Project: 2669 (Run 3, Clone 192, Gen 30)
One of my machines started the unit listed in the subject on Thursday, and finished it Friday. The log shows that it was turned in, but no credit has show up in the last 24 hours. Did the unit actually make it, or does a collection server need a kick?
--- Opening Log file [May 14 12:43:38 UTC]
# Mac OS X SMP Console Edition ################################################
                       Folding@Home Client Version 6.24R1
                          http://folding.stanford.edu
Launch directory: /Users/********/Library/Folding@home
Executable: ./fah6
Arguments: -oneunit
[12:43:38] - Ask before connecting: No
[12:43:38] - User name: Joe_H (Team 38910)
[12:43:38] - User ID: 74A191A36AA6AED3
[12:43:38] - Machine ID: 1
[12:43:38]
[12:43:38] Loaded queue successfully.
[12:43:38] - Preparing to get new work unit...
[12:43:38] Cleaning up work directory
[12:43:39] + Attempting to get work packet
[12:43:39] - Connecting to assignment server
[12:43:40] - Successful: assigned to (171.64.65.56).
[12:43:40] + News From Folding@Home: Welcome to Folding@Home
[12:43:40] Loaded queue successfully.
[12:44:06] + Closed connections
[12:44:06]
[12:44:06] + Processing work unit
[12:44:06] At least 4 processors must be requested; read 1.
[12:44:06] Core required: FahCore_a2.exe
[12:44:06] Core found.
[12:44:06] Working on queue slot 03 [May 14 12:44:06 UTC]
[12:44:06] + Working ...
[12:44:07]
[12:44:07] *------------------------------*
[12:44:07] Folding@Home Gromacs SMP Core
[12:44:07] Version 2.07 (Sun Apr 19 14:29:51 PDT 2009)
[12:44:07]
[12:44:07] Preparing to commence simulation
[12:44:07] - Ensuring status. Pleases...
[12:44:07] - Working with standard loops on this execution.
[12:44:07] - Files status OK
[12:44:08] - Expanded Called DecompressByteArray: compressed_data_size=Called DecompressByteArray: compressed_data_size=4844352 data_size=- Digital signature verified
[12:44:08]
[12:44:08] Project: 2669 (Run - Digital signature verified
[12:44:08]
[12:44:08] Project: 2669 (Run 3, Clone 192, Gen 30)
[12:44:08]
[12:44:09] M.D.
[12:44:09] ing M.D.
[12:44:18] one 192, Gen 30)
[12:44:18]
[12:44:18] Entering M.D.
[12:44:28]  (0%)
[12:59:00] Completed 2500 out of 250000 steps  (1%)
[13:13:32] Completed 5000 out of 250000 steps  (2%)
[13:28:05] Completed 7500 out of 250000 steps  (3%)
[13:42:38] Completed 10000 out of 250000 steps  (4%)
[13:57:11] Completed 12500 out of 250000 steps  (5%)
[12:00:41] Completed 240000 out of 250000 steps  (96%)
[12:15:16] Completed 242500 out of 250000 steps  (97%)
[12:29:47] Completed 245000 out of 250000 steps  (98%)
[12:44:16] Completed 247500 out of 250000 steps  (99%)
[12:58:50] Completed 250000 out of 250000 steps  (100%)
[12:58:52] DynamicWrapper: Finished Work Unit: sleep=10000
[12:59:02]
[12:59:02] Finished Work Unit:
[12:59:02] - Reading up to 21148416 from "work/wudata_03.trr": Read 21148416
[12:59:02] trr file hash check passed.
[12:59:02] - Reading up to 4470700 from "work/wudata_03.xtc": Read 4470700
[12:59:02] xtc file hash check passed.
[12:59:02] edr file hash check passed.
[12:59:02] logfile size: 192671
[12:59:02] Leaving Run
[12:59:04] - Writing 25956539 bytes of core data to disk...
[12:59:05]   ... Done.
[12:59:16] - Shutting down core
[12:59:16]
[12:59:16] Folding@home Core Shutdown: FINISHED_UNIT
[13:02:26] CoreStatus = 64 (100)
[13:02:26] Sending work to server
[13:02:26] Project: 2669 (Run 3, Clone 192, Gen 30)
[13:02:26] + Attempting to send results [May 15 13:02:26 UTC]
[13:07:36] + Results successfully sent
[13:07:36] Thank you for your contribution to Folding@Home.
[13:07:36] + Number of Units Completed: 11
[13:07:40] + -oneunit flag given and have now finished a unit. Exiting.- Preparing to get new work unit...
[13:07:40] Cleaning up work directory
Folding@Home Client Shutdown.
susato
Re: Project: 2669 (Run 3, Clone 192, Gen 30)
Post by susato »
It isn't in the database yet. I suggest you give it a few more days (it's the weekend after all) then ask one of the mods here for a re-check.
I notice you used the -oneunit flag to shut down Folding after the unit completed. If you have restarted this instance - did you get the same WU back again, or are you now folding a different one?
Got a different WU, same project but in Run 11. Figured I would report this problem and check back in a bit to see what comes of it.
As for the -oneunit flag, I have found that on that machine it helps make certain the work queue gets properly cleaned up on shutdown and gives me a chance to be certain it won't have started and then kept a partially completed unit past the expiration. That machine is not running all the time, sometimes off for several days, and many of these units have short expiration times.
Still no sign of credit on this unit, did it ever make it? Machine has completed, turned in and received credit for a different 2669 unit over the weekend already.
Your WU has not showed up in the mod db yet. Apparently it was downloaded [May 14 12:43:40 UTC] and uploaded at [May 15 13:02:26 UTC] so you had the WU 1.01 days which is well within the deadline of 3.0 days. I'll ask the Pande Group to look into this one since I can't see anything wrong in FAHlog.txt. (I can't promise when they'll be able to respond.)
