stats update issue?
AgrFan
stats update issue?
Post by AgrFan »
I'm missing points for a SMP A2 unit from yesterday ... stats update just ran and the points are still missing.
Can a mod please check this unit to see what happened to it --> Project: 2669 (Run 11, Clone 138, Gen 114)
Thanks!
Aardvark
Re: stats update issue?
Post by Aardvark »
AgraFan.
There is a section on the Forum titled "Issues With a Specific WU" that is designed to handle
the sort of request you have. Posting there helps the process run at a optimum.
What is past is prologue!
