
[20:00:16] Timer requesting checkpoint
[20:15:47] Timer requesting checkpoint
[20:30:58] Timer requesting checkpoint
--- Opening Log file [June 23 20:45:02 UTC]
[20:45:02] - Ask before connecting: No
[20:45:02] - User name: 48harry48 (Team 67290)
[20:45:02] - User ID: 1F4F9C933BE845BC
[20:45:02] - Machine ID: 3
[20:45:02]
[20:45:02] Loaded queue successfully.
[20:45:02] Initialization complete
[20:45:02]
[20:45:02] + Processing work unit
[20:45:02] Core required: FahCore_7c.exe
[20:45:02] Core found.
[20:45:03] Working on queue slot 04 [June 23 20:45:03 UTC]
[20:45:03] + Working ...
[20:45:05]
[20:45:05] *------------------------------*
[20:45:05] Folding@Home Double Gromacs Core C
[20:45:05] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[20:45:05]
[20:45:05] Preparing to commence simulation
[20:45:05] - Files status OK
[20:45:06] - Expanded 230912 -> 635624 (decompressed 275.2 percent)
[20:45:06]
[20:45:06] Project: 3863 (Run 599, Clone 3, Gen 7)
[20:45:06]
[20:45:07] Assembly optimizations on if available.
[20:45:07] Entering M.D.
[20:45:13] Will resume from checkpoint file
[20:45:16] Working on p3863_fkbprelative_ligand
[20:45:16] Completed 0 out of 1500000 steps  (0%)
[20:45:17] Extra SSE2 boost OK
[20:45:19] Resuming from checkpoint
[20:45:21] Verified work/wudata_04.log
[20:45:21] Verified work/wudata_04.edr
[20:45:23] File work/wudata_04.xvg has changed since last checkpoint
[20:45:23] mdrun returned -1
[20:45:23] Going to send back what have done.
[20:45:23] logfile size: 56380
[20:45:23] - Writing 56918 bytes of core data to disk...
[20:45:23] Done: 56406 -> 13347 (compressed to 23.6 percent)
[20:45:23]   ... Done.
[20:45:25]
[20:45:25] Folding@home Core Shutdown: EARLY_UNIT_END
[20:45:33] CoreStatus = 72 (114)
[20:45:33] Sending work to server
[20:45:33] Project: 3863 (Run 599, Clone 3, Gen 7)
[20:45:33] + Attempting to send results [June 23 20:45:33 UTC]
[20:45:43] + Results successfully sent
[20:45:43] Thank you for your contribution to Folding@Home.
[20:45:52] - Preparing to get new work unit...
[20:45:52] + Attempting to get work packet
[20:45:52] - Connecting to assignment server
[20:45:54] - Successful: assigned to (128.143.48.226).
[20:45:54] + News From Folding@Home: Welcome to Folding@Home
[20:45:54] Loaded queue successfully.
[20:46:02] + Closed connections
[20:46:11]
[20:46:11] + Processing work unit
[20:46:11] Core required: FahCore_7c.exe
[20:46:11] Core found.
[20:46:11] Working on queue slot 05 [June 23 20:46:11 UTC]
[20:46:11] + Working ...
[20:46:30]
[20:46:30] *------------------------------*
[20:46:30] Folding@Home Double Gromacs Core C
[20:46:30] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[20:46:30]
[20:46:30] Preparing to commence simulation
[20:46:30] - Files status OK
[20:46:31] - Expanded 627040 -> 3592360 (decompressed 572.9 percent)
[20:46:31]
[20:46:31] Project: 3864 (Run 382, Clone 11, Gen 0)
[20:46:31]
[20:46:33] Assembly optimizations on if available.
[20:46:33] Entering M.D.
[20:46:46] Working on p3862_fkbprelative_complex
[20:46:46] Completed 0 out of 300000 steps  (0%)
[20:46:47] Extra SSE2 boost OK
[20:54:19] Opening C:\Documents and Settings\harold mullan\Application Data\Folding@home-x86\MyFolding.html...
[20:54:36] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=48harry48...
[20:54:50] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=67290...
[21:00:53] mdrun returned -1
[21:00:53] Going to send back what have done.
[21:00:53] logfile size: 136029
[21:00:53] - Writing 136567 bytes of core data to disk...
[21:00:53] Done: 136055 -> 11487 (compressed to 8.4 percent)
[21:00:53]   ... Done.
[21:00:53]
[21:00:53] Folding@home Core Shutdown: EARLY_UNIT_END
[21:00:55] CoreStatus = 72 (114)
[21:00:55] Sending work to server
[21:00:55] Project: 3864 (Run 382, Clone 11, Gen 0)
[21:00:55] + Attempting to send results [June 23 21:00:55 UTC]
[21:00:56] + Results successfully sent
[21:00:56] Thank you for your contribution to Folding@Home.
[21:01:00] - Preparing to get new work unit...
[21:01:00] + Attempting to get work packet
[21:01:00] - Connecting to assignment server
[21:01:01] - Successful: assigned to (128.143.48.226).
[21:01:01] + News From Folding@Home: Welcome to Folding@Home
[21:01:01] Loaded queue successfully.
[21:01:05] + Closed connections
[21:01:10]
[21:01:10] + Processing work unit
[21:01:10] Core required: FahCore_7c.exe
[21:01:10] Core found.
[21:01:10] Working on queue slot 06 [June 23 21:01:10 UTC]
[21:01:10] + Working ...
[21:01:10]
[21:01:10] *------------------------------*
[21:01:10] Folding@Home Double Gromacs Core C
[21:01:10] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[21:01:10]
[21:01:10] Preparing to commence simulation
[21:01:10] - Files status OK
[21:01:10] - Expanded 233602 -> 640092 (decompressed 274.0 percent)
[21:01:10]
[21:01:10] Project: 3863 (Run 545, Clone 10, Gen 10)
[21:01:10]
[21:01:10] Assembly optimizations on if available.
[21:01:10] Entering M.D.
[21:01:16] Working on p3863_fkbprelative_ligand
[21:01:16] Completed 0 out of 1500000 steps  (0%)
[21:01:16] Extra SSE2 boost OK
[21:16:17] Timer requesting checkpoint
[21:31:17] Timer requesting checkpoint
[21:42:52] Completed 15000 out of 1500000 steps  (1%)
[21:57:53] Timer requesting checkpoint
[22:12:53] Timer requesting checkpoint
[22:27:53] Timer requesting checkpoint
[22:42:53] Timer requesting checkpoint
[22:46:31] Completed 30000 out of 1500000 steps  (2%)
[23:01:33] Timer requesting checkpoint
[23:16:39] Timer requesting checkpoint
[23:33:15] Timer requesting checkpoint
--- Opening Log file [June 24 19:31:25 UTC]
[19:31:25] - Ask before connecting: No
[19:31:25] - User name: 48harry48 (Team 67290)
[19:31:25] - User ID: 1F4F9C933BE845BC
[19:31:25] - Machine ID: 3
[19:31:25]
[19:31:26] Loaded queue successfully.
[19:31:26] Initialization complete
[19:31:27]
[19:31:27] + Processing work unit
[19:31:27] Core required: FahCore_7c.exe
[19:31:27] Core found.
[19:31:27] Working on queue slot 06 [June 24 19:31:27 UTC]
[19:31:27] + Working ...
[19:31:27]
[19:31:27] *------------------------------*
[19:31:27] Folding@Home Double Gromacs Core C
[19:31:27] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[19:31:27]
[19:31:27] Preparing to commence simulation
[19:31:27] - Files status OK
[19:31:27] - Expanded 233602 -> 640092 (decompressed 274.0 percent)
[19:31:27]
[19:31:27] Project: 3863 (Run 545, Clone 10, Gen 10)
[19:31:27]
[19:31:28] Assembly optimizations on if available.
[19:31:28] Entering M.D.
[19:31:40] Will resume from checkpoint file
[19:32:05] Working on p3863_fkbprelative_ligand
[19:32:05] Completed 0 out of 1500000 steps  (0%)
[19:32:06] Extra SSE2 boost OK
[19:32:07] Resuming from checkpoint
[19:32:07] Verified work/wudata_06.log
[19:32:07] Verified work/wudata_06.edr
[19:32:08] Verified work/wudata_06.xvg
[19:32:08] Verified work/wudata_06.trr
[19:32:08] Verified work/wudata_06.xtc
[19:32:08] Completed 35980 out of 1500000 steps  (2%)
[19:47:08] Timer requesting checkpoint
[20:02:10] Timer requesting checkpoint
[20:05:22] Completed 45000 out of 1500000 steps  (3%)
[20:20:23] Timer requesting checkpoint
[20:35:23] Timer requesting checkpoint
[21:06:07] Completed 60000 out of 1500000 steps  (4%)
[21:21:08] Timer requesting checkpoint
[21:36:08] Timer requesting checkpoint
[21:51:11] Timer requesting checkpoint
[21:57:09] Completed 75000 out of 1500000 steps  (5%)
[22:12:10] Timer requesting checkpoint
[22:27:16] Timer requesting checkpoint
[22:42:28] Timer requesting checkpoint
[22:57:43] Timer requesting checkpoint
[23:12:49] Timer requesting checkpoint
[23:28:02] Timer requesting checkpoint
--- Opening Log file [June 25 18:44:34 UTC]
[18:44:35] - Ask before connecting: No
[18:44:35] - User name: 48harry48 (Team 67290)
[18:44:35] - User ID: 1F4F9C933BE845BC
[18:44:35] - Machine ID: 3
[18:44:35]
[18:44:35] Loaded queue successfully.
[18:44:35] Initialization complete
[18:44:37]
[18:44:37] + Processing work unit
[18:44:37] Core required: FahCore_7c.exe
[18:44:37] Core found.
[18:44:37] Working on queue slot 06 [June 25 18:44:37 UTC]
[18:44:37] + Working ...
[18:44:37]
[18:44:37] *------------------------------*
[18:44:37] Folding@Home Double Gromacs Core C
[18:44:37] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[18:44:37]
[18:44:37] Preparing to commence simulation
[18:44:37] - Files status OK
[18:44:38] - Expanded 233602 -> 640092 (decompressed 274.0 percent)
[18:44:43]
[18:44:43] Project: 3863 (Run 545, Clone 10, Gen 10)
[18:44:43]
[18:44:47] Assembly optimizations on if available.
[18:44:47] Entering M.D.
[18:44:54] Will resume from checkpoint file
[18:45:10] Working on p3863_fkbprelative_ligand
[18:45:10] Completed 0 out of 1500000 steps  (0%)
[18:45:11] Extra SSE2 boost OK
[18:45:13] Resuming from checkpoint
[18:45:13] Verified work/wudata_06.log
[18:45:13] Verified work/wudata_06.edr
[18:45:13] Verified work/wudata_06.xvg
[18:45:13] Verified work/wudata_06.trr
[18:45:13] Verified work/wudata_06.xtc
[18:45:13] Completed 82147 out of 1500000 steps  (5%)
[19:00:13] Timer requesting checkpoint
[19:15:20] Timer requesting checkpoint
[19:30:21] Timer requesting checkpoint
[19:45:22] Timer requesting checkpoint
[20:00:24] Timer requesting checkpoint
--- Opening Log file [June 26 18:41:42 UTC]
[18:41:42] - Ask before connecting: No
[18:41:42] - User name: 48harry48 (Team 67290)
[18:41:42] - User ID: 1F4F9C933BE845BC
[18:41:42] - Machine ID: 3
[18:41:42]
[18:41:42] Loaded queue successfully.
[18:41:42] Initialization complete
[18:41:45]
[18:41:45] + Processing work unit
[18:41:45] Core required: FahCore_7c.exe
[18:41:45] Core found.
[18:41:47] Working on queue slot 06 [June 26 18:41:47 UTC]
[18:41:47] + Working ...
[18:42:04]
[18:42:04] *------------------------------*
[18:42:04] Folding@Home Double Gromacs Core C
[18:42:04] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[18:42:04]
[18:42:04] Preparing to commence simulation
[18:42:04] - Files status OK
[18:42:04] - Expanded 233602 -> 640092 (decompressed 274.0 percent)
[18:42:04]
[18:42:04] Project: 3863 (Run 545, Clone 10, Gen 10)
[18:42:04]
[18:42:05] Assembly optimizations on if available.
[18:42:05] Entering M.D.
[18:42:11] Will resume from checkpoint file
[18:42:13] Working on p3863_fkbprelative_ligand
[18:42:13] Completed 0 out of 1500000 steps  (0%)
[18:42:14] Extra SSE2 boost OK
[18:42:15] Resuming from checkpoint
[18:42:16] Verified work/wudata_06.log
[18:42:16] Verified work/wudata_06.edr
[18:42:16] Verified work/wudata_06.xvg
[18:42:16] Verified work/wudata_06.trr
[18:42:16] Verified work/wudata_06.xtc
[18:42:16] Completed 107101 out of 1500000 steps  (7%)
[18:57:16] Timer requesting checkpoint
[19:12:16] Timer requesting checkpoint
[19:27:16] Timer requesting checkpoint
[19:30:16] Completed 120000 out of 1500000 steps  (8%)
[19:45:17] Timer requesting checkpoint
[20:00:21] Timer requesting checkpoint
[20:15:21] Timer requesting checkpoint
[20:30:21] Timer requesting checkpoint
[20:41:59] Completed 135000 out of 1500000 steps  (9%)
[20:57:06] Timer requesting checkpoint
[21:12:06] Timer requesting checkpoint
[21:27:06] Timer requesting checkpoint
[21:27:37] Completed 150000 out of 1500000 steps  (10%)
[21:42:39] Timer requesting checkpoint
[21:57:39] Timer requesting checkpoint
Reason: Added code tags.
[20:45:25]
The above shows where the client was likely shutdown ungracefully, causing file consistency problems (some files were updated, some not.). So on restart, so did the client.
Please also enclose log snips inside the code tags, as above...
harry48
Post by harry48 »
sorry the logs have gone only have them from the 27th , thanks for your help , harry
