shiryunaga
Posts: 50 Joined: Tue Apr 14, 2009 6:51 am
Hardware configuration: Intel Core i3 2100 3092.91 MHz (99.77 x 31.0)
Post
by shiryunaga » Wed May 06, 2009 1:45 am
Nonzero force sum on GPU
[00:36:09] + Closed connections
[00:36:09]
[00:36:09] + Processing work unit
[00:36:09] Core required: FahCore_11.exe
[00:36:09] Core found.
[00:36:09] Working on queue slot 05 [May 6 00:36:09 UTC]
[00:36:09] + Working ...
[00:36:09] - Calling '.\FahCore_11.exe -dir work/ -suffix 05 -priority 96 -checkpoint 30 -service -verbose -lifeline 420 -version 623'
[00:36:09]
[00:36:09] *------------------------------*
[00:36:09] Folding@Home GPU Core - Beta
[00:36:09] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[00:36:09]
[00:36:09] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:36:09] Build host: amoeba
[00:36:09] Board Type: AMD
[00:36:09] Core :
[00:36:09] Preparing to commence simulation
[00:36:09] - Looking at optimizations...
[00:36:09] - Created dyn
[00:36:09] - Files status OK
[00:36:09] - Expanded 85755 -> 444252 (decompressed 518.0 percent)
[00:36:09] Called DecompressByteArray: compressed_data_size=85755 data_size=444252, decompressed_data_size=444252 diff=0
[00:36:09] - Digital signature verified
[00:36:09]
[00:36:09] Project: 4751 (Run 4, Clone 367, Gen 27)
[00:36:09]
[00:36:09] Assembly optimizations on if available.
[00:36:09] Entering M.D.
[00:36:15] Tpr hash work/wudata_05.tpr: 2177645689 1032610330 3415775883 2304359576 1001613337
[00:36:16] Working on 1254 p4751_lam5w_300K_g91
[00:36:16] Client config found, loading data.
[00:36:16] Starting GUI Server
[00:36:28] mdrun_gpu returned
[00:36:28] Nonzero force sum on GPU
[00:36:28]
[00:36:28] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:36:31] CoreStatus = 7A (122)
[00:36:31] Sending work to server
[00:36:31] Project: 4751 (Run 4, Clone 367, Gen 27)
[00:36:31] - Read packet limit of 540015616... Set to 524286976.
[00:36:31] - Error: Could not get length of results file work/wuresults_05.dat
[00:36:31] - Error: Could not read unit 05 file. Removing from queue.
[00:36:31] Trying to send all finished work units
[00:36:31] + No unsent completed units remaining.
[00:36:31] - Preparing to get new work unit...
[00:36:31] + Attempting to get work packet
[00:36:31] - Will indicate memory of 1022 MB
[00:36:31] - Connecting to assignment server
[00:36:31] Connecting to http://assign-GPU.stanford.edu:8080/
[00:37:15] Posted data.
[00:37:15] Initial: 40AB; - Successful: assigned to (171.64.65.103).
[00:37:15] + News From Folding@Home: GPU folding beta
[00:37:15] Loaded queue successfully.
[00:37:15] Connecting to http://171.64.65.103:8080/
[00:37:38] Posted data.
[00:37:38] Initial: 0000; - Receiving payload (expected size: 86267)
[00:37:58] - Downloaded at ~4 kB/s
[00:37:58] - Averaged speed for that direction ~3 kB/s
[00:37:58] + Received work.
[00:37:58] Trying to send all finished work units
[00:37:58] + No unsent completed units remaining.
[00:37:58] + Closed connections
[00:38:03]
[00:38:03] + Processing work unit
[00:38:03] Core required: FahCore_11.exe
[00:38:03] Core found.
[00:38:03] Working on queue slot 06 [May 6 00:38:03 UTC]
[00:38:03] + Working ...
[00:38:03] - Calling '.\FahCore_11.exe -dir work/ -suffix 06 -priority 96 -checkpoint 30 -service -verbose -lifeline 420 -version 623'
[00:38:03]
[00:38:03] *------------------------------*
[00:38:03] Folding@Home GPU Core - Beta
[00:38:03] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[00:38:03]
[00:38:03] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:38:03] Build host: amoeba
[00:38:03] Board Type: AMD
[00:38:03] Core :
[00:38:03] Preparing to commence simulation
[00:38:03] - Looking at optimizations...
[00:38:03] - Created dyn
[00:38:03] - Files status OK
[00:38:03] - Expanded 85755 -> 444252 (decompressed 518.0 percent)
[00:38:03] Called DecompressByteArray: compressed_data_size=85755 data_size=444252, decompressed_data_size=444252 diff=0
[00:38:03] - Digital signature verified
[00:38:03]
[00:38:03] Project: 4751 (Run 4, Clone 367, Gen 27)
[00:38:03]
[00:38:03] Assembly optimizations on if available.
[00:38:03] Entering M.D.
[00:38:09] Tpr hash work/wudata_06.tpr: 2177645689 1032610330 3415775883 2304359576 1001613337
[00:38:09] Working on 1254 p4751_lam5w_300K_g91
[00:38:10] Client config found, loading data.
[00:38:10] Starting GUI Server
[00:38:20] mdrun_gpu returned
[00:38:20] Nonzero force sum on GPU
[00:38:20]
[00:38:20] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:38:23] CoreStatus = 7A (122)
[00:38:23] Sending work to server
[00:38:23] Project: 4751 (Run 4, Clone 367, Gen 27)
[00:38:23] - Read packet limit of 540015616... Set to 524286976.
[00:38:23] - Error: Could not get length of results file work/wuresults_06.dat
[00:38:23] - Error: Could not read unit 06 file. Removing from queue.
[00:38:23] Trying to send all finished work units
[00:38:23] + No unsent completed units remaining.
[00:38:23] - Preparing to get new work unit...
[00:38:23] + Attempting to get work packet
[00:38:23] - Will indicate memory of 1022 MB
[00:38:23] - Connecting to assignment server
[00:38:23] Connecting to http://assign-GPU.stanford.edu:8080/
[00:38:27] Posted data.
[00:38:27] Initial: 40AB; - Successful: assigned to (171.64.65.103).
[00:38:27] + News From Folding@Home: GPU folding beta
[00:38:27] Loaded queue successfully.
[00:38:27] Connecting to http://171.64.65.103:8080/
[00:38:33] Posted data.
[00:38:33] Initial: 0000; - Receiving payload (expected size: 86267)
[00:38:50] - Downloaded at ~4 kB/s
[00:38:50] - Averaged speed for that direction ~3 kB/s
[00:38:50] + Received work.
[00:38:50] Trying to send all finished work units
[00:38:50] + No unsent completed units remaining.
[00:38:50] + Closed connections
[00:38:55]
[00:38:55] + Processing work unit
[00:38:55] Core required: FahCore_11.exe
[00:38:55] Core found.
[00:38:55] Working on queue slot 07 [May 6 00:38:55 UTC]
[00:38:55] + Working ...
[00:38:55] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -priority 96 -checkpoint 30 -service -verbose -lifeline 420 -version 623'
[00:38:55]
[00:38:55] *------------------------------*
[00:38:55] Folding@Home GPU Core - Beta
[00:38:55] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[00:38:55]
[00:38:55] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:38:55] Build host: amoeba
[00:38:55] Board Type: AMD
[00:38:55] Core :
[00:38:55] Preparing to commence simulation
[00:38:55] - Looking at optimizations...
[00:38:55] - Created dyn
[00:38:55] - Files status OK
[00:38:55] - Expanded 85755 -> 444252 (decompressed 518.0 percent)
[00:38:55] Called DecompressByteArray: compressed_data_size=85755 data_size=444252, decompressed_data_size=444252 diff=0
[00:38:55] - Digital signature verified
[00:38:55]
[00:38:55] Project: 4751 (Run 4, Clone 367, Gen 27)
[00:38:55]
[00:38:55] Assembly optimizations on if available.
[00:38:55] Entering M.D.
[00:39:01] Tpr hash work/wudata_07.tpr: 2177645689 1032610330 3415775883 2304359576 1001613337
[00:39:01] Working on 1254 p4751_lam5w_300K_g91
[00:39:02] Client config found, loading data.
[00:39:02] Starting GUI Server
[00:39:12] mdrun_gpu returned
[00:39:12] Nonzero force sum on GPU
[00:39:12]
[00:39:12] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:39:15] CoreStatus = 7A (122)
[00:39:15] Sending work to server
[00:39:15] Project: 4751 (Run 4, Clone 367, Gen 27)
[00:39:15] - Read packet limit of 540015616... Set to 524286976.
[00:39:15] - Error: Could not get length of results file work/wuresults_07.dat
[00:39:15] - Error: Could not read unit 07 file. Removing from queue.
[00:39:15] Trying to send all finished work units
[00:39:15] + No unsent completed units remaining.
[00:39:15] - Preparing to get new work unit...
[00:39:15] + Attempting to get work packet
[00:39:15] - Will indicate memory of 1022 MB
[00:39:15] - Connecting to assignment server
[00:39:15] Connecting to http://assign-GPU.stanford.edu:8080/
[00:39:17] Posted data.
[00:39:17] Initial: 40AB; - Successful: assigned to (171.64.65.103).
[00:39:17] + News From Folding@Home: GPU folding beta
[00:39:17] Loaded queue successfully.
[00:39:17] Connecting to http://171.64.65.103:8080/
[00:39:18] Posted data.
[00:39:18] Initial: 0000; - Receiving payload (expected size: 86267)
[00:39:40] - Downloaded at ~3 kB/s
[00:39:40] - Averaged speed for that direction ~3 kB/s
[00:39:40] + Received work.
[00:39:40] Trying to send all finished work units
[00:39:40] + No unsent completed units remaining.
[00:39:40] + Closed connections
[00:39:45]
[00:39:45] + Processing work unit
[00:39:45] Core required: FahCore_11.exe
[00:39:45] Core found.
[00:39:45] Working on queue slot 08 [May 6 00:39:45 UTC]
[00:39:45] + Working ...
[00:39:45] - Calling '.\FahCore_11.exe -dir work/ -suffix 08 -priority 96 -checkpoint 30 -service -verbose -lifeline 420 -version 623'
[00:39:45]
[00:39:45] *------------------------------*
[00:39:45] Folding@Home GPU Core - Beta
[00:39:45] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[00:39:45]
[00:39:45] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:39:45] Build host: amoeba
[00:39:45] Board Type: AMD
[00:39:45] Core :
[00:39:45] Preparing to commence simulation
[00:39:45] - Looking at optimizations...
[00:39:45] - Created dyn
[00:39:45] - Files status OK
[00:39:45] - Expanded 85755 -> 444252 (decompressed 518.0 percent)
[00:39:45] Called DecompressByteArray: compressed_data_size=85755 data_size=444252, decompressed_data_size=444252 diff=0
[00:39:45] - Digital signature verified
[00:39:45]
[00:39:45] Project: 4751 (Run 4, Clone 367, Gen 27)
[00:39:45]
[00:39:45] Assembly optimizations on if available.
[00:39:45] Entering M.D.
[00:39:51] Tpr hash work/wudata_08.tpr: 2177645689 1032610330 3415775883 2304359576 1001613337
[00:39:51] Working on 1254 p4751_lam5w_300K_g91
[00:39:52] Client config found, loading data.
[00:39:52] Starting GUI Server
[00:40:02] mdrun_gpu returned
[00:40:02] Nonzero force sum on GPU
[00:40:02]
[00:40:02] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:40:05] CoreStatus = 7A (122)
[00:40:05] Sending work to server
[00:40:05] Project: 4751 (Run 4, Clone 367, Gen 27)
[00:40:05] - Read packet limit of 540015616... Set to 524286976.
[00:40:05] - Error: Could not get length of results file work/wuresults_08.dat
[00:40:05] - Error: Could not read unit 08 file. Removing from queue.
[00:40:05] Trying to send all finished work units
[00:40:05] + No unsent completed units remaining.
[00:40:05] - Preparing to get new work unit...
[00:40:05] + Attempting to get work packet
[00:40:05] - Will indicate memory of 1022 MB
[00:40:05] - Connecting to assignment server
[00:40:05] Connecting to http://assign-GPU.stanford.edu:8080/
[00:40:08] Posted data.
[00:40:08] Initial: 40AB; - Successful: assigned to (171.64.65.103).
[00:40:08] + News From Folding@Home: GPU folding beta
[00:40:08] Loaded queue successfully.
[00:40:08] Connecting to http://171.64.65.103:8080/
[00:40:10] Posted data.
[00:40:10] Initial: 0000; - Receiving payload (expected size: 86267)
[00:40:29] - Downloaded at ~4 kB/s
[00:40:29] - Averaged speed for that direction ~3 kB/s
[00:40:29] + Received work.
[00:40:29] Trying to send all finished work units
[00:40:29] + No unsent completed units remaining.
[00:40:29] + Closed connections
[00:40:34]
[00:40:34] + Processing work unit
[00:40:34] Core required: FahCore_11.exe
[00:40:34] Core found.
[00:40:34] Working on queue slot 09 [May 6 00:40:34 UTC]
[00:40:34] + Working ...
[00:40:34] - Calling '.\FahCore_11.exe -dir work/ -suffix 09 -priority 96 -checkpoint 30 -service -verbose -lifeline 420 -version 623'
[00:40:35]
[00:40:35] *------------------------------*
[00:40:35] Folding@Home GPU Core - Beta
[00:40:35] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[00:40:35]
[00:40:35] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:40:35] Build host: amoeba
[00:40:35] Board Type: AMD
[00:40:35] Core :
[00:40:35] Preparing to commence simulation
[00:40:35] - Looking at optimizations...
[00:40:35] - Created dyn
[00:40:35] - Files status OK
[00:40:35] - Expanded 85755 -> 444252 (decompressed 518.0 percent)
[00:40:35] Called DecompressByteArray: compressed_data_size=85755 data_size=444252, decompressed_data_size=444252 diff=0
[00:40:35] - Digital signature verified
[00:40:35]
[00:40:35] Project: 4751 (Run 4, Clone 367, Gen 27)
[00:40:35]
[00:40:35] Assembly optimizations on if available.
[00:40:35] Entering M.D.
[00:40:41] Tpr hash work/wudata_09.tpr: 2177645689 1032610330 3415775883 2304359576 1001613337
[00:40:41] Working on 1254 p4751_lam5w_300K_g91
[00:40:42] Client config found, loading data.
[00:40:42] Starting GUI Server
[00:40:53] mdrun_gpu returned
[00:40:53] Nonzero force sum on GPU
[00:40:53]
[00:40:53] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:40:55] CoreStatus = 7A (122)
[00:40:55] Sending work to server
[00:40:55] Project: 4751 (Run 4, Clone 367, Gen 27)
[00:40:55] - Read packet limit of 540015616... Set to 524286976.
[00:40:55] - Error: Could not get length of results file work/wuresults_09.dat
[00:40:55] - Error: Could not read unit 09 file. Removing from queue.
[00:40:55] EUE limit exceeded. Pausing 24 hours.
Folding@Home user since Feb 2009
Leoslocks
Posts: 120 Joined: Fri Jan 25, 2008 3:20 am
Hardware configuration: Q6600 | P35-DQ6 | Crucial 2 x 1 GB ram | VisionTek 3870 GPU2 Version 6.20| CPU three 6.20 Clients
Post
by Leoslocks » Wed May 06, 2009 3:34 am
Same result here. 146 WU completed without a hitch and then this one.
[17:14:03] + Number of Units Completed: 146
[17:14:09] Project: 4751 (Run 4, Clone 367, Gen 27)
[17:14:09]
[17:14:09] Assembly optimizations on if available.
[17:14:09] Entering M.D.
[17:14:15] Tpr hash work/wudata_06.tpr: 2177645689 1032610330 3415775883 2304359576 1001613337
[17:14:15] Working on 1254 p4751_lam5w_300K_g91
[17:14:16] Client config found, loading data.
[17:14:16] Starting GUI Server
[17:14:21] mdrun_gpu returned
[17:14:21] Nonzero force sum on GPU
[17:14:21]
[17:14:21] Folding@home Core Shutdown: UNSTABLE_MACHINE
[17:14:25] CoreStatus = 7A (122)
[17:14:25] Sending work to server
[17:14:25] Project: 4751 (Run 4, Clone 367, Gen 27)
[17:14:25] - Read packet limit of 540015616... Set to 524286976.
[17:14:25] - Error: Could not get length of results file work/wuresults_06.dat
[17:14:25] - Error: Could not read unit 06 file. Removing from queue.
[17:14:25] - Preparing to get new work unit...
[17:14:25] + Attempting to get work packet
[17:14:25] - Connecting to assignment server
[17:14:25] - Successful: assigned to (171.64.65.103).
[17:14:25] + News From Folding@Home: GPU folding beta
[17:14:26] Loaded queue successfully.
[17:14:27] + Closed connections
[17:14:32]
[17:14:32] + Processing work unit
[17:14:32] Core required: FahCore_11.exe
[17:14:32] Core found.
[17:14:32] Working on queue slot 07 [May 5 17:14:32 UTC]
[17:14:32] + Working ...
[17:14:32]
[17:14:32] *------------------------------*
[17:14:32] Folding@Home GPU Core - Beta
[17:14:32] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[17:14:32]
[17:14:32] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[17:14:32] Build host: amoeba
[17:14:32] Board Type: AMD
[17:14:32] Core :
[17:14:32] Preparing to commence simulation
[17:14:32] - Looking at optimizations...
[17:14:32] - Created dyn
[17:14:32] - Files status OK
[17:14:32] - Expanded 85755 -> 444252 (decompressed 518.0 percent)
[17:14:32] Called DecompressByteArray: compressed_data_size=85755 data_size=444252, decompressed_data_size=444252 diff=0
[17:14:32] - Digital signature verified
[17:14:32]
[17:14:32] Project: 4751 (Run 4, Clone 367, Gen 27)
[17:14:32]
[17:14:32] Assembly optimizations on if available.
[17:14:32] Entering M.D.
[17:14:38] Tpr hash work/wudata_07.tpr: 2177645689 1032610330 3415775883 2304359576 1001613337
[17:14:38] Working on 1254 p4751_lam5w_300K_g91
[17:14:39] Client config found, loading data.
[17:14:39] Starting GUI Server
[17:14:44] mdrun_gpu returned
[17:14:44] Nonzero force sum on GPU
[17:14:44]
[17:14:44] Folding@home Core Shutdown: UNSTABLE_MACHINE
[17:14:48] CoreStatus = 7A (122)
[17:14:48] Sending work to server
[17:14:48] Project: 4751 (Run 4, Clone 367, Gen 27)
[17:14:48] - Read packet limit of 540015616... Set to 524286976.
[17:14:48] - Error: Could not get length of results file work/wuresults_07.dat
[17:14:48] - Error: Could not read unit 07 file. Removing from queue.
[17:14:48] - Preparing to get new work unit...
[17:14:48] + Attempting to get work packet
[17:14:48] - Connecting to assignment server
[17:14:48] - Successful: assigned to (171.64.65.103).
[17:14:48] + News From Folding@Home: GPU folding beta
[17:14:49] Loaded queue successfully.
[17:14:50] + Closed connections
[17:14:55]
[17:14:55] + Processing work unit
[17:14:55] Core required: FahCore_11.exe
[17:14:55] Core found.
[17:14:55] Working on queue slot 08 [May 5 17:14:55 UTC]
[17:14:55] + Working ...
[17:14:55]
[17:14:55] *------------------------------*
[17:14:55] Folding@Home GPU Core - Beta
[17:14:55] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[17:14:55]
[17:14:55] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[17:14:55] Build host: amoeba
[17:14:55] Board Type: AMD
[17:14:55] Core :
[17:14:55] Preparing to commence simulation
[17:14:55] - Looking at optimizations...
[17:14:55] - Created dyn
[17:14:55] - Files status OK
[17:14:55] - Expanded 85755 -> 444252 (decompressed 518.0 percent)
[17:14:55] Called DecompressByteArray: compressed_data_size=85755 data_size=444252, decompressed_data_size=444252 diff=0
[17:14:55] - Digital signature verified
[17:14:55]
[17:14:55] Project: 4751 (Run 4, Clone 367, Gen 27)
[17:14:55]
[17:14:55] Assembly optimizations on if available.
[17:14:55] Entering M.D.
[17:15:01] Tpr hash work/wudata_08.tpr: 2177645689 1032610330 3415775883 2304359576 1001613337
[17:15:01] Working on 1254 p4751_lam5w_300K_g91
[17:15:02] Client config found, loading data.
[17:15:02] Starting GUI Server
[17:15:07] mdrun_gpu returned
[17:15:07] Nonzero force sum on GPU
[17:15:07]
[17:15:07] Folding@home Core Shutdown: UNSTABLE_MACHINE
[17:15:11] CoreStatus = 7A (122)
[17:15:11] Sending work to server
[17:15:11] Project: 4751 (Run 4, Clone 367, Gen 27)
[17:15:11] - Read packet limit of 540015616... Set to 524286976.
[17:15:11] - Error: Could not get length of results file work/wuresults_08.dat
[17:15:11] - Error: Could not read unit 08 file. Removing from queue.
[17:15:11] - Preparing to get new work unit...
[17:15:11] + Attempting to get work packet
[17:15:11] - Connecting to assignment server
[17:15:11] - Successful: assigned to (171.64.65.103).
[17:15:11] + News From Folding@Home: GPU folding beta
[17:15:11] Loaded queue successfully.
[17:15:12] + Closed connections
[17:15:17]
[17:15:17] + Processing work unit
[17:15:17] Core required: FahCore_11.exe
[17:15:17] Core found.
[17:15:17] Working on queue slot 09 [May 5 17:15:17 UTC]
[17:15:17] + Working ...
[17:15:17]
[17:15:17] *------------------------------*
[17:15:17] Folding@Home GPU Core - Beta
[17:15:17] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[17:15:17]
[17:15:17] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[17:15:17] Build host: amoeba
[17:15:17] Board Type: AMD
[17:15:17] Core :
[17:15:17] Preparing to commence simulation
[17:15:17] - Looking at optimizations...
[17:15:17] - Created dyn
[17:15:17] - Files status OK
[17:15:17] - Expanded 85755 -> 444252 (decompressed 518.0 percent)
[17:15:17] Called DecompressByteArray: compressed_data_size=85755 data_size=444252, decompressed_data_size=444252 diff=0
[17:15:17] - Digital signature verified
[17:15:17]
[17:15:17] Project: 4751 (Run 4, Clone 367, Gen 27)
[17:15:17]
[17:15:17] Assembly optimizations on if available.
[17:15:17] Entering M.D.
[17:15:23] Tpr hash work/wudata_09.tpr: 2177645689 1032610330 3415775883 2304359576 1001613337
[17:15:24] Working on 1254 p4751_lam5w_300K_g91
[17:15:24] Client config found, loading data.
[17:15:24] Starting GUI Server
[17:15:30] mdrun_gpu returned
[17:15:30] Nonzero force sum on GPU
[17:15:30]
[17:15:30] Folding@home Core Shutdown: UNSTABLE_MACHINE
[17:15:34] CoreStatus = 7A (122)
[17:15:34] Sending work to server
[17:15:34] Project: 4751 (Run 4, Clone 367, Gen 27)
[17:15:34] - Read packet limit of 540015616... Set to 524286976.
[17:15:34] - Error: Could not get length of results file work/wuresults_09.dat
[17:15:34] - Error: Could not read unit 09 file. Removing from queue.
[17:15:34] - Preparing to get new work unit...
[17:15:34] + Attempting to get work packet
[17:15:34] - Connecting to assignment server
[17:15:34] - Successful: assigned to (171.64.65.103).
[17:15:34] + News From Folding@Home: GPU folding beta
[17:15:34] Loaded queue successfully.
[17:15:35] + Closed connections
[17:15:40]
[17:15:40] + Processing work unit
[17:15:40] Core required: FahCore_11.exe
[17:15:40] Core found.
[17:15:40] Working on queue slot 00 [May 5 17:15:40 UTC]
[17:15:40] + Working ...
[17:15:40]
[17:15:40] *------------------------------*
[17:15:40] Folding@Home GPU Core - Beta
[17:15:40] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[17:15:40]
[17:15:40] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[17:15:40] Build host: amoeba
[17:15:40] Board Type: AMD
[17:15:40] Core :
[17:15:40] Preparing to commence simulation
[17:15:40] - Looking at optimizations...
[17:15:40] - Created dyn
[17:15:40] - Files status OK
[17:15:40] - Expanded 85755 -> 444252 (decompressed 518.0 percent)
[17:15:40] Called DecompressByteArray: compressed_data_size=85755 data_size=444252, decompressed_data_size=444252 diff=0
[17:15:40] - Digital signature verified
[17:15:40]
[17:15:40] Project: 4751 (Run 4, Clone 367, Gen 27)
[17:15:40]
[17:15:40] Assembly optimizations on if available.
[17:15:40] Entering M.D.
[17:15:46] Tpr hash work/wudata_00.tpr: 2177645689 1032610330 3415775883 2304359576 1001613337
[17:15:47] Working on 1254 p4751_lam5w_300K_g91
[17:15:47] Client config found, loading data.
[17:15:48] Starting GUI Server
[17:15:53] mdrun_gpu returned
[17:15:53] Nonzero force sum on GPU
[17:15:53]
[17:15:53] Folding@home Core Shutdown: UNSTABLE_MACHINE
[17:15:57] CoreStatus = 7A (122)
[17:15:57] Sending work to server
[17:15:57] Project: 4751 (Run 4, Clone 367, Gen 27)
[17:15:57] - Read packet limit of 540015616... Set to 524286976.
[17:15:57] - Error: Could not get length of results file work/wuresults_00.dat
[17:15:57] - Error: Could not read unit 00 file. Removing from queue.
[17:15:57] EUE limit exceeded. Pausing 24 hours.
Folding@Home Client Shutdown.
the animal
Posts: 41 Joined: Mon Feb 25, 2008 5:04 pm
Post
by the animal » Wed May 06, 2009 6:02 am
I got instant NANs with this WU.
Posts: 20824 Joined: Thu Nov 29, 2007 10:13 pm
Post
by bruce » Wed May 06, 2009 6:24 am
Several other people have had the same experience. I've reported it as a bad WU.
Freddy_Frog
Posts: 9 Joined: Sat Aug 09, 2008 11:48 am
Post
by Freddy_Frog » Fri May 08, 2009 12:18 pm
I just had this one with the same result on a single stock speed 4870
[11:09:58] Completed 97%
[11:12:28] Completed 98%
[11:14:58] Completed 99%
[11:17:29] Completed 100%
[11:17:29] Successful run
[11:17:29] DynamicWrapper: Finished Work Unit: sleep=10000
[11:17:39] Reserved 200296 bytes for xtc file; Cosm status=0
[11:17:39] Allocated 200296 bytes for xtc file
[11:17:39] - Reading up to 200296 from "work/wudata_09.xtc": Read 200296
[11:17:39] Read 200296 bytes from xtc file; available packet space=786230168
[11:17:39] xtc file hash check passed.
[11:17:39] Reserved 30216 30216 786230168 bytes for arc file=<work/wudata_09.trr> Cosm status=0
[11:17:39] Allocated 30216 bytes for arc file
[11:17:39] - Reading up to 30216 from "work/wudata_09.trr": Read 30216
[11:17:39] Read 30216 bytes from arc file; available packet space=786199952
[11:17:39] trr file hash check passed.
[11:17:39] Allocated 560 bytes for edr file
[11:17:39] Read bedfile
[11:17:39] edr file hash check passed.
[11:17:39] Allocated 39125 bytes for logfile
[11:17:39] Read logfile
[11:17:39] GuardedRun: success in DynamicWrapper
[11:17:39] GuardedRun: done
[11:17:39] Run: GuardedRun completed.
[11:17:41] - Writing 270709 bytes of core data to disk...
[11:17:41] Done: 270197 -> 239550 (compressed to 88.6 percent)
[11:17:41] ... Done.
[11:17:42] - Shutting down core
[11:17:42]
[11:17:42] Folding@home Core Shutdown: FINISHED_UNIT
[11:17:45] CoreStatus = 64 (100)
[11:17:45] Unit 9 finished with 92 percent of time to deadline remaining.
[11:17:45] Updated performance fraction: 0.931532
[11:17:45] Sending work to server
[11:17:45] Project: 4752 (Run 0, Clone 485, Gen 6)
[11:17:45] - Read packet limit of 540015616... Set to 524286976.
[11:17:45] + Attempting to send results [May 8 11:17:45 UTC]
[11:17:45] - Reading file work/wuresults_09.dat from core
[11:17:45] (Read 240062 bytes from disk)
[11:17:45] Connecting to http://171.64.65.103:8080/
[11:17:48] Posted data.
[11:17:48] Initial: 0000; - Uploaded at ~58 kB/s
[11:17:49] - Averaged speed for that direction ~57 kB/s
[11:17:49] + Results successfully sent
[11:17:49] Thank you for your contribution to Folding@Home.
[11:17:49] + Number of Units Completed: 178
[11:17:53] Trying to send all finished work units
[11:17:53] + No unsent completed units remaining.
[11:17:53] - Preparing to get new work unit...
[11:17:53] + Attempting to get work packet
[11:17:53] - Will indicate memory of 4093 MB
[11:17:53] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 11
[11:17:53] - Connecting to assignment server
[11:17:53] Connecting to http://assign-GPU.stanford.edu:8080/
[11:17:54] Posted data.
[11:17:54] Initial: 40AB; - Successful: assigned to (171.64.65.103).
[11:17:54] + News From Folding@Home: GPU folding beta
[11:17:54] Loaded queue successfully.
[11:17:54] Connecting to http://171.64.65.103:8080/
[11:17:55] Posted data.
[11:17:55] Initial: 0000; + Could not connect to Work Server
[11:17:55] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[11:18:04] + Attempting to get work packet
[11:18:04] - Will indicate memory of 4093 MB
[11:18:04] - Connecting to assignment server
[11:18:04] Connecting to http://assign-GPU.stanford.edu:8080/
[11:18:05] Posted data.
[11:18:05] Initial: 40AB; - Successful: assigned to (171.64.65.103).
[11:18:05] + News From Folding@Home: GPU folding beta
[11:18:05] Loaded queue successfully.
[11:18:05] Connecting to http://171.64.65.103:8080/
[11:18:06] Posted data.
[11:18:06] Initial: 0000; - Receiving payload (expected size: 86267)
[11:18:07] - Downloaded at ~84 kB/s
[11:18:07] - Averaged speed for that direction ~80 kB/s
[11:18:07] + Received work.
[11:18:07] Trying to send all finished work units
[11:18:07] + No unsent completed units remaining.
[11:18:07] + Closed connections
[11:18:07]
[11:18:07] + Processing work unit
[11:18:07] Core required: FahCore_11.exe
[11:18:07] Core found.
[11:18:07] Working on queue slot 00 [May 8 11:18:07 UTC]
[11:18:07] + Working ...
[11:18:07] - Calling '.\FahCore_11.exe -dir work/ -suffix 00 -checkpoint 15 -verbose -lifeline 7544 -version 623'
[11:18:07]
[11:18:07] *------------------------------*
[11:18:07] Folding@Home GPU Core - Beta
[11:18:07] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[11:18:07]
[11:18:07] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:18:07] Build host: amoeba
[11:18:07] Board Type: AMD
[11:18:07] Core :
[11:18:07] Preparing to commence simulation
[11:18:07] - Looking at optimizations...
[11:18:07] - Created dyn
[11:18:07] - Files status OK
[11:18:07] - Expanded 85755 -> 444252 (decompressed 518.0 percent)
[11:18:07] Called DecompressByteArray: compressed_data_size=85755 data_size=444252, decompressed_data_size=444252 diff=0
[11:18:07] - Digital signature verified
[11:18:07]
[11:18:07] Project: 4751 (Run 4, Clone 367, Gen 27)
[11:18:07]
[11:18:07] Assembly optimizations on if available.
[11:18:07] Entering M.D.
[11:18:13] Tpr hash work/wudata_00.tpr: 2177645689 1032610330 3415775883 2304359576 1001613337
[11:18:14] Working on 1254 p4751_lam5w_300K_g91
[11:18:14] Client config found, loading data.
[11:18:14] Starting GUI Server
[11:18:18] mdrun_gpu returned
[11:18:18] Nonzero force sum on GPU
[11:18:18]
[11:18:18] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:18:21] CoreStatus = 7A (122)
[11:18:21] Sending work to server
[11:18:21] Project: 4751 (Run 4, Clone 367, Gen 27)
[11:18:21] - Read packet limit of 540015616... Set to 524286976.
[11:18:21] - Error: Could not get length of results file work/wuresults_00.dat
[11:18:21] - Error: Could not read unit 00 file. Removing from queue.
[11:18:21] Trying to send all finished work units
[11:18:21] + No unsent completed units remaining.
[11:18:21] - Preparing to get new work unit...
[11:18:21] + Attempting to get work packet
[11:18:21] - Will indicate memory of 4093 MB
[11:18:21] - Connecting to assignment server
[11:18:21] Connecting to http://assign-GPU.stanford.edu:8080/
[11:18:22] Posted data.
[11:18:22] Initial: 40AB; - Successful: assigned to (171.64.65.103).
[11:18:22] + News From Folding@Home: GPU folding beta
[11:18:22] Loaded queue successfully.
[11:18:22] Connecting to http://171.64.65.103:8080/
[11:18:23] Posted data.
[11:18:23] Initial: 0000; - Receiving payload (expected size: 86267)
[11:18:24] - Downloaded at ~84 kB/s
[11:18:24] - Averaged speed for that direction ~81 kB/s
[11:18:24] + Received work.
[11:18:24] Trying to send all finished work units
[11:18:24] + No unsent completed units remaining.
[11:18:24] + Closed connections
[11:18:29]
[11:18:29] + Processing work unit
[11:18:29] Core required: FahCore_11.exe
[11:18:29] Core found.
[11:18:29] Working on queue slot 01 [May 8 11:18:29 UTC]
[11:18:29] + Working ...
[11:18:29] - Calling '.\FahCore_11.exe -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 7544 -version 623'
[11:18:29]
[11:18:29] *------------------------------*
[11:18:29] Folding@Home GPU Core - Beta
[11:18:29] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[11:18:29]
[11:18:29] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:18:29] Build host: amoeba
[11:18:29] Board Type: AMD
[11:18:29] Core :
[11:18:29] Preparing to commence simulation
[11:18:29] - Looking at optimizations...
[11:18:29] - Created dyn
[11:18:29] - Files status OK
[11:18:29] - Expanded 85755 -> 444252 (decompressed 518.0 percent)
[11:18:29] Called DecompressByteArray: compressed_data_size=85755 data_size=444252, decompressed_data_size=444252 diff=0
[11:18:29] - Digital signature verified
[11:18:29]
[11:18:29] Project: 4751 (Run 4, Clone 367, Gen 27)
[11:18:29]
[11:18:29] Assembly optimizations on if available.
[11:18:29] Entering M.D.
[11:18:35] Tpr hash work/wudata_01.tpr: 2177645689 1032610330 3415775883 2304359576 1001613337
[11:18:36] Working on 1254 p4751_lam5w_300K_g91
[11:18:36] Client config found, loading data.
[11:18:36] Starting GUI Server
[11:18:40] mdrun_gpu returned
[11:18:40] Nonzero force sum on GPU
[11:18:40]
[11:18:40] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:18:44] CoreStatus = 7A (122)
[11:18:44] Sending work to server
[11:18:44] Project: 4751 (Run 4, Clone 367, Gen 27)
[11:18:44] - Read packet limit of 540015616... Set to 524286976.
[11:18:44] - Error: Could not get length of results file work/wuresults_01.dat
[11:18:44] - Error: Could not read unit 01 file. Removing from queue.
[11:18:44] Trying to send all finished work units
[11:18:44] + No unsent completed units remaining.
[11:18:44] - Preparing to get new work unit...
[11:18:44] + Attempting to get work packet
[11:18:44] - Will indicate memory of 4093 MB
[11:18:44] - Connecting to assignment server
[11:18:44] Connecting to http://assign-GPU.stanford.edu:8080/
[11:18:44] Posted data.
[11:18:44] Initial: 40AB; - Successful: assigned to (171.64.65.103).
[11:18:44] + News From Folding@Home: GPU folding beta
[11:18:45] Loaded queue successfully.
[11:18:45] Connecting to http://171.64.65.103:8080/
[11:18:45] Posted data.
[11:18:45] Initial: 0000; - Receiving payload (expected size: 86267)
[11:18:47] - Downloaded at ~42 kB/s
[11:18:47] - Averaged speed for that direction ~73 kB/s
[11:18:47] + Received work.
[11:18:47] Trying to send all finished work units
[11:18:47] + No unsent completed units remaining.
[11:18:47] + Closed connections
[11:18:52]
[11:18:52] + Processing work unit
[11:18:52] Core required: FahCore_11.exe
[11:18:52] Core found.
[11:18:52] Working on queue slot 02 [May 8 11:18:52 UTC]
[11:18:52] + Working ...
[11:18:52] - Calling '.\FahCore_11.exe -dir work/ -suffix 02 -checkpoint 15 -verbose -lifeline 7544 -version 623'
[11:18:52]
[11:18:52] *------------------------------*
[11:18:52] Folding@Home GPU Core - Beta
[11:18:52] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[11:18:52]
[11:18:52] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:18:52] Build host: amoeba
[11:18:52] Board Type: AMD
[11:18:52] Core :
[11:18:52] Preparing to commence simulation
[11:18:52] - Looking at optimizations...
[11:18:52] - Created dyn
[11:18:52] - Files status OK
[11:18:52] - Expanded 85755 -> 444252 (decompressed 518.0 percent)
[11:18:52] Called DecompressByteArray: compressed_data_size=85755 data_size=444252, decompressed_data_size=444252 diff=0
[11:18:52] - Digital signature verified
[11:18:52]
[11:18:52] Project: 4751 (Run 4, Clone 367, Gen 27)
[11:18:52]
[11:18:52] Assembly optimizations on if available.
[11:18:52] Entering M.D.
[11:18:58] Tpr hash work/wudata_02.tpr: 2177645689 1032610330 3415775883 2304359576 1001613337
[11:18:58] Working on 1254 p4751_lam5w_300K_g91
[11:18:58] Client config found, loading data.
[11:18:58] Starting GUI Server
[11:19:02] mdrun_gpu returned
[11:19:02] Nonzero force sum on GPU
[11:19:02]
[11:19:02] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:19:06] CoreStatus = 7A (122)
[11:19:06] Sending work to server
[11:19:06] Project: 4751 (Run 4, Clone 367, Gen 27)
[11:19:06] - Read packet limit of 540015616... Set to 524286976.
[11:19:06] - Error: Could not get length of results file work/wuresults_02.dat
[11:19:06] - Error: Could not read unit 02 file. Removing from queue.
[11:19:06] Trying to send all finished work units
[11:19:06] + No unsent completed units remaining.
[11:19:06] - Preparing to get new work unit...
[11:19:06] + Attempting to get work packet
[11:19:06] - Will indicate memory of 4093 MB
[11:19:06] - Connecting to assignment server
[11:19:06] Connecting to http://assign-GPU.stanford.edu:8080/
[11:19:07] Posted data.
[11:19:07] Initial: 40AB; - Successful: assigned to (171.64.65.103).
[11:19:07] + News From Folding@Home: GPU folding beta
[11:19:07] Loaded queue successfully.
[11:19:07] Connecting to http://171.64.65.103:8080/
[11:19:08] Posted data.
[11:19:08] Initial: 0000; - Receiving payload (expected size: 86267)
[11:19:09] - Downloaded at ~84 kB/s
[11:19:09] - Averaged speed for that direction ~75 kB/s
[11:19:09] + Received work.
[11:19:09] Trying to send all finished work units
[11:19:09] + No unsent completed units remaining.
[11:19:09] + Closed connections
[11:19:14]
[11:19:14] + Processing work unit
[11:19:14] Core required: FahCore_11.exe
[11:19:14] Core found.
[11:19:14] Working on queue slot 03 [May 8 11:19:14 UTC]
[11:19:14] + Working ...
[11:19:14] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -checkpoint 15 -verbose -lifeline 7544 -version 623'
[11:19:14]
[11:19:14] *------------------------------*
[11:19:14] Folding@Home GPU Core - Beta
[11:19:14] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[11:19:14]
[11:19:14] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:19:14] Build host: amoeba
[11:19:14] Board Type: AMD
[11:19:14] Core :
[11:19:14] Preparing to commence simulation
[11:19:14] - Looking at optimizations...
[11:19:14] - Created dyn
[11:19:14] - Files status OK
[11:19:14] - Expanded 85755 -> 444252 (decompressed 518.0 percent)
[11:19:14] Called DecompressByteArray: compressed_data_size=85755 data_size=444252, decompressed_data_size=444252 diff=0
[11:19:14] - Digital signature verified
[11:19:14]
[11:19:14] Project: 4751 (Run 4, Clone 367, Gen 27)
[11:19:14]
[11:19:14] Assembly optimizations on if available.
[11:19:14] Entering M.D.
[11:19:20] Tpr hash work/wudata_03.tpr: 2177645689 1032610330 3415775883 2304359576 1001613337
[11:19:21] Working on 1254 p4751_lam5w_300K_g91
[11:19:21] Client config found, loading data.
[11:19:21] Starting GUI Server
[11:19:25] mdrun_gpu returned
[11:19:25] Nonzero force sum on GPU
[11:19:25]
[11:19:25] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:19:28] CoreStatus = 7A (122)
[11:19:28] Sending work to server
[11:19:28] Project: 4751 (Run 4, Clone 367, Gen 27)
[11:19:28] - Read packet limit of 540015616... Set to 524286976.
[11:19:28] - Error: Could not get length of results file work/wuresults_03.dat
[11:19:28] - Error: Could not read unit 03 file. Removing from queue.
[11:19:28] Trying to send all finished work units
[11:19:28] + No unsent completed units remaining.
[11:19:28] - Preparing to get new work unit...
[11:19:28] + Attempting to get work packet
[11:19:28] - Will indicate memory of 4093 MB
[11:19:28] - Connecting to assignment server
[11:19:28] Connecting to http://assign-GPU.stanford.edu:8080/
[11:19:29] Posted data.
[11:19:29] Initial: 40AB; - Successful: assigned to (171.64.65.103).
[11:19:29] + News From Folding@Home: GPU folding beta
[11:19:29] Loaded queue successfully.
[11:19:29] Connecting to http://171.64.65.103:8080/
[11:19:30] Posted data.
[11:19:30] Initial: 0000; - Receiving payload (expected size: 86267)
[11:19:31] - Downloaded at ~84 kB/s
[11:19:31] - Averaged speed for that direction ~77 kB/s
[11:19:31] + Received work.
[11:19:31] Trying to send all finished work units
[11:19:31] + No unsent completed units remaining.
[11:19:31] + Closed connections
[11:19:36]
[11:19:36] + Processing work unit
[11:19:36] Core required: FahCore_11.exe
[11:19:36] Core found.
[11:19:36] Working on queue slot 04 [May 8 11:19:36 UTC]
[11:19:36] + Working ...
[11:19:36] - Calling '.\FahCore_11.exe -dir work/ -suffix 04 -checkpoint 15 -verbose -lifeline 7544 -version 623'
[11:19:36]
[11:19:36] *------------------------------*
[11:19:36] Folding@Home GPU Core - Beta
[11:19:36] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[11:19:36]
[11:19:36] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:19:36] Build host: amoeba
[11:19:36] Board Type: AMD
[11:19:36] Core :
[11:19:36] Preparing to commence simulation
[11:19:36] - Looking at optimizations...
[11:19:36] - Created dyn
[11:19:36] - Files status OK
[11:19:36] - Expanded 85755 -> 444252 (decompressed 518.0 percent)
[11:19:36] Called DecompressByteArray: compressed_data_size=85755 data_size=444252, decompressed_data_size=444252 diff=0
[11:19:36] - Digital signature verified
[11:19:36]
[11:19:36] Project: 4751 (Run 4, Clone 367, Gen 27)
[11:19:36]
[11:19:36] Assembly optimizations on if available.
[11:19:36] Entering M.D.
[11:19:42] Tpr hash work/wudata_04.tpr: 2177645689 1032610330 3415775883 2304359576 1001613337
[11:19:43] Working on 1254 p4751_lam5w_300K_g91
[11:19:43] Client config found, loading data.
[11:19:43] Starting GUI Server
[11:19:47] mdrun_gpu returned
[11:19:47] Nonzero force sum on GPU
[11:19:47]
[11:19:47] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:19:50] CoreStatus = 7A (122)
[11:19:50] Sending work to server
[11:19:50] Project: 4751 (Run 4, Clone 367, Gen 27)
[11:19:50] - Read packet limit of 540015616... Set to 524286976.
[11:19:50] - Error: Could not get length of results file work/wuresults_04.dat
[11:19:50] - Error: Could not read unit 04 file. Removing from queue.
[11:19:50] EUE limit exceeded. Pausing 24 hours.
[11:51:08] ***** Got a SIGTERM signal (2)
[11:51:08] Killing all core threads
--- Opening Log file [May 8 11:55:51 UTC]
http://folding.stanford.edu
Launch directory: C:\Tools(x86)\FAH GPU
Executable: C:\Tools(x86)\FAH GPU\FAHGPU.exe
Arguments: -verbosity 9
[11:55:51] - Ask before connecting: No
[11:55:51] - User name: Freddy_Frog (Team 31707)
[11:55:51] - Machine ID: 2
[11:55:51]
[11:55:52] Loaded queue successfully.
[11:55:52] - Preparing to get new work unit...
[11:55:52] - Autosending finished units... [May 8 11:55:52 UTC]
[11:55:52] Trying to send all finished work units
[11:55:52] + No unsent completed units remaining.
[11:55:52] - Autosend completed
[11:55:52] + Attempting to get work packet
[11:55:52] - Will indicate memory of 4093 MB
[11:55:52] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 11
[11:55:52] - Connecting to assignment server
[11:55:52] Connecting to http://assign-GPU.stanford.edu:8080/
[11:55:53] Posted data.
[11:55:53] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[11:55:53] + News From Folding@Home: GPU folding beta
[11:55:53] Loaded queue successfully.
[11:55:53] Connecting to http://171.64.65.102:8080/
[11:55:54] Posted data.
[11:55:54] Initial: 0000; - Receiving payload (expected size: 69165)
[11:55:55] - Downloaded at ~67 kB/s
[11:55:55] - Averaged speed for that direction ~75 kB/s
[11:55:55] + Received work.
[11:55:55] + Closed connections
[11:55:55]
[11:55:55] + Processing work unit
[11:55:55] Core required: FahCore_11.exe
[11:55:55] Core found.
[11:55:55] Working on queue slot 05 [May 8 11:55:55 UTC]
[11:55:55] + Working ...
[11:55:55] - Calling '.\FahCore_11.exe -dir work/ -suffix 05 -checkpoint 15 -verbose -lifeline 2772 -version 623'
[11:55:57]
[11:55:57] *------------------------------*
[11:55:57] Folding@Home GPU Core - Beta
[11:55:57] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[11:55:57]
[11:55:57] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:55:57] Build host: amoeba
[11:55:57] Board Type: AMD
[11:55:57] Core :
[11:55:57] Preparing to commence simulation
[11:55:57] - Looking at optimizations...
[11:55:58] - Created dyn
[11:55:58] - Files status OK
[11:55:58] - Expanded 68653 -> 357580 (decompressed 520.8 percent)
[11:55:58] Called DecompressByteArray: compressed_data_size=68653 data_size=357580, decompressed_data_size=357580 diff=0
[11:55:58] - Digital signature verified
[11:55:58]
[11:55:58] Project: 5745 (Run 2, Clone 69, Gen 183)
[11:55:58]
[11:55:58] Assembly optimizations on if available.
[11:55:58] Entering M.D.
[11:56:04] Tpr hash work/wudata_05.tpr: 4133447060 1439088481 2854150942 2365735834 3732791512
[11:56:04] Working on Protein
[11:56:04] Client config found, loading data.
[11:56:04] Starting GUI Server
[11:57:54] Completed 1%
[11:59:42] Completed 2%
[12:01:30] Completed 3%
[12:03:19] Completed 4%
Leoslocks
Post
by Leoslocks » Fri May 08, 2009 1:07 pm
It takes a little while to purge this WU from the system after it is reported as bad.
Fold On.
bapriebe
Posts: 44 Joined: Sun Apr 20, 2008 8:33 am
Hardware configuration: HP xw4600 workstation (4GB)+Q9650+Sapphire Vapor-X HD4890, HP Z600 workstation (4GB)+2xXEON E5540+Sapphire HD5770, HP ML350 server (4GB)+2xXEON E5520+Diamond HD3850
Post
by bapriebe » Wed May 20, 2009 8:10 pm
Leoslocks wrote: It takes a little while to purge this WU from the system after it is reported as bad.
Would it be expected that this one is still kicking around after 12 days? I just got the "Nonzero force sum on GPU" and it's shut down my newly-installed 4850. Every time I restart the GPU client this WU comes back and shuts it right back down again for 24 hours. It was dispatched from
VijayPande
Pande Group Member
Posts: 2058 Joined: Fri Nov 30, 2007 6:25 am
Post
by VijayPande » Thu May 21, 2009 5:21 pm
Thanks for the heads up. This is handled automatically via a script, daily at 8am pacific time. However, we found an issue with crontab (the part of unix that does things in an automated fashion) that lead to this script not running. It was run yesterday manually and crontab was fixed. It did successfully run automatically this morning, which suggests it should be fixed.
Prof. Vijay Pande, PhD
Chair, Biophysics
Stanford University
