171.65.103.98 - Cannot get GPU WU's
I have 4 clients that have been trying to get work for over an hour now. I also can no longer get to the server status page. Every time Stanford schedules work on the servers something goes wrong. Heck of a way to run a railroad.
Re: 171.65.103.98 - Cannot get GPU WU's
Can now get Nvidia client WU's but still unable to connect to assignment server for ATI Client WU's.
chluk2425
- Hardware configuration: Q9550 @ 3.8GHz
Asus P5Q-D
HIS HD4870 @820 w/ ccc 9.3 Vista 64bit
G-Skills DDR21066 2*2G
Seagate 500G *2 RAID1
same here... using ATi, can't get any job from the server...
This is related to this announcement : viewtopic.php?f=24&t=9997
Still unable to get ATI wu's. Its now been down for over 4 hours.
Well, the News Blog from 4 days ago says "it is possible that the GPU AS and PS3 AS will be down, although we are working on migrating those this week to avoid downtime." followed by "At its worst, those servers should only be down for about 3 hours, assuming all goes well with the infrastructure work being done."
Somehow "at it's worst" and "assuming all goes well" are sort of contradictoory. I'm sure the AS will be back on-line as soon as they can get it functioning. I can confirm that I cannot connect to http://171.65.103.98:8080/ from here, either, so there's nothing you can do except be patient.
Bruce,bruce wrote:Well, the News Blog from 4 days ago says "it is possible that the GPU AS and PS3 AS will be down, although we are working on migrating those this week to avoid downtime." followed by "At its worst, those servers should only be down for about 3 hours, assuming all goes well with the infrastructure work being done."
Thanks for that information and confirmation. It does help to know that there are still issues. I hate the red status box in Fahmon, but I will try to be patient as you suggest. Again thanks.
chluk2425
Asus P5Q-D
still down....
that a bit has been an hour or even more ....
it said accepting from server statue, but i can't get any work..
[edit]
i understand that it's holiday today.... but does anyone aware that the server is down again?...
[19:06:13] Work directory not found. Creating...
[19:06:13] Could not open work queue, generating new queue...
[19:06:13] Initialization complete
[19:06:13] - Preparing to get new work unit...
[19:06:13] + Attempting to get work packet
[19:06:13] - Autosending finished units... [May 19 19:06:13 UTC]
[19:06:13] Trying to send all finished work units
[19:06:13] + No unsent completed units remaining.
[19:06:13] - Autosend completed
[19:06:13] - Will indicate memory of 4095 MB
[19:06:13] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 7, Stepping: 10
[19:06:13] - Connecting to assignment server
[19:06:13] Connecting to http://assign-GPU.stanford.edu:8080/
[19:06:14] Posted data.
[19:06:14] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[19:06:14] + Couldn't get work instructions.
[19:06:14] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[19:06:22] + Attempting to get work packet
[19:06:22] - Will indicate memory of 4095 MB
[19:06:22] - Connecting to assignment server
[19:06:22] Connecting to http://assign-GPU.stanford.edu:8080/
[19:06:22] Posted data.
[19:06:22] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[19:06:22] + Couldn't get work instructions.
[19:06:22] - Attempt #2 to get work failed, and no other work to do.
[19:06:40] + Attempting to get work packet
[19:06:40] - Will indicate memory of 4095 MB
[19:06:40] - Connecting to assignment server
[19:06:40] Connecting to http://assign-GPU.stanford.edu:8080/
[19:06:41] Posted data.
[19:06:41] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[19:06:41] + Couldn't get work instructions.
[19:06:41] - Attempt #3 to get work failed, and no other work to do.
[19:07:07] + Attempting to get work packet
[19:07:07] - Will indicate memory of 4095 MB
[19:07:07] - Connecting to assignment server
[19:07:07] Connecting to http://assign-GPU.stanford.edu:8080/
[19:07:08] Posted data.
[19:07:08] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[19:07:08] + Couldn't get work instructions.
[19:07:08] - Attempt #4 to get work failed, and no other work to do.
[19:07:53] + Attempting to get work packet
[19:07:53] - Will indicate memory of 4095 MB
[19:07:53] - Connecting to assignment server
[19:07:53] Connecting to http://assign-GPU.stanford.edu:8080/
[19:07:54] Posted data.
[19:07:54] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[19:07:54] + Couldn't get work instructions.
[19:07:54] - Attempt #5 to get work failed, and no other work to do.
[19:09:15] + Attempting to get work packet
[19:09:15] - Will indicate memory of 4095 MB
[19:09:15] - Connecting to assignment server
[19:09:15] Connecting to http://assign-GPU.stanford.edu:8080/
[19:09:16] Posted data.
[19:09:16] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[19:09:16] + Couldn't get work instructions.
[19:09:16] - Attempt #6 to get work failed, and no other work to do.
[edit]
I've been away from F@H for a while due to PC stability issues, today when I choose to try making a comeback nothing works, lol...
Been trying to get a new WU since just before 6PM CET, and now it's past 11PM CET. My log file looks like this all the way through:
What's wrong?[21:04:57] + Attempting to get work packet
[21:04:57] - Connecting to assignment server
[21:04:58] - Successful: assigned to (171.64.65.103).
[21:04:58] + News From Folding@Home: Welcome to Folding@Home
[21:04:58] Loaded queue successfully.
[21:04:59] + Could not connect to Work Server
[21:04:59] - Attempt #5 to get work failed, and no other work to do.
[21:06:31] + Attempting to get work packet
[21:06:31] - Connecting to assignment server
[21:06:32] + No appropriate work server was available; will try again in a bit.
[21:06:32] + Couldn't get work instructions.
[21:06:32] - Attempt #6 to get work failed, and no other work to do.
Mekhed
- Hardware configuration: HD 3870 / HD 3870x2 / HD 4870 / E8400 / Q9550 / AMD 4800+ x2 939
I've got 5 ATI clients like this.
[18:28:20] + Attempting to send results [May 19 18:28:20 UTC]
[18:28:20] - Reading file work/wuresults_02.dat from core
[18:28:20] (Read 238737 bytes from disk)
[18:28:20] Connecting to http://171.64.65.103:8080/
[18:28:25] Posted data.
[18:28:25] Initial: 0000; - Uploaded at ~46 kB/s
[18:28:25] - Averaged speed for that direction ~41 kB/s
[18:28:25] + Results successfully sent
[18:28:25] Thank you for your contribution to Folding@Home.
[18:28:25] + Number of Units Completed: 331
[18:28:29] Trying to send all finished work units
[18:28:29] + No unsent completed units remaining.
[18:28:29] - Preparing to get new work unit...
[18:28:29] + Attempting to get work packet
[18:28:29] - Will indicate memory of 3070 MB
[18:28:29] - Connecting to assignment server
[18:28:29] Connecting to http://assign-GPU.stanford.edu:8080/
[18:28:30] Posted data.
[18:28:30] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:28:30] + Couldn't get work instructions.
[18:28:30] - Attempt #1 to get work failed, and no other work to do.
[18:28:39] + Attempting to get work packet
[18:28:39] - Will indicate memory of 3070 MB
[18:28:39] - Connecting to assignment server
[18:28:39] Connecting to http://assign-GPU.stanford.edu:8080/
[18:28:40] Posted data.
[18:28:40] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:28:40] + Couldn't get work instructions.
[18:28:40] - Attempt #2 to get work failed, and no other work to do.
[18:28:55] + Attempting to get work packet
[18:28:55] - Will indicate memory of 3070 MB
[18:28:55] - Connecting to assignment server
[18:28:55] Connecting to http://assign-GPU.stanford.edu:8080/
[18:28:56] Posted data.
[18:28:56] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:28:56] + Couldn't get work instructions.
[18:28:56] - Attempt #3 to get work failed, and no other work to do.
[18:29:18] + Attempting to get work packet
[18:29:18] - Will indicate memory of 3070 MB
[18:29:18] - Connecting to assignment server
[18:29:18] Connecting to http://assign-GPU.stanford.edu:8080/
[18:29:19] Posted data.
[18:29:19] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:29:19] + Couldn't get work instructions.
[18:29:19] - Attempt #4 to get work failed, and no other work to do.
[18:30:06] + Attempting to get work packet
[18:30:06] - Will indicate memory of 3070 MB
[18:30:06] - Connecting to assignment server
[18:30:06] Connecting to http://assign-GPU.stanford.edu:8080/
[18:30:07] Posted data.
[18:30:07] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:30:07] + Couldn't get work instructions.
[18:30:07] - Attempt #5 to get work failed, and no other work to do.
[18:31:35] + Attempting to get work packet
[18:31:35] - Will indicate memory of 3070 MB
[18:31:35] - Connecting to assignment server
[18:31:35] Connecting to http://assign-GPU.stanford.edu:8080/
[18:31:35] Posted data.
[18:31:35] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:31:35] + Couldn't get work instructions.
[18:31:35] - Attempt #6 to get work failed, and no other work to do.
[18:34:29] + Attempting to get work packet
[18:34:29] - Will indicate memory of 3070 MB
[18:34:29] - Connecting to assignment server
[18:34:29] Connecting to http://assign-GPU.stanford.edu:8080/
[18:34:30] Posted data.
[18:34:30] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:34:30] + Couldn't get work instructions.
[18:34:30] - Attempt #7 to get work failed, and no other work to do.
[18:40:03] + Attempting to get work packet
[18:40:03] - Will indicate memory of 3070 MB
[18:40:03] - Connecting to assignment server
[18:40:03] Connecting to http://assign-GPU.stanford.edu:8080/
[18:40:03] Posted data.
[18:40:03] Initial: 40AB; - Successful: assigned to (171.64.65.103).
[18:40:03] + News From Folding@Home: Welcome to Folding@Home
[18:40:03] Loaded queue successfully.
[18:40:03] Connecting to http://171.64.65.103:8080/
[18:40:04] Posted data.
[18:40:04] Initial: 0000; + Could not connect to Work Server
[18:40:04] - Attempt #8 to get work failed, and no other work to do.
[18:50:47] + Attempting to get work packet
[18:50:47] - Will indicate memory of 3070 MB
[18:50:47] - Connecting to assignment server
[18:50:47] Connecting to http://assign-GPU.stanford.edu:8080/
[18:50:48] Posted data.
[18:50:48] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:50:48] + Couldn't get work instructions.
[18:50:48] - Attempt #9 to get work failed, and no other work to do.
[19:12:20] + Attempting to get work packet
[19:12:20] - Will indicate memory of 3070 MB
[19:12:20] - Connecting to assignment server
[19:12:20] Connecting to http://assign-GPU.stanford.edu:8080/
[19:12:21] Posted data.
[19:12:21] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[19:12:21] + Couldn't get work instructions.
[19:12:21] - Attempt #10 to get work failed, and no other work to do.
[19:55:06] + Attempting to get work packet
[19:55:06] - Will indicate memory of 3070 MB
[19:55:06] - Connecting to assignment server
[19:55:06] Connecting to http://assign-GPU.stanford.edu:8080/
[19:55:06] Posted data.
[19:55:06] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[19:55:06] + Couldn't get work instructions.
[19:55:06] - Attempt #11 to get work failed, and no other work to do.
[20:43:09] + Attempting to get work packet
[20:43:09] - Will indicate memory of 3070 MB
[20:43:09] - Connecting to assignment server
[20:43:09] Connecting to http://assign-GPU.stanford.edu:8080/
[20:43:10] Posted data.
[20:43:10] Initial: 40AB; - Successful: assigned to (171.64.65.103).
[20:43:10] + News From Folding@Home: Welcome to Folding@Home
[20:43:10] Loaded queue successfully.
[20:43:10] Connecting to http://171.64.65.103:8080/
[20:43:11] Posted data.
[20:43:11] Initial: 0000; + Could not connect to Work Server
[20:43:11] - Attempt #12 to get work failed, and no other work to do.
[21:31:20] + Attempting to get work packet
[21:31:20] - Will indicate memory of 3070 MB
[21:31:20] - Connecting to assignment server
[21:31:20] Connecting to http://assign-GPU.stanford.edu:8080/
[21:31:21] Posted data.
[21:31:21] Initial: 40AB; - Successful: assigned to (171.64.65.103).
[21:31:21] + News From Folding@Home: Welcome to Folding@Home
[21:31:21] Loaded queue successfully.
[21:31:21] Connecting to http://171.64.65.103:8080/
[21:31:21] Initial: 0000; + Could not connect to Work Server
[21:31:21] - Attempt #13 to get work failed, and no other work to do.
[21:37:54] - Autosending finished units... [May 19 21:37:54 UTC]
[21:37:54] Trying to send all finished work units
[21:37:54] + No unsent completed units remaining.
[21:37:54] - Autosend completed-
VijayPande
- Pande Group Member
Thanks for the heads up. This was a tricky side effect of the migration of the GPU-AS. This is now resolved. Sorry it took so long to pin this one down!
Prof. Vijay Pande, PhD
Chair, Biophysics
Stanford University
Chair, Biophysics
Stanford University
Mekhed
Thank You Vijay
