Project: 5900 (Run 9, Clone 562, Gen 23)
[12:11:42] + Closed connections
[12:11:47]
[12:11:47] + Processing work unit
[12:11:47] Core required: FahCore_14.exe
[12:11:47] Core found.
[12:11:47] Working on queue slot 01 [April 28 12:11:47 UTC]
[12:11:47] + Working ...
[12:11:47] - Calling '.\FahCore_14.exe -dir work/ -suffix 01 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 4168 -version 620'
[12:11:47]
[12:11:47] *------------------------------*
[12:11:47] Folding@Home GPU Core - Beta
[12:11:47] Version 1.25 (Mon Mar 2 19:49:32 PST 2009)
[12:11:47]
[12:11:47] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:11:47] Build host: vspm46
[12:11:47] Board Type: Nvidia
[12:11:47] Core :
[12:11:47] Preparing to commence simulation
[12:11:47] - Looking at optimizations...
[12:11:47] - Created dyn
[12:11:47] - Files status OK
[12:11:48] - Expanded 70148 -> 360060 (decompressed 513.2 percent)
[12:11:48] Called DecompressByteArray: compressed_data_size=70148 data_size=360060, decompressed_data_size=360060 diff=0
[12:11:48] - Digital signature verified
[12:11:48]
[12:11:48] Project: 5900 (Run 9, Clone 562, Gen 23)
[12:11:48]
[12:11:48] Assembly optimizations on if available.
[12:11:48] Entering M.D.
[12:11:54] Tpr hash work/wudata_01.tpr: 4109588167 2269031020 640620253 3753872212 208673505
[12:11:54] Working on Protein
[12:11:56] Client config found, loading data.
[12:11:56] Starting GUI Server
[12:13:27] Completed 1%
{snip}
[14:47:10] Completed 72%
[14:49:07] SEH code: 3221225477
[14:49:07] Run: exception thrown during GuardedRun
[14:49:07] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[14:49:07] Going to send back what have done -- stepsTotalG=2000000
[14:49:07] Work fraction=0.7273 steps=2000000.
[14:49:11] logfile size=96875 infoLength=96875 edr=0 trr=23
[14:49:11] - Writing 97411 bytes of core data to disk...
[14:49:11] Done: 96899 -> 6015 (compressed to 6.2 percent)
[14:49:11] ... Done.
[14:49:11]
[14:49:11] Folding@home Core Shutdown: EARLY_UNIT_END
[14:49:13] CoreStatus = 72 (114)
[14:49:13] Sending work to server
[14:49:13] Project: 5900 (Run 9, Clone 562, Gen 23)
[14:49:13] - Read packet limit of 540015616... Set to 524286976.
[14:49:13] + Attempting to send results [April 28 14:49:13 UTC]
[14:49:13] - Reading file work/wuresults_01.dat from core
[14:49:13] (Read 6527 bytes from disk)
[14:49:13] Connecting to http://171.64.122.70:8080/
[14:49:14] Posted data.
[14:49:14] Initial: 0000; - Uploaded at ~7 kB/s
[14:49:14] - Averaged speed for that direction ~51 kB/s
[14:49:14] + Results successfully sent
[14:49:14] Thank you for your contribution to Folding@Home.Still catching up on the Lenovo (I waited to get the memtestG80 results, which I had to run over a period of time). Unsatble machine (two days after last WU problem).
Project: 5900 (Run 6, Clone 293, Gen 48)
[13:45:23] + Closed connections
[13:45:23]
[13:45:23] + Processing work unit
[13:45:23] Core required: FahCore_14.exe
[13:45:23] Core found.
[13:45:23] Working on queue slot 04 [April 30 13:45:23 UTC]
[13:45:23] + Working ...
[13:45:23] - Calling '.\FahCore_14.exe -dir work/ -suffix 04 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 4168 -version 620'
[13:45:23]
[13:45:23] *------------------------------*
[13:45:23] Folding@Home GPU Core - Beta
[13:45:23] Version 1.25 (Mon Mar 2 19:49:32 PST 2009)
[13:45:23]
[13:45:23] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:45:23] Build host: vspm46
[13:45:23] Board Type: Nvidia
[13:45:23] Core :
[13:45:23] Preparing to commence simulation
[13:45:23] - Looking at optimizations...
[13:45:23] - Created dyn
[13:45:23] - Files status OK
[13:45:23] - Expanded 70257 -> 360060 (decompressed 512.4 percent)
[13:45:23] Called DecompressByteArray: compressed_data_size=70257 data_size=360060, decompressed_data_size=360060 diff=0
[13:45:24] - Digital signature verified
[13:45:24]
[13:45:24] Project: 5900 (Run 6, Clone 293, Gen 48)
[13:45:24]
[13:45:24] Assembly optimizations on if available.
[13:45:24] Entering M.D.
[13:45:30] Tpr hash work/wudata_04.tpr: 1729566050 4040402945 4000142696 3399358747 1500310308
[13:45:31] Working on Protein
[13:45:32] Client config found, loading data.
[13:45:32] Starting GUI Server
[13:46:43] Completed 1%
{snip}
[14:24:12] Completed 20%
[14:25:18] SEH code: 3221225477
[14:25:18] Run: exception thrown during GuardedRun
[14:25:18] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[14:25:18] Going to send back what have done -- stepsTotalG=2000000
[14:25:18] Work fraction=0.2040 steps=2000000.
[14:25:22] logfile size=33093 infoLength=33093 edr=0 trr=23
[14:25:22] - Writing 33629 bytes of core data to disk...
[14:25:22] Done: 33117 -> 4809 (compressed to 14.5 percent)
[14:25:22] ... Done.
[14:25:22]
[14:25:22] Folding@home Core Shutdown: UNSTABLE_MACHINE
[14:25:25] CoreStatus = 7A (122)
[14:25:25] Sending work to server
[14:25:25] Project: 5900 (Run 6, Clone 293, Gen 48)
[14:25:25] - Read packet limit of 540015616... Set to 524286976.
[14:25:25] + Attempting to send results [April 30 14:25:25 UTC]
[14:25:25] - Reading file work/wuresults_04.dat from core
[14:25:25] (Read 5321 bytes from disk)
[14:25:25] Connecting to http://171.64.122.70:8080/
[14:25:28] Posted data.
[14:25:28] Initial: 0000; - Uploaded at ~2 kB/s
[14:25:28] - Averaged speed for that direction ~83 kB/s
[14:25:28] + Results successfully sent
[14:25:28] Thank you for your contribution to Folding@Home.Code: Select all
[00:46:05] + Closed connections
[00:46:05]
[00:46:05] + Processing work unit
[00:46:05] Core required: FahCore_14.exe
[00:46:05] Core found.
[00:46:05] Working on queue slot 04 [May 2 00:46:05 UTC]
[00:46:05] + Working ...
[00:46:05] - Calling '.\FahCore_14.exe -dir work/ -suffix 04 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 4168 -version 620'
[00:46:06]
[00:46:06] *------------------------------*
[00:46:06] Folding@Home GPU Core - Beta
[00:46:06] Version 1.25 (Mon Mar 2 19:49:32 PST 2009)
[00:46:06]
[00:46:06] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:46:06] Build host: vspm46
[00:46:06] Board Type: Nvidia
[00:46:06] Core :
[00:46:06] Preparing to commence simulation
[00:46:06] - Looking at optimizations...
[00:46:06] - Created dyn
[00:46:06] - Files status OK
[00:46:06] - Expanded 70325 -> 360060 (decompressed 511.9 percent)
[00:46:06] Called DecompressByteArray: compressed_data_size=70325 data_size=360060, decompressed_data_size=360060 diff=0
[00:46:06] - Digital signature verified
[00:46:06]
[00:46:06] Project: 5900 (Run 5, Clone 629, Gen 19)
[00:46:06]
[00:46:06] Assembly optimizations on if available.
[00:46:06] Entering M.D.
[00:46:12] Tpr hash work/wudata_04.tpr: 2063065014 3609296950 891063415 2419175989 2431757096
[00:46:13] Working on Protein
[00:46:14] Client config found, loading data.
[00:46:14] Starting GUI Server
[00:47:45] Completed 1%
{snip}
[04:18:24] Completed 98%
[04:19:07] SEH code: 3221225477
[04:19:07] Run: exception thrown during GuardedRun
[04:19:07] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[04:19:07] Going to send back what have done -- stepsTotalG=2000000
[04:19:07] Work fraction=0.9821 steps=2000000.
[04:19:11] logfile size=172179 infoLength=172179 edr=0 trr=23
[04:19:11] - Writing 172715 bytes of core data to disk...
[04:19:11] Done: 172203 -> 6859 (compressed to 3.9 percent)
[04:19:11] ... Done.
[04:19:11]
[04:19:11] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:19:14] CoreStatus = 7A (122)
[04:19:14] Sending work to server
[04:19:14] Project: 5900 (Run 5, Clone 629, Gen 19)
[04:19:14] - Read packet limit of 540015616... Set to 524286976.
[04:19:14] + Attempting to send results [May 2 04:19:14 UTC]
[04:19:14] - Reading file work/wuresults_04.dat from core
[04:19:14] (Read 7371 bytes from disk)
[04:19:14] Connecting to http://171.64.122.70:8080/
[04:19:14] Posted data.
[04:19:14] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[04:19:14] - Uploaded at ~16 kB/s
[04:19:14] - Averaged speed for that direction ~107 kB/s
[04:19:14] + Results successfully sent
[04:19:14] Thank you for your contribution to Folding@Home.Project: 5900 (Run 12, Clone 510, Gen 36)
Project: 5900 (Run 9, Clone 734, Gen 3)
Project: 5900 (Run 10, Clone 884, Gen 3)
Project: 5900 (Run 1, Clone 626, Gen 15)
Project: 5900 (Run 13, Clone 567, Gen 27)
Edit: to add title to first WU.
