Updated public beta clients
Any announcements about FAH policy, servers and new projects will be made here.
Locked
kasson
Pande Group Member
Post by kasson »
We are in the process of releasing the updated beta clients. So far, beta2 has been released for OSX-Intel-Console and Linux versions. These are available from the download page. Other clients will be coming shortly. These clients will expire August 2, 2008.
The Linux and OSX clients have no major differences beta1 to beta2. We anticipate a few minor changes in the Windows SMP client.
Thanks for contributing! Please direct questions and comments to the appropriate client-specific forums.
Beberg
Pande Group Member
Re: Updated public beta clients
Post by Beberg »
Three more updated betas ready and waiting on the downloads page:
Windows Console
Windows GUI
GPU console
No significant changes to these three.
kasson
Pande Group Member
Post by kasson »
The Windows SMP client v5.91beta6 is now posted. This client has one substantial change--it checks on startup to make sure mpiexec can run. Hopefully this will clarify of the install/configuration problems and provide guidance to users on how to fix them.
(The underlying issues with mpiexec are inherent to the MPI libraries and not to FAH; we may at some point switch MPI libraries, but debugging the libraries is beyond our scope.)
Beberg
Pande Group Member
Post by Beberg »
Two more:
OSX Intel SMP Installer
OSX PPC
Beberg
Pande Group Member
Post by Beberg »
The Windows CPU console and GPU console 6.01beta3's have been put on the downloads page. These should resolve the very large log file issue.
Beberg
Pande Group Member
Post by Beberg »
Windows CPU console and GPU console 6.01beta4's have been put on the downloads page.
Fix: Crash at start on some systems.
Beberg
Pande Group Member
Post by Beberg »
I have just put updated6.01beta5 Windows CPU and GPU (Radeon X16xx, X18xx, X19xx and ATI FireStream) clients up. Both console and System Tray versions.
Please note that the system tray version DO NOT yet contain the new viewer, so this beta has no graphics. Please test them for stability and functionality, as a rather large amount of code was moved about. Pausing, restart, try to start 2 systray clients (which it should let you), and check the logs and other behaviors. Generally try and break it :)
Thanks.
Locked
