Project: 2671 (Run 49, Clone 68, Gen 28)
Post by 314159 »
I apologize in advance for not editing this down more but I have little time today and wanted to alert the powers that be to this one ASAP.
It looks like one that should be flagged as a BAD, BAD, WU. :ewink:
We'll see in a few days if someone manages to complete it on another platform vs. Linux.
[17:01:57] + Attempting to send results [May 12 17:01:57 UTC]
[17:01:57] - Reading file work/wuresults_08.dat from core
[17:01:57]   (Read 49172675 bytes from disk)
[17:01:57] Connecting to http://171.67.108.24:8080/
[17:06:57] Posted data.
[17:06:57] Initial: 0000; - Uploaded at ~155 kB/s
[17:07:05] - Averaged speed for that direction ~147 kB/s
[17:07:05] + Results successfully sent
[17:07:05] Thank you for your contribution to Folding@Home.
[17:07:05] + Number of Units Completed: 58
[17:07:20] Core required: FahCore_a2.exe
[17:07:20] Core found.
[17:07:21] Working on queue slot 09 [May 12 17:07:21 UTC]
[17:07:21] + Working ...
[17:07:21] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a2.exe -dir work/ -suffix 09 -checkpoint 15  -verbose -lifeline 5818 -version 624'
[17:07:21]
[17:07:21] *------------------------------*
[17:07:21] Folding@Home Gromacs SMP Core
[17:07:21] Version 2.07 (Sun Apr 19 14:51:09 PDT 2009)
[17:07:21]
[17:07:21] Preparing to commence simulation
[17:07:21] - Ensuring status. Please wait.
[17:07:30] - Assembly optimizations manually forced on.
[17:07:30] - Not checking prior termination.
[17:07:31] - Expanded 4837022 -> 24036661 (decompressed 496.9 percent)
[17:07:31] Called DecompressByteArray: compressed_data_size=4837022 data_size=24036661, decompressed_data_size=24036661 diff=0
[17:07:31] - Digital signature verified
[17:07:31]
[17:07:31] Project: 2671 (Run 49, Clone 68, Gen 28)
[17:07:31]
[17:07:31] Assembly optimizations on if available.
[17:07:31] Entering M.D.
[17:07:37] Using Gromacs checkpoints
[17:07:40] fcCheckPointResume: file hashes different -- aborting.
[17:07:40] s different -- aborting.
[17:07:44] CoreStatus = FF (255)
[17:07:44] Sending work to server
[17:07:44] Project: 2671 (Run 49, Clone 68, Gen 28)
[17:07:44] - Error: Could not get length of results file work/wuresults_09.dat
[17:07:44] - Error: Could not read unit 09 file. Removing from queue.
[17:07:44] Trying to send all finished work units
[17:07:44] + No unsent completed units remaining.
[17:07:44] - Preparing to get new work unit...
[17:07:44] + Attempting to get work packet
[17:07:46] Initial: 43AB; - Successful: assigned to (171.67.108.24).
[17:07:46] + News From Folding@Home: Welcome to Folding@Home
[17:07:46] Loaded queue successfully.
[17:07:46] Connecting to http://171.67.108.24:8080/
[17:07:53] Posted data.
[17:07:53] Initial: 0000; - Receiving payload (expected size: 4837534)
[17:07:59] - Downloaded at ~787 kB/s
[17:07:59] - Averaged speed for that direction ~1012 kB/s
[17:07:59] + Received work.
[17:07:59] Trying to send all finished work units
[17:07:59] + No unsent completed units remaining.
[17:07:59] + Closed connections
[17:08:04]
[17:08:04] + Processing work unit
[17:08:04] Core required: FahCore_a2.exe
[17:08:04] Core found.
[17:08:04] Working on queue slot 00 [May 12 17:08:04 UTC]
[17:08:04] + Working ...
[17:08:04] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a2.exe -dir work/ -suffix 00 -checkpoint 15 -verbose -lifeline 5818 -version 624'
[17:08:04]
[17:08:04] *------------------------------*
[17:08:04] Folding@Home Gromacs SMP Core
[17:08:04] Version 2.07 (Sun Apr 19 14:51:09 PDT 2009)
[17:08:04]
[17:08:04] Preparing to commence simulation
[17:08:04] - Ensuring status. Please wait.
[17:08:14] - Assembly optimizations manually forced on.
[17:08:14] - Not checking prior termination.
[17:08:15] - Expanded 4837022 -> 24036661 (decompressed 496.9 percent)
[17:08:15] Called DecompressByteArray: compressed_data_size=4837022 data_size=24036661, decompressed_data_size=24036661 diff=0
[17:08:15] - Digital signature verified
[17:08:15]
[17:08:15] Project: 2671 (Run 49, Clone 68, Gen 28)
[17:08:15]
[17:08:15] Assembly optimizations on if available.
[17:08:15] Entering M.D.
[17:08:21] Using Gromacs checkpoints
[17:08:24] fcCheckPointResume: file hashes different -- aborting.
[17:08:24] s different -- aborting.
[17:08:28] CoreStatus = FF (255)
[17:08:28] Sending work to server
[17:08:28] Project: 2671 (Run 49, Clone 68, Gen 28)
[17:08:28] - Error: Could not get length of results file work/wuresults_00.dat
[17:08:28] - Error: Could not read unit 00 file. Removing from queue.
[17:08:28] Trying to send all finished work units
[17:08:28] + No unsent completed units remaining.
[17:08:28] - Preparing to get new work unit...
[17:08:28] + Attempting to get work packet
[17:08:28] - Will indicate memory of 1000 MB
[17:08:28] - Connecting to assignment server
[17:08:28] Connecting to http://assign.stanford.edu:8080/
[17:08:29] Posted data.
[17:08:29] Initial: 43AB; - Successful: assigned to (171.67.108.24).
[17:08:29] + News From Folding@Home: Welcome to Folding@Home
[17:08:29] Loaded queue successfully.
[17:08:29] Connecting to http://171.67.108.24:8080/
[17:08:36] Posted data.
[17:08:36] Initial: 0000; - Receiving payload (expected size: 4837534)
[17:08:42] - Downloaded at ~787 kB/s
[17:08:42] - Averaged speed for that direction ~967 kB/s
[17:08:42] + Received work.
[17:08:42] Trying to send all finished work units
[17:08:42] + No unsent completed units remaining.
[17:08:42] + Closed connections
[17:08:47]
[17:08:47] + Processing work unit
[17:08:47] Core required: FahCore_a2.exe
[17:08:47] Core found.
[17:08:47] Working on queue slot 01 [May 12 17:08:47 UTC]
[17:08:47] + Working ...
[17:08:47] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a2.exe -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 5818 -version 624'
[17:08:48]
[17:08:48] *------------------------------*
[17:08:48] Folding@Home Gromacs SMP Core
[17:08:48] Version 2.07 (Sun Apr 19 14:51:09 PDT 2009)
[17:08:48]
[17:08:48] Preparing to commence simulation
[17:08:48] - Ensuring status. Please wait.
[17:08:57] - Assembly optimizations manually forced on.
[17:08:57] - Not checking prior termination.
[17:08:58] - Expanded 4837022 -> 24036661 (decompressed 496.9 percent)
[17:08:58] Called DecompressByteArray: compressed_data_size=4837022 data_size=24036661, decompressed_data_size=24036661 diff=0
[17:08:58] - Digital signature verified
[17:08:58]
[17:08:58] Project: 2671 (Run 49, Clone 68, Gen 28)
[17:08:58]
[17:08:58] Assembly optimizations on if available.
[17:08:58] Entering M.D.
[17:09:04] Using Gromacs checkpoints
[17:09:07] fcCheckPointResume: file hashes different -- aborting.
[17:09:07] s different -- aborting.
[17:09:11] CoreStatus = FF (255)
[17:09:11] Sending work to server
[17:09:11] Project: 2671 (Run 49, Clone 68, Gen 28)
[17:09:11] - Error: Could not get length of results file work/wuresults_01.dat
[17:09:11] - Error: Could not read unit 01 file. Removing from queue.
[17:09:11] Trying to send all finished work units
[17:09:11] + No unsent completed units remaining.
[17:09:11] - Preparing to get new work unit...
[17:09:11] + Attempting to get work packet
[17:09:11] - Will indicate memory of 1000 MB
[17:09:11] - Connecting to assignment server
[17:09:11] Connecting to http://assign.stanford.edu:8080/
[17:09:13] Posted data.
[17:09:13] Initial: 43AB; - Successful: assigned to (171.67.108.24).
[17:09:13] + News From Folding@Home: Welcome to Folding@Home
[17:09:13] Loaded queue successfully.
[17:09:13] Connecting to http://171.67.108.24:8080/
[17:09:15] Posted data.
[17:09:15] Initial: 0000; - Error: Bad packet type from server, expected work assignment
[17:09:15] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[17:09:30] + Attempting to get work packet
[17:09:30] - Will indicate memory of 1000 MB
[17:09:30] - Connecting to assignment server
[17:09:30] Connecting to http://assign.stanford.edu:8080/
[17:09:31] Posted data.
[17:09:31] Initial: 43AB; - Successful: assigned to (171.67.108.24).
[17:09:31] + News From Folding@Home: Welcome to Folding@Home
[17:09:32] Loaded queue successfully.
[17:09:32] Connecting to http://171.67.108.24:8080/
[17:09:38] Posted data.
[17:09:38] Initial: 0000; - Receiving payload (expected size: 4837418)
[17:09:44] - Downloaded at ~787 kB/s
[17:09:44] - Averaged speed for that direction ~931 kB/s
[17:09:44] + Received work.
[17:09:44] Trying to send all finished work units
[17:09:44] + No unsent completed units remaining.
[17:09:44] + Closed connections
[17:09:49]
[17:09:49] + Processing work unit
[17:09:49] Core required: FahCore_a2.exe
[17:09:49] Core found.
[17:09:49] Working on queue slot 02 [May 12 17:09:49 UTC]
[17:09:49] + Working ...
[17:09:49] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a2.exe -dir work/ -suffix 02 -checkpoint 15 -verbose -lifeline 5818 -version 624'
[17:09:49]
[17:09:49] *------------------------------*
[17:09:49] Folding@Home Gromacs SMP Core
[17:09:49] Version 2.07 (Sun Apr 19 14:51:09 PDT 2009)
[17:09:49]
[17:09:49] Preparing to commence simulation
[17:09:49] - Ensuring status. Please wait.
[17:09:59] - Assembly optimizations manually forced on.
[17:09:59] - Not checking prior termination.
[17:10:00] - Expanded 4836906 -> 24036661 (decompressed 496.9 percent)
[17:10:00] Called DecompressByteArray: compressed_data_size=4836906 data_size=24036661, decompressed_data_size=24036661 diff=0
[17:10:00] - Digital signature verified
[17:10:00]
[17:10:00] Project: 2671 (Run 49, Clone 75, Gen 28)
[17:10:00]
[17:10:00] Assembly optimizations on if available.
[17:10:00] Entering M.D.
[17:10:09] Completed 0 out of 250000 steps  (0%)
[17:16:31] Completed 2500 out of 250000 steps  (1%)
[17:22:51] Completed 5000 out of 250000 steps  (2%)
and etc.
John (from the central part of the Commonwealth of Virginia, U.S.A.)
A friendly visitor to what hopefully will remain a friendly Forum.
With thanks to all of the dedicated volunteers on the staff here!!
Re: Project: 2671 (Run 49, Clone 68, Gen 28)
There's no data for this WU in the DB ... but I don't expect we'll have a lot if it fail with the same error for everyone ... :(
